Test Adapter HeatingControl v2.12.x
@moppel2810 Iobroker-Instanzen- Expertenmoduns (das Männchen anclicken oben) und den Adapter dann in der Log-Stufe auf debug stellen
@Hobi Nimm das Widget (vis-jqui-mfd muss installiert sein):
[{"tpl":"tplJquiInputDatetime","data":{"oid":"heatingcontrol.0.Profiles.0.Bad.Mon.Periods.0.time","g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"timeOnly":true,"hideSeconds":true,"size":"4","class":"","filterkey":"","name":"Mo Zeit bis","locked":false,"g_last_change":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"140px","top":"470px","width":"77px","height":"25px","font-weight":"bold","font-size":"","word-spacing":"","letter-spacing":"","line-height":"","z-index":"10","color":"","border-width":"","border-style":"","border-radius":"4px"},"widgetSet":"jqui"}] -
@Hobi sagte in Test Adapter HeatingControl v0.3.x:
Was kann ich da machen?
In JS würde ich jetzt sagen den richtigen Datentyp nehmen, wie das aber in Blockly geht, keine Ahnung.
Was ich mich allerdings frage, ist, wozu Du da überhaupt ein Script meinst zu brauchen. Es gibt ein fertiges Vis zum Adapter welches ohne Blockly Gedöns auskommt, was spricht dagegen das zu verwenden? Und selbst wenn Du es nicht verwendest, dann nimms zum spicken.
@Rene_HM said in Test Adapter HeatingControl v0.3.x:
@martinschm bzgl. des logs mit dem Fenstersensor.
Eigentlich sieht das log wie erwartet aus:- um 23:08:13 wird erkannt, dass ein Fenster offen ist
- um 23:08:30 wird erkannt, dass alle 4 Fenster wieder zu sind
Trotzdem läuft er in beiden Fällen in den Abwesenheits-Zweig, was im ersten Fall nicht sein sollte. Im ersten Fall sollte er in den FensterAuf-Modus laufen... Deshalb folgende Fragen:
- welche Absenkung fährst du (relative oder absolut)?
- ist das Verhalten anders, wenn du mihome.0.devices.magnet_158d0001de8c5e öffnest? Das ist der letzte Sensor, der für den Raum geprüft wird...
- wird im Datenpunkt heatingcontrol.0.Rooms.Schlafzimmer.WindowIsOpen angezeigt, dass ein Fenster offen ist?
- SensorDelay verwendest du nicht?
ich verwende
- absolute Absenkung.
- SensorDelay ist 0
- WindowisOpen wird angezeigt als true
- der magnet_158d0001de8c5e ist der SZ Mitte, Log hab ich unten angehängt. Funktioniert leider auch nicht.
2019-12-30 19:43:48.075 - [32minfo[39m: heatingcontrol.0 (8950) Schlafzimmer window open on SZ Mitte 2019-12-30 19:43:48.076 - [34mdebug[39m: heatingcontrol.0 (8950) room to check is Schlafzimmer 2019-12-30 19:43:48.077 - [32minfo[39m: heatingcontrol.0 (8950) calculating new target temperatures 2019-12-30 19:43:48.077 - [34mdebug[39m: heatingcontrol.0 (8950) ### 222 not handled yet 2019-12-30 19:43:48.077 - [34mdebug[39m: heatingcontrol.0 (8950) ### not handled mihome.0.devices.magnet_158d0001de8c5e.state {"val":true,"ack":true,"ts":1577731428070,"q":0,"from":"system.adapter.mihome.0","user":"system.user.admin","lc":1577731428070} 2019-12-30 19:43:48.080 - [34mdebug[39m: heatingcontrol.0 (8950) profile type 2 2019-12-30 19:43:48.080 - [34mdebug[39m: heatingcontrol.0 (8950) get profile 2019-12-30 19:43:48.081 - [34mdebug[39m: heatingcontrol.0 (8950) profile 0 2019-12-30 19:43:48.081 - [34mdebug[39m: heatingcontrol.0 (8950) check room Schlafzimmer 2019-12-30 19:43:48.081 - [34mdebug[39m: heatingcontrol.0 (8950) VacationAbsentDecrease {"val":0,"ack":true,"ts":1576691313966,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1576691313966} 2019-12-30 19:43:48.082 - [34mdebug[39m: heatingcontrol.0 (8950) number of periods 4 2019-12-30 19:43:48.082 - [34mdebug[39m: heatingcontrol.0 (8950) check ID Profiles.0.Schlafzimmer.Sa-So.Periods.0.time 2019-12-30 19:43:48.083 - [34mdebug[39m: heatingcontrol.0 (8950) check time for Schlafzimmer Profiles.0.Schlafzimmer.Sa-So.Periods.0.time 19 2019-12-30 19:43:48.083 - [34mdebug[39m: heatingcontrol.0 (8950) check ID Profiles.0.Schlafzimmer.Sa-So.Periods.1.time 2019-12-30 19:43:48.083 - [34mdebug[39m: heatingcontrol.0 (8950) check ID Profiles.0.Schlafzimmer.Sa-So.Periods.2.time 2019-12-30 19:43:48.084 - [34mdebug[39m: heatingcontrol.0 (8950) check ID Profiles.0.Schlafzimmer.Sa-So.Periods.3.time 2019-12-30 19:43:48.084 - [34mdebug[39m: heatingcontrol.0 (8950) ### current > 1 0 2 2019-12-30 19:43:48.085 - [34mdebug[39m: heatingcontrol.0 (8950) ### new target temp19 2019-12-30 19:43:48.085 - [32minfo[39m: heatingcontrol.0 (8950) room Schlafzimmer Thermostat HM-CC-RT-DN OEQ1733333 set to 19 2019-12-30 19:43:48.085 - [34mdebug[39m: heatingcontrol.0 (8950) thermostat hm-rpc.0.OEQ1733333.4.SET_TEMPERATURE nothing to do, already 19 2019-12-30 19:43:48.089 - [33mwarn[39m: heatingcontrol.0 (8950) HandleActorsGeneral: not implemented yet 2019-12-30 19:43:48.090 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 31 Dec 2019 09:00:00 2019-12-30 19:43:48.091 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 30 Dec 2019 21:00:00 2019-12-30 19:43:48.092 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 30 Dec 2019 21:15:00 2019-12-30 19:43:48.094 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 30 Dec 2019 21:30:00 2019-12-30 19:43:48.095 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 4 Jan 2020 09:00:00 2019-12-30 19:43:48.096 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 4 Jan 2020 21:00:00 2019-12-30 19:43:48.101 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 4 Jan 2020 21:15:00 2019-12-30 19:43:48.103 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 4 Jan 2020 21:30:00 2019-12-30 19:43:48.104 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 31 Dec 2019 08:00:00 2019-12-30 19:43:48.106 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 31 Dec 2019 14:20:00 2019-12-30 19:43:48.107 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 31 Dec 2019 18:00:00 2019-12-30 19:43:48.108 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 4 Jan 2020 08:00:00 2019-12-30 19:43:48.109 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 4 Jan 2020 18:00:00 2019-12-30 19:43:48.112 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 4 Jan 2020 18:30:00 2019-12-30 19:43:48.113 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 4 Jan 2020 19:00:00 2019-12-30 19:43:48.114 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 31 Dec 2019 00:00:00 2019-12-30 19:43:48.115 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 31 Dec 2019 12:00:00 2019-12-30 19:43:48.116 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 31 Dec 2019 16:00:00 2019-12-30 19:43:48.117 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 4 Jan 2020 05:00:00 2019-12-30 19:43:48.117 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 4 Jan 2020 12:00:00 2019-12-30 19:43:48.119 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 4 Jan 2020 16:00:00 2019-12-30 19:44:08.370 - [34mdebug[39m: heatingcontrol.0 (8950) ### handle state change hm-rpc.0.OEQ1711111.4.ACTUAL_TEMPERATURE {"val":20.9,"ack":true,"ts":1577731448369,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1577731448369} 2019-12-30 19:44:08.370 - [34mdebug[39m: heatingcontrol.0 (8950) ### hm-rpc.0.OEQ1711111.4.ACTUAL_TEMPERATURE mihome.0.devices.magnet_158d0001de8c5e.state 20.9 true 2019-12-30 19:44:08.371 - [34mdebug[39m: heatingcontrol.0 (8950) ### handle state change hm-rpc.0.OEQ1711111.4.SET_TEMPERATURE {"val":16,"ack":true,"ts":1577731448369,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1577705436500} 2019-12-30 19:44:08.371 - [34mdebug[39m: heatingcontrol.0 (8950) ### hm-rpc.0.OEQ1711111.4.SET_TEMPERATURE hm-rpc.0.OEQ1711111.4.ACTUAL_TEMPERATURE 16 20.9 2019-12-30 19:44:08.371 - [34mdebug[39m: heatingcontrol.0 (8950) ### 111 not handled yet 2019-12-30 19:44:08.371 - [34mdebug[39m: heatingcontrol.0 (8950) handle id hm-rpc.0.OEQ1711111.4.ACTUAL_TEMPERATURE state {"val":20.9,"ack":true,"ts":1577731448369,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1577731448369} 2019-12-30 19:44:08.371 - [34mdebug[39m: heatingcontrol.0 (8950) ### handle devices [{"id":12,"name":"HM-CC-RT-DN OEQ1711111","OID_Current":"hm-rpc.0.OEQ1711111.4.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ1711111.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"Kinderschlafzimmer"}] 2019-12-30 19:44:08.371 - [34mdebug[39m: heatingcontrol.0 (8950) ### 111 not handled yetDie Absenkung scheint auch in den anderen Räumen nicht zu funktionieren. Habe es grade mal in einem anderen Zimmer versucht.
undefined2019-12-30 22:14:29.828 - info: host.RasPi "system.adapter.heatingcontrol.0" enabled 2019-12-30 22:14:29.855 - info: host.RasPi instance system.adapter.heatingcontrol.0 started with pid 26464 2019-12-30 22:14:32.420 - info: heatingcontrol.0 (26464) starting. Version 0.3.13 in /opt/iobroker/node_modules/iobroker.heatingcontrol, node: v8.16.1 2019-12-30 22:14:33.184 - info: heatingcontrol.0 (26464) initial check for heating period based on settings between 01.10. and 31.03. 2019-12-30 22:14:33.185 - info: heatingcontrol.0 (26464) heating period is true 2019-12-30 22:14:33.317 - info: heatingcontrol.0 (26464) check for heating period based on settings between 01.10. and 31.03. 2019-12-30 22:14:33.732 - info: heatingcontrol.0 (26464) checking all actors 2019-12-30 22:14:33.741 - info: heatingcontrol.0 (26464) 0 actors are on of 1 2019-12-30 22:14:33.752 - info: heatingcontrol.0 (26464) checking all external states 2019-12-30 22:14:33.757 - info: heatingcontrol.0 (26464) setting PublicHolidyToday to false 2019-12-30 22:14:33.764 - info: heatingcontrol.0 (26464) setting Present to false 2019-12-30 22:14:33.769 - info: heatingcontrol.0 (26464) setting VacationAbsent to false 2019-12-30 22:14:33.775 - info: heatingcontrol.0 (26464) setting GuestsPresent to false 2019-12-30 22:14:33.780 - info: heatingcontrol.0 (26464) setting PartyNow to false 2019-12-30 22:14:33.785 - info: heatingcontrol.0 (26464) setting HolidayPresent to false 2019-12-30 22:14:33.788 - info: heatingcontrol.0 (26464) external states checked, done 2019-12-30 22:14:33.794 - info: heatingcontrol.0 (26464) calculating new target temperatures 2019-12-30 22:14:33.835 - info: heatingcontrol.0 (26464) setting to reduced/increased temperature in Wohnzimmer to 16 2019-12-30 22:14:33.836 - info: heatingcontrol.0 (26464) room Wohnzimmer Thermostat zigbee.0.00158d000237dead.temperature target is 16 2019-12-30 22:14:33.839 - error: heatingcontrol.0 (26464) exception in CheckTemperatureChange [invalid id ""] 2019-12-30 22:14:33.849 - info: heatingcontrol.0 (26464) subscribe heatingcontrol.0.PublicHolidyToday 2019-12-30 22:14:33.851 - info: heatingcontrol.0 (26464) subscribe heatingcontrol.0.Present 2019-12-30 22:14:33.853 - info: heatingcontrol.0 (26464) subscribe heatingcontrol.0.VacationAbsent 2019-12-30 22:14:33.855 - info: heatingcontrol.0 (26464) subscribe heatingcontrol.0.HolidayPresent 2019-12-30 22:14:33.857 - info: heatingcontrol.0 (26464) subscribe heatingcontrol.0.GuestsPresent 2019-12-30 22:14:33.859 - info: heatingcontrol.0 (26464) subscribe heatingcontrol.0.PartyNow 2019-12-30 22:14:33.861 - info: heatingcontrol.0 (26464) subscribe Schlafzimmer / zigbee.0.00158d000232392b.temperature 2019-12-30 22:14:33.864 - info: heatingcontrol.0 (26464) subscribe Bad / zigbee.0.00158d0002739ff4.temperature 2019-12-30 22:14:33.868 - info: heatingcontrol.0 (26464) subscribe Wohnzimmer / zigbee.0.00158d000237dead.temperature 2019-12-30 22:14:36.821 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.alive 2019-12-30 22:14:36.823 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.connected 2019-12-30 22:14:36.824 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memRss 2019-12-30 22:14:36.825 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memHeapTotal 2019-12-30 22:14:36.826 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memHeapUsed 2019-12-30 22:14:36.826 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.eventLoopLag 2019-12-30 22:14:36.827 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.uptime 2019-12-30 22:14:36.828 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.inputCount 2019-12-30 22:14:36.829 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.outputCount 2019-12-30 22:14:36.830 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.cpu 2019-12-30 22:14:36.830 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.cputime 2019-12-30 22:14:37.159 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime 2019-12-30 22:14:37.398 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.alive 2019-12-30 22:14:37.399 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.connected 2019-12-30 22:14:37.400 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memRss 2019-12-30 22:14:37.401 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memHeapTotal 2019-12-30 22:14:37.402 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memHeapUsed 2019-12-30 22:14:37.403 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.eventLoopLag 2019-12-30 22:14:37.404 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.uptime 2019-12-30 22:14:37.405 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.inputCount 2019-12-30 22:14:37.406 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.outputCount 2019-12-30 22:14:37.422 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.cpu 2019-12-30 22:14:37.423 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.cputime 2019-12-30 22:14:37.424 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime 2019-12-30 22:14:37.657 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.alive 2019-12-30 22:14:37.673 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.connected 2019-12-30 22:14:37.674 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memRss 2019-12-30 22:14:37.676 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memHeapTotal 2019-12-30 22:14:37.677 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memHeapUsed 2019-12-30 22:14:37.678 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.eventLoopLag 2019-12-30 22:14:37.678 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.uptime 2019-12-30 22:14:37.679 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.inputCount 2019-12-30 22:14:37.680 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.outputCount 2019-12-30 22:14:37.694 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.cpu 2019-12-30 22:14:37.695 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.cputime 2019-12-30 22:14:38.413 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.temperature 2019-12-30 22:14:38.419 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime 2019-12-30 22:14:38.420 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.rssi 2019-12-30 22:14:38.902 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.temperature 2019-12-30 22:14:38.907 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime 2019-12-30 22:14:39.283 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.alive 2019-12-30 22:14:39.300 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.connected 2019-12-30 22:14:39.301 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memRss 2019-12-30 22:14:39.302 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memHeapTotal 2019-12-30 22:14:39.303 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memHeapUsed 2019-12-30 22:14:39.304 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.eventLoopLag 2019-12-30 22:14:39.305 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.uptime 2019-12-30 22:14:39.321 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.inputCount 2019-12-30 22:14:39.323 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.outputCount 2019-12-30 22:14:39.325 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.cpu 2019-12-30 22:14:39.327 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.cputime 2019-12-30 22:14:39.352 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.alive 2019-12-30 22:14:39.354 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.connected 2019-12-30 22:14:39.355 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memRss 2019-12-30 22:14:39.356 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memHeapTotal 2019-12-30 22:14:39.359 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memHeapUsed 2019-12-30 22:14:39.360 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.eventLoopLag 2019-12-30 22:14:39.361 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.uptime 2019-12-30 22:14:39.362 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.inputCount 2019-12-30 22:14:39.363 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.outputCount 2019-12-30 22:14:39.364 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.cpu 2019-12-30 22:14:39.365 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.cputime 2019-12-30 22:14:39.400 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.alive 2019-12-30 22:14:39.412 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memRss 2019-12-30 22:14:39.414 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memHeapTotal 2019-12-30 22:14:39.416 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memHeapUsed 2019-12-30 22:14:39.418 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.load 2019-12-30 22:14:39.432 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.uptime 2019-12-30 22:14:39.433 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.mem 2019-12-30 22:14:39.434 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.freemem 2019-12-30 22:14:39.435 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memAvailable 2019-12-30 22:14:39.436 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.inputCount 2019-12-30 22:14:39.436 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.outputCount 2019-12-30 22:14:39.437 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.eventLoopLag 2019-12-30 22:14:39.438 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.compactgroupProcesses 2019-12-30 22:14:39.438 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.instancesAsProcess 2019-12-30 22:14:39.439 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.instancesAsCompact 2019-12-30 22:14:39.450 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.cpu 2019-12-30 22:14:39.451 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.cputime 2019-12-30 22:14:39.470 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.temperature 2019-12-30 22:14:39.474 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime 2019-12-30 22:14:39.543 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.alive 2019-12-30 22:14:39.544 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.connected 2019-12-30 22:14:39.545 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memRss 2019-12-30 22:14:39.545 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memHeapTotal 2019-12-30 22:14:39.546 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memHeapUsed 2019-12-30 22:14:39.547 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.eventLoopLag 2019-12-30 22:14:39.547 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.uptime 2019-12-30 22:14:39.548 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.inputCount 2019-12-30 22:14:39.549 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.outputCount 2019-12-30 22:14:39.559 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.cpu 2019-12-30 22:14:39.560 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.cputime 2019-12-30 22:14:39.864 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.uptime 2019-12-30 22:14:40.112 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.uptime 2019-12-30 22:14:40.116 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.rssi 2019-12-30 22:14:40.292 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.temperature 2019-12-30 22:14:40.297 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.uptime 2019-12-30 22:14:40.298 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.rssi 2019-12-30 22:14:40.448 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.uptime 2019-12-30 22:14:40.451 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.rssi 2019-12-30 22:14:40.662 - warn: heatingcontrol.0 (26464) device not found zigbee.0.84182600000ead8e.available 2019-12-30 22:14:40.786 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.temperature 2019-12-30 22:14:40.791 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.uptime 2019-12-30 22:14:40.792 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.rssi 2019-12-30 22:14:41.008 