    4. Test Adapter Z-Wave 2 (v0.6.x / v0.7.x)
      A Former User last edited by
      Bin wieder zurück auf den Standard-Adapter, da hier irgendwas nicht gepasst hat. Aber der Reihe nach:
      Hier erstmal ein Teil des Logs wegen dem Error "The transaction timed out". Hat sich allerdings nach ein paar Stunden eingependelt und kam danach nicht mehr vor 🤷‍♂️
      2019-12-24 20:36:08.065 - debug: zwave2.0 (5847) state zwave2.0.Node_005.Thermostat_Setpoint.setpoint_heating changed: 17 (ack = true)
      2019-12-24 20:36:26.541 - debug: zwave2.0 (5847) Node 4: metadata updated: airTemperature
      2019-12-24 20:36:26.543 - debug: zwave2.0 (5847) Node 4: value updated: airTemperature => 20.87
      2019-12-24 20:36:26.561 - debug: zwave2.0 (5847) state zwave2.0.Node_004.Multilevel_Sensor.airTemperature changed: 20.87 (ack = true)
      2019-12-24 20:38:00.014 - debug: zwave2.0 (5847) state zwave2.0.Node_005.Thermostat_Setpoint.setpoint_heating changed: 17 (ack = false)
      2019-12-24 20:38:00.019 - debug: zwave2.0 (5847) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = false)
      2019-12-24 20:38:00.041 - debug: zwave2.0 (5847) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = false)
      2019-12-24 20:38:05.394 - debug: zwave2.0 (5847) Node 5: value updated: setpoint_heating => 17
      2019-12-24 20:38:05.412 - debug: zwave2.0 (5847) state zwave2.0.Node_005.Thermostat_Setpoint.setpoint_heating changed: 17 (ack = true)
      2019-12-24 20:38:05.415 - debug: zwave2.0 (5847) state zwave2.0.Node_005.Thermostat_Setpoint.setpoint_heating changed: 17 (ack = true)
      2019-12-24 20:38:06.714 - debug: zwave2.0 (5847) Node 4: value updated: setpoint_heating => 21.5
      2019-12-24 20:38:06.727 - debug: zwave2.0 (5847) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      2019-12-24 20:38:06.732 - debug: zwave2.0 (5847) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      2019-12-24 20:38:07.822 - error: zwave2.0 (5847) The transaction timed out
      2019-12-24 20:40:00.012 - debug: zwave2.0 (5847) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = false)
      2019-12-24 20:40:00.021 - debug: zwave2.0 (5847) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = false)
      2019-12-24 20:40:00.028 - debug: zwave2.0 (5847) state zwave2.0.Node_005.Thermostat_Setpoint.setpoint_heating changed: 17 (ack = false)
      2019-12-24 20:40:05.120 - error: zwave2.0 (5847) The transaction timed out
      2019-12-24 20:40:06.409 - debug: zwave2.0 (5847) Node 4: value updated: setpoint_heating => 21.5
      2019-12-24 20:40:06.423 - debug: zwave2.0 (5847) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      2019-12-24 20:40:06.428 - debug: zwave2.0 (5847) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      2019-12-24 20:40:07.383 - info: web.0 (1457) <==Disconnect system.user.admin from ::ffff:192.168.178.11 vis.0
      2019-12-24 20:40:07.907 - debug: zwave2.0 (5847) Node 5: value updated: setpoint_heating => 17
      2019-12-24 20:40:07.919 - debug: zwave2.0 (5847) state zwave2.0.Node_005.Thermostat_Setpoint.setpoint_heating changed: 17 (ack = true)
      2019-12-24 20:40:07.922 - debug: zwave2.0 (5847) state zwave2.0.Node_005.Thermostat_Setpoint.setpoint_heating changed: 17 (ack = true)
      2019-12-24 20:40:10.509 - info: web.0 (1457) ==>Connected system.user.admin from ::ffff:192.168.178.11
      2019-12-24 20:42:00.037 - debug: zwave2.0 (5847) state zwave2.0.Node_005.Thermostat_Setpoint.setpoint_heating changed: 17 (ack = false)
      2019-12-24 20:42:00.041 - debug: zwave2.0 (5847) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = false)
      2019-12-24 20:42:00.056 - debug: zwave2.0 (5847) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = false)
      2019-12-24 20:42:05.510 - debug: zwave2.0 (5847) Node 5: value updated: setpoint_heating => 17
      2019-12-24 20:42:05.537 - debug: zwave2.0 (5847) state zwave2.0.Node_005.Thermostat_Setpoint.setpoint_heating changed: 17 (ack = true)
      2019-12-24 20:42:05.543 - debug: zwave2.0 (5847) state zwave2.0.Node_005.Thermostat_Setpoint.setpoint_heating changed: 17 (ack = true)
      2019-12-24 20:42:06.851 - debug: zwave2.0 (5847) Node 4: value updated: setpoint_heating => 21.5
      2019-12-24 20:42:06.864 - debug: zwave2.0 (5847) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      2019-12-24 20:42:06.869 - debug: zwave2.0 (5847) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      2019-12-24 20:42:08.172 - debug: zwave2.0 (5847) Node 11: value updated: setpoint_heating => 21.5
      2019-12-24 20:42:08.184 - debug: zwave2.0 (5847) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      2019-12-24 20:42:08.190 - debug: zwave2.0 (5847) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      2019-12-24 20:44:00.030 - debug: zwave2.0 (5847) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = false)
      2019-12-24 20:44:00.058 - debug: zwave2.0 (5847) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = false)
      2019-12-24 20:44:00.060 - debug: zwave2.0 (5847) state zwave2.0.Node_005.Thermostat_Setpoint.setpoint_heating changed: 17 (ack = false)
      2019-12-24 20:44:05.344 - debug: zwave2.0 (5847) Node 11: value updated: setpoint_heating => 21.5
      2019-12-24 20:44:05.357 - debug: zwave2.0 (5847) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      2019-12-24 20:44:05.362 - debug: zwave2.0 (5847) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      2019-12-24 20:44:06.444 - error: zwave2.0 (5847) The transaction timed out
      2019-12-24 20:44:07.870 - debug: zwave2.0 (5847) Node 5: value updated: setpoint_heating => 17
      2019-12-24 20:44:07.882 - debug: zwave2.0 (5847) state zwave2.0.Node_005.Thermostat_Setpoint.setpoint_heating changed: 17 (ack = true)
