    4. JavaScript
    5. Sekunden in d/h/m umrechnen
      guergen @Mic last edited by guergen
      @Mic Hier der inhalt von NUC.uptime:
        "user": "system.user.admin",
        "ts": 1577495005124,
        "common": {
          "name": "Controller - uptime in seconds",
          "type": "string",
          "role": "value",
          "unit": "seconds",
          "read": true,
          "write": false
        "native": {},
        "acl": {
          "object": 1636,
          "owner": "system.user.admin",
          "state": 1636
        "_id": "system.host.NUC.uptime",
        "type": "state"
      Und hier mein DP:
        "ts": 1573829622690,
        "common": {
          "name": "Uptime_NUC",
          "role": "",
          "type": "string",
          "desc": "Manuell erzeugt",
          "read": true,
          "write": true
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636
        "_id": "javascript.0.Eigene_Datenpunkte.Haus.Uptime_NUC",
        "type": "state"
      Folgende Fehler kommen dann im Log:
      javascript.0 2019-12-29 09:20:25.538 error (1857) at processImmediate (timers.js:658:5)
      javascript.0 2019-12-29 09:20:25.538 error (1857) at tryOnImmediate (timers.js:676:5)
      javascript.0 2019-12-29 09:20:25.538 error (1857) at runCallback (timers.js:705:18)
      javascript.0 2019-12-29 09:20:25.538 error (1857) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:226:41)
      javascript.0 2019-12-29 09:20:25.538 error (1857) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4745:37)
      javascript.0 2019-12-29 09:20:25.538 error (1857) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
      javascript.0 2019-12-29 09:20:25.538 error (1857) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
      javascript.0 2019-12-29 09:20:25.538 error (1857) at Object.<anonymous> (script.js.common.Diverse_Scripte.nuc-test:3:29)
      javascript.0 2019-12-29 09:20:25.537 error (1857) Error in callback: TypeError: dp.state.val.split is not a function
      Das Zeichen für das ausführen des Scriptes wird gelb
      • Dolomiti
        Dolomiti last edited by Dolomiti
        was werden den in beiden Fällen für Werte geliefert? Wenn ich die Uptime von meinem Host anzeigen lasse, steht dort eine Zahl. Mit der Split-Funktion versuchst du bei jedem Leerzeichen die Zahl zu trennen. Da du aber nur eine Zahl ohne Leerzeichen hast funktioniert das nicht.
        Versuch mal das Split wegzulassen und dann bei timesec die eckigen Klammern.
        on({id: 'system.host.ioBroker-Test.uptime'/*Controller - uptime in seconds*/, change: "ne"}, function (dp) {
         log (dp.state.val);
        	var timesec = dp.state.val;
        	var timenew = Math.floor(timesec / 3600 )+'h'+Math.floor( (timesec % 3600) / 60 )+'min';
            setState('javascript.0.Uptime_iobtest'/*javascript 0 Uptime iobtest*/,timenew);
         log (timenew);
        • Nashra
          Nashra Most Active Forum Testing last edited by Nashra
          Warum so kompliziert. Einfach ein Basic-html Widget in VIS (gehe mal davon aus das Du es dafür brauchst)
          und im html Bereich dies rein
          Uptime : {d:proxmox.0.node_Netzserver.uptime;Math.floor( ((d)/60/60/24) )} Tage‚{h:proxmox.0.node_Netzserver.uptime;Math.floor( ((h)/60/60) % 24 )} Std‚ {m:proxmox.0.node_Netzserver.uptime;Math.floor( ((m)/60) % 60 )} Min
            guergen @Dolomiti last edited by
            @Dolomiti Das interessante ist ja, dass bei beiden die selben Werte gesetzt werden, bei dem einen Script geht es, bei dem anderen nicht
            • Dolomiti
              @guergen
              Du hast Recht. Hab es mit meinem NAS ausprobiert. Hier funktioniert es auch. Hängt es vielleicht mit der Struktur der Ausgangswerte zusammen?
              Edit: Bei der System-Uptime ist der Type Number, beim NAS ein String. Meines Wissens nach funktioniert Split nur beim String. Bei Number macht das ja auch keinen Sinn, das es nur einen Wert gibt ohne Leerzeichen o.Ä. Beim NAS findet er kein Leerzeichen und nimmt deshalb auromatisch die ganze Zahl.
                @Dolomiti Mit Deinem Vorschlag des Scripts fängt er jetzt grade bei 1 minute an.... es sind aber 11700 sekunden
                • Dolomiti
                  @guergen
                  Bei mir passt es zusammen
                  G 2 Replies Last reply Reply Quote 0
                    @Dolomiti Hmmh.....:
                      @Dolomiti Wenn ich jetzt die eckigen Klammern einfüge kommt folgendes:
                      • Dolomiti
                        @guergen
                        Hat der Tag nicht nur 86400 Sekunden. Sind da nicht zwei Nullen zuviel?
                        Poste mal dein Skript.
                          @Dolomiti Ähhh... ja.... habe es grade geändert, das andere waren hundertstel Sekunden....
                          Aber es nutzt trotzdem nichts:
                          on({id: 'system.host.NUC.uptime', change: "ne"}, function (dp) {
                           log (dp.state.val);
                          	var timenew = Math.floor(timesec[0] / 86400 )+'Tage'+Math.floor( (timesec[0] % 86400) / 3600 )+'h'+Math.floor( (timesec[0] % 3600) / 60 )+'min';
                              setState('javascript.0.Eigene_Datenpunkte.Haus.Uptime_NUC',timenew);
                           log (timenew);
                          Homer.J. 1 Reply Last reply Reply Quote 0
                          • Dolomiti
                            @guergen
                            Du musst die eckigen Klammern weglassen.
                              @Dolomiti Oh man...
                              Manchmal sieht man vor lauter Bäumen den Wald nicht...
                              Danke!
                              Lauft!
                              • Homer.J.
                                Homer.J. @guergen last edited by Homer.J.
                                @guergen nimm mal das.
                                ({id: 'proxmox.0.qemu_iobroker.uptime'/*uptime*/, change: "ne"}, function (dp) {
                                 //log (dp.state.val);
                                	var timenew = Math.floor(timesec /60/60/24 )+' Tag(e), '+Math.floor(timesec / 60/60 % 24)+' Std, '+Math.floor( (timesec / 60) % 60  )+' Min';
                                    setState('javascript.0.Vis.Anzeige.iobroker_Laufzeit'/*iobroker Laufzeit*/,timenew);
                                 //log (timenew);
                                  guergen @Homer.J. last edited by
                                  @Homer-J das "code_" und das "text" muss noch raus 🙂
                                  • Homer.J.
                                    @guergen jab ändere es. 😊
                                    funktioniert es. ?
                                      @Homer-J JA!
                                      Sieht einfacher aus... dann kommt man mit den Nullen nicht durcheinander!
                                      2012
