    4. Beta-Test js-controller 2.2.x GitHub
      crunchip Forum Testing Most Active @darkiop last edited by crunchip
      @darkiop habe noch nie ein sudo verwendet🤔
      aber es tut sich was👍
      > iobroker.js-controller@2.1.1 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.11.3
      > iobroker.js-controller@2.1.1 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      41 file(s) successfully synchronized with ioBroker storage.
      Please DO NOT copy files manually into ioBroker storage directories!
      The following notifications happened during sync:
      - Added 40 Files in Directory "daswetter.admin"
      - Ignoring Directory "icons-material-svg" because officially not created as meta object. Plea                       se remove directory!
      - Ignoring Directory "icons-material-svg.admin" because officially not created as meta object                       . Please remove directory!
      - Ignoring Directory "icons-mfd-svg" because officially not created as meta object. Please re                       move directory!
      - Ignoring Directory "icons-mfd-svg.admin" because officially not created as meta object. Ple                       ase remove directory!
      - Ignoring Directory "iobroker.admin.admin" because officially not created as meta object. Pl                       ease remove directory!
      - Ignoring Directory "iobroker.discovery.admin" because officially not created as meta object                       . Please remove directory!
      - Ignoring Directory "multicast.admin" because officially not created as meta object. Please                        remove directory!
      - Ignoring Directory "sayit.0" because officially not created as meta object. Please remove d                       irectory!
      - Added 1 Files in Directory "vis.0"
      npm WARN ws@7.2.1 requires a peer of bufferutil@^4.0.1 but none is installed. You must instal                       l peer dependencies yourself.
      npm WARN ws@7.2.1 requires a peer of utf-8-validate@^5.0.2 but none is installed. You must in                       stall peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted                        {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/os                       x-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor                       @1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      + iobroker.js-controller@2.1.1
      updated 8 packages in 71.234s
      was mir aber nichts nützt, immer noch 2.1.1
      Homer.J. 1 Reply Last reply Reply Quote 0
      • Homer.J.
        Homer.J. @crunchip last edited by
        @crunchip wollte bei mir auch nicht, so ging es.
        cd /opt/iobroker
        iobroker stop
        iobroker update
        npm install ioBroker/ioBroker.js-controller
          crunchip Forum Testing Most Active @Homer.J. last edited by
          @Homer-J auch das funktioniert nicht
            crunchip Forum Testing Most Active @crunchip last edited by
            @crunchip wird immer besser
            root@IoBroker:~# sudo -H -u iobroker npm install iobroker.js-controller
            Error: EACCES: permission denied, scandir '/root'
            TypeError: Cannot read property 'get' of undefined
                at errorMessage (/usr/lib/node_modules/npm/lib/utils/error-message.js:38:39)
                at errorHandler (/usr/lib/node_modules/npm/lib/utils/error-handler.js:201:13)
                at /usr/lib/node_modules/npm/bin/npm-cli.js:78:20
                at cb (/usr/lib/node_modules/npm/lib/npm.js:225:22)
                at /usr/lib/node_modules/npm/lib/npm.js:263:24
                at /usr/lib/node_modules/npm/lib/config/core.js:81:7
                at Array.forEach (<anonymous>)
                at /usr/lib/node_modules/npm/lib/config/core.js:80:13
                at f (/usr/lib/node_modules/npm/node_modules/once/once.js:25:25)
                at /usr/lib/node_modules/npm/lib/config/core.js:110:20
            TypeError: Cannot read property 'loaded' of undefined
                at exit (/usr/lib/node_modules/npm/lib/utils/error-handler.js:97:27)
                at process.errorHandler (/usr/lib/node_modules/npm/lib/utils/error-handler.js:216:3)
                at process.emit (events.js:198:13)
                at emitPromiseRejectionWarnings (internal/process/promises.js:140:18)
                at process._tickCallback (internal/process/next_tick.js:69:34)
              var doExit = npm.config.loaded ? npm.config.get('_exit') : true
                at process._fatalException (internal/bootstrap/node.js:497:27)
              A Former User @crunchip last edited by
              @crunchip du bist im falschen Verzeichnis, führ das mal in /opt/iobroker aus... 🙂
                crunchip Forum Testing Most Active @Guest last edited by
                @ilovegym ja, ich war schon im richtigen Verzeichnis, hatte aber putty geschlossen, da es ja stehn bleibt und nicht weiterläuft, siehe ⬇ ,
                @crunchip sagte in Beta-Test js-controller 2.2.x GitHub:
                ich bekomm´s immer noch nicht gebacken, den Js-controller zu installieren
                root@IoBroker:~# cd /opt/iobroker
                root@IoBroker:/opt/iobroker# iobroker stop
                root@IoBroker:/opt/iobroker# npm install ioBroker/ioBroker.js-controller
                [..................] / rollbackFailedOptional: verb npm-session cfd65c7e37e779d
                hatte nach erneutem öffnen von Putty, vergessen ins Verzeichnis zu wechseln. So der so, es geht weder mit/ohne sudo auch ein iobroker upload hilft nicht
                  @crunchip
                  Befehl mit sudo gibt mir die 2.1.1, habs mal mit direkteingabe 2.2.4 probiert---No matching found und der übliche Befehl
                  bleibt stehn, siehe
                  @apollon77 hast du eine Idee?
