    5. Blockly Selektor u. Aufzählungen Geräte zählen
      sigi234 Forum Testing Most Active @dslraser last edited by sigi234
      @dslraser
      Keine Ahnung warum Fenster nicht geht. Habe eh nur einen Sensor im Bad.
      Jetzt bekomme ich Fehler:
      12:14:09.166	error	javascript.0 (9200) at stateText (script.js.Status.Fenster_zaehlen:29:39)
      12:14:09.166	error	javascript.0 (9200) at Object.<anonymous> (script.js.Status.Fenster_zaehlen:690:9)
      29: return getObject(id).common.states[val];
      690: if (stateText(idFenster, wert) == 'TILTED') {
      javascript.0	2019-12-28 12:14:09.166	error	(9200) at processImmediate (timers.js:658:5)
      javascript.0	2019-12-28 12:14:09.166	error	(9200) at tryOnImmediate (timers.js:676:5)
      javascript.0	2019-12-28 12:14:09.166	error	(9200) at runCallback (timers.js:705:18)
      javascript.0	2019-12-28 12:14:09.166	error	(9200) at Immediate.setImmediate (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\adapter.js:4828:37)
      javascript.0	2019-12-28 12:14:09.166	error	(9200) at Object.stateChange (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\main.js:439:25)
      javascript.0	2019-12-28 12:14:09.166	error	(9200) at Object.callback (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1101:38)
      javascript.0	2019-12-28 12:14:09.166	error	(9200) at Object.<anonymous> (script.js.Status.Fenster_zaehlen:690:9)
      javascript.0	2019-12-28 12:14:09.166	error	(9200) at stateText (script.js.Status.Fenster_zaehlen:29:39)
      javascript.0	2019-12-28 12:14:09.166	error	(9200) Error in callback: TypeError: Cannot read property 'true' of undefined
      javascript.0	2019-12-28 12:14:09.163	warn	(9200) at processImmediate (timers.js:658:5)
      javascript.0	2019-12-28 12:14:09.163	warn	(9200) at tryOnImmediate (timers.js:676:5)
      javascript.0	2019-12-28 12:14:09.163	warn	(9200) at runCallback (timers.js:705:18)
      javascript.0	2019-12-28 12:14:09.163	warn	(9200) at Immediate.setImmediate (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\adapter.js:4828:37)
      javascript.0	2019-12-28 12:14:09.162	warn	(9200) at Object.stateChange (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\main.js:439:25)
      javascript.0	2019-12-28 12:14:09.162	warn	(9200) at Object.callback (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1101:38)
      javascript.0	2019-12-28 12:14:09.162	warn	(9200) at Object.<anonymous> (script.js.Status.Fenster_dslraser:46:3)
      javascript.0	2019-12-28 12:14:09.162	warn	(9200) at setState (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1404:20)
      javascript.0	2019-12-28 12:14:09.162	warn	(9200) You are assigning a number to the state "javascript.0.Eigene_Datenpunkte.04email.Fensterstatus.Anzahl_geoffnete_Fenster" which expects a boolean. Please fix your code to use a boolean or chang
      Glaube es hat was mit den Drehkontakt zu tun, habe so einen nicht. Darum der Fehler 'TILTED'
      dslraser paul53 3 Replies Last reply Reply Quote 0
      • dslraser
        dslraser Forum Testing Most Active @sigi234 last edited by dslraser
        @sigi234 sagte in Fenster zählen mit Blockly Selektor Aufzählungen:
        wieso kommt das bei Dir ?
        Da legt das Blockly gar nichts an ? Die angelegten Datenpunkte sind unter 0_userdata.0
        Wenn Du das verändert hast, dann mußt Du auch den Rest im Blockly anpassen.
          @dslraser sagte in Fenster zählen mit Blockly Selektor Aufzählungen:
          Kommt von eine Blockly Skript, ist von dir?
          Versendet eine Mail.
          • dslraser
            @sigi234
            das ist aber ein anderes Blockly. Da ist anscheinend ein Datenpunkt falsch.
            Poste mal den Export.
