    4. Apple Homekit Siri
    Apple Homekit Siri
      pix last edited by
      @versteckt:
      Du hast 'nen Punkt zuviel, das Modul heisst hap-nodejs `
      Danke, blöder Fehler. Copy & Paste wär besser gewesen. :lol:
      Installation davon hat geklappt
      MacMini-Ethernet:~ pix$ cd /tmp
      MacMini-Ethernet:tmp pix$ npm cache clean
      MacMini-Ethernet:tmp pix$ npm install hap-nodejs
      curve25519@1.1.0 install /private/tmp/node_modules/hap-nodejs/node_modules/curve25519
      node-gyp rebuild
      ! CXX(target) Release/obj.target/curve/node_curve.o
      SOLINK_MODULE(target) Release/curve.node
      ! > ed25519@0.0.3 install /private/tmp/node_modules/hap-nodejs/node_modules/ed25519
      node-gyp rebuild
      ! CC(target) Release/obj.target/ed25519/src/ed25519/keypair.o
      CC(target) Release/obj.target/ed25519/src/ed25519/sign.o
      CC(target) Release/obj.target/ed25519/src/ed25519/open.o
      CC(target) Release/obj.target/ed25519/src/ed25519/crypto_verify_32.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_double_scalarmult.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_frombytes.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_scalarmult_base.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_precomp_0.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_p2_0.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_p2_dbl.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_0.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_dbl.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_to_p2.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_to_cached.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_tobytes.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_madd.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_add.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_msub.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_sub.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_p1p1_to_p3.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_p1p1_to_p2.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_tobytes.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_0.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_1.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_cmov.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_copy.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_neg.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_add.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_sub.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_mul.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_sq.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_sq2.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_invert.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_tobytes.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_isnegative.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_isnonzero.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_frombytes.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_pow22523.o
      CC(target) Release/obj.target/ed25519/src/ed25519/sc_reduce.o
      CC(target) Release/obj.target/ed25519/src/ed25519/sc_muladd.o
      CXX(target) Release/obj.target/ed25519/src/ed25519.o
      SOLINK_MODULE(target) Release/ed25519.node
      ! > mdns@2.2.11 install /private/tmp/node_modules/hap-nodejs/node_modules/mdns
      node-gyp rebuild
      ! CXX(target) Release/obj.target/dns_sd_bindings/src/dns_sd.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_browse.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_enumerate_domains.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_get_addr_info.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_process_result.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_ref.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_ref_deallocate.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_ref_sock_fd.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_register.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_resolve.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/mdns_utils.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/network_interface.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/socket_watcher.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_ref.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_create.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_deallocate.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_set_value.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_get_length.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_buffer_to_object.o
      SOLINK_MODULE(target) Release/dns_sd_bindings.node
      ! > bignum@0.11.0 install /private/tmp/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum
      node-gyp configure build
      ! CXX(target) Release/obj.target/bignum/bignum.o
      SOLINK_MODULE(target) Release/bignum.node
      hap-nodejs@0.0.7 node_modules/hap-nodejs
      ├── debug@2.2.0 (ms@0.7.1)
      ├── node-persist@0.0.6 (q@1.1.2, mkdirp@0.3.5)
      ├── curve25519@1.1.0 (bindings@1.2.1, nan@2.1.0)
      ├── ed25519@0.0.3 (bindings@1.2.1, nan@2.1.0)
      ├── mdns@2.2.11 (bindings@1.2.1, nan@2.1.0)
      └── srp@0.2.0 (bignum@0.11.0)
      Danach den Adapter wieder gelöscht und neu installiert. Danach die Instanz wieder gestartet und wieder Fehler:
      2015-12-14 00:18:55.400  - info: host.MacMini-Ethernet.fritz.box object change system.adapter.homekit.0
      2015-12-14 00:18:55.413  - info: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 started with pid 32913
      2015-12-14 00:18:56.043  - error: uncaught exception: Module version mismatch. Expected 46, got 47.
      2015-12-14 00:18:56.058  - error: Error: Module version mismatch. Expected 46, got 47.
          at Error (native)
          at Object.Module._extensions..node (module.js:460:18)
          at Module.load (module.js:356:32)
          at Function.Module._load (module.js:311:12)
          at Module.require (module.js:366:17)
          at require (module.js:385:17)
          at Object. <anonymous>(/Users/pix/Documents/iobroker/node_modules/mdns/lib/dns_sd.js:24:20)
          at Module._compile (module.js:435:26)
          at Object.Module._extensions..js (module.js:442:10)
      2015-12-14 00:18:56.128  - debug: homekit.0 objectDB connected
      2015-12-14 00:18:56.137  - debug: homekit.0 statesDB connected
      2015-12-14 00:18:56.345  - info: homekit.0 starting. Version 0.0.7 in /Users/pix/Documents/iobroker/node_modules/iobroker.homekit
      2015-12-14 00:18:56.350  - info: homekit.0 requesting all states
      2015-12-14 00:18:56.351  - info: homekit.0 requesting all objects
      2015-12-14 00:18:56.385  - error: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)</anonymous>
      Laut Installationslog beim Adapterinstallieren müssten jetzt alle module installiert sein
      iobroker.homekit@0.0.7 node_modules/iobroker.homekit
      └── hap-nodejs@0.0.7 (srp@0.2.0, node-persist@0.0.6, curve25519@1.1.0, ed25519@0.0.3)
      Also nochmal im Verzeichnis nachgesehen:
      Mini-Ethernet:iobroker.homekit pix$ pwd
      MacMini-Ethernet:iobroker.homekit pix$ find . -name *.node -ls
      37754159       48 -rwxr-xr-x    1 pix              staff               20932 14 Dez 00:17 ./node_modules/hap-nodejs/node_modules/curve25519/build/Release/curve.node
      37754303      184 -rwxr-xr-x    1 pix              staff               93508 14 Dez 00:17 ./node_modules/hap-nodejs/node_modules/ed25519/build/Release/ed25519.node
      Es sind wieder nur zwei. Sind die vielleicht woanders?
      dns_sd_bindings.node habe ich gar nicht auf der Platte gefunden,
      bignum.node liegt in iobroker/node_modules/bignum/build/Release/bignum.node
      Zum Schluss nochmal hap-nodejs installiert und Instanz aktiviert, aber ohne Erfolg.
      Pix
        Headroom68 last edited by
        @pix:
        Pix</anonymous> `
        Hallo Pix,
        das Paket mdns scheinst Du schon im iobroker/node_modules Verzeichnis zu haben.