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Power 2019-12-30 22:14:41.074 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.temperature 2019-12-30 22:14:41.079 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.uptime 2019-12-30 22:14:41.080 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.rssi 2019-12-30 22:14:41.198 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.uptime 2019-12-30 22:14:42.562 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.temperature 2019-12-30 22:14:42.566 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime 2019-12-30 22:14:42.788 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.temperature 2019-12-30 22:14:42.792 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime 2019-12-30 22:14:42.793 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.rssi 2019-12-30 22:14:43.813 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime 2019-12-30 22:14:44.104 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.temperature 2019-12-30 22:14:44.108 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime 2019-12-30 22:14:44.730 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.temperature 2019-12-30 22:14:44.736 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime 2019-12-30 22:14:44.737 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.rssi 2019-12-30 22:14:45.279 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.temperature 2019-12-30 22:14:45.282 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.uptime 2019-12-30 22:14:45.514 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.uptime 2019-12-30 22:14:45.652 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.uptime 2019-12-30 22:14:45.656 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.rssi 2019-12-30 22:14:45.922 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.Relay0.Power 2019-12-30 22:14:45.960 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.alive 2019-12-30 22:14:45.971 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.connected 2019-12-30 22:14:45.972 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memRss 2019-12-30 22:14:45.973 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memHeapTotal 2019-12-30 22:14:45.974 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memHeapUsed 2019-12-30 22:14:45.984 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.eventLoopLag 2019-12-30 22:14:45.985 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.uptime 2019-12-30 22:14:45.986 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.inputCount 2019-12-30 22:14:45.988 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.outputCount 2019-12-30 22:14:45.989 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.cpu 2019-12-30 22:14:45.991 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.cputime 2019-12-30 22:14:46.000 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.temperature 2019-12-30 22:14:46.001 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.uptime 2019-12-30 22:14:46.002 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.rssi 2019-12-30 22:14:46.209 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Power 2019-12-30 22:14:46.277 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.temperature 2019-12-30 22:14:46.281 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.uptime 2019-12-30 22:14:46.282 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.rssi 2019-12-30 22:14:46.400 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.temperature 2019-12-30 22:14:46.404 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.uptime 2019-12-30 22:14:46.528 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.temperature 2019-12-30 22:14:46.532 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.uptime 2019-12-30 22:14:46.533 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.rssi 2019-12-30 22:14:46.737 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.alive 2019-12-30 22:14:46.747 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.connected 2019-12-30 22:14:46.748 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memRss 2019-12-30 22:14:46.749 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memHeapTotal 2019-12-30 22:14:46.750 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memHeapUsed 2019-12-30 22:14:46.750 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.eventLoopLag 2019-12-30 22:14:46.751 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.uptime 2019-12-30 22:14:46.752 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.inputCount 2019-12-30 22:14:46.753 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.outputCount 2019-12-30 22:14:46.762 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.cpu 2019-12-30 22:14:46.763 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.cputime 2019-12-30 22:14:47.442 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.alive 2019-12-30 22:14:47.443 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.connected 2019-12-30 22:14:47.444 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.memRss 2019-12-30 22:14:47.445 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.memHeapTotal 2019-12-30 22:14:47.445 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.memHeapUsed 2019-12-30 22:14:47.446 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.eventLoopLag 2019-12-30 22:14:47.447 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.uptime 2019-12-30 22:14:47.448 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.inputCount 2019-12-30 22:14:47.450 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.outputCount 2019-12-30 22:14:47.467 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.cpu 2019-12-30 22:14:47.470 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.cputime 2019-12-30 22:14:47.968 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.temperature 2019-12-30 22:14:47.972 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime 2019-12-30 22:14:48.182 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.temperature 2019-12-30 22:14:48.186 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime 2019-12-30 22:14:49.171 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime 2019-12-30 22:14:49.182 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.alive 2019-12-30 22:14:49.193 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.connected 2019-12-30 22:14:49.194 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.memRss 2019-12-30 22:14:49.195 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.memHeapTotal 2019-12-30 22:14:49.195 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.memHeapUsed 2019-12-30 22:14:49.196 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.eventLoopLag 2019-12-30 22:14:49.197 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.uptime 2019-12-30 22:14:49.197 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.inputCount 2019-12-30 22:14:49.198 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.outputCount 2019-12-30 22:14:49.211 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.cpu 2019-12-30 22:14:49.212 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.cputime 2019-12-30 22:14:49.307 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.temperature 2019-12-30 22:14:49.318 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime 2019-12-30 22:14:49.319 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.rssi 2019-12-30 22:14:49.928 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime 2019-12-30 22:14:49.931 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.rssi 2019-12-30 22:14:50.299 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.alive 2019-12-30 22:14:50.309 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.connected 2019-12-30 22:14:50.310 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.memRss 2019-12-30 22:14:50.311 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.memHeapTotal 2019-12-30 22:14:50.311 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.memHeapUsed 2019-12-30 22:14:50.312 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.eventLoopLag 2019-12-30 22:14:50.313 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.uptime 2019-12-30 22:14:50.313 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.inputCount 2019-12-30 22:14:50.314 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.outputCount 2019-12-30 22:14:50.322 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.cpu 2019-12-30 22:14:50.323 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.cputime 2019-12-30 22:14:50.717 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.temperature 2019-12-30 22:14:50.721 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.uptime 2019-12-30 22:14:50.848 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.uptime 2019-12-30 22:14:50.851 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.rssi 2019-12-30 22:14:50.915 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.temperature 2019-12-30 22:14:50.919 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.uptime 2019-12-30 22:14:50.920 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.rssi 2019-12-30 22:14:51.005 - warn: heatingcontrol.0 (26464) device not found yeelight-2.0.WZDeckenleuchte.info.connect 2019-12-30 22:14:51.006 - warn: heatingcontrol.0 (26464) device not found yeelight-2.0.SZDeckenleuchte.info.connect 2019-12-30 22:14:51.007 - warn: heatingcontrol.0 (26464) device not found yeelight-2.0.KZDeckenleuchte.info.connect 2019-12-30 22:14:51.007 - warn: heatingcontrol.0 (26464) device not found yeelight-2.0.KuechePendelleuchte.info.connect 2019-12-30 22:14:51.008 - warn: heatingcontrol.0 (26464) device not found yeelight-2.0.KuechePendelleuchte.control.power 2019-12-30 22:14:51.130 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.Relay0.Power 2019-12-30 22:14:51.198 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.uptime 2019-12-30 22:14:51.434 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.alive 2019-12-30 22:14:51.435 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.connected 2019-12-30 22:14:51.441 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memRss 2019-12-30 22:14:51.442 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memHeapTotal 2019-12-30 22:14:51.442 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memHeapUsed 2019-12-30 22:14:51.443 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.eventLoopLag 2019-12-30 22:14:51.444 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.uptime 2019-12-30 22:14:51.445 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.inputCount 2019-12-30 22:14:51.445 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.outputCount 2019-12-30 22:14:51.477 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.cpu 2019-12-30 22:14:51.479 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.cputime 2019-12-30 22:14:51.480 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Power 2019-12-30 22:14:51.489 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.temperature 2019-12-30 22:14:51.493 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.uptime 2019-12-30 22:14:51.600 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.temperature 2019-12-30 22:14:51.616 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.uptime 2019-12-30 22:14:51.617 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.rssi 2019-12-30 22:14:51.732 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.temperature 2019-12-30 22:14:51.733 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.uptime 2019-12-30 22:14:51.734 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.rssi 2019-12-30 22:14:52.388 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.alive 2019-12-30 22:14:52.389 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.connected 2019-12-30 22:14:52.390 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memRss 2019-12-30 22:14:52.390 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memHeapTotal 2019-12-30 22:14:52.391 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memHeapUsed 2019-12-30 22:14:52.402 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.eventLoopLag 2019-12-30 22:14:52.403 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.uptime 2019-12-30 22:14:52.404 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.inputCount 2019-12-30 22:14:52.404 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.outputCount 2019-12-30 22:14:52.405 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.cpu 2019-12-30 22:14:52.405 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.cputime 2019-12-30 22:14:52.666 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.alive 2019-12-30 22:14:52.667 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.connected 2019-12-30 22:14:52.667 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memRss 2019-12-30 22:14:52.668 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memHeapTotal 2019-12-30 22:14:52.669 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memHeapUsed 2019-12-30 22:14:52.669 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.eventLoopLag 2019-12-30 22:14:52.670 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.uptime 2019-12-30 22:14:52.670 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.inputCount 2019-12-30 22:14:52.671 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.outputCount 2019-12-30 22:14:52.679 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.cpu 2019-12-30 22:14:52.680 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.cputime 2019-12-30 22:14:53.381 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime 2019-12-30 22:14:53.575 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.temperature 2019-12-30 22:14:53.578 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime 2019-12-30 22:14:54.286 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.alive 2019-12-30 22:14:54.291 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.connected 2019-12-30 22:14:54.292 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memRss 2019-12-30 22:14:54.296 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memHeapTotal 2019-12-30 22:14:54.306 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memHeapUsed 2019-12-30 22:14:54.307 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.eventLoopLag 2019-12-30 22:14:54.308 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.uptime 2019-12-30 22:14:54.309 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.inputCount 2019-12-30 22:14:54.310 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.outputCount 2019-12-30 22:14:54.315 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.cpu 2019-12-30 22:14:54.318 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.cputime 2019-12-30 22:14:54.330 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.alive 2019-12-30 22:14:54.332 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.connected 2019-12-30 22:14:54.333 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memRss 2019-12-30 22:14:54.334 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memHeapTotal 2019-12-30 22:14:54.334 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memHeapUsed 2019-12-30 22:14:54.335 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.eventLoopLag 2019-12-30 22:14:54.335 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.uptime 2019-12-30 22:14:54.343 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.inputCount 2019-12-30 22:14:54.344 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.outputCount 2019-12-30 22:14:54.345 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.cpu 2019-12-30 22:14:54.346 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.cputime 2019-12-30 22:14:54.397 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.alive 2019-12-30 22:14:54.398 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memRss 2019-12-30 22:14:54.398 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memHeapTotal 2019-12-30 22:14:54.399 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memHeapUsed 2019-12-30 22:14:54.399 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.load 2019-12-30 22:14:54.400 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.uptime 2019-12-30 22:14:54.400 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.mem 2019-12-30 22:14:54.401 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.freemem 2019-12-30 22:14:54.401 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memAvailable 2019-12-30 22:14:54.402 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.inputCount 2019-12-30 22:14:54.402 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.outputCount 2019-12-30 22:14:54.403 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.eventLoopLag 2019-12-30 22:14:54.404 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.compactgroupProcesses 2019-12-30 22:14:54.414 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.instancesAsProcess 2019-12-30 22:14:54.415 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.instancesAsCompact 2019-12-30 22:14:54.416 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.cpu 2019-12-30 22:14:54.416 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.cputime 2019-12-30 22:14:54.511 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.temperature 2019-12-30 22:14:54.514 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime 2019-12-30 22:14:54.534 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.alive 2019-12-30 22:14:54.543 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.connected 2019-12-30 22:14:54.544 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memRss 2019-12-30 22:14:54.545 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memHeapTotal 2019-12-30 22:14:54.547 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memHeapUsed 2019-12-30 22:14:54.555 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.eventLoopLag 2019-12-30 22:14:54.555 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.uptime 2019-12-30 22:14:54.556 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.inputCount 2019-12-30 22:14:54.557 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.outputCount 2019-12-30 22:14:54.557 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.cpu 2019-12-30 22:14:54.558 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.cputime 2019-12-30 22:14:54.588 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime 2019-12-30 22:14:54.591 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.rssi 2019-12-30 22:14:55.124 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime 2019-12-30 22:14:56.052 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.uptime 2019-12-30 22:14:56.185 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.uptime 2019-12-30 22:14:56.188 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.rssi 2019-12-30 22:14:56.313 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.uptime 2019-12-30 22:14:56.316 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.rssi 2019-12-30 22:14:56.346 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.Relay0.Power 2019-12-30 22:14:56.414 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.uptime 2019-12-30 22:14:56.803 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.uptime 2019-12-30 22:14:56.804 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.rssi 2019-12-30 22:14:56.938 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.temperature 2019-12-30 22:14:56.942 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.uptime 2019-12-30 22:14:57.143 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Power 2019-12-30 22:14:57.208 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.temperature 2019-12-30 22:14:57.212 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.uptime 2019-12-30 22:14:57.213 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.rssi 2019-12-30 22:14:58.787 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime 2019-12-30 22:14:58.983 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime 2019-12-30 22:14:58.986 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.rssi 2019-12-30 22:14:59.712 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.temperature 2019-12-30 22:14:59.717 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime 2019-12-30 22:14:59.991 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime 