    4. Test Adapter lovelace v0.2.x
    • marcuskl
      marcuskl @Garfonso last edited by marcuskl
      @Garfonso
      Hier der Log:
      2019-12-27 21:34:52.286 - debug: lovelace.0 (2374) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2019-12-27 21:34:52.346 - debug: lovelace.0 (2374) Objects client ready ... initialize now
      2019-12-27 21:34:52.355 - debug: lovelace.0 (2374) Objects create PubSub Client
      2019-12-27 21:34:52.360 - debug: lovelace.0 (2374) Objects client initialize lua scripts
      2019-12-27 21:34:52.371 - debug: lovelace.0 (2374) Objects connected to redis: 127.0.0.1:9001
      2019-12-27 21:34:52.381 - debug: lovelace.0 (2374) objectDB connected
      2019-12-27 21:34:52.384 - debug: lovelace.0 (2374) Redis States: Use Redis connection: 127.0.0.1:9000
      2019-12-27 21:34:52.396 - debug: lovelace.0 (2374) States create PubSub Client
      2019-12-27 21:34:52.397 - debug: lovelace.0 (2374) statesDB connected
      2019-12-27 21:34:52.454 - debug: lovelace.0 (2374) States connected to redis: 127.0.0.1:9000
      2019-12-27 21:34:54.274 - info: lovelace.0 (2374) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.lovelace, node: v10.17.0
      2019-12-27 21:34:54.393 - debug: lovelace.0 (2374) Schedule restart: 0 2 * * *
      2019-12-27 21:34:54.429 - info: lovelace.0 (2374) http server listening on port 8091
      2019-12-27 21:34:54.983 - debug: lovelace.0 (2374) rgb - Controls: {
      "states": [
      "indicator": false,
      "type": "number",
      "write": true,
      "name": "RED",
      "required": true,
      "defaultRole": "level.color.red",
      "id": "shelly.0.SHRGBW2#5A38A7#1.color.red"
      "indicator": false,
      "type": "number",
      "write": true,
      "name": "GREEN",
      "required": true,
      "defaultRole": "level.color.green",
      "id": "shelly.0.SHRGBW2#5A38A7#1.color.green"
      "indicator": false,
      "type": "number",
      "write": true,
      "name": "BLUE",
      "required": true,
      "defaultRole": "level.color.blue",
      "id": "shelly.0.SHRGBW2#5A38A7#1.color.blue"
      "indicator": false,
      "type": "number",
      "write": true,
      "name": "DIMMER",
      "required": false,
      "defaultRole": "level.dimmer"
      "indicator": false,
      "type": "number",
      "write": true,
      "name": "BRIGHTNESS",
      "required": false,
      "id": "shelly.0.SHRGBW2#5A38A7#1.color.gain"
      "indicator": false,
      "type": "number",
      "write": true,
      "name": "SATURATION",
      "required": false
      "indicator": false,
      "type": "number",
      "write": true,
      "name": "TEMPERATURE",
      "required": false,
      "defaultRole": "level.color.temperature"
      "indicator": false,
      "type": "boolean",
      "write": true,
      "name": "ON_LIGHT",
      "required": false,
      "defaultRole": "switch.light"
      "indicator": false,
      "type": "boolean",
      "write": true,
      "name": "ON",
      "required": false,
      "id": "shelly.0.SHRGBW2#5A38A7#1.color.Switch"
      "indicator": false,
      "type": "boolean",
      "write": false,
      "name": "ON_ACTUAL",
      "required": false,
      "defaultRole": "state.light"
      "indicator": true,
      "name": "WORKING",
      "required": false,
      "defaultRole": "indicator.working"
      "indicator": true,
      "type": "boolean",
      "name": "UNREACH",
      "required": false,
      "defaultRole": "indicator.maintenance.unreach"
      "indicator": true,
      "type": "boolean",
      "name": "LOWBAT",
      "required": false,
      "defaultRole": "indicator.maintenance.lowbat"
      "indicator": true,
      "type": "boolean",
      "name": "MAINTAIN",
      "required": false,
      "defaultRole": "indicator.maintenance"
      "indicator": true,
      "name": "ERROR",
      "required": false,
      "defaultRole": "indicator.error"
      "type": "rgb"
      2019-12-27 21:34:54.989 - debug: lovelace.0 (2374) [Type-Detector] Created auto device: light.LED_Strips_Wohnzimmer - rgb - shelly.0.SHRGBW2#5A38A7#1.color
      2019-12-27 21:34:54.990 - warn: lovelace.0 (2374) Could not add shelly.0.SHRGBW2#5A38A7#1.color of type rgbSingle -> no on/off control found.
      2019-12-27 21:34:54.992 - warn: lovelace.0 (2374) Duplicates found for light.LED_Strips_Wohnzimmer
      2019-12-27 21:34:54.992 - debug: lovelace.0 (2374) [Type-Detector] device shelly.0.SHRGBW2#5A38A7#1.color.effect - info - shelly.0.SHRGBW2#5A38A7#1.color is not yet supported
      2019-12-27 21:34:54.998 - debug: lovelace.0 (2374) [Type-Detector] Created auto device: light.Switch - light - shelly.0.SHSW-1#12C27E#1.Relay0.Switch
      2019-12-27 21:34:55.003 - warn: lovelace.0 (2374) Duplicates found for light.Switch
      2019-12-27 21:34:55.008 - warn: lovelace.0 (2374) Duplicates found for light.Switch
      2019-12-27 21:34:55.012 - debug: lovelace.0 (2374) [Type-Detector] Created auto device: light.K_chenlicht_POWER - light - sonoff.0.Küchenlicht.POWER
      2019-12-27 21:34:55.019 - debug: lovelace.0 (2374) [Type-Detector] Created auto device: light.Nachtlicht_Benchy_POWER - light - sonoff.0.Nachtlicht Benchy.POWER
      2019-12-27 21:34:55.034 - debug: lovelace.0 (2374) [Type-Detector] Created auto device: light.Nachtlicht_Flur - light - sonoff.0.Nachtlicht Flur
      2019-12-27 21:34:55.035 - debug: lovelace.0 (2374) [Type-Detector] device sonoff.0.Nachtlicht Flur.Time - info - sonoff.0.Nachtlicht Flur is not yet supported
      2019-12-27 21:34:55.039 - debug: lovelace.0 (2374) [Type-Detector] Created auto device: light.Nachtlicht_Liah_POWER - light - sonoff.0.Nachtlicht Liah.POWER
      2019-12-27 21:34:55.043 - debug: lovelace.0 (2374) [Type-Detector] Created auto device: light.Nachtlicht_Marcus_POWER - light - sonoff.0.Nachtlicht Marcus.POWER
      2019-12-27 21:34:55.047 - debug: lovelace.0 (2374) [Type-Detector] Created auto device: light.Schreibtischlampe_POWER - light - sonoff.0.Schreibtischlampe.POWER
      2019-12-27 21:34:55.063 - debug: lovelace.0 (2374) [Type-Detector] Created auto device: light.Weihnachtsbaum - light - sonoff.0.Weihnachtsbaum
      2019-12-27 21:34:55.063 - debug: lovelace.0 (2374) [Type-Detector] device sonoff.0.Weihnachtsbaum.Time - info - sonoff.0.Weihnachtsbaum is not yet supported
      2019-12-27 21:34:55.068 - debug: lovelace.0 (2374) [Type-Detector] device lgtv.0.states.volume - info - lgtv.0.states.volume is not yet supported
      2019-12-27 21:34:55.074 - debug: lovelace.0 (2374) [Type-Detector] Created auto device: switch.Switch_TV_power - socket - lgtv.0.states.power
      2019-12-27 21:34:55.078 - debug: lovelace.0 (2374) [Type-Detector] device lgtv.0.states.launch - info - lgtv.0.states.launch is not yet supported
      2019-12-27 21:34:55.082 - debug: lovelace.0 (2374) [Type-Detector] Created auto device: switch.TV_Steckdose_POWER - socket - sonoff.0.TV Steckdose.POWER
      2019-12-27 21:34:55.085 - debug: lovelace.0 (2374) [Type-Detector] Created auto device: switch.switch_on - socket - tuya.0.17014830b4e62d5a02cc.1
      2019-12-27 21:34:55.090 - debug: lovelace.0 (2374) [Type-Detector] device chromecast.0.Küche.status.volume - volume - chromecast.0.Küche.status.volume is not yet supported
      2019-12-27 21:34:55.094 - debug: lovelace.0 (2374) [Type-Detector] device chromecast.0.Schlafzimmer.status.volume - volume - chromecast.0.Schlafzimmer.status.volume is not yet supported
      2019-12-27 21:34:55.098 - debug: lovelace.0 (2374) [Type-Detector] device chromecast.0.WohnzimmerJBL.status.volume - volume - chromecast.0.WohnzimmerJBL.status.volume is not yet supported
      2019-12-27 21:34:55.101 - debug: lovelace.0 (2374) [Type-Detector] device zigbee.0.000b57fffe897c9a.battery - info - zigbee.0.000b57fffe897c9a.battery is not yet supported
      2019-12-27 21:34:55.104 - debug: lovelace.0 (2374) [Type-Detector] device zigbee.0.00158d000320258a.battery - info - zigbee.0.00158d000320258a.battery is not yet supported
      2019-12-27 21:34:55.107 - debug: lovelace.0 (2374) [Type-Detector] device zigbee.0.ccccccfffe31ffb8.battery - info - zigbee.0.ccccccfffe31ffb8.battery is not yet supported
      2019-12-27 21:34:55.110 - debug: lovelace.0 (2374) [Type-Detector] device zigbee.0.00158d0003d53cb8.battery - info - zigbee.0.00158d0003d53cb8.battery is not yet supported
      2019-12-27 21:34:55.185 - debug: lovelace.0 (2374) [Type-Detector] Created auto device: weather.Gaggenau__Baden_W_rttemberg_Deutschland_ - weatherForecast - daswetter.0.NextDays.Location_1
      2019-12-27 21:34:55.185 - debug: lovelace.0 (2374) [Type-Detector] device daswetter.0.NextDays.Location_1.Day_1.Wetter_Symbol_id - info - daswetter.0.NextDays.Location_1 is not yet supported
      2019-12-27 21:34:55.186 - debug: lovelace.0 (2374) [Type-Detector] device scene.0.Bettfertig - info - scene.0.Bettfertig is not yet supported
      2019-12-27 21:34:55.188 - debug: lovelace.0 (2374) [Type-Detector] device scene.0.Fernsehabend - info - scene.0.Fernsehabend is not yet supported
      2019-12-27 21:34:55.199 - debug: lovelace.0 (2374) rgbSingle - Controls: {
      "states": [
      "indicator": false,
      "type": "string",
      "write": true,
      "name": "RGB",
      "required": true,
      "defaultRole": "level.color.rgb",
      "id": "zigbee.0.ccccccfffe5c48af.color"
      "indicator": false,
      "type": "number",
      "write": true,
      "name": "DIMMER",
      "required": false,
      "defaultRole": "level.dimmer",
      "id": "zigbee.0.ccccccfffe5c48af.brightness"
      "indicator": false,
      "type": "number",
      "write": true,
      "required": false
      "indicator": false,
      "type": "number",
      "write": true,
      "required": false
      "indicator": false,
      "type": "number",
      "write": true,
      "required": false,
      "defaultRole": "level.color.temperature",
      "id": "zigbee.0.ccccccfffe5c48af.colortemp"
      "indicator": false,
      "type": "boolean",
      "write": true,
      "name": "ON_LIGHT",
      "required": false,
      "indicator": false,
      "type": "boolean",
      "write": true,
      "name": "ON",
      "required": false,
      "id": "zigbee.0.ccccccfffe5c48af.state"
      "indicator": false,
      "type": "boolean",
      "write": false,
      "required": false,
      "defaultRole": "state.light",
      "id": "zigbee.0.ccccccfffe5c48af.available"
      "indicator": true,
      "name": "WORKING",
      "required": false,
      "indicator": true,
      "type": "boolean",
      "name": "UNREACH",
      "required": false,
      "indicator": true,
      "type": "boolean",
      "name": "LOWBAT",
      "required": false,
      "indicator": true,
      "type": "boolean",
      "name": "MAINTAIN",
      "required": false,
      "indicator": true,
      "name": "ERROR",
      "required": false,
      "type": "rgbSingle"
      2019-12-27 21:34:55.200 - warn: lovelace.0 (2374) no max value for light object 'zigbee.0.ccccccfffe5c48af.colortemp' defined -> using fallback max = '153'
      2019-12-27 21:34:55.201 - warn: lovelace.0 (2374) no min value for light object 'zigbee.0.ccccccfffe5c48af.colortemp' defined -> using fallback max = '450'
      2019-12-27 21:34:55.201 - debug: lovelace.0 (2374) light.Stehlampe ct needs kelvin conversion: false
      2019-12-27 21:34:55.202 - debug: lovelace.0 (2374) Color already present, skip R,G,B color.
      2019-12-27 21:34:55.202 - debug: lovelace.0 (2374) [Type-Detector] Created auto device: light.Stehlampe - rgbSingle - zigbee.0.ccccccfffe5c48af
      2019-12-27 21:34:55.202 - debug: lovelace.0 (2374) [Type-Detector] device zigbee.0.ccccccfffe5c48af.groups - info - zigbee.0.ccccccfffe5c48af is not yet supported
      2019-12-27 21:34:55.203 - debug: lovelace.0 (2374) AUTO Device detected: shelly.0.SHRGBW2#5A38A7#1.color => light
      2019-12-27 21:34:55.204 - debug: lovelace.0 (2374) AUTO Device detected: shelly.0.SHSW-1#12C27E#1.Relay0.Switch => light
      2019-12-27 21:34:55.204 - debug: lovelace.0 (2374) AUTO Device detected: sonoff.0.Küchenlicht.POWER => light
      2019-12-27 21:34:55.204 - debug: lovelace.0 (2374) AUTO Device detected: sonoff.0.Nachtlicht Benchy.POWER => light
      2019-12-27 21:34:55.204 - debug: lovelace.0 (2374) AUTO Device detected: sonoff.0.Nachtlicht Flur => light
      2019-12-27 21:34:55.205 - debug: lovelace.0 (2374) AUTO Device detected: sonoff.0.Nachtlicht Liah.POWER => light
      2019-12-27 21:34:55.205 - debug: lovelace.0 (2374) AUTO Device detected: sonoff.0.Nachtlicht Marcus.POWER => light
      2019-12-27 21:34:55.205 - debug: lovelace.0 (2374) AUTO Device detected: sonoff.0.Schreibtischlampe.POWER => light
      2019-12-27 21:34:55.205 - debug: lovelace.0 (2374) AUTO Device detected: sonoff.0.Weihnachtsbaum => light
      2019-12-27 21:34:55.205 - debug: lovelace.0 (2374) AUTO Device detected: lgtv.0.states.power => switch
      2019-12-27 21:34:55.206 - debug: lovelace.0 (2374) AUTO Device detected: sonoff.0.TV Steckdose.POWER => switch
      2019-12-27 21:34:55.206 - debug: lovelace.0 (2374) AUTO Device detected: tuya.0.17014830b4e62d5a02cc.1 => switch
      2019-12-27 21:34:55.206 - debug: lovelace.0 (2374) AUTO Device detected: daswetter.0.NextDays.Location_1 => weather
      2019-12-27 21:34:55.206 - debug: lovelace.0 (2374) AUTO Device detected: zigbee.0.ccccccfffe5c48af => light
      2019-12-27 21:34:55.293 - debug: lovelace.0 (2374) Create manual device: sensor.CPU_Temperatur - info.0.sysinfo.cpu.temperature.main
      2019-12-27 21:34:55.298 - debug: lovelace.0 (2374) Create manual device: input_select.tv_launch - lgtv.0.states.launch
      2019-12-27 21:34:55.303 - debug: lovelace.0 (2374) Create manual device: input_number.FernseherVolume - lgtv.0.states.volume
      2019-12-27 21:34:55.306 - debug: lovelace.0 (2374) Create manual device: media_player.tv_remote_rewind - lgtv.0.states.mediaRewind
      2019-12-27 21:34:55.309 - debug: lovelace.0 (2374) Create manual device: media_player.tv_remote_forward - lgtv.0.states.mediaFastForward
      2019-12-27 21:34:55.313 - debug: lovelace.0 (2374) Create manual device: media_player.tv_pause - lgtv.0.states.mediaPause
      2019-12-27 21:34:55.316 - debug: lovelace.0 (2374) Create manual device: media_player.tv_remote_play - lgtv.0.states.mediaPlay
      2019-12-27 21:34:55.318 - debug: lovelace.0 (2374) Create manual device: media_player.tv_channel_down - lgtv.0.states.channelDown
      2019-12-27 21:34:55.321 - debug: lovelace.0 (2374) Create manual device: media_player.tv_channel_up - lgtv.0.states.channelUp
      2019-12-27 21:34:55.325 - debug: lovelace.0 (2374) Create manual device: media_player.tv_volume_down - lgtv.0.states.volumeDown
      2019-12-27 21:34:55.329 - debug: lovelace.0 (2374) Create manual device: media_player.tv_volume_up - lgtv.0.states.volumeUp
      2019-12-27 21:34:55.332 - debug: lovelace.0 (2374) Create manual device: switch.tv_remote_mute - lgtv.0.states.mute
      2019-12-27 21:34:55.334 - debug: lovelace.0 (2374) Create manual device: light.Schlafzimmerlicht - shelly.0.SHSW-1#12C27E#1.Relay0.Switch
      2019-12-27 21:34:55.337 - debug: lovelace.0 (2374) Create manual device: light.Wohnzimmerlicht - shelly.0.SHSW-1#94147C#1.Relay0.Switch
      2019-12-27 21:34:55.340 - debug: lovelace.0 (2374) Create manual device: switch.Fernseher - javascript.0.scriptEnabled.Vis.Fernseher_Power
      2019-12-27 21:34:55.344 - debug: lovelace.0 (2374) Create manual device: light.Flurlicht - shelly.0.SHSW-1#943F39#1.Relay0.Switch
