    2. Русский
    3. ioBroker
    4. ioBroker основное
    5. Arduino+Mqtt FAQ для начинающих.
    • I
      instalator last edited by
      @Securbond:
      @instalator:
      @Securbond:
      не посмотришь где я косячу ?
      #include <spi.h> // Ethernet shield
      #include <ethernet.h> // Ethernet shield
      #include <pubsubclient.h> // MQTT
      #include <virtualwire.h>
      #include <easytransfervirtualwire.h>
      #include <wire.h>
      #include <liquidcrystal_i2c.h>
      LiquidCrystal_I2C lcd(0x27,16,2);
      byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
      byte server[] = {192, 168, 0, 102}; //IP Брокера
      IPAddress ip(192, 168, 0, 112);
      ! EthernetClient ethClient;
      PubSubClient client(server, 1883, callback, ethClient);
      #define id_connect "UNO_1"
      #define Prefix_subscribe "UNO/Detskaya/"
      void callback(char* topic, byte* payload, unsigned int length) {
      payload[length] = '\0';
      // Serial.print(topic);
      // Serial.print("=");
      String strTopic = String(topic);
      String strPayload = String((char*)payload);
      // Serial.println(strPayload);
      callback_iobroker(strTopic, strPayload);
      //create object
      EasyTransferVirtualWire ET;
      ! struct SEND_DATA_STRUCTURE
      //put your variable definitions here for the data you want to send
      //THIS MUST BE EXACTLY THE SAME ON THE OTHER ARDUINO
      //Struct can'e be bigger then 26 bytes for VirtualWire version
      byte ID;
      long TemperatureBMP = 0;
      long TemperatureDS = 0;
      long Pressure = 0;
      ! //give a name to the group of data
      SEND_DATA_STRUCTURE mydata;
      byte ID;
      long Pressure = 0;
      ! void setup(){
      //start the library, pass in the data details
      ET.begin(details(mydata));
      Serial.begin(9600);
      // Initialise the IO and ISR
      vw_set_ptt_inverted(true); // Required for DR3100
      vw_setup(2000); // Bits per sec Скорость порта
      vw_set_rx_pin(8); //порт к которому подключен приемник 433 мГц
      vw_rx_start(); // Start the receiver PLL running
      lcd.init(); // Инициализируем экран
      lcd.backlight(); //Включаем подсветку
      ! Ethernet.begin(mac, ip);
      if (client.connect(id_connect)) {
      client.publish("UNO/Detskaya/Temp", "0");
      client.publish("UNO/Detskaya/Pressure", "0");
      client.subscribe("UNO/Detskaya/#");
      ! void loop(){
      //check and see if a data packet has come in.
      if(ET.receiveData()){
      //this is how you access the variables. [name of the group].[variable name]
      //since we have data, we will blink it out.
      if (mydata.ID == 1)
      int TempBMP= (mydata.TemperatureBMP);
      TempBMP = ((TempBMP)/100);
      float TempDS= (mydata.TemperatureDS);
      TempDS = ((TempDS)/100);
      float Pressure2= (mydata.Pressure);
      Pressure2 = ((Pressure2)/100);
       client.loop();
        if (!client.connected()) {
      client.publish("UNO/Detskaya/Temp", TempDS);
       client.publish("UNO/Detskaya/Pressure", Pressure2);
      // Serial.print(TempBMP); //Вывод информации в COM порт
      // Serial.println(", TempBMP:");
      // Температуру в градусах Цельсия
      Serial.print(TempDS);
      Serial.print(" C°,");
      Serial.print(Pressure2);
      Serial.print(" mm/");
      //Выводим давление в мм.рт ст
      Serial.println();
      Serial.println();
      delay(1000);
                                        //Вывод информации на  LCD Экран
      lcd.clear();//очищаем экран от старых данных
      lcd.setCursor(0,0);//Устанавливаем курсор в начало первой строки
      lcd.print("T1:");//Выводим первую температуру
      lcd.print(TempDS);
      lcd.setCursor(8,0);// устанавливаем курсор на 8 позицию в первой строке
      lcd.print(" T2:");//Выводим вторую температуру
      lcd.print(TempBMP);
      //аналогично выводим вторую строку
      lcd.setCursor(0,1);//Устанавливаем курсор в начало второй строки
      lcd.print("Davlenie:");//Выводим давление
      lcd.print(Pressure2);
      ! }</liquidcrystal_i2c.h></wire.h></easytransfervirtualwire.h></virtualwire.h></pubsubclient.h></ethernet.h></spi.h>
      Ругается -
      >! priemnik433_E2.ino: In function 'void callback(char*, byte*, unsigned int)':
      >! priemnik433_E2:28: error: 'callback_iobroker' was not declared in this scope
      >! priemnik433_E2.ino: In function 'void loop()':
      >! priemnik433_E2:96: error: no matching function for call to 'PubSubClient::publish(const char [18], float&)'