2019-12-30 22:14:59.994 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.rssi 2019-12-30 22:15:00.324 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.temperature 2019-12-30 22:15:00.327 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime 2019-12-30 22:15:00.959 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.alive 2019-12-30 22:15:00.966 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.connected 2019-12-30 22:15:00.967 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memRss 2019-12-30 22:15:00.968 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memHeapTotal 2019-12-30 22:15:00.977 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memHeapUsed 2019-12-30 22:15:00.978 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.eventLoopLag 2019-12-30 22:15:00.978 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.uptime 2019-12-30 22:15:00.979 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.inputCount 2019-12-30 22:15:00.979 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.outputCount 2019-12-30 22:15:00.980 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.cpu 2019-12-30 22:15:00.980 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.cputime 2019-12-30 22:15:01.554 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.Relay0.Power 2019-12-30 22:15:01.557 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.Relay0.Energy 2019-12-30 22:15:01.598 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.temperature 2019-12-30 22:15:01.603 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.uptime 2019-12-30 22:15:01.604 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.rssi 2019-12-30 22:15:01.624 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.temperature 2019-12-30 22:15:01.627 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.uptime 2019-12-30 22:15:01.706 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.temperature 2019-12-30 22:15:01.709 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.uptime 2019-12-30 22:15:01.738 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.alive 2019-12-30 22:15:01.748 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.connected 2019-12-30 22:15:01.748 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memRss 2019-12-30 22:15:01.749 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memHeapTotal 2019-12-30 22:15:01.749 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memHeapUsed 2019-12-30 22:15:01.750 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.eventLoopLag 2019-12-30 22:15:01.751 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.uptime 2019-12-30 22:15:01.751 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.inputCount 2019-12-30 22:15:01.752 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.outputCount 2019-12-30 22:15:01.759 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.cpu 2019-12-30 22:15:01.760 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.cputime 2019-12-30 22:15:02.142 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.uptime 2019-12-30 22:15:02.145 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.rssi 2019-12-30 22:15:02.277 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.uptime 2019-12-30 22:15:02.350 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Power 2019-12-30 22:15:02.354 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Energy 2019-12-30 22:15:02.413 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.uptime 2019-12-30 22:15:02.416 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.rssi 2019-12-30 22:15:02.442 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.alive 2019-12-30 22:15:02.443 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.connected 2019-12-30 22:15:02.444 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.memRss 2019-12-30 22:15:02.445 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.memHeapTotal 2019-12-30 22:15:02.445 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.memHeapUsed 2019-12-30 22:15:02.446 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.eventLoopLag 2019-12-30 22:15:02.446 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.uptime 2019-12-30 22:15:02.447 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.inputCount 2019-12-30 22:15:02.447 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.outputCount 2019-12-30 22:15:02.460 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.cpu 2019-12-30 22:15:02.464 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.cputime 2019-12-30 22:15:03.050 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.uptime 2019-12-30 22:15:04.185 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.alive 2019-12-30 22:15:04.196 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.connected 2019-12-30 22:15:04.197 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.memRss 2019-12-30 22:15:04.198 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.memHeapTotal 2019-12-30 22:15:04.198 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.memHeapUsed 2019-12-30 22:15:04.199 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.eventLoopLag 2019-12-30 22:15:04.199 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.uptime 2019-12-30 22:15:04.200 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.inputCount 2019-12-30 22:15:04.200 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.outputCount 2019-12-30 22:15:04.208 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.cpu 2019-12-30 22:15:04.209 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.cputime 2019-12-30 22:15:04.210 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime 2019-12-30 22:15:04.386 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.temperature 2019-12-30 22:15:04.390 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime 2019-12-30 22:15:04.391 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.rssi 2019-12-30 22:15:04.906 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime 2019-12-30 22:15:04.909 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.rssi 2019-12-30 22:15:05.301 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.alive 2019-12-30 22:15:05.311 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.connected 2019-12-30 22:15:05.312 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.memRss 2019-12-30 22:15:05.313 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.memHeapTotal 2019-12-30 22:15:05.313 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.memHeapUsed 2019-12-30 22:15:05.314 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.eventLoopLag 2019-12-30 22:15:05.314 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.uptime 2019-12-30 22:15:05.315 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.inputCount 2019-12-30 22:15:05.316 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.outputCount 2019-12-30 22:15:05.322 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.cpu 2019-12-30 22:15:05.323 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.cputime 2019-12-30 22:15:05.395 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime 2019-12-30 22:15:05.530 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime 2019-12-30 22:15:06.406 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.alive 2019-12-30 22:15:06.414 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.connected 2019-12-30 22:15:06.415 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memRss 2019-12-30 22:15:06.416 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memHeapTotal 2019-12-30 22:15:06.417 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memHeapUsed 2019-12-30 22:15:06.418 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.eventLoopLag 2019-12-30 22:15:06.425 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.uptime 2019-12-30 22:15:06.426 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.inputCount 2019-12-30 22:15:06.427 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.outputCount 2019-12-30 22:15:06.428 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.cpu 2019-12-30 22:15:06.428 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.cputime 2019-12-30 22:15:06.832 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.temperature 2019-12-30 22:15:06.837 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.uptime 2019-12-30 22:15:06.838 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.rssi 2019-12-30 22:15:07.011 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.temperature 2019-12-30 22:15:07.018 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.uptime 2019-12-30 22:15:07.020 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.rssi 2019-12-30 22:15:07.122 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.temperature 2019-12-30 22:15:07.127 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.uptime 2019-12-30 22:15:07.344 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.temperature 2019-12-30 22:15:07.353 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.uptime 2019-12-30 22:15:07.354 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.rssi 2019-12-30 22:15:07.392 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.alive 2019-12-30 22:15:07.393 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.connected 2019-12-30 22:15:07.394 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memRss 2019-12-30 22:15:07.395 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memHeapTotal 2019-12-30 22:15:07.395 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memHeapUsed 2019-12-30 22:15:07.396 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.eventLoopLag 2019-12-30 22:15:07.397 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.uptime 2019-12-30 22:15:07.413 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.inputCount 2019-12-30 22:15:07.415 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.outputCount 2019-12-30 22:15:07.416 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.cpu 2019-12-30 22:15:07.417 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.cputime 2019-12-30 22:15:07.476 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.uptime 2019-12-30 22:15:07.549 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Power 2019-12-30 22:15:07.611 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.uptime 2019-12-30 22:15:07.661 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.alive 2019-12-30 22:15:07.673 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.connected 2019-12-30 22:15:07.675 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memRss 2019-12-30 22:15:07.676 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memHeapTotal 2019-12-30 22:15:07.676 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memHeapUsed 2019-12-30 22:15:07.677 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.eventLoopLag 2019-12-30 22:15:07.678 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.uptime 2019-12-30 22:15:07.679 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.inputCount 2019-12-30 22:15:07.680 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.outputCount 2019-12-30 22:15:07.691 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.cpu 2019-12-30 22:15:07.692 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.cputime 2019-12-30 22:15:08.250 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.temperature 2019-12-30 22:15:08.256 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.uptime 2019-12-30 22:15:08.258 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.rssi 2019-12-30 22:15:09.292 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.alive 2019-12-30 22:15:09.305 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.connected 2019-12-30 22:15:09.307 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memRss 2019-12-30 22:15:09.308 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memHeapTotal 2019-12-30 22:15:09.309 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memHeapUsed 2019-12-30 22:15:09.310 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.eventLoopLag 2019-12-30 22:15:09.316 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.uptime 2019-12-30 22:15:09.347 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.inputCount 2019-12-30 22:15:09.349 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.outputCount 2019-12-30 22:15:09.350 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.cpu 2019-12-30 22:15:09.351 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.cputime 2019-12-30 22:15:09.366 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.alive 2019-12-30 22:15:09.367 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.connected 2019-12-30 22:15:09.368 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memRss 2019-12-30 22:15:09.369 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memHeapTotal 2019-12-30 22:15:09.370 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memHeapUsed 2019-12-30 22:15:09.370 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.eventLoopLag 2019-12-30 22:15:09.371 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.uptime 2019-12-30 22:15:09.372 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.inputCount 2019-12-30 22:15:09.373 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.outputCount 2019-12-30 22:15:09.374 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.cpu 2019-12-30 22:15:09.374 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.cputime 2019-12-30 22:15:09.402 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.alive 2019-12-30 22:15:09.424 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memRss 2019-12-30 22:15:09.425 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memHeapTotal 2019-12-30 22:15:09.426 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memHeapUsed 2019-12-30 22:15:09.427 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.load 2019-12-30 22:15:09.428 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.uptime 2019-12-30 22:15:09.428 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.mem 2019-12-30 22:15:09.429 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.freemem 2019-12-30 22:15:09.430 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memAvailable 2019-12-30 22:15:09.430 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.inputCount 2019-12-30 22:15:09.431 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.outputCount 2019-12-30 22:15:09.446 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.eventLoopLag 2019-12-30 22:15:09.447 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.compactgroupProcesses 2019-12-30 22:15:09.448 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.instancesAsProcess 2019-12-30 22:15:09.449 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.instancesAsCompact 2019-12-30 22:15:09.450 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.cpu 2019-12-30 22:15:09.451 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.cputime 2019-12-30 22:15:09.548 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.alive 2019-12-30 22:15:09.549 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.connected 2019-12-30 22:15:09.551 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memRss 2019-12-30 22:15:09.552 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memHeapTotal 2019-12-30 22:15:09.563 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memHeapUsed 2019-12-30 22:15:09.564 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.eventLoopLag 2019-12-30 22:15:09.565 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.uptime 2019-12-30 22:15:09.566 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.inputCount 2019-12-30 22:15:09.567 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.outputCount 2019-12-30 22:15:09.567 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.cpu 2019-12-30 22:15:09.568 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.cputime 2019-12-30 22:15:09.601 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.temperature 2019-12-30 22:15:09.605 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime 2019-12-30 22:15:09.787 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime 2019-12-30 22:15:10.110 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.temperature 2019-12-30 22:15:10.116 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime 2019-12-30 22:15:10.117 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.rssi 2019-12-30 22:15:10.724 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.temperature 2019-12-30 22:15:10.728 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime 2019-12-30 22:15:11.304 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.temperature 2019-12-30 22:15:11.308 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime 2019-12-30 22:15:11.309 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.rssi 2019-12-30 22:15:12.179 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.Relay0.Power 2019-12-30 22:15:12.247 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.temperature 2019-12-30 22:15:12.250 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.uptime 2019-12-30 22:15:12.417 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.temperature 2019-12-30 22:15:12.422 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.uptime 2019-12-30 22:15:12.423 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.rssi 2019-12-30 22:15:12.519 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.temperature 2019-12-30 22:15:12.523 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.uptime 2019-12-30 22:15:12.537 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.temperature 2019-12-30 22:15:12.541 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.uptime 2019-12-30 22:15:12.542 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.rssi 2019-12-30 22:15:12.678 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.uptime 2019-12-30 22:15:12.689 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.rssi 2019-12-30 22:15:12.750 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Power 2019-12-30 22:15:12.815 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.temperature 2019-12-30 22:15:12.819 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.uptime 2019-12-30 22:15:13.448 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.temperature 2019-12-30 22:15:13.452 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.uptime 2019-12-30 22:15:13.453 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.rssi 2019-12-30 22:15:15.009 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.temperature 2019-12-30 22:15:15.014 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime 2019-12-30 22:15:15.184 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime 2019-12-30 22:15:15.310 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.temperature 2019-12-30 22:15:15.316 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime 2019-12-30 22:15:15.317 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.rssi 2019-12-30 22:15:15.922 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.temperature 2019-12-30 22:15:15.927 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime 2019-12-30 22:15:15.990 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.alive 2019-12-30 22:15:15.991 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.connected 2019-12-30 22:15:15.992 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memRss 2019-12-30 22:15:15.993 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memHeapTotal 2019-12-30 22:15:15.994 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memHeapUsed 2019-12-30 22:15:15.995 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.eventLoopLag 2019-12-30 22:15:15.996 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.uptime 2019-12-30 22:15:15.997 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.inputCount 2019-12-30 22:15:15.998 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.outputCount 2019-12-30 22:15:16.009 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.cpu 2019-12-30 22:15:16.011 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.cputime 2019-12-30 22:15:16.705 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime 2019-12-30 22:15:16.708 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.rssi 2019-12-30 22:15:16.750 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.alive 2019-12-30 22:15:16.762 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.connected 2019-12-30 22:15:16.764 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memRss 2019-12-30 22:15:16.764 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memHeapTotal 2019-12-30 22:15:16.765 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memHeapUsed 2019-12-30 22:15:16.766 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.eventLoopLag 2019-12-30 22:15:16.767 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.uptime 2019-12-30 22:15:16.767 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.inputCount 2019-12-30 22:15:16.768 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.outputCount 2019-12-30 22:15:16.777 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.cpu 2019-12-30 22:15:16.778 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.cputime 2019-12-30 22:15:16.815 - info: host.RasPi "system.adapter.heatingcontrol.0" disabled 2019-12-30 22:15:16.817 - info: host.RasPi stopInstance system.adapter.heatingcontrol.0 (force=false, process=true) 2019-12-30 22:15:16.822 - info: heatingcontrol.0 (26464) Adapter is disabled => stop 2019-12-30 22:15:16.823 - info: host.RasPi stopInstance system.adapter.heatingcontrol.0 send kill signal 2019-12-30 22:15:16.826 - info: heatingcontrol.0 (26464) cleaned everything up... 2019-12-30 22:15:16.836 - info: heatingcontrol.0 (26464) Got terminate signal TERMINATE_YOURSELF 2019-12-30 22:15:16.839 - info: heatingcontrol.0 (26464) Got terminate signal TERMINATE_YOURSELF 2019-12-30 22:15:16.841 - info: heatingcontrol.0 (26464) terminating 2019-12-30 22:15:16.844 - info: heatingcontrol.0 (26464) Terminated (NO_ERROR): Without reason 2019-12-30 22:15:16.851 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.sigKill 2019-12-30 22:15:16.857 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.alive 2019-12-30 22:15:16.858 - warn: heatingcontrol.0 (26464) device not found heatingcontrol.0.system.adapter.heatingcontrol.0.sigKill 2019-12-30 22:15:17.367 - info: host.RasPi instance system.adapter.heatingcontrol.0 terminated with code 0 (NO_ERROR)wenn ich den adapter starte bekomme ich neuerdings dieses log. Und das scheint ewig so weiter zu gehen.
