    4. Admin Adapter 3.7.3 - keine Adapter mehr
    UNSOLVED Admin Adapter 3.7.3 - keine Adapter mehr
      Muhagl last edited by
      Gleiches Problem nach Admin-Update auf 3.7.3.
      OS: linux
      JS controller installiert: 2.1.1
      Node.js v10.17.0
      NPM 6.12.0
      VG
        auch gerade installiert, admin 3.7.2 auf 3.7.3 und selbe Problem
        host.IoBroker	2019-12-29 13:04:45.909	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
        admin.0	2019-12-29 13:04:05.385	info	(4803) Use link "http://localhost:8081" to configure.
        admin.0	2019-12-29 13:04:05.384	info	(4803) http server listening on port 8081
        admin.0	2019-12-29 13:04:05.102	info	(4803) received all objects
        admin.0	2019-12-29 13:04:02.100	info	(4803) requesting all objects
        admin.0	2019-12-29 13:04:02.098	info	(4803) requesting all states
        admin.0	2019-12-29 13:04:02.034	info	(4803) starting. Version 3.7.3 in /opt/iobroker/node_modules/iobroker.admin, node: v10.17.0
        host.IoBroker	2019-12-29 13:04:00.053	info	iobroker exit 0
        host.IoBroker	2019-12-29 13:03:59.046	info	instance system.adapter.admin.0 started with pid 4803
        host.IoBroker	2019-12-29 13:03:59.018	info	"system.adapter.admin.0" enabled
        host.IoBroker	2019-12-29 13:03:58.984	info	iobroker host.IoBroker Adapter "system.adapter.admin.0" is started
        host.IoBroker	2019-12-29 13:03:58.982	info	iobroker Adapter "admin" updated
        host.IoBroker	2019-12-29 13:03:58.923	info	iobroker upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
        host.IoBroker	2019-12-29 13:03:58.864	info	iobroker upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
        host.IoBroker	2019-12-29 13:03:58.801	info	iobroker upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
        host.IoBroker	2019-12-29 13:03:58.659	info	iobroker Update "system.adapter.admin.0"
        host.IoBroker	2019-12-29 13:03:58.575	info	iobroker upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
        host.IoBroker	2019-12-29 13:03:01.742	info	iobroker npm install iobroker.admin@3.7.3 --loglevel error --prefix "/opt/iobroker" (System call)
        host.IoBroker	2019-12-29 13:03:01.740	info	iobroker NPM version: 6.11.3
        host.IoBroker	2019-12-29 13:03:01.647	info	instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
        admin.0	2019-12-29 13:03:01.102	info	(901) Terminated (NO_ERROR): Without reason
        admin.0	2019-12-29 13:03:01.101	info	(901) terminating
        admin.0	2019-12-29 13:03:01.059	info	(901) Got terminate signal TERMINATE_YOURSELF
        host.IoBroker	2019-12-29 13:03:01.047	info	stopInstance system.adapter.admin.0 send kill signal
        host.IoBroker	2019-12-29 13:03:01.045	info	stopInstance system.adapter.admin.0 (force=false, process=true)
        host.IoBroker	2019-12-29 13:03:01.038	info	"system.adapter.admin.0" disabled
        admin.0	2019-12-29 13:03:00.993	info	(901) terminating http server on port 8081
        admin.0	2019-12-29 13:03:00.991	info	(901) Adapter is disabled => stop
        host.IoBroker	2019-12-29 13:03:00.956	info	iobroker host.IoBroker Adapter "system.adapter.admin.0" is stopped.
        host.IoBroker	2019-12-29 13:03:00.899	info	iobroker Update admin from @3.7.2 to @3.7.3
        host.IoBroker	2019-12-29 13:02:58.735	info	iobroker upgrade admin
        window.controllers/Controllers sollte nicht mehr verwendet werden. Verwenden Sie es nicht für die Browser-Erkennung. ace.js:1
        Passwort-Felder sind auf einer unsicheren (http://) Seite vorhanden. Dies ist ein Sicherheitsrisiko, durch das Zugangsdaten gestohlen werden können.
        10.1.1.10:8081
        Fancytree@1 Fancytree.filterNodes() leavesOnly option is deprecated since 2.9.0 / 2015-04-19. Use opts.leavesOnly instead. jquery.fancytree-all.js:113
        Subscribe: system.host.* admin.js:1305
        Unsibscribe: system.host.* admin.js:1329
        clear admin.js:1490
        Subscribe: system.adapter.* admin.js:1305
        Subscribe: *.info.connection admin.js:1305
        477 adminInstances.js:1065
        Unsibscribe: system.adapter.* admin.js:1329
        Unsibscribe: *.info.connection admin.js:1329
        Source-Map-Fehler: Error: NetworkError when attempting to fetch resource.
        Ressourcen-Adresse: moz-extension://xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxx/content/js/purify.min.js
        Source-Map-Adresse: purify.min.js.map
        Timeout for repository adminHosts.js:483
        Subscribe Logs admin.js:1382
          Leute ja....
          2.1.1 mit 3.7.3 GEHT NICHT
          es bringt nix wenn jeder jetzt Postet "es geht nicht"
          ES IST BEKANNT
            A Former User @Chaot last edited by
            @Chaot ja, der 2.2.2 ist noch Beta und auch noch nicht im latest.
              C-3po last edited by C-3po
              OK, und nun?
              Scheinbar geht ja sonst alles.