      >! priemnik433_E2.ino:96:47: note: candidates are:
      >! In file included from priemnik433_E2.ino:3:0:
      >! C:\Users\Bond-PC\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:117:12: note: boolean PubSubClient::publish(const char*, const char*)
      >! boolean publish(const char* topic, const char* payload);
      >! C:\Users\Bond-PC\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:117:12: note: no known conversion for argument 2 from 'float' to 'const char*'
      >! C:\Users\Bond-PC\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:118:12: note: boolean PubSubClient::publish(const char*, const char*, boolean)
      >! boolean publish(const char* topic, const char* payload, boolean retained);
      >! C:\Users\Bond-PC\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:118:12: note: candidate expects 3 arguments, 2 provided
      >! C:\Users\Bond-PC\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:119:12: note: boolean PubSubClient::publish(const char*, const uint8_t*, unsigned int)
      >! boolean publish(const char* topic, const uint8_t * payload, unsigned int plength);
      >! C:\Users\Bond-PC\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:119:12: note: candidate expects 3 arguments, 2 provided
      >! C:\Users\Bond-PC\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:120:12: note: boolean PubSubClient::publish(const char*, const uint8_t*, unsigned int, boolean)
      >! boolean publish(const char* topic, const uint8_t * payload, unsigned int plength, boolean retained);
      >! C:\Users\Bond-PC\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:120:12: note: candidate expects 4 arguments, 2 provided
      >! priemnik433_E2:97: error: no matching function for call to 'PubSubClient::publish(const char [22], float&)'
      >! priemnik433_E2.ino:97:55: note: candidates are:
      >! 'callback_iobroker' was not declared in this scope `
      Типы переменных передаваемые в функцию не совпадают.
      Пробуй так
              char b[5];
          String char_TempDS = String(TempDS);
          char_TempDS.toCharArray(b,5);
          client.publish("UNO/Detskaya/Temp", b);
              String char_Pressure2 = String(Pressure2);
          char_Pressure2.toCharArray(b,5);
      Остались только эти ошибки
      но судя по всему дело все в тех же переменных `
      Ну ругается же на 28 строку - callback_iobroker(strTopic, strPayload);
      Где в коде сама функция, вызываешь функуию callback_iobroker(strTopic, strPayload); а самой функции нету
        Securbond last edited by
        @instalator:
        @Securbond:
        @instalator:
        Пробуй так
                char b[5];
        Где в коде сама функция, вызываешь функуию callback_iobroker(strTopic, strPayload); а самой функции нету `
        как раз хотел спросить что делает эта функция
        /////////////////////////////////От Брокера//////////////////////////////////////////////
        void callback_iobroker(String strTopic, String strPayload){
          if (strTopic == "0"){
        добавил, ошибок больше стало аааааааа….........
        • I
          @Securbond:
          добавил, ошибок больше стало аааааааа…......... `
          Эта функция принимает strTopic от iobroker.
          • I
            @instalator:
            @Securbond:
            Для примера:
              if (strTopic == "myhome/Lighting/BedRoom_Main") {
                if (strPayload == "0") {
                  digitalWrite(23, 0);
                  delay(pause);
                  client.publish("myhome/Lighting/BedRoom_Main", "0");
                else if (strPayload == "1") {
                  digitalWrite(23, 1);
                  delay(pause);
                  client.publish("myhome/Lighting/BedRoom_Main", "1");
              @instalator:
              @instalator:
              @Securbond:
              Для примера:
                    delay(pause);
                    delay(pause);
              как понял это обратная связь, если на брокере значение поменять она передает его ардуине так ??
              я эту функцию временно закоментил и залил скетч.
              объекты создались но данные не приходят везде стоит - 0
              • I
                @Securbond:
                ! filename="77.JPG" index="0">~~ `
                Правильно понял, это callback.
                а данные у тебя и не будут передаватся брокеру (в коду у тебя так написано), только если ты кабель из ардуины выдернишь и заново вставишь, тогда передадутся данные в iobroker.
