    4. [Vorstellung] Meine zweite Visualisierung
      DennisMenger @Kuddel last edited by
      @Kuddel super danke
        DennisMenger last edited by Negalein
        Teil 1
        <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="1xhq]CF5|L8T:e3!T,eV" x="121" y="-3307">
         <value name="OID0">
           <shadow type="field_oid" id="2-;6RL-j;|G*ArqTG1YN">
             <field name="oid">hmip.0.devices.3014F711A00000DA4994DB9F.channels.1.windowOpen</field>
         <value name="OID1">
           <shadow type="field_oid" id="HVjS`S%;z.oO#A%@?UwN">
             <field name="oid">hmip.0.devices.3014F711A00007DA4989AD87.channels.1.windowOpen</field>
         <value name="OID2">
           <shadow type="field_oid" id="`1zZ0_d~+Zq6q%2,guN(">
             <field name="oid">hmip.0.devices.3014F711A00000DA4994DB86.channels.1.windowOpen</field>
           <block type="control" id="+KE!n1mO,v#37eCLWau8">
             <field name="OID">javascript.0.VIS-Status.alle_fenster_eg_geschlossen</field>
               <block type="logic_boolean" id="3cZSLKgqD{5UUDV]5L9%">
               <block type="comment" id="gC*ZeYN|f3kr/.I[9DP#">
                 <field name="COMMENT">Sofaecke</field>
                   <block type="controls_if" id="HPB,4eTF.uoaO{_+!3u.">
                       <block type="logic_compare" id="%@~okf=@+-A*91gcVoPT">
                         <field name="OP">EQ</field>
                           <block type="get_value" id="NLB`S^q,7Ezk^-5FO~dq">
                             <field name="OID">hmip.0.devices.3014F711A00000DA4994DB9F.channels.1.windowOpen</field>
                           <block type="logic_boolean" id="2Zt/rI_kZf9JRrX(%[+=">
                       <block type="control" id="t%OD+4?^;Q2EAW[{gezg">
                           <block type="logic_boolean" id="x6;G~-S)P^vsQgyDy9jp">
                       <block type="comment" id="h-#fBL:)4*zpY=ygP4L+">
                         <field name="COMMENT">Terrasse</field>
                           <block type="controls_if" id="Ws}5}dkY;DP;[mbkf*?T">
                               <block type="logic_compare" id="[aAkmc(hIxC4B_ef(02h">
                                   <block type="get_value" id="oy,pXr=MMD;A3bT}_z}%">
                                     <field name="OID">hmip.0.devices.3014F711A00007DA4989AD87.channels.1.windowOpen</field>
                                   <block type="logic_boolean" id="fm`J]%Qn?!{m#87d0D+e">
                               <block type="control" id="rxIluhfn:;7hz`bSN*JO">
                                   <block type="logic_boolean" id="l+lw[US]=)gT9LT0K*.C">
                               <block type="comment" id="Q?WR3aB:#~[Y%`+Q@k-X">
                                 <field name="COMMENT">Essecke</field>
                                   <block type="controls_if" id="GwR1Chvv*lZ0OYUCT%zT">
                                       <block type="logic_compare" id="#!4|5=PNGp*QSWpYv6Ox">
                                           <block type="get_value" id="pmzZZpJLGsc6ztzT12Fp">
                                             <field name="OID">hmip.0.devices.3014F711A00000DA4994DB86.channels.1.windowOpen</field>
                                           <block type="logic_boolean" id="A9[[W3SNU:c@D(v5c],.">
                                       <block type="control" id="M|@3-CZwB5;NhARTE2g@">
                                           <block type="logic_boolean" id=":K%I%=+F|{BVB0^`|b%1">
        Teil 2:
        <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="Am#Mvvb/*1YJDMz?~{jC" x="121" y="-2789">
         <value name="OID0">
           <shadow type="field_oid" id="^Rnuo?@=GaPu0(B]CbPF">
         <value name="OID1">
           <shadow type="field_oid" id="QT?xIh7zwWae63n)567T">
         <value name="OID2">
           <shadow type="field_oid" id="lqQsO)+}EIG`A5SEQ[^s">
           <block type="controls_if" id="srHu]+:v1PF4Df6VAkDp">
               <block type="logic_operation" id=";7L~HfPom:D}|:FHFHmW" inline="false">
                 <field name="OP">OR</field>
                   <block type="logic_operation" id="tAIX9mXkKpsLPOKe;!wm" inline="false">
                       <block type="logic_compare" id="^hNN!_u~7@%rhT?,pGx!">
                           <block type="get_value" id="1kw=ck+jlGF7E,o(m*TP">
                           <block type="logic_boolean" id="dlee^R!ZwIpm|3W;a.gK">
                       <block type="logic_compare" id="]~wCrMl9d;,,zS~`^]Nf">
                           <block type="get_value" id="@7ZQu/3,LS{9xCS/|PQ*">
                           <block type="logic_boolean" id="Xr{x-T+d^8zoe]j)#;Zl">
                   <block type="logic_compare" id="u.D%QT7f@1q:(GeBV(wb">
                       <block type="get_value" id="B=l,y8S-Gg??UZ1#vus(">
                       <block type="logic_boolean" id="Gs#^|(N?05J2`y_]+ZT2">
               <block type="control" id="zO}9d*sWT}RMP*47UhC{">
                   <block type="logic_boolean" id="DZ~=Vh9{AGqaB{1{J4|?">
             <statement name="ELSE">
               <block type="control" id="Nn+FIb%v0OvZ*ytwYYj+">
                   <block type="logic_boolean" id="!XuypNuAE[ydF?#Gw%V3">
        Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
        Hier gehts zur Hilfe.