      2019-12-27 21:34:55.351 - debug: lovelace.0 (2374) Create manual device: sensor.pve_cpu_utilization - proxmox.0.node_pve.cpu
      2019-12-27 21:34:55.354 - debug: lovelace.0 (2374) Create manual device: sensor.server_ram_auslastung - proxmox.0.node_pve.memory.used_lev
      2019-12-27 21:34:55.357 - debug: lovelace.0 (2374) Create manual device: sensor.akku_bm_flur - zigbee.0.00158d000320258a.battery
      2019-12-27 21:34:55.360 - debug: lovelace.0 (2374) Create manual device: input_boolean.Schreibtisch - tuya.0.17014830b4e62d5a02cc.1
      2019-12-27 21:34:55.364 - debug: lovelace.0 (2374) Create manual device: sensor.Schreibtisch_Strom - tuya.0.17014830b4e62d5a02cc.4
      2019-12-27 21:34:55.368 - debug: lovelace.0 (2374) Create manual device: input_number.GHomeWohnzimmer - chromecast.0.WohnzimmerJBL.status.volume
      2019-12-27 21:34:55.372 - debug: lovelace.0 (2374) Create manual device: input_number.GHomeSchlafzimmer - chromecast.0.Schlafzimmer.status.volume
      2019-12-27 21:34:55.376 - debug: lovelace.0 (2374) Create manual device: input_number.GHomeKueche - chromecast.0.Küche.status.volume
      2019-12-27 21:34:55.379 - debug: lovelace.0 (2374) Create manual device: input_boolean.zuruck - broadlink2.0.RM:RMMINI-40-7c-2f.L.CODE_26001a000f07064d0c6a0c0001d009000265090002440f0006470a000d050000000000000000000000000000
      2019-12-27 21:34:55.383 - debug: lovelace.0 (2374) Create manual device: light.Schreibtischlampe - sonoff.0.Schreibtischlampe.POWER
      2019-12-27 21:34:55.385 - debug: lovelace.0 (2374) Create manual device: sensor.MaxDownstream - upnp.0.WANDevice_-_FRITZ!Box_6490_Cable.WANDevice.WANCommonInterfaceConfig.GetCommonLinkProperties.DownstreamMaxKbit
      2019-12-27 21:34:55.389 - debug: lovelace.0 (2374) Create manual device: sensor.MaxUpstream - upnp.0.WANDevice_-_FRITZ!Box_6490_Cable.WANDevice.WANCommonInterfaceConfig.GetCommonLinkProperties.UpstreamMaxKbit
      2019-12-27 21:34:55.393 - debug: lovelace.0 (2374) Create manual device: sensor.akku_dimmer - zigbee.0.000b57fffe897c9a.battery
      2019-12-27 21:34:55.396 - debug: lovelace.0 (2374) Create manual device: media_player.tv_remote_home - lgtv.0.remote.home
      2019-12-27 21:34:55.399 - debug: lovelace.0 (2374) Create manual device: media_player.tv_remote_menu - lgtv.0.remote.menu
      2019-12-27 21:34:55.402 - debug: lovelace.0 (2374) Create manual device: media_player.tv_remote_back - lgtv.0.remote.back
      2019-12-27 21:34:55.410 - debug: lovelace.0 (2374) Create manual device: media_player.tv_remote_up - lgtv.0.remote.up
      2019-12-27 21:34:55.414 - debug: lovelace.0 (2374) Create manual device: media_player.tv_remote_down - lgtv.0.remote.down
      2019-12-27 21:34:55.417 - debug: lovelace.0 (2374) Create manual device: media_player.tv_remote_left - lgtv.0.remote.left
      2019-12-27 21:34:55.420 - debug: lovelace.0 (2374) Create manual device: media_player.tv_remote_right - lgtv.0.remote.right
      2019-12-27 21:34:55.423 - debug: lovelace.0 (2374) Create manual device: media_player.tv_remote_enter - lgtv.0.remote.enter
      2019-12-27 21:34:55.426 - debug: lovelace.0 (2374) Create manual device: sensor.akku_switch_marcus - zigbee.0.00158d00026ebcbf.battery
      2019-12-27 21:34:55.430 - debug: lovelace.0 (2374) Create manual device: sensor.energie_gesamt - sonoff.0.Zähler Verteiler.ENERGY_Total
      2019-12-27 21:34:55.433 - debug: lovelace.0 (2374) Create manual device: sensor.energie_heute - sonoff.0.Zähler Verteiler.ENERGY_Today
      2019-12-27 21:34:55.436 - debug: lovelace.0 (2374) Create manual device: sensor.l1_leistung - sonoff.0.Zähler Verteiler.ENERGY_Power_0
      2019-12-27 21:34:55.440 - debug: lovelace.0 (2374) Create manual device: sensor.l2_leistung - sonoff.0.Zähler Verteiler.ENERGY_Power_1
      2019-12-27 21:34:55.443 - debug: lovelace.0 (2374) Create manual device: sensor.l3_leistung - sonoff.0.Zähler Verteiler.ENERGY_Power_2
      2019-12-27 21:34:55.446 - debug: lovelace.0 (2374) Create manual device: sensor.l1_spannung - sonoff.0.Zähler Verteiler.ENERGY_Voltage_0
      2019-12-27 21:34:55.449 - debug: lovelace.0 (2374) Create manual device: sensor.l2_spannung - sonoff.0.Zähler Verteiler.ENERGY_Voltage_1
      2019-12-27 21:34:55.452 - debug: lovelace.0 (2374) Create manual device: sensor.l3_spannung - sonoff.0.Zähler Verteiler.ENERGY_Voltage_2
      2019-12-27 21:34:55.456 - debug: lovelace.0 (2374) Create manual device: sensor.l1_strom - sonoff.0.Zähler Verteiler.ENERGY_Current_0
      2019-12-27 21:34:55.459 - debug: lovelace.0 (2374) Create manual device: sensor.l2_strom - sonoff.0.Zähler Verteiler.ENERGY_Current_1
      2019-12-27 21:34:55.462 - debug: lovelace.0 (2374) Create manual device: sensor.l3_strom - sonoff.0.Zähler Verteiler.ENERGY_Current_2
      2019-12-27 21:34:55.466 - debug: lovelace.0 (2374) Create manual device: sensor.akku_stehlampe_schalter - zigbee.0.ccccccfffe31ffb8.battery
      2019-12-27 21:34:55.469 - debug: lovelace.0 (2374) Create manual device: light.nachtlicht_flur - sonoff.0.Nachtlicht Flur.POWER
      2019-12-27 21:34:55.472 - debug: lovelace.0 (2374) Create manual device: sensor.akku_tür_sensor - zigbee.0.00158d0003d53cb8.battery
      2019-12-27 21:34:55.475 - debug: lovelace.0 (2374) Create manual device: switch.green - 0_userdata.0.Lovelace.Emulate.wohnzimmer_grün
      2019-12-27 21:34:55.478 - debug: lovelace.0 (2374) Create manual device: switch.blue - 0_userdata.0.Lovelace.Emulate.wohnzimmer_blau
      2019-12-27 21:34:55.481 - debug: lovelace.0 (2374) Create manual device: switch.red - 0_userdata.0.Lovelace.Emulate.wohnzimmer_red
      2019-12-27 21:34:55.484 - debug: lovelace.0 (2374) Create manual device: switch.turkis - 0_userdata.0.Lovelace.Emulate.wohnzimmer_turkis
      2019-12-27 21:34:55.487 - debug: lovelace.0 (2374) Create manual device: switch.violett - 0_userdata.0.Lovelace.Emulate.wohnzimmer_violtett
      2019-12-27 21:34:55.490 - debug: lovelace.0 (2374) Create manual device: switch.warmweiß - 0_userdata.0.Lovelace.Emulate.wohnzimmer_warmweiß
      2019-12-27 21:34:55.494 - debug: lovelace.0 (2374) Create manual device: switch.kaltweiß - 0_userdata.0.Lovelace.Emulate.wohnzimmer_kaltweiß
      2019-12-27 21:34:55.497 - debug: lovelace.0 (2374) Create manual device: switch.v_up_ghome_wohnzimmer - 0_userdata.0.Lovelace.Emulate.v_up_ghome_wohnzimmer
      2019-12-27 21:34:55.499 - debug: lovelace.0 (2374) Create manual device: switch.v_down_ghome_wohnzimmer - 0_userdata.0.Lovelace.Emulate.v_down_ghome_wohnzimmer
      2019-12-27 21:34:55.502 - debug: lovelace.0 (2374) Create manual device: switch.tv_remote_netflix - 0_userdata.0.Lovelace.Emulate.launch_netflix
      2019-12-27 21:34:55.506 - debug: lovelace.0 (2374) Create manual device: switch.tv_remote_amazon - 0_userdata.0.Lovelace.Emulate.launch_amazon
      2019-12-27 21:34:55.509 - debug: lovelace.0 (2374) Create manual device: switch.v_down_ghome_kueche - 0_userdata.0.Lovelace.Emulate.v_down_ghome_kueche
      2019-12-27 21:34:55.512 - debug: lovelace.0 (2374) Create manual device: switch.v_up_ghome_kueche - 0_userdata.0.Lovelace.Emulate.v_up_ghome_kueche
      2019-12-27 21:34:55.516 - debug: lovelace.0 (2374) Create manual device: switch.v_down_ghome_schlafzimmer - 0_userdata.0.Lovelace.Emulate.v_down_ghome_schlafzimmer
      2019-12-27 21:34:55.518 - debug: lovelace.0 (2374) Create manual device: switch.v_up_ghome_schlafzimmer - 0_userdata.0.Lovelace.Emulate.v_up_ghome_schlafzimmer
      2019-12-27 21:34:55.521 - debug: lovelace.0 (2374) Create manual device: switch.fernsehabend - scene.0.Fernsehabend
      2019-12-27 21:34:55.525 - debug: lovelace.0 (2374) Create manual device: switch.rgb_syncron - 0_userdata.0.Automation.rgb_syncron
      2019-12-27 21:34:55.528 - debug: lovelace.0 (2374) Create manual device: switch.schreibtischsteckdose_automatik - 0_userdata.0.Automation.schreibtischsteckdose_automatik_aus
      2019-12-27 21:34:55.531 - debug: lovelace.0 (2374) Create manual device: switch.flurlicht_automatik - 0_userdata.0.Automation.flurlicht_automatik
      2019-12-27 21:34:55.535 - debug: lovelace.0 (2374) Create manual device: switch.zentral_aus - 0_userdata.0.Zentral_Funktionen.zentral_aus
      2019-12-27 21:34:55.538 - debug: lovelace.0 (2374) Create manual device: switch.led_strips_automatik - 0_userdata.0.Automation.led_strips_automatik
      2019-12-27 21:34:55.541 - debug: lovelace.0 (2374) Create manual device: switch.bettfertig - scene.0.Bettfertig
      2019-12-27 21:34:55.545 - debug: lovelace.0 (2374) Create manual device: alarm_control_panel.defaultAlarm - lovelace.0.control.alarm
      2019-12-27 21:34:55.593 - debug: lovelace.0 (2374) light.LED_Strips_Wohnzimmer got [0,100,100] from Red 255 and {"r":186,"g":0,"b":0} and old hsv [0,100,73]
      2019-12-27 21:34:55.594 - debug: lovelace.0 (2374) light.LED_Strips_Wohnzimmer got [0,100,72.94117647058823] from Green 0 and {"r":186,"g":0,"b":0} and old hsv [0,100,73]
      2019-12-27 21:34:55.595 - debug: lovelace.0 (2374) light.LED_Strips_Wohnzimmer got [0,100,72.94117647058823] from Blue 0 and {"r":186,"g":0,"b":0} and old hsv [0,100,73]
      2019-12-27 21:34:55.837 - debug: lovelace.0 (2374) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_1.iconURL
      2019-12-27 21:34:55.840 - debug: lovelace.0 (2374) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_1.Maximale_Temperatur_value
      2019-12-27 21:34:55.841 - debug: lovelace.0 (2374) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_2.iconURL
      2019-12-27 21:34:55.842 - debug: lovelace.0 (2374) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_2.Maximale_Temperatur_value
      2019-12-27 21:34:55.843 - debug: lovelace.0 (2374) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_2.Minimale_Temperatur_value
      2019-12-27 21:34:55.844 - debug: lovelace.0 (2374) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_3.iconURL
      2019-12-27 21:34:55.845 - debug: lovelace.0 (2374) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_3.Maximale_Temperatur_value
      2019-12-27 21:34:55.847 - debug: lovelace.0 (2374) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_3.Minimale_Temperatur_value
      2019-12-27 21:34:55.848 - debug: lovelace.0 (2374) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_4.iconURL
      2019-12-27 21:34:55.849 - debug: lovelace.0 (2374) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_4.Maximale_Temperatur_value
      2019-12-27 21:34:55.850 - debug: lovelace.0 (2374) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_4.Minimale_Temperatur_value
      2019-12-27 21:34:55.851 - debug: lovelace.0 (2374) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_5.iconURL
      2019-12-27 21:34:55.852 - debug: lovelace.0 (2374) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_5.Maximale_Temperatur_value
      2019-12-27 21:34:55.853 - debug: lovelace.0 (2374) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_5.Minimale_Temperatur_value
      2019-12-27 21:34:55.855 - debug: lovelace.0 (2374) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_6.iconURL
      2019-12-27 21:34:55.856 - debug: lovelace.0 (2374) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_6.Maximale_Temperatur_value
      2019-12-27 21:34:55.857 - debug: lovelace.0 (2374) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_6.Minimale_Temperatur_value
      2019-12-27 21:34:55.858 - debug: lovelace.0 (2374) IoB Subscribe on 0_userdata.0.Zentral_Funktionen.zentral_aus
      2019-12-27 21:34:55.859 - debug: lovelace.0 (2374) IoB Subscribe on scene.0.Bettfertig
      2019-12-27 21:34:55.860 - debug: lovelace.0 (2374) IoB Subscribe on scene.0.Fernsehabend
      2019-12-27 21:34:55.861 - debug: lovelace.0 (2374) IoB Subscribe on shelly.0.SHSW-1#943F39#1.Relay0.Switch
      2019-12-27 21:34:55.863 - debug: lovelace.0 (2374) IoB Subscribe on shelly.0.SHSW-1#12C27E#1.Relay0.Switch
      2019-12-27 21:34:55.864 - debug: lovelace.0 (2374) IoB Subscribe on sonoff.0.Nachtlicht Benchy.POWER
      2019-12-27 21:34:55.865 - debug: lovelace.0 (2374) IoB Subscribe on shelly.0.SHSW-1#94147C#1.Relay0.Switch
      2019-12-27 21:34:55.866 - debug: lovelace.0 (2374) IoB Subscribe on zigbee.0.ccccccfffe5c48af.state
      2019-12-27 21:34:55.867 - debug: lovelace.0 (2374) IoB Subscribe on zigbee.0.ccccccfffe5c48af.colortemp
      2019-12-27 21:34:55.870 - debug: lovelace.0 (2374) IoB Subscribe on zigbee.0.ccccccfffe5c48af.brightness
      2019-12-27 21:34:55.872 - debug: lovelace.0 (2374) IoB Subscribe on zigbee.0.ccccccfffe5c48af.color
      2019-12-27 21:34:55.873 - debug: lovelace.0 (2374) IoB Subscribe on shelly.0.SHRGBW2#5A38A7#1.color.white
      2019-12-27 21:34:55.873 - debug: lovelace.0 (2374) IoB Subscribe on sonoff.0.Nachtlicht Liah.POWER
      2019-12-27 21:34:55.874 - debug: lovelace.0 (2374) IoB Subscribe on sonoff.0.Küchenlicht.POWER
      2019-12-27 21:34:55.875 - debug: lovelace.0 (2374) IoB Subscribe on sonoff.0.Schreibtischlampe.POWER
      2019-12-27 21:34:55.877 - debug: lovelace.0 (2374) IoB Subscribe on sonoff.0.Nachtlicht Flur.POWER
      2019-12-27 21:34:55.878 - debug: lovelace.0 (2374) IoB Subscribe on sonoff.0.Weihnachtsbaum.POWER
      2019-12-27 21:34:55.878 - debug: lovelace.0 (2374) IoB Subscribe on sonoff.0.TV Steckdose.POWER
      2019-12-27 21:34:55.879 - debug: lovelace.0 (2374) IoB Subscribe on tuya.0.17014830b4e62d5a02cc.1
      2019-12-27 21:34:55.880 - debug: lovelace.0 (2374) IoB Subscribe on 0_userdata.0.Automation.schreibtischsteckdose_automatik_aus
      2019-12-27 21:34:55.881 - debug: lovelace.0 (2374) IoB Subscribe on 0_userdata.0.Automation.rgb_syncron
      2019-12-27 21:34:55.881 - debug: lovelace.0 (2374) IoB Subscribe on 0_userdata.0.Automation.led_strips_automatik
      2019-12-27 21:34:55.882 - debug: lovelace.0 (2374) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.wohnzimmer_red
      2019-12-27 21:34:55.883 - debug: lovelace.0 (2374) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.wohnzimmer_blau
      2019-12-27 21:34:55.884 - debug: lovelace.0 (2374) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.wohnzimmer_grün
      2019-12-27 21:34:55.885 - debug: lovelace.0 (2374) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.wohnzimmer_violtett
      2019-12-27 21:34:55.886 - debug: lovelace.0 (2374) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.wohnzimmer_turkis
      2019-12-27 21:34:55.886 - debug: lovelace.0 (2374) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.wohnzimmer_warmweiß
      2019-12-27 21:34:55.887 - debug: lovelace.0 (2374) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.wohnzimmer_kaltweiß
      2019-12-27 21:34:55.888 - debug: lovelace.0 (2374) IoB Subscribe on sonoff.0.Nachtlicht Marcus.POWER
      2019-12-27 21:34:55.889 - debug: lovelace.0 (2374) IoB Subscribe on 0_userdata.0.Automation.flurlicht_automatik
      2019-12-27 21:34:55.890 - debug: lovelace.0 (2374) IoB Subscribe on lgtv.0.states.power
      2019-12-27 21:34:55.891 - debug: lovelace.0 (2374) IoB Subscribe on lgtv.0.remote.back
      2019-12-27 21:34:55.892 - debug: lovelace.0 (2374) IoB Subscribe on lgtv.0.remote.menu
      2019-12-27 21:34:55.893 - debug: lovelace.0 (2374) IoB Subscribe on lgtv.0.remote.home
      2019-12-27 21:34:55.893 - debug: lovelace.0 (2374) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.launch_netflix
      2019-12-27 21:34:55.894 - debug: lovelace.0 (2374) IoB Subscribe on lgtv.0.remote.up