              Warten auf update ? Oder mit Rollback (nur wie) ohne alles zu zerlegen. Einige Leuts haben ja damit probs gehabt.
                crunchip Forum Testing Most Active @arteck last edited by
                @arteck Kein Problem und auch nicht beabsichtigt, Forum hatte nicht aktualisiert(Browser), sonst hätte ich
                • 1.das Problem im Vorfeld gelesen
                • 2.gar nicht erst probiert
                  Homoran Global Moderator Administrators @C-3po last edited by Homoran
                  @C-3po sagte in Admin Adapter 3.7.3 - keine Adapter mehr:
                  Wie ich gestern schon schrieb ist iobroker install admin@3.7.2 der weg der Wahl.
                  Wenn dann der controller meckert, dass ein Upgrade nicht möglich sei, weil bereits die neueste Version drauf ist muss man natürlich dafür sorgen, dass diese neueste Version vorher verschwindet mit: iobroker del admin
                    C-3po last edited by Negalein
                    @Homoran said in Admin Adapter 3.7.3 - keine Adapter mehr:
                    wie zu erwarten. Ein (nur) Install ging nicht.
                    mein vorgehen (um weitere Fragen zu vermeiden)
                    cd /opt/iobroker
                    iobroker stop
                    iobroker del admin
                    iobroker start
                    kein admin da zum starten. Das Install hat den Admin nicht gleichzeitig hinzugefügt.
                    also zusätzlich noch:
                    iobroker add admin
                    nun isser wieder da.
                    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
                    Hier gehts zur Hilfe.
                      Sorry - ja iobroker add admin muss dann noch kommen.
                      Es hätte sogar alleinig gereicht ohne vorheriges install
                      Ein add macht immer ein zusätzliches install wenn die Daten nicht existieren.
                      Wenn doch fügt das add eine weitere Instanz zu
                        Sorry
                        Du musst dich nicht Entschuldigen. Du nicht 😉
                        Das gilt für das ganze Team. 🙂
                        • Chaot
                          Chaot @sigi234 last edited by Chaot
                          @sigi234 Und wie stabil läuft das Ding (2.2.2) mittlerweile?
                          eventuell teste ich den auch mal an. Zeit habe ich ja momentan.
                          @Homoran Nach den trägen Weihnachtstagen sind jetzt aber alle wach 😁
                            dischi last edited by dischi
                            Bin Neuling und lese eigentlich immer nur mit und hole mir hier meine Inspirationen für das Aussehen meines iobroker. Nach Update auf 3.7.3 hatte ich auch die Probleme mit der fehlenden Anzeige der Adapter. Dank @Homoran habe ich es geschafft, wieder auf die 3.7.2 umzustellen. Finde es echt toll, wie einem hier bei solchen Problemen geholfen wird.
                            Vorgehensweise:
                            iobroker stop
                            iobroker del admin
                            iobroker add admin
                            iobroker start
                            Jetzt funzt alles wieder.
                            Nochmals Danke @Homoran für die Hilfe
                              sigi234 Forum Testing Most Active @Chaot last edited by
                              @Chaot sagte in Admin Adapter 3.7.3 - keine Adapter mehr:
                              https://forum.iobroker.net/topic/28139/beta-test-js-controller-2-2-x-github
                              • JB_Sullivan
                                JB_Sullivan last edited by
                                Damit das hier nicht ausufert, kann man vielleicht solange bis der Bug bereinigt ist, die Version wieder zurückziehen oder über den Info Adapter ein PopUp schalten, so wie damals beim js-controller Update für Windows Nutzer.
                                Also ein Warnhinweis - wer js-controller 2.1.1 installiert hat, bitte KEIN Admin Adapter Update auf 3.7.3 ausführen.
                                  apollon77 @JB_Sullivan last edited by
                                  @JB_Sullivan ich update latest gleich da es die 3.7.1 zieht.
                                  • Dominik F.
                                    Dominik F. last edited by
                                    als Info: Habe nun Admin 3.7.4 installiert und das Problem tauchte wieder auf, die Adapter sind wieder verschwunden.
                                    nutze js-controller 2.1.1
                                    C 1 Reply Last reply Reply Quote 1
                                      Colt @Dominik F. last edited by
                                      @Dominik-F said in Admin Adapter 3.7.3 - keine Adapter mehr:
                                      selbes bei mir
                                        apollon77 last edited by
                                        Bitte mal Shift reload bzw browser cache löschen nicht das alte files noch gecached sind oder so
                                          deta Most Active @apollon77 last edited by deta
                                          @apollon77 gerade probiert mit F5 beim Chromium und Firefox unter Linux. Leider keine Anzeige.
                                            dtp last edited by
                                            Ganz klasse. Jetzt hatte ich hier auch die 3.7.3 installiert und das Problem gehabt, dass die Adapter nicht mehr angezeigt wurden. Doch leider konnte ich nicht so einfach
                                            del admin
                                            ausführen, weil das bei mir über den Portainer im ioBroker-Container nicht funktioniert. Daher habe ich den admin im node_modules-Verzeichnis mit
                                            rm -R iobroker.admin
                                            gelöscht und dann mit
                                            wieder installiert. Nur leider klappt jetzt der Zugriff auf den ioBroker nicht mehr.
                                            Wie kriege ich das Ding wieder zum Laufen?
                                            admin adapter 3.7.3
                                            38
                                            107
                                            12139