          bug77 @Kuddel last edited by
          @Kuddel said in [Vorstellung] Meine zweite Visualisierung:
          @bug77 ich habe dein Problem noch nicht so ganz verstanden. könntest du vllt. zur Verdeutlichung paar Screenshots anhängen?
          Einfach gefragt, kann ich das Icon der Navigation Buttons anhand eines States setzen, statt dem Iconverzeichnis.
          Ich möchte einfach das Icon anzeigen, welches den aktuellen Kalendertag anzeigt.
          Das Icon time_calendar.png zeigt ja immer die 14.
            Kuddel @DennisMenger last edited by Kuddel
            @DennisMenger ich habe direkt eine Frage: Wieso verwendest du zwei Blöcke, also zwei Trigger für die selbe Aufgabe ?
            Ich würde nur den unteren Triggger nehmen und damit testen:
              Kuddel @bug77 last edited by
              @bug77 wenn du es z.b. per Blockly hinbekomsmt den Pfad zum Icon in einen Datenpunkt zu schreiben, sollte das gehen.
              Pfad könnte zb sein: /vis.0/VIS/Meine_Icons/Kalender/Tag_1.jpg
              Datenobjekt = javascript.0.navi.kalender_icon_pfad
              In der VIS muss dann den Pfad zum Icon wie folget hinterlegen: {javascript.0.navi.kalender_icon_pfad}
              Entscheidend sind die geschweiften Klammern
                bug77 last edited by bug77
                Vielen Dank, die Klammern waren der entscheidende Tip , danke 👍
                Komisch ist nur, wenn ich icons in /vis.0/main/Meine_Icons/Kalender/ lege, sind sie über ftp vorhanden mit 777 Rechten, aber im Vis Editor ist der Ordner leer und man kann sie auf nicht direkt aufrufen 🧐
                EDIT:
                wie gesagt über Ftp/ssh sind die Dateien drauf, aber im Vis nicht vorhanden.
                Wenn ich die Icons direkt im Vis Editor hochlade, geht es. naja komisch
                  @Kuddel das Blockly ist aus deiner Vis. Habe nur die Geräte ausgetauscht, daher dachte ich dass es sonst so bleiben kann. Ich teste das dann mal nur mit einem Trigger.
                  • O
                    Oli @Kuddel last edited by Oli
                    @Kuddel
                    hier mal mein Lösungsansatz zum Adapter schalten:
                    Diese bitte in die Zeile 5 des Scriptes kopieren
                    createState('Adapter.Adapter', 0, { name: 'Adapter zum schalten', desc: 'Adapter zum schalten', type: 'number', unit: '', min: '0', max: '255', role: '',read: true, write: true });
                    Das hier bitte in die Zeile 49
                    devicename="Adapter.Adapter"+counter.toString()+".KompletterNameAdapter";
                            createState(devicename, 'empty', { name: 'Kompletter Name des Adapters', desc: '', type: 'string', role: '',read: true, write: true });
                            setStateDelayed(devicename, devicenameName, 800);
                    und das gier ganz unten nach den letzten Klammern "});" in eine neue Zeile
                    on({id:"javascript.0.Adapter.Adapter", change: 'any'}, function (dpobj) {
                        if (getState("javascript.0.Adapter.Adapter").val != 0) {
                            const instanz = "javascript." + instance;
                            var adapterName = getState(instanz + ".Adapter.Adapter").val;
                            var adapter = getState(instanz + ".Adapter.Adapter" + adapterName + ".KompletterNameAdapter").val; // Name und Instanz des Adapters
                            var idAdapter = "system.adapter." + adapter;
                            var obj = getObject(idAdapter);
                            if (dpobj.state.val == false) {
                                obj.common.enabled = true;  // Adapter einschalten
                            } else if (dpobj.state.val == true) {
                                obj.common.enabled = false;  // Adapter ausschalten
                            setObject(idAdapter, obj);
                            setStateDelayed('javascript.0.Adapter.Adapter', 0, 800);
                    der Button dazu:
                    [{"tpl":"tplHqButton","data":{"oid":"javascript.0.Adapter.Adapter","min":"3","max":"3","timeAsInterval":"true","infoLeftFontSize":"12","infoFontRightSize":"12","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":"0","signals-icon-0":"{javascript.0.Adapter.Adapter3.Bild}","signals-icon-size-0":"40","signals-blink-0":true,"signals-horz-0":"10","signals-vert-0":"10","signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":"1","signals-icon-1":"{javascript.0.Adapter.Adapter3.Bild}","signals-icon-size-1":"40","signals-blink-1":false,"signals-horz-1":"10","signals-vert-1":"10","signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":"2","signals-icon-2":"{javascript.0.Adapter.Adapter3.Bild}","signals-icon-size-2":"40","signals-blink-2":true,"signals-horz-2":"10","signals-vert-2":"10","signals-hide-edit-2":false,"pushButton":false,"usejQueryStyle":false,"g_visibility":false,"styleActive":"hq-button-no-background","name":"Bild","infoLeftPaddingLeft":"15","infoLeftPaddingRight":"50","infoRightPaddingRight":"15","gestures-swipeLeft-limit":"-1","gestures-rotateLeft-limit":"2","styleNormal":"hq-button-no-background","testActive":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"descriptionLeft":"Side brush lifetime reset","descriptionLeftDisabled":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-oid-0":"javascript.0.Adapter.Adapter3.Connected","signals-oid-1":"javascript.0.Adapter.Adapter3.Connected","g_center":true,"iconName":"","btIconWidth":"56","offsetAuto":"true","leftOffset":"15","topOffset":"55","signals-oid-2":"javascript.0.Adapter.Adapter3.Connected"},"style":{"left":"1400px","top":"152px","width":"50px","height":"50px","border-width":"","border-style":"","border-color":"","border-radius":"10px","z-index":"20","text-align":"center","font-size":"small","box-shadow":"","background":"#212121","background-color":"#212121"},"widgetSet":"hqwidgets"}]