        Evtl. Dort löschen und nochmal probieren?
        • V
          versteckt last edited by
          Ja probier mal
          Gesendet von meinem iPhone mit Tapatalk
          5373_alarmanlage.txt
            pix last edited by
            ich habe nun mdns aus dem node_modules Verzeichnis genommen und hap-nodejs und anschließend den Adapter neu installiert. Tatscächlich war schonmal eine Datei mehr im besagten Verzeichnis :lol:
            37774377       48 -rwxr-xr-x    1 pix              staff               20932 14 Dez 11:53 ./node_modules/hap-nodejs/node_modules/curve25519/build/Release/curve.node
            37774523      184 -rwxr-xr-x    1 pix              staff               93508 14 Dez 11:53 ./node_modules/hap-nodejs/node_modules/ed25519/build/Release/ed25519.node
            37774610      208 -rwxr-xr-x    1 pix              staff              104656 14 Dez 11:53 ./node_modules/hap-nodejs/node_modules/mdns/build/Release/dns_sd_bindings.node
            Fehlt aber immer noch eine (./node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/build/Release/bignum.node)
            Also bin ich mit srp genauso vorgegangen. Erstmal aus dem node_modules-Verzeichnis rausgnemommen und nochmal hap-nodejs und anschließend den (vor gelöschten) Adapter neu installiert. Aber es blieb dabei. Nur drei Dateien und srp fehlt vielleicht jetzt in node_modules ???
            Wir sind auf dem richtigen Weg … 😉
            Pix
              @pix:
              Pix `
              unter /opt/iobroker/node_modules sollten nur io-Adapter liegen (zumindest bei mir). Evtl. liegt bei Dir da noch mehr quer ?
              Was kommt denn für eine Fehlermeldung ?
              • V
                Hallo, für mich sieht das auch so aus, als wie wenn da was falsch rumliegt.
                Der node_modules Ordner unter /Users/xxx/ioBroker sollte normalerweise folgenden Inhalt haben:
                (Je nachdem wieviele Adapter du halt installiert hast)
                Christians-Mac-mini:node_modules christian$ pwd
                /Users/christian/DEVELOPMENT/node_modules
                Christians-Mac-mini:node_modules christian$ ls -al
                total 32
                drwxrwxrwx@ 42 christian  staff   1428 Dec 14 18:41 .
                drwxrwxrwx@ 13 christian  staff    442 Dec  7 15:42 ..
                -rwxrwxrwx@  1 christian  staff  14340 Oct 26 15:33 .DS_Store
                drwxrwxrwx@  4 christian  staff    136 Dec  7 15:42 .bin
                drwxrwxrwx   2 christian  staff     68 Sep  5 11:12 etc
                drwxr-xr-x  15 christian  staff    510 Dec 13 08:33 ioBroker.homekit
                drwxrwxrwx@ 10 christian  staff    340 May 21  2015 iobroker
                drwxrwxrwx   3 christian  staff    102 Sep  5 11:13 iobroker-data
                drwxr-xr-x  14 christian  staff    476 Dec  7 15:47 iobroker.admin
                drwxrwxrwx@ 12 christian  staff    408 May 28  2015 iobroker.email
                drwxrwxrwx  11 christian  staff    374 Jul 19 16:06 iobroker.flot
                drwxrwxrwx@ 14 christian  staff    476 Jul 19 16:05 iobroker.history
                drwxrwxrwx@ 11 christian  staff    374 Jun 17 08:56 iobroker.hm-rega
                drwxrwxrwx  13 christian  staff    442 Jul 19 15:48 iobroker.hm-rpc
                drwxrwxrwx  12 christian  staff    408 Sep 27 17:47 iobroker.hmm
                drwxrwxrwx  15 christian  staff    510 Sep  5 11:27 iobroker.ical
                drwxrwxrwx  12 christian  staff    408 Dec 12 15:46 iobroker.icons-addictive-flavour-png
                drwxrwxrwx  11 christian  staff    374 Jul 19 16:55 iobroker.icons-material-png
                drwxrwxrwx  11 christian  staff    374 Dec 11 15:34 iobroker.icons-mfd-png
                drwxrwxrwx  11 christian  staff    374 Sep 15 12:31 iobroker.icons-ultimate-png
                drwxrwxrwx  12 christian  staff    408 Dec 11 15:32 iobroker.javascript
                drwxr-xr-x  21 christian  staff    714 Dec  7 15:43 iobroker.js-controller
                drwxrwxrwx  15 christian  staff    510 Sep  5 11:28 iobroker.node-red
                drwxrwxrwx  14 christian  staff    476 Dec 14 14:21 iobroker.occ
                drwxrwxrwx  11 christian  staff    374 Jul 19 15:01 iobroker.onkyo
                drwxrwxrwx  12 christian  staff    408 Dec 12 15:37 iobroker.pushover
                drwxrwxrwx@ 11 christian  staff    374 Jul 19 16:05 iobroker.rickshaw
                drwxrwxrwx  12 christian  staff    408 Dec 11 15:24 iobroker.scenes
                drwxrwxrwx  13 christian  staff    442 Sep 15 11:44 iobroker.terminal
                drwxrwxrwx  13 christian  staff    442 Dec 11 15:33 iobroker.vis
                drwxrwxrwx  10 christian  staff    340 Dec 12 15:46 iobroker.vis-bars
                drwxrwxrwx  11 christian  staff    374 Dec 11 15:33 iobroker.vis-hqwidgets
                drwxrwxrwx  11 christian  staff    374 Dec 11 15:33 iobroker.vis-metro
                drwxr-xr-x@ 13 christian  staff    442 Oct 16 11:49 iobroker.vis-template
                drwxr-xr-x@ 15 christian  staff    510 Oct 29 19:49 iobroker.vis-web-admin
                drwxrwxrwx  14 christian  staff    476 Jul  4 07:37 iobroker.volksbox
                drwxrwxrwx  13 christian  staff    442 Nov 20 19:06 iobroker.web
                drwxrwxrwx  17 christian  staff    578 Dec  5 18:48 iobroker.zwave
                drwxrwxrwx   2 christian  staff     68 Sep  5 11:13 log
                drwxrwxrwx   6 christian  staff    204 Sep  5 11:20 node_modules
                drwxrwxrwx  25 christian  staff    850 Aug  4 18:06 openzwave-control-panel
                drwxrwxrwx@ 15 christian  staff    510 May 21  2015 sinopia
                  pix last edited by
                  Au verdammt. Ich habe über 400 Objekte in dem Ordner. Da muss ich wohl aufräumen.