      2019-12-27 21:34:55.895 - debug: lovelace.0 (2374) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.launch_amazon
      2019-12-27 21:34:55.896 - debug: lovelace.0 (2374) IoB Subscribe on lgtv.0.remote.left
      2019-12-27 21:34:55.897 - debug: lovelace.0 (2374) IoB Subscribe on lgtv.0.remote.enter
      2019-12-27 21:34:55.898 - debug: lovelace.0 (2374) IoB Subscribe on lgtv.0.remote.right
      2019-12-27 21:34:55.898 - debug: lovelace.0 (2374) IoB Subscribe on lgtv.0.remote.down
      2019-12-27 21:34:55.899 - debug: lovelace.0 (2374) IoB Subscribe on lgtv.0.states.channelUp
      2019-12-27 21:34:55.900 - debug: lovelace.0 (2374) IoB Subscribe on lgtv.0.states.channelDown
      2019-12-27 21:34:55.901 - debug: lovelace.0 (2374) IoB Subscribe on lgtv.0.states.mediaRewind
      2019-12-27 21:34:55.902 - debug: lovelace.0 (2374) IoB Subscribe on lgtv.0.states.mediaPlay
      2019-12-27 21:34:55.903 - debug: lovelace.0 (2374) IoB Subscribe on lgtv.0.states.mediaFastForward
      2019-12-27 21:34:55.904 - debug: lovelace.0 (2374) IoB Subscribe on lgtv.0.states.volumeDown
      2019-12-27 21:34:55.905 - debug: lovelace.0 (2374) IoB Subscribe on lgtv.0.states.mute
      2019-12-27 21:34:55.905 - debug: lovelace.0 (2374) IoB Subscribe on lgtv.0.states.volumeUp
      2019-12-27 21:34:55.906 - debug: lovelace.0 (2374) IoB Subscribe on lgtv.0.states.launch
      2019-12-27 21:34:55.908 - debug: lovelace.0 (2374) IoB Subscribe on chromecast.0.WohnzimmerJBL.status.volume
      2019-12-27 21:34:55.908 - debug: lovelace.0 (2374) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.v_down_ghome_wohnzimmer
      2019-12-27 21:34:55.909 - debug: lovelace.0 (2374) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.v_up_ghome_wohnzimmer
      2019-12-27 21:34:55.910 - debug: lovelace.0 (2374) IoB Subscribe on chromecast.0.Küche.status.volume
      2019-12-27 21:34:55.911 - debug: lovelace.0 (2374) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.v_down_ghome_kueche
      2019-12-27 21:34:55.912 - debug: lovelace.0 (2374) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.v_up_ghome_kueche
      2019-12-27 21:34:55.913 - debug: lovelace.0 (2374) IoB Subscribe on chromecast.0.Schlafzimmer.status.volume
      2019-12-27 21:34:55.914 - debug: lovelace.0 (2374) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.v_down_ghome_schlafzimmer
      2019-12-27 21:34:55.914 - debug: lovelace.0 (2374) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.v_up_ghome_schlafzimmer
      2019-12-27 21:34:55.915 - debug: lovelace.0 (2374) IoB Subscribe on upnp.0.WANDevice_-_FRITZ!Box_6490_Cable.WANDevice.WANCommonInterfaceConfig.GetCommonLinkProperties.DownstreamMaxKbit
      2019-12-27 21:34:55.916 - debug: lovelace.0 (2374) IoB Subscribe on upnp.0.WANDevice_-_FRITZ!Box_6490_Cable.WANDevice.WANCommonInterfaceConfig.GetCommonLinkProperties.UpstreamMaxKbit
      2019-12-27 21:34:55.917 - debug: lovelace.0 (2374) IoB Subscribe on sonoff.0.Zähler Verteiler.ENERGY_Current_0
      2019-12-27 21:34:55.918 - debug: lovelace.0 (2374) IoB Subscribe on sonoff.0.Zähler Verteiler.ENERGY_Current_1
      2019-12-27 21:34:55.919 - debug: lovelace.0 (2374) IoB Subscribe on sonoff.0.Zähler Verteiler.ENERGY_Current_2
      2019-12-27 21:34:55.920 - debug: lovelace.0 (2374) IoB Subscribe on sonoff.0.Zähler Verteiler.ENERGY_Power_0
      2019-12-27 21:34:55.921 - debug: lovelace.0 (2374) IoB Subscribe on sonoff.0.Zähler Verteiler.ENERGY_Power_1
      2019-12-27 21:34:55.922 - debug: lovelace.0 (2374) IoB Subscribe on sonoff.0.Zähler Verteiler.ENERGY_Power_2
      2019-12-27 21:34:55.923 - debug: lovelace.0 (2374) IoB Subscribe on sonoff.0.Zähler Verteiler.ENERGY_Today
      2019-12-27 21:34:55.923 - debug: lovelace.0 (2374) IoB Subscribe on zigbee.0.00158d00026ebcbf.battery
      2019-12-27 21:34:55.924 - debug: lovelace.0 (2374) IoB Subscribe on zigbee.0.000b57fffe897c9a.battery
      2019-12-27 21:34:55.925 - debug: lovelace.0 (2374) IoB Subscribe on zigbee.0.00158d000320258a.battery
      2019-12-27 21:34:55.926 - debug: lovelace.0 (2374) IoB Subscribe on zigbee.0.ccccccfffe31ffb8.battery
      2019-12-27 21:34:55.927 - debug: lovelace.0 (2374) IoB Subscribe on zigbee.0.00158d0003d53cb8.battery
      2019-12-27 21:34:58.092 - debug: lovelace.0 (2374) HASS Auth: no_token
      2019-12-27 21:34:58.405 - debug: lovelace.0 (2374) HASS Subscribe: state_changed
      2019-12-27 21:34:58.408 - debug: lovelace.0 (2374) HASS Subscribe: component_loaded
      2019-12-27 21:34:58.409 - debug: lovelace.0 (2374) HASS Subscribe: core_config_updated
      2019-12-27 21:34:58.409 - debug: lovelace.0 (2374) HASS Subscribe: service_registered
      2019-12-27 21:34:58.410 - debug: lovelace.0 (2374) HASS Subscribe: service_removed
      2019-12-27 21:34:58.411 - debug: lovelace.0 (2374) HASS Subscribe: panels_updated
      2019-12-27 21:34:58.412 - debug: lovelace.0 (2374) HASS Subscribe: themes_updated
      2019-12-27 21:34:58.412 - debug: lovelace.0 (2374) HASS Subscribe: lovelace_updated
      2019-12-27 21:34:58.413 - debug: lovelace.0 (2374) HASS Subscribe: persistent_notifications_updated
      2019-12-27 21:34:58.440 - debug: lovelace.0 (2374) get config: false
      2019-12-27 21:34:58.441 - debug: lovelace.0 (2374) Get translations: de
      2019-12-27 21:34:58.893 - debug: lovelace.0 (2374) HASS UnSubscribe: {"type":"unsubscribe_events","subscription":10,"id":20}
      2019-12-27 21:34:58.895 - debug: lovelace.0 (2374) HASS Subscribe: persistent_notifications_updated
      2019-12-27 21:34:59.290 - debug: lovelace.0 (2374) Add custom cards: background.jpg as jpg
      2019-12-27 21:34:59.291 - debug: lovelace.0 (2374) Add custom cards: battery-entity.js as js
      2019-12-27 21:34:59.291 - debug: lovelace.0 (2374) Add custom cards: button-card.js as js
      2019-12-27 21:34:59.292 - debug: lovelace.0 (2374) Add custom cards: button-entity-row.js as js
      2019-12-27 21:34:59.292 - debug: lovelace.0 (2374) Add custom cards: compact-custom-header.js as js
      2019-12-27 21:34:59.292 - debug: lovelace.0 (2374) Add custom cards: dual-gauge-card.js as js
      2019-12-27 21:34:59.292 - debug: lovelace.0 (2374) Add custom cards: light-entity-card.js as js
      2019-12-27 21:34:59.292 - debug: lovelace.0 (2374) Add custom cards: mini-graph-card-bundle.js as js
      2019-12-27 21:34:59.293 - debug: lovelace.0 (2374) Add custom cards: remote-card.js as js
      2019-12-27 21:34:59.293 - debug: lovelace.0 (2374) Add custom cards: rgb-light-card.js as js
      2019-12-27 21:34:59.293 - debug: lovelace.0 (2374) Add custom cards: vertical-stack-in-card.js as js
      Helligkeit ist 0-100 bei der Zigbee leuchte.
      Attribute:
      brightness: shelly.0.SHRGBW2#5A38A7#1.color.gain
      brightness_pct: 73
      friendly_name: Wohnzimmer Licht
      hs_blue: shelly.0.SHRGBW2#5A38A7#1.color.blue
      hs_color: shelly.0.SHRGBW2#5A38A7#1.color.red
      hs_green: shelly.0.SHRGBW2#5A38A7#1.color.green
      supported_features: 17
      @Garfonso sagte in Test Adapter lovelace v0.2.x:
      Das sieht merkwürdig aus... ist das ein Gerät mit Farbe/Farbtemperatur oder nur Helligkeit? Was ist bei der Helligkeit das min/max?
      Das gerät hat
      • einmal ein level.color.white Wert 0-100 um die Warmweißen LED's zu dimmen
      • ein level.brightness Wert 0-100 um die RGB Led's zu Dimmen
      • für Color nutze ich level.color.rgb womit ich die Farbe über ein Hex einstelle
      • Garfonso
        Garfonso Developer @WW1983 last edited by Garfonso
        @WW1983 said in Test Adapter lovelace v0.2.x:
        Eine Kleinigtkeit hätte ich noch. Aber glaube nicht das du es beeinflussen kannst. Wenn ich ein Licht angenommen auf 50% dimme. Dann ausschalte und wieder anschalte, springt er direkt auf 100%. Merkt sich nicht die letzten Einstellungen
        Hm.. also wenn es ein Licht ist, was von "mir" angelegt wurde, dann sollte beim einschalten tatsächlich nur der Switch gestellt werden (also der on/off state auf true) und damit die letzte Helligkeit behalten werden. Anders sieht das bei Lampen aus, die nur an/aus und Brightness haben, da ist noch "der alte" Code am Werk, der irgendwie immer 100% setzt. Ich habe mal eine Testversion hochgeladen (wieder der Tratschtante Link) bei der das auch auf "meinen" Code umgebogen wird. Geht bei mir und gefällt mir so auch besser. 🙂
        @marcuskl
        Ok, und was geht jetzt genau nicht? grübel
        Also er erkennt "shelly.0.SHRGBW2#5A38A7#1.color.gain" als Dimmer -> damit wird er versuchen die Helligkeit zu regeln. "level.color.white" wird nicht vom Typedetector erkannt als etwas, womit er was anfangen kann (Problem dabei: Das ist ein anderes repository und wird ggf. noch woanders genutzt, da werden Änderungen nicht "so einfach" werden, vermute ich. Keine Ahnung). Zwei "Dimmer" sind bisher in meinem Code auch noch nicht vorgesehen, da müsste ich drüber nachdenken.
        Wenn der Slider "stecken" bleibt, dann werden da Werte außerhalb von dem Bereich gesetzt, den der als Min/Max hat oder gar keine Zahlen... wie ist dann der Wert in ioBroker? Was sind min/max Werte vom ioBroker state?
        Warum steht in deinem Screenshot "iob max" bei den Attributen? Das sollte es bei einer Lampe mit Farbe (bzw. in der neusten Testversion gar nicht) nicht (mehr) geben (ggf. mal Seite neuladen).
        (Farbeinstellungen verschwinden in Lovelace, wenn die Lampe aus = Helligkeit 0 ist, das ist normal)
        W marcuskl 2 Replies Last reply Reply Quote 0
          WW1983 @Garfonso last edited by
          @Garfonso
          Danke! Habs eben getestet... hat allerdings nicht funktioniert. Springt wieder zurück auf auf 100%
          • Garfonso
            @WW1983
            Äh.. vielleicht hab ich vergessen die Datei hochzuladen. Hab es nochmal alles neu gemacht.
              @Garfonso
              Leider funktioniert es immer noch nicht. Du meinst doch diesen Link?
              http://tratschtante.de/iobroker.lovelace-1.0.6.tgz
              • Garfonso
                @WW1983
                ja, korrekt. Die richtige Datei ist jetzt auch drinnen. Hm. Kannst du einen Screenshot der attribute (Lovelace instanz Einstellungen -> Entitäten, zeige Attribute) machen?
                  @Garfonso
                  Klar. Hoffe der Ausschnitt reicht. Bekomme nicht mehr vom Tablet drauf:
                  • Garfonso
                    @WW1983
                    Und das mit den 100% beim anschalten hast du bei allen Lampen? Hm... dann muss da was anderes reinspielen. Wenn du die States einzeln schaltest geht es?
                      Alex975 @holgerwolf last edited by
                      @holgerwolf sagte in Test Adapter lovelace v0.2.x:
                      @sigi234 Nicht viel:
                      type: 'custom:simple-thermostat'
                      entity: climate.Thermostat_Hobby_1
                      Hätte gerne auch noch andere Parameter auf der Karte, aber die Anleitung gibt auch nix her.
                      Edit: Gerade noch die Infos hier gefunden:
                      https://github.com/nervetattoo/simple-thermostat
                      mich würde aber interessieren, wie deine einzelnen Datenpunkte zu dem Thermostat definiert sind. also welche rolle haben sie bekommen und hast du den DP nochmal einzeln einen Raum und Funktion zugewiesen oder nur dem Hauptordner?
                        Alex975 @Alex975 last edited by Alex975
                        @Alex975 sagte in Test Adapter lovelace v0.2.x:
                        PS. Ich habe zumindest was hinbekommen, wenn ich die aktuelle Temp. auf value.temperature und die sollvorgabe auf level.temperature stelle.
                        problem ist , sobald was an der sollvorgabe oder akutellen temp was geändert wird, setzt er die rollen beide wieder auf value zurück...
                        und dann wird nur noch die sollvorgabe in der custom card angezeigt
                          @Garfonso
                          Ich habe das jetzt direkt über ioBroker getestet. Liegt wohl leider an dem Hue Adapter selber. Wenn ich das Objekt aus und an schalte wird springt der Wert wieder auf 100%
                            Hat zufällig auch jemand mit der aktuellen Version Darstellungsfehler auf dem iPad / iPhone? Auf dem PC (Firefox) sieht alles normal aus.
                            Auf dem iPad ist es übrigens auch egal welchen Browser ich nutze.
                            Die Light Buttons erhalten einen komischen Kreis wenn ich die ausmache:
                            • marcuskl
                              @Garfonso also habe es jetzt mal ausführlich getestet.
                              Der Shelly lässt sich nicht einschalten oder sonstiges, da geht garnichts.
                              Bei meiner Zigbee Tadfri Bulb funktioniert die Änderung der Farbtemperatur nicht und der Dimmwert ist falsch, bei der ist min=0 max=100.
                              Hier die Attribute:
                              brightness: zigbee.0.ccccccfffe5c48af.brightness
                              brightness_pct: 39.21568627450981
                              color_temp: zigbee.0.ccccccfffe5c48af.colortemp
                              entity_picture: ./adapter/zigbee/img/TRADFRI.bulb.E27.png
                              friendly_name: Wohnzimmer Hintergrundbeleuchtung
                              hs_color: zigbee.0.ccccccfffe5c48af.color
                              max_mireds: 450
                              min_mireds: 153
                              supported_features: 19
                              Folgendes steht auch noch im Log:
                              lovelace.0	2019-12-29 19:33:07.357	warn	(29254) no min value for light object 'zigbee.0.ccccccfffe5c48af.colortemp' defined -> using fallback max = '450'
                              lovelace.0	2019-12-29 19:33:07.357	warn	(29254) no max value for light object 'zigbee.0.ccccccfffe5c48af.colortemp' defined -> using fallback max = '153'
                              lovelace.0	2019-12-29 19:33:07.349	warn	(29254) Duplicates found for light.Switch
                              lovelace.0	2019-12-29 19:33:07.348	warn	(29254) Duplicates found for light.LED_Strips_Wohnzimmer
                              lovelace.0	2019-12-29 19:33:07.346	warn	(29254) Could not add shelly.0.SHRGBW2#5A38A7#1.color of type rgbSingle -> no on/off control found.
                              Hier noch ein Bild von den Shelly objekten, vllt hilft es:
                              • Garfonso
                                Garfonso Developer @marcuskl last edited by
                                @marcuskl said in Test Adapter lovelace v0.2.x:
                                Hm. Was heißt "falsch"? Ist die % Zahl eine andere? Wenn ja, wie anders? (also z.B. 50% soll = X % ist)
                                Wird die Farbtemperatur im Bereich ~150-600 eingestellt? Oder eher in den 1000ern?
                                Könntest du nochmal ein debug log von der Erkennung posten.
                                marcuskl 1 Reply Last reply Reply Quote 0
                                • marcuskl
                                  @Garfonso 50% ist 50, man kann 0 bis 100 einstellen.
                                  Das Problem ist, wenn ich den Dimmer (auf Bild rot markiert) nutze, dimmt es zwar hoch, aber sobald ich eine andere Farbe auswähle, springt der Dimmer auf die hälfte zurück.
                                  Die Farbtemperatur ist im 1000er Bereich.