                    hoffe es funktioniert.
                      @DennisMenger oh stimmt. nur ist bei mir der erste block mittlerweile deaktiviert
                      • Z
                        Zipkart @bug77 last edited by
                        @bug77 hallo. Das liegt am letzten Update des Systems. Eigene Icons muss man nun über den integrierten Dateimanager hochladen. Als Ziel muss es ein Ordner unterhalb von vis.0 liegen. Ich musste auch alle verschieben. Danach ging es dann.
                        • Firewalker99
                          Firewalker99 last edited by Firewalker99
                          Hallo Zusammen und schöne Feiertage,
                          habe leichte Probleme beim Import der Java Script ZIP.
                          • Will ich alle Scripte exportieren erscheint: File 2019-12-25-scripts.zip.zip not found.
                          • Importiere ich die Zip 2019-11-06-scripts.zip ohne vorherigen Export bekomme ich beim in jedem Script Syntax Error und außer den Gruppen wird nicht angelegt.
                          Ich vermute irgendwelche fehlenden Rechtevergaben weiß jedoch nicht wo ich hier ansetzen soll?
                          BlocklyJavascriptTypeScript
                          Fehler
                          Cannot parse "script.js.java.shutdown.reboot_qnap-b": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.java.shutdown.shutdown_qnap-archiv_v0_1": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.java.shutdown.shutdown_synology_v0_1": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.java.sonstige.abfall_tage": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.java.sonstige.hm_meldungen": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.java.sonstige.kodi_fanart": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.java.sonstige.onlinezeit": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.java.sonstige.regenradar": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.java.sonstige.speedtest": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.java.sonstige.upnp_update": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.java.wol.wol_daniel": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.java.wol.wol_esxp01": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.java.wol.wol_esxp02": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.java.wol.wol_qnap_archiv": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.java.wol.wol_synology": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.java.wol.wol_winnas": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.java.wol.wol_xmg": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.heizung.wohnzimmer_v0_3": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.sontiges.temperaturen": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.steckdosen.haushalt.geschirrspueler_v0_1": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.iobroker-pi_api_sync": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.NAS_und_VMware.shutdown_synology_v0_1": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.heizung.ankleide_v0_1": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.heizung.kueche_v0_1": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.heizung.schlafzimmer_v0_1": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.licht.aussenbeleuchtung": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.licht.kueche_v0_2": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.licht.schlafzimmer_v0_3": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.licht.weckzeit_jenny": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.licht.weihnachten": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.rolladen.leinwand_v0_3": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.rolladen.lueftung_rolladen_v0_2": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.sontiges.alexa_ansagen.außentemperatur": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.sontiges.kamera_auf_TV": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.sontiges.tuerklingel": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.sontiges.weckradio": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.steckdosen.buero_monitore_v0_1": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.steckdosen.haushalt.trockner_v0_1": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.steckdosen.haushalt.waschmaschine_v0_1": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.steckdosen.kodi_steckdose_v0_3": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.steckdosen.ps4_lueftung_v0_2": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.steckdosen.schlafzimmer_tv_v0_1": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.steckdosen.vu_receiver": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.backup_erstellen": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.reboot_skript": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.ressourcen_berechnungen": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.iobroker": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.iobroker_instanz": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.iobroker_pi": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.iobroker_pi_instanz": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.qnap_archiv": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.qnap_b": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.sonoff_bewaesserung": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.synology": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.unifi_ap_eg": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.unifi_ap_og": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.unifi_ap_pavillon": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.unifi_switch_rack": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.unifi_switch_wohnzimmer": