    4. Beta-Test js-controller 2.2.x GitHub
      Jan1 @apollon77 last edited by
      @apollon77
      2019-12-27 17:59:45.680  - warn: node-red.0 (2019) TypeError: adapter.getMessage is not a function
          at processMessages (/opt/iobroker/node_modules/iobroker.node-red/main.js:141:13)
          at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.node-red/main.js:33:5)
          at Adapter.emit (events.js:198:13)
          at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4785:34)
          at Immediate.setImmediate [as _onImmediate] (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:227:41)
          at runCallback (timers.js:705:18)
          at tryOnImmediate (timers.js:676:5)
          at processImmediate (timers.js:658:5)
        apollon77 @Jan1 last edited by
        @Jan1 Dann läuft nicht der js-controller 2.2.2 🙂 Vllt restrt vergessen oder so?
          @apollon77
          Der Beelink wurde rebootet, also mehr Restart geht nicht😊
            @Jan1 Aber danach kams jetzt nicht mehr oder ?! Also mit der 2.2.2 ist die Funktion wieder da ...
            • MathiasJ
              MathiasJ last edited by
              Hi, Radar2 wird kurz grün, dann wieder rot.
              bin auf der Version 2.2.2
              radar2.0	2019-12-28 06:36:52.079	error	at process._tickCallback (internal/process/next_tick.js:63:19)
              radar2.0	2019-12-28 06:36:52.079	error	at state.handle.lookup (dgram.js:242:18)
              radar2.0	2019-12-28 06:36:52.079	error	(12861) Error: bind EACCES 0.0.0.0:67
              radar2.0	2019-12-28 06:36:52.078	error	(12861) uncaught exception: bind EACCES 0.0.0.0:67
              und
              host.ioBroker-RasPi4	2019-12-28 06:43:01.923	error	Caught by controller[0]: port: 67 }
              host.ioBroker-RasPi4	2019-12-28 06:43:01.923	error	Caught by controller[0]: address: '0.0.0.0',
              host.ioBroker-RasPi4	2019-12-28 06:43:01.923	error	Caught by controller[0]: syscall: 'bind',
              host.ioBroker-RasPi4	2019-12-28 06:43:01.923	error	Caught by controller[0]: code: 'EACCES',
              host.ioBroker-RasPi4	2019-12-28 06:43:01.923	error	Caught by controller[0]: errno: 'EACCES',
              host.ioBroker-RasPi4	2019-12-28 06:43:01.922	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:63:19)
              host.ioBroker-RasPi4	2019-12-28 06:43:01.922	error	Caught by controller[0]: at state.handle.lookup (dgram.js:242:18)
              host.ioBroker-RasPi4	2019-12-28 06:43:01.921	error	Caught by controller[0]: { Error: bind EACCES 0.0.0.0:67
              ble ist nur noch gelb, im LOG wird aber nichts angezeigt. Alles natürlich im debug.
              Gruß,
              Mathias
                darkiop Most Active @apollon77 last edited by
                @apollon77 Kurzer Zwischenstand, es gibt auch über Nacht nichts negatives zu berichten - Augenscheinlich alles beim Alten 🙂
                  @apollon77 sagte in Beta-Test js-controller 2.2.x GitHub:
                  Nein sieht alles sehr sauber aus und auch sonst keine Auffälligkeiten. Hatte mit Problemen gerechnet, da ich einige der Adapter laufen habe, die im ersten Post als evt. problematisch gelten.
                  • MathiasJ
                    @apollon77
                    hat sich erledigt.
                    Nach einem Fix und 2 mal neu upgedatet mit
                    npm install ioBroker/ioBroker.js-controller
                    und
                    sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller
                    laufen ble und Radar2 wieder.
                    beim ersteren Code kamen zig Fehlermeldungen, beim zweiten Code ging es dann.
                    Gruß,
                    Mathias
                      Einstein67 last edited by
                      Mit JS-2.2.2 "laufen" hier alle meine Adapter problemlos!