                  Vielleicht habe ich Node und npm damals im falschen Ordner installiert [emoji30]
                  Pix
                  Edit: Hier die Dateien im Ordner
                  MacMini-Ethernet:node_modules pix$ ls -al
                  total 32
                  drwxr-xr-x 399 pix staff 13566 14 Dez 12:04 .
                  drwxrwxrwx 10 pix staff 340 15 Dez 11:51 ..
                  -rw-r--r--@ 1 pix staff 14340 14 Dez 12:00 .DS_Store
                  drwxr-xr-x 28 pix staff 952 8 Dez 14:23 .bin
                  drwxr-xr-x 10 pix staff 340 25 Nov 16:50 HAP-NodeJS
                  drwxrwxrwx 10 pix staff 340 20 Nov 02:08 abbrev
                  drwxrwxrwx 7 pix staff 238 8 Dez 14:19 accepts
                  drwxr-xr-x 10 pix staff 340 8 Dez 14:19 adm-zip
                  drwxrwxrwx 9 pix staff 306 8 Dez 14:19 after
                  drwxr-xr-x 6 pix staff 204 8 Dez 14:23 align-text
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 amdefine
                  drwxrwxrwx 6 pix staff 204 18 Nov 17:40 ansi-regex
                  drwxrwxrwx 6 pix staff 204 18 Nov 17:40 ansi-styles
                  drwxr-xr-x 7 pix staff 238 8 Dez 14:23 ap
                  drwxr-xr-x 8 pix staff 272 8 Dez 14:23 argf
                  drwxrwxrwx 9 pix staff 306 20 Nov 02:08 argparse
                  drwxrwxrwx 6 pix staff 204 8 Dez 14:19 array-flatten
                  drwxrwxrwx 8 pix staff 272 8 Dez 14:19 arraybuffer.slice
                  drwxr-xr-x 10 pix staff 340 8 Dez 14:23 asap
                  drwxrwxrwx 9 pix staff 306 20 Nov 02:08 asn1
                  drwxrwxrwx 5 pix staff 170 20 Nov 02:08 assert-plus
                  drwxrwxrwx 8 pix staff 272 20 Nov 02:08 async
                  drwxrwxrwx 10 pix staff 340 20 Nov 02:08 authenticate-pam
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 aws-sign2
                  drwxrwxrwx 10 pix staff 340 25 Nov 16:51 aws4
                  drwxr-xr-x 9 pix staff 306 8 Dez 14:23 babel-runtime
                  drwxr-xr-x 10 pix staff 340 8 Dez 14:19 backo2
                  drwxrwxrwx 14 pix staff 476 20 Nov 02:08 backoff
                  drwxrwxrwx 11 pix staff 374 20 Nov 02:08 balanced-match
                  drwxrwxrwx 12 pix staff 408 8 Dez 14:19 base64-arraybuffer
                  drwxrwxrwx 6 pix staff 204 8 Dez 14:19 base64-url
                  drwxrwxrwx 6 pix staff 204 8 Dez 14:19 base64id
                  drwxrwxrwx 8 pix staff 272 8 Dez 14:19 benchmark
                  drwxr-xr-x 9 pix staff 306 8 Dez 14:19 better-assert
                  drwxr-xr-x 10 pix staff 340 8 Dez 14:23 big-number
                  drwxrwxrwx 14 pix staff 476 25 Nov 16:50 bignum
                  drwxr-xr-x 12 pix staff 408 8 Dez 14:23 bignumber.js
                  drwxrwxrwx 5 pix staff 170 18 Nov 17:40 bindings
                  drwxrwxrwx 10 pix staff 340 20 Nov 02:08 bl
                  drwxrwxrwx 9 pix staff 306 8 Dez 14:19 blob
                  drwxr-xr-x 9 pix staff 306 8 Dez 14:20 block-stream
                  drwxrwxrwx 8 pix staff 272 8 Dez 14:21 body-parser
                  drwxrwxrwx 11 pix staff 374 20 Nov 02:08 boom
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 brace-expansion
                  drwxrwxrwx 9 pix staff 306 20 Nov 02:08 browser-request
                  drwxr-xr-x 9 pix staff 306 8 Dez 14:23 buffer-writer
                  drwxrwxrwx 11 pix staff 374 8 Dez 14:21 bufferutil
                  drwxrwxrwx 6 pix staff 204 8 Dez 14:19 bytes
                  drwxr-xr-x 8 pix staff 272 8 Dez 14:19 callsite
                  drwxrwxrwx 6 pix staff 204 18 Nov 17:40 camelcase
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 caseless
                  drwxr-xr-x 7 pix staff 238 8 Dez 14:23 center-align
                  drwxr-xr-x 8 pix staff 272 8 Dez 14:23 chainsaw
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 chalk
                  drwxrwxrwx 11 pix staff 374 18 Nov 17:40 cliui
                  drwxrwxrwx 6 pix staff 204 18 Nov 17:40 code-point-at
                  drwxrwxrwx 9 pix staff 306 25 Nov 16:49 coffee-compiler
                  drwxrwxrwx 13 pix staff 442 25 Nov 16:49 coffee-script
                  drwxr-xr-x 10 pix staff 340 8 Dez 14:19 colors
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 combined-stream
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 commander
                  drwxr-xr-x 9 pix staff 306 8 Dez 14:19 component-bind
                  drwxr-xr-x 11 pix staff 374 8 Dez 14:19 component-emitter
                  drwxr-xr-x 10 pix staff 340 8 Dez 14:19 component-inherit
                  drwxrwxrwx 9 pix staff 306 20 Nov 02:08 concat-map
                  drwxrwxrwx 7 pix staff 238 8 Dez 14:19 connect-flash
                  drwxrwxrwx 7 pix staff 238 8 Dez 14:19 content-disposition
                  drwxrwxrwx 7 pix staff 238 8 Dez 14:19 content-type
                  drwxrwxrwx 7 pix staff 238 8 Dez 14:19 cookie
                  drwxrwxrwx 7 pix staff 238 8 Dez 14:19 cookie-parser
                  drwxrwxrwx 7 pix staff 238 8 Dez 14:19 cookie-signature
                  drwxr-xr-x 21 pix staff 714 8 Dez 14:23 core-js
                  drwxrwxrwx 8 pix staff 272 20 Nov 02:08 core-util-is
                  drwxrwxrwx 7 pix staff 238 8 Dez 14:19 crc
                  drwxr-xr-x 11 pix staff 374 25 Nov 17:01 cron-parser
                  drwxrwxrwx 9 pix staff 306 20 Nov 02:08 cryptiles
                  drwxrwxrwx 13 pix staff 442 20 Nov 02:08 ctype
                  drwxr-xr-x 13 pix staff 442 25 Nov 16:51 curve25519
                  drwxr-xr-x 5 pix staff 170 8 Dez 14:19 cycle
                  drwxr-xr-x 8 pix staff 272 8 Dez 14:19 daemonize2