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.win10": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.winnas": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.wlan_failover": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.java.sonstige.logs_vis": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.NAS_und_VMware.start_stop_esxp": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.licht.kodi_licht_v0_1": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.licht.schriftleuchte_v0_2": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.licht.weckzeit_daniel": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.steckdosen.kamera": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.kamera_überwachung": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.system_ctr_vis": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.esx_nuc": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.NAS_und_VMware.wake_on_lan_v0_2": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.rolladen.rolladen_beamer_v0_3": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.rolladen.rolladen_verdunkelung_v0_1": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.sontiges.briefkasten_tuerklingel_v0_1": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.anwesenheit": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.echo_stati": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.ccu": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.nut-server": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.omv": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.pihole": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.sophos": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.unifi_controller": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.uptime.vu_wohnzimmer": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.NAS_und_VMware.shutdown_WinNAS_v01": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.licht.lichterkette_flur_v0_3": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.licht.lichtkugeln_v0_2": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.usv_shutdown": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.steckdosen.harmony_schaltung_v0_4": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.sontiges.tablet": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.vis_status": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.sontiges.alexa_benachrichtigungen": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.zeiten_v01": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.rolladen.rolladen_tag_nacht": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.system.adapter_starten_stoppen": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.sontiges.benachrichtigungen_v0_1": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.sontiges.staubsauger_v0_2": SyntaxError: Unexpected token / in JSON at position 0, Cannot parse "script.js.smarthome.sontiges.bewaesserung": SyntaxError: Unexpected token / in JSON at position 0
                          Bass-T 1 Reply Last reply Reply Quote 0
                            @Kuddel
                            Das Blockly funktioniert leider nur zum Teil. Datenpunkt wird geändert in false, wenn ich ein Fenster öffne. Schließe ich das aber wieder, wird der Datenpunkt aber nicht wieder auf true gesetzt. Ich habe keine Ahnung warum.
                              @DennisMenger probiere mal statt "sonst" den Befehl "sonst falls" und prüfe ob alle fenster geschlossen sind und setze dann den DP auf true
                                Kuddel @Oli last edited by
                                @Oli wo kommt der DP javascript.0.Adapter.Name her ? Den habe ich nicht und was genau macht der DP "Adapter zum schalten"?
                                • O
                                  @Kuddel
                                  sorry hatte die Bezeichnung des Datenpunktes nochmal geändert, Script und Widget im oberen Poste neu eingefügt, du musst im Widget bei min und max die jeweilige Adapternummer anpassen
                                  Also für den Adapter "javascript.0.Adapter.Adapter1" die 1 eingeben usw.
                                    @Kuddel und was trage ich bei sonst falls ein? Nochmal die drei ODER-Abfragen?
                                    K D 2 Replies Last reply Reply Quote 0
                                      @DennisMenger ja die drei Werte von oben nur nicht mit ODER sondern mit UND dem Wert für geschlossen. ich denke "false"
                                      • tr1plx
                                        tr1plx @Kuddel last edited by tr1plx
                                        @Kuddel Vielen Dank für die tolle Vorlage. Ich lerne dadurch sehr viel über VIS und ioBroker im Allgemeinen. Ich arbeite gerade am Batteriestatus meiner HM-Geräte - in der Vorschau des VIS wird der Batteriestatus grün angezeigt (vgl. Flur - Alarmsirene)
                                        Im Browser nacher ist es aber nicht mehr grün - was mache ich falsch ?
                                        EDIT/UPDATE:
                                        Hab es rausbekommen. Da gibt es noch ein Background-Widget... das hab ich übersehen
                                          DennisMenger @DennisMenger last edited by DennisMenger
                                          @Kuddel Wert bleibt beim schließen der Fenster leider auf false. Alle Fenster geschlossen, Wert auf true gesetzt und dann probiert.
                                            @DennisMenger in deinem ersten check ist der dritte wert "falsch" und nicht wie bei den ersten beiden "wahr".
                                            Ändere das mal bitte
                                            template vis
                                            148
                                            1324
                                            493431
