    3. Entwicklung
    4. Zigbee Adapter mit neuem Converter
      DocGame last edited by
      Auch ich habe Unmengen an Fehlermeldungen. Irgendwie scheint es ja ein Timer Problem zu geben.
      Die Geräte laufen alle aber die Fehler beim Pairen (Post weiter oben) und im Log geben mir zu denken.
      Kann man was dagegen tun?
      Hier der Log:
      2019-12-25 00:54:25.548 - info: host.IOBroker(SmartHome) instance system.adapter.zigbee.0 terminated with code null ()
      2019-12-25 00:54:26.690 - info: host.IOBroker(SmartHome) instance system.adapter.zigbee.0 started with pid 22932
      2019-12-25 00:54:33.777 - info: zigbee.0 (22932) starting. Version 1.0.0-b in C:/Iobroker/SmartHome/node_modules/iobroker.zigbee, node: v10.16.3
      2019-12-25 00:54:33.826 - info: zigbee.0 (22932) Starting Zigbee...
      2019-12-25 00:54:35.974 - info: zigbee.0 (22932) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20191106}}
      2019-12-25 00:54:35.990 - info: zigbee.0 (22932) Unable to disable LED, unsupported function.
      2019-12-25 00:54:35.990 - info: zigbee.0 (22932) --> transmitPower : -22
      2019-12-25 00:54:36.047 - info: zigbee.0 (22932) Currently 28 devices are joined:
      2019-12-25 00:54:36.054 - info: zigbee.0 (22932) Configuring 0x04cf8cdf3c75b44a lumi.remote.b686opcn01
      2019-12-25 00:54:36.063 - info: zigbee.0 (22932) 0x7cb03eaa0a07b6c8 (addr 10073): AB3257001NJ - OSRAM Smart+ plug (Router)
      2019-12-25 00:54:36.063 - info: zigbee.0 (22932) 0x7cb03eaa0a07b27e (addr 15178): AB3257001NJ - OSRAM Smart+ plug (Router)
      2019-12-25 00:54:36.064 - info: zigbee.0 (22932) 0x84182600000e47bf (addr 47298): AB3257001NJ - OSRAM Smart+ plug (Router)
      2019-12-25 00:54:36.064 - info: zigbee.0 (22932) 0x841826000010673d (addr 38644): AB3257001NJ - OSRAM Smart+ plug (Router)
      2019-12-25 00:54:36.065 - info: zigbee.0 (22932) 0x00158d000255dc96 (addr 1374): WXKG02LM - Xiaomi Aqara double key wireless wall switch (EndDevice)
      2019-12-25 00:54:36.065 - info: zigbee.0 (22932) 0x7cb03eaa0a07cf0e (addr 26335): AB3257001NJ - OSRAM Smart+ plug (Router)
      2019-12-25 00:54:36.066 - info: zigbee.0 (22932) 0x7cb03eaa0a016776 (addr 19576): AB3257001NJ - OSRAM Smart+ plug (Router)
      2019-12-25 00:54:36.066 - info: zigbee.0 (22932) 0x84182600000e8d75 (addr 30467): AB3257001NJ - OSRAM Smart+ plug (Router)
      2019-12-25 00:54:36.067 - info: zigbee.0 (22932) 0x7cb03eaa00acad07 (addr 54035): AB3257001NJ - OSRAM Smart+ plug (Router)
      2019-12-25 00:54:36.067 - info: zigbee.0 (22932) 0xec1bbdfffe972085 (addr 42481): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
      2019-12-25 00:54:36.067 - info: zigbee.0 (22932) 0x04cf8cdf3c75b44a (addr 25822): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
      2019-12-25 00:54:36.068 - info: zigbee.0 (22932) 0x00158d00028f7b08 (addr 53798): WXKG03LM - Xiaomi Aqara single key wireless wall switch (EndDevice)
      2019-12-25 00:54:36.068 - info: zigbee.0 (22932) 0x04cf8cdf3c75c2c5 (addr 40615): WXCJKG12LM - Xiaomi Aqara Opple switch 2 bands (EndDevice)