                  drwxrwxrwx 5 pix staff 170 20 Nov 02:08 dashdash
                  drwxrwxrwx 13 pix staff 442 18 Nov 17:40 debug
                  drwxrwxrwx 6 pix staff 204 18 Nov 17:40 decamelize
                  drwxr-xr-x 10 pix staff 340 8 Dez 14:19 deep-equal
                  drwxrwxrwx 10 pix staff 340 20 Nov 02:08 deep-is
                  drwxrwxrwx 8 pix staff 272 20 Nov 02:08 delayed-stream
                  drwxrwxrwx 8 pix staff 272 8 Dez 14:19 depd
                  drwxrwxrwx 5 pix staff 170 8 Dez 14:19 destroy
                  drwxrwxrwx 9 pix staff 306 25 Nov 16:51 duplexer
                  drwxrwxrwx 10 pix staff 340 25 Nov 16:50 duplexify
                  drwxr-xr-x 9 pix staff 306 8 Dez 14:20 ecc-jsbn
                  drwxrwxrwx 13 pix staff 442 25 Nov 16:50 ed25519
                  drwxrwxrwx 6 pix staff 204 8 Dez 14:19 ee-first
                  drwxrwxrwx 7 pix staff 238 25 Nov 16:50 end-of-stream
                  drwxrwxrwx 11 pix staff 374 8 Dez 14:19 engine.io
                  drwxr-xr-x 13 pix staff 442 8 Dez 14:19 engine.io-client
                  drwxrwxrwx 12 pix staff 408 8 Dez 14:19 engine.io-parser
                  drwxrwxrwx 6 pix staff 204 8 Dez 14:19 escape-html
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 escape-string-regexp
                  drwxrwxrwx 9 pix staff 306 20 Nov 02:08 escodegen
                  drwxrwxrwx 8 pix staff 272 20 Nov 02:08 esprima
                  drwxrwxrwx 9 pix staff 306 20 Nov 02:08 estraverse
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 esutils
                  drwxrwxrwx 7 pix staff 238 8 Dez 14:19 etag
                  drwxrwxrwx 10 pix staff 340 25 Nov 16:51 event-stream
                  drwxrwxrwx 9 pix staff 306 8 Dez 14:21 express
                  drwxrwxrwx 9 pix staff 306 8 Dez 14:20 express-session
                  drwxrwxrwx 12 pix staff 408 20 Nov 02:08 extend
                  drwxrwxrwx 12 pix staff 408 20 Nov 02:08 extsprintf
                  drwxr-xr-x 8 pix staff 272 8 Dez 14:19 eyes
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 fast-levenshtein
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 faye-websocket
                  drwxrwxrwx 10 pix staff 340 20 Nov 02:08 fileset
                  drwxrwxrwx 7 pix staff 238 8 Dez 14:20 finalhandler
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 forever-agent
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 form-data
                  drwxr-xr-x 7 pix staff 238 8 Dez 14:20 forwarded
                  drwxrwxrwx 7 pix staff 238 8 Dez 14:19 fresh
                  drwxrwxrwx 9 pix staff 306 25 Nov 16:51 from
                  drwxr-xr-x 3 pix staff 102 25 Nov 16:48 ftp-response-parser
                  drwxrwxrwx 9 pix staff 306 20 Nov 02:08 generate-function
                  drwxrwxrwx 9 pix staff 306 20 Nov 02:08 generate-object-property
                  drwxr-xr-x 11 pix staff 374 8 Dez 14:23 generic-pool
                  drwxrwxrwx 8 pix staff 272 20 Nov 02:08 glob
                  drwxr-xr-x 10 pix staff 340 8 Dez 14:19 global
                  drwxr-xr-x 10 pix staff 340 8 Dez 14:20 graceful-fs
                  drwxrwxrwx 8 pix staff 272 20 Nov 02:08 graceful-readlink
                  drwxrwxrwx 18 pix staff 612 20 Nov 02:08 handlebars
                  drwxr-xr-x 7 pix staff 238 8 Dez 14:20 har-validator
                  drwxrwxrwx 12 pix staff 408 20 Nov 02:08 harmonyhubjs-client
                  drwxrwxrwx 9 pix staff 306 20 Nov 02:08 harmonyhubjs-discover
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 has-ansi
                  drwxr-xr-x 11 pix staff 374 8 Dez 14:19 has-binary
                  drwxrwxrwx 11 pix staff 374 8 Dez 14:19 has-binary-data
                  drwxr-xr-x 9 pix staff 306 8 Dez 14:19 has-cors
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 has-flag
                  drwxr-xr-x 7 pix staff 238 8 Dez 14:23 hashish
                  drwxrwxrwx 14 pix staff 476 20 Nov 02:08 hawk
                  drwxrwxrwx 11 pix staff 374 20 Nov 02:08 hoek
                  drwxrwxrwx 7 pix staff 238 8 Dez 14:19 http-errors
                  drwxrwxrwx 10 pix staff 340 20 Nov 02:08 http-signature
                  drwxr-xr-x 9 pix staff 306 8 Dez 14:19 i
                  drwxrwxrwx 10 pix staff 340 8 Dez 14:19 iconv-lite
                  drwxr-xr-x 8 pix staff 272 8 Dez 14:19 indexof
                  drwxrwxrwx 8 pix staff 272 20 Nov 02:08 inflight
                  drwxrwxrwx 8 pix staff 272 20 Nov 02:08 inherits
                  drwxr-xr-x 6 pix staff 204 8 Dez 14:23 ini
                  drwxr-xr-x 7 pix staff 238 8 Dez 14:23 inote-util
                  drwxrwxrwx 5 pix staff 170 18 Nov 17:40 invert-kv
                  drwxr-xr-x@ 15 pix staff 510 29 Nov 18:33 ioBroker.vis-communicate
                  drwxr-xr-x 11 pix staff 374 19 Aug 15:23 iobroker
                  drwxr-xr-x 14 pix staff 476 8 Dez 14:20 iobroker.admin
                  drwxrwxrwx 14 pix staff 476 26 Nov 12:41 iobroker.dwd
                  drwxr-xr-x 12 pix staff 408 8 Dez 14:22 iobroker.flot
                  drwxr-xr-x 11 pix staff 374 19 Aug 15:23 iobroker.fritzbox
                  drwxrwxrwx 12 pix staff 408 30 Nov 16:28 iobroker.harmony
                  drwxrwxrwx 13 pix staff 442 19 Aug 15:23 iobroker.history
                  drwxrwxrwx 11 pix staff 374 19 Aug 15:23 iobroker.hm-rega
                  drwxr-xr-x 13 pix staff 442 19 Aug 15:23 iobroker.hm-rpc
                  drwxrwxrwx 10 pix staff 340 19 Okt 14:00 iobroker.hmm
                  drwxr-xr-x 12 pix staff 408 14 Dez 12:04 iobroker.homekit
                  drwxr-xr-x 14 pix staff 476 23 Aug 14:37 iobroker.ical
