    4. Beta-Test js-controller 2.2.x GitHub
      apollon77 @Garfonso last edited by
      @Garfonso Gute Idee 🙂
        Jan1 @apollon77 last edited by
        @apollon77
        2019-12-27 17:59:45.680  - warn: node-red.0 (2019) TypeError: adapter.getMessage is not a function
            at processMessages (/opt/iobroker/node_modules/iobroker.node-red/main.js:141:13)
            at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.node-red/main.js:33:5)
            at Adapter.emit (events.js:198:13)
            at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4785:34)
            at Immediate.setImmediate [as _onImmediate] (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:227:41)
            at runCallback (timers.js:705:18)
            at tryOnImmediate (timers.js:676:5)
            at processImmediate (timers.js:658:5)
          apollon77 @Jan1 last edited by
          @Jan1 Dann läuft nicht der js-controller 2.2.2 🙂 Vllt restrt vergessen oder so?
            @apollon77
            Der Beelink wurde rebootet, also mehr Restart geht nicht😊
              @Jan1 Aber danach kams jetzt nicht mehr oder ?! Also mit der 2.2.2 ist die Funktion wieder da ...
              • MathiasJ
                MathiasJ last edited by
                Hi, Radar2 wird kurz grün, dann wieder rot.
                bin auf der Version 2.2.2
                radar2.0	2019-12-28 06:36:52.079	error	at process._tickCallback (internal/process/next_tick.js:63:19)
                radar2.0	2019-12-28 06:36:52.079	error	at state.handle.lookup (dgram.js:242:18)
                radar2.0	2019-12-28 06:36:52.079	error	(12861) Error: bind EACCES 0.0.0.0:67
                radar2.0	2019-12-28 06:36:52.078	error	(12861) uncaught exception: bind EACCES 0.0.0.0:67
                und
                host.ioBroker-RasPi4	2019-12-28 06:43:01.923	error	Caught by controller[0]: port: 67 }
                host.ioBroker-RasPi4	2019-12-28 06:43:01.923	error	Caught by controller[0]: address: '0.0.0.0',
                host.ioBroker-RasPi4	2019-12-28 06:43:01.923	error	Caught by controller[0]: syscall: 'bind',
                host.ioBroker-RasPi4	2019-12-28 06:43:01.923	error	Caught by controller[0]: code: 'EACCES',
                host.ioBroker-RasPi4	2019-12-28 06:43:01.923	error	Caught by controller[0]: errno: 'EACCES',
                host.ioBroker-RasPi4	2019-12-28 06:43:01.922	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:63:19)
                host.ioBroker-RasPi4	2019-12-28 06:43:01.922	error	Caught by controller[0]: at state.handle.lookup (dgram.js:242:18)
                host.ioBroker-RasPi4	2019-12-28 06:43:01.921	error	Caught by controller[0]: { Error: bind EACCES 0.0.0.0:67
                ble ist nur noch gelb, im LOG wird aber nichts angezeigt. Alles natürlich im debug.
                Gruß,
                Mathias
                  darkiop Most Active @apollon77 last edited by
                  @apollon77 Kurzer Zwischenstand, es gibt auch über Nacht nichts negatives zu berichten - Augenscheinlich alles beim Alten 🙂
                    @apollon77 sagte in Beta-Test js-controller 2.2.x GitHub:
                    Nein sieht alles sehr sauber aus und auch sonst keine Auffälligkeiten. Hatte mit Problemen gerechnet, da ich einige der Adapter laufen habe, die im ersten Post als evt. problematisch gelten.
                    • MathiasJ
                      @apollon77
                      hat sich erledigt.
                      Nach einem Fix und 2 mal neu upgedatet mit
                      npm install ioBroker/ioBroker.js-controller
                      und
                      sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller
                      laufen ble und Radar2 wieder.
                      beim ersteren Code kamen zig Fehlermeldungen, beim zweiten Code ging es dann.
                      Gruß,
                      Mathias
                        Einstein67 last edited by
                        Mit JS-2.2.2 "laufen" hier alle meine Adapter problemlos!
                        Was nicht funktioniert, ist das löschen von Instanzen und Adapter über die Admin-GUI. Beim Versuch einen Adapter/Instanz zu löschen wird das Entfernen mit einem "Exit 0" beendet. Danach wird die Adapter-Konfigurationsseite geöffnet, und Adapter/Instanz ist noch vorhanden ...
                        Über die Konsole geht das entfernen problemlos!
                        apollon77 J 2 Replies Last reply Reply Quote 0
                          apollon77 @Einstein67 last edited by
                          @Einstein67 was genau steht im log?
                            Jan1 @Einstein67 last edited by Jan1
                            @Einstein67
                            stimmt und hier gleich mal ein Log dazu:
                            $ ./iobroker del iogo
                            Delete adapter "iogo"
                            host.Beelink Counted 1 instances of iogo
                            host.Beelink Counted 1 adapter for iogo
                            host.Beelink Counted 1 states of iogo
                            host.Beelink Counted 14 states of system.adapter.iogo
                            ERROR: Cannot delete iogo files folder: Not existsCannot delete iogo.admin files folder: Not exists
                            ERROR: host.Beelink error: Not exists
                            host.Beelink Deleting 17 object(s).
                            npm uninstall iobroker.iogo --silent --save --prefix "/opt/iobroker" (System call)
                            und hier der Versuch die Instanz zu löschen, was nicht funktioniert:
                              apollon77 @Jan1 last edited by apollon77
                              @Jan1 sieht an sich ok aus. Sind die system.adapter.iogo states noch vorhanden? Oder sind die weg? Läuft das npm uninstall vllt noch irgendwie?
                              Dann bitte mal ein GitHub issue anlegen. Prüfe ich später.
                              J ? 2 Replies Last reply Reply Quote 0
                                @apollon77
                                Die states sind weg, nur die Instanz lässt sich nicht löschen, zumindest in der Admin GUI.
                                  Einstein67 @Jan1 last edited by
                                  @Jan1 Danke für die Logs. Haben bei mir auch so ausgesehen.
                                  Jetzt muss ich das nicht mehr "nachspielen" und Schrrenshots machen 😉
                                    @Einstein67
                                    Aber ein Issue dazu darfst erstellen 😊
                                    Homer.J. E 2 Replies Last reply Reply Quote 0
                                    • Homer.J.
                                      Homer.J. @Jan1 last edited by
                                      Läuft keine Fehler im Log bei 41 laufenden Instanzen. 👍
                                        @Jan1 said in Beta-Test js-controller 2.2.x GitHub:
                                        Ist erledigt! Und .... ich hasse Englisch 😉
                                          A Former User @apollon77 last edited by
                                          Das hab ich schon länger, er löscht nur ein Teil aus den Verzeichnissen ohne Fehlermeldung, aber die Verzeichnisse der Adapter bleiben bestehen, und da meint der Admin anscheinend, dass der Adapter noch installiert ist.. obwohl die Dateien im Verzeichnis weg sind..
                                          Lösche ich das Verzeichnis des gelöschten Adapters dann per hand, sieht man den Adapter im Admin auch nicht mehr.
                                          • HappyTeaFriend
                                            HappyTeaFriend Forum Testing last edited by
                                            Bei mir läuft alles nach dem Update:
                                            Hatte nur den Permissions Fehler mit der pids.txt Datei. Jedoch mit dem Fixer hat es geklappt.
                                            beta github js-controller
                                            18
                                            169
                                            18727
