    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Драйвер Mqtt + Arduino
      revenkopa last edited by
      Вот код :
      ! #include <dht.h>#include <esp8266wifi.h>#include <pubsubclient.h>#define DHTPIN 5
      ! //#define DHTTYPE DHT11 // DHT 11
      ! #define DHTTYPE DHT22 // DHT 22 (AM2302)
      ! //#define DHTTYPE DHT21 // DHT 21 (AM2301)
      ! float dht_h ; // Reading temperature or humidity takes about 250 milliseconds!
      ! float dht_t ; // Read temperature as Celsius (the default)
      ! DHT dht(DHTPIN, DHTTYPE);
      ! #define Rel1pin 12
      ! #define Rel2pin 13
      ! #define But1pin 4
      ! #define But2pin 6
      ! // Update these with values suitable for your network.
      ! const char* ssid = "kv7";
      ! const char* password = "*****";
      ! //const char
      mqtt_server = "broker.mqtt-dashboard.com";
      ! IPAddress MQTTserver(192, 168, 1, 120);
      ! String MQTT_CN = "kv7/Kitchen/1";
      ! IPAddress IPAdrr (192, 168, 1, 201);
      ! IPAddress IPGW (192, 168, 1, 1);
      ! IPAddress Mask (255, 255, 255, 0);
      ! unsigned long TimerSendTH = 0;
      ! unsigned long TimerSendTHOFF = 2000;
      ! unsigned long TimerRel1 = 0;
      ! unsigned long TimerRel1OFF = 5000;
      ! unsigned long TimerRel2 = 0;
      ! unsigned long TimerRel2OFF = 6000;
      ! WiFiClient espClient;
      ! PubSubClient client(espClient);
      ! long lastMsg = 0;
      ! char msg[50];
      ! int value = 0;
      ! void setup() {
      ! pinMode(BUILTIN_LED, OUTPUT); // Initialize the BUILTIN_LED pin as an output
      ! pinMode(12, OUTPUT);
      ! pinMode(13, OUTPUT);
      ! pinMode( 4, INPUT);
      ! dht.begin();
      ! Serial.begin(115200);
      ! WiFi.begin(ssid, password);
      ! WiFi.config(IPAdrr, IPGW, Mask ); //Comment for DHCP
      ! setup_wifi();
      ! client.setServer(MQTTserver, 1883);
      ! client.setCallback(callback);
      ! void setup_wifi() {
      ! delay(10);
      ! // We start by connecting to a WiFi network
      ! Serial.println();
      ! Serial.print("Connecting to ");
      ! Serial.println(ssid);
      ! // WiFi.begin(ssid, password);
      ! while (WiFi.status() != WL_CONNECTED) {
      ! delay(500);
      ! Serial.print(".");
      ! Serial.println("");
      ! Serial.println("WiFi connected");
      ! Serial.println("IP address: ");
      ! Serial.println(WiFi.localIP());
      ! void callback(char
      topic, byte
      payload, unsigned int length) {
      ! payload[length] = '\0';
      ! String strTopic = String(topic);
      ! strTopic.replace(MQTT_CN,"");
      ! String strPayload = String((char
      )payload);
      ! Serial.print("Message arrived [");
      ! Serial.print(strTopic+" | ");
      ! Serial.print(strPayload);
      ! Serial.print("]");
      ! if (strTopic == "/Rel1") {
      ! if (strPayload == "0") digitalWrite(Rel1pin, !LOW);
      ! else if (strPayload == "1") digitalWrite(Rel1pin, !HIGH);
      ! else if (strTopic == "/Rel2") {
      ! if (strPayload == "0") digitalWrite(Rel2pin, !LOW);
      ! else if (strPayload == "1") digitalWrite(Rel2pin, !HIGH);
      ! boolean reconnect() {
      ! Serial.print("Attempting MQTT connection…");
      ! // if (client.connect(("Controller "+MQTT_CN).c_str() ))
      ! if (client.connect("Controller 1"))
      ! // Once connected, publish an announcement...
