    5. Axis Dome PTZ Kamera Schwenkbefehl starten
    • Glasfaser
      Glasfaser @Michmu last edited by Glasfaser
      @Michmu
      Brauchst du unbedingt ein Skript !?
      Test mal mit dem Widget .
      Benutzer / Passwort noch anpassen
      [{"tpl":"tplIconHttpGet","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"url":"http://root:Passwort@IpAdresse/axis-cgi/virtualinput/activate.cgi?schemaversion=1&port=1","text":"","src":"/vis.0/Wohnen/control_arrow_right.png","imageHeight":"98"},"style":{"left":"691px","top":"110px","width":"76px","height":"58px","z-index":"5"},"widgetSet":"jqui"}]
        @Glasfaser Ich habe den Widget getestet. Leider ohne Erfolg. Die Kameraposition ändert sich nicht. Ich benötige den Skript um die Kamera an meine Haustür zu zoomen wenn es klingelt und wenn der Bewegungsmelder aktiv ist soll die Kamera zur Seitentür schwenken und jeweils ein Foto per Telegram versenden.
        • Glasfaser
          @Michmu
          Ich habe kein Axis Kamera , deshalb kann ich dir nur bedingt weiterhelfen .
          Eigentlich was über URL geht sollte auch über das Widget gehen , so habe ich mein PTZ Steuerung im ioBroker VIS dazu erstellt .
          Bei meiner Hikvision muß ich die Sicherheitseinstellung freigeben ( IP von ioBroker ) .
          Hast du vielleicht auch so Einstellungen !??
          Du kannst es testen wenn du ein Ping auf deine Cam gibst von deinem ioBroker System aus ,ob er überhaupt darüber erreichbar ist .
          Kannst du hierrüber steuern .
          ( deine URL eintragen )
           <variables>
             <variable type="" id="WWjgMprUMf:um)P(p+2~">result</variable>
           </variables>
           <block type="request" id="rjPZc#a*~|;%AR$pzFa#" x="38" y="38">
             <mutation with_statement="true"></mutation>
             <field name="WITH_STATEMENT">TRUE</field>
             <field name="LOG">log</field>
             <value name="URL">
               <shadow type="text" id=")wIDYh#8E@!3?wirBTp-">
                 <field name="TEXT"></field>
               <block type="debug" id="+M[?0F={Oz067?Qfnx=(">
                 <value name="TEXT">
                   <shadow type="text" id="+2iN/QsDa33_?tVFzfH[">
                   <block type="variables_get" id="MBgRC:8oZkJCIZDfmYOE">
                     <field name="VAR" id="WWjgMprUMf:um)P(p+2~" variabletype="">result</field>
            habe es mal getestet. Leider auch ohne Erfolg.
            • Glasfaser
              @Michmu
              Nimm mein Blockly nur die URL anpassen !
              Was kommt unten im Log als Ergebniss ?
                01:11:50.154 info javascript.0 (31755) Start javascript script.js.PTZ_IPcam.Foto_Haustür
                01:11:50.176 info javascript.0 (31755) script.js.PTZ_IPcam.Foto_Haustür: registered 0 subscriptions and 0 schedules
                01:11:50.232 info javascript.0 (31755) script.js.PTZ_IPcam.Foto_Haustür: test
                • Glasfaser
                  Glasfaser @Glasfaser last edited by Glasfaser
                  @Glasfaser sagte in Axis Dome PTZ Kamera Schwenkbefehl starten:
                  @Michmu
                   <variables>
                   </variables>
                     <value name="URL">
                         <value name="TEXT">
                  Öffne den Spoiler , nimm den Code und füge Ihn in Blockly ein .
                  Dein erstellter Blockly funktioniert nicht , brauche die Auswertung von result !!!!