      2019-12-24 20:44:07.888 - debug: zwave2.0 (5847) state zwave2.0.Node_005.Thermostat_Setpoint.setpoint_heating changed: 17 (ack = true)
      Hier der Log des Fehlers, der für mich nicht nachvollziehbar ist. Ich habe ein paar Blockly Skripte für die Heizungssteuerung laufen. Aus irgendeinem Grund springen zwei Thermostate ständig vom vorgegebenen Wert (Node 11= 19) & (Node 4= 21,5) auf 18.5. Dieser Wert kommt in den Skripten aber überhaupt nicht vor und ist auch sonst nirgends zu finden. Somit sind die Thermostate ständig am justieren 🤔
      zwave2.0	2019-12-26 11:12:02.966	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 11:12:02.959	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 11:12:02.945	debug	(10816) Node 11: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 11:12:02.817	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 11:12:02.814	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 11:12:02.799	debug	(10816) Node 4: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 11:12:00.063	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 11:12:00.011	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 11:10:03.328	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 19 (ack = true)
      zwave2.0	2019-12-26 11:10:03.321	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 19 (ack = true)
      zwave2.0	2019-12-26 11:10:03.308	debug	(10816) Node 11: value updated: setpoint_heating => 19
      zwave2.0	2019-12-26 11:10:03.185	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      zwave2.0	2019-12-26 11:10:03.180	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      zwave2.0	2019-12-26 11:10:03.162	debug	(10816) Node 4: value updated: setpoint_heating => 21.5
      zwave2.0	2019-12-26 11:10:03.105	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      zwave2.0	2019-12-26 11:10:03.100	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 11:10:03.084	debug	(10816) Node 4: value updated: setpoint_heating => 21.5
      zwave2.0	2019-12-26 11:10:02.967	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 19 (ack = true)
      zwave2.0	2019-12-26 11:10:02.960	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 11:10:02.938	debug	(10816) Node 11: value updated: setpoint_heating => 19
      zwave2.0	2019-12-26 11:10:00.079	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 19 (ack = false)
      zwave2.0	2019-12-26 11:10:00.071	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = false)
      zwave2.0	2019-12-26 11:10:00.043	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 11:10:00.012	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 11:08:02.915	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 11:08:02.909	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 11:08:02.889	debug	(10816) Node 11: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 11:08:02.761	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 11:08:02.755	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 11:08:02.738	debug	(10816) Node 4: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 11:08:00.082	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 11:08:00.011	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 11:06:24.574	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      zwave2.0	2019-12-26 11:06:24.566	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      zwave2.0	2019-12-26 11:06:24.551	debug	(10816) Node 4: value updated: setpoint_heating => 21.5
      zwave2.0	2019-12-26 11:06:24.437	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = false)
      zwave2.0	2019-12-26 11:06:23.847	debug	(10816) state zwave2.0.Node_004.Multilevel_Sensor.airTemperature changed: 18.14 (ack = true)
      zwave2.0	2019-12-26 11:06:23.835	debug	(10816) Node 4: value updated: airTemperature => 18.14
      zwave2.0	2019-12-26 11:06:23.834	debug	(10816) Node 4: metadata updated: airTemperature
      zwave2.0	2019-12-26 11:06:01.606	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 11:06:01.599	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 11:06:01.588	debug	(10816) Node 11: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 11:06:00.021	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 11:05:03.175	debug	(10816) state zwave2.0.Node_005.Multilevel_Sensor.airTemperature changed: 17.52 (ack = true)
      zwave2.0	2019-12-26 11:05:03.109	debug	(10816) Node 5: value updated: airTemperature => 17.52
      zwave2.0	2019-12-26 11:05:03.108	debug	(10816) Node 5: metadata updated: airTemperature
      zwave2.0	2019-12-26 11:05:02.951	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 19 (ack = true)
      zwave2.0	2019-12-26 11:05:02.945	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 19 (ack = true)
      zwave2.0	2019-12-26 11:05:02.928	debug	(10816) Node 11: value updated: setpoint_heating => 19
      zwave2.0	2019-12-26 11:05:00.048	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 19 (ack = false)
      zwave2.0	2019-12-26 11:04:01.681	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 11:04:01.674	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 11:04:01.660	debug	(10816) Node 11: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 11:04:00.042	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 11:02:01.639	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 11:02:01.578	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 11:02:01.567	debug	(10816) Node 11: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 11:02:00.016	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 11:01:47.921	debug	(10816) state zwave2.0.Node_002.Multilevel_Sensor.airTemperature changed: 22.2 (ack = true)
      zwave2.0	2019-12-26 11:01:47.897	debug	(10816) Node 2: value updated: airTemperature => 22.2