      2019-12-25 00:54:36.069 - info: zigbee.0 (22932) 0xccccccfffe9734b3 (addr 54953): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
      2019-12-25 00:54:36.069 - info: zigbee.0 (22932) 0x00158d000289e4c9 (addr 24380): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
      2019-12-25 00:54:36.070 - info: zigbee.0 (22932) 0x0017880104f18654 (addr 46006): 324131092621 - Philips Hue dimmer switch (EndDevice)
      2019-12-25 00:54:36.071 - info: zigbee.0 (22932) 0x00124b00199448e7 (addr 33729): GL-C-008 - Gledopto Zigbee LED controller RGB + CCT (Router)
      2019-12-25 00:54:36.071 - info: zigbee.0 (22932) 0x00158d0002c63f59 (addr 52457): ZNLDP12LM - Xiaomi Aqara smart LED bulb (EndDevice)
      2019-12-25 00:54:36.072 - info: zigbee.0 (22932) 0x7cb03eaa0a050960 (addr 33724): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
      2019-12-25 00:54:36.073 - info: zigbee.0 (22932) 0x7cb03eaa0a036286 (addr 8995): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
      2019-12-25 00:54:36.073 - info: zigbee.0 (22932) 0x00158d0002c63dc8 (addr 35036): ZNLDP12LM - Xiaomi Aqara smart LED bulb (Router)
      2019-12-25 00:54:36.074 - info: zigbee.0 (22932) 0x00178801028652de (addr 30102): 8718696449691 - Philips Hue White Single bulb B22 (Router)
      2019-12-25 00:54:36.074 - info: zigbee.0 (22932) 0x00158d00028f7bcd (addr 42654): WXKG03LM - Xiaomi Aqara single key wireless wall switch (EndDevice)
      2019-12-25 00:54:36.075 - info: zigbee.0 (22932) 0x00158d0002c8ca73 (addr 11574): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
      2019-12-25 00:54:36.075 - info: zigbee.0 (22932) 0x00158d0004216e65 (addr 46515): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2019-12-25 00:54:36.076 - info: zigbee.0 (22932) 0x00158d0002d40924 (addr 19664): WXKG02LM - Xiaomi Aqara double key wireless wall switch (EndDevice)
      2019-12-25 00:54:36.078 - info: zigbee.0 (22932) 0x00158d0003e748be (addr 56062): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2019-12-25 00:54:36.081 - info: zigbee.0 (22932) 0x00158d0002ca09bc (addr 38230): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2019-12-25 00:54:36.082 - info: zigbee.0 (22932) Zigbee started
      2019-12-25 00:54:46.065 - error: zigbee.0 (22932) Failed to configure 0x04cf8cdf3c75b44a lumi.remote.b686opcn01, attempt 1 (Error: AREQ - ZDO - bindRsp after 10000ms
      at Timeout.object.timer.setTimeout [as _onTimeout] (C:\Iobroker\SmartHome\node_modules\iobroker.zigbee\node_modules\zigbee-herdsman\dist\utils\waitress.js:44:24)
      at ontimeout (timers.js:436:11)
      at tryOnTimeout (timers.js:300:5)
      at listOnTimeout (timers.js:263:5)
      at Timer.processTimers (timers.js:223:10))
      2019-12-25 00:54:46.066 - info: zigbee.0 (22932) Configuring 0x04cf8cdf3c75c2c5 lumi.remote.b486opcn01
      2019-12-25 00:54:56.079 - error: zigbee.0 (22932) Failed to configure 0x04cf8cdf3c75c2c5 lumi.remote.b486opcn01, attempt 1 (Error: AREQ - ZDO - bindRsp after 10000ms
      2019-12-25 00:54:56.081 - info: zigbee.0 (22932) Configuring 0x0017880104f18654 RWL021
      2019-12-25 00:54:58.518 - info: zigbee.0 (22932) Zigbee: allowing new devices to join.