                    Michmu last edited by Negalein
                    01:20:51.727	info	javascript.0 (31755) Start javascript script.js.PTZ_IPcam.Foto_Haustür
                    01:20:51.743	info	javascript.0 (31755) script.js.PTZ_IPcam.Foto_Haustür: request: http://192.168.188.45/axis-cgi/virtualinput/activate.cgi?schemaversion=1&port=2
                    01:20:51.745	info	javascript.0 (31755) script.js.PTZ_IPcam.Foto_Haustür: registered 0 subscriptions and 0 schedules
                    01:20:51.769	info	javascript.0 (31755) script.js.PTZ_IPcam.Foto_Haustür: <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"> <html><head> <title>401 Unauthorized</title> </head><body> <h1>Unauthorized</h1> <p>This server could not verify that you are authorized to access the document requested. Either you supplied the wrong credentials (e.g., bad password), or your browser doesn't understand how to supply the credentials required.</p> </body></html>
                    • Glasfaser
                      @Michmu
                      Deine URL ist falsch !
                      User und Passwort fehlt !
                      so wie du es angegeben hast , wie im Browser !!!!!
                        Michmu last edited by Michmu
                        auch bei
                        http://root:passwort@192.168.188.45/axis-cgi/virtualinput/activate.cgi?schemaversion=1&port=2
                        kommt das gleiche Ergebniss
                        Das ist mein Ergebniss mit benutzer root und dem passwort welches auch im Browser funktioniert
                        • Glasfaser
                          @Michmu
                          root ist doch nicht dein Benutzer und Passwort dein Passwort ...oder !?
                          Laut Log hast du keine Zugriffsrechte , Passwort oder Benutzer falsch !
                          Was ist hiermit !???
                          @Michmu
                          EDIT : Mehr kann ich dir nicht helfen , das wird wohl ein Rechteproblem sein !
                            Michmu @Glasfaser last edited by Michmu
                            Ich habe das Passwort mit einem Anderen Browser nochmal getestet. Es ist das richtige.
                            Ich weiß nicht wo ich die Rechte einstellen sollte.
                            wie Ping ich denn die Kamera von iobroker aus ?
                            • Glasfaser
                              @Michmu
                              Wie schon erwähnt ,habe ich Sicherheitseinstellungen in der Software von der Kamera , wo ich die IP Adresse von ioBroker freigeben mußte und auch sowas habe :
                              Ich weiß dann auch nicht weiter , vielleicht meldet sich noch einer der die gleiche Kamera hat.
                                @Glasfaser Trotzdem danke für deine Mühe.
                                Schönen Abend noch. Gute Nacht
                                  Hat nicht jemand noch eine Idee?
                                  Glasfaser 2 Replies Last reply Reply Quote 0
                                  • Glasfaser
                                    @Michmu
                                    Versuche mal mit diesem Blockly , damit kann ich auch meine Cam den Presents ansteuern
                                    Wird über " curl -X PUT " ausgeführt .
                                    Braucht´s nur dein Passwort anpassen :
                                     <block type="exec" id="}[qQqxO?P::o(h.-aF0q" x="38" y="141">
                                       <mutation with_statement="false"></mutation>
                                       <field name="WITH_STATEMENT">FALSE</field>
                                       <field name="LOG"></field>
                                       <value name="COMMAND">
                                         <shadow type="text" id="{KoNWjRE)=KsfP6)4A6]">
                                           <field name="TEXT">http://root:Passwort@192.168.188.45/axis-cgi/virtualinput/activate.cgi?schemaversion=1&amp;port=1</field>
                                      A Former User @Glasfaser last edited by
                                      @Glasfaser Hi, kann das nicht importieren, fehlt da nicht noch was?
                                      Ist doch einfach nur ein Exec Baustein mit dem Curl command, oder ?
                                      • Glasfaser
                                        Glasfaser @Guest last edited by
                                        @ilovegym sagte in Axis Dome PTZ Kamera Schwenkbefehl starten:
                                        Bin unterwegs , muß ich mir später anschauen ...
                                        Genau ... Exec Baustein mit dem Curl command .
                                        • Glasfaser
                                          @Michmu
                                          Schau mal hier , Jey Cee hat ein Adapter erstellt :
                                          Test Adapter onvif v0.1.x
                                            Hi Leute,
                                            ich habe den Fehler gefunden! Es war das Sonderzeichen im Passwort.
                                            Se dürfen nur folgende Zeichen verwendet werden:
                                            A–Z, a–z, 0–9, + und / verwendet sowie = am Ende
                                            Da der Username und das Passwort per Base64 Kodiert werden.
                                            Danke für eure Hilfe.
                                            Gruß Michael
                                            blockly multimedia security
                                            2562