      zwave2.0	2019-12-26 11:01:47.895	debug	(10816) Node 2: metadata updated: airTemperature
      zwave2.0	2019-12-26 11:00:23.904	debug	(10816) state zwave2.0.Node_004.Multilevel_Sensor.airTemperature changed: 18.75 (ack = true)
      zwave2.0	2019-12-26 11:00:23.844	debug	(10816) Node 4: value updated: airTemperature => 18.75
      zwave2.0	2019-12-26 11:00:23.842	debug	(10816) Node 4: metadata updated: airTemperature
      zwave2.0	2019-12-26 11:00:03.320	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 19 (ack = true)
      zwave2.0	2019-12-26 11:00:03.312	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 19 (ack = true)
      zwave2.0	2019-12-26 11:00:03.284	debug	(10816) Node 11: value updated: setpoint_heating => 19
      zwave2.0	2019-12-26 11:00:03.062	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 19 (ack = true)
      zwave2.0	2019-12-26 11:00:03.056	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 11:00:03.044	debug	(10816) Node 11: value updated: setpoint_heating => 19
      zwave2.0	2019-12-26 11:00:00.115	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 19 (ack = false)
      zwave2.0	2019-12-26 11:00:00.112	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 10:58:01.606	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:58:01.603	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:58:01.595	debug	(10816) Node 11: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 10:58:00.020	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 10:56:29.295	debug	(10816) system.adapter.admin.0: logging true
      zwave2.0	2019-12-26 10:56:23.869	debug	(10816) state zwave2.0.Node_004.Multilevel_Sensor.airTemperature changed: 19.28 (ack = true)
      zwave2.0	2019-12-26 10:56:23.847	debug	(10816) Node 4: value updated: airTemperature => 19.28
      zwave2.0	2019-12-26 10:56:23.846	debug	(10816) Node 4: metadata updated: airTemperature
      zwave2.0	2019-12-26 10:56:01.655	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:56:01.635	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:56:01.614	debug	(10816) Node 11: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 10:56:00.029	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 10:55:01.581	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 19 (ack = true)
      zwave2.0	2019-12-26 10:55:01.575	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 19 (ack = true)
      zwave2.0	2019-12-26 10:55:01.559	debug	(10816) Node 11: value updated: setpoint_heating => 19
      zwave2.0	2019-12-26 10:55:00.033	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 19 (ack = false)
      zwave2.0	2019-12-26 10:54:01.624	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:54:01.619	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:54:01.607	debug	(10816) Node 11: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 10:54:00.035	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 10:52:23.863	debug	(10816) state zwave2.0.Node_004.Multilevel_Sensor.airTemperature changed: 19.72 (ack = true)
      zwave2.0	2019-12-26 10:52:23.851	debug	(10816) Node 4: value updated: airTemperature => 19.72
      zwave2.0	2019-12-26 10:52:23.851	debug	(10816) Node 4: metadata updated: airTemperature
      zwave2.0	2019-12-26 10:52:01.664	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:52:01.657	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:52:01.645	debug	(10816) Node 11: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 10:52:00.045	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 10:51:03.159	debug	(10816) state zwave2.0.Node_005.Multilevel_Sensor.airTemperature changed: 18.05 (ack = true)
      zwave2.0	2019-12-26 10:51:03.125	debug	(10816) Node 5: value updated: airTemperature => 18.05
      zwave2.0	2019-12-26 10:51:03.124	debug	(10816) Node 5: metadata updated: airTemperature
      zwave2.0	2019-12-26 10:50:39.743	debug	(10816) state zwave2.0.Node_007.status changed: asleep (ack = true)
      zwave2.0	2019-12-26 10:50:39.743	info	(10816) Node 7: is now asleep
      zwave2.0	2019-12-26 10:50:29.744	debug	(10816) state zwave2.0.Node_007.status changed: awake (ack = true)
      zwave2.0	2019-12-26 10:50:29.743	info	(10816) Node 7: is now awake
      zwave2.0	2019-12-26 10:50:01.862	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 19 (ack = true)
      zwave2.0	2019-12-26 10:50:01.857	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 19 (ack = true)
      zwave2.0	2019-12-26 10:50:01.845	debug	(10816) Node 11: value updated: setpoint_heating => 19
      zwave2.0	2019-12-26 10:50:01.647	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 19 (ack = true)
      zwave2.0	2019-12-26 10:50:01.643	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:50:01.625	debug	(10816) Node 11: value updated: setpoint_heating => 19
      zwave2.0	2019-12-26 10:50:00.048	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 19 (ack = false)
      zwave2.0	2019-12-26 10:50:00.014	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 10:48:23.868	debug	(10816) state zwave2.0.Node_004.Multilevel_Sensor.airTemperature changed: 20.34 (ack = true)
      zwave2.0	2019-12-26 10:48:23.856	debug	(10816) Node 4: value updated: airTemperature => 20.34
      zwave2.0	2019-12-26 10:48:23.855	debug	(10816) Node 4: metadata updated: airTemperature
      zwave2.0	2019-12-26 10:48:01.621	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:48:01.615	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:48:01.597	debug	(10816) Node 11: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 10:48:00.026	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 10:47:06.816	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:47:06.811	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:47:06.799	debug	(10816) Node 11: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 10:47:05.214	debug	(10816) state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 10:41:36.447	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 10 (ack = true)