                      Was nicht funktioniert, ist das löschen von Instanzen und Adapter über die Admin-GUI. Beim Versuch einen Adapter/Instanz zu löschen wird das Entfernen mit einem "Exit 0" beendet. Danach wird die Adapter-Konfigurationsseite geöffnet, und Adapter/Instanz ist noch vorhanden ...
                      Über die Konsole geht das entfernen problemlos!
                      apollon77 J 2 Replies Last reply Reply Quote 0
                        apollon77 @Einstein67 last edited by
                        @Einstein67 was genau steht im log?
                          Jan1 @Einstein67 last edited by Jan1
                          @Einstein67
                          stimmt und hier gleich mal ein Log dazu:
                          $ ./iobroker del iogo
                          Delete adapter "iogo"
                          host.Beelink Counted 1 instances of iogo
                          host.Beelink Counted 1 adapter for iogo
                          host.Beelink Counted 1 states of iogo
                          host.Beelink Counted 14 states of system.adapter.iogo
                          ERROR: Cannot delete iogo files folder: Not existsCannot delete iogo.admin files folder: Not exists
                          ERROR: host.Beelink error: Not exists
                          host.Beelink Deleting 17 object(s).
                          npm uninstall iobroker.iogo --silent --save --prefix "/opt/iobroker" (System call)
                          und hier der Versuch die Instanz zu löschen, was nicht funktioniert:
                            apollon77 @Jan1 last edited by apollon77
                            @Jan1 sieht an sich ok aus. Sind die system.adapter.iogo states noch vorhanden? Oder sind die weg? Läuft das npm uninstall vllt noch irgendwie?
                            Dann bitte mal ein GitHub issue anlegen. Prüfe ich später.
                            J ? 2 Replies Last reply Reply Quote 0
                              @apollon77
                              Die states sind weg, nur die Instanz lässt sich nicht löschen, zumindest in der Admin GUI.
                                Einstein67 @Jan1 last edited by
                                @Jan1 Danke für die Logs. Haben bei mir auch so ausgesehen.
                                Jetzt muss ich das nicht mehr "nachspielen" und Schrrenshots machen 😉
                                  @Einstein67
                                  Aber ein Issue dazu darfst erstellen 😊
                                  Homer.J. E 2 Replies Last reply Reply Quote 0
                                  • Homer.J.
                                    Homer.J. @Jan1 last edited by
                                    Läuft keine Fehler im Log bei 41 laufenden Instanzen. 👍
                                      @Jan1 said in Beta-Test js-controller 2.2.x GitHub:
                                      Ist erledigt! Und .... ich hasse Englisch 😉
                                        A Former User @apollon77 last edited by
                                        Das hab ich schon länger, er löscht nur ein Teil aus den Verzeichnissen ohne Fehlermeldung, aber die Verzeichnisse der Adapter bleiben bestehen, und da meint der Admin anscheinend, dass der Adapter noch installiert ist.. obwohl die Dateien im Verzeichnis weg sind..
                                        Lösche ich das Verzeichnis des gelöschten Adapters dann per hand, sieht man den Adapter im Admin auch nicht mehr.
                                        • HappyTeaFriend
                                          HappyTeaFriend Forum Testing last edited by
                                          Bei mir läuft alles nach dem Update:
                                          Hatte nur den Permissions Fehler mit der pids.txt Datei. Jedoch mit dem Fixer hat es geklappt.
                                            sigi234 Forum Testing Most Active @apollon77 last edited by sigi234
                                            @apollon77
                                            V 2.2.2
                                            Das ist Neu:
                                            undefined2019-12-29 00:16:21.275 - error: admin.0 (1472) Cannot check file: C:\Program Files\iobroker\Test\log/iobroker.2019-12-28.log
                                            2019-12-29 00:16:23.543 - error: admin.0 (1472) Cannot check file: C:\Program Files\iobroker\Test\log/iobroker.2019-12-28.log
                                            2019-12-29 00:16:47.526 - error: admin.0 (1472) Cannot check file: C:\Program Files\iobroker\Test\log/iobroker.2019-12-28.log
                                            beta github js-controller
                                            18
                                            169
                                            18727