                                  lovelace.0	2019-12-29 23:06:11.462	debug	(13541) Add custom cards: vertical-stack-in-card.js as js
                                  lovelace.0	2019-12-29 23:06:11.462	debug	(13541) Add custom cards: rgb-light-card.js as js
                                  lovelace.0	2019-12-29 23:06:11.461	debug	(13541) Add custom cards: remote-card.js as js
                                  lovelace.0	2019-12-29 23:06:11.461	debug	(13541) Add custom cards: mini-graph-card-bundle.js as js
                                  lovelace.0	2019-12-29 23:06:11.461	debug	(13541) Add custom cards: light-entity-card.js as js
                                  lovelace.0	2019-12-29 23:06:11.461	debug	(13541) Add custom cards: dual-gauge-card.js as js
                                  lovelace.0	2019-12-29 23:06:11.460	debug	(13541) Add custom cards: compact-custom-header.js as js
                                  lovelace.0	2019-12-29 23:06:11.460	debug	(13541) Add custom cards: button-entity-row.js as js
                                  lovelace.0	2019-12-29 23:06:11.460	debug	(13541) Add custom cards: button-card.js as js
                                  lovelace.0	2019-12-29 23:06:11.460	debug	(13541) Add custom cards: battery-entity.js as js
                                  lovelace.0	2019-12-29 23:06:11.459	debug	(13541) Add custom cards: background.jpg as jpg
                                  lovelace.0	2019-12-29 23:06:11.345	debug	(13541) HASS Subscribe: persistent_notifications_updated
                                  lovelace.0	2019-12-29 23:06:11.344	debug	(13541) HASS UnSubscribe: {"type":"unsubscribe_events","subscription":10,"id":20}
                                  lovelace.0	2019-12-29 23:06:10.781	debug	(13541) Get translations: de
                                  lovelace.0	2019-12-29 23:06:10.779	debug	(13541) get config: false
                                  lovelace.0	2019-12-29 23:06:10.752	debug	(13541) HASS Subscribe: persistent_notifications_updated
                                  lovelace.0	2019-12-29 23:06:10.751	debug	(13541) HASS Subscribe: lovelace_updated
                                  lovelace.0	2019-12-29 23:06:10.750	debug	(13541) HASS Subscribe: themes_updated
                                  lovelace.0	2019-12-29 23:06:10.749	debug	(13541) HASS Subscribe: panels_updated
                                  lovelace.0	2019-12-29 23:06:10.749	debug	(13541) HASS Subscribe: service_removed
                                  lovelace.0	2019-12-29 23:06:10.748	debug	(13541) HASS Subscribe: service_registered
                                  lovelace.0	2019-12-29 23:06:10.747	debug	(13541) HASS Subscribe: core_config_updated
                                  lovelace.0	2019-12-29 23:06:10.746	debug	(13541) HASS Subscribe: component_loaded
                                  lovelace.0	2019-12-29 23:06:10.745	debug	(13541) HASS Subscribe: state_changed
                                  lovelace.0	2019-12-29 23:06:10.484	debug	(13541) HASS Auth: no_token
                                  lovelace.0	2019-12-29 23:06:08.052	debug	(13541) IoB Subscribe on zigbee.0.00158d0003d53cb8.battery
                                  lovelace.0	2019-12-29 23:06:08.051	debug	(13541) IoB Subscribe on zigbee.0.ccccccfffe31ffb8.battery
                                  lovelace.0	2019-12-29 23:06:08.051	debug	(13541) IoB Subscribe on zigbee.0.00158d000320258a.battery
                                  lovelace.0	2019-12-29 23:06:08.050	debug	(13541) IoB Subscribe on zigbee.0.000b57fffe897c9a.battery
                                  lovelace.0	2019-12-29 23:06:08.049	debug	(13541) IoB Subscribe on zigbee.0.00158d00026ebcbf.battery
                                  lovelace.0	2019-12-29 23:06:08.048	debug	(13541) IoB Subscribe on sonoff.0.Zähler Verteiler.ENERGY_Today
                                  lovelace.0	2019-12-29 23:06:08.047	debug	(13541) IoB Subscribe on sonoff.0.Zähler Verteiler.ENERGY_Power_2
                                  lovelace.0	2019-12-29 23:06:08.046	debug	(13541) IoB Subscribe on sonoff.0.Zähler Verteiler.ENERGY_Power_1
                                  lovelace.0	2019-12-29 23:06:08.045	debug	(13541) IoB Subscribe on sonoff.0.Zähler Verteiler.ENERGY_Power_0
                                  lovelace.0	2019-12-29 23:06:08.044	debug	(13541) IoB Subscribe on sonoff.0.Zähler Verteiler.ENERGY_Current_2
                                  lovelace.0	2019-12-29 23:06:08.043	debug	(13541) IoB Subscribe on sonoff.0.Zähler Verteiler.ENERGY_Current_1
                                  lovelace.0	2019-12-29 23:06:08.042	debug	(13541) IoB Subscribe on sonoff.0.Zähler Verteiler.ENERGY_Current_0
                                  lovelace.0	2019-12-29 23:06:08.041	debug	(13541) IoB Subscribe on upnp.0.WANDevice_-_FRITZ!Box_6490_Cable.WANDevice.WANCommonInterfaceConfig.GetCommonLinkProperties.UpstreamMaxKbit
                                  lovelace.0	2019-12-29 23:06:08.041	debug	(13541) IoB Subscribe on upnp.0.WANDevice_-_FRITZ!Box_6490_Cable.WANDevice.WANCommonInterfaceConfig.GetCommonLinkProperties.DownstreamMaxKbit
                                  lovelace.0	2019-12-29 23:06:08.040	debug	(13541) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.v_up_ghome_schlafzimmer
                                  lovelace.0	2019-12-29 23:06:08.039	debug	(13541) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.v_down_ghome_schlafzimmer
                                  lovelace.0	2019-12-29 23:06:08.038	debug	(13541) IoB Subscribe on chromecast.0.Schlafzimmer.status.volume
                                  lovelace.0	2019-12-29 23:06:08.037	debug	(13541) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.v_up_ghome_kueche
                                  lovelace.0	2019-12-29 23:06:08.036	debug	(13541) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.v_down_ghome_kueche
                                  lovelace.0	2019-12-29 23:06:08.035	debug	(13541) IoB Subscribe on chromecast.0.Küche.status.volume
                                  lovelace.0	2019-12-29 23:06:08.034	debug	(13541) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.v_up_ghome_wohnzimmer
                                  lovelace.0	2019-12-29 23:06:08.033	debug	(13541) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.v_down_ghome_wohnzimmer
                                  lovelace.0	2019-12-29 23:06:08.033	debug	(13541) IoB Subscribe on chromecast.0.WohnzimmerJBL.status.volume
                                  lovelace.0	2019-12-29 23:06:08.032	debug	(13541) IoB Subscribe on lgtv.0.states.launch
                                  lovelace.0	2019-12-29 23:06:08.031	debug	(13541) IoB Subscribe on lgtv.0.states.volumeUp
                                  lovelace.0	2019-12-29 23:06:08.030	debug	(13541) IoB Subscribe on lgtv.0.states.mute
                                  lovelace.0	2019-12-29 23:06:08.029	debug	(13541) IoB Subscribe on lgtv.0.states.volumeDown
                                  lovelace.0	2019-12-29 23:06:08.028	debug	(13541) IoB Subscribe on lgtv.0.states.mediaFastForward
                                  lovelace.0	2019-12-29 23:06:08.027	debug	(13541) IoB Subscribe on lgtv.0.states.mediaPlay
                                  lovelace.0	2019-12-29 23:06:08.026	debug	(13541) IoB Subscribe on lgtv.0.states.mediaRewind
                                  lovelace.0	2019-12-29 23:06:08.025	debug	(13541) IoB Subscribe on lgtv.0.states.channelDown
                                  lovelace.0	2019-12-29 23:06:08.025	debug	(13541) IoB Subscribe on lgtv.0.states.channelUp
                                  lovelace.0	2019-12-29 23:06:08.024	debug	(13541) IoB Subscribe on lgtv.0.remote.down
                                  lovelace.0	2019-12-29 23:06:08.023	debug	(13541) IoB Subscribe on lgtv.0.remote.right
                                  lovelace.0	2019-12-29 23:06:08.022	debug	(13541) IoB Subscribe on lgtv.0.remote.enter
                                  lovelace.0	2019-12-29 23:06:08.021	debug	(13541) IoB Subscribe on lgtv.0.remote.left
                                  lovelace.0	2019-12-29 23:06:08.020	debug	(13541) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.launch_amazon
                                  lovelace.0	2019-12-29 23:06:08.019	debug	(13541) IoB Subscribe on lgtv.0.remote.up
                                  lovelace.0	2019-12-29 23:06:08.018	debug	(13541) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.launch_netflix
                                  lovelace.0	2019-12-29 23:06:08.017	debug	(13541) IoB Subscribe on lgtv.0.remote.home
                                  lovelace.0	2019-12-29 23:06:08.017	debug	(13541) IoB Subscribe on lgtv.0.remote.menu
                                  lovelace.0	2019-12-29 23:06:08.016	debug	(13541) IoB Subscribe on lgtv.0.remote.back
                                  lovelace.0	2019-12-29 23:06:08.015	debug	(13541) IoB Subscribe on lgtv.0.states.power
                                  lovelace.0	2019-12-29 23:06:08.014	debug	(13541) IoB Subscribe on 0_userdata.0.Automation.flurlicht_automatik
                                  lovelace.0	2019-12-29 23:06:08.013	debug	(13541) IoB Subscribe on sonoff.0.Nachtlicht Marcus.POWER
                                  lovelace.0	2019-12-29 23:06:08.012	debug	(13541) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.wohnzimmer_kaltweiß
                                  lovelace.0	2019-12-29 23:06:08.011	debug	(13541) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.wohnzimmer_warmweiß
                                  lovelace.0	2019-12-29 23:06:08.010	debug	(13541) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.wohnzimmer_turkis
                                  lovelace.0	2019-12-29 23:06:08.009	debug	(13541) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.wohnzimmer_violtett
                                  lovelace.0	2019-12-29 23:06:08.009	debug	(13541) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.wohnzimmer_grün
                                  lovelace.0	2019-12-29 23:06:08.008	debug	(13541) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.wohnzimmer_blau
                                  lovelace.0	2019-12-29 23:06:08.007	debug	(13541) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.wohnzimmer_red
                                  lovelace.0	2019-12-29 23:06:08.006	debug	(13541) IoB Subscribe on 0_userdata.0.Automation.led_strips_automatik
                                  lovelace.0	2019-12-29 23:06:08.005	debug	(13541) IoB Subscribe on 0_userdata.0.Automation.rgb_syncron
                                  lovelace.0	2019-12-29 23:06:08.004	debug	(13541) IoB Subscribe on 0_userdata.0.Automation.schreibtischsteckdose_automatik_aus
                                  lovelace.0	2019-12-29 23:06:08.002	debug	(13541) IoB Subscribe on tuya.0.17014830b4e62d5a02cc.1
                                  lovelace.0	2019-12-29 23:06:08.002	debug	(13541) IoB Subscribe on sonoff.0.TV Steckdose.POWER
                                  lovelace.0	2019-12-29 23:06:08.001	debug	(13541) IoB Subscribe on sonoff.0.Weihnachtsbaum.POWER
                                  lovelace.0	2019-12-29 23:06:08.000	debug	(13541) IoB Subscribe on sonoff.0.Nachtlicht Flur.POWER
                                  lovelace.0	2019-12-29 23:06:07.999	debug	(13541) IoB Subscribe on sonoff.0.Schreibtischlampe.POWER
                                  lovelace.0	2019-12-29 23:06:07.998	debug	(13541) IoB Subscribe on sonoff.0.Küchenlicht.POWER
                                  lovelace.0	2019-12-29 23:06:07.997	debug	(13541) IoB Subscribe on sonoff.0.Nachtlicht Liah.POWER
                                  lovelace.0	2019-12-29 23:06:07.996	debug	(13541) IoB Subscribe on shelly.0.SHRGBW2#5A38A7#1.color.white
                                  lovelace.0	2019-12-29 23:06:07.996	debug	(13541) IoB Subscribe on zigbee.0.ccccccfffe5c48af.color
                                  lovelace.0	2019-12-29 23:06:07.994	debug	(13541) IoB Subscribe on zigbee.0.ccccccfffe5c48af.brightness
                                  lovelace.0	2019-12-29 23:06:07.991	debug	(13541) IoB Subscribe on zigbee.0.ccccccfffe5c48af.colortemp
                                  lovelace.0	2019-12-29 23:06:07.990	debug	(13541) IoB Subscribe on zigbee.0.ccccccfffe5c48af.state
                                  lovelace.0	2019-12-29 23:06:07.989	debug	(13541) IoB Subscribe on shelly.0.SHSW-1#94147C#1.Relay0.Switch
                                  lovelace.0	2019-12-29 23:06:07.988	debug	(13541) IoB Subscribe on sonoff.0.Nachtlicht Benchy.POWER
                                  lovelace.0	2019-12-29 23:06:07.988	debug	(13541) IoB Subscribe on shelly.0.SHSW-1#12C27E#1.Relay0.Switch
                                  lovelace.0	2019-12-29 23:06:07.987	debug	(13541) IoB Subscribe on shelly.0.SHSW-1#943F39#1.Relay0.Switch
                                  lovelace.0	2019-12-29 23:06:07.986	debug	(13541) IoB Subscribe on scene.0.Fernsehabend
                                  lovelace.0	2019-12-29 23:06:07.985	debug	(13541) IoB Subscribe on scene.0.Bettfertig
                                  lovelace.0	2019-12-29 23:06:07.984	debug	(13541) IoB Subscribe on 0_userdata.0.Zentral_Funktionen.zentral_aus
                                  lovelace.0	2019-12-29 23:06:07.983	debug	(13541) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_6.Minimale_Temperatur_value
                                  lovelace.0	2019-12-29 23:06:07.982	debug	(13541) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_6.Maximale_Temperatur_value
                                  lovelace.0	2019-12-29 23:06:07.981	debug	(13541) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_6.iconURL
                                  lovelace.0	2019-12-29 23:06:07.980	debug	(13541) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_5.Minimale_Temperatur_value
                                  lovelace.0	2019-12-29 23:06:07.979	debug	(13541) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_5.Maximale_Temperatur_value
                                  lovelace.0	2019-12-29 23:06:07.978	debug	(13541) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_5.iconURL
                                  lovelace.0	2019-12-29 23:06:07.977	debug	(13541) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_4.Minimale_Temperatur_value
                                  lovelace.0	2019-12-29 23:06:07.976	debug	(13541) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_4.Maximale_Temperatur_value
                                  lovelace.0	2019-12-29 23:06:07.975	debug	(13541) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_4.iconURL
                                  lovelace.0	2019-12-29 23:06:07.974	debug	(13541) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_3.Minimale_Temperatur_value
                                  lovelace.0	2019-12-29 23:06:07.973	debug	(13541) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_3.Maximale_Temperatur_value
                                  lovelace.0	2019-12-29 23:06:07.972	debug	(13541) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_3.iconURL
                                  lovelace.0	2019-12-29 23:06:07.971	debug	(13541) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_2.Minimale_Temperatur_value
                                  lovelace.0	2019-12-29 23:06:07.970	debug	(13541) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_2.Maximale_Temperatur_value
                                  lovelace.0	2019-12-29 23:06:07.969	debug	(13541) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_2.iconURL
                                  lovelace.0	2019-12-29 23:06:07.968	debug	(13541) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_1.Maximale_Temperatur_value
                                  lovelace.0	2019-12-29 23:06:07.967	debug	(13541) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_1.iconURL
                                  lovelace.0	2019-12-29 23:06:07.711	debug	(13541) light.LED_Strips_Wohnzimmer got [0,100,100] from Blue 0 and {"r":255,"g":0,"b":0} and old hsv [0,100,100]
                                  lovelace.0	2019-12-29 23:06:07.710	debug	(13541) light.LED_Strips_Wohnzimmer got [0,100,100] from Green 0 and {"r":255,"g":0,"b":0} and old hsv [0,100,100]
                                  lovelace.0	2019-12-29 23:06:07.709	debug	(13541) light.LED_Strips_Wohnzimmer got [0,100,100] from Red 255 and {"r":255,"g":0,"b":0} and old hsv [0,100,100]
                                  lovelace.0	2019-12-29 23:06:07.661	debug	(13541) Create manual device: alarm_control_panel.defaultAlarm - lovelace.0.control.alarm
                                  lovelace.0	2019-12-29 23:06:07.658	debug	(13541) Create manual device: switch.bettfertig - scene.0.Bettfertig
                                  lovelace.0	2019-12-29 23:06:07.655	debug	(13541) Create manual device: switch.led_strips_automatik - 0_userdata.0.Automation.led_strips_automatik
                                  lovelace.0	2019-12-29 23:06:07.652	debug	(13541) Create manual device: switch.zentral_aus - 0_userdata.0.Zentral_Funktionen.zentral_aus
                                  lovelace.0	2019-12-29 23:06:07.649	debug	(13541) Create manual device: switch.flurlicht_automatik - 0_userdata.0.Automation.flurlicht_automatik
                                  lovelace.0	2019-12-29 23:06:07.646	debug	(13541) Create manual device: switch.schreibtischsteckdose_automatik - 0_userdata.0.Automation.schreibtischsteckdose_automatik_aus
                                  lovelace.0	2019-12-29 23:06:07.643	debug	(13541) Create manual device: switch.rgb_syncron - 0_userdata.0.Automation.rgb_syncron
                                  lovelace.0	2019-12-29 23:06:07.640	debug	(13541) Create manual device: switch.fernsehabend - scene.0.Fernsehabend
                                  lovelace.0	2019-12-29 23:06:07.636	debug	(13541) Create manual device: switch.v_up_ghome_schlafzimmer - 0_userdata.0.Lovelace.Emulate.v_up_ghome_schlafzimmer
                                  lovelace.0	2019-12-29 23:06:07.633	debug	(13541) Create manual device: switch.v_down_ghome_schlafzimmer - 0_userdata.0.Lovelace.Emulate.v_down_ghome_schlafzimmer
                                  lovelace.0	2019-12-29 23:06:07.630	debug	(13541) Create manual device: switch.v_up_ghome_kueche - 0_userdata.0.Lovelace.Emulate.v_up_ghome_kueche
                                  lovelace.0	2019-12-29 23:06:07.627	debug	(13541) Create manual device: switch.v_down_ghome_kueche - 0_userdata.0.Lovelace.Emulate.v_down_ghome_kueche
                                  lovelace.0	2019-12-29 23:06:07.623	debug	(13541) Create manual device: switch.tv_remote_amazon - 0_userdata.0.Lovelace.Emulate.launch_amazon
                                  lovelace.0	2019-12-29 23:06:07.620	debug	(13541) Create manual device: switch.tv_remote_netflix - 0_userdata.0.Lovelace.Emulate.launch_netflix
                                  lovelace.0	2019-12-29 23:06:07.617	debug	(13541) Create manual device: switch.v_down_ghome_wohnzimmer - 0_userdata.0.Lovelace.Emulate.v_down_ghome_wohnzimmer