      zwave2.0	2019-12-26 10:41:36.441	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 10 (ack = true)
      zwave2.0	2019-12-26 10:41:36.429	debug	(10816) Node 4: value updated: setpoint_heating => 10
      zwave2.0	2019-12-26 10:41:35.073	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 10 (ack = false)
      zwave2.0	2019-12-26 10:40:01.504	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      zwave2.0	2019-12-26 10:40:01.501	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      zwave2.0	2019-12-26 10:40:01.494	debug	(10816) Node 4: value updated: setpoint_heating => 21.5
      zwave2.0	2019-12-26 10:40:01.429	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      zwave2.0	2019-12-26 10:40:01.426	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:40:01.417	debug	(10816) Node 4: value updated: setpoint_heating => 21.5
      zwave2.0	2019-12-26 10:40:00.039	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = false)
      zwave2.0	2019-12-26 10:40:00.018	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 10:39:03.159	debug	(10816) state zwave2.0.Node_005.Multilevel_Sensor.airTemperature changed: 18.58 (ack = true)
      zwave2.0	2019-12-26 10:39:03.139	debug	(10816) Node 5: value updated: airTemperature => 18.58
      zwave2.0	2019-12-26 10:39:03.137	debug	(10816) Node 5: metadata updated: airTemperature
      zwave2.0	2019-12-26 10:39:00.078	debug	(10816) state zwave2.0.Node_006.Multilevel_Sensor.airTemperature changed: 19.4 (ack = true)
      zwave2.0	2019-12-26 10:39:00.057	debug	(10816) Node 6: value updated: airTemperature => 19.4
      zwave2.0	2019-12-26 10:39:00.056	debug	(10816) Node 6: metadata updated: airTemperature
      zwave2.0	2019-12-26 10:38:01.471	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:38:01.466	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:38:01.455	debug	(10816) Node 4: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 10:38:00.124	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 10:37:18.985	debug	(10816) state zwave2.0.Node_011.Multilevel_Sensor.airTemperature changed: 19.54 (ack = true)
      zwave2.0	2019-12-26 10:37:18.962	debug	(10816) Node 11: value updated: airTemperature => 19.54
      zwave2.0	2019-12-26 10:37:18.960	debug	(10816) Node 11: metadata updated: airTemperature
      zwave2.0	2019-12-26 10:36:01.374	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:36:01.367	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:36:01.352	debug	(10816) Node 4: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 10:36:00.012	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 10:35:01.356	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      zwave2.0	2019-12-26 10:35:01.351	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      zwave2.0	2019-12-26 10:35:01.338	debug	(10816) Node 4: value updated: setpoint_heating => 21.5
      zwave2.0	2019-12-26 10:35:00.012	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = false)
      zwave2.0	2019-12-26 10:34:23.882	debug	(10816) state zwave2.0.Node_004.Multilevel_Sensor.airTemperature changed: 21.13 (ack = true)
      zwave2.0	2019-12-26 10:34:23.872	debug	(10816) Node 4: value updated: airTemperature => 21.13
      zwave2.0	2019-12-26 10:34:23.871	debug	(10816) Node 4: metadata updated: airTemperature
      zwave2.0	2019-12-26 10:34:01.402	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:34:01.398	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:34:01.385	debug	(10816) Node 4: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 10:34:00.027	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 10:32:01.339	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:32:01.335	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:32:01.313	debug	(10816) Node 4: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 10:32:00.012	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 10:30:01.570	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      zwave2.0	2019-12-26 10:30:01.567	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      zwave2.0	2019-12-26 10:30:01.562	debug	(10816) Node 4: value updated: setpoint_heating => 21.5
      zwave2.0	2019-12-26 10:30:01.499	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      zwave2.0	2019-12-26 10:30:01.496	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:30:01.485	debug	(10816) Node 4: value updated: setpoint_heating => 21.5
      zwave2.0	2019-12-26 10:30:00.088	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = false)
      zwave2.0	2019-12-26 10:30:00.084	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 10:29:03.170	debug	(10816) state zwave2.0.Node_005.Multilevel_Sensor.airTemperature changed: 19.02 (ack = true)
      zwave2.0	2019-12-26 10:29:03.151	debug	(10816) Node 5: value updated: airTemperature => 19.02
      zwave2.0	2019-12-26 10:29:03.149	debug	(10816) Node 5: metadata updated: airTemperature
      zwave2.0	2019-12-26 10:28:01.376	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:28:01.371	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:28:01.356	debug	(10816) Node 4: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 10:28:00.012	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 10:26:01.396	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:26:01.390	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:26:01.376	debug	(10816) Node 4: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 10:26:00.031	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 10:25:18.992	debug	(10816) state zwave2.0.Node_011.Multilevel_Sensor.airTemperature changed: 20.16 (ack = true)