                добавь строки в общий луп
                char b[5];
                  @instalator:
                  @Securbond:
                  char b[5];
                  client.publish("UNO/Detskaya/Temp", b); `
                  А разве сейчас не так ?
                  void loop(){
                      if (mydata.ID == 1)
                       client.loop();
                          char b[5];
                  • I
                    @Securbond:
                    @instalator:
                    @Securbond:
                    char b[5];
                    void loop(){
                        if (mydata.ID == 1)
                         client.loop();
                            char b[5];
                    нет, не ужели нельзя чуток подумать и вникнуть в код?
                    void loop(){
                     char b[5];
                        if (mydata.ID == 1)
                         client.loop();
                      @instalator:
                      @Securbond:
                      @instalator:
                      char b[5];
                      void loop(){
                          if (mydata.ID == 1)
                           client.loop();
                              char b[5];
                      void loop(){
                       char b[5];
                          if (mydata.ID == 1)
                           client.loop();
                      Пришлось еще объявить в начале программы (глобально)
                      float TempDS и float Pressure2,
                      иначе выдавал ошибку
                      но легче не стало на брокер ничего не передает.
                      на LCD всё отображает. :roll: :?
                      • I
                        @Securbond:
                        на LCD всё отображает. :roll: :? `
                        замени строки :
                        на
                        #define id_connect "UNO-Detskaya"
                          @instalator:
                          @Securbond:
                          Похоже проблема в подключении к локалке, пока что не вижу шилда в сети …
                          Спасибо, сейчас попробую голый скетч залить. На всякий случай [http://forum.iobroker.net/viewtopic.php?f=33&amp;t=1609](http://forum.iobroker.net/viewtopic.php?f=33&amp;t=1609), мало ли)
                          Проверил резисторную сборку стоят резы на 250 Om
                          И еще, подключил и комп и сеть, раскомментировал отладочные строки
                          тут Serial.print(topic);
                          и
                          тутvoid callback_iobroker(String strTopic, String strPayload){
                          if (strTopic == "UNO/Detskaya/Temp") {
                          Так вот в СОМ порт кроме температуры больше ничего не сыпится, по соединению вообще ноль информации.
                          P.S. Вообще странно, потому что при заливке стандартного скетча вэб сервера, все работает прекрасно :roll: :?:
                            pmaster last edited by
                            подскажите, что могу делать не так?
                            данные на брокер приходят исправно. но я не могу ничего отправить обратно.
                            беру к примеру выключатель, лампочку, прописываю их на топик их состояния, нажимаю выключатель, на экране лампочки зажигаются, гаснут. а данные от брокера на mqtt сервер не уходят.
                            • I
                              @pmaster:
                              беру к примеру выключатель, лампочку, прописываю их на топик их состояния, нажимаю выключатель, на экране лампочки зажигаются, гаснут. а данные от брокера на mqtt сервер не уходят. ` вы что то путаете наверное. Иоб выступает в качестве сервера mqtt. Он отправит значение всем подписавшимся на топик клиентам.
                                я ничего не путаю. в качестве сервера у меня стоит mosquitto. Иоб выступает в качестве клиента. С проблемой разобрался :). По умолчанию в клиенте mqtt не стоит галочка "publish" (на топике).
                                сейчас возник вопрос. можно ли отключить получение своих же сообщений? т.е. я публикую сообщение, и оно тут же приходит мне обратно.
                                  smoker_vvo last edited by
                                  instalator - Доброго времени! Есть вопрос по скетчу - скомпилировался, загрузился… работает. НО! температуру кажет -127, типа датчика не видит, а это не правда, запускаем типовой ТЕстер от Ардуино 1.0.6 - датчик есть температуру кажет.
                                  Dallas Temperature IC Control Library Demo
                                  Locating devices...Found 1 devices.
                                  Parasite power is: ON
                                  Found device 0 with address: 2880E93A04000010
                                  Setting resolution to 9
                                  Resolution actually set to: 9
                                  Requesting temperatures...DONE
                                  Temperature for device: 0
                                  Temp 😄 25.00 Temp F: 77.00
                                  Как видно - адрес найден...
                                  Вбиваем его сюда:
                                  #define ONE_WIRE_BUS 8
                                  #define TEMPERATURE_PRECISION 9 - сам добавил, без нее то же -127
                                  OneWire oneWire(ONE_WIRE_BUS);
                                  DallasTemperature DS_sensors(&oneWire);
                                  // 28 80 E9 3A 04 00 00 10
                                  DeviceAddress addr_T1 = { 0x28, 0x80, 0xE9, 0x3A, 0x04, 0x00, 0x00, 0x10 };
                                  float T1 = 0;
                                  Ну вот результат -
                                  • I
                                    @smoker_vvo:
                                    температуру кажет -127, типа датчика не видит, а это не правда, запускаем типовой ТЕстер от Ардуино 1.0.6 - датчик есть температуру кажет. `
                                    версия библиотек какая? попробуй откатить на предыдущую
                                    20920