                                  lovelace.0	2019-12-29 23:06:07.614	debug	(13541) Create manual device: switch.v_up_ghome_wohnzimmer - 0_userdata.0.Lovelace.Emulate.v_up_ghome_wohnzimmer
                                  lovelace.0	2019-12-29 23:06:07.611	debug	(13541) Create manual device: switch.kaltweiß - 0_userdata.0.Lovelace.Emulate.wohnzimmer_kaltweiß
                                  lovelace.0	2019-12-29 23:06:07.608	debug	(13541) Create manual device: switch.warmweiß - 0_userdata.0.Lovelace.Emulate.wohnzimmer_warmweiß
                                  lovelace.0	2019-12-29 23:06:07.605	debug	(13541) Create manual device: switch.violett - 0_userdata.0.Lovelace.Emulate.wohnzimmer_violtett
                                  lovelace.0	2019-12-29 23:06:07.602	debug	(13541) Create manual device: switch.turkis - 0_userdata.0.Lovelace.Emulate.wohnzimmer_turkis
                                  lovelace.0	2019-12-29 23:06:07.599	debug	(13541) Create manual device: switch.red - 0_userdata.0.Lovelace.Emulate.wohnzimmer_red
                                  lovelace.0	2019-12-29 23:06:07.596	debug	(13541) Create manual device: switch.blue - 0_userdata.0.Lovelace.Emulate.wohnzimmer_blau
                                  lovelace.0	2019-12-29 23:06:07.593	debug	(13541) Create manual device: switch.green - 0_userdata.0.Lovelace.Emulate.wohnzimmer_grün
                                  lovelace.0	2019-12-29 23:06:07.590	debug	(13541) Create manual device: sensor.akku_tür_sensor - zigbee.0.00158d0003d53cb8.battery
                                  lovelace.0	2019-12-29 23:06:07.587	debug	(13541) Create manual device: light.nachtlicht_flur - sonoff.0.Nachtlicht Flur.POWER
                                  lovelace.0	2019-12-29 23:06:07.584	debug	(13541) Create manual device: sensor.akku_stehlampe_schalter - zigbee.0.ccccccfffe31ffb8.battery
                                  lovelace.0	2019-12-29 23:06:07.581	debug	(13541) Create manual device: sensor.l3_strom - sonoff.0.Zähler Verteiler.ENERGY_Current_2
                                  lovelace.0	2019-12-29 23:06:07.578	debug	(13541) Create manual device: sensor.l2_strom - sonoff.0.Zähler Verteiler.ENERGY_Current_1
                                  lovelace.0	2019-12-29 23:06:07.575	debug	(13541) Create manual device: sensor.l1_strom - sonoff.0.Zähler Verteiler.ENERGY_Current_0
                                  lovelace.0	2019-12-29 23:06:07.572	debug	(13541) Create manual device: sensor.l3_spannung - sonoff.0.Zähler Verteiler.ENERGY_Voltage_2
                                  lovelace.0	2019-12-29 23:06:07.569	debug	(13541) Create manual device: sensor.l2_spannung - sonoff.0.Zähler Verteiler.ENERGY_Voltage_1
                                  lovelace.0	2019-12-29 23:06:07.565	debug	(13541) Create manual device: sensor.l1_spannung - sonoff.0.Zähler Verteiler.ENERGY_Voltage_0
                                  lovelace.0	2019-12-29 23:06:07.562	debug	(13541) Create manual device: sensor.l3_leistung - sonoff.0.Zähler Verteiler.ENERGY_Power_2
                                  lovelace.0	2019-12-29 23:06:07.559	debug	(13541) Create manual device: sensor.l2_leistung - sonoff.0.Zähler Verteiler.ENERGY_Power_1
                                  lovelace.0	2019-12-29 23:06:07.556	debug	(13541) Create manual device: sensor.l1_leistung - sonoff.0.Zähler Verteiler.ENERGY_Power_0
                                  lovelace.0	2019-12-29 23:06:07.552	debug	(13541) Create manual device: sensor.energie_heute - sonoff.0.Zähler Verteiler.ENERGY_Today
                                  lovelace.0	2019-12-29 23:06:07.549	debug	(13541) Create manual device: sensor.energie_gesamt - sonoff.0.Zähler Verteiler.ENERGY_Total
                                  lovelace.0	2019-12-29 23:06:07.546	debug	(13541) Create manual device: sensor.akku_switch_marcus - zigbee.0.00158d00026ebcbf.battery
                                  lovelace.0	2019-12-29 23:06:07.543	debug	(13541) Create manual device: media_player.tv_remote_enter - lgtv.0.remote.enter
                                  lovelace.0	2019-12-29 23:06:07.540	debug	(13541) Create manual device: media_player.tv_remote_right - lgtv.0.remote.right
                                  lovelace.0	2019-12-29 23:06:07.537	debug	(13541) Create manual device: media_player.tv_remote_left - lgtv.0.remote.left
                                  lovelace.0	2019-12-29 23:06:07.534	debug	(13541) Create manual device: media_player.tv_remote_down - lgtv.0.remote.down
                                  lovelace.0	2019-12-29 23:06:07.531	debug	(13541) Create manual device: media_player.tv_remote_up - lgtv.0.remote.up
                                  lovelace.0	2019-12-29 23:06:07.528	debug	(13541) Create manual device: media_player.tv_remote_back - lgtv.0.remote.back
                                  lovelace.0	2019-12-29 23:06:07.525	debug	(13541) Create manual device: media_player.tv_remote_menu - lgtv.0.remote.menu
                                  lovelace.0	2019-12-29 23:06:07.522	debug	(13541) Create manual device: media_player.tv_remote_home - lgtv.0.remote.home
                                  lovelace.0	2019-12-29 23:06:07.519	debug	(13541) Create manual device: sensor.akku_dimmer - zigbee.0.000b57fffe897c9a.battery
                                  lovelace.0	2019-12-29 23:06:07.516	debug	(13541) Create manual device: sensor.MaxUpstream - upnp.0.WANDevice_-_FRITZ!Box_6490_Cable.WANDevice.WANCommonInterfaceConfig.GetCommonLinkProperties.UpstreamMaxKbit
                                  lovelace.0	2019-12-29 23:06:07.512	debug	(13541) Create manual device: sensor.MaxDownstream - upnp.0.WANDevice_-_FRITZ!Box_6490_Cable.WANDevice.WANCommonInterfaceConfig.GetCommonLinkProperties.DownstreamMaxKbit
                                  lovelace.0	2019-12-29 23:06:07.510	debug	(13541) Create manual device: light.Schreibtischlampe - sonoff.0.Schreibtischlampe.POWER
                                  lovelace.0	2019-12-29 23:06:07.507	debug	(13541) Create manual device: input_boolean.zuruck - broadlink2.0.RM:RMMINI-40-7c-2f.L.CODE_26001a000f07064d0c6a0c0001d009000265090002440f0006470a000d050000000000000000000000000000
                                  lovelace.0	2019-12-29 23:06:07.503	debug	(13541) Create manual device: input_number.GHomeKueche - chromecast.0.Küche.status.volume
                                  lovelace.0	2019-12-29 23:06:07.500	debug	(13541) Create manual device: input_number.GHomeSchlafzimmer - chromecast.0.Schlafzimmer.status.volume
                                  lovelace.0	2019-12-29 23:06:07.497	debug	(13541) Create manual device: input_number.GHomeWohnzimmer - chromecast.0.WohnzimmerJBL.status.volume
                                  lovelace.0	2019-12-29 23:06:07.493	debug	(13541) Create manual device: sensor.Schreibtisch_Strom - tuya.0.17014830b4e62d5a02cc.4
                                  lovelace.0	2019-12-29 23:06:07.489	debug	(13541) Create manual device: input_boolean.Schreibtisch - tuya.0.17014830b4e62d5a02cc.1
                                  lovelace.0	2019-12-29 23:06:07.486	debug	(13541) Create manual device: sensor.akku_bm_flur - zigbee.0.00158d000320258a.battery
                                  lovelace.0	2019-12-29 23:06:07.483	debug	(13541) Create manual device: sensor.server_ram_auslastung - proxmox.0.node_pve.memory.used_lev
                                  lovelace.0	2019-12-29 23:06:07.475	debug	(13541) Create manual device: sensor.pve_cpu_utilization - proxmox.0.node_pve.cpu
                                  lovelace.0	2019-12-29 23:06:07.471	debug	(13541) Create manual device: light.Flurlicht - shelly.0.SHSW-1#943F39#1.Relay0.Switch
                                  lovelace.0	2019-12-29 23:06:07.467	debug	(13541) Create manual device: switch.Fernseher - javascript.0.scriptEnabled.Vis.Fernseher_Power
                                  lovelace.0	2019-12-29 23:06:07.464	debug	(13541) Create manual device: light.Wohnzimmerlicht - shelly.0.SHSW-1#94147C#1.Relay0.Switch
                                  lovelace.0	2019-12-29 23:06:07.460	debug	(13541) Create manual device: light.Schlafzimmerlicht - shelly.0.SHSW-1#12C27E#1.Relay0.Switch
                                  lovelace.0	2019-12-29 23:06:07.457	debug	(13541) Create manual device: switch.tv_remote_mute - lgtv.0.states.mute
                                  lovelace.0	2019-12-29 23:06:07.454	debug	(13541) Create manual device: media_player.tv_volume_up - lgtv.0.states.volumeUp
                                  lovelace.0	2019-12-29 23:06:07.451	debug	(13541) Create manual device: media_player.tv_volume_down - lgtv.0.states.volumeDown
                                  lovelace.0	2019-12-29 23:06:07.448	debug	(13541) Create manual device: media_player.tv_channel_up - lgtv.0.states.channelUp
                                  lovelace.0	2019-12-29 23:06:07.444	debug	(13541) Create manual device: media_player.tv_channel_down - lgtv.0.states.channelDown
                                  lovelace.0	2019-12-29 23:06:07.439	debug	(13541) Create manual device: media_player.tv_remote_play - lgtv.0.states.mediaPlay
                                  lovelace.0	2019-12-29 23:06:07.436	debug	(13541) Create manual device: media_player.tv_pause - lgtv.0.states.mediaPause
                                  lovelace.0	2019-12-29 23:06:07.433	debug	(13541) Create manual device: media_player.tv_remote_forward - lgtv.0.states.mediaFastForward
                                  lovelace.0	2019-12-29 23:06:07.430	debug	(13541) Create manual device: media_player.tv_remote_rewind - lgtv.0.states.mediaRewind
                                  lovelace.0	2019-12-29 23:06:07.426	debug	(13541) Create manual device: input_number.FernseherVolume - lgtv.0.states.volume
                                  lovelace.0	2019-12-29 23:06:07.421	debug	(13541) Create manual device: input_select.tv_launch - lgtv.0.states.launch
                                  lovelace.0	2019-12-29 23:06:07.398	debug	(13541) Create manual device: sensor.CPU_Temperatur - info.0.sysinfo.cpu.temperature.main
                                  lovelace.0	2019-12-29 23:06:07.318	debug	(13541) AUTO Device detected: zigbee.0.ccccccfffe5c48af => light
                                  lovelace.0	2019-12-29 23:06:07.318	debug	(13541) AUTO Device detected: daswetter.0.NextDays.Location_1 => weather
                                  lovelace.0	2019-12-29 23:06:07.318	debug	(13541) AUTO Device detected: tuya.0.17014830b4e62d5a02cc.1 => switch
                                  lovelace.0	2019-12-29 23:06:07.317	debug	(13541) AUTO Device detected: sonoff.0.TV Steckdose.POWER => switch
                                  lovelace.0	2019-12-29 23:06:07.317	debug	(13541) AUTO Device detected: lgtv.0.states.power => switch
                                  lovelace.0	2019-12-29 23:06:07.317	debug	(13541) AUTO Device detected: sonoff.0.Weihnachtsbaum => light
                                  lovelace.0	2019-12-29 23:06:07.317	debug	(13541) AUTO Device detected: sonoff.0.Schreibtischlampe.POWER => light
                                  lovelace.0	2019-12-29 23:06:07.316	debug	(13541) AUTO Device detected: sonoff.0.Nachtlicht Marcus.POWER => light
                                  lovelace.0	2019-12-29 23:06:07.316	debug	(13541) AUTO Device detected: sonoff.0.Nachtlicht Liah.POWER => light
                                  lovelace.0	2019-12-29 23:06:07.316	debug	(13541) AUTO Device detected: sonoff.0.Nachtlicht Flur => light
                                  lovelace.0	2019-12-29 23:06:07.316	debug	(13541) AUTO Device detected: sonoff.0.Nachtlicht Benchy.POWER => light
                                  lovelace.0	2019-12-29 23:06:07.315	debug	(13541) AUTO Device detected: sonoff.0.Küchenlicht.POWER => light
                                  lovelace.0	2019-12-29 23:06:07.315	debug	(13541) AUTO Device detected: shelly.0.SHSW-1#12C27E#1.Relay0.Switch => light
                                  lovelace.0	2019-12-29 23:06:07.314	debug	(13541) AUTO Device detected: shelly.0.SHRGBW2#5A38A7#1.color => light
                                  lovelace.0	2019-12-29 23:06:07.314	debug	(13541) [Type-Detector] device zigbee.0.ccccccfffe5c48af.groups - info - zigbee.0.ccccccfffe5c48af is not yet supported
                                  lovelace.0	2019-12-29 23:06:07.313	debug	(13541) [Type-Detector] Created auto device: light.Stehlampe - rgbSingle - zigbee.0.ccccccfffe5c48af
                                  lovelace.0	2019-12-29 23:06:07.313	debug	(13541) Color already present, skip R,G,B color.
                                  lovelace.0	2019-12-29 23:06:07.312	debug	(13541) light.Stehlampe ct needs kelvin conversion: false
                                  lovelace.0	2019-12-29 23:06:07.312	warn	(13541) no min value for light object 'zigbee.0.ccccccfffe5c48af.colortemp' defined -> using fallback max = '450'
                                  lovelace.0	2019-12-29 23:06:07.312	warn	(13541) no max value for light object 'zigbee.0.ccccccfffe5c48af.colortemp' defined -> using fallback max = '153'
                                  lovelace.0	2019-12-29 23:06:07.310	debug	(13541) rgbSingle - Controls: { "states": [ { "indicator": false, "type": "string", "write": true, "name": "RGB", "required": true, "defaultRole": "level.colo
                                  lovelace.0	2019-12-29 23:06:07.299	debug	(13541) [Type-Detector] device scene.0.Fernsehabend - info - scene.0.Fernsehabend is not yet supported
                                  lovelace.0	2019-12-29 23:06:07.298	debug	(13541) [Type-Detector] device scene.0.Bettfertig - info - scene.0.Bettfertig is not yet supported
                                  lovelace.0	2019-12-29 23:06:07.297	debug	(13541) [Type-Detector] device daswetter.0.NextDays.Location_1.Day_1.Wetter_Symbol_id - info - daswetter.0.NextDays.Location_1 is not yet supported
                                  lovelace.0	2019-12-29 23:06:07.296	debug	(13541) [Type-Detector] Created auto device: weather.Gaggenau__Baden_W_rttemberg_Deutschland_ - weatherForecast - daswetter.0.NextDays.Location_1
                                  lovelace.0	2019-12-29 23:06:07.220	debug	(13541) [Type-Detector] device zigbee.0.00158d0003d53cb8.battery - info - zigbee.0.00158d0003d53cb8.battery is not yet supported
                                  lovelace.0	2019-12-29 23:06:07.216	debug	(13541) [Type-Detector] device zigbee.0.ccccccfffe31ffb8.battery - info - zigbee.0.ccccccfffe31ffb8.battery is not yet supported
                                  lovelace.0	2019-12-29 23:06:07.213	debug	(13541) [Type-Detector] device zigbee.0.00158d000320258a.battery - info - zigbee.0.00158d000320258a.battery is not yet supported
                                  lovelace.0	2019-12-29 23:06:07.210	debug	(13541) [Type-Detector] device zigbee.0.000b57fffe897c9a.battery - info - zigbee.0.000b57fffe897c9a.battery is not yet supported
                                  lovelace.0	2019-12-29 23:06:07.207	debug	(13541) [Type-Detector] device chromecast.0.WohnzimmerJBL.status.volume - volume - chromecast.0.WohnzimmerJBL.status.volume is not yet supported
                                  lovelace.0	2019-12-29 23:06:07.203	debug	(13541) [Type-Detector] device chromecast.0.Schlafzimmer.status.volume - volume - chromecast.0.Schlafzimmer.status.volume is not yet supported
                                  lovelace.0	2019-12-29 23:06:07.200	debug	(13541) [Type-Detector] device chromecast.0.Küche.status.volume - volume - chromecast.0.Küche.status.volume is not yet supported
                                  lovelace.0	2019-12-29 23:06:07.195	debug	(13541) [Type-Detector] Created auto device: switch.switch_on - socket - tuya.0.17014830b4e62d5a02cc.1
                                  lovelace.0	2019-12-29 23:06:07.191	debug	(13541) [Type-Detector] Created auto device: switch.TV_Steckdose_POWER - socket - sonoff.0.TV Steckdose.POWER
                                  lovelace.0	2019-12-29 23:06:07.187	debug	(13541) [Type-Detector] device lgtv.0.states.launch - info - lgtv.0.states.launch is not yet supported
                                  lovelace.0	2019-12-29 23:06:07.184	debug	(13541) [Type-Detector] Created auto device: switch.Switch_TV_power - socket - lgtv.0.states.power
                                  lovelace.0	2019-12-29 23:06:07.178	debug	(13541) [Type-Detector] device lgtv.0.states.volume - info - lgtv.0.states.volume is not yet supported
                                  lovelace.0	2019-12-29 23:06:07.172	debug	(13541) [Type-Detector] device sonoff.0.Weihnachtsbaum.Time - info - sonoff.0.Weihnachtsbaum is not yet supported
                                  lovelace.0	2019-12-29 23:06:07.172	debug	(13541) [Type-Detector] Created auto device: light.Weihnachtsbaum - light - sonoff.0.Weihnachtsbaum
                                  lovelace.0	2019-12-29 23:06:07.156	debug	(13541) [Type-Detector] Created auto device: light.Schreibtischlampe_POWER - light - sonoff.0.Schreibtischlampe.POWER
                                  lovelace.0	2019-12-29 23:06:07.152	debug	(13541) [Type-Detector] Created auto device: light.Nachtlicht_Marcus_POWER - light - sonoff.0.Nachtlicht Marcus.POWER
                                  lovelace.0	2019-12-29 23:06:07.147	debug	(13541) [Type-Detector] Created auto device: light.Nachtlicht_Liah_POWER - light - sonoff.0.Nachtlicht Liah.POWER
                                  lovelace.0	2019-12-29 23:06:07.143	debug	(13541) [Type-Detector] device sonoff.0.Nachtlicht Flur.Time - info - sonoff.0.Nachtlicht Flur is not yet supported
                                  lovelace.0	2019-12-29 23:06:07.143	debug	(13541) [Type-Detector] Created auto device: light.Nachtlicht_Flur - light - sonoff.0.Nachtlicht Flur
                                  lovelace.0	2019-12-29 23:06:07.127	debug	(13541) [Type-Detector] Created auto device: light.Nachtlicht_Benchy_POWER - light - sonoff.0.Nachtlicht Benchy.POWER
                                  lovelace.0	2019-12-29 23:06:07.123	debug	(13541) [Type-Detector] Created auto device: light.K_chenlicht_POWER - light - sonoff.0.Küchenlicht.POWER
                                  lovelace.0	2019-12-29 23:06:07.118	warn	(13541) Duplicates found for light.Switch
                                  lovelace.0	2019-12-29 23:06:07.113	warn	(13541) Duplicates found for light.Switch
                                  lovelace.0	2019-12-29 23:06:07.109	debug	(13541) [Type-Detector] Created auto device: light.Switch - light - shelly.0.SHSW-1#12C27E#1.Relay0.Switch
                                  lovelace.0	2019-12-29 23:06:07.104	debug	(13541) [Type-Detector] device shelly.0.SHRGBW2#5A38A7#1.color.effect - info - shelly.0.SHRGBW2#5A38A7#1.color is not yet supported
                                  lovelace.0	2019-12-29 23:06:07.103	warn	(13541) Duplicates found for light.LED_Strips_Wohnzimmer
                                  lovelace.0	2019-12-29 23:06:07.101	warn	(13541) Could not add shelly.0.SHRGBW2#5A38A7#1.color of type rgbSingle -> no on/off control found.