      zwave2.0	2019-12-26 10:25:18.973	debug	(10816) Node 11: value updated: airTemperature => 20.16
      zwave2.0	2019-12-26 10:25:18.971	debug	(10816) Node 11: metadata updated: airTemperature
      zwave2.0	2019-12-26 10:25:01.369	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      zwave2.0	2019-12-26 10:25:01.361	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      zwave2.0	2019-12-26 10:25:01.349	debug	(10816) Node 4: value updated: setpoint_heating => 21.5
      zwave2.0	2019-12-26 10:25:00.015	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = false)
      zwave2.0	2019-12-26 10:24:01.394	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:24:01.388	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:24:01.373	debug	(10816) Node 4: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 10:24:00.012	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 10:22:01.371	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:22:01.365	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:22:01.353	debug	(10816) Node 4: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 10:22:00.042	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 10:21:03.181	debug	(10816) state zwave2.0.Node_005.Multilevel_Sensor.airTemperature changed: 19.54 (ack = true)
      zwave2.0	2019-12-26 10:21:03.159	debug	(10816) Node 5: value updated: airTemperature => 19.54
      zwave2.0	2019-12-26 10:21:03.158	debug	(10816) Node 5: metadata updated: airTemperature
      zwave2.0	2019-12-26 10:20:01.518	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      zwave2.0	2019-12-26 10:20:01.504	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      zwave2.0	2019-12-26 10:20:01.485	debug	(10816) Node 4: value updated: setpoint_heating => 21.5
      zwave2.0	2019-12-26 10:20:01.435	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      zwave2.0	2019-12-26 10:20:01.430	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:20:01.409	debug	(10816) Node 4: value updated: setpoint_heating => 21.5
      zwave2.0	2019-12-26 10:20:00.035	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = false)
      zwave2.0	2019-12-26 10:20:00.015	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 10:18:07.513	debug	(10816) state zwave2.0.Node_010.Meter.deltaTime_513 changed: 0 (ack = true)
      zwave2.0	2019-12-26 10:18:07.509	debug	(10816) state zwave2.0.Node_010.Meter.value_513 changed: 0 (ack = true)
      zwave2.0	2019-12-26 10:18:07.485	debug	(10816) Node 10: value updated: deltaTime_513 => 0
      zwave2.0	2019-12-26 10:18:07.483	debug	(10816) Node 10: metadata updated: deltaTime_513
      zwave2.0	2019-12-26 10:18:07.482	debug	(10816) Node 10: value updated: value_513 => 0
      zwave2.0	2019-12-26 10:18:07.480	debug	(10816) Node 10: metadata updated: value_513
      zwave2.0	2019-12-26 10:18:04.509	debug	(10816) state zwave2.0.Node_010.Meter.deltaTime_513 changed: 0 (ack = true)
      zwave2.0	2019-12-26 10:18:04.507	debug	(10816) state zwave2.0.Node_010.Meter.value_513 changed: 4.54 (ack = true)
      zwave2.0	2019-12-26 10:18:04.480	debug	(10816) Node 10: value updated: deltaTime_513 => 0
      zwave2.0	2019-12-26 10:18:04.479	debug	(10816) Node 10: metadata updated: deltaTime_513
      zwave2.0	2019-12-26 10:18:04.478	debug	(10816) Node 10: value updated: value_513 => 4.54
      zwave2.0	2019-12-26 10:18:04.477	debug	(10816) Node 10: metadata updated: value_513
      zwave2.0	2019-12-26 10:18:01.398	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:18:01.390	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:18:01.376	debug	(10816) Node 4: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 10:18:00.031	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 10:16:01.350	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:16:01.348	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = true)
      zwave2.0	2019-12-26 10:16:01.340	debug	(10816) Node 4: value updated: setpoint_heating => 18.5
      zwave2.0	2019-12-26 10:16:00.012	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 18.5 (ack = false)
      zwave2.0	2019-12-26 10:15:01.444	debug	(10816) state zwave2.0.Node_004.Thermostat_Setpoint.setpoint_heating changed: 21.5 (ack = true)
      Hier der Log Ausschnitt vom Standard-Adapter mit den selben Skripten, wo alles ohne Probleme läuft.
      zwave.0	2019-12-26 13:40:04.540	debug	(2267) value changed: 11 comClass: 67 value: {"value_id":"11-67-1-1","node_id":11,"class_id":67,"type":"decimal","genre":"user","instance":1,"index":1,"label":"Heating 1","units":"C","help":"Set the T
      zwave.0	2019-12-26 13:40:02.996	debug	(2267) value changed: 4 comClass: 67 value: {"value_id":"4-67-1-1","node_id":4,"class_id":67,"type":"decimal","genre":"user","instance":1,"index":1,"label":"Heating 1","units":"C","help":"Set the Ther
      zwave.0	2019-12-26 13:40:01.571	debug	(2267) value changed: 5 comClass: 67 value: {"value_id":"5-67-1-1","node_id":5,"class_id":67,"type":"decimal","genre":"user","instance":1,"index":1,"label":"Heating 1","units":"C","help":"Set the Ther
      zwave.0	2019-12-26 13:40:00.065	debug	(2267) setState for: nodeID=11: comClass=67: index=1: instance=1: value=19
      zwave.0	2019-12-26 13:40:00.064	debug	(2267) stateChange zwave.0.NODE11.THERMOSTAT_SETPOINT.Heat_1 set {"val":19,"ack":false,"ts":1577364000032,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1577363820809}
      zwave.0	2019-12-26 13:40:00.038	debug	(2267) setState for: nodeID=4: comClass=67: index=1: instance=1: value=21.5
      zwave.0	2019-12-26 13:40:00.037	debug	(2267) stateChange zwave.0.NODE4.THERMOSTAT_SETPOINT.Heat_1 set {"val":21.5,"ack":false,"ts":1577364000022,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1577362129934}