                  drwxr-xr-x 11 pix staff 374 19 Aug 15:23 iobroker.icons-addictive-flavour-png
                  drwxr-xr-x 10 pix staff 340 19 Aug 15:23 iobroker.icons-material-png
                  drwxr-xr-x 10 pix staff 340 19 Aug 15:23 iobroker.icons-material-svg
                  drwxrwxrwx 10 pix staff 340 25 Sep 12:39 iobroker.icons-mfd-png
                  drwxrwxrwx 10 pix staff 340 27 Sep 19:36 iobroker.icons-mfd-svg
                  drwxr-xr-x 10 pix staff 340 19 Aug 15:23 iobroker.icons-ultimate-png
                  drwxrwxrwx 12 pix staff 408 11 Dez 00:52 iobroker.javascript
                  drwxr-xr-x 20 pix staff 680 3 Nov 18:19 iobroker.js-controller
                  drwxrwxrwx 16 pix staff 544 19 Aug 15:23 iobroker.legacy
                  drwxr-xr-x 10 pix staff 340 9 Nov 10:15 iobroker.mobile
                  drwxr-xr-x 12 pix staff 408 19 Aug 15:23 iobroker.motion
                  drwxrwxrwx 12 pix staff 408 25 Nov 16:50 iobroker.mqtt
                  drwxr-xr-x 14 pix staff 476 23 Aug 14:33 iobroker.node-red
                  drwxr-xr-x 14 pix staff 476 19 Aug 15:23 iobroker.occ
                  drwxr-xr-x 12 pix staff 408 29 Aug 18:40 iobroker.ping
                  drwxrwxrwx 11 pix staff 374 12 Okt 23:01 iobroker.pushbullet
                  drwxrwxrwx 12 pix staff 408 19 Aug 15:23 iobroker.pushover
                  drwxr-xr-x 12 pix staff 408 8 Dez 14:22 iobroker.rickshaw
                  drwxr-xr-x 17 pix staff 578 26 Nov 12:59 iobroker.sayit
                  drwxrwxrwx 12 pix staff 408 13 Dez 12:48 iobroker.scenes
                  drwxr-xr-x 10 pix staff 340 29 Sep 02:41 iobroker.sequence
                  drwxrwxrwx 11 pix staff 374 1 Okt 18:08 iobroker.simple-api
                  drwxr-xr-x 3 pix staff 102 13 Dez 12:48 iobroker.socketio
                  drwxr-xr-x 12 pix staff 408 17 Sep 19:20 iobroker.sonos
                  drwxr-xr-x 10 pix staff 340 12 Dez 17:02 iobroker.sql
                  drwxr-xr-x 15 pix staff 510 26 Aug 00:14 iobroker.terminal
                  drwxr-xr-x 10 pix staff 340 2 Okt 18:11 iobroker.vcard
                  drwxrwxrwx 14 pix staff 476 9 Dez 13:43 iobroker.vis
                  drwxrwxrwx 9 pix staff 306 25 Sep 12:51 iobroker.vis-bars
                  drwxrwxrwx 10 pix staff 340 27 Sep 19:41 iobroker.vis-colorpicker
                  drwxrwxrwx 10 pix staff 340 14 Okt 13:35 iobroker.vis-fancyswitch
                  drwxrwxrwx 14 pix staff 476 18 Nov 17:42 iobroker.vis-google-fonts
                  drwxrwxrwx 12 pix staff 408 2 Dez 13:07 iobroker.vis-hqwidgets
                  drwxrwxrwx 10 pix staff 340 3 Nov 12:20 iobroker.vis-jqui-mfd
                  drwxr-xr-x 11 pix staff 374 23 Aug 14:40 iobroker.vis-lcars
                  drwxrwxrwx 12 pix staff 408 7 Dez 15:11 iobroker.vis-metro
                  drwxrwxrwx 10 pix staff 340 4 Okt 22:03 iobroker.vis-rgraph
                  drwxrwxrwx 10 pix staff 340 5 Okt 23:23 iobroker.vis-timeandweather
                  drwxr-xr-x 14 pix staff 476 8 Dez 14:21 iobroker.web
                  drwxrwxrwx 11 pix staff 374 29 Okt 15:00 iobroker.yr
                  drwxr-xr-x 13 pix staff 442 8 Dez 14:19 ipaddr.js
                  drwxr-xr-x 10 pix staff 340 8 Dez 14:19 is
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 is-absolute
                  drwxr-xr-x 9 pix staff 306 8 Dez 14:23 is-buffer
                  drwxrwxrwx 6 pix staff 204 18 Nov 17:40 is-fullwidth-code-point
                  drwxrwxrwx 12 pix staff 408 20 Nov 02:08 is-my-json-valid
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 is-property
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 is-relative
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 is-typedarray
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 isarray
                  drwxrwxrwx 10 pix staff 340 20 Nov 02:08 isstream
                  drwxrwxrwx 8 pix staff 272 20 Nov 02:08 istanbul
                  drwxrwxrwx 7 pix staff 238 25 Nov 16:51 ivona-node
                  drwxrwxrwx 13 pix staff 442 20 Nov 02:08 jodid25519
                  drwxrwxrwx 11 pix staff 374 20 Nov 02:08 js-yaml
                  drwxrwxrwx 9 pix staff 306 20 Nov 02:08 jsbn
                  drwxr-xr-x 3 pix staff 102 25 Nov 16:48 jsftp
                  drwxrwxrwx 13 pix staff 442 20 Nov 02:08 json-schema
                  drwxrwxrwx 10 pix staff 340 20 Nov 02:08 json-stringify-safe
                  drwxrwxrwx 11 pix staff 374 8 Dez 14:19 json3
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 jsonpointer
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 jsprim
                  drwxr-xr-x 6 pix staff 204 8 Dez 14:19 keypress
                  drwxr-xr-x 6 pix staff 204 8 Dez 14:23 kind-of
                  drwxr-xr-x 6 pix staff 204 8 Dez 14:23 lazy-cache
                  drwxrwxrwx 7 pix staff 238 18 Nov 17:40 lcid
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 levn
                  drwxrwxrwx 30 pix staff 1020 20 Nov 02:08 lodash
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 lodash._baseassign
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 lodash._basecopy
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 lodash._bindcallback
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 lodash._createassigner
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 lodash._getnative
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 lodash._isiterateecall
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 lodash.assign
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 lodash.isarguments
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 lodash.isarray