      2019-12-25 00:55:00.935 - warn: zigbee.0 (22932) Failed to execute routing table for '0x7cb03eaa0a07b6c8'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
      2019-12-25 00:55:07.698 - error: zigbee.0 (22932) Failed to configure 0x0017880104f18654 RWL021, attempt 1 (Error: AREQ - ZDO - bindRsp after 10000ms
      2019-12-25 00:55:08.988 - info: javascript.0 (6072) script.js.Bot-Scripts.Batterie_Telegramm: {"id":"mihome.0.devices.smoke_158d000287ac2a.percent","newState":{"val":73.4,"ts":1577231708968,"ack":true,"lc":1577231708968,"from":"system.adapter.mihome.0","q":0},"oldState":{"val":71.6,"ts":1577228480798,"ack":true,"lc":1577205011731,"from":"system.adapter.mihome.0","q":0},"state":{"val":73.4,"ts":1577231708968,"ack":true,"lc":1577231708968,"from":"system.adapter.mihome.0","q":0}}
      2019-12-25 00:55:11.190 - warn: zigbee.0 (22932) Failed to execute routing table for '0x7cb03eaa0a07b27e'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
      2019-12-25 00:55:21.257 - info: zigbee.0 (22932) Configuring 0x04cf8cdf3c75b44a lumi.remote.b686opcn01
      2019-12-25 00:55:21.400 - error: zigbee.0 (22932) Failed to execute LQI for '0x84182600000e47bf'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
      2019-12-25 00:55:31.265 - error: zigbee.0 (22932) Failed to configure 0x04cf8cdf3c75b44a lumi.remote.b686opcn01, attempt 2 (Error: AREQ - ZDO - bindRsp after 10000ms
      2019-12-25 00:55:31.402 - warn: zigbee.0 (22932) Failed to execute routing table for '0x84182600000e47bf'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
      2019-12-25 00:55:41.742 - warn: zigbee.0 (22932) Failed to execute routing table for '0x841826000010673d'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
      2019-12-25 00:55:47.533 - info: zigbee.0 (22932) Configuring 0x04cf8cdf3c75b44a lumi.remote.b686opcn01
      2019-12-25 00:55:52.089 - warn: zigbee.0 (22932) Failed to execute routing table for '0x7cb03eaa0a07cf0e'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
      2019-12-25 00:55:57.544 - error: zigbee.0 (22932) Failed to configure 0x04cf8cdf3c75b44a lumi.remote.b686opcn01, attempt 3 (Error: AREQ - ZDO - bindRsp after 10000ms
      2019-12-25 00:56:02.225 - info: zigbee.0 (22932) Zigbee: stop joining
      2019-12-25 00:56:02.463 - warn: zigbee.0 (22932) Failed to execute routing table for '0x7cb03eaa0a016776'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
      2019-12-25 00:56:12.774 - error: zigbee.0 (22932) Failed to execute LQI for '0x84182600000e8d75'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
      2019-12-25 00:56:22.777 - warn: zigbee.0 (22932) Failed to execute routing table for '0x84182600000e8d75'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
      2019-12-25 00:56:33.727 - warn: zigbee.0 (22932) Failed to execute routing table for '0x7cb03eaa00acad07'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
      2019-12-25 00:56:46.322 - error: zigbee.0 (22932) Failed to execute LQI for '0x7cb03eaa0a050960'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
      2019-12-25 00:56:56.323 - warn: zigbee.0 (22932) Failed to execute routing table for '0x7cb03eaa0a050960'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
      2019-12-25 00:57:06.439 - error: zigbee.0 (22932) Failed to execute LQI for '0x7cb03eaa0a036286'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
      2019-12-25 00:57:16.443 - warn: zigbee.0 (22932) Failed to execute routing table for '0x7cb03eaa0a036286'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
      2019-12-25 00:57:26.445 - error: zigbee.0 (22932) Failed to execute LQI for '0x00158d0002c63dc8'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
      2019-12-25 00:57:36.448 - warn: zigbee.0 (22932) Failed to execute routing table for '0x00158d0002c63dc8'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
      2019-12-25 00:57:46.449 - error: zigbee.0 (22932) Failed to execute LQI for '0x00178801028652de'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
      2019-12-25 00:57:56.451 - warn: zigbee.0 (22932) Failed to execute routing table for '0x00178801028652de'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
        Schrubbel @Garfonso last edited by
        @Garfonso
        Okay Danke. Das ist ja auch richtig so.