                  root@IoBroker:/opt/iobroker# sudo -H -u iobroker npm install iobroker.js-controller
                  NPM version: 6.11.3
                  - Ignoring Directory "icons-material-svg" because officially not created as meta object. Please remove directory!
                  - Ignoring Directory "icons-material-svg.admin" because officially not created as meta object. Please remove directory!
                  - Ignoring Directory "icons-mfd-svg" because officially not created as meta object. Please remove directory!
                  - Ignoring Directory "icons-mfd-svg.admin" because officially not created as meta object. Please remove directory!
                  - Ignoring Directory "iobroker.admin.admin" because officially not created as meta object. Please remove directory!
                  - Ignoring Directory "iobroker.discovery.admin" because officially not created as meta object. Please remove directory!
                  - Ignoring Directory "sayit.0" because officially not created as meta object. Please remove directory!
                  npm WARN ws@7.2.1 requires a peer of bufferutil@^4.0.1 but none is installed. You must install peer dependencies yourself.
                  npm WARN ws@7.2.1 requires a peer of utf-8-validate@^5.0.2 but none is installed. You must install peer dependencies yourself.
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                  updated 1 package in 70.729s
                  root@IoBroker:/opt/iobroker# npm install iobroker.js-controller@2.2.4
                  npm ERR! code ETARGET
                  npm ERR! notarget No matching version found for iobroker.js-controller@2.2.4.
                  npm ERR! notarget In most cases you or one of your dependencies are requesting
                  npm ERR! notarget a package version that doesn't exist.
                  npm ERR!     /home/iobroker/.npm/_logs/2019-12-30T15_58_00_588Z-debug.log
                  [..................] / rollbackFailedOptional: verb npm-session f2424b93be34e960
                  • Homer.J.
                    Homer.J. @crunchip last edited by Homer.J.
                    @crunchip hab es eben nochmal bei mir durchlaufen lassen, kurz warten und es läuft.
                    cd /opt/iobroker
                    iobroker stop
                    apt update
                    apt upgrade
                      darkiop Most Active last edited by
                      @apollon77 Ich wollte eben mit bei ein paar Objekten aufräumen für welche Daten noch in die Maria DB über sql.0 geschrieben werden. Das Abstellen funktioniert aktuell aber nicht - habe es auch mit einen neuem Objekt (Typ Zahl) nachgestellt (SQL Historie aktiviert und versucht wieder zu deaktivieren) - du hattest zun Beginn des Tests von 2.2.x gesagt hier könnte etwas im argen liegen.
                        apollon77 @darkiop last edited by
                        @darkiop ok. Checke
                          darkiop Most Active @apollon77 last edited by
                          @apollon77 Noch zur Info:
                          warn: sql.0 (1282) Cannot get index of "javascript.0.Test-Number": id not found
                          Das war der Test DP, in der Datenbank gibt es ihn nicht mehr - im Admin wird er aber noch als aktiv angezeigt und sobald man in die Einstellungen für den DP geht kommt das Log.
                            @darkiop hm ... naja dann wird das der Grund sein sql spezifisch. Hat dann nix mit dem Controller zu tun. Leg dazu bitte mal sql issue an.
                              @apollon77
                              https://github.com/ioBroker/ioBroker.sql/issues/92
                              Ich geh später nochmal auf 2.1 zurück und teste es da nochmal. Bin mir nicht sicher, aber ich meine vor 2-3 Wochen einen DP deaktiviert zu haben.