      ! client.publish(MQTT_CN.c_str() ," online");
      ! // ... and resubscribe
      ! Serial.print("Subscribe...ok "+MQTT_CN);
      ! client.subscribe((MQTT_CN+"/#").c_str() );
      ! else Serial.print("Fail...");
      ! return client.connected();
      ! boolean measurements() {
      ! Serial.print("measurements... ");
      ! dht_h = dht.readHumidity();
      ! dht_t = dht.readTemperature();
      ! if (isnan(dht_h) || isnan(dht_t) || isnan(dht.readTemperature(true))) return false;
      ! return true;
      ! void loop() {
      ! if (!client.connected()) reconnect();
      ! client.loop();
      ! // digitalWrite(12, !digitalRead(4) );
      ! // digitalWrite(13, !digitalRead(4) );
      ! // TimerSendTH = 0;
      ! //TimerSendTHOFF = 2000;
      ! // TimerRel1 = 0;
      ! // TimerRel1OFF = 5000;
      ! // TimerRel2 = 0;
      ! // TimerRel2OFF = 6000;
      ! //measurements();
      ! //snprintf (msg, 75, "%2d", DHT.humidity);
      ! dtostrf (dht_h,0,2,msg );
      ! // client.publish((MQTT_CN+ "/humidity").c_str(), msg);
      ! // Serial.println(dht_h);
      ! dtostrf ( dht_t,0,2,msg );
      ! // client.publish((MQTT_CN+"/temperature").c_str(), msg);
      ! // Serial.println(dht_t);
      ! client.publish((MQTT_CN+"/Rel1").c_str(),String( !digitalRead(12)).c_str());
      ! Serial.println((MQTT_CN+"/Rel1"+String( !digitalRead(12))).c_str() );
      ! delay(500);
      ! client.publish((MQTT_CN+"/Rel2").c_str(),String( !digitalRead(13)).c_str());
      ! Serial.println((MQTT_CN+"/Rel2"+String( !digitalRead(13))).c_str() );
      ! delay(500);
      ! }</pubsubclient.h></esp8266wifi.h></dht.h>
        Вот точно такая же фигня была :
        Раньше такая строка отправлялась от брокера: myhome/Bedroom/Servo
        Сейчас: mqtt/0/myhome/Bedroom/Servo
        только не помогает ранее найденое лекарство - строка префикса и так пустая
        • I
          instalator last edited by
          Я просто оставлю свой код, который реально работает у меня в данный момент.
          266_kitchen_mqtt.rar
          Я так и не пойму какая разница ` > Раньше такая строка отправлялась от брокера: myhome/Bedroom/Servo
          Сейчас: mqtt/0/myhome/Bedroom/Servo `
          Что это меняет?
            Haus last edited by
            "Я просто оставлю свой код, который реально работает у меня в данный момент."
            Спасибо за примеры опробовал работает.
            Вопрос, в твоём коде заменил библиотеку для ENC28J60 и адрес DS18BB20.
            Не мог скомпелировать всё ругался на callbac и указывал на строчку, так как в коде не понимаю стёр callbac и всё сработало.
            Температуры показывает , переменные создались. Не связано ли это с ENC28J60 ?
            ! EthernetClient ethClient;
            ! //PubSubClient client(server, 1883, callback, ethClient);
            ! PubSubClient client(server, 1883, ethClient);
            ! #define id_connect "myhome-kitchen"
            ! #define Prefix_subscribe "myhome/Kitchen/"
              electric69 last edited by
              @Haus:
              ! #define Prefix_subscribe "myhome/Kitchen/" `
              Ардуина отправляет (публикует) данные в ioBroker.
              А как обстоят дела с подпиской? Данные от ioBroker передаются в ардуину?
              • I
                @Haus:
                а сама функция то далее по коду есть?
                void callback(char* topic, byte* payload, unsigned int length) {
                   // Serial.print(topic);
                   // Serial.print("=");
                    String strPayload = String((char*)payload);
                   // Serial.println(strPayload);
                    callback_iobroker(strTopic, strPayload);
                  Haus last edited by
                  Я же написал "в твоём коде заменил библиотеку для ENC28J60 (#include <uipethernet.h>) и адрес DS18BB20", а он всё callbac ну я и стёр эту функцию в PubSubClient client(server, 1883, callback, ethClient) получилось вот так PubSubClient client(server, 1883, ethClient) .Понимаю что это неправильно, про бывал другие примеры ситуация похожая. Так как спросить больше не у кого, прошу помощи у вас. В чём может быть проблема? Вот этот код компилируется нормально.
                  ! #include <spi.h>#include <uipethernet.h>// UIP Ethernet Library to support ENC28J60 ethernet module.