        Nur habe ich auch die ganzen Routing Fehlermeldungen bei den Plugs, da dachte ich das die Routing FW vielleicht besser wäre. Da aber im großen und ganzen alles funktioniert werde ich alles so lassen bis mein neuer Stick fertig ist.
          heinzie last edited by
          mal ein blöde Frage, kann man mit dem Adapter auch Werte von z.B. dem Aqara Temperatursensor direkt abfragen?
          oder gibt es nur neue Werte wenn des Sensor die selber liefert
            arteck Developer Most Active @DocGame last edited by
            @DocGame es sind nur warnings. die Geräte antworten nicht in der vorgegebenen Zeit
              arteck Developer Most Active @heinzie last edited by
              @heinzie nein .. alle Sensoren liefern die Werte ab.. man kann die nicht extra antriggern
                Matdos last edited by
                Installation klappt nicht bekomme die Fehlermeldung, fehlen hier Rechte für die Installation?
                $ ./iobroker url "https://github.com/ioBroker/ioBroker.zigbee/tarball/herdsman" --debug
                install https://github.com/ioBroker/ioBroker.zigbee/tarball/herdsman
                npm install https://github.com/ioBroker/ioBroker.zigbee/tarball/herdsman --production --save --prefix "/opt/iobroker" (System call)
                npm
                WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd-converters/node_modules/debugnpm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd-converters/node_modules/zcl-id
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/alexa-cookie2/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/alexa-remote2/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/arr-diff/package.json'
                npm
                WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/arr-union/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/array-unique/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/assign-symbols/package.json'
                npm WARN enoent
                ENOENT: no such file or directory, open '/opt/iobroker/node_modules/atob/package.json'npm
                WARN enoent
                ENOENT: no such file or directory, open '/opt/iobroker/node_modules/base/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/braces/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/buffer/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/bufferhelper/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/cache-base/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/class-utils/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/decode-uri-component/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/dotenv/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/eventemitter3/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/expand-brackets/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/extglob/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/fill-range/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/fragment-cache/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/get-value/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/has-value/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/has-values/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/http-proxy/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/http-proxy-middleware/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/http-proxy-response-rewrite/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/https/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/ieee754/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.alexa2/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.hm-rega/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.hm-rpc/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.viessmann/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/is-glob/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/map-cache/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/micromatch/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/mixin-deep/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/nanomatch/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/nearest-color/package.json'
                npm WARN enoent
                ENOENT: no such file or directory, open '/opt/iobroker/node_modules/object.pick/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/pascalcase/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/posix-character-classes/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/querystring/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/regex-not/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/repeat-element/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/requires-port/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/resolve-url/package.json'
                npm
                WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/ret/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/safe-regex/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/snapdragon/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/snapdragon-node/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/snapdragon-util/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/source-map-resolve/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/source-map-url/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/split-string/package.json'
                npm WARN
                enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/ssh2/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/ssh2-streams/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/to-regex/package.json'
                npm
                WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/to-regex-range/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/union-value/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/unset-value/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/urix/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/use/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/virtual-device-sdk/package.json'
                npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
                npm
                ERR! path /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd-converters/node_modules/debugnpm ERR! code EACCES
                npm ERR! errno -13
                npm ERR!