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 lodash.keys
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 lodash.restparam
                  drwxr-xr-x 6 pix staff 204 25 Nov 17:01 long-timeout
                  drwxr-xr-x 6 pix staff 204 8 Dez 14:23 longest
                  drwxrwxrwx 10 pix staff 340 25 Nov 16:51 lru-cache
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 ltx
                  drwxrwxrwx 10 pix staff 340 25 Nov 16:51 map-stream
                  drwxr-xr-x 7 pix staff 238 8 Dez 14:20 media-typer
                  drwxrwxrwx 6 pix staff 204 8 Dez 14:19 merge-descriptors
                  drwxrwxrwx 7 pix staff 238 8 Dez 14:19 methods
                  drwxrwxrwx 8 pix staff 272 20 Nov 02:08 mime
                  drwxr-xr-x 8 pix staff 272 8 Dez 14:20 mime-db
                  drwxr-xr-x 7 pix staff 238 8 Dez 14:20 mime-types
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 minimatch
                  drwxrwxrwx 9 pix staff 306 20 Nov 02:08 minimist
                  drwxrwxrwx 11 pix staff 374 20 Nov 02:08 mkdirp
                  drwxr-xr-x 3 pix staff 102 25 Nov 16:50 mqtt-packet
                  drwxrwxrwx 8 pix staff 272 18 Nov 17:40 ms
                  drwxr-xr-x 14 pix staff 476 8 Dez 14:23 mssql
                  drwxr-xr-x 7 pix staff 238 8 Dez 14:20 mute-stream
                  drwxr-xr-x 9 pix staff 306 8 Dez 14:23 mysql
                  drwxr-xr-x 29 pix staff 986 8 Dez 14:21 nan
                  drwxr-xr-x 13 pix staff 442 8 Dez 14:23 nconf
                  drwxr-xr-x 10 pix staff 340 8 Dez 14:19 ncp
                  drwxrwxrwx 8 pix staff 272 8 Dez 14:19 negotiator
                  drwxrwxrwx 8 pix staff 272 20 Nov 02:08 node-persist
                  drwxrwxrwx 10 pix staff 340 25 Nov 17:01 node-schedule
                  drwxrwxrwx 12 pix staff 408 20 Nov 02:08 node-uuid
                  drwxrwxrwx 9 pix staff 306 20 Nov 02:08 node-xmpp-client
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 node-xmpp-core
                  drwxrwxrwx 8 pix staff 272 20 Nov 02:08 node-xmpp-jid
                  drwxr-xr-x 10 pix staff 340 8 Dez 14:19 node.extend
                  drwxr-xr-x 12 pix staff 408 21 Aug 19:15 node_modules
                  drwxrwxrwx 11 pix staff 374 20 Nov 02:08 nopt
                  drwxr-xr-x 24 pix staff 816 8 Dez 14:19 npm
                  drwxrwxrwx 6 pix staff 204 18 Nov 17:40 number-is-nan
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 oauth-sign
                  drwxr-xr-x 10 pix staff 340 8 Dez 14:19 object-component
                  drwxrwxrwx 11 pix staff 374 8 Dez 14:19 object-keys
                  drwxrwxrwx 7 pix staff 238 8 Dez 14:19 on-finished
                  drwxrwxrwx 7 pix staff 238 8 Dez 14:19 on-headers
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 once
                  drwxrwxrwx 10 pix staff 340 20 Nov 02:08 optimist
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 optionator
                  drwxrwxrwx 7 pix staff 238 25 Nov 16:50 options
                  drwxrwxrwx 6 pix staff 204 18 Nov 17:40 os-locale
                  drwxr-xr-x 6 pix staff 204 8 Dez 14:23 packet-reader
                  drwxr-xr-x 17 pix staff 578 25 Nov 16:48 parse-listing
                  drwxr-xr-x 6 pix staff 204 8 Dez 14:19 parsejson
                  drwxr-xr-x 6 pix staff 204 8 Dez 14:19 parseqs
                  drwxr-xr-x 7 pix staff 238 8 Dez 14:19 parseuri
                  drwxrwxrwx 8 pix staff 272 8 Dez 14:19 parseurl
                  drwxrwxrwx 6 pix staff 204 8 Dez 14:19 passport
                  drwxrwxrwx 6 pix staff 204 8 Dez 14:19 passport-local
                  drwxrwxrwx 8 pix staff 272 8 Dez 14:19 passport-strategy
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 path-is-absolute
                  drwxrwxrwx 7 pix staff 238 8 Dez 14:19 path-to-regexp
                  drwxrwxrwx 8 pix staff 272 8 Dez 14:19 pause
                  drwxrwxrwx 8 pix staff 272 25 Nov 16:51 pause-stream
                  drwxr-xr-x 13 pix staff 442 8 Dez 14:23 pg
                  drwxr-xr-x 9 pix staff 306 8 Dez 14:23 pg-connection-string
                  drwxr-xr-x 10 pix staff 340 8 Dez 14:23 pg-types
                  drwxr-xr-x 10 pix staff 340 8 Dez 14:23 pgpass
                  drwxr-xr-x 6 pix staff 204 8 Dez 14:20 pinkie
                  drwxr-xr-x 6 pix staff 204 8 Dez 14:20 pinkie-promise
                  drwxr-xr-x 10 pix staff 340 8 Dez 14:19 pkginfo
                  drwxr-xr-x 6 pix staff 204 8 Dez 14:23 postgres-array
                  drwxr-xr-x 6 pix staff 204 8 Dez 14:23 postgres-bytea
                  drwxr-xr-x 6 pix staff 204 8 Dez 14:23 postgres-date
                  drwxr-xr-x 6 pix staff 204 8 Dez 14:23 postgres-interval
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 prelude-ls
                  drwxr-xr-x 8 pix staff 272 8 Dez 14:20 process-nextick-args
                  drwxr-xr-x 16 pix staff 544 8 Dez 14:23 promise
                  drwxr-xr-x 7 pix staff 238 8 Dez 14:20 proxy-addr
                  drwxr-xr-x 10 pix staff 340 25 Nov 16:50 pump
                  drwxrwxrwx 7 pix staff 238 18 Nov 17:40 q
                  drwxr-xr-x 15 pix staff 510 8 Dez 14:20 qs
                  drwxrwxrwx 7 pix staff 238 8 Dez 14:19 range-parser
                  drwxr-xr-x 8 pix staff 272 8 Dez 14:21 raw-body
                  drwxr-xr-x 6 pix staff 204 8 Dez 14:20 read
                  drwxrwxrwx 15 pix staff 510 20 Nov 02:08 readable-stream
                  drwxrwxrwx 8 pix staff 272 20 Nov 02:08 reconnect-core
                  drwxrwxrwx 10 pix staff 340 25 Nov 16:50 reduplexer