Ideas anyone?verwende aqara sensoren für temperatur und shellys sollen stellantriebe für die fbh schalten.
Was machen da die warnungen mit bezug auf yeelight, mclighting etc im log?
@piscator83 schau dir mal deine Konfiguration an. Du musst die TargetOID in den Thermostaten setzen. Nur die Ist-OID reicht nicht!
siehe im logexception in CheckTemperatureChange [invalid id ""]Dadurch werden alle states im System subscribed, was zu den vielen Warnungen führt...
Wenn du nur Temperatur-Sensoren hast, musst du dir die Target-OID's irgendwo anders (evtl. in einem script) anlegen. Wir brauchen die, um die aktuelle Zieltemperatur zu speichern. Normalerweise passiert das in den Thermostaten...
heatingcontrol.0 2019-12-31 08:43:34.457 debug (2068) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933362844} from deconz.0.Sensors.21.open heatingcontrol.0 2019-12-31 08:43:34.455 debug (2068) got sensor state {"val":false,"ack":true,"ts":1577717574989,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577638441163} from deconz.0.Sensors.20.open heatingcontrol.0 2019-12-31 08:43:34.453 debug (2068) got sensor state {"val":false,"ack":true,"ts":1577717574989,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933207327} from deconz.0.Sensors.19.open heatingcontrol.0 2019-12-31 08:43:34.452 debug (2068) got sensor state {"val":false,"ack":true,"ts":1577717574987,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933122635} from deconz.0.Sensors.18.open heatingcontrol.0 2019-12-31 08:43:34.451 debug (2068) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933025797} from deconz.0.Sensors.17.open heatingcontrol.0 2019-12-31 08:43:34.450 debug (2068) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576932905933} from deconz.0.Sensors.16.open heatingcontrol.0 2019-12-31 08:43:34.449 debug (2068) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577007719646} from deconz.0.Sensors.15.open heatingcontrol.0 2019-12-31 08:43:34.448 debug (2068) Check sensors for Wohnzimmer heatingcontrol.0 2019-12-31 08:43:34.435 debug (2068) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577644284922} from deconz.0.Sensors.24.open heatingcontrol.0 2019-12-31 08:43:34.435 debug (2068) got sensor state {"val":0,"ack":true,"ts":1577778970470,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1577778970470} from hm-rpc.1.0007D5699E9605.1.STATE heatingcontrol.0 2019-12-31 08:43:34.434 debug (2068) Check sensors for Küche heatingcontrol.0 2019-12-31 08:43:34.430 warn (2068) Badezimmer no valid result from hm-rpc.1.0000D56996187D heatingcontrol.0 2019-12-31 08:43:34.429 debug (2068) got sensor state null from hm-rpc.1.0000D56996187D heatingcontrol.0 2019-12-31 08:43:34.425 debug (2068) Check sensors for Badezimmer heatingcontrol.0 2019-12-31 08:43:34.420 debug (2068) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577705276875} from deconz.0.Sensors.23.open heatingcontrol.0 2019-12-31 08:43:34.420 debug (2068) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576925832752} from deconz.0.Sensors.11.open heatingcontrol.0 2019-12-31 08:43:34.418 debug (2068) Check sensors for Arbeitszimmer heatingcontrol.0 2019-12-31 08:43:34.418 debug (2068) [INFO] status = true next event: 4 Jan 2020 20:00:00 heatingcontrol.0 2019-12-31 08:43:34.417 debug (2068) [INFO] status = true next event: 4 Jan 2020 15:00:00 heatingcontrol.0 2019-12-31 08:43:34.416 debug (2068) [INFO] status = true next event: 4 Jan 2020 11:00:00 heatingcontrol.0 2019-12-31 08:43:34.415 debug (2068) [INFO] status = true next event: 4 Jan 2020 07:00:00 heatingcontrol.0 2019-12-31 08:43:34.415 debug (2068) [INFO] status = true next event: 4 Jan 2020 04:00:00 heatingcontrol.0 2019-12-31 08:43:34.414 debug (2068) [INFO] status = true next event: 31 Dec 2019 20:00:00 heatingcontrol.0 2019-12-31 08:43:34.414 debug (2068) [INFO] status = true next event: 31 Dec 2019 15:00:00 heatingcontrol.0 2019-12-31 08:43:34.413 debug (2068) [INFO] status = true next event: 31 Dec 2019 11:00:00 heatingcontrol.0 2019-12-31 08:43:34.413 debug (2068) [INFO] status = true next event: 1 Jan 2020 07:00:00 heatingcontrol.0 2019-12-31 08:43:34.411 debug (2068) [INFO] status = true next event: 1 Jan 2020 04:00:00 heatingcontrol.0 2019-12-31 08:43:34.401 debug (2068) create cron job #9 at 21:0 string: 0 0 21 * * 0,6 Europe/Berlin heatingcontrol.0 2019-12-31 08:43:34.399 debug (2068) create cron job #8 at 16:0 string: 0 0 16 * * 0,6 Europe/Berlin heatingcontrol.0 2019-12-31 08:43:34.398 debug (2068) create cron job #7 at 12:0 string: 0 0 12 * * 0,6 Europe/Berlin heatingcontrol.0 2019-12-31 08:43:34.396 debug (2068) create cron job #6 at 8:0 string: 0 0 8 * * 0,6 Europe/Berlin heatingcontrol.0 2019-12-31 08:43:34.392 debug (2068) create cron job #5 at 5:0 string: 0 0 5 * * 0,6 Europe/Berlin heatingcontrol.0 2019-12-31 08:43:34.391 debug (2068) create cron job #4 at 21:0 string: 0 0 21 * * 1-5 Europe/Berlin heatingcontrol.0 2019-12-31 08:43:34.390 debug (2068) create cron job #3 at 16:0 string: 0 0 16 * * 1-5 Europe/Berlin heatingcontrol.0 2019-12-31 08:43:34.388 debug (2068) create cron job #2 at 12:0 string: 0 0 12 * * 1-5 Europe/Berlin heatingcontrol.0 2019-12-31 08:43:34.380 debug (2068) create cron job #1 at 8:0 string: 0 0 8 * * 1-5 Europe/Berlin heatingcontrol.0 2019-12-31 08:43:34.367 debug (2068) create cron job #0 at 5:0 string: 0 0 5 * * 1-5 Europe/Berlin heatingcontrol.0 2019-12-31 08:43:34.366 debug (2068) ---2 found time for Wohnzimmer at {"val":"21:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 21:00 heatingcontrol.0 2019-12-31 08:43:34.365 debug (2068) ---2 found time for Wohnzimmer at {"val":"16:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 16:00 heatingcontrol.0 2019-12-31 08:43:34.365 debug (2068) ---2 found time for Wohnzimmer at {"val":"12:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 12:00 heatingcontrol.0 2019-12-31 08:43:34.364 debug (2068) ---2 found time for Wohnzimmer at {"val":"08:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 08:00 heatingcontrol.0 2019-12-31 08:43:34.364 debug (2068) ---2 found time for Wohnzimmer at {"val":"05:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 05:00 heatingcontrol.0 2019-12-31 08:43:34.363 debug (2068) setting Sa - Su heatingcontrol.0 2019-12-31 08:43:34.363 debug (2068) ---1 found time for Wohnzimmer at {"val":"21:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 21:00 heatingcontrol.0 2019-12-31 08:43:34.362 debug (2068) ---1 found time for Wohnzimmer at {"val":"16:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 16:00 heatingcontrol.0 2019-12-31 08:43:34.361 debug (2068) ---1 found time for Wohnzimmer at {"val":"12:00","ack":false,"ts":1577542409214,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1577542409214} 12:00 heatingcontrol.0 2019-12-31 08:43:34.079 debug (2068) ---1 found time for Wohnzimmer at {"val":"08:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 08:00 heatingcontrol.0 2019-12-31 08:43:34.078 debug (2068) ---1 found time for Wohnzimmer at {"val":"05:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 05:00 heatingcontrol.0 2019-12-31 08:43:34.077 debug (2068) setting Mo - Fr heatingcontrol.0 2019-12-31 08:43:34.077 debug (2068) ---2 found time for Küche at {"val":"21:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 21:00 heatingcontrol.0 2019-12-31 08:43:34.077 debug (2068) ---2 found time for Küche at {"val":"16:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 16:00 heatingcontrol.0 2019-12-31 08:43:34.076 debug (2068) ---2 found time for Küche at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00 heatingcontrol.0 2019-12-31 08:43:34.075 debug (2068) ---2 found time for Küche at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00 heatingcontrol.0 2019-12-31 08:43:34.074 debug (2068) ---2 found time for Küche at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00 heatingcontrol.0 2019-12-31 08:43:34.074 debug (2068) setting Sa - Su heatingcontrol.0 2019-12-31 08:43:34.073 debug (2068) ---1 found time for Küche at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00 heatingcontrol.0 2019-12-31 08:43:34.067 debug (2068) ---1 found time for Küche at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00 heatingcontrol.0 2019-12-31 08:43:34.066 debug (2068) ---1 found time for Küche at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00 heatingcontrol.0 2019-12-31 08:43:34.064 debug (2068) ---1 found time for Küche at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00 heatingcontrol.0 2019-12-31 08:43:34.064 debug (2068) ---1 found time for Küche at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00 heatingcontrol.0 2019-12-31 08:43:34.063 debug (2068) setting Mo - Fr heatingcontrol.0 2019-12-31 08:43:34.063 debug (2068) ---2 found time for Badezimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00 heatingcontrol.0 2019-12-31 08:43:34.062 debug (2068) ---2 found time for Badezimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00 heatingcontrol.0 2019-12-31 08:43:34.061 debug (2068) ---2 found time for Badezimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00 heatingcontrol.0 2019-12-31 08:43:34.061 debug (2068) ---2 found time for Badezimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00 heatingcontrol.0 2019-12-31 08:43:34.060 debug (2068) ---2 found time for Badezimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00 heatingcontrol.0 2019-12-31 08:43:34.060 debug (2068) setting Sa - Su heatingcontrol.0 2019-12-31 08:43:34.059 debug (2068) ---1 found time for Badezimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00 heatingcontrol.0 2019-12-31 08:43:34.059 debug (2068) ---1 found time for Badezimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00 heatingcontrol.0 2019-12-31 08:43:34.057 debug (2068) ---1 found time for Badezimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00 heatingcontrol.0 2019-12-31 08:43:34.057 debug (2068) ---1 found time for Badezimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00 heatingcontrol.0 2019-12-31 08:43:34.056 debug (2068) ---1 found time for Badezimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00 heatingcontrol.0 2019-12-31 08:43:34.056 debug (2068) setting Mo - Fr heatingcontrol.0 2019-12-31 08:43:34.055 debug (2068) push to list = 21,00 heatingcontrol.0 2019-12-31 08:43:34.055 debug (2068) ---2 found time for Arbeitszimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00 heatingcontrol.0 2019-12-31 08:43:34.054 debug (2068) push to list = 16,00 heatingcontrol.0 2019-12-31 08:43:34.054 debug (2068) ---2 found time for Arbeitszimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00 heatingcontrol.0 2019-12-31 08:43:34.054 debug (2068) push to list = 12,00 heatingcontrol.0 2019-12-31 08:43:34.054 debug (2068) ---2 found time for Arbeitszimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00 heatingcontrol.0 2019-12-31 08:43:34.053 debug (2068) push to list = 08,00 heatingcontrol.0 2019-12-31 08:43:34.053 debug (2068) ---2 found time for Arbeitszimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00 heatingcontrol.0 2019-12-31 08:43:34.053 debug (2068) push to list = 05,00 heatingcontrol.0 2019-12-31 08:43:34.052 debug (2068) ---2 found time for Arbeitszimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00 heatingcontrol.0 2019-12-31 08:43:34.052 debug (2068) setting Sa - Su heatingcontrol.0 2019-12-31 08:43:34.052 debug (2068) push to list = 21,00 heatingcontrol.0 2019-12-31 08:43:34.052 debug (2068) ---1 found time for Arbeitszimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00 heatingcontrol.0 2019-12-31 08:43:34.051 debug (2068) push to list = 16,00 heatingcontrol.0 2019-12-31 08:43:34.051 debug (2068) ---1 found time for Arbeitszimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00 heatingcontrol.0 2019-12-31 08:43:34.050 debug (2068) push to list = 12,00 heatingcontrol.0 2019-12-31 08:43:34.050 debug (2068) ---1 found time for Arbeitszimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00 heatingcontrol.0 2019-12-31 08:43:34.007 debug (2068) push to list = 08,00 heatingcontrol.0 2019-12-31 08:43:34.007 debug (2068) ---1 found time for Arbeitszimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00 heatingcontrol.0 2019-12-31 08:43:33.967 debug (2068) push to list = 05,00 heatingcontrol.0 2019-12-31 08:43:33.967 debug (2068) ---1 found time for Arbeitszimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00 heatingcontrol.0 2019-12-31 08:43:33.965 debug (2068) setting Mo - Fr heatingcontrol.0 2019-12-31 08:43:33.965 debug (2068) profile 0 heatingcontrol.0 2019-12-31 08:43:33.963 debug (2068) get profile heatingcontrol.0 2019-12-31 08:43:33.963 debug (2068) start CalculateNextTime, profile type 2 heatingcontrol.0 2019-12-31 08:43:33.954 debug (2068) system date format DD.MM.YYYY heatingcontrol.0 2019-12-31 08:43:33.952 debug (2068) CreateDatepoints done heatingcontrol.0 2019-12-31 08:43:33.952 debug (2068) not active.... Kinderzimmer heatingcontrol.0 2019-12-31 08:43:33.952 debug (2068) not active.... Schlafzimmer heatingcontrol.0 2019-12-31 08:43:33.951 debug (2068) add state Profiles.0.Wohnzimmer.Sa-So.Periods.4 max 5 heatingcontrol.0 2019-12-31 08:43:33.951 debug (2068) add state Profiles.0.Wohnzimmer.Sa-So.Periods.3 max 5 heatingcontrol.0 2019-12-31 08:43:33.951 debug (2068) add state Profiles.0.Wohnzimmer.Sa-So.Periods.2 max 5 heatingcontrol.0 2019-12-31 08:43:33.951 debug (2068) add state Profiles.0.Wohnzimmer.Sa-So.Periods.1 max 5 heatingcontrol.0 2019-12-31 08:43:33.951 debug (2068) add state Profiles.0.Wohnzimmer.Sa-So.Periods.0 max 5 heatingcontrol.0 2019-12-31 08:43:33.951 debug (2068) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.4 max 5 heatingcontrol.0 2019-12-31 08:43:33.950 debug (2068) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.3 max 5 heatingcontrol.0 2019-12-31 08:43:33.950 debug (2068) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.2 max 5 heatingcontrol.0 2019-12-31 08:43:33.950 debug (2068) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.1 max 5 heatingcontrol.0 2019-12-31 08:43:33.950 debug (2068) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.0 max 5 heatingcontrol.0 2019-12-31 08:43:33.950 debug (2068) Profile Type Mo-FR + Sa-So, profiles 1 heatingcontrol.0 2019-12-31 08:43:33.949 debug (2068) room Wohnzimmer with 5 periods heatingcontrol.0 2019-12-31 08:43:33.893 debug (2068) create data profile points (absolute) for Wohnzimmer heatingcontrol.0 2019-12-31 08:43:33.892 debug (2068) add state Profiles.0.Küche.Sa-So.Periods.4 max 5 heatingcontrol.0 2019-12-31 08:43:33.892 debug (2068) add state Profiles.0.Küche.Sa-So.Periods.3 max 5 heatingcontrol.0 2019-12-31 08:43:33.892 debug (2068) add state Profiles.0.Küche.Sa-So.Periods.2 max 5 heatingcontrol.0 2019-12-31 08:43:33.892 debug (2068) add state Profiles.0.Küche.Sa-So.Periods.1 max 5 heatingcontrol.0 2019-12-31 08:43:33.892 debug (2068) add state Profiles.0.Küche.Sa-So.Periods.0 max 5 heatingcontrol.0 2019-12-31 08:43:33.892 debug (2068) add state Profiles.0.Küche.Mo-Fr.Periods.4 max 5 heatingcontrol.0 2019-12-31 08:43:33.891 debug (2068) add state Profiles.0.Küche.Mo-Fr.Periods.3 max 5 heatingcontrol.0 2019-12-31 08:43:33.891 debug (2068) add state Profiles.0.Küche.Mo-Fr.Periods.2 max 5 heatingcontrol.0 2019-12-31 08:43:33.891 debug (2068) add state Profiles.0.Küche.Mo-Fr.Periods.1 max 5 heatingcontrol.0 2019-12-31 08:43:33.891 debug (2068) add state Profiles.0.Küche.Mo-Fr.Periods.0 max 5 heatingcontrol.0 2019-12-31 08:43:33.891 debug (2068) Profile Type Mo-FR + Sa-So, profiles 1 heatingcontrol.0 2019-12-31 08:43:33.891 debug (2068) room Küche with 5 periods heatingcontrol.0 2019-12-31 08:43:33.747 debug (2068) create data profile points (absolute) for Küche heatingcontrol.0 2019-12-31 08:43:33.746 debug (2068) add state Profiles.0.Badezimmer.Sa-So.Periods.4 max 5 heatingcontrol.0 2019-12-31 08:43:33.741 debug (2068) add state Profiles.0.Badezimmer.Sa-So.Periods.3 max 5 heatingcontrol.0 2019-12-31 08:43:33.740 debug (2068) add state Profiles.0.Badezimmer.Sa-So.Periods.2 max 5 heatingcontrol.0 2019-12-31 08:43:33.740 debug (2068) add state Profiles.0.Badezimmer.Sa-So.Periods.1 max 5 heatingcontrol.0 2019-12-31 08:43:33.740 debug (2068) add state Profiles.0.Badezimmer.Sa-So.Periods.0 max 5 heatingcontrol.0 2019-12-31 08:43:33.739 debug (2068) add state Profiles.0.Badezimmer.Mo-Fr.Periods.4 max 5 heatingcontrol.0 2019-12-31 08:43:33.739 debug (2068) add state Profiles.0.Badezimmer.Mo-Fr.Periods.3 max 5 heatingcontrol.0 2019-12-31 08:43:33.739 debug (2068) add state Profiles.0.Badezimmer.Mo-Fr.Periods.2 max 5 heatingcontrol.0 2019-12-31 08:43:33.739 debug (2068) add state Profiles.0.Badezimmer.Mo-Fr.Periods.1 max 5Moin, das ist jetzt der Debug hoffe ihr könnt mir weiter helfen.
heatingcontrol.0 2019-12-31 08:57:18.828 debug (2068) system.adapter.admin.0: logging true heatingcontrol.0 2019-12-31 08:57:07.314 debug (2068) system.adapter.admin.0: logging false heatingcontrol.0 2019-12-31 08:46:41.174 debug (2068) system.adapter.admin.0: logging true heatingcontrol.0 2019-12-31 08:43:34.461 error (2068) exception in main [invalid id ""] heatingcontrol.0 2019-12-31 08:43:34.460 info (2068) checking all actorsDas ist da jetzt noch dazu gekommen. Ich glaube auch das meine Uhr falsch geht bzw wenn ich auf die admin Uhr gucke stimmt die zeit aber die Zeit jetzt im debug ist ne Std hinterher.
@moppel2810 sagte in Test Adapter HeatingControl v0.3.x:
Hier stimmt eine Konfiguration nicht. Eine OID ist nicht gesetzt...
Hier muss der gesamte Pfad zum Datenpunkt in die Konfiguration, nicht nur der Name des Gerätes. ich denke hier fehlt .state
Ansonsten sehe ich nur, dass alle Fenster geschlossen sind.
Bzgl. des Feiertag-Problems sehe ich nichts im log. Hier wäre der Start des Adapters und das Schalten auf Feiertag interessant, das fehlt aber im log. -
@Rene_HM ich weiß du bist kein Hellseher
aber hast du eine Idee was da fehlen könnte? Ich verzweifel hier bald bei der Suche
@Rene_HM hab jetzt mal mit debug den Adapter neugestartet und das kommt dabei raus. Das mit dem Badezimmerfensterkontakt sollte sich erledigt haben hoffe ich.