                syscall access
                npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd-converters/node_modules/debug'npm ERR! { Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd-converters/node_modules/debug'
                npm ERR! stack: 'Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd-converters/node_modules/debug'',
                npm
                ERR! errno: -13,npm ERR! code: 'EACCES',
                npm ERR! syscall: 'access',
                npm ERR! path: '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd-converters/node_modules/debug' }
                npm ERR!
                npm ERR! The operation was rejected by your operating system.
                npm ERR! It is likely you do not have the permissions to access this file as the current user
                npm ERR!
                npm
                ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try running
                npm ERR! the command again as root/Administrator (though this is not recommended).
                npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2019-12-27T17_08_55_516Z-debug.log
                ERROR: host.Home Cannot install https://github.com/ioBroker/ioBroker.zigbee/tarball/herdsman: 243
                ERROR: process exited with code 25
                Habe das eben entdeckt muss man das Updaten??
                  Jan1 @Matdos last edited by
                  @matdos1gmx-de
                  Das ist der alte Contoller und sollte mal ein Update erhalten, dann steht im Log ständig was von "permission denied", könnte mal der Fixer richten und dann Code im Code Tag posten und nicht einfach rein kopieren.
                    Matdos @Jan1 last edited by
                    @Jan1
                    Ja deswegen Frage ich ja ob mir da eine Berechtigung fehlt.
                    Welchen Fixer? Was muss ich da machen?
                    Wie postet man im Code Tag?
                    MFG
                      @matdos1gmx-de
                      Fixer in der Suche eingeben, wirst bestimmt schnell finden, da steht dann auch gleich die Erklärung dabei.
                      Code Tack ist das Symbol </>
                        @Jan1
                        Alles klar beim Update vom JS Controller steht das auch mit dem Fixer jetzt hat nach dem Update (musste beim update auch den Fixer benutzen) auch die Installation von Zigbee funktioniert!!!
                          @matdos1gmx-de
                          dann is ja alles gut
                            @Jan1
                            Jup danke dir!
                              Matdos last edited by Matdos
                              Hm hab da was komisches, anlernen geht super schnell!!! Das ist mal Top!
                              Aber habe jetzt als erstes das EG angelernt und OG war gestoppt.
                              Danach EG gestoppt und OG angelernt damit sich die 2 nicht in die Quere kommen.
                              Dabei ist mir garnicht aufgefallen das beim anlernen von den OG Geräten gar keine Ordner erstellt werden, erst nachdem ich ein Script ändern wollte.
                              Die zwei Lampen wo jetzt im OG auftauchen ohne Ordner sind erschienen als ich die Spannung weg und wieder drauf gelegt habe mit einer Fehlermeldung.
                              Jetzt noch mal alle Geräte löschen und neu anleren?
                              Edit : habe jetzt alles noch mal neu angelernt, mit gestopptem EG Zigbee Stick.
                              Diesmal hat der Adapter die Ordner beim anlernen erstellt so weit so gut.
                              Nachdem ich das OG wieder fertig hatte lies sich der EG Stick nicht mehr starten, nach mehrmaligem Reset und Speichern und abziehen und wieder einstecken wurde er irgendwann wieder grün aber hatte alle Geräte aus dem EG verloren, sprich der grüne Haken war weg und das durchgestrichene Wlan Symbol war dafür da, was macht ihr da?? Ich habe alles gelöscht- Hard Reset und alles noch mal angelernt.
                                @Asgothian
                                Ist das jetzt normal das gar kein Verbose State mehr da ist?
                                Wie muss ich jetzt Yahka konfigurieren, brauch ich gar kein Schript mehr?
                                Danke!
                                • Asgothian
                                  Asgothian Developer @Matdos last edited by
                                  @matdos1gmx-de
                                  Ein Script brauchst du Immer noch, allerdings nicht mehr mit 2 States. Es funktioniert jetzt so:
                                  Wenn du den Befehl "abschliessen" geben willst, dann musst du "lock" in den state schreiben. Nach einer Zeit (wenn er abgeschlossen hat) sollte das Schloss dann mit "locked" antworten.