                  drwxr-xr-x 10 pix staff 340 8 Dez 14:23 remove
                  drwxr-xr-x 6 pix staff 204 8 Dez 14:23 repeat-string
                  drwxrwxrwx 16 pix staff 544 20 Nov 02:08 request
                  drwxrwxrwx 10 pix staff 340 20 Nov 02:08 resolve
                  drwxr-xr-x 11 pix staff 374 8 Dez 14:19 revalidator
                  drwxr-xr-x 6 pix staff 204 8 Dez 14:23 right-align
                  drwxr-xr-x 7 pix staff 238 8 Dez 14:19 rimraf
                  drwxrwxrwx 7 pix staff 238 25 Nov 16:48 sax
                  drwxr-xr-x 15 pix staff 510 8 Dez 14:23 seedrandom
                  drwxrwxrwx 9 pix staff 306 20 Nov 02:08 semaphore
                  drwxr-xr-x 17 pix staff 578 8 Dez 14:19 semver
                  drwxrwxrwx 8 pix staff 272 8 Dez 14:19 send
                  drwxr-xr-x 8 pix staff 272 8 Dez 14:23 seq
                  drwxrwxrwx 7 pix staff 238 8 Dez 14:19 serve-static
                  drwxrwxrwx 7 pix staff 238 25 Nov 16:50 server-destroy
                  drwxrwxrwx 12 pix staff 408 20 Nov 02:08 sntp
                  drwxrwxrwx 12 pix staff 408 8 Dez 14:21 socket.io
                  drwxrwxrwx 8 pix staff 272 8 Dez 14:19 socket.io-adapter
                  drwxrwxrwx 10 pix staff 340 8 Dez 14:21 socket.io-client
                  drwxr-xr-x 3 root staff 102 8 Dez 14:19 socket.io-parser
                  drwxrwxrwx 12 pix staff 408 20 Nov 02:08 source-map
                  drwxrwxrwx 10 pix staff 340 25 Nov 16:51 split
                  drwxr-xr-x 7 pix staff 238 8 Dez 14:23 sprintf
                  drwxrwxrwx 12 pix staff 408 20 Nov 02:08 sprintf-js
                  drwxr-xr-x 7 pix staff 238 8 Dez 14:23 sql-client
                  drwxr-xr-x 14 pix staff 476 8 Dez 14:23 sqlite3
                  drwxr-xr-x 10 pix staff 340 8 Dez 14:20 sshpk
                  drwxr-xr-x 8 pix staff 272 8 Dez 14:19 stack-trace
                  drwxrwxrwx 7 pix staff 238 8 Dez 14:19 statuses
                  drwxrwxrwx 9 pix staff 306 25 Nov 16:51 stream-combiner
                  drwxrwxrwx 6 pix staff 204 18 Nov 17:40 string-width
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 string_decoder
                  drwxrwxrwx 9 pix staff 306 20 Nov 02:08 stringstream
                  drwxrwxrwx 6 pix staff 204 18 Nov 17:40 strip-ansi
                  drwxr-xr-x 8 pix staff 272 25 Nov 16:49 suncalc
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 supports-color
                  drwxr-xr-x 8 pix staff 272 8 Dez 14:23 tedious
                  drwxrwxrwx 9 pix staff 306 25 Nov 16:51 through
                  drwxr-xr-x 3 pix staff 102 25 Nov 16:50 through2
                  drwxrwxrwx 8 pix staff 272 20 Nov 02:08 tls-connect
                  drwxr-xr-x 7 pix staff 238 8 Dez 14:19 to-array
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 tough-cookie
                  drwxr-xr-x 9 pix staff 306 8 Dez 14:23 traverse
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 tunnel-agent
                  drwxrwxrwx 10 pix staff 340 20 Nov 02:08 tweetnacl
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 type-check
                  drwxr-xr-x 7 pix staff 238 8 Dez 14:21 type-is
                  drwxrwxrwx 9 pix staff 306 20 Nov 02:08 uglify-js
                  drwxrwxrwx 9 pix staff 306 20 Nov 02:08 uglify-to-browserify
                  drwxrwxrwx 7 pix staff 238 8 Dez 14:19 uid-safe
                  drwxrwxrwx 9 pix staff 306 25 Nov 16:50 ultron
                  drwxrwxrwx 6 pix staff 204 25 Nov 16:51 unorm
                  drwxr-xr-x 7 pix staff 238 8 Dez 14:20 unpipe
                  drwxrwxrwx 11 pix staff 374 8 Dez 14:21 utf-8-validate
                  drwxrwxrwx 13 pix staff 442 8 Dez 14:19 utf8
                  drwxrwxrwx 8 pix staff 272 20 Nov 02:08 util-deprecate
                  drwxr-xr-x 11 pix staff 374 8 Dez 14:20 utile
                  drwxrwxrwx 7 pix staff 238 8 Dez 14:19 utils-merge
                  drwxrwxrwx 7 pix staff 238 8 Dez 14:19 vary
                  drwxrwxrwx 13 pix staff 442 20 Nov 02:08 verror
                  drwxrwxrwx 7 pix staff 238 25 Nov 16:49 wake_on_lan
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 websocket-driver
                  drwxrwxrwx 6 pix staff 204 20 Nov 02:08 websocket-extensions
                  drwxrwxrwx 9 pix staff 306 20 Nov 02:08 which
                  drwxrwxrwx 7 pix staff 238 18 Nov 17:40 window-size
                  drwxr-xr-x 14 pix staff 476 8 Dez 14:20 winston
                  drwxrwxrwx 8 pix staff 272 20 Nov 02:08 wordwrap
                  drwxrwxrwx 6 pix staff 204 18 Nov 17:40 wrap-ansi
                  drwxrwxrwx 7 pix staff 238 20 Nov 02:08 wrappy
                  drwxrwxrwx 15 pix staff 510 25 Nov 16:51 ws
                  drwxrwxrwx 6 pix staff 204 25 Nov 16:48 xml2js
                  drwxr-xr-x 7 pix staff 238 25 Nov 16:48 xmlbuilder
                  drwxr-xr-x 9 pix staff 306 8 Dez 14:19 xmlhttprequest
                  drwxrwxrwx 11 pix staff 374 20 Nov 02:08 xtend
                  drwxrwxrwx 8 pix staff 272 18 Nov 17:40 y18n
                  drwxrwxrwx 9 pix staff 306 18 Nov 17:40 yalm
                  drwxrwxrwx 10 pix staff 340 18 Nov 17:40 yargs
                    pix last edited by
                    nachdem ich mein System mal gründlich aufgeräumt habe, hat die Installation von Homekit endlich geklappt! Vielen Dank für Eure Hilfe.
                    Etwas tricky war die Koppelung. Ich musste leider die Schlüsselbundsynchronisation über iCloud einschalten, sonst war es nicht möglich zu koppeln.
                    Heute abend werde ich mal fleissig einrichten.
                    Danke nochmal,
                    Pix