      zwave.0	2019-12-26 13:40:00.027	debug	(2267) setState for: nodeID=5: comClass=67: index=1: instance=1: value=17
      zwave.0	2019-12-26 13:40:00.026	debug	(2267) stateChange zwave.0.NODE5.THERMOSTAT_SETPOINT.Heat_1 set {"val":17,"ack":false,"ts":1577364000022,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1577363397307}
      zwave.0	2019-12-26 13:39:04.862	debug	(2267) value changed: 6 comClass: 49 value: {"value_id":"6-49-1-1","node_id":6,"class_id":49,"type":"decimal","genre":"user","instance":1,"index":1,"label":"Air Temperature","units":"C","help":"Air Te
      zwave.0	2019-12-26 13:39:02.951	debug	(2267) value changed: 5 comClass: 49 value: {"value_id":"5-49-1-1","node_id":5,"class_id":49,"type":"decimal","genre":"user","instance":1,"index":1,"label":"Air Temperature","units":"C","help":"Air Te
      zwave.0	2019-12-26 13:38:23.664	debug	(2267) value changed: 4 comClass: 49 value: {"value_id":"4-49-1-1","node_id":4,"class_id":49,"type":"decimal","genre":"user","instance":1,"index":1,"label":"Air Temperature","units":"C","help":"Air Te
      zwave.0	2019-12-26 13:37:03.650	debug	(2267) value changed: 11 comClass: 67 value: {"value_id":"11-67-1-1","node_id":11,"class_id":67,"type":"decimal","genre":"user","instance":1,"index":1,"label":"Heating 1","units":"C","help":"Set the T
      zwave.0	2019-12-26 13:37:00.812	debug	(2267) setState for: nodeID=11: comClass=67: index=1: instance=1: value=19
      zwave.0	2019-12-26 13:37:00.811	debug	(2267) stateChange zwave.0.NODE11.THERMOSTAT_SETPOINT.Heat_1 set {"val":19,"ack":false,"ts":1577363820809,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1577363820809}
      zwave.0	2019-12-26 13:35:02.970	debug	(2267) value changed: 5 comClass: 67 value: {"value_id":"5-67-1-1","node_id":5,"class_id":67,"type":"decimal","genre":"user","instance":1,"index":1,"label":"Heating 1","units":"C","help":"Set the Ther
      zwave.0	2019-12-26 13:35:01.419	debug	(2267) value changed: 4 comClass: 67 value: {"value_id":"4-67-1-1","node_id":4,"class_id":67,"type":"decimal","genre":"user","instance":1,"index":1,"label":"Heating 1","units":"C","help":"Set the Ther
      zwave.0	2019-12-26 13:35:00.053	debug	(2267) setState for: nodeID=5: comClass=67: index=1: instance=1: value=17
      zwave.0	2019-12-26 13:35:00.051	debug	(2267) stateChange zwave.0.NODE5.THERMOSTAT_SETPOINT.Heat_1 set {"val":17,"ack":false,"ts":1577363700043,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1577363397307}
      zwave.0	2019-12-26 13:35:00.047	debug	(2267) setState for: nodeID=4: comClass=67: index=1: instance=1: value=21.5
      zwave.0	2019-12-26 13:35:00.046	debug	(2267) stateChange zwave.0.NODE4.THERMOSTAT_SETPOINT.Heat_1 set {"val":21.5,"ack":false,"ts":1577363700041,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1577362129934}
      zwave.0	2019-12-26 13:33:18.800	debug	(2267) value changed: 11 comClass: 49 value: {"value_id":"11-49-1-1","node_id":11,"class_id":49,"type":"decimal","genre":"user","instance":1,"index":1,"label":"Air Temperature","units":"C","help":"Air
      zwave.0	2019-12-26 13:33:02.958	debug	(2267) value changed: 5 comClass: 49 value: {"value_id":"5-49-1-1","node_id":5,"class_id":49,"type":"decimal","genre":"user","instance":1,"index":1,"label":"Air Temperature","units":"C","help":"Air Te
      zwave.0	2019-12-26 13:31:19.928	debug	(2267) value changed: 6 comClass: 49 value: {"value_id":"6-49-1-1","node_id":6,"class_id":49,"type":"decimal","genre":"user","instance":1,"index":1,"label":"Air Temperature","units":"C","help":"Air Te
      zwave.0	2019-12-26 13:30:23.672	debug	(2267) value changed: 4 comClass: 49 value: {"value_id":"4-49-1-1","node_id":4,"class_id":49,"type":"decimal","genre":"user","instance":1,"index":1,"label":"Air Temperature","units":"C","help":"Air Te
      zwave.0	2019-12-26 13:30:01.673	debug	(2267) value changed: 4 comClass: 67 value: {"value_id":"4-67-1-1","node_id":4,"class_id":67,"type":"decimal","genre":"user","instance":1,"index":1,"label":"Heating 1","units":"C","help":"Set the Ther
      zwave.0	2019-12-26 13:30:00.264	debug	(2267) value changed: 5 comClass: 67 value: {"value_id":"5-67-1-1","node_id":5,"class_id":67,"type":"decimal","genre":"user","instance":1,"index":1,"label":"Heating 1","units":"C","help":"Set the Ther
      zwave.0	2019-12-26 13:30:00.043	debug	(2267) setState for: nodeID=4: comClass=67: index=1: instance=1: value=21.5
      zwave.0	2019-12-26 13:30:00.043	debug	(2267) stateChange zwave.0.NODE4.THERMOSTAT_SETPOINT.Heat_1 set {"val":21.5,"ack":false,"ts":1577363400037,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1577362129934}
      zwave.0	2019-12-26 13:30:00.040	debug	(2267) setState for: nodeID=5: comClass=67: index=1: instance=1: value=17
      zwave.0	2019-12-26 13:30:00.039	debug	(2267) stateChange zwave.0.NODE5.THERMOSTAT_SETPOINT.Heat_1 set {"val":17,"ack":false,"ts":1577363400036,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1577363397307}
      zwave.0	2019-12-26 13:29:58.865	debug	(2267) value changed: 5 comClass: 67 value: {"value_id":"5-67-1-1","node_id":5,"class_id":67,"type":"decimal","genre":"user","instance":1,"index":1,"label":"Heating 1","units":"C","help":"Set the Ther
      zwave.0	2019-12-26 13:29:57.313	debug	(2267) setState for: nodeID=5: comClass=67: index=1: instance=1: value=17
      zwave.0	2019-12-26 13:29:57.312	debug	(2267) stateChange zwave.0.NODE5.THERMOSTAT_SETPOINT.Heat_1 set {"val":17,"ack":false,"ts":1577363397307,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1577363397307}
      Eine Namensänderung bleibt auch nicht erhalten. Wenn ich z.B. bei Node_011 den Namen "Eurotronic Spirit" in "Thermostat (Bad)" ändere, steht da nach einiger Zeit wieder "Eurotronic Spirit".