                                  Das gleiche beim aufschliessen, nur mit "unlock"
                                  A.
                                    Matdos @Asgothian last edited by
                                    @Asgothian
                                    Hm ok aber wie siehts das Script dazu aus (weisst doch wenn es nicht mit Blockly geht steh ich auf dem Schlauch) ein Screenshot wäre super dann könnt ich es abschreiben.🤕
                                      Habe das jetzt seit gestern Nacht um 0.30 am laufen aber habe hier noch ein paar Probleme.
                                      @Asgothian
                                      Von den Thermostaten bekomme ich keine Rückmeldung aber steuern lassen sie sich, was heute morgen dazu gekommen ist,ist lediglich die Signalstärke beim Dominik aber auch hier werden keine anderen Werte gesendet, habe es auch schon versucht mit Batterie raus und wieder rein am Thermostat, mal das vom Wc Datenpukte entfernt und Adapter neu gestartet (Datenpunkte wurden wieder erstellt aber wieder ohne Werte)
                                      Hast du da eventuell ne Idee bzw. wie lang hat es bei dir gedauert bis die Werte geschrieben wurden, du hattest ja auch geschrieben das du ein Tag warten musstest oder?
                                      Der Bewegungsmelder sendet immer mal wieder aktuelle Lux Werte (nicht immer) und bleibt immer auf false bei Motion Detection.
                                      Habe hier auch schon versucht ihn nochmal neu anzulernen hat aber auch nichts gebracht.
                                      TImeout Thermostat Arbeitszimmer
                                      Timeout Theromstat WC
                                      Timeout Bewegungsmelder Xiaomi
                                      Warnmeldungen zu den Timeouts
                                      • Asgothian
                                        @matdos1gmx-de Das deutet darauf hin das die Thermostate nicht erfolgreich konfiguriert wurden. Wenn das nicht passiert senden sie keine Werte, lassen sich aber steuern.
                                        A.
                                          Matdos @Asgothian last edited by Matdos
                                          @Asgothian
                                          Ok denn BW habe ich jetzt nach mehrmaligen löschen und anlernen wieder am laufen aber die Thermostate wollen einfach nicht.
                                          Wie muss ich da vorgehen? Habe das Thermostat komplett aus der Liste entfernt, resetet und neu angelernt.
                                            @Asgothian
                                            Ok die Thermostate laufen jetzt nach dem anleren habe ich auf das kleine i geklickt und als dann der Link Wert unter Ojekte eingetragen wurde habe ich das Thermostat auf 30 Grad gestellt damit es voll auffährt und dann auf 5 Grag damit es komlett zu fährt erst dann hatte ich alle Werte drin und konnte das Thermostat im OG verbauen.
                                            Habe den Fehler gemacht das ich das Thermostat nicht komplett am Coordinator konfiguriert habe sondern so wie beim alten Adapter anlernen und dann gleich verbauen, der hat sich dann die Werte irgendwann selber geholt, das geht jetzt mit dem neuen nicht mehr.
                                            Du hast ja mit dem Schloss geschrieben das wenn ich es mit Lock schließe oder unlock öffne das das Schloss dann im selben Feld mit Locked und Unlocked antwortet oder?
                                            Habe das Schloss jetzt mehrmals gelöscht und angelernt ich habe die Signalstärke und kann es mit Lock und unlock steuern nur wird kein Locked und Unlocked geschrieben, wenn ich auf das i klicke sehe ich die HW Version 4 vom Schloss, is das jetzt auch wie bei den Thermostaten noch nicht richtig konfiguriert?
                                            Edit:
                                            Hm habs eben noch mal probiert und es wird der Fehler ins Log geschrieben, denke da muss ich nochmal löschen und neu anlernen.
                                            herdsman shpeherd zigbee adapter
                                            58
                                            498
                                            98824