heatingcontrol.0 2019-12-31 09:36:45.523 error (6841) exception in main [invalid id ""] heatingcontrol.0 2019-12-31 09:36:45.522 info (6841) checking all actors heatingcontrol.0 2019-12-31 09:36:45.476 debug (6841) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933362844} from deconz.0.Sensors.21.open heatingcontrol.0 2019-12-31 09:36:45.476 debug (6841) got sensor state {"val":false,"ack":true,"ts":1577717574989,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577638441163} from deconz.0.Sensors.20.open heatingcontrol.0 2019-12-31 09:36:45.475 debug (6841) got sensor state {"val":false,"ack":true,"ts":1577717574989,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933207327} from deconz.0.Sensors.19.open heatingcontrol.0 2019-12-31 09:36:45.472 debug (6841) got sensor state {"val":false,"ack":true,"ts":1577717574987,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933122635} from deconz.0.Sensors.18.open heatingcontrol.0 2019-12-31 09:36:45.470 debug (6841) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933025797} from deconz.0.Sensors.17.open heatingcontrol.0 2019-12-31 09:36:45.468 debug (6841) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576932905933} from deconz.0.Sensors.16.open heatingcontrol.0 2019-12-31 09:36:45.466 debug (6841) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577007719646} from deconz.0.Sensors.15.open heatingcontrol.0 2019-12-31 09:36:45.423 debug (6841) Check sensors for Wohnzimmer heatingcontrol.0 2019-12-31 09:36:45.359 debug (6841) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577644284922} from deconz.0.Sensors.24.open heatingcontrol.0 2019-12-31 09:36:45.357 debug (6841) got sensor state {"val":0,"ack":true,"ts":1577784161106,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1577784161106} from hm-rpc.1.0007D5699E9605.1.STATE heatingcontrol.0 2019-12-31 09:36:45.355 debug (6841) Check sensors for Küche heatingcontrol.0 2019-12-31 09:36:45.308 debug (6841) got sensor state {"val":0,"ack":true,"ts":1577784919740,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1577628013202} from hm-rpc.1.0000D56996187D.1.STATE heatingcontrol.0 2019-12-31 09:36:45.305 debug (6841) Check sensors for Badezimmer heatingcontrol.0 2019-12-31 09:36:45.296 debug (6841) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577705276875} from deconz.0.Sensors.23.open heatingcontrol.0 2019-12-31 09:36:45.293 debug (6841) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576925832752} from deconz.0.Sensors.11.open heatingcontrol.0 2019-12-31 09:36:45.259 debug (6841) Check sensors for Arbeitszimmer heatingcontrol.0 2019-12-31 09:36:45.257 debug (6841) [INFO] status = true next event: 4 Jan 2020 20:00:00 heatingcontrol.0 2019-12-31 09:36:45.256 debug (6841) [INFO] status = true next event: 4 Jan 2020 15:00:00 heatingcontrol.0 2019-12-31 09:36:45.253 debug (6841) [INFO] status = true next event: 4 Jan 2020 11:00:00 heatingcontrol.0 2019-12-31 09:36:45.252 debug (6841) [INFO] status = true next event: 4 Jan 2020 07:00:00 heatingcontrol.0 2019-12-31 09:36:45.251 debug (6841) [INFO] status = true next event: 4 Jan 2020 04:00:00 heatingcontrol.0 2019-12-31 09:36:45.251 debug (6841) [INFO] status = true next event: 31 Dec 2019 20:00:00 heatingcontrol.0 2019-12-31 09:36:45.250 debug (6841) [INFO] status = true next event: 31 Dec 2019 15:00:00 heatingcontrol.0 2019-12-31 09:36:45.250 debug (6841) [INFO] status = true next event: 31 Dec 2019 11:00:00 heatingcontrol.0 2019-12-31 09:36:45.247 debug (6841) [INFO] status = true next event: 1 Jan 2020 07:00:00 heatingcontrol.0 2019-12-31 09:36:45.246 debug (6841) [INFO] status = true next event: 1 Jan 2020 04:00:00 heatingcontrol.0 2019-12-31 09:36:45.231 debug (6841) create cron job #9 at 21:0 string: 0 0 21 * * 0,6 Europe/Berlin heatingcontrol.0 2019-12-31 09:36:45.228 debug (6841) create cron job #8 at 16:0 string: 0 0 16 * * 0,6 Europe/Berlin heatingcontrol.0 2019-12-31 09:36:45.226 debug (6841) create cron job #7 at 12:0 string: 0 0 12 * * 0,6 Europe/Berlin heatingcontrol.0 2019-12-31 09:36:45.220 debug (6841) create cron job #6 at 8:0 string: 0 0 8 * * 0,6 Europe/Berlin heatingcontrol.0 2019-12-31 09:36:45.216 debug (6841) create cron job #5 at 5:0 string: 0 0 5 * * 0,6 Europe/Berlin heatingcontrol.0 2019-12-31 09:36:45.214 debug (6841) create cron job #4 at 21:0 string: 0 0 21 * * 1-5 Europe/Berlin heatingcontrol.0 2019-12-31 09:36:45.213 debug (6841) create cron job #3 at 16:0 string: 0 0 16 * * 1-5 Europe/Berlin heatingcontrol.0 2019-12-31 09:36:45.211 debug (6841) create cron job #2 at 12:0 string: 0 0 12 * * 1-5 Europe/Berlin heatingcontrol.0 2019-12-31 09:36:45.203 debug (6841) create cron job #1 at 8:0 string: 0 0 8 * * 1-5 Europe/Berlin heatingcontrol.0 2019-12-31 09:36:45.186 debug (6841) create cron job #0 at 5:0 string: 0 0 5 * * 1-5 Europe/Berlin heatingcontrol.0 2019-12-31 09:36:45.185 debug (6841) ---2 found time for Wohnzimmer at {"val":"21:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 21:00 heatingcontrol.0 2019-12-31 09:36:45.183 debug (6841) ---2 found time for Wohnzimmer at {"val":"16:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 16:00 heatingcontrol.0 2019-12-31 09:36:45.182 debug (6841) ---2 found time for Wohnzimmer at {"val":"12:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 12:00 heatingcontrol.0 2019-12-31 09:36:45.180 debug (6841) ---2 found time for Wohnzimmer at {"val":"08:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 08:00 heatingcontrol.0 2019-12-31 09:36:45.178 debug (6841) ---2 found time for Wohnzimmer at {"val":"05:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 05:00 heatingcontrol.0 2019-12-31 09:36:45.175 debug (6841) setting Sa - Su heatingcontrol.0 2019-12-31 09:36:45.175 debug (6841) ---1 found time for Wohnzimmer at {"val":"21:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 21:00 heatingcontrol.0 2019-12-31 09:36:45.173 debug (6841) ---1 found time for Wohnzimmer at {"val":"16:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 16:00 heatingcontrol.0 2019-12-31 09:36:45.171 debug (6841) ---1 found time for Wohnzimmer at {"val":"12:00","ack":false,"ts":1577542409214,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1577542409214} 12:00 heatingcontrol.0 2019-12-31 09:36:45.169 debug (6841) ---1 found time for Wohnzimmer at {"val":"08:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 08:00 heatingcontrol.0 2019-12-31 09:36:45.168 debug (6841) ---1 found time for Wohnzimmer at {"val":"05:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 05:00 heatingcontrol.0 2019-12-31 09:36:45.165 debug (6841) setting Mo - Fr heatingcontrol.0 2019-12-31 09:36:45.165 debug (6841) ---2 found time for Küche at {"val":"21:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 21:00 heatingcontrol.0 2019-12-31 09:36:45.163 debug (6841) ---2 found time for Küche at {"val":"16:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 16:00 heatingcontrol.0 2019-12-31 09:36:45.162 debug (6841) ---2 found time for Küche at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00 heatingcontrol.0 2019-12-31 09:36:45.158 debug (6841) ---2 found time for Küche at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00 heatingcontrol.0 2019-12-31 09:36:45.156 debug (6841) ---2 found time for Küche at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00 heatingcontrol.0 2019-12-31 09:36:45.152 debug (6841) setting Sa - Su heatingcontrol.0 2019-12-31 09:36:45.152 debug (6841) ---1 found time for Küche at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00 heatingcontrol.0 2019-12-31 09:36:45.148 debug (6841) ---1 found time for Küche at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00 heatingcontrol.0 2019-12-31 09:36:45.144 debug (6841) ---1 found time for Küche at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00 heatingcontrol.0 2019-12-31 09:36:45.141 debug (6841) ---1 found time for Küche at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00 heatingcontrol.0 2019-12-31 09:36:45.139 debug (6841) ---1 found time for Küche at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00 heatingcontrol.0 2019-12-31 09:36:45.135 debug (6841) setting Mo - Fr heatingcontrol.0 2019-12-31 09:36:45.135 debug (6841) ---2 found time for Badezimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00 heatingcontrol.0 2019-12-31 09:36:45.132 debug (6841) ---2 found time for Badezimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00 heatingcontrol.0 2019-12-31 09:36:45.130 debug (6841) ---2 found time for Badezimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00 heatingcontrol.0 2019-12-31 09:36:45.128 debug (6841) ---2 found time for Badezimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00 heatingcontrol.0 2019-12-31 09:36:45.126 debug (6841) ---2 found time for Badezimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00 heatingcontrol.0 2019-12-31 09:36:45.101 debug (6841) setting Sa - Su heatingcontrol.0 2019-12-31 09:36:45.100 debug (6841) ---1 found time for Badezimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00 heatingcontrol.0 2019-12-31 09:36:45.099 debug (6841) ---1 found time for Badezimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00 heatingcontrol.0 2019-12-31 09:36:45.096 debug (6841) ---1 found time for Badezimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00 heatingcontrol.0 2019-12-31 09:36:45.095 debug (6841) ---1 found time for Badezimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00 heatingcontrol.0 2019-12-31 09:36:45.093 debug (6841) ---1 found time for Badezimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00 heatingcontrol.0 2019-12-31 09:36:45.089 debug (6841) setting Mo - Fr heatingcontrol.0 2019-12-31 09:36:45.089 debug (6841) push to list = 21,00 heatingcontrol.0 2019-12-31 09:36:45.089 debug (6841) ---2 found time for Arbeitszimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00 heatingcontrol.0 2019-12-31 09:36:45.085 debug (6841) push to list = 16,00 heatingcontrol.0 2019-12-31 09:36:45.085 debug (6841) ---2 found time for Arbeitszimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00 heatingcontrol.0 2019-12-31 09:36:45.082 debug (6841) push to list = 12,00 heatingcontrol.0 2019-12-31 09:36:45.082 debug (6841) ---2 found time for Arbeitszimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00 heatingcontrol.0 2019-12-31 09:36:45.072 debug (6841) push to list = 08,00 heatingcontrol.0 2019-12-31 09:36:45.072 debug (6841) ---2 found time for Arbeitszimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00 heatingcontrol.0 2019-12-31 09:36:45.069 debug (6841) push to list = 05,00 heatingcontrol.0 2019-12-31 09:36:45.068 debug (6841) ---2 found time for Arbeitszimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00 heatingcontrol.0 2019-12-31 09:36:45.063 debug (6841) setting Sa - Su heatingcontrol.0 2019-12-31 09:36:45.062 debug (6841) push to list = 21,00 heatingcontrol.0 2019-12-31 09:36:45.061 debug (6841) ---1 found time for Arbeitszimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00 heatingcontrol.0 2019-12-31 09:36:45.057 debug (6841) push to list = 16,00 heatingcontrol.0 2019-12-31 09:36:45.057 debug (6841) ---1 found time for Arbeitszimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00 heatingcontrol.0 2019-12-31 09:36:45.051 debug (6841) push to list = 12,00 heatingcontrol.0 2019-12-31 09:36:45.051 debug (6841) ---1 found time for Arbeitszimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00 heatingcontrol.0 2019-12-31 09:36:45.043 debug (6841) push to list = 08,00 heatingcontrol.0 2019-12-31 09:36:45.042 debug (6841) ---1 found time for Arbeitszimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00 heatingcontrol.0 2019-12-31 09:36:45.029 debug (6841) push to list = 05,00 heatingcontrol.0 2019-12-31 09:36:45.027 debug (6841) ---1 found time for Arbeitszimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00 heatingcontrol.0 2019-12-31 09:36:45.017 debug (6841) setting Mo - Fr heatingcontrol.0 2019-12-31 09:36:45.015 debug (6841) profile 0 heatingcontrol.0 2019-12-31 09:36:45.000 debug (6841) get profile heatingcontrol.0 2019-12-31 09:36:45.000 debug (6841) start CalculateNextTime, profile type 2 heatingcontrol.0 2019-12-31 09:36:44.998 debug (6841) system date format DD.MM.YYYY heatingcontrol.0 2019-12-31 09:36:44.968 debug (6841) CreateDatepoints done heatingcontrol.0 2019-12-31 09:36:44.968 debug (6841) not active.... Kinderzimmer heatingcontrol.0 2019-12-31 09:36:44.968 debug (6841) not active.... Schlafzimmer heatingcontrol.0 2019-12-31 09:36:44.968 debug (6841) add state Profiles.0.Wohnzimmer.Sa-So.Periods.4 max 5 heatingcontrol.0 2019-12-31 09:36:44.967 debug (6841) add state Profiles.0.Wohnzimmer.Sa-So.Periods.3 max 5 heatingcontrol.0 2019-12-31 09:36:44.966 debug (6841) add state Profiles.0.Wohnzimmer.Sa-So.Periods.2 max 5 heatingcontrol.0 2019-12-31 09:36:44.966 debug (6841) add state Profiles.0.Wohnzimmer.Sa-So.Periods.1 max 5 heatingcontrol.0 2019-12-31 09:36:44.966 debug (6841) add state Profiles.0.Wohnzimmer.Sa-So.Periods.0 max 5 heatingcontrol.0 2019-12-31 09:36:44.965 debug (6841) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.4 max 5 heatingcontrol.0 2019-12-31 09:36:44.965 debug (6841) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.3 max 5 heatingcontrol.0 2019-12-31 09:36:44.965 debug (6841) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.2 max 5 heatingcontrol.0 2019-12-31 09:36:44.964 debug (6841) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.1 max 5 heatingcontrol.0 2019-12-31 09:36:44.964 debug (6841) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.0 max 5 heatingcontrol.0 2019-12-31 09:36:44.964 debug (6841) Profile Type Mo-FR + Sa-So, profiles 1 heatingcontrol.0 2019-12-31 09:36:44.963 debug (6841) room Wohnzimmer with 5 periods heatingcontrol.0 2019-12-31 09:36:44.904 debug (6841) create data profile points (absolute) for Wohnzimmer heatingcontrol.0 2019-12-31 09:36:44.903 debug (6841) add state Profiles.0.Küche.Sa-So.Periods.4 max 5 heatingcontrol.0 2019-12-31 09:36:44.900 debug (6841) add state Profiles.0.Küche.Sa-So.Periods.3 max 5 heatingcontrol.0 2019-12-31 09:36:44.900 debug (6841) add state Profiles.0.Küche.Sa-So.Periods.2 max 5 heatingcontrol.0 2019-12-31 09:36:44.900 debug (6841) add state Profiles.0.Küche.Sa-So.Periods.1 max 5 heatingcontrol.0 2019-12-31 09:36:44.899 debug (6841) add state Profiles.0.Küche.Sa-So.Periods.0 max 5 heatingcontrol.0 2019-12-31 09:36:44.899 debug (6841) add state Profiles.0.Küche.Mo-Fr.Periods.4 max 5 heatingcontrol.0 2019-12-31 09:36:44.897 debug (6841) add state Profiles.0.Küche.Mo-Fr.Periods.3 max 5 heatingcontrol.0 2019-12-31 09:36:44.897 debug (6841) add state Profiles.0.Küche.Mo-Fr.Periods.2 max 5 heatingcontrol.0 2019-12-31 09:36:44.896 debug (6841) add state Profiles.0.Küche.Mo-Fr.Periods.1 max 5 heatingcontrol.0 2019-12-31 09:36:44.896 debug (6841) add state Profiles.0.Küche.Mo-Fr.Periods.0 max 5 heatingcontrol.0 2019-12-31 09:36:44.896 debug (6841) Profile Type Mo-FR + Sa-So, profiles 1 heatingcontrol.0 2019-12-31 09:36:44.895 debug (6841) room Küche with 5 periods heatingcontrol.0 2019-12-31 09:36:44.839 debug (6841) create data profile points (absolute) for Küche heatingcontrol.0 2019-12-31 09:36:44.838 debug (6841) add state Profiles.0.Badezimmer.Sa-So.Periods.4 max 5 heatingcontrol.0 2019-12-31 09:36:44.837 debug (6841) add state Profiles.0.Badezimmer.Sa-So.Periods.3 max 5 heatingcontrol.0 2019-12-31 09:36:44.835 debug (6841) add state Profiles.0.Badezimmer.Sa-So.Periods.2 max 5 heatingcontrol.0 2019-12-31 09:36:44.833 debug (6841) add state Profiles.0.Badezimmer.Sa-So.Periods.1 max 5 heatingcontrol.0 2019-12-31 09:36:44.833 debug (6841) add state Profiles.0.Badezimmer.Sa-So.Periods.0 max 5 heatingcontrol.0 2019-12-31 09:36:44.833 debug (6841) add state Profiles.0.Badezimmer.Mo-Fr.Periods.4 max 5 heatingcontrol.0 2019-12-31 09:36:44.832 debug (6841) add state Profiles.0.Badezimmer.Mo-Fr.Periods.3 max 5 heatingcontrol.0 2019-12-31 09:36:44.832 debug (6841) add state Profiles.0.Badezimmer.Mo-Fr.Periods.2 max 5 heatingcontrol.0 2019-12-31 09:36:44.832 debug (6841) add state Profiles.0.Badezimmer.Mo-Fr.Periods.1 max 5 heatingcontrol.0 2019-12-31 09:36:44.831 debug (6841) add state Profiles.0.Badezimmer.Mo-Fr.Periods.0 max 5 heatingcontrol.0 2019-12-31 09:36:44.831 debug (6841) Profile Type Mo-FR + Sa-So, profiles 1 heatingcontrol.0 2019-12-31 09:36:44.831 debug (6841) room Badezimmer with 5 periods heatingcontrol.0 2019-12-31 09:36:44.671 debug (6841) create data profile points (absolute) for Badezimmer heatingcontrol.0 2019-12-31 09:36:44.671 debug (6841) add state Profiles.0.Arbeitszimmer.Sa-So.Periods.4 max 5 heatingcontrol.0 2019-12-31 09:36:44.670 debug (6841) add state Profiles.0.Arbeitszimmer.Sa-So.Periods.3 max 5 heatingcontrol.0 2019-12-31 09:36:44.670 debug (6841) add state Profiles.0.Arbeitszimmer.Sa-So.Periods.2 max 5 heatingcontrol.0 2019-12-31 09:36:44.670 debug (6841) add state Profiles.0.Arbeitszimmer.Sa-So.Periods.1 max 5 heatingcontrol.0 2019-12-31 09:36:44.670 debug (6841) add state Profiles.0.Arbeitszimmer.Sa-So.Periods.0 max 5 heatingcontrol.0 2019-12-31 09:36:44.669 debug (6841) add state Profiles.0.Arbeitszimmer.Mo-Fr.Periods.4 max 5 heatingcontrol.0 2019-12-31 09:36:44.669 debug (6841) add state Profiles.0.Arbeitszimmer.Mo-Fr.Periods.3 max 5 heatingcontrol.0 2019-12-31 09:36:44.669 debug (6841) add state Profiles.0.Arbeitszimmer.Mo-Fr.Periods.2 max 5 heatingcontrol.0 2019-12-31 09:36:44.668 debug (6841) add state Profiles.0.Arbeitszimmer.Mo-Fr.Periods.1 max 5 heatingcontrol.0 2019-12-31 09:36:44.667 debug (6841) add state Profiles.0.Arbeitszimmer.Mo-Fr.Periods.0 max 5 heatingcontrol.0 2019-12-31 09:36:44.667 debug (6841) Profile Type Mo-FR + Sa-So, profiles 1 heatingcontrol.0 2019-12-31 09:36:44.667 debug (6841) room Arbeitszimmer with 5 periods heatingcontrol.0 2019-12-31 09:36:44.616 debug (6841) create data profile points (absolute) for Arbeitszimmer heatingcontrol.0 2019-12-31 09:36:44.616 debug (6841) rooms 6 heatingcontrol.0 2019-12-31 09:36:44.608 debug (6841) create data points for Wohnzimmer heatingcontrol.0 2019-12-31 09:36:44.601 debug (6841) create data points for Küche heatingcontrol.0 2019-12-31 09:36:44.593 debug (6841) create data points for Badezimmer heatingcontrol.0 2019-12-31 09:36:44.586 debug (6841) create data points for Arbeitszimmer heatingcontrol.0 2019-12-31 09:36:44.455 debug (6841) start CreateDatepoints heatingcontrol.0 2019-12-31 09:36:44.454 debug (6841) devices [{"id":1,"name":"","OID_Target":"","isActive":false,"type":2,"room":"Arbeitszimmer"},{"id":2,"name":"Fenster- / Türkontaktsensor (2) open","OID_Current":"deconz.0.Sensors.11.open","isA heatingcontrol.0 2019-12-31 09:36:44.430 info (6841) starting. Version 0.3.14 in /opt/iobroker/node_modules/iobroker.heatingcontrol, node: v10.17.0 heatingcontrol.0 2019-12-31 09:36:44.053 debug (6841) States connected to redis: 127.0.0.1:9000 heatingcontrol.0 2019-12-31 09:36:44.032 debug (6841) statesDB connected heatingcontrol.0 2019-12-31 09:36:44.031 debug (6841) States create PubSub Client heatingcontrol.0 2019-12-31 09:36:44.027 debug (6841) Objects connected to redis: 127.0.0.1:9001 heatingcontrol.0 2019-12-31 09:36:44.026 debug (6841) Redis States: Use Redis connection: 127.0.0.1:9000 heatingcontrol.0 2019-12-31 09:36:44.024 debug (6841) objectDB connected heatingcontrol.0 2019-12-31 09:36:44.015 debug (6841) Objects client initialize lua scripts heatingcontrol.0 2019-12-31 09:36:44.014 debug (6841) Objects create PubSub Client heatingcontrol.0 2019-12-31 09:36:44.012 debug (6841) Objects client ready ... initialize now heatingcontrol.0 2019-12-31 09:36:43.992 debug (6841) Redis Objects: Use Redis connection: 127.0.0.1:9001 heatingcontrol.0 2019-12-31 09:36:41.084 info (4045) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason heatingcontrol.0 2019-12-31 09:36:41.084 info (4045) terminating heatingcontrol.0 2019-12-31 09:36:41.084 debug (4045) cron job stopped heatingcontrol.0 2019-12-31 09:36:41.084 debug (4045) cron job stopped heatingcontrol.0 2019-12-31 09:36:41.084 debug (4045) cron job stopped -
@martinschm said in Test Adapter HeatingControl v0.3.x:
@Rene_HM said in Test Adapter HeatingControl v0.3.x:
@martinschm bzgl. des logs mit dem Fenstersensor.