              @sigi234
              Blockly_Fenster_Mail.txt
              • dslraser
                @sigi234
                da fehlt der wichtigste Punkt. (das was den Fehler verursacht) Da ist die Funktion zum Datenpunkt anlegen nicht drinn.
                Poste mal den RAW vom angemeckerten Datenpunkt. Von dem...
                  @sigi234
                    "user": "system.user.admin",
                    "ts": 1576780234612,
                    "common": {
                      "name": "04email.Fensterstatus.Anzahl_geoffnete_Fenster",
                      "role": "state",
                      "type": "boolean",
                      "desc": "Manuell erzeugt",
                      "read": true,
                      "write": true,
                      "def": false
                    "native": {},
                    "acl": {
                      "object": 1636,
                      "owner": "system.user.admin",
                      "state": 1636
                    "_id": "javascript.0.Eigene_Datenpunkte.04email.Fensterstatus.Anzahl_geoffnete_Fenster",
                    "type": "state"
                  • dslraser
                    "type": "boolean",
                    das hast Du dann aber selbst gemacht....😊 ("desc": "Manuell erzeugt",)
                    mach da mal number draus
                    "type": "boolean",
                    also so
                    "type": "number",
                      Schaut so aus, erledigt.
                      So, in diesen Blockly funktioniert also der Selektor. Dann muss in deinen was nicht stimmen. (Drehkontakt)
                      • dslraser
                        lösche mal im Blockly diesen Teil (also in dem Blockly aus diesem Thread) und versuche es dann nochmal.
                        sigi234 paul53 2 Replies Last reply Reply Quote 0
                          paul53 @sigi234 last edited by paul53
                          @sigi234 sagte:
                          Mind. einer der Datenpunkte hat offenbar keine Zustandstexte (common.states).
                          Ob "TILTED" geliefert wird, spielt keine Rolle.
                            Wo finde ich den?
                              paul53 @dslraser last edited by paul53
                              @dslraser
                              Ändere besser die Funktion
                              in
                              if(getObject(id).common.states) return getObject(id).common.states[val];
                              return 'kein Zustandstext !';
                              • dslraser
                                Dieses Blockly arbeitet auch anders. Dieses Fenster Blockly "liest" in der Werteliste, so wie oben erklärt. Wenn Du z.B. das Licht Blockly für Deine Fenster nimmst und da mal Deinen Fenster Selektor nimmst, sollte das auch funktionieren.
                                Ich mach nochmal eins, nur für die einfachen Fenstersensoren. Dies von oben ist ja extra für die "gemischte" Konstellation mit Drehgriffen.
                                  Cool
                                  Geht das auch mit Türen?
                                  Ich habe diese Sensoren auch an der Terrassentür und Haustür. Das ist eine eigene Aufzählung (Tür)
                                  Habe versuch das Fenster Blockly mit Notepad++ zu bearbeiten und alle Fenster mit Tür ersetzt. Das geht leider nicht.
                                  • dslraser
                                    dslraser Forum Testing Most Active @paul53 last edited by
                                    @paul53 sagte in Fenster zählen mit Blockly Selektor Aufzählungen:
                                    Werden dann nicht vorhandene ignoriert (z.B. TILTED) und das Blockly nimmt dann nur die vorhandenen ?
                                      @dslraser sagte:
                                      "TILTED" ist einer von 3 Zustandstexten. In der Funktion wird nur geprüft, ob überhaupt Zustandstexte vorhanden sind. Falls ja, wird der zum Wert passende Zustandstext zurück gegeben, andernfalls "kein Zustandstext !". So wird ein Error-Log bei fehlenden Zustandstexten vermieden.
                                      • dslraser
                                        Danke Dir. Ich habe es im Export im Fenster Blockly im ersten Post geändert.
                                          Soll man die alten DP löschen? Ok.
                                          Fenster gekippt gibt es bei mir nicht.
                                          paul53 dslraser 2 Replies Last reply Reply Quote 0
                                            @sigi234 sagte:
                                            Aber offenbar mind. einen Datenpunkt, der keine Zustandstexte hat.
                                            blockly
                                            14
                                            202
                                            24928