                    :lol:
                    • V
                      Hallo, freut mich das zu hören.
                      Ja das Thema "Schlüsselbundsync" ist etwas, das Apple vorschreibt.
                      LG Christian
                      • fischi87
                        fischi87 last edited by
                        Servus,
                        also bei mir läuft der adapter ja recht gut aber ein freund wollte diesen auch haben und da hab ich Probleme mit der installation.
                        habe dass schon versucht wie bei pix aber ohne erfolg.?!
                        dns_sd_bindings.target.mk:130: recipe for target 'Release/obj.target/dns_sd_bindings/src/dns_sd.o' failed
                        make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
                        make: Leaving directory '/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdns/build'
                        gyp ERR! build error
                        gyp ERR! stack Error: `make` failed with exit code: 2
                        gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:267:23)
                        gyp ERR! stack     at ChildProcess.EventEmitter.emit (events.js:98:17)
                        gyp ERR! stack     at Process.ChildProcess._handle.onexit (child_process.js:789:12)
                        gyp ERR! System Linux 4.1.7-v7+
                        gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                        gyp ERR! cwd /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdns
                        gyp ERR! node -v v0.10.22
                        gyp ERR! node-gyp -v v0.11.0
                        gyp ERR! not ok
                        npm ERR! mdns@2.2.11 install: `node-gyp rebuild`
                        npm ERR! Exit status 1
                        npm ERR!
                        npm ERR! Failed at the mdns@2.2.11 install script.
                        npm ERR! This is most likely a problem with the mdns package,
                        npm ERR! not with npm itself.
                        npm ERR! Tell the author that this fails on your system:
                        npm ERR!     node-gyp rebuild
                        npm ERR! You can get their info via:
                        npm ERR!     npm owner ls mdns
                        npm ERR! There is likely additional logging output above.
                        npm ERR! System Linux 4.1.7-v7+
                        npm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "https://github.com/husky-koglhof/ioBroker.homekit/tarball/master" "--production"
                        npm ERR! cwd /opt/iobroker
                        npm ERR! node -v v0.10.22
                        npm ERR! npm -v 1.3.14
                        npm ERR! code ELIFECYCLE
                        npm ERR!
                        npm ERR! Additional logging details can be found in:
                        npm ERR!     /opt/iobroker/npm-debug.log
                        npm ERR! not ok code 0
                        root@raspberrypi:/opt/iobroker#
                        Mit freundlichen Grüßen
                        • V
                          Hallo fischi87, welche Node Version verwendest du?
                          habe gerade gesehen, da wurde mit der 0.10er probiert.
                          Will nur Fehler ausschliessen, vermute aber eher, das eine library fehlt.
                          Ich such mal schnell und gebe Bescheid.
                          • V
                            Probier mal folgendes:
                            apt-get update
                            apt-get install git-core libnss-mdns libavahi-compat-libdnssd-dev -y
                            • V
                              Gleich mal als Info, bei mir hat nach der Aktualisierung von ioBroker auf die letzte Version
                              homekit nicht mehr funktioniert.
                              Musste einen neuen Username setzen, und leider am iPhone alles neu einrichten.
                              Dass muss ich mir genauer ansehen. Ev. war es auch nur bei mir ein Problem.
                              • fischi87
                                weil du der beste best 🙂
                                danke genau da war der Fehler vielen dank und weiter so!!!
                                • fischi87
                                  Nein, hab das selbe Problem mit dem Adapter 😞
                                  • V
                                    Welches Problem nun?
                                    • fischi87
                                      Geräte sind nicht mehr erreichbar mit eve.
                                      • V
                                        Ok, kannst du einen reboot durchführen?
                                        Ich muss das ansonsten genau analysieren.
                                        Ich hab bei mir alles in eve gelöscht und von vorne angefangen und das sollte der letzte Weg sein.
                                        • fischi87
                                          okay hast recht noch Löschung von eve alles wieder cool!!!
                                          • fischi87
                                            servus
                                            also der homefit adapter läuft unter eve nicht mehr, Aktoren waren nicht mehr erreichbar und nach neuinstallation findet eve den Biobroker bridge nicht mehr!!!
                                            gibt es neue erkennnise bezüglich des adapters?
                                            250
                                            52392