      • AlCalzone
        AlCalzone Developer @Guest last edited by
        @JungleFire Die ioBroker-Logs helfen mir leider nicht wirklich. Ich brauche tatsächlich (wie oben mit Rolf_KA durchexerziert) Logdateien. Da sollte auch zu erkennen sein, warum die Thermostate falsch gehen.
        ? 1 Reply Last reply Reply Quote 1
          A Former User @AlCalzone last edited by
          @AlCalzone
          Hab ich mir schon fast gedacht. Sorry, aber das sind für mich teilweise alles immer noch "Böhmische Dörfer" 😕
          Würde dir da gerne weiterhelfen, aber das ist mir dann doch alles zu zeitintensiv. Habe einige Skripte für die Heizungssteuerung etc. dran hängen.
            Rolf_KA last edited by
            @JungleFire - Das ist jetzt aber wirklich schade 😢
            AlCalzone hatte es oben doch gut beschrieben mit der Logfile Erstellung - das dauert vielleicht 10 Min.
            Und wenn Du dir noch das Programm WinSCP auf deinem PC installierst, geht das Finden/Suchen/Kopieren auf dem Raspi und der LOG Datei noch einfacher.
            Wenn wir ioBroker Nutzer nicht solche engagierte Adapter Entwickler unterstützen, entstehen auch keine guten Adapter - ich würde dafür sogar Zahlen.
            Sein Z-Wave 2 Adapter ist meiner Meinung nach wirklich gut, auch wenn dieser natürlich in dem frühen Stadium auch noch nicht perfekt ist, aber ohne Unterstützung kann er seinen Adapter auch nicht verbessern!
            Ich werde AlCalzone jedenfalls mit weiteren Tests und noch anderen Z-Wave Modulen wie Schalter/RollerShutter/Dimmer und meine Erkenntnisse und Probleme mit seinem Z-Wave 2 Adapter unterstützen und ihm berichten 👍 👍 👍
            Wir ioBroker User sollten wirklich froh sein, das es solche Adapter Entwickler gibt - Danke @AlCalzone ! 😳
            VG, @Rolf_KA
              @AlCalzone
              Anbei noch Korrektur Vorschläge zum 6 Fach Z-Wave Taster ZHC5002:
              Unter der Configuration CC sollten die "multilevelSwitchForButton1" (bis 5) editierbar sein.
              Standardwert ist 33488896 (4 Byte) - Beschreibung unten:
              Bei MultilevelSwitchForButton1" (bis 6)
              Derzeit bin ich am Fibaro RollerShutter 2 testen, geht soweit auch mit deinem Adapter, habe dazu aber noch eine Frage:
              Wie kann ich auslesen, ob der Rollladen nach einem Tastendruck hoch oder runterfährt?
              (Das wäre zum Scripten und für Szenensetzung sehr gut.)
              Danke dir für deine Unterstützung und wenn Du etwas benötigst, gebe Bescheid.
              @Rolf_KA
                Rolf_KA @Rolf_KA last edited by
                Unter der Configuration CC sollten die "multilevelSwitchForButton1" (bis 6) editierbar sein 😏
                AlCalzone 2 Replies Last reply Reply Quote 0
                • AlCalzone
                  AlCalzone Developer @Rolf_KA last edited by
                  @Rolf_KA Danke für den Hinweis mit den Config-Datenpunkten. Im Adapter verfolge ich die Strategie, dass User keine komplizierten Werte selbst berechnen müssen, da mit/ohne Vorzeichen etc immer zu Problemen führt. Die genannten Datenpunkte sind daher gesplittet in Enable/Disable, Upper switch value und Lower Switch value (wie in der Anleitung). Dummerweise heißen die aber alle gleich, da ich die Konfiguration nur automatisiert aus OpenHAB importiert habe. Wird angepasst.
                  Ich habe aber erst noch einen sehr penetranten Bug auszuräuchern, den ich bei mir selbst gefunden habe.
                  @JungleFire Ich habs für dich hier nochmal zusammen gefasst. Hoffe, du bekommst es so auch hin:
                  1. (Adapter im Admin stoppen)
                  2. per SSH anmelden
                  3. Zum User ioBroker wechseln: sudo su iobroker -s /bin/bash
                  4. Ins Adapterverzeichnis wechseln: cd /opt/iobroker/node_modules/iobroker.zwave2
                  5. Adapter manuell starten: LOGTOFILE=true node build/main.js --force --logs
                  6. Merken, wo die Logdatei geschrieben wird. Im Zweifel in /opt/iobroker/node_modules/zwave-js
                  7. Nachdem im ioBroker-Log für den entsprechenden Node "interview completed" erscheint, z.B. die Temperatur ändern.
                  8. Adapter auf der Konsole wieder stoppen (Strg+C), mir die Datei schicken.
                  • AlCalzone
                    @Rolf_KA Ich habe gerade v0.6.3 veröffentlicht. Da gab es nochmal einige Änderungen an den Indicator-Datenpunkten, die angesprochenen Configuration-Datenpunkte sollten jetzt alle da sein und fehlende Datenpunkte bei Multi-Channel-Geräten sollten jetzt auch nicht mehr vorkommen.
                    R 2 Replies Last reply Reply Quote 1
                      Rolf_KA @AlCalzone last edited by
                      @AlCalzone
                      Habe das mit dem RollerShutter 2 (Fibaro "hoch" oder "runter") jetzt wohl verstanden...
                      https://manuals.fibaro.com/roller-shutter-2/
                      (Beim https.../roller-shutter-3) wurde von Fibaro wohl einiges dazu umgestellt - weshalb der 3er, wohl "noch nicht" so begeisterte Nutzer fand - bzw. in anderen Systemen...)
                      bolded text
                        @AlCalzone Moin Moin
                        Das sieht doch schon sehr viel besser und aufgeräumter aus, perfekt 🙂
                        (Untern Screenshot:)
                        Was mir aber aufgefallen ist, dass unter der Indicator CC das lcdBacklight_48 wieder verschwunden ist.