                  ! #include <pubsubclient.h>// MQTT publisher/subscriber client library
                  ! #include <wire.h>#include <liquidcrystal_i2c.h>// i2C bus converter compatible library for LCD
                  ! LiquidCrystal_I2C lcd(0x27,16,2);
                  ! byte mac[] = { 0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED }; // Set the mac address for the arduino nano mcu
                  ! byte server[] = { 192, 168, 1, 16 }; // Set MQTT broker server IP address
                  ! //char server[] = "xxx.xxxxxxx.xxx"; // Set MQTT broker server domain address
                  ! byte ip[] = { 192, 168, 1, 11 }; // Set the IP address for the arduino nano mcu
                  ! int LED = 6; // Initialize digital pin 6 to LED variable
                  ! String msgString; // Initialize msgString variable
                  ! void callback(char* topic, byte* payload, unsigned int length) {
                  ! // Handle message arrived upon a publish from a MQTT client
                  ! char message_buff[100];
                  ! int i;
                  ! for(i=0; i <length; i++)/{<br="">message_buff = payload;
                  ! message_buff = '\0';
                  ! msgString = String(message_buff);
                  ! Serial.println("message arrived: " + msgString); // Serial output of received callback payload
                  ! if(msgString == "0")
                  ! digitalWrite(LED, LOW); // If message payload received is 0, LED is turned off
                  ! lcd.clear(); // Clear previously printed values in the LCD
                  ! lcd.print("D6 : OFF"); // Print The Message on LCD
                  ! lcd.setCursor(0,1); // Set top cursor position on 16x2 LCD module
                  ! else if (msgString == "1")
                  ! digitalWrite(LED, HIGH); // If message payload received is 1, LED is turned on
                  ! lcd.print("D6 : ON"); // Print The Message on LCD
                  ! } else {
                  ! lcd.print("Device Status"); // Print Device Status message on LCD
                  ! lcd.print(msgString); // Print The message payload on LCD
                  ! lcd.setCursor(1,1); // Set top cursor position on 16x2 LCD module
                  ! PubSubClient client(server, 1883, callback, ethClient); // Initialize a MQTT client instance
                  ! void setup()
                  ! Serial.begin(9600); // Set the Serial Buad rate to 9600
                  ! pinMode(LED, OUTPUT); // Set LED connected pin to OUTPUT mode
                  ! lcd.init(); // Initialize the 16X2 LCD
                  ! lcd.backlight();
                  ! Ethernet.begin(mac, ip);
                  ! if (client.connect("arduinoClient")) { // Check the MQTT broker connectivity
                  ! client.publish("topic","connected"); // Publish ethernet connected status to MQTT topic
                  ! client.subscribe("topic"); // Subscribe to a MQTT topic
                  ! void loop()
                  ! client.loop();
                  ____</length;></liquidcrystal_i2c.h></wire.h></pubsubclient.h></uipethernet.h></spi.h></uipethernet.h>
                    Haus last edited by
                    Чего хочу сделать:
                    Есть 2 аккумулятивных бака, раньше в них стояли простые термометры и показывали температуру. Сейчас вместо них всунуты DS18B20 и на экране компьютера, телефона всё прекрасно отображается. Но когда хочешь докинуть дров чтобы до грузить баки, под рукой может неокозатца телефона чтобы прикинуть сколько дров подбросить. Хочу поставить рядом с котлом LCD монитор чтобы видеть температуру баков 4х2=8 датчиков переданную с сервера. Также можно было бы и снимать температуру с датчиков отображать на дисплей и отправлять серверу.
                    • I
                      @Haus:
                      ! int i;
                      ! } else {
                      ! void setup()
                      ! lcd.backlight();
                      ! void loop()
                      ! client.loop();
                      ____</length;></liquidcrystal_i2c.h></wire.h></pubsubclient.h></uipethernet.h></spi.h> ______Что за ошибку дает при компиляции? у меня нету твоих библиотек, проверить не могу.
                      Какую кстати версию библиотеки PubSubClient.h юзаете?
                      Добавил которая стоит у меня, вроде 1.9 версия.
                      Обновил у себя до версии 2.4 все нормально компилится. Мой код который я выкладывал компилится у вас? или ошибки только когда добавляете свеоего кода?___
                      266_pubsubