    4. Beta-Test js-controller 2.2.x GitHub
      adaer @apollon77 last edited by
      @apollon77
      Habe zufällig Gestern den js-controller einen update verpasst nach 2.1.1 ... Alles noch frisch im Kopf... mache auch mit...
      • Neuschwansteini
        Neuschwansteini @apollon77 last edited by
        @apollon77 sagte in Beta-Test js-controller 2.2.x GitHub:
        Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller versuchen. Bitte berichtet solche Fälle hier im Thread.
        Hi, erster Slave geupdatet, läuft, allerdings nur nach der "sudo -H - Methode" - auch der Fixer wollte nicht fixen, was gefixt hätte werden sollen.. 🙂
        Hier mal das Log:
        pi@berrymotion:/opt/iobroker $ npm install ioBroker/ioBroker.js-controller
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/readdirp
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/ws
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/chokidar
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.objects-redis
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston-daily-rotate-file
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@types
        npm ERR! code EACCES
        npm ERR! syscall access
        npm ERR! path /opt/iobroker/node_modules/readdirp
        npm ERR! errno -13
        npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/readdirp'
        npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/readdirp']
        npm ERR!   stack:
        npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/readdirp\'',
        npm ERR!   errno: -13,
        npm ERR!   code: 'EACCES',
        npm ERR!   syscall: 'access',
        npm ERR!   path: '/opt/iobroker/node_modules/readdirp' }
        npm ERR!
        npm ERR! The operation was rejected by your operating system.
        npm ERR! It is likely you do not have the permissions to access this file as the current user
        npm ERR!
        npm ERR! If you believe this might be a permissions issue, please double-check the
        npm ERR! permissions of the file and its containing directories, or try running
        npm ERR! the command again as root/Administrator.
        npm ERR!     /home/pi/.npm/_logs/2019-12-27T15_54_46_726Z-debug.log
        pi@berrymotion:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash -
            Welcome to the ioBroker installation fixer!
            Script version: 2019-11-10
            You might need to enter your password a couple of times.
            Installing prerequisites (1/3)
        Get:1 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
        Get:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB]
        Get:3 https://deb.nodesource.com/node_10.x stretch InRelease [4,585 B]
        Get:4 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages [11.7 MB]
        Get:5 https://deb.nodesource.com/node_10.x stretch/main armhf Packages [764 B]
        Fetched 11.7 MB in 37s (312 kB/s)
        Reading package lists... Done
            Checking ioBroker user and directory permissions (2/3)
        Created /etc/sudoers.d/iobroker
        Fixing directory permissions...
            Checking autostart (3/3)
        Enabling autostart...
        Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        npm ERR! errno -13
        npm ERR!   stack:
        npm ERR!
        npm ERR!
        npm ERR!     /home/pi/.npm/_logs/2019-12-27T15_58_12_257Z-debug.log
        pi@berrymotion:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller
        > iobroker.js-controller@2.2.0 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.12.0
        > iobroker.js-controller@2.2.0 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        + iobroker.js-controller@2.2.0
        added 4 packages from 4 contributors, removed 33 packages and updated 21 packages in 181.41s
           │      New minor version of npm available! 6.12.0 → 6.13.1       │
           │   Changelog: https://github.com/npm/cli/releases/tag/v6.13.1   │
           │               Run npm install -g npm to update!                │
        pi@berrymotion:/opt/iobroker $ iobroker start
          sigi234 Forum Testing Most Active @apollon77 last edited by sigi234
          @apollon77
          Alle Adapter Grün, teste weiter. Aber Version 2.2.0
          Edit: V 2.2.2
            apollon77 last edited by apollon77
            Für die 2.4 die Ende ärz kommt wird dann getMessage noch entfernt ... folgende Adapter können Probleme machen
            • ...frankjoke mehrere
            • ioBroker.discovery
            • ioBroker.email ?
            • ioBroker.hmm
            • ioBroker.megad
            • ioBroker.megadd
            • ioBroker.megaesp
            • ioBroker.mqtt
            • ioBroker.node-red
            • ioBroker.noolite
            • ioBroker.opcua
            • ioBroker.owfs
            • ioBroker.ping
            • ioBroker.pushover ?
            • ioBroker.pushsafer
            • ioBroker.sayit
            • ioBroker.snips
            • ioBroker.telegram
            • ioBroker.wrapper
            • ioBroker.zigbee
            • ioBroker.zont
            • iobroker.km200
              darkiop Most Active @apollon77 last edited by darkiop
              @apollon77 jup. für telegram kann ich das schonmal bestäigen:
              telegram.0 (1873) TypeError: adapter.getMessage is not a function
              Edit: ioBroker.ping hast du auch in der Liste - der läuft hier ohne Fehlermeldung.