Eigentlich sieht das log wie erwartet aus:- um 23:08:13 wird erkannt, dass ein Fenster offen ist
- um 23:08:30 wird erkannt, dass alle 4 Fenster wieder zu sind
Trotzdem läuft er in beiden Fällen in den Abwesenheits-Zweig, was im ersten Fall nicht sein sollte. Im ersten Fall sollte er in den FensterAuf-Modus laufen... Deshalb folgende Fragen:
- welche Absenkung fährst du (relative oder absolut)?
- ist das Verhalten anders, wenn du mihome.0.devices.magnet_158d0001de8c5e öffnest? Das ist der letzte Sensor, der für den Raum geprüft wird...
- wird im Datenpunkt heatingcontrol.0.Rooms.Schlafzimmer.WindowIsOpen angezeigt, dass ein Fenster offen ist?
- SensorDelay verwendest du nicht?
ich verwende
- absolute Absenkung.
- SensorDelay ist 0
- WindowisOpen wird angezeigt als true
- der magnet_158d0001de8c5e ist der SZ Mitte, Log hab ich unten angehängt. Funktioniert leider auch nicht.
2019-12-30 19:43:48.075 - [32minfo[39m: heatingcontrol.0 (8950) Schlafzimmer window open on SZ Mitte 2019-12-30 19:43:48.076 - [34mdebug[39m: heatingcontrol.0 (8950) room to check is Schlafzimmer 2019-12-30 19:43:48.077 - [32minfo[39m: heatingcontrol.0 (8950) calculating new target temperatures 2019-12-30 19:43:48.077 - [34mdebug[39m: heatingcontrol.0 (8950) ### 222 not handled yet 2019-12-30 19:43:48.077 - [34mdebug[39m: heatingcontrol.0 (8950) ### not handled mihome.0.devices.magnet_158d0001de8c5e.state {"val":true,"ack":true,"ts":1577731428070,"q":0,"from":"system.adapter.mihome.0","user":"system.user.admin","lc":1577731428070} 2019-12-30 19:43:48.080 - [34mdebug[39m: heatingcontrol.0 (8950) profile type 2 2019-12-30 19:43:48.080 - [34mdebug[39m: heatingcontrol.0 (8950) get profile 2019-12-30 19:43:48.081 - [34mdebug[39m: heatingcontrol.0 (8950) profile 0 2019-12-30 19:43:48.081 - [34mdebug[39m: heatingcontrol.0 (8950) check room Schlafzimmer 2019-12-30 19:43:48.081 - [34mdebug[39m: heatingcontrol.0 (8950) VacationAbsentDecrease {"val":0,"ack":true,"ts":1576691313966,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1576691313966} 2019-12-30 19:43:48.082 - [34mdebug[39m: heatingcontrol.0 (8950) number of periods 4 2019-12-30 19:43:48.082 - [34mdebug[39m: heatingcontrol.0 (8950) check ID Profiles.0.Schlafzimmer.Sa-So.Periods.0.time 2019-12-30 19:43:48.083 - [34mdebug[39m: heatingcontrol.0 (8950) check time for Schlafzimmer Profiles.0.Schlafzimmer.Sa-So.Periods.0.time 19 2019-12-30 19:43:48.083 - [34mdebug[39m: heatingcontrol.0 (8950) check ID Profiles.0.Schlafzimmer.Sa-So.Periods.1.time 2019-12-30 19:43:48.083 - [34mdebug[39m: heatingcontrol.0 (8950) check ID Profiles.0.Schlafzimmer.Sa-So.Periods.2.time 2019-12-30 19:43:48.084 - [34mdebug[39m: heatingcontrol.0 (8950) check ID Profiles.0.Schlafzimmer.Sa-So.Periods.3.time 2019-12-30 19:43:48.084 - [34mdebug[39m: heatingcontrol.0 (8950) ### current > 1 0 2 2019-12-30 19:43:48.085 - [34mdebug[39m: heatingcontrol.0 (8950) ### new target temp19 2019-12-30 19:43:48.085 - [32minfo[39m: heatingcontrol.0 (8950) room Schlafzimmer Thermostat HM-CC-RT-DN OEQ1733333 set to 19 2019-12-30 19:43:48.085 - [34mdebug[39m: heatingcontrol.0 (8950) thermostat hm-rpc.0.OEQ1733333.4.SET_TEMPERATURE nothing to do, already 19 2019-12-30 19:43:48.089 - [33mwarn[39m: heatingcontrol.0 (8950) HandleActorsGeneral: not implemented yet 2019-12-30 19:43:48.090 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 31 Dec 2019 09:00:00 2019-12-30 19:43:48.091 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 30 Dec 2019 21:00:00 2019-12-30 19:43:48.092 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 30 Dec 2019 21:15:00 2019-12-30 19:43:48.094 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 30 Dec 2019 21:30:00 2019-12-30 19:43:48.095 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 4 Jan 2020 09:00:00 2019-12-30 19:43:48.096 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 4 Jan 2020 21:00:00 2019-12-30 19:43:48.101 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 4 Jan 2020 21:15:00 2019-12-30 19:43:48.103 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 4 Jan 2020 21:30:00 2019-12-30 19:43:48.104 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 31 Dec 2019 08:00:00 2019-12-30 19:43:48.106 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 31 Dec 2019 14:20:00 2019-12-30 19:43:48.107 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 31 Dec 2019 18:00:00 2019-12-30 19:43:48.108 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 4 Jan 2020 08:00:00 2019-12-30 19:43:48.109 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 4 Jan 2020 18:00:00 2019-12-30 19:43:48.112 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 4 Jan 2020 18:30:00 2019-12-30 19:43:48.113 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 4 Jan 2020 19:00:00 2019-12-30 19:43:48.114 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 31 Dec 2019 00:00:00 2019-12-30 19:43:48.115 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 31 Dec 2019 12:00:00 2019-12-30 19:43:48.116 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 31 Dec 2019 16:00:00 2019-12-30 19:43:48.117 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 4 Jan 2020 05:00:00 2019-12-30 19:43:48.117 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 4 Jan 2020 12:00:00 2019-12-30 19:43:48.119 - [34mdebug[39m: heatingcontrol.0 (8950) [INFO] status = true next event: 4 Jan 2020 16:00:00 2019-12-30 19:44:08.370 - [34mdebug[39m: heatingcontrol.0 (8950) ### handle state change hm-rpc.0.OEQ1711111.4.ACTUAL_TEMPERATURE {"val":20.9,"ack":true,"ts":1577731448369,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1577731448369} 2019-12-30 19:44:08.370 - [34mdebug[39m: heatingcontrol.0 (8950) ### hm-rpc.0.OEQ1711111.4.ACTUAL_TEMPERATURE mihome.0.devices.magnet_158d0001de8c5e.state 20.9 true 2019-12-30 19:44:08.371 - [34mdebug[39m: heatingcontrol.0 (8950) ### handle state change hm-rpc.0.OEQ1711111.4.SET_TEMPERATURE {"val":16,"ack":true,"ts":1577731448369,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1577705436500} 2019-12-30 19:44:08.371 - [34mdebug[39m: heatingcontrol.0 (8950) ### hm-rpc.0.OEQ1711111.4.SET_TEMPERATURE hm-rpc.0.OEQ1711111.4.ACTUAL_TEMPERATURE 16 20.9 2019-12-30 19:44:08.371 - [34mdebug[39m: heatingcontrol.0 (8950) ### 111 not handled yet 2019-12-30 19:44:08.371 - [34mdebug[39m: heatingcontrol.0 (8950) handle id hm-rpc.0.OEQ1711111.4.ACTUAL_TEMPERATURE state {"val":20.9,"ack":true,"ts":1577731448369,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1577731448369} 2019-12-30 19:44:08.371 - [34mdebug[39m: heatingcontrol.0 (8950) ### handle devices [{"id":12,"name":"HM-CC-RT-DN OEQ1711111","OID_Current":"hm-rpc.0.OEQ1711111.4.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ1711111.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"Kinderschlafzimmer"}] 2019-12-30 19:44:08.371 - [34mdebug[39m: heatingcontrol.0 (8950) ### 111 not handled yetDie Absenkung scheint auch in den anderen Räumen nicht zu funktionieren. Habe es grade mal in einem anderen Zimmer versucht.
@Rene_HM kannst du hier auch nochmal kurz schauen, ist evtl untergegangen. Leider funktioniert grade gar keine Absenkung bei Fenster offen
Das bekommen wir schon hin...
Zuerst müssen wir das hier beseitigen:exception in main [invalid id ""]Ich denke, du hast irgendeinen Aktor falsch konfiguriert. Erste Frage: benötigst du überhaupt Aktoren? Aktoren sind eigentlich ein Sonderfall hier... Wenn nicht, dann schalte UseActors im admin aus...
@martinschm sagte in Test Adapter HeatingControl v0.3.x:
nein, das habe ich noch auf dem Schirm. Ich verstehe hier leider nur noch nicht, was hier schief läuft. Da bin ich noch am suchen...
Welche Version vom adapter läuft eigentlich bei dir? -
@Rene_HM so jetzt sieht der debug nach Neustart so aus.
heatingcontrol.0 2019-12-31 11:19:45.513 debug (4204) #subscribtion finished heatingcontrol.0 2019-12-31 11:19:45.513 info (4204) subscribe Küche deconz.0.Sensors.24.open heatingcontrol.0 2019-12-31 11:19:45.512 info (4204) subscribe Küche hm-rpc.1.0007D5699E9605.1.STATE heatingcontrol.0 2019-12-31 11:19:45.512 info (4204) subscribe Wohnzimmer deconz.0.Sensors.21.open heatingcontrol.0 2019-12-31 11:19:45.511 info (4204) subscribe Wohnzimmer deconz.0.Sensors.20.open heatingcontrol.0 2019-12-31 11:19:45.511 info (4204) subscribe Wohnzimmer deconz.0.Sensors.19.open heatingcontrol.0 2019-12-31 11:19:45.510 info (4204) subscribe Wohnzimmer deconz.0.Sensors.18.open heatingcontrol.0 2019-12-31 11:19:45.510 info (4204) subscribe Wohnzimmer deconz.0.Sensors.17.open heatingcontrol.0 2019-12-31 11:19:45.509 info (4204) subscribe Wohnzimmer deconz.0.Sensors.16.open heatingcontrol.0 2019-12-31 11:19:45.509 info (4204) subscribe Wohnzimmer deconz.0.Sensors.15.open heatingcontrol.0 2019-12-31 11:19:45.508 info (4204) subscribe Badezimmer hm-rpc.1.0000D56996187D.1.STATE heatingcontrol.0 2019-12-31 11:19:45.507 info (4204) subscribe Arbeitszimmer deconz.0.Sensors.23.open heatingcontrol.0 2019-12-31 11:19:45.507 info (4204) subscribe Arbeitszimmer deconz.0.Sensors.11.open heatingcontrol.0 2019-12-31 11:19:45.507 debug (4204) device not active heatingcontrol.0 2019-12-31 11:19:45.506 debug (4204) no subscribe Path2PartyNowDP heatingcontrol.0 2019-12-31 11:19:45.506 debug (4204) no subscribe Path2GuestsPresentDP heatingcontrol.0 2019-12-31 11:19:45.506 debug (4204) no subscribe Path2HolidayPresentDP heatingcontrol.0 2019-12-31 11:19:45.506 debug (4204) no subscribe Path2VacationDP heatingcontrol.0 2019-12-31 11:19:45.506 info (4204) subscribe javascript.0.scriptEnabled.Anwesenheit.An_Abwesenheit heatingcontrol.0 2019-12-31 11:19:45.505 info (4204) subscribe feiertage.0.heute.boolean heatingcontrol.0 2019-12-31 11:19:45.498 debug (4204) #start subscribtion heatingcontrol.0 2019-12-31 11:19:45.497 debug (4204) [INFO] status = true next event: 4 Jan 2020 20:00:00 heatingcontrol.0 2019-12-31 11:19:45.477 debug (4204) [INFO] status = true next event: 4 Jan 2020 15:00:00 heatingcontrol.0 2019-12-31 11:19:45.476 debug (4204) [INFO] status = true next event: 4 Jan 2020 11:00:00 heatingcontrol.0 2019-12-31 11:19:45.475 debug (4204) [INFO] status = true next event: 4 Jan 2020 07:00:00 heatingcontrol.0 2019-12-31 11:19:45.472 debug (4204) [INFO] status = true next event: 4 Jan 2020 04:00:00 heatingcontrol.0 2019-12-31 11:19:45.470 debug (4204) [INFO] status = true next event: 31 Dec 2019 20:00:00 heatingcontrol.0 2019-12-31 11:19:45.469 debug (4204) [INFO] status = true next event: 31 Dec 2019 15:00:00 heatingcontrol.0 2019-12-31 11:19:45.469 debug (4204) [INFO] status = true next event: 31 Dec 2019 11:00:00 heatingcontrol.0 2019-12-31 11:19:45.468 debug (4204) [INFO] status = true next event: 1 Jan 2020 07:00:00 heatingcontrol.0 2019-12-31 11:19:45.465 debug (4204) [INFO] status = true next event: 1 Jan 2020 04:00:00 heatingcontrol.0 2019-12-31 11:19:45.448 debug (4204) thermostat hm-rpc.1.000A97099C1E52.1.SET_POINT_TEMPERATURE nothing to do, already 21 heatingcontrol.0 2019-12-31 11:19:45.440 info (4204) room Wohnzimmer Thermostat Fußbodenheizung Wohnzimmer.SET_POINT_TEMPERATURE target is 21 heatingcontrol.0 2019-12-31 11:19:45.440 debug (4204) ### new target temp21 heatingcontrol.0 2019-12-31 11:19:45.440 debug (4204) ### current > 1 1 2 heatingcontrol.0 2019-12-31 11:19:45.439 debug (4204) Wohnzimmer found period 1 with 21 on 08,00 heatingcontrol.0 2019-12-31 11:19:45.437 debug (4204) check ID Profiles.0.Wohnzimmer.Sa-So.Periods.4.time heatingcontrol.0 2019-12-31 11:19:45.432 debug (4204) check ID Profiles.0.Wohnzimmer.Sa-So.Periods.3.time heatingcontrol.0 2019-12-31 11:19:45.427 debug (4204) check ID Profiles.0.Wohnzimmer.Sa-So.Periods.2.time heatingcontrol.0 2019-12-31 11:19:45.427 debug (4204) check time for Wohnzimmer Profiles.0.Wohnzimmer.Sa-So.Periods.1.time 21 heatingcontrol.0 2019-12-31 11:19:45.421 debug (4204) check ID Profiles.0.Wohnzimmer.Sa-So.Periods.1.time heatingcontrol.0 2019-12-31 11:19:45.421 debug (4204) check time for Wohnzimmer Profiles.0.Wohnzimmer.Sa-So.Periods.0.time 17 heatingcontrol.0 2019-12-31 11:19:45.417 debug (4204) check ID Profiles.0.Wohnzimmer.Sa-So.Periods.0.time heatingcontrol.0 2019-12-31 11:19:45.416 debug (4204) FindNextPeriod for 12/31/2019, 10:19:45 AM in Wohnzimmer heatingcontrol.0 2019-12-31 11:19:45.415 debug (4204) check room Wohnzimmer heatingcontrol.0 2019-12-31 11:19:45.363 debug (4204) thermostat hm-rpc.1.000A17098D4CEA.1.SET_POINT_TEMPERATURE nothing to do, already 21 heatingcontrol.0 2019-12-31 11:19:45.359 info (4204) room Küche Thermostat Heizung Küche.SET_POINT_TEMPERATURE target is 21 heatingcontrol.0 2019-12-31 11:19:45.358 debug (4204) ### new target temp21 heatingcontrol.0 2019-12-31 11:19:45.358 debug (4204) ### current > 1 1 2 heatingcontrol.0 2019-12-31 11:19:45.358 debug (4204) Küche found period 1 with 21 on 08,00 heatingcontrol.0 2019-12-31 11:19:45.356 debug (4204) check ID Profiles.0.Küche.Sa-So.Periods.4.time heatingcontrol.0 2019-12-31 11:19:45.355 debug (4204) check ID Profiles.0.Küche.Sa-So.Periods.3.time heatingcontrol.0 2019-12-31 11:19:45.352 debug (4204) check ID Profiles.0.Küche.Sa-So.Periods.2.time heatingcontrol.0 2019-12-31 11:19:45.352 debug (4204) check time for Küche Profiles.0.Küche.Sa-So.Periods.1.time 21 heatingcontrol.0 2019-12-31 11:19:45.340 debug (4204) check ID Profiles.0.Küche.Sa-So.Periods.1.time heatingcontrol.0 2019-12-31 11:19:45.340 debug (4204) check time for Küche Profiles.0.Küche.Sa-So.Periods.0.time 17 heatingcontrol.0 2019-12-31 11:19:45.335 debug (4204) check ID Profiles.0.Küche.Sa-So.Periods.0.time heatingcontrol.0 2019-12-31 11:19:45.335 debug (4204) FindNextPeriod for 12/31/2019, 10:19:45 AM in Küche heatingcontrol.0 2019-12-31 11:19:45.334 debug (4204) check room Küche heatingcontrol.0 2019-12-31 10:19:45.287 debug 2 heatingcontrol.0 2019-12-31 10:19:45.287 debug (4204) check ID Profiles.0.Arbeitszimmer.Sa-So.Periods.4.time heatingcontrol.0 2019-12-31 10:19:45.283 debug (4204) check ID Profiles.0.Arbeitszimmer.Sa-So.Periods.3.time heatingcontrol.0 2019-12-31 10:19:45.281 debug (4204) check ID Profiles.0.Arbeitszimmer.Sa-So.Periods.2.time heatingcontrol.0 2019-12-31 10:19:45.280 debug (4204) check time for Arbeitszimmer Profiles.0.Arbeitszimmer.Sa-So.Periods.1.time 21 heatingcontrol.0 2019-12-31 10:19:45.278 debug (4204) check ID Profiles.0.Arbeitszimmer.Sa-So.Periods.1.time heatingcontrol.0 2019-12-31 10:19:45.276 debug (4204) check time for Arbeitszimmer Profiles.0.Arbeitszimmer.Sa-So.Periods.0.time 17 heatingcontrol.0 2019-12-31 10:19:45.269 debug (4204) check ID