                        Anbei mal das gesicherte ioBroker Node_002 von dem 6 Fach Taster...
                        zwave2.0.Node_002.json
                        Eine Log Datei werde ich dir auch noch erstellen und zu dem RollerShutter schreibe auch noch etwas.
                        Danke dir!
                        Indicator CC - fehlt das: lcdBacklight_48
                          @AlCalzone
                          Habe gerade gesehen... 😉
                          Anbei schon mal die aktuell Cache Datei.
                          d6e3a2ab.json
                          Node_003 + Node_004 sind die besagten Fibaro RollerShutter - dazu später mehr, funktionieren aber soweit.
                            @AlCalzone
                            So, jetzt noch die Log Datei: zwave-1207.log
                              @AlCalzone
                              Thema RollerShutter (Fibaro): Diese funktionieren mit deinem Adapter auch perfekt.
                              Was bei dem RollerShutter aber noch fehlt, ist die Scene CC
                              Bei dem 6 Fach Taster ist die Central_Scene CC ja vorhanden, deshalb dachte ich, dass diese bei allen Nodes vorhanden ist bzw. bei denen, die Scene auch unterstützen.
                              Unter OpenZWave bekomme ich unter Scene die jeweilige Nr. für die gedrückte Taste (S1, S2 - 1, 2, o. 3 x gedrückt usw.)
                              (Wie unten beschrieben)
                              Ende der Woche bekommen ich noch ein paar RollerShutter3 (RollerShutter2 ist ja leider nicht mehr lieferbar), Dimmer2 sowie doubleSwitch2 – alles von Fibaro. (Werde darüber auch berichten)
                              Nochmals vielen Dank für deine Unterstützung und schon mal einen guten Rutsch ins Neue Jahr 2020 !
                              Verbunden mit viel Gesundheute, Glück und Erfolg 🙂
                              Unter OpenZWave:
                              Scene Nrn. (von Fibaro)
                              • AlCalzone
                                @Rolf_KA Ui, du warst fleißig!
                                1. LCD Backlight: Laut Log wird es unterstützt, aber dann kein Wert abgefragt - hier muss ich dir doch mal eine Testversion mit mehr logs machen.
                                2. multilevelSwitchForButton4: Hattest du die Objekte in ioBroker gelöscht? Ggf. ist der noch alt.
                                3. Dimmer2, DoubleSwitch2 und RollerShutter2 funktionieren 😉
                                4. Du verwechselst die Scene Activation CC mit der Central Scene CC. Letztere ist unterstützt, erstere fehlt noch. Gibt bereits ein Issue für: https://github.com/AlCalzone/node-zwave-js/issues/516
                                CliffS created this issue in AlCalzone/node-zwave-js
                                closed The command class Scene Activation is not implemented #516
                                • AlCalzone
                                  @Rolf_KA In Kürze ist v0.6.4-beta.0 verfügbar, bitte erstelle mir damit einen Log (Cache-Datei vorher löschen, wenn vorhanden).
                                    @AlCalzone
                                    Zu 1:
                                    Nachdem ich das LCD Backlight selbst unter dem Indicator CC eingetragen habe (alter Name: lcdBacklight_48) und das Backlight wieder aktiviert habe (255) kam plötzlich der neue Name, aber ohne Wert.
                                    (Ist sicherlich so wie Du geschrieben hast - kein Wert Abgefragt)
                                    Was auch etwas schade ist, das die LED und LCD Einstellungen nach einem Stromausfall nicht an den 6 Fach Taster neu übertragen werden - Nach einem Stromausfall sind alle 6 LEDs + LCD Backlight aus.
                                    Aber das kann man locker über ein Script regeln.
                                    Zu 2:
                                    Ja, vor dem Adapter Update habe ich das kompl. Nodes_002 im ioBroker gelöscht (eben dieser 6 Fach Taster)
                                    Ich hatte dann in deinem Devices Verzeichnis unter 0x234 den multilevelSwitchForButton4 in der heatit_z-scene_controller.json gelöscht.
                                    Danach die Cache Datei und das kompl. Nodes_002 gelöscht und deinen Adapter gestartet (war vorher natürlich OFF)
                                    Hier das Original:
                                    heatit_z-scene_controller-Orginal.json
                                    Hier meine Änderung:
                                    Zu 3:
                                    Kann ich bestätigen RollerShutter2 funktioniert, RollerShutter3 kommt bei mir wohl erst kommende Woche an.
                                    Hätte ja gerne noch den RollerShutter2 bestellt, aber den gibt es wohl nicht mehr 😞
                                    Zu 4:
                                    Schon wieder etwas dazu gelernt 🙂
                                    Danke dir nochmal für alles - wenn Du etwas brauchst, gebe Bescheid.
                                      @AlCalzone
                                      Okay, kommt in wenige Minuten 🙂
                                      • AlCalzone
                                        @Rolf_KA sagte in Test Adapter Z-Wave 2 (v0.6.x):
                                        Hups, den hab ich übersehen. Wird in der nächsten Version entfernt.
                                          @AlCalzone
                                          Sorry, da funktioniert was nicht...
                                          • AlCalzone
                                            @Rolf_KA Das ist irgendwas in Node.js selbst. Logg dich mal neu ein oder starte die Kiste neu.
                                            test z-wave
                                            4712