              Telegram wirft die Meldung, sendet aber trotzdem.
                apollon77 @darkiop last edited by apollon77
                @darkiop Telegram 1.4.7 auf GitHub ist kompatibel
                  adaer last edited by
                  Für Zigbee kann ich das auch bestätigen:
                  host.MyRasPi	2019-12-27 17:24:40.862	info	Restart adapter system.adapter.zigbee.0 because enabled
                  host.MyRasPi	2019-12-27 17:24:40.862	info	instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
                  host.MyRasPi	2019-12-27 17:24:40.861	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                  host.MyRasPi	2019-12-27 17:24:40.861	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                  host.MyRasPi	2019-12-27 17:24:40.860	error	Caught by controller[0]: at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:685:17)
                  host.MyRasPi	2019-12-27 17:24:40.860	error	Caught by controller[0]: at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6783:25)
                  host.MyRasPi	2019-12-27 17:24:40.859	error	Caught by controller[0]: at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7086:22)
                  host.MyRasPi	2019-12-27 17:24:40.859	error	Caught by controller[0]: at Adapter.emit (events.js:208:7)
                  host.MyRasPi	2019-12-27 17:24:40.858	error	Caught by controller[0]: at emitNone (events.js:106:13)
                  host.MyRasPi	2019-12-27 17:24:40.857	error	Caught by controller[0]: at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.zigbee/main.js:171:31)
                  host.MyRasPi	2019-12-27 17:24:40.856	error	Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1627:5)
                  host.MyRasPi	2019-12-27 17:24:40.854	error	Caught by controller[0]: at processMessages (/opt/iobroker/node_modules/iobroker.zigbee/main.js:177:13)
                  host.MyRasPi	2019-12-27 17:24:40.851	error	Caught by controller[0]: TypeError: adapter.getMessage is not a function
                  zigbee.0	2019-12-27 17:24:40.277	info	(22092) Terminated (NO_ERROR): Without reason
                  zigbee.0	2019-12-27 17:24:40.275	info	(22092) terminating
                  zigbee.0	2019-12-27 17:24:40.141	error	(22092) TypeError: adapter.getMessage is not a function at processMessages (/opt/iobroker/node_modules/iobroker.zigbee/main.js:177:13) at main (/opt/iobroker/node_modules/iobroker.zigbee/main.
                  zigbee.0	2019-12-27 17:24:40.138	error	(22092) uncaught exception: adapter.getMessage is not a function
                  zigbee.0	2019-12-27 17:24:40.113	info	(22092) Reset coordinator
                  zigbee.0	2019-12-27 17:24:40.038	info	(22092) Queue is: true
                  zigbee.0	2019-12-27 17:24:40.037	info	(22092) Start on port: /dev/ttyACM0 channel 11
                  zigbee.0	2019-12-27 17:24:39.954	info	(22092) starting. Version 0.11.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.12.0
                  host.MyRasPi	2019-12-27 17:24:35.568	info	instance system.adapter.zigbee.0 started with pid 22092
                  host.MyRasPi	2019-12-27 17:24:05.541	info	Restart adapter system.adapter.zigbee.0 because enabled
                    Ok, dann installiert bitte mal neu von Github. Die 2.2.2 fügt die "getMessage" erstmal wieder hinzu. Wir werfen das in der 2.4 (nächstes Release Ende März) dann raus. Das sollte genug Zeit geben die Adapter vorzubereiten.
                      Yesssss Sir... 🙂 Thank you very much..
                      zigbee.0	2019-12-27 17:54:40.100	info	(10097) 1 (0x00158d0002792080): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                      zigbee.0	2019-12-27 17:54:40.065	info	(10097) Shepherd ready. {"state":"Coordinator","channel":"11","panId":6754,"extPanId":[221,221,221,221,221,221,221,221],"ieeeAddr":"0x00124b0018e1b30a","nwkAddr":0}
                      zigbee.0	2019-12-27 17:54:40.062	info	(10097) Zigbee-shepherd ready. Firmware version: 2.6.3 rev 20180815
                      zigbee.0	2019-12-27 17:54:40.036	info	(10097) zigbee-shepherd started!
                      zigbee.0	2019-12-27 17:54:38.207	info	(10097) Reset coordinator
                      zigbee.0	2019-12-27 17:54:38.133	info	(10097) Queue is: true
                      zigbee.0	2019-12-27 17:54:38.131	info	(10097) Start on port: /dev/ttyACM0 channel 11
                      zigbee.0	2019-12-27 17:54:38.077	info	(10097) starting. Version 0.11.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.12.0
                      host.MyRasPi	2019-12-27 17:54:34.278	info	instance system.adapter.zigbee.0 started with pid 10097
                      host.MyRasPi	2019-12-27 17:54:34.245	info	"system.adapter.zigbee.0" enabled
                      v2.2.2
                        Ok, zu testen ist bitte ob alles noch w´so tut wie bisher. Achtet mal auf die Logfiles das die jetzt wieder sauber rotiert werden und aufgeräumt werden.