                                  lovelace.0	2019-12-29 23:06:07.100	debug	(13541) [Type-Detector] Created auto device: light.LED_Strips_Wohnzimmer - rgb - shelly.0.SHRGBW2#5A38A7#1.color
                                  lovelace.0	2019-12-29 23:06:07.093	debug	(13541) rgb - Controls: { "states": [ { "indicator": false, "type": "number", "write": true, "name": "RED", "required": true, "defaultRole": "level.color.red"
                                  lovelace.0	2019-12-29 23:06:06.541	info	(13541) http server listening on port 8091
                                  lovelace.0	2019-12-29 23:06:06.505	debug	(13541) Schedule restart: 0 2 * * *
                                  lovelace.0	2019-12-29 23:06:06.385	info	(13541) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.lovelace, node: v10.17.0
                                  lovelace.0	2019-12-29 23:06:04.609	debug	(13541) States connected to redis: 127.0.0.1:9000
                                  lovelace.0	2019-12-29 23:06:04.556	debug	(13541) statesDB connected
                                  lovelace.0	2019-12-29 23:06:04.554	debug	(13541) States create PubSub Client
                                  lovelace.0	2019-12-29 23:06:04.546	debug	(13541) Objects connected to redis: 127.0.0.1:9001
                                  lovelace.0	2019-12-29 23:06:04.543	debug	(13541) Redis States: Use Redis connection: 127.0.0.1:9000
                                  lovelace.0	2019-12-29 23:06:04.540	debug	(13541) objectDB connected
                                  lovelace.0	2019-12-29 23:06:04.528	debug	(13541) Objects client initialize lua scripts
                                  lovelace.0	2019-12-29 23:06:04.526	debug	(13541) Objects create PubSub Client
                                  lovelace.0	2019-12-29 23:06:04.522	debug	(13541) Objects client ready ... initialize now
                                  lovelace.0	2019-12-29 23:06:04.485	debug	(13541) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  • Garfonso
                                    Garfonso Developer @marcuskl last edited by Garfonso
                                    Ok, ja, da hab ich die Konvertierung der Farben zu genau genommen... das hab ich wieder rausgenommen. Wenn du nochmal von dem tratschtante Link installierst, ist das weg.
                                    Das passt leider nicht zu:
                                    Das wird vermutlich noch öfter ein Problem... da ist mir etwas unklar, wie ich das erkennen soll. Wenn die Farbwerte im 1000er Bereich sind, dann ist es Kelvin. HASS arbeitet aber mit Mireds. Die sind normalerweise zwischen 150 und 450 und dazu noch andersrum. Das muss entsprechend konvertiert werden. Das Problem ist, wenn keine Einheit gesetzt wurde und kein Min und Max, kann ich das beim erstellen nicht wirklich feststellen. Ich hab jetzt eingebaut, dass er, wenn Werte von ioBroker kommen, die prüft und wenn die >1000 sind die Kelvinkonvertierung anschaltet. Vermutlich müsste das Problem damit halbwegs gelöst sein. Ansonsten mal die Einheit auf "K" für Kelvin stellen oder min/max was einstellen (2200-6500 ist bei Kelvin oft der Fall).
                                    -> also auch dafür nochmal neu installieren und testen. 🙂
                                    Zum shelly:
                                    Das sieht doch schon gut aus. Was geht denn genau nicht? (Ich kann das ja nicht riechen 😉 )
                                    Du hast das log aus dem Admin kopiert, oder? Da ist jetzt leider die Ausgabe, die mir in dem Fall weiterhelfen würde abgeschnitten. Da bräuchte ich das aus dem File direkt.
                                      ecki945 last edited by ecki945
                                      @Garfonso Ich hoffe ich darf hier mal mit ner Zwischenfrage reingrätschen:
                                      es geht um diese Card:
                                      geschaltet / gedimmt wird über knx -> dali. Die KNX Adresse / Rückmeldeadresse habe ich wie im knx-beitrag im raw modus geändert. Die Verknüfung mittels Funktionen und Räume gesetzte. Wenn ich den Drehregler betätige wird die Lampe entsprechend auf Wert gedimmt. Was nicht geht, ist wenn ich auf das Lampensymbol klicke. Dann passiert nichts. Ich habe als enitity die Dimmwertgruppenadresse angegeben. Benötigt diese Card noch eine 2te enitiy, dass das funktionert?
                                      (ich habe 4 gruppenadressen für diese Lampe. Schalt + RM Schalt, bzw. Dimmwert und RM Dimmwert)
                                      • marcuskl
                                        marcuskl @Garfonso last edited by
                                        @Garfonso
                                        Ich habe den Link nochmal neu installiert und das mit der Helligkeit funktioniert jetzt, aber mit der Farbtemperatur nicht.
                                        Habe nun in dem Farbtemperatur Objekt ein min Wert und ein max Wert hinzugefügt und jetzt geht es.
                                        Beim Shelly funktioniert garnichts, also net mal das einschalten.
                                        2019-12-30 08:47:29.518 - info: host.iobroker instance system.adapter.lovelace.0 terminated with code 156 (156)
                                        2019-12-30 08:47:31.501 - info: host.iobroker instance system.adapter.lovelace.0 started with pid 18046
                                        2019-12-30 08:47:33.403 - debug: lovelace.0 (18046) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        2019-12-30 08:47:33.440 - debug: lovelace.0 (18046) Objects client ready ... initialize now
                                        2019-12-30 08:47:33.444 - debug: lovelace.0 (18046) Objects create PubSub Client
                                        2019-12-30 08:47:33.445 - debug: lovelace.0 (18046) Objects client initialize lua scripts
                                        2019-12-30 08:47:33.459 - debug: lovelace.0 (18046) objectDB connected
                                        2019-12-30 08:47:33.461 - debug: lovelace.0 (18046) Redis States: Use Redis connection: 127.0.0.1:9000
                                        2019-12-30 08:47:33.465 - debug: lovelace.0 (18046) Objects connected to redis: 127.0.0.1:9001
                                        2019-12-30 08:47:33.473 - debug: lovelace.0 (18046) States create PubSub Client
                                        2019-12-30 08:47:33.475 - debug: lovelace.0 (18046) statesDB connected
                                        2019-12-30 08:47:33.530 - debug: lovelace.0 (18046) States connected to redis: 127.0.0.1:9000
                                        2019-12-30 08:47:35.089 - info: lovelace.0 (18046) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.lovelace, node: v10.17.0
                                        2019-12-30 08:47:35.207 - debug: lovelace.0 (18046) Schedule restart: 0 2 * * *
                                        2019-12-30 08:47:35.244 - info: lovelace.0 (18046) http server listening on port 8091
                                        2019-12-30 08:47:35.849 - debug: lovelace.0 (18046) rgb - Controls: {
                                        "states": [
                                        "indicator": false,
                                        "type": "number",
                                        "write": true,
                                        "name": "RED",
                                        "required": true,
                                        "defaultRole": "level.color.red",
                                        "id": "shelly.0.SHRGBW2#5A38A7#1.color.red"
                                        "indicator": false,
                                        "type": "number",
                                        "write": true,
                                        "name": "GREEN",
                                        "required": true,
                                        "defaultRole": "level.color.green",
                                        "id": "shelly.0.SHRGBW2#5A38A7#1.color.green"
                                        "indicator": false,
                                        "type": "number",
                                        "write": true,
                                        "name": "BLUE",
                                        "required": true,
                                        "defaultRole": "level.color.blue",
                                        "id": "shelly.0.SHRGBW2#5A38A7#1.color.blue"
                                        "indicator": false,
                                        "type": "number",
                                        "write": true,
                                        "name": "DIMMER",
                                        "required": false,
                                        "defaultRole": "level.dimmer"
                                        "indicator": false,
                                        "type": "number",
                                        "write": true,
                                        "name": "BRIGHTNESS",
                                        "required": false,
                                        "id": "shelly.0.SHRGBW2#5A38A7#1.color.gain"
                                        "indicator": false,
                                        "type": "number",
                                        "write": true,
                                        "name": "SATURATION",
                                        "required": false
                                        "indicator": false,
                                        "type": "number",
                                        "write": true,
                                        "name": "TEMPERATURE",
                                        "required": false,
                                        "defaultRole": "level.color.temperature"
                                        "indicator": false,
                                        "type": "boolean",
                                        "write": true,
                                        "name": "ON_LIGHT",
                                        "required": false,
                                        "defaultRole": "switch.light"
                                        "indicator": false,
                                        "type": "boolean",
                                        "write": true,
                                        "name": "ON",
                                        "required": false,
                                        "id": "shelly.0.SHRGBW2#5A38A7#1.color.Switch"
                                        "indicator": false,
                                        "type": "boolean",
                                        "write": false,
                                        "name": "ON_ACTUAL",
                                        "required": false,
                                        "defaultRole": "state.light"
                                        "indicator": true,
                                        "name": "WORKING",
                                        "required": false,
                                        "defaultRole": "indicator.working"
                                        "indicator": true,
                                        "type": "boolean",
                                        "name": "UNREACH",
                                        "required": false,
                                        "defaultRole": "indicator.maintenance.unreach"
                                        "indicator": true,
                                        "type": "boolean",
                                        "name": "LOWBAT",
                                        "required": false,
                                        "defaultRole": "indicator.maintenance.lowbat"
                                        "indicator": true,
                                        "type": "boolean",
                                        "name": "MAINTAIN",
                                        "required": false,
                                        "defaultRole": "indicator.maintenance"
                                        "indicator": true,
                                        "name": "ERROR",
                                        "required": false,
                                        "defaultRole": "indicator.error"
                                        "type": "rgb"
                                        2019-12-30 08:47:35.855 - debug: lovelace.0 (18046) [Type-Detector] Created auto device: light.LED_Strips_Wohnzimmer - rgb - shelly.0.SHRGBW2#5A38A7#1.color
                                        2019-12-30 08:47:35.856 - warn: lovelace.0 (18046) Could not add shelly.0.SHRGBW2#5A38A7#1.color of type rgbSingle -> no on/off control found.
                                        2019-12-30 08:47:35.856 - debug: lovelace.0 (18046) dimmer - Controls: {
                                        "states": [
                                        "indicator": false,
                                        "type": "number",
                                        "write": true,
                                        "name": "SET",
                                        "required": true,
                                        "defaultRole": "level.dimmer",
                                        "id": "shelly.0.SHRGBW2#5A38A7#1.color.white"
                                        "indicator": false,
                                        "type": "number",
                                        "write": false,
                                        "name": "ACTUAL",
                                        "required": false,
                                        "defaultRole": "value.dimmer"
                                        "indicator": false,
                                        "type": "boolean",
                                        "write": true,
                                        "name": "ON_SET",
                                        "required": false,
                                        "indicator": false,
                                        "type": "boolean",
                                        "write": false,
                                        "required": false,
                                        "indicator": true,
                                        "name": "WORKING",
                                        "required": false,
                                        "indicator": true,
                                        "type": "boolean",
                                        "name": "UNREACH",
                                        "required": false,
                                        "indicator": true,
                                        "type": "boolean",
                                        "name": "LOWBAT",
                                        "required": false,
                                        "indicator": true,
                                        "type": "boolean",
                                        "name": "MAINTAIN",
                                        "required": false,
                                        "indicator": true,
                                        "name": "ERROR",
                                        "required": false,
                                        "type": "dimmer"
                                        2019-12-30 08:47:35.858 - warn: lovelace.0 (18046) Duplicates found for light.LED_Strips_Wohnzimmer
                                        2019-12-30 08:47:35.858 - debug: lovelace.0 (18046) [Type-Detector] device shelly.0.SHRGBW2#5A38A7#1.color.effect - info - shelly.0.SHRGBW2#5A38A7#1.color is not yet supported
                                        2019-12-30 08:47:35.864 - debug: lovelace.0 (18046) [Type-Detector] Created auto device: light.Switch - light - shelly.0.SHSW-1#12C27E#1.Relay0.Switch
                                        2019-12-30 08:47:35.868 - warn: lovelace.0 (18046) Duplicates found for light.Switch
                                        2019-12-30 08:47:35.874 - warn: lovelace.0 (18046) Duplicates found for light.Switch
                                        2019-12-30 08:47:35.879 - debug: lovelace.0 (18046) [Type-Detector] Created auto device: light.K_chenlicht_POWER - light - sonoff.0.Küchenlicht.POWER
                                        2019-12-30 08:47:35.885 - debug: lovelace.0 (18046) [Type-Detector] Created auto device: light.Nachtlicht_Benchy_POWER - light - sonoff.0.Nachtlicht Benchy.POWER
                                        2019-12-30 08:47:35.899 - debug: lovelace.0 (18046) [Type-Detector] Created auto device: light.Nachtlicht_Flur - light - sonoff.0.Nachtlicht Flur
                                        2019-12-30 08:47:35.900 - debug: lovelace.0 (18046) [Type-Detector] device sonoff.0.Nachtlicht Flur.Time - info - sonoff.0.Nachtlicht Flur is not yet supported
                                        2019-12-30 08:47:35.904 - debug: lovelace.0 (18046) [Type-Detector] Created auto device: light.Nachtlicht_Liah_POWER - light - sonoff.0.Nachtlicht Liah.POWER
                                        2019-12-30 08:47:35.908 - debug: lovelace.0 (18046) [Type-Detector] Created auto device: light.Nachtlicht_Marcus_POWER - light - sonoff.0.Nachtlicht Marcus.POWER
                                        2019-12-30 08:47:35.913 - debug: lovelace.0 (18046) [Type-Detector] Created auto device: light.Schreibtischlampe_POWER - light - sonoff.0.Schreibtischlampe.POWER
                                        2019-12-30 08:47:35.928 - debug: lovelace.0 (18046) [Type-Detector] Created auto device: light.Weihnachtsbaum - light - sonoff.0.Weihnachtsbaum
                                        2019-12-30 08:47:35.929 - debug: lovelace.0 (18046) [Type-Detector] device sonoff.0.Weihnachtsbaum.Time - info - sonoff.0.Weihnachtsbaum is not yet supported
                                        2019-12-30 08:47:35.934 - debug: lovelace.0 (18046) [Type-Detector] device lgtv.0.states.volume - info - lgtv.0.states.volume is not yet supported
                                        2019-12-30 08:47:35.941 - debug: lovelace.0 (18046) [Type-Detector] Created auto device: switch.Switch_TV_power - socket - lgtv.0.states.power
                                        2019-12-30 08:47:35.944 - debug: lovelace.0 (18046) [Type-Detector] device lgtv.0.states.launch - info - lgtv.0.states.launch is not yet supported
                                        2019-12-30 08:47:35.948 - debug: lovelace.0 (18046) [Type-Detector] Created auto device: switch.TV_Steckdose_POWER - socket - sonoff.0.TV Steckdose.POWER
                                        2019-12-30 08:47:35.952 - debug: lovelace.0 (18046) [Type-Detector] Created auto device: switch.switch_on - socket - tuya.0.17014830b4e62d5a02cc.1
                                        2019-12-30 08:47:35.956 - debug: lovelace.0 (18046) [Type-Detector] device chromecast.0.Küche.status.volume - volume - chromecast.0.Küche.status.volume is not yet supported
                                        2019-12-30 08:47:35.960 - debug: lovelace.0 (18046) [Type-Detector] device chromecast.0.Schlafzimmer.status.volume - volume - chromecast.0.Schlafzimmer.status.volume is not yet supported
                                        2019-12-30 08:47:35.964 - debug: lovelace.0 (18046) [Type-Detector] device chromecast.0.WohnzimmerJBL.status.volume - volume - chromecast.0.WohnzimmerJBL.status.volume is not yet supported
                                        2019-12-30 08:47:35.967 - debug: lovelace.0 (18046) [Type-Detector] device zigbee.0.000b57fffe897c9a.battery - info - zigbee.0.000b57fffe897c9a.battery is not yet supported
                                        2019-12-30 08:47:35.970 - debug: lovelace.0 (18046) [Type-Detector] device zigbee.0.00158d000320258a.battery - info - zigbee.0.00158d000320258a.battery is not yet supported
                                        2019-12-30 08:47:35.974 - debug: lovelace.0 (18046) [Type-Detector] device zigbee.0.ccccccfffe31ffb8.battery - info - zigbee.0.ccccccfffe31ffb8.battery is not yet supported
                                        2019-12-30 08:47:35.977 - debug: lovelace.0 (18046) [Type-Detector] device zigbee.0.00158d0003d53cb8.battery - info - zigbee.0.00158d0003d53cb8.battery is not yet supported
                                        2019-12-30 08:47:36.054 - debug: lovelace.0 (18046) [Type-Detector] Created auto device: weather.Gaggenau__Baden_W_rttemberg_Deutschland_ - weatherForecast - daswetter.0.NextDays.Location_1
                                        2019-12-30 08:47:36.054 - debug: lovelace.0 (18046) [Type-Detector] device daswetter.0.NextDays.Location_1.Day_1.Wetter_Symbol_id - info - daswetter.0.NextDays.Location_1 is not yet supported
                                        2019-12-30 08:47:36.056 - debug: lovelace.0 (18046) [Type-Detector] device scene.0.Bettfertig - info - scene.0.Bettfertig is not yet supported
                                        2019-12-30 08:47:36.057 - debug: lovelace.0 (18046) [Type-Detector] device scene.0.Fernsehabend - info - scene.0.Fernsehabend is not yet supported
                                        2019-12-30 08:47:36.068 - debug: lovelace.0 (18046) rgbSingle - Controls: {
                                        "states": [
                                        "indicator": false,
                                        "type": "string",
                                        "write": true,
                                        "name": "RGB",
                                        "required": true,
                                        "defaultRole": "level.color.rgb",
                                        "id": "zigbee.0.ccccccfffe5c48af.color"
                                        "indicator": false,
                                        "type": "number",
                                        "write": true,
                                        "name": "DIMMER",
                                        "required": false,
                                        "id": "zigbee.0.ccccccfffe5c48af.brightness"
                                        "indicator": false,
                                        "type": "number",
                                        "write": true,
                                        "required": false
                                        "indicator": false,
                                        "type": "number",
                                        "write": true,
                                        "required": false
                                        "indicator": false,
                                        "type": "number",
                                        "write": true,
                                        "required": false,
                                        "defaultRole": "level.color.temperature",
                                        "id": "zigbee.0.ccccccfffe5c48af.colortemp"
                                        "indicator": false,
                                        "type": "boolean",
                                        "write": true,
                                        "name": "ON_LIGHT",
                                        "required": false,
                                        "indicator": false,
                                        "type": "boolean",
                                        "write": true,
                                        "name": "ON",
                                        "required": false,
                                        "id": "zigbee.0.ccccccfffe5c48af.state"
                                        "indicator": false,
                                        "type": "boolean",
                                        "write": false,
                                        "required": false,
                                        "defaultRole": "state.light",
                                        "id": "zigbee.0.ccccccfffe5c48af.available"
                                        "indicator": true,
                                        "name": "WORKING",
                                        "required": false,
                                        "indicator": true,
                                        "type": "boolean",
                                        "name": "UNREACH",
                                        "required": false,
                                        "indicator": true,
                                        "type": "boolean",
                                        "name": "LOWBAT",
                                        "required": false,
                                        "indicator": true,
                                        "type": "boolean",
                                        "name": "MAINTAIN",
                                        "required": false,
                                        "indicator": true,
                                        "name": "ERROR",
                                        "required": false,
                                        "type": "rgbSingle"
                                        2019-12-30 08:47:36.070 - debug: lovelace.0 (18046) light.Stehlampe ct needs kelvin conversion: true
                                        2019-12-30 08:47:36.070 - debug: lovelace.0 (18046) Color already present, skip R,G,B color.