                              darkiop created this issue in ioBroker/ioBroker.sql
                              closed Beim deaktivieren vom SQL Logging: Cannot get index of ... #92
                              • simatec
                                simatec Developer Most Active @Einstein67 last edited by
                                @Einstein67 sagte in Beta-Test js-controller 2.2.x GitHub:
                                @apollon77
                                Die Logs sehen nicht so schlecht aus. Allerdings ist, im Vergleich zu den Logs von vor 2 Tagen, nun auch eine Fehlermeldung vorhanden: "ERROR: No packet manager found"
                                Web-GUI - Entfernen einer Instanz
                                $ ./iobroker del info.0
                                Delete adapter "info.0"
                                host.iob10b Counted 1 instances of info.0
                                host.iob10b Counted 1 devices of info.0
                                host.iob10b Counted 58 channels of info.0
                                host.iob10b Counted 294 states of info.0
                                host.iob10b Counted 14 states of system.adapter.info.0
                                host.iob10b Deleting 368 object(s).
                                host.iob10b: Only 200 objects left to be deleted.
                                process exited with code 0
                                Web-GUI - Adapter löschen
                                Delete adapter "info"
                                host.iob10b Counted 1 adapter for info
                                host.iob10b Deleting 2 object(s).
                                npm uninstall iobroker.info --silent --save --prefix "/opt/iobroker" (System call)
                                Danach öffnet sich in beiden Fällen die AdapterKonfiguration ....
                                Was mir noch aufgefallen ist: Das entfernen von Adaptern/Instanzen funktioniert mittels Konsole auch nur dann, wenn ioBroker vorher gestoppt wurde!
                                Konsole - ioBroker läuft. Instanz wird nicht gelöscht (nach starten ist nach einiger Zeit der Adapter auch wieder da)
                                iobroker@iob10b:~$ iobroker del info
                                host.iob10b Deleting 369 object(s).
                                Konsole - ioBroker gestoppt und trotz der Fehlermeldung am Ende, wird die Instanz und der Adapter entfernt.
                                iobroker@iob10b:~$ iobroker stop
                                 Cannot write files: /opt/iobroker/iobroker-data/files/info.admin/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/files/info.admin/_data.json'
                                Kann ich ebenfalls so bestätigen ...
                                  So, ich denke ich hab das Problem mit dem Adapter löschen gefunden. Eine Sache ist noch offen die ich mit Bluefox klären muss - es ist noch was mit den History/Custom-Einstellungen im Argen.
                                  Eine 2.2.5 vllt morgen oder Neujahr dann :-))
                                  ? 1 Reply Last reply Reply Quote 1
                                  • twonky
                                    twonky last edited by
                                    Die Reconnect Probleme im Multihost ist mit der Version 2.2.4 behoben.
                                    Ich habe master auf 2.1.1 und slave auf 2.2.4. Wenn der master neustartet verbinden sie die slaves nun wieder korrekt.
                                    • twonky
                                      Mir ist noch ein Problem aufgefallen:
                                      Ich habe 2 Systeme im Multihost, master auf 2.1.1 gelassen und slave von 2.1.1 auf 2.2.4 aktualisiert. Nach dem Update hat es mir die https Zertifikate überschrieben. Normalerweise habe ich da ein Pfad zum Dateisystem vom master stehen, aber nach dem Update standen dort generierte Zertifikate vom slave drin. Ist das so gewünscht oder soll ich ein github issue anlegen?
                                        apollon77 @twonky last edited by
                                        @twonky cool. Danke. Ich verstehe immer noch Nicht warum die re-subscribes nicht tun aber naja. Jetzt wird im Zweifel nochmal subscribed. Danke!!
                                          @twonky was hast du genau wie angegeben? Der „setup First“ Prozess hat seit der 2.0/1 einen Mechanismus drin das das Zertifikat geprüft wird und wenn es nicht mehr gültig ist oder zu schwach oder zu lang gültig ist dann werden neue Zertifikate erzeugt.
                                          Wie sieht denn dein System.cerrificates Objekt aus? Poste bitte mal.
                                            A Former User @apollon77 last edited by A Former User
                                            @apollon77 Moin, habe heute morgen ein update vom Bring! Adapter gemacht, und jetzt wollte ich die Instanz und den Adapter löschen, da ich den eigentlich nicht mehr benötige (Alexa2 sei Dank)...
                                            Habe einen ganz komischen Effekt, wenn ich im Admin ( 3.7.5) ( js-controller 2.2.4, Node 10.17.0, NPM 6.13.0) die Instanz löschen lasse, löscht er sie, anschließend öffnet sich aber die Konfig-Seite vom Bring-Adapter und die Instanz ist wieder da.
                                            Im Log steht "packet manager not found" ..
                                            Wenn ich die Instanz stoppe, dann läuft auch kein Process mehr, hab auch mal die ganze VM rebootet... mit nem anderem Adapter das gleiche.. hmm hat noch jemand das Problem?