Profiles.0.Arbeitszimmer.Sa-So.Periods.0.time heatingcontrol.0 2019-12-31 10:19:45.269 debug (4204) FindNextPeriod for 12/31/2019, 10:19:45 AM in Arbeitszimmer heatingcontrol.0 2019-12-31 10:19:45.262 debug (4204) check room Arbeitszimmer heatingcontrol.0 2019-12-31 10:19:45.262 debug (4204) profile 0 heatingcontrol.0 2019-12-31 10:19:45.260 debug (4204) get profile heatingcontrol.0 2019-12-31 10:19:45.260 debug (4204) profile type 2 heatingcontrol.0 2019-12-31 10:19:45.252 info (4204) calculating new target temperatures heatingcontrol.0 2019-12-31 10:19:45.251 info (4204) external states checked, done heatingcontrol.0 2019-12-31 10:19:45.249 debug (4204) checking Path2HolidayPresentDP heatingcontrol.0 2019-12-31 10:19:45.248 debug (4204) checking Path2PartyNowDP heatingcontrol.0 2019-12-31 10:19:45.245 debug (4204) checking Path2GuestsPresentDP heatingcontrol.0 2019-12-31 10:19:45.244 debug (4204) checking Path2VacationDP heatingcontrol.0 2019-12-31 10:19:45.240 info (4204) setting Present to true heatingcontrol.0 2019-12-31 10:19:45.239 debug (4204) got Present (1) {"val":true,"ack":true,"ts":1577726419908,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1577726419858} heatingcontrol.0 2019-12-31 10:19:45.237 debug (4204) checking Path2PresentDP heatingcontrol.0 2019-12-31 10:19:45.232 info (4204) setting PublicHolidyToday to true heatingcontrol.0 2019-12-31 10:19:45.229 debug (4204) checking Path2FeiertagAdapter heatingcontrol.0 2019-12-31 10:19:45.228 info (4204) checking all external states heatingcontrol.0 2019-12-31 10:19:45.223 debug (4204) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933362844} from deconz.0.Sensors.21.open heatingcontrol.0 2019-12-31 10:19:45.220 debug (4204) got sensor state {"val":false,"ack":true,"ts":1577717574989,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577638441163} from deconz.0.Sensors.20.open heatingcontrol.0 2019-12-31 10:19:45.217 debug (4204) got sensor state {"val":false,"ack":true,"ts":1577717574989,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933207327} from deconz.0.Sensors.19.open heatingcontrol.0 2019-12-31 10:19:45.210 debug (4204) got sensor state {"val":false,"ack":true,"ts":1577717574987,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933122635} from deconz.0.Sensors.18.open heatingcontrol.0 2019-12-31 10:19:45.209 debug (4204) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933025797} from deconz.0.Sensors.17.open heatingcontrol.0 2019-12-31 10:19:45.205 debug (4204) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576932905933} from deconz.0.Sensors.16.open heatingcontrol.0 2019-12-31 10:19:45.203 debug (4204) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577007719646} from deconz.0.Sensors.15.open heatingcontrol.0 2019-12-31 10:19:45.201 debug (4204) Check sensors for Wohnzimmer heatingcontrol.0 2019-12-31 10:19:45.196 debug (4204) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577644284922} from deconz.0.Sensors.24.open heatingcontrol.0 2019-12-31 10:19:45.195 debug (4204) got sensor state {"val":0,"ack":true,"ts":1577786742689,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1577786742689} from hm-rpc.1.0007D5699E9605.1.STATE heatingcontrol.0 2019-12-31 10:19:45.192 debug (4204) Check sensors for Küche heatingcontrol.0 2019-12-31 10:19:45.186 debug (4204) got sensor state {"val":0,"ack":true,"ts":1577785259127,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1577628013202} from hm-rpc.1.0000D56996187D.1.STATE heatingcontrol.0 2019-12-31 10:19:45.184 debug (4204) Check sensors for Badezimmer heatingcontrol.0 2019-12-31 10:19:45.179 debug (4204) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577705276875} from deconz.0.Sensors.23.open heatingcontrol.0 2019-12-31 10:19:45.176 debug (4204) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576925832752} from deconz.0.Sensors.11.open heatingcontrol.0 2019-12-31 10:19:45.157 debug (4204) Check sensors for Arbeitszimmer heatingcontrol.0 2019-12-31 10:19:45.156 debug (4204) [INFO] status = true next event: 4 Jan 2020 20:00:00 heatingcontrol.0 2019-12-31 10:19:45.155 debug (4204) [INFO] status = true next event: 4 Jan 2020 15:00:00 heatingcontrol.0 2019-12-31 10:19:45.154 debug (4204) [INFO] status = true next event: 4 Jan 2020 11:00:00 heatingcontrol.0 2019-12-31 10:19:45.153 debug (4204) [INFO] status = true next event: 4 Jan 2020 07:00:00 heatingcontrol.0 2019-12-31 10:19:45.152 debug (4204) [INFO] status = true next event: 4 Jan 2020 04:00:00 heatingcontrol.0 2019-12-31 10:19:45.151 debug (4204) [INFO] status = true next event: 31 Dec 2019 20:00:00 heatingcontrol.0 2019-12-31 10:19:45.151 debug (4204) [INFO] status = true next event: 31 Dec 2019 15:00:00 heatingcontrol.0 2019-12-31 10:19:45.150 debug (4204) [INFO] status = true next event: 31 Dec 2019 11:00:00 heatingcontrol.0 2019-12-31 10:19:45.150 debug (4204) [INFO] status = true next event: 1 Jan 2020 07:00:00 heatingcontrol.0 2019-12-31 10:19:45.147 debug (4204) [INFO] status = true next event: 1 Jan 2020 04:00:00 heatingcontrol.0 2019-12-31 10:19:45.134 debug (4204) create cron job #9 at 21:0 string: 0 0 21 * * 0,6 Europe/Berlin heatingcontrol.0 2019-12-31 10:19:45.132 debug (4204) create cron job #8 at 16:0 string: 0 0 16 * * 0,6 Europe/Berlin heatingcontrol.0 2019-12-31 10:19:45.129 debug (4204) create cron job #7 at 12:0 string: 0 0 12 * * 0,6 Europe/Berlin heatingcontrol.0 2019-12-31 10:19:45.127 debug (4204) create cron job #6 at 8:0 string: 0 0 8 * * 0,6 Europe/Berlin heatingcontrol.0 2019-12-31 10:19:45.120 debug (4204) create cron job #5 at 5:0 string: 0 0 5 * * 0,6 Europe/Berlin heatingcontrol.0 2019-12-31 10:19:45.117 debug (4204) create cron job #4 at 21:0 string: 0 0 21 * * 1-5 Europe/Berlin heatingcontrol.0 2019-12-31 10:19:45.115 debug (4204) create cron job #3 at 16:0 string: 0 0 16 * * 1-5 Europe/Berlin heatingcontrol.0 2019-12-31 10:19:45.110 debug (4204) create cron job #2 at 12:0 string: 0 0 12 * * 1-5 Europe/Berlin heatingcontrol.0 2019-12-31 10:19:45.099 debug (4204) create cron job #1 at 8:0 string: 0 0 8 * * 1-5 Europe/Berlin heatingcontrol.0 2019-12-31 10:19:45.078 debug (4204) create cron job #0 at 5:0 string: 0 0 5 * * 1-5 Europe/Berlin heatingcontrol.0 2019-12-31 10:19:45.078 debug (4204) ---2 found time for Wohnzimmer at {"val":"21:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 21:00 heatingcontrol.0 2019-12-31 10:19:45.075 debug (4204) ---2 found time for Wohnzimmer at {"val":"16:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 16:00 heatingcontrol.0 2019-12-31 10:19:45.072 debug (4204) ---2 found time for Wohnzimmer at {"val":"12:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 12:00 heatingcontrol.0 2019-12-31 10:19:45.070 debug (4204) ---2 found time for Wohnzimmer at {"val":"08:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 08:00 heatingcontrol.0 2019-12-31 10:19:45.067 debug (4204) ---2 found time for Wohnzimmer at {"val":"05:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 05:00 heatingcontrol.0 2019-12-31 10:19:45.062 debug (4204) setting Sa - Su heatingcontrol.0 2019-12-31 10:19:45.062 debug (4204) ---1 found time for Wohnzimmer at {"val":"21:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 21:00 heatingcontrol.0 2019-12-31 10:19:45.060 debug (4204) ---1 found time for Wohnzimmer at {"val":"16:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 16:00 heatingcontrol.0 2019-12-31 10:19:45.059 debug (4204) ---1 found time for Wohnzimmer at {"val":"12:00","ack":false,"ts":1577542409214,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1577542409214} 12:00 heatingcontrol.0 2019-12-31 10:19:45.057 debug (4204) ---1 found time for Wohnzimmer at {"val":"08:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 08:00 heatingcontrol.0 2019-12-31 10:19:45.055 debug (4204) ---1 found time for Wohnzimmer at {"val":"05:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 05:00 heatingcontrol.0 2019-12-31 10:19:45.052 debug (4204) setting Mo - Fr heatingcontrol.0 2019-12-31 10:19:45.051 debug (4204) ---2 found time for Küche at {"val":"21:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 21:00 heatingcontrol.0 2019-12-31 10:19:45.049 debug (4204) ---2 found time for Küche at {"val":"16:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 16:00 heatingcontrol.0 2019-12-31 10:19:45.047 debug (4204) ---2 found time for Küche at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00 heatingcontrol.0 2019-12-31 10:19:45.036 debug (4204) ---2 found time for Küche at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00 heatingcontrol.0 2019-12-31 10:19:45.031 debug (4204) ---2 found time for Küche at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00 heatingcontrol.0 2019-12-31 10:19:45.028 debug (4204) setting Sa - Su heatingcontrol.0 2019-12-31 10:19:45.028 debug (4204) ---1 found time for Küche at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00 heatingcontrol.0 2019-12-31 10:19:45.021 debug (4204) ---1 found time for Küche at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00 heatingcontrol.0 2019-12-31 10:19:45.019 debug (4204) ---1 found time for Küche at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00 heatingcontrol.0 2019-12-31 10:19:45.018 debug (4204) ---1 found time for Küche at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00 heatingcontrol.0 2019-12-31 10:19:45.017 debug (4204) ---1 found time for Küche at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00 heatingcontrol.0 2019-12-31 10:19:45.011 debug (4204) setting Mo - Fr heatingcontrol.0 2019-12-31 10:19:45.011 debug (4204) ---2 found time for Badezimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00 heatingcontrol.0 2019-12-31 10:19:45.010 debug (4204) ---2 found time for Badezimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00 heatingcontrol.0 2019-12-31 10:19:45.009 debug (4204) ---2 found time for Badezimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00 heatingcontrol.0 2019-12-31 10:19:45.007 debug (4204) ---2 found time for Badezimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00 heatingcontrol.0 2019-12-31 10:19:45.004 debug (4204) ---2 found time for Badezimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00 heatingcontrol.0 2019-12-31 10:19:44.996 debug (4204) setting Sa - Su heatingcontrol.0 2019-12-31 10:19:44.996 debug (4204) ---1 found time for Badezimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00 heatingcontrol.0 2019-12-31 10:19:44.993 debug (4204) ---1 found time for Badezimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00 heatingcontrol.0 2019-12-31 10:19:44.988 debug (4204) ---1 found time for Badezimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00 heatingcontrol.0 2019-12-31 10:19:44.987 debug (4204) ---1 found time for Badezimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00 heatingcontrol.0 2019-12-31 10:19:44.986 debug (4204) ---1 found time for Badezimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00 heatingcontrol.0 2019-12-31 10:19:44.985 debug (4204) setting Mo - Fr heatingcontrol.0 2019-12-31 10:19:44.985 debug (4204) push to list = 21,00 heatingcontrol.0 2019-12-31 10:19:44.985 debug (4204) ---2 found time for Arbeitszimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00 heatingcontrol.0 2019-12-31 10:19:44.983 debug (4204) push to list = 16,00 heatingcontrol.0 2019-12-31 10:19:44.982 debug (4204) ---2 found time for Arbeitszimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00 heatingcontrol.0 2019-12-31 10:19:44.974 debug (4204) push to list = 12,00 heatingcontrol.0 2019-12-31 10:19:44.974 debug (4204) ---2 found time for Arbeitszimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00 heatingcontrol.0 2019-12-31 10:19:44.963 debug (4204) push to list = 08,00 heatingcontrol.0 2019-12-31 10:19:44.962 debug (4204) ---2 found time for Arbeitszimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00 heatingcontrol.0 2019-12-31 10:19:44.943 debug (4204) push to list = 05,00 heatingcontrol.0 2019-12-31 10:19:44.943 debug (4204) ---2 found time for Arbeitszimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00 heatingcontrol.0 2019-12-31 10:19:44.942 debug (4204) setting Sa - Su heatingcontrol.0 2019-12-31 10:19:44.942 debug (4204) push to list = 21,00 heatingcontrol.0 2019-12-31 10:19:44.942 debug (4204) ---1 found time for Arbeitszimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00 heatingcontrol.0 2019-12-31 10:19:44.941 debug (4204) push to list = 16,00 heatingcontrol.0 2019-12-31 10:19:44.940 debug (4204) ---1 found time for Arbeitszimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00 heatingcontrol.0 2019-12-31 10:19:44.932 debug (4204) push to list = 12,00 heatingcontrol.0 2019-12-31 10:19:44.931 debug (4204) ---1 found time for Arbeitszimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00 heatingcontrol.0 2019-12-31 10:19:44.930 debug (4204) push to list = 08,00 heatingcontrol.0 2019-12-31 10:19:44.930 debug (4204) ---1 found time for Arbeitszimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00 heatingcontrol.0 2019-12-31 10:19:44.921 debug (4204) push to list = 05,00 heatingcontrol.0 2019-12-31 10:19:44.920 debug (4204) ---1 found time for Arbeitszimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00 heatingcontrol.0 2019-12-31 10:19:44.919 debug (4204) setting Mo - Fr heatingcontrol.0 2019-12-31 10:19:44.919 debug (4204) profile 0 heatingcontrol.0 2019-12-31 10:19:44.909 debug (4204) get profile heatingcontrol.0 2019-12-31 10:19:44.909 debug (4204) start CalculateNextTime, profile type 2 heatingcontrol.0 2019-12-31 10:19:44.908 debug (4204) system date format DD.MM.YYYY heatingcontrol.0 2019-12-31 10:19:44.885 debug (4204) CreateDatepoints done heatingcontrol.0 2019-12-31 10:19:44.885 debug (4204) not active.... Kinderzimmer heatingcontrol.0 2019-12-31 10:19:44.885 debug (4204) not active.... Schlafzimmer heatingcontrol.0 2019-12-31 10:19:44.885 debug (4204) add state Profiles.0.Wohnzimmer.Sa-So.Periods.4 max 5 heatingcontrol.0 2019-12-31 10:19:44.885 debug (4204) add state Profiles.0.Wohnzimmer.Sa-So.Periods.3 max 5 heatingcontrol.0 2019-12-31 10:19:44.885 debug (4204) add state Profiles.0.Wohnzimmer.Sa-So.Periods.2 max 5 heatingcontrol.0 2019-12-31 10:19:44.885 debug (4204) add state Profiles.0.Wohnzimmer.Sa-So.Periods.1 max 5 heatingcontrol.0 2019-12-31 10:19:44.884 debug (4204) add state Profiles.0.Wohnzimmer.Sa-So.Periods.0 max 5 heatingcontrol.0 2019-12-31 10:19:44.884 debug (4204) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.4 max 5 heatingcontrol.0 2019-12-31 