                                        2019-12-30 08:47:36.071 - debug: lovelace.0 (18046) [Type-Detector] Created auto device: light.Stehlampe - rgbSingle - zigbee.0.ccccccfffe5c48af
                                        2019-12-30 08:47:36.071 - debug: lovelace.0 (18046) [Type-Detector] device zigbee.0.ccccccfffe5c48af.groups - info - zigbee.0.ccccccfffe5c48af is not yet supported
                                        2019-12-30 08:47:36.072 - debug: lovelace.0 (18046) AUTO Device detected: shelly.0.SHRGBW2#5A38A7#1.color => light
                                        2019-12-30 08:47:36.072 - debug: lovelace.0 (18046) AUTO Device detected: shelly.0.SHSW-1#12C27E#1.Relay0.Switch => light
                                        2019-12-30 08:47:36.072 - debug: lovelace.0 (18046) AUTO Device detected: sonoff.0.Küchenlicht.POWER => light
                                        2019-12-30 08:47:36.073 - debug: lovelace.0 (18046) AUTO Device detected: sonoff.0.Nachtlicht Benchy.POWER => light
                                        2019-12-30 08:47:36.073 - debug: lovelace.0 (18046) AUTO Device detected: sonoff.0.Nachtlicht Flur => light
                                        2019-12-30 08:47:36.073 - debug: lovelace.0 (18046) AUTO Device detected: sonoff.0.Nachtlicht Liah.POWER => light
                                        2019-12-30 08:47:36.073 - debug: lovelace.0 (18046) AUTO Device detected: sonoff.0.Nachtlicht Marcus.POWER => light
                                        2019-12-30 08:47:36.074 - debug: lovelace.0 (18046) AUTO Device detected: sonoff.0.Schreibtischlampe.POWER => light
                                        2019-12-30 08:47:36.074 - debug: lovelace.0 (18046) AUTO Device detected: sonoff.0.Weihnachtsbaum => light
                                        2019-12-30 08:47:36.074 - debug: lovelace.0 (18046) AUTO Device detected: lgtv.0.states.power => switch
                                        2019-12-30 08:47:36.074 - debug: lovelace.0 (18046) AUTO Device detected: sonoff.0.TV Steckdose.POWER => switch
                                        2019-12-30 08:47:36.075 - debug: lovelace.0 (18046) AUTO Device detected: tuya.0.17014830b4e62d5a02cc.1 => switch
                                        2019-12-30 08:47:36.075 - debug: lovelace.0 (18046) AUTO Device detected: daswetter.0.NextDays.Location_1 => weather
                                        2019-12-30 08:47:36.075 - debug: lovelace.0 (18046) AUTO Device detected: zigbee.0.ccccccfffe5c48af => light
                                        2019-12-30 08:47:36.124 - debug: lovelace.0 (18046) Create manual device: sensor.CPU_Temperatur - info.0.sysinfo.cpu.temperature.main
                                        2019-12-30 08:47:36.143 - debug: lovelace.0 (18046) Create manual device: input_select.tv_launch - lgtv.0.states.launch
                                        2019-12-30 08:47:36.146 - debug: lovelace.0 (18046) Create manual device: input_number.FernseherVolume - lgtv.0.states.volume
                                        2019-12-30 08:47:36.149 - debug: lovelace.0 (18046) Create manual device: media_player.tv_remote_rewind - lgtv.0.states.mediaRewind
                                        2019-12-30 08:47:36.151 - debug: lovelace.0 (18046) Create manual device: media_player.tv_remote_forward - lgtv.0.states.mediaFastForward
                                        2019-12-30 08:47:36.153 - debug: lovelace.0 (18046) Create manual device: media_player.tv_pause - lgtv.0.states.mediaPause
                                        2019-12-30 08:47:36.155 - debug: lovelace.0 (18046) Create manual device: media_player.tv_remote_play - lgtv.0.states.mediaPlay
                                        2019-12-30 08:47:36.158 - debug: lovelace.0 (18046) Create manual device: media_player.tv_channel_down - lgtv.0.states.channelDown
                                        2019-12-30 08:47:36.162 - debug: lovelace.0 (18046) Create manual device: media_player.tv_channel_up - lgtv.0.states.channelUp
                                        2019-12-30 08:47:36.164 - debug: lovelace.0 (18046) Create manual device: media_player.tv_volume_down - lgtv.0.states.volumeDown
                                        2019-12-30 08:47:36.166 - debug: lovelace.0 (18046) Create manual device: media_player.tv_volume_up - lgtv.0.states.volumeUp
                                        2019-12-30 08:47:36.168 - debug: lovelace.0 (18046) Create manual device: switch.tv_remote_mute - lgtv.0.states.mute
                                        2019-12-30 08:47:36.170 - debug: lovelace.0 (18046) Create manual device: light.Schlafzimmerlicht - shelly.0.SHSW-1#12C27E#1.Relay0.Switch
                                        2019-12-30 08:47:36.172 - debug: lovelace.0 (18046) Create manual device: light.Wohnzimmerlicht - shelly.0.SHSW-1#94147C#1.Relay0.Switch
                                        2019-12-30 08:47:36.174 - debug: lovelace.0 (18046) Create manual device: switch.Fernseher - javascript.0.scriptEnabled.Vis.Fernseher_Power
                                        2019-12-30 08:47:36.177 - debug: lovelace.0 (18046) Create manual device: light.Flurlicht - shelly.0.SHSW-1#943F39#1.Relay0.Switch
                                        2019-12-30 08:47:36.179 - debug: lovelace.0 (18046) Create manual device: sensor.pve_cpu_utilization - proxmox.0.node_pve.cpu
                                        2019-12-30 08:47:36.181 - debug: lovelace.0 (18046) Create manual device: sensor.server_ram_auslastung - proxmox.0.node_pve.memory.used_lev
                                        2019-12-30 08:47:36.183 - debug: lovelace.0 (18046) Create manual device: sensor.akku_bm_flur - zigbee.0.00158d000320258a.battery
                                        2019-12-30 08:47:36.186 - debug: lovelace.0 (18046) Create manual device: input_boolean.Schreibtisch - tuya.0.17014830b4e62d5a02cc.1
                                        2019-12-30 08:47:36.188 - debug: lovelace.0 (18046) Create manual device: sensor.Schreibtisch_Strom - tuya.0.17014830b4e62d5a02cc.4
                                        2019-12-30 08:47:36.190 - debug: lovelace.0 (18046) Create manual device: input_number.GHomeWohnzimmer - chromecast.0.WohnzimmerJBL.status.volume
                                        2019-12-30 08:47:36.193 - debug: lovelace.0 (18046) Create manual device: input_number.GHomeSchlafzimmer - chromecast.0.Schlafzimmer.status.volume
                                        2019-12-30 08:47:36.195 - debug: lovelace.0 (18046) Create manual device: input_number.GHomeKueche - chromecast.0.Küche.status.volume
                                        2019-12-30 08:47:36.198 - debug: lovelace.0 (18046) Create manual device: input_boolean.zuruck - broadlink2.0.RM:RMMINI-40-7c-2f.L.CODE_26001a000f07064d0c6a0c0001d009000265090002440f0006470a000d050000000000000000000000000000
                                        2019-12-30 08:47:36.200 - debug: lovelace.0 (18046) Create manual device: light.Schreibtischlampe - sonoff.0.Schreibtischlampe.POWER
                                        2019-12-30 08:47:36.202 - debug: lovelace.0 (18046) Create manual device: sensor.MaxDownstream - upnp.0.WANDevice_-_FRITZ!Box_6490_Cable.WANDevice.WANCommonInterfaceConfig.GetCommonLinkProperties.DownstreamMaxKbit
                                        2019-12-30 08:47:36.204 - debug: lovelace.0 (18046) Create manual device: sensor.MaxUpstream - upnp.0.WANDevice_-_FRITZ!Box_6490_Cable.WANDevice.WANCommonInterfaceConfig.GetCommonLinkProperties.UpstreamMaxKbit
                                        2019-12-30 08:47:36.206 - debug: lovelace.0 (18046) Create manual device: sensor.akku_dimmer - zigbee.0.000b57fffe897c9a.battery
                                        2019-12-30 08:47:36.208 - debug: lovelace.0 (18046) Create manual device: media_player.tv_remote_home - lgtv.0.remote.home
                                        2019-12-30 08:47:36.210 - debug: lovelace.0 (18046) Create manual device: media_player.tv_remote_menu - lgtv.0.remote.menu
                                        2019-12-30 08:47:36.212 - debug: lovelace.0 (18046) Create manual device: media_player.tv_remote_back - lgtv.0.remote.back
                                        2019-12-30 08:47:36.215 - debug: lovelace.0 (18046) Create manual device: media_player.tv_remote_up - lgtv.0.remote.up
                                        2019-12-30 08:47:36.216 - debug: lovelace.0 (18046) Create manual device: media_player.tv_remote_down - lgtv.0.remote.down
                                        2019-12-30 08:47:36.218 - debug: lovelace.0 (18046) Create manual device: media_player.tv_remote_left - lgtv.0.remote.left
                                        2019-12-30 08:47:36.221 - debug: lovelace.0 (18046) Create manual device: media_player.tv_remote_right - lgtv.0.remote.right
                                        2019-12-30 08:47:36.223 - debug: lovelace.0 (18046) Create manual device: media_player.tv_remote_enter - lgtv.0.remote.enter
                                        2019-12-30 08:47:36.225 - debug: lovelace.0 (18046) Create manual device: sensor.akku_switch_marcus - zigbee.0.00158d00026ebcbf.battery
                                        2019-12-30 08:47:36.227 - debug: lovelace.0 (18046) Create manual device: sensor.energie_gesamt - sonoff.0.Zähler Verteiler.ENERGY_Total
                                        2019-12-30 08:47:36.229 - debug: lovelace.0 (18046) Create manual device: sensor.energie_heute - sonoff.0.Zähler Verteiler.ENERGY_Today
                                        2019-12-30 08:47:36.231 - debug: lovelace.0 (18046) Create manual device: sensor.l1_leistung - sonoff.0.Zähler Verteiler.ENERGY_Power_0
                                        2019-12-30 08:47:36.233 - debug: lovelace.0 (18046) Create manual device: sensor.l2_leistung - sonoff.0.Zähler Verteiler.ENERGY_Power_1
                                        2019-12-30 08:47:36.239 - debug: lovelace.0 (18046) Create manual device: sensor.l3_leistung - sonoff.0.Zähler Verteiler.ENERGY_Power_2
                                        2019-12-30 08:47:36.241 - debug: lovelace.0 (18046) Create manual device: sensor.l1_spannung - sonoff.0.Zähler Verteiler.ENERGY_Voltage_0
                                        2019-12-30 08:47:36.243 - debug: lovelace.0 (18046) Create manual device: sensor.l2_spannung - sonoff.0.Zähler Verteiler.ENERGY_Voltage_1
                                        2019-12-30 08:47:36.245 - debug: lovelace.0 (18046) Create manual device: sensor.l3_spannung - sonoff.0.Zähler Verteiler.ENERGY_Voltage_2
                                        2019-12-30 08:47:36.247 - debug: lovelace.0 (18046) Create manual device: sensor.l1_strom - sonoff.0.Zähler Verteiler.ENERGY_Current_0
                                        2019-12-30 08:47:36.249 - debug: lovelace.0 (18046) Create manual device: sensor.l2_strom - sonoff.0.Zähler Verteiler.ENERGY_Current_1
                                        2019-12-30 08:47:36.250 - debug: lovelace.0 (18046) Create manual device: sensor.l3_strom - sonoff.0.Zähler Verteiler.ENERGY_Current_2
                                        2019-12-30 08:47:36.252 - debug: lovelace.0 (18046) Create manual device: sensor.akku_stehlampe_schalter - zigbee.0.ccccccfffe31ffb8.battery
                                        2019-12-30 08:47:36.254 - debug: lovelace.0 (18046) Create manual device: light.nachtlicht_flur - sonoff.0.Nachtlicht Flur.POWER
                                        2019-12-30 08:47:36.256 - debug: lovelace.0 (18046) Create manual device: sensor.akku_tür_sensor - zigbee.0.00158d0003d53cb8.battery
                                        2019-12-30 08:47:36.258 - debug: lovelace.0 (18046) Create manual device: switch.green - 0_userdata.0.Lovelace.Emulate.wohnzimmer_grün
                                        2019-12-30 08:47:36.260 - debug: lovelace.0 (18046) Create manual device: switch.blue - 0_userdata.0.Lovelace.Emulate.wohnzimmer_blau
                                        2019-12-30 08:47:36.262 - debug: lovelace.0 (18046) Create manual device: switch.red - 0_userdata.0.Lovelace.Emulate.wohnzimmer_red
                                        2019-12-30 08:47:36.264 - debug: lovelace.0 (18046) Create manual device: switch.turkis - 0_userdata.0.Lovelace.Emulate.wohnzimmer_turkis
                                        2019-12-30 08:47:36.266 - debug: lovelace.0 (18046) Create manual device: switch.violett - 0_userdata.0.Lovelace.Emulate.wohnzimmer_violtett
                                        2019-12-30 08:47:36.267 - debug: lovelace.0 (18046) Create manual device: switch.warmweiß - 0_userdata.0.Lovelace.Emulate.wohnzimmer_warmweiß
                                        2019-12-30 08:47:36.269 - debug: lovelace.0 (18046) Create manual device: switch.kaltweiß - 0_userdata.0.Lovelace.Emulate.wohnzimmer_kaltweiß
                                        2019-12-30 08:47:36.271 - debug: lovelace.0 (18046) Create manual device: switch.v_up_ghome_wohnzimmer - 0_userdata.0.Lovelace.Emulate.v_up_ghome_wohnzimmer
                                        2019-12-30 08:47:36.273 - debug: lovelace.0 (18046) Create manual device: switch.v_down_ghome_wohnzimmer - 0_userdata.0.Lovelace.Emulate.v_down_ghome_wohnzimmer
                                        2019-12-30 08:47:36.275 - debug: lovelace.0 (18046) Create manual device: switch.tv_remote_netflix - 0_userdata.0.Lovelace.Emulate.launch_netflix
                                        2019-12-30 08:47:36.276 - debug: lovelace.0 (18046) Create manual device: switch.tv_remote_amazon - 0_userdata.0.Lovelace.Emulate.launch_amazon
                                        2019-12-30 08:47:36.278 - debug: lovelace.0 (18046) Create manual device: switch.v_down_ghome_kueche - 0_userdata.0.Lovelace.Emulate.v_down_ghome_kueche
                                        2019-12-30 08:47:36.280 - debug: lovelace.0 (18046) Create manual device: switch.v_up_ghome_kueche - 0_userdata.0.Lovelace.Emulate.v_up_ghome_kueche
                                        2019-12-30 08:47:36.282 - debug: lovelace.0 (18046) Create manual device: switch.v_down_ghome_schlafzimmer - 0_userdata.0.Lovelace.Emulate.v_down_ghome_schlafzimmer
                                        2019-12-30 08:47:36.284 - debug: lovelace.0 (18046) Create manual device: switch.v_up_ghome_schlafzimmer - 0_userdata.0.Lovelace.Emulate.v_up_ghome_schlafzimmer
                                        2019-12-30 08:47:36.286 - debug: lovelace.0 (18046) Create manual device: switch.fernsehabend - scene.0.Fernsehabend
                                        2019-12-30 08:47:36.288 - debug: lovelace.0 (18046) Create manual device: switch.rgb_syncron - 0_userdata.0.Automation.rgb_syncron
                                        2019-12-30 08:47:36.289 - debug: lovelace.0 (18046) Create manual device: switch.schreibtischsteckdose_automatik - 0_userdata.0.Automation.schreibtischsteckdose_automatik_aus
                                        2019-12-30 08:47:36.291 - debug: lovelace.0 (18046) Create manual device: switch.flurlicht_automatik - 0_userdata.0.Automation.flurlicht_automatik
                                        2019-12-30 08:47:36.293 - debug: lovelace.0 (18046) Create manual device: switch.zentral_aus - 0_userdata.0.Zentral_Funktionen.zentral_aus
                                        2019-12-30 08:47:36.295 - debug: lovelace.0 (18046) Create manual device: switch.led_strips_automatik - 0_userdata.0.Automation.led_strips_automatik
                                        2019-12-30 08:47:36.297 - debug: lovelace.0 (18046) Create manual device: switch.bettfertig - scene.0.Bettfertig
                                        2019-12-30 08:47:36.299 - debug: lovelace.0 (18046) Create manual device: alarm_control_panel.defaultAlarm - lovelace.0.control.alarm
                                        2019-12-30 08:47:36.305 - debug: lovelace.0 (18046) light.LED_Strips_Wohnzimmer got [0,100,100] from Red 255 and {"r":255,"g":0,"b":0} and old hsv [0,100,100]
                                        2019-12-30 08:47:36.306 - debug: lovelace.0 (18046) light.LED_Strips_Wohnzimmer got [0,100,100] from Green 0 and {"r":255,"g":0,"b":0} and old hsv [0,100,100]
                                        2019-12-30 08:47:36.306 - debug: lovelace.0 (18046) light.LED_Strips_Wohnzimmer got [0,100,100] from Blue 0 and {"r":255,"g":0,"b":0} and old hsv [0,100,100]
                                        2019-12-30 08:47:36.526 - debug: lovelace.0 (18046) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_1.iconURL
                                        2019-12-30 08:47:36.528 - debug: lovelace.0 (18046) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_1.Maximale_Temperatur_value
                                        2019-12-30 08:47:36.529 - debug: lovelace.0 (18046) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_2.iconURL
                                        2019-12-30 08:47:36.530 - debug: lovelace.0 (18046) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_2.Maximale_Temperatur_value
                                        2019-12-30 08:47:36.531 - debug: lovelace.0 (18046) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_2.Minimale_Temperatur_value
                                        2019-12-30 08:47:36.532 - debug: lovelace.0 (18046) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_3.iconURL
                                        2019-12-30 08:47:36.533 - debug: lovelace.0 (18046) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_3.Maximale_Temperatur_value
                                        2019-12-30 08:47:36.535 - debug: lovelace.0 (18046) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_3.Minimale_Temperatur_value
                                        2019-12-30 08:47:36.536 - debug: lovelace.0 (18046) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_4.iconURL
                                        2019-12-30 08:47:36.537 - debug: lovelace.0 (18046) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_4.Maximale_Temperatur_value
                                        2019-12-30 08:47:36.538 - debug: lovelace.0 (18046) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_4.Minimale_Temperatur_value
                                        2019-12-30 08:47:36.540 - debug: lovelace.0 (18046) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_5.iconURL
                                        2019-12-30 08:47:36.541 - debug: lovelace.0 (18046) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_5.Maximale_Temperatur_value