                                            Hier das log ( hab mal dem rtsp-adapter getestet)( 11.41 Uhr nochmal bearbeitet auf debug)
                                            2019-12-31 11:39:35.775  - info: host.iobroker "system.adapter.rtspStream.0" enabled
                                            2019-12-31 11:39:35.798  - info: host.iobroker instance system.adapter.rtspStream.0 started with pid 5753
                                            2019-12-31 11:39:35.890  - info: host.iobroker instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
                                            2019-12-31 11:39:36.357  - debug: rtspStream.0 (5753) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                            2019-12-31 11:39:36.397  - debug: rtspStream.0 (5753) Objects client ready ... initialize now
                                            2019-12-31 11:39:36.401  - debug: rtspStream.0 (5753) Objects create System PubSub Client
                                            2019-12-31 11:39:36.401  - debug: rtspStream.0 (5753) Objects create User PubSub Client
                                            2019-12-31 11:39:36.402  - debug: rtspStream.0 (5753) Objects client initialize lua scripts
                                            2019-12-31 11:39:36.425  - debug: rtspStream.0 (5753) Objects connected to redis: 0.0.0.0:9001
                                            2019-12-31 11:39:36.428  - debug: rtspStream.0 (5753) objectDB connected
                                            2019-12-31 11:39:36.430  - debug: rtspStream.0 (5753) Redis States: Use Redis connection: 0.0.0.0:9000
                                            2019-12-31 11:39:36.443  - debug: rtspStream.0 (5753) States create User PubSub Client
                                            2019-12-31 11:39:36.461  - debug: rtspStream.0 (5753) States create System PubSub Client
                                            2019-12-31 11:39:36.512  - debug: rtspStream.0 (5753) States connected to redis: 0.0.0.0:9000
                                            2019-12-31 11:39:36.513  - debug: rtspStream.0 (5753) statesDB connected
                                            2019-12-31 11:39:37.252  - info: rtspStream.0 (5753) starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.rtspStream, node: v10.17.0
                                            2019-12-31 11:39:37.271  - debug: rtspStream.0 (5753) Starting rtsp Stream
                                            2019-12-31 11:39:37.371  - debug: rtspStream.0 (5753) State Change: rtspStream.0.startStream to true ack false
                                            2019-12-31 11:39:37.372  - debug: rtspStream.0 (5753) Start stream on rtsp://admin:admin@192.168.0.88/12with port 554
                                            2019-12-31 11:39:43.201  - info: host.iobroker iobroker del rtspStream.0
                                            2019-12-31 11:39:44.323  - info: host.iobroker iobroker Delete adapter "rtspStream.0"
                                            2019-12-31 11:39:44.339  - info: host.iobroker iobroker host.iobroker Counted 1 instances of rtspStream.0
                                            2019-12-31 11:39:44.377  - info: host.iobroker iobroker host.iobroker Counted 1 states of rtspStream.0
                                            2019-12-31 11:39:44.388  - info: host.iobroker iobroker host.iobroker Counted 14 states of system.adapter.rtspStream.0
                                            2019-12-31 11:39:46.124  - info: host.iobroker iobroker host.iobroker Deleting 16 object(s).
                                            2019-12-31 11:39:46.905  - info: host.iobroker object deleted system.adapter.rtspStream.0
                                            2019-12-31 11:39:46.905  - info: host.iobroker stopInstance system.adapter.rtspStream.0 (force=false, process=true)
                                            2019-12-31 11:39:46.909  - info: rtspStream.0 (5753) Got terminate signal TERMINATE_YOURSELF
                                            2019-12-31 11:39:46.906  - info: host.iobroker stopInstance system.adapter.rtspStream.0 send kill signal
                                            2019-12-31 11:39:46.913  - info: Set hostname iobroker for system.adapter.rtspStream.0
                                            2019-12-31 11:39:46.928  - info: host.iobroker stopInstance system.adapter.rtspStream.0 (force=false, process=true)
                                            2019-12-31 11:39:46.931  - info: host.iobroker stopInstance system.adapter.rtspStream.0 send kill signal
                                            2019-12-31 11:39:46.934  - info: rtspStream.0 (5753) Got terminate signal TERMINATE_YOURSELF
                                            2019-12-31 11:39:47.410  - info: rtspStream.0 (5753) terminating
                                            2019-12-31 11:39:47.411  - info: rtspStream.0 (5753) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                            2019-12-31 11:39:47.907  - info: host.iobroker stopInstance system.adapter.rtspStream.0 killing pid 5753
                                            2019-12-31 11:39:47.914  - info: host.iobroker iobroker exit 0
                                            beta github js-controller
                                            18
                                            169
                                            18701