                        Auch das History-Adapter (sql/Influxdb/history) noch tun, auch wenn es um Aktivieren/deaktivieren von Objekten geht. Auch iot hinzufügen von neuen Dingen und so generelle Dinge. Also alles was unter der Haube Objekte oder States subscribed ...
                          Jan1 last edited by Jan1
                          So die 2.2.2 ist drauf und alles läuft.
                          Einzig Node-Red hatte nach dem Start ein paar Warnungen im Log, die verschwinden aber von alleine, bevor ich sie kopieren konnte. Alles was ich in Node-Red drin habe läuft aber wie vorher auch.
                          Zigbee ohne Probleme, war bei mir aber auch mit 2.2.1 nicht anders
                          • Garfonso
                            Garfonso Developer @apollon77 last edited by
                            @apollon77 said in Beta-Test js-controller 2.2.x GitHub:
                            Vorschlag: im log einen entsprechenden Error ausgeben lassen. Dann nerven die User die Entwickler auch entsprechend. 😉
                              apollon77 @Jan1 last edited by
                              @Jan1 Schau doch mal ins Logfile auf Platte (/opt/iobroker/log/...)
                                apollon77 @Garfonso last edited by
                                @Garfonso Gute Idee 🙂
                                  Jan1 @apollon77 last edited by
                                  @apollon77
                                  2019-12-27 17:59:45.680  - warn: node-red.0 (2019) TypeError: adapter.getMessage is not a function
                                      at processMessages (/opt/iobroker/node_modules/iobroker.node-red/main.js:141:13)
                                      at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.node-red/main.js:33:5)
                                      at Adapter.emit (events.js:198:13)
                                      at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4785:34)
                                      at Immediate.setImmediate [as _onImmediate] (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:227:41)
                                      at runCallback (timers.js:705:18)
                                      at tryOnImmediate (timers.js:676:5)
                                      at processImmediate (timers.js:658:5)
                                    @Jan1 Dann läuft nicht der js-controller 2.2.2 🙂 Vllt restrt vergessen oder so?
                                      @apollon77
                                      Der Beelink wurde rebootet, also mehr Restart geht nicht😊
                                        @Jan1 Aber danach kams jetzt nicht mehr oder ?! Also mit der 2.2.2 ist die Funktion wieder da ...
                                        • MathiasJ
                                          MathiasJ last edited by
                                          Hi, Radar2 wird kurz grün, dann wieder rot.
                                          bin auf der Version 2.2.2
                                          radar2.0	2019-12-28 06:36:52.079	error	at process._tickCallback (internal/process/next_tick.js:63:19)
                                          radar2.0	2019-12-28 06:36:52.079	error	at state.handle.lookup (dgram.js:242:18)
                                          radar2.0	2019-12-28 06:36:52.079	error	(12861) Error: bind EACCES 0.0.0.0:67
                                          radar2.0	2019-12-28 06:36:52.078	error	(12861) uncaught exception: bind EACCES 0.0.0.0:67
                                          und
                                          host.ioBroker-RasPi4	2019-12-28 06:43:01.923	error	Caught by controller[0]: port: 67 }
                                          host.ioBroker-RasPi4	2019-12-28 06:43:01.923	error	Caught by controller[0]: address: '0.0.0.0',
                                          host.ioBroker-RasPi4	2019-12-28 06:43:01.923	error	Caught by controller[0]: syscall: 'bind',
                                          host.ioBroker-RasPi4	2019-12-28 06:43:01.923	error	Caught by controller[0]: code: 'EACCES',
                                          host.ioBroker-RasPi4	2019-12-28 06:43:01.923	error	Caught by controller[0]: errno: 'EACCES',
                                          host.ioBroker-RasPi4	2019-12-28 06:43:01.922	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:63:19)
                                          host.ioBroker-RasPi4	2019-12-28 06:43:01.922	error	Caught by controller[0]: at state.handle.lookup (dgram.js:242:18)
                                          host.ioBroker-RasPi4	2019-12-28 06:43:01.921	error	Caught by controller[0]: { Error: bind EACCES 0.0.0.0:67
                                          ble ist nur noch gelb, im LOG wird aber nichts angezeigt. Alles natürlich im debug.
                                          Gruß,
                                          Mathias
                                            @apollon77 Kurzer Zwischenstand, es gibt auch über Nacht nichts negatives zu berichten - Augenscheinlich alles beim Alten 🙂
                                            31.7k
                                            79.8k
                                            beta github js-controller
                                            18
                                            169
                                            15419