                                        2019-12-30 08:47:36.542 - debug: lovelace.0 (18046) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_5.Minimale_Temperatur_value
                                        2019-12-30 08:47:36.543 - debug: lovelace.0 (18046) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_6.iconURL
                                        2019-12-30 08:47:36.545 - debug: lovelace.0 (18046) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_6.Maximale_Temperatur_value
                                        2019-12-30 08:47:36.546 - debug: lovelace.0 (18046) IoB Subscribe on daswetter.0.NextDays.Location_1.Day_6.Minimale_Temperatur_value
                                        2019-12-30 08:47:36.548 - debug: lovelace.0 (18046) IoB Subscribe on 0_userdata.0.Zentral_Funktionen.zentral_aus
                                        2019-12-30 08:47:36.549 - debug: lovelace.0 (18046) IoB Subscribe on scene.0.Bettfertig
                                        2019-12-30 08:47:36.550 - debug: lovelace.0 (18046) IoB Subscribe on scene.0.Fernsehabend
                                        2019-12-30 08:47:36.552 - debug: lovelace.0 (18046) IoB Subscribe on shelly.0.SHSW-1#943F39#1.Relay0.Switch
                                        2019-12-30 08:47:36.553 - debug: lovelace.0 (18046) IoB Subscribe on shelly.0.SHSW-1#12C27E#1.Relay0.Switch
                                        2019-12-30 08:47:36.554 - debug: lovelace.0 (18046) IoB Subscribe on sonoff.0.Nachtlicht Benchy.POWER
                                        2019-12-30 08:47:36.556 - debug: lovelace.0 (18046) IoB Subscribe on shelly.0.SHSW-1#94147C#1.Relay0.Switch
                                        2019-12-30 08:47:36.556 - debug: lovelace.0 (18046) IoB Subscribe on zigbee.0.ccccccfffe5c48af.state
                                        2019-12-30 08:47:36.557 - debug: lovelace.0 (18046) IoB Subscribe on zigbee.0.ccccccfffe5c48af.colortemp
                                        2019-12-30 08:47:36.559 - debug: lovelace.0 (18046) IoB Subscribe on zigbee.0.ccccccfffe5c48af.brightness
                                        2019-12-30 08:47:36.559 - debug: lovelace.0 (18046) IoB Subscribe on zigbee.0.ccccccfffe5c48af.color
                                        2019-12-30 08:47:36.560 - debug: lovelace.0 (18046) IoB Subscribe on shelly.0.SHRGBW2#5A38A7#1.color.white
                                        2019-12-30 08:47:36.561 - debug: lovelace.0 (18046) IoB Subscribe on sonoff.0.Nachtlicht Liah.POWER
                                        2019-12-30 08:47:36.562 - debug: lovelace.0 (18046) IoB Subscribe on sonoff.0.Küchenlicht.POWER
                                        2019-12-30 08:47:36.562 - debug: lovelace.0 (18046) IoB Subscribe on sonoff.0.Schreibtischlampe.POWER
                                        2019-12-30 08:47:36.563 - debug: lovelace.0 (18046) IoB Subscribe on sonoff.0.Nachtlicht Flur.POWER
                                        2019-12-30 08:47:36.564 - debug: lovelace.0 (18046) IoB Subscribe on sonoff.0.Weihnachtsbaum.POWER
                                        2019-12-30 08:47:36.565 - debug: lovelace.0 (18046) IoB Subscribe on sonoff.0.TV Steckdose.POWER
                                        2019-12-30 08:47:36.567 - debug: lovelace.0 (18046) IoB Subscribe on tuya.0.17014830b4e62d5a02cc.1
                                        2019-12-30 08:47:36.568 - debug: lovelace.0 (18046) IoB Subscribe on 0_userdata.0.Automation.schreibtischsteckdose_automatik_aus
                                        2019-12-30 08:47:36.569 - debug: lovelace.0 (18046) IoB Subscribe on 0_userdata.0.Automation.rgb_syncron
                                        2019-12-30 08:47:36.571 - debug: lovelace.0 (18046) IoB Subscribe on 0_userdata.0.Automation.led_strips_automatik
                                        2019-12-30 08:47:36.572 - debug: lovelace.0 (18046) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.wohnzimmer_red
                                        2019-12-30 08:47:36.573 - debug: lovelace.0 (18046) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.wohnzimmer_blau
                                        2019-12-30 08:47:36.574 - debug: lovelace.0 (18046) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.wohnzimmer_grün
                                        2019-12-30 08:47:36.575 - debug: lovelace.0 (18046) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.wohnzimmer_violtett
                                        2019-12-30 08:47:36.576 - debug: lovelace.0 (18046) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.wohnzimmer_turkis
                                        2019-12-30 08:47:36.577 - debug: lovelace.0 (18046) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.wohnzimmer_warmweiß
                                        2019-12-30 08:47:36.578 - debug: lovelace.0 (18046) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.wohnzimmer_kaltweiß
                                        2019-12-30 08:47:36.579 - debug: lovelace.0 (18046) IoB Subscribe on sonoff.0.Nachtlicht Marcus.POWER
                                        2019-12-30 08:47:36.580 - debug: lovelace.0 (18046) IoB Subscribe on 0_userdata.0.Automation.flurlicht_automatik
                                        2019-12-30 08:47:36.582 - debug: lovelace.0 (18046) IoB Subscribe on lgtv.0.states.power
                                        2019-12-30 08:47:36.586 - debug: lovelace.0 (18046) IoB Subscribe on lgtv.0.remote.back
                                        2019-12-30 08:47:36.586 - debug: lovelace.0 (18046) IoB Subscribe on lgtv.0.remote.menu
                                        2019-12-30 08:47:36.587 - debug: lovelace.0 (18046) IoB Subscribe on lgtv.0.remote.home
                                        2019-12-30 08:47:36.588 - debug: lovelace.0 (18046) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.launch_netflix
                                        2019-12-30 08:47:36.589 - debug: lovelace.0 (18046) IoB Subscribe on lgtv.0.remote.up
                                        2019-12-30 08:47:36.589 - debug: lovelace.0 (18046) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.launch_amazon
                                        2019-12-30 08:47:36.591 - debug: lovelace.0 (18046) IoB Subscribe on lgtv.0.remote.left
                                        2019-12-30 08:47:36.592 - debug: lovelace.0 (18046) IoB Subscribe on lgtv.0.remote.enter
                                        2019-12-30 08:47:36.592 - debug: lovelace.0 (18046) IoB Subscribe on lgtv.0.remote.right
                                        2019-12-30 08:47:36.593 - debug: lovelace.0 (18046) IoB Subscribe on lgtv.0.remote.down
                                        2019-12-30 08:47:36.594 - debug: lovelace.0 (18046) IoB Subscribe on lgtv.0.states.channelUp
                                        2019-12-30 08:47:36.594 - debug: lovelace.0 (18046) IoB Subscribe on lgtv.0.states.channelDown
                                        2019-12-30 08:47:36.596 - debug: lovelace.0 (18046) IoB Subscribe on lgtv.0.states.mediaRewind
                                        2019-12-30 08:47:36.597 - debug: lovelace.0 (18046) IoB Subscribe on lgtv.0.states.mediaPlay
                                        2019-12-30 08:47:36.598 - debug: lovelace.0 (18046) IoB Subscribe on lgtv.0.states.mediaFastForward
                                        2019-12-30 08:47:36.600 - debug: lovelace.0 (18046) IoB Subscribe on lgtv.0.states.volumeDown
                                        2019-12-30 08:47:36.601 - debug: lovelace.0 (18046) IoB Subscribe on lgtv.0.states.mute
                                        2019-12-30 08:47:36.602 - debug: lovelace.0 (18046) IoB Subscribe on lgtv.0.states.volumeUp
                                        2019-12-30 08:47:36.603 - debug: lovelace.0 (18046) IoB Subscribe on lgtv.0.states.launch
                                        2019-12-30 08:47:36.605 - debug: lovelace.0 (18046) IoB Subscribe on chromecast.0.WohnzimmerJBL.status.volume
                                        2019-12-30 08:47:36.605 - debug: lovelace.0 (18046) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.v_down_ghome_wohnzimmer
                                        2019-12-30 08:47:36.606 - debug: lovelace.0 (18046) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.v_up_ghome_wohnzimmer
                                        2019-12-30 08:47:36.607 - debug: lovelace.0 (18046) IoB Subscribe on chromecast.0.Küche.status.volume
                                        2019-12-30 08:47:36.608 - debug: lovelace.0 (18046) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.v_down_ghome_kueche
                                        2019-12-30 08:47:36.609 - debug: lovelace.0 (18046) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.v_up_ghome_kueche
                                        2019-12-30 08:47:36.609 - debug: lovelace.0 (18046) IoB Subscribe on chromecast.0.Schlafzimmer.status.volume
                                        2019-12-30 08:47:36.610 - debug: lovelace.0 (18046) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.v_down_ghome_schlafzimmer
                                        2019-12-30 08:47:36.611 - debug: lovelace.0 (18046) IoB Subscribe on 0_userdata.0.Lovelace.Emulate.v_up_ghome_schlafzimmer
                                        2019-12-30 08:47:36.612 - debug: lovelace.0 (18046) IoB Subscribe on upnp.0.WANDevice_-_FRITZ!Box_6490_Cable.WANDevice.WANCommonInterfaceConfig.GetCommonLinkProperties.DownstreamMaxKbit
                                        2019-12-30 08:47:36.613 - debug: lovelace.0 (18046) IoB Subscribe on upnp.0.WANDevice_-_FRITZ!Box_6490_Cable.WANDevice.WANCommonInterfaceConfig.GetCommonLinkProperties.UpstreamMaxKbit
                                        2019-12-30 08:47:36.613 - debug: lovelace.0 (18046) IoB Subscribe on sonoff.0.Zähler Verteiler.ENERGY_Current_0
                                        2019-12-30 08:47:36.614 - debug: lovelace.0 (18046) IoB Subscribe on sonoff.0.Zähler Verteiler.ENERGY_Current_1
                                        2019-12-30 08:47:36.615 - debug: lovelace.0 (18046) IoB Subscribe on sonoff.0.Zähler Verteiler.ENERGY_Current_2
                                        2019-12-30 08:47:36.616 - debug: lovelace.0 (18046) IoB Subscribe on sonoff.0.Zähler Verteiler.ENERGY_Power_0
                                        2019-12-30 08:47:36.617 - debug: lovelace.0 (18046) IoB Subscribe on sonoff.0.Zähler Verteiler.ENERGY_Power_1
                                        2019-12-30 08:47:36.618 - debug: lovelace.0 (18046) IoB Subscribe on sonoff.0.Zähler Verteiler.ENERGY_Power_2
                                        2019-12-30 08:47:36.618 - debug: lovelace.0 (18046) IoB Subscribe on sonoff.0.Zähler Verteiler.ENERGY_Today
                                        2019-12-30 08:47:36.619 - debug: lovelace.0 (18046) IoB Subscribe on zigbee.0.00158d00026ebcbf.battery
                                        2019-12-30 08:47:36.620 - debug: lovelace.0 (18046) IoB Subscribe on zigbee.0.000b57fffe897c9a.battery
                                        2019-12-30 08:47:36.621 - debug: lovelace.0 (18046) IoB Subscribe on zigbee.0.00158d000320258a.battery
                                        2019-12-30 08:47:36.623 - debug: lovelace.0 (18046) IoB Subscribe on zigbee.0.ccccccfffe31ffb8.battery
                                        2019-12-30 08:47:36.624 - debug: lovelace.0 (18046) IoB Subscribe on zigbee.0.00158d0003d53cb8.battery
                                        2019-12-30 08:47:38.865 - debug: lovelace.0 (18046) HASS Auth: no_token
                                        2019-12-30 08:47:39.157 - debug: lovelace.0 (18046) HASS Subscribe: state_changed
                                        2019-12-30 08:47:39.159 - debug: lovelace.0 (18046) HASS Subscribe: component_loaded
                                        2019-12-30 08:47:39.160 - debug: lovelace.0 (18046) HASS Subscribe: core_config_updated
                                        2019-12-30 08:47:39.161 - debug: lovelace.0 (18046) HASS Subscribe: service_registered
                                        2019-12-30 08:47:39.162 - debug: lovelace.0 (18046) HASS Subscribe: service_removed
                                        2019-12-30 08:47:39.163 - debug: lovelace.0 (18046) HASS Subscribe: panels_updated
                                        2019-12-30 08:47:39.163 - debug: lovelace.0 (18046) HASS Subscribe: themes_updated
                                        2019-12-30 08:47:39.164 - debug: lovelace.0 (18046) HASS Subscribe: lovelace_updated
                                        2019-12-30 08:47:39.165 - debug: lovelace.0 (18046) HASS Subscribe: persistent_notifications_updated
                                        2019-12-30 08:47:39.193 - debug: lovelace.0 (18046) get config: false
                                        2019-12-30 08:47:39.194 - debug: lovelace.0 (18046) Get translations: de
                                        2019-12-30 08:47:39.522 - debug: lovelace.0 (18046) HASS UnSubscribe: {"type":"unsubscribe_events","subscription":10,"id":22}
                                        2019-12-30 08:47:39.524 - debug: lovelace.0 (18046) HASS Subscribe: persistent_notifications_updated
                                        2019-12-30 08:47:40.110 - debug: lovelace.0 (18046) Add custom cards: background.jpg as jpg
                                        2019-12-30 08:47:40.111 - debug: lovelace.0 (18046) Add custom cards: battery-entity.js as js
                                        2019-12-30 08:47:40.112 - debug: lovelace.0 (18046) Add custom cards: button-card.js as js
                                        2019-12-30 08:47:40.112 - debug: lovelace.0 (18046) Add custom cards: button-entity-row.js as js
                                        2019-12-30 08:47:40.112 - debug: lovelace.0 (18046) Add custom cards: compact-custom-header.js as js
                                        2019-12-30 08:47:40.113 - debug: lovelace.0 (18046) Add custom cards: dual-gauge-card.js as js
                                        2019-12-30 08:47:40.113 - debug: lovelace.0 (18046) Add custom cards: light-entity-card.js as js
                                        2019-12-30 08:47:40.113 - debug: lovelace.0 (18046) Add custom cards: mini-graph-card-bundle.js as js
                                        2019-12-30 08:47:40.113 - debug: lovelace.0 (18046) Add custom cards: remote-card.js as js
                                        2019-12-30 08:47:40.114 - debug: lovelace.0 (18046) Add custom cards: rgb-light-card.js as js
                                        2019-12-30 08:47:40.114 - debug: lovelace.0 (18046) Add custom cards: vertical-stack-in-card.js as js
                                        • Garfonso
                                          Garfonso Developer @ecki945 last edited by
                                          @ecki945
                                          Ja, es geht bei dem, was ich gemacht hatte alles um diese Karte. 😉
                                          Also, wenn die Zuordnung Schalt + RM geht, dann braucht diese Karte die Schalt GA und Dimmwert GA. (Nach der Zuordnung sind für ioBroker die RM GAs nicht mehr relevant). Das Problem oder die Besonderheit ist, dass der lovelace Adapter die "selber" erkennen muss. Das geht über Raum + Funktion und eine Struktur der Objekten in Ordnern. Es wird im Grunde so etwas erwartet:
                                          Mein KNX Projekt sah da deutlich anders aus... daher habe ich mir die Devices so mit der Alias Funktion zusammen gebaut. Da kann man die Ordner anlegen und die States mit denen im KNX verknüpfen. Dazu müsste es im Forum schon etwas geben. Das geht, soweit ich weiß, bisher nur über Änderungen im RAW-Teil des Alias Objektes, da muss im Common-Part folgendes dazu:
                                          alias: {
                                          Bei Id müsstest du dann einmal für den "state" die Schalt GA eintragen und für Brightness die Dimm GA. Und die anderen Sachen müssen auch wie im Bild gesetzt sein, also Rolle und type für schalten auf boolean und für dimmen auf number. Dann kann er die Lampe erkennen und dann geht es auch mit Schalten + Dimmen über die Karte.
                                          @marcuskl said in Test Adapter lovelace v0.2.x:
                                          Hm.. die Controls sehen aber doch ok aus.. grübel. Noch ein paar Fragen:
                                          1. Wenn du im ioBroker schaltest bzw. dimmst oder Farbe änderst -> kommt das in lovelace an?
                                          2. Wenn du in Lovelace was machst, gibt es dann einen Fehler im Log? Oder überhaupt eine Meldung? Beim Anschalten müsste eigentlich sowas auftauchen:
                                          2019-12-30 13:13:03.854  - debug: lovelace.1 (17812) No additional data in service call -> only turn on.
                                          2019-12-30 13:12:55.988  - debug: lovelace.1 (17812) turn_off alias.0.lamps.Josephine_Decke.state
                                          Ich glaube ich guck mal, ob ich nicht auch ein manuelles konfigurieren der attribute einbauen kann... das scheint mir irgendwie weniger Ärger zu machen. grübel
                                          marcuskl 1 Reply Last reply Reply Quote 0
                                          • Moe
                                            Moe last edited by
                                            Schönen guten Tag,
                                            Ich bekomme meine Tado Thermostate nicht angezeigt in der Thermostat Card.
                                            Die Karte bekommt keine Werte und wird leer angezeigt.
                                            Jemand eine Idee wodran es liegen kann ?
                                            Als Entity nutze die Steuerbare Temperatur des Tado Thermostates ( zur Auswahl stehen gemessene Temperatur, Einstellbare Temperatur, Luftfeuchtigkeit )
                                            Wenn ich mir helfen könntest würde ich mich freuen
                                            1.4k
                                            call for action lovelace test visualisierung
                                            131
                                            1051
                                            375575