10:19:44.884 debug (4204) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.3 max 5 heatingcontrol.0 2019-12-31 10:19:44.884 debug (4204) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.2 max 5 heatingcontrol.0 2019-12-31 10:19:44.884 debug (4204) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.1 max 5 heatingcontrol.0 2019-12-31 10:19:44.883 debug (4204) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.0 max 5 heatingcontrol.0 2019-12-31 10:19:44.883 debug (4204) Profile Type Mo-FR + Sa-So, profiles 1 heatingcontrol.0 2019-12-31 10:19:44.883 debug (4204) room Wohnzimmer with 5 periods heatingcontrol.0 2019-12-31 10:19:44.673 debug (4204) create data profile points (absolute) for Wohnzimmer heatingcontrol.0 2019-12-31 10:19:44.670 debug (4204) add state Profiles.0.Küche.Sa-So.Periods.4 max 5 heatingcontrol.0 2019-12-31 10:19:44.670 debug (4204) add state Profiles.0.Küche.Sa-So.Periods.3 max 5 heatingcontrol.0 2019-12-31 10:19:44.670 debug (4204) add state Profiles.0.Küche.Sa-So.Periods.2 max 5 heatingcontrol.0 2019-12-31 10:19:44.670 debug (4204) add state Profiles.0.Küche.Sa-So.Periods.1 max 5 heatingcontrol.0 2019-12-31 10:19:44.670 debug (4204) add state Profiles.0.Küche.Sa-So.Periods.0 max 5 heatingcontrol.0 2019-12-31 10:19:44.670 debug (4204) add state Profiles.0.Küche.Mo-Fr.Periods.4 max 5 heatingcontrol.0 2019-12-31 10:19:44.669 debug (4204) add state Profiles.0.Küche.Mo-Fr.Periods.3 max 5 heatingcontrol.0 2019-12-31 10:19:44.667 debug (4204) add state Profiles.0.Küche.Mo-Fr.Periods.2 max 5 heatingcontrol.0 2019-12-31 10:19:44.667 debug (4204) add state Profiles.0.Küche.Mo-Fr.Periods.1 max 5 heatingcontrol.0 2019-12-31 10:19:44.665 debug (4204) add state Profiles.0.Küche.Mo-Fr.Periods.0 max 5 heatingcontrol.0 2019-12-31 10:19:44.665 debug (4204) Profile Type Mo-FR + Sa-So, profiles 1 heatingcontrol.0 2019-12-31 10:19:44.665 debug (4204) room Küche with 5 periods heatingcontrol.0 2019-12-31 10:19:44.475 debug (4204) create data profile points (absolute) for Küche heatingcontrol.0 2019-12-31 10:19:44.475 debug (4204) add state Profiles.0.Badezimmer.Sa-So.Periods.4 max 5 heatingcontrol.0 2019-12-31 10:19:44.475 debug (4204) add state Profiles.0.Badezimmer.Sa-So.Periods.3 max 5 heatingcontrol.0 2019-12-31 10:19:44.475 debug (4204) add state Profiles.0.Badezimmer.Sa-So.Periods.2 max 5 heatingcontrol.0 2019-12-31 10:19:44.475 debug (4204) add state Profiles.0.Badezimmer.Sa-So.Periods.1 max 5 heatingcontrol.0 2019-12-31 10:19:44.475 debug (4204) add state Profiles.0.Badezimmer.Sa-So.Periods.0 max 5 heatingcontrol.0 2019-12-31 10:19:44.474 debug (4204) add state Profiles.0.Badezimmer.Mo-Fr.Periods.4 max 5 heatingcontrol.0 2019-12-31 10:19:44.474 debug (4204) add state Profiles.0.Badezimmer.Mo-Fr.Periods.3 max 5 heatingcontrol.0 2019-12-31 10:19:44.474 debug (4204) add state Profiles.0.Badezimmer.Mo-Fr.Periods.2 max 5 heatingcontrol.0 2019-12-31 10:19:44.474 debug (4204) add state Profiles.0.Badezimmer.Mo-Fr.Periods.1 max 5 heatingcontrol.0 2019-12-31 10:19:44.474 debug (4204) add state Profiles.0.Badezimmer.Mo-Fr.Periods.0 max 5 heatingcontrol.0 2019-12-31 10:19:44.474 debug (4204) Profile Type Mo-FR + Sa-So, profiles 1 heatingcontrol.0 2019-12-31 10:19:44.473 debug (4204) room Badezimmer with 5 periods heatingcontrol.0 2019-12-31 10:19:44.332 debug (4204) create data profile points (absolute) for Badezimmer heatingcontrol.0 2019-12-31 10:19:44.331 debug (4204) add state Profiles.0.Arbeitszimmer.Sa-So.Periods.4 max 5 heatingcontrol.0 2019-12-31 10:19:44.331 debug (4204) add state Profiles.0.Arbeitszimmer.Sa-So.Periods.3 max 5 heatingcontrol.0 2019-12-31 10:19:44.331 debug (4204) add state Profiles.0.Arbeitszimmer.Sa-So.Periods.2 max 5 heatingcontrol.0 2019-12-31 10:19:44.331 debug (4204) add state Profiles.0.Arbeitszimmer.Sa-So.Periods.1 max 5 heatingcontrol.0 2019-12-31 10:19:44.331 debug (4204) add state Profiles.0.Arbeitszimmer.Sa-So.Periods.0 max 5 heatingcontrol.0 2019-12-31 10:19:44.331 debug (4204) add state Profiles.0.Arbeitszimmer.Mo-Fr.Periods.4 max 5 heatingcontrol.0 2019-12-31 10:19:44.331 debug (4204) add state Profiles.0.Arbeitszimmer.Mo-Fr.Periods.3 max 5 heatingcontrol.0 2019-12-31 10:19:44.330 debug (4204) add state Profiles.0.Arbeitszimmer.Mo-Fr.Periods.2 max 5 heatingcontrol.0 2019-12-31 10:19:44.330 debug (4204) add state Profiles.0.Arbeitszimmer.Mo-Fr.Periods.1 max 5 heatingcontrol.0 2019-12-31 10:19:44.330 debug (4204) add state Profiles.0.Arbeitszimmer.Mo-Fr.Periods.0 max 5 heatingcontrol.0 2019-12-31 10:19:44.330 debug (4204) Profile Type Mo-FR + Sa-So, profiles 1 heatingcontrol.0 2019-12-31 10:19:44.329 debug (4204) room Arbeitszimmer with 5 periods heatingcontrol.0 2019-12-31 10:19:44.278 debug (4204) create data profile points (absolute) for Arbeitszimmer heatingcontrol.0 2019-12-31 10:19:44.278 debug (4204) rooms 6 heatingcontrol.0 2019-12-31 10:19:44.263 debug (4204) create data points for Wohnzimmer heatingcontrol.0 2019-12-31 10:19:44.252 debug (4204) create data points for Küche heatingcontrol.0 2019-12-31 10:19:44.248 debug (4204) create data points for Badezimmer heatingcontrol.0 2019-12-31 10:19:44.226 debug (4204) create data points for Arbeitszimmer heatingcontrol.0 2019-12-31 10:19:43.903 debug (4204) start CreateDatepoints heatingcontrol.0 2019-12-31 11:19:45.322 debug (4204) thermostat hm-rpc.1.000A17098D4EAA.1.SET_POINT_TEMPERATURE nothing to do, already 23 heatingcontrol.0 2019-12-31 11:19:45.321 info (4204) room Badezimmer Thermostat Heizung Bad.SET_POINT_TEMPERATURE target is 23 heatingcontrol.0 2019-12-31 11:19:45.321 debug (4204) thermostat hm-rpc.1.000A97099C1E2C.1.SET_POINT_TEMPERATURE nothing to do, already 23 heatingcontrol.0 2019-12-31 11:19:45.318 info (4204) room Badezimmer Thermostat Fußbodenheizung Bad.SET_POINT_TEMPERATURE target is 23 heatingcontrol.0 2019-12-31 11:19:45.318 debug (4204) ### new target temp23 heatingcontrol.0 2019-12-31 11:19:45.318 debug (4204) ### current > 1 1 2 heatingcontrol.0 2019-12-31 11:19:45.318 debug (4204) Badezimmer found period 1 with 23 on 08,00 heatingcontrol.0 2019-12-31 11:19:45.316 debug (4204) check ID Profiles.0.Badezimmer.Sa-So.Periods.4.time heatingcontrol.0 2019-12-31 11:19:45.314 debug (4204) check ID Profiles.0.Badezimmer.Sa-So.Periods.3.time heatingcontrol.0 2019-12-31 11:19:45.311 debug (4204) check ID Profiles.0.Badezimmer.Sa-So.Periods.2.time heatingcontrol.0 2019-12-31 11:19:45.311 debug (4204) check time for Badezimmer Profiles.0.Badezimmer.Sa-So.Periods.1.time 23 heatingcontrol.0 2019-12-31 11:19:45.310 debug (4204) check ID Profiles.0.Badezimmer.Sa-So.Periods.1.time heatingcontrol.0 2019-12-31 11:19:45.310 debug (4204) check time for Badezimmer Profiles.0.Badezimmer.Sa-So.Periods.0.time 19 heatingcontrol.0 2019-12-31 11:19:45.307 debug (4204) check ID Profiles.0.Badezimmer.Sa-So.Periods.0.time heatingcontrol.0 2019-12-31 11:19:45.307 debug (4204) FindNextPeriod for 12/31/2019, 10:19:45 AM in Badezimmer heatingcontrol.0 2019-12-31 11:19:45.306 debug (4204) check room Badezimmer heatingcontrol.0 2019-12-31 11:19:45.297 debug (4204) thermostat hm-rpc.1.000A1709ACCE17.1.SET_POINT_TEMPERATURE nothing to do, already 21 heatingcontrol.0 2019-12-31 11:19:45.291 info (4204) room Arbeitszimmer Thermostat Heizung Arbeitszimmer.SET_POINT_TEMPERATURE target is 21 heatingcontrol.0 2019-12-31 11:19:45.291 debug (4204) ### new target temp21 heatingcontrol.0 2019-12-31 11:19:45.291 debug (4204) ### current > 1 1 2 heatingcontrol.0 2019-12-31 11:19:45.289 debug (4204) Arbeitszimmer found period 1 with 21 on 08,00 heatingcontrol.0 2019-12-31 11:19:45.287 debug (4204) check ID Profiles.0.Arbeitszimmer.Sa-So.Periods.4.time heatingcontrol.0 2019-12-31 11:19:45.283 debug (4204) check ID Profiles.0.Arbeitszimmer.Sa-So.Periods.3.time heatingcontrol.0 2019-12-31 11:19:45.281 debug (4204) check ID Profiles.0.Arbeitszimmer.Sa-So.Periods.2.time heatingcontrol.0 2019-12-31 11:19:45.280 debug (4204) check time for Arbeitszimmer Profiles.0.Arbeitszimmer.Sa-So.Periods.1.time 21 heatingcontrol.0 2019-12-31 11:19:45.278 debug (4204) check ID Profiles.0.Arbeitszimmer.Sa-So.Periods.1.time heatingcontrol.0 2019-12-31 11:19:45.276 debug (4204) check time for Arbeitszimmer Profiles.0.Arbeitszimmer.Sa-So.Periods.0.time 17 heatingcontrol.0 2019-12-31 11:19:45.269 debug (4204) check ID Profiles.0.Arbeitszimmer.Sa-So.Periods.0.time heatingcontrol.0 2019-12-31 11:19:45.269 debug (4204) FindNextPeriod for 12/31/2019, 10:19:45 AM in Arbeitszimmer heatingcontrol.0 2019-12-31 11:19:45.262 debug (4204) check room Arbeitszimmer heatingcontrol.0 2019-12-31 11:19:45.262 debug (4204) profile 0 heatingcontrol.0 2019-12-31 11:19:45.260 debug (4204) get profile heatingcontrol.0 2019-12-31 11:19:45.260 debug (4204) profile type 2 heatingcontrol.0 2019-12-31 11:19:45.252 info (4204) calculating new target temperatures heatingcontrol.0 2019-12-31 11:19:45.251 info (4204) external states checked, done heatingcontrol.0 2019-12-31 11:19:45.249 debug (4204) checking Path2HolidayPresentDP heatingcontrol.0 2019-12-31 11:19:45.248 debug (4204) checking Path2PartyNowDP heatingcontrol.0 2019-12-31 11:19:45.245 debug (4204) checking Path2GuestsPresentDP heatingcontrol.0 2019-12-31 11:19:45.244 debug (4204) checking Path2VacationDP heatingcontrol.0 2019-12-31 11:19:45.240 info (4204) setting Present to true heatingcontrol.0 2019-12-31 11:19:45.239 debug (4204) got Present (1) {"val":true,"ack":true,"ts":1577726419908,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1577726419858} heatingcontrol.0 2019-12-31 11:19:45.237 debug (4204) checking Path2PresentDP heatingcontrol.0 2019-12-31 11:19:45.232 info (4204) setting PublicHolidyToday to true heatingcontrol.0 2019-12-31 11:19:45.229 debug (4204) checking Path2FeiertagAdapter heatingcontrol.0 2019-12-31 11:19:45.228 info (4204) checking all external states heatingcontrol.0 2019-12-31 11:19:45.223 debug (4204) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933362844} from deconz.0.Sensors.21.open heatingcontrol.0 2019-12-31 11:19:45.220 debug (4204) got sensor state {"val":false,"ack":true,"ts":1577717574989,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577638441163} from deconz.0.Sensors.20.open heatingcontrol.0 2019-12-31 11:19:45.217 debug (4204) got sensor state {"val":false,"ack":true,"ts":1577717574989,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933207327} from deconz.0.Sensors.19.open heatingcontrol.0 2019-12-31 11:19:45.210 debug (4204) got sensor state {"val":false,"ack":true,"ts":1577717574987,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933122635} from deconz.0.Sensors.18.open heatingcontrol.0 2019-12-31 11:19:45.209 debug (4204) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933025797} from deconz.0.Sensors.17.open heatingcontrol.0 2019-12-31 11:19:45.205 debug (4204) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576932905933} from deconz.0.Sensors.16.open heatingcontrol.0 2019-12-31 11:19:45.203 debug (4204) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577007719646} from deconz.0.Sensors.15.open heatingcontrol.0 2019-12-31 11:19:45.201 debug (4204) Check sensors for Wohnzimmer heatingcontrol.0 2019-12-31 11:19:45.196 debug (4204) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577644284922} from deconz.0.Sensors.24.open heatingcontrol.0 2019-12-31 11:19:45.195 debug (4204) got sensor state {"val":0,"ack":true,"ts":1577786742689,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1577786742689} from hm-rpc.1.0007D5699E9605.1.STATE heatingcontrol.0 2019-12-31 11:19:45.192 debug (4204) Check sensors for Küche heatingcontrol.0 2019-12-31 11:19:45.186 debug (4204) got sensor state {"val":0,"ack":true,"ts":1577785259127,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1577628013202} from hm-rpc.1.0000D56996187D.1.STATE heatingcontrol.0 2019-12-31 11:19:45.184 debug (4204) Check sensors for Badezimmer heatingcontrol.0 2019-12-31 11:19:45.179 debug (4204) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577705276875} from deconz.0.Sensors.23.open heatingcontrol.0 2019-12-31 11:19:45.176 debug (4204) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576925832752} from deconz.0.Sensors.11.open heatingcontrol.0 2019-12-31 11:19:45.157 debug (4204) Check sensors for Arbeitszimmer heatingcontrol.0 2019-12-31 11:19:45.156 debug (4204) [INFO] status = true next event: 4 Jan 2020 20:00:00 heatingcontrol.0 2019-12-31 11:19:45.155 debug (4204) [INFO] status = true next event: 4 Jan 2020 15:00:00 heatingcontrol.0 2019-12-31 11:19:45.154 debug (4204) [INFO] status = true next event: 4 Jan 2020 11:00:00 heatingcontrol.0 2019-12-31 11:19:45.153 debug (4204) [INFO] status = true next event: 4 Jan 2020 07:00:00 heatingcontrol.0 2019-12-31 11:19:45.152 debug (4204) [INFO] status = true next event: 4 Jan 2020 04:00:00 heatingcontrol.0 2019-12-31 11:19:45.151 debug (4204) [INFO] status = true next event: 31 Dec 2019 20:00:00 heatingcontrol.0 2019-12-31 11:19:45.151 debug (4204) [INFO] status = true next event: 31 Dec 2019 15:00:00 heatingcontrol.0 2019-12-31 11:19:45.150 debug (4204) [INFO] status = true next event: 31 Dec 2019 11:00:00 heatingcontrol.0 2019-12-31 11:19:45.150 debug (4204) [INFO] status = true next event: 1 Jan 2020 07:00:00 heatingcontrol.0 2019-12-31 11:19:45.147 debug (4204) [INFO] status = true next event: 1 Jan 2020 04:00:00 heatingcontrol.0 2019-12-31 11:19:45.134 debug (4204) create cron job #9 at 21:0 string: 0 0 21 * * 0,6 Europe/Berlin heatingcontrol.0 2019-12-31 11:19:45.132 debug (4204) create cron job #8 at 16:0 string: 0 0 16 * * 0,6 Europe/Berlin heatingcontrol.0 2019-12-31 11:19:45.129 debug (4204) create cron job #7 at 12:0 string: 0 0 12 * * 0,6 Europe/Berlin heatingcontrol.0 2019-12-31 11:19:45.127 debug (4204) create cron job #6 at 8:0 string: 0 0 8 * * 0,6 Europe/Berlin heatingcontrol.0 2019-12-31 11:19:45.120 debug (4204) create cron job #5 at 5:0 string: 0 0 5 * * 0,6 Europe/Berlin heatingcontrol.0 2019-12-31 11:19:45.117 debug (4204) create cron job #4 at 21:0 string: 0 0 21 * * 1-5 Europe/Berlin -
Jetzt siehts aus als wenn alles funktioniert
Alle Thermostate reagieren auf die Einstellungen.
Oder siehst du da noch was was ich ändern sollte? -
@moppel2810 sieht soweit gut aus...
Hallo! Das hatte ich Anfangs genommen - allerdings öffnet der Fully oder auch Chrome auf meinem Tablet dann immer eine Tastatur.
Daher habe ich ein System verwendet, dass ich bereits bei meiner Timer-Konfiguration verwendet habe.LG
HolgerP.S.: Guten Rutsch!
@guergen
LG
Holger
P.S.: Guten Rutsch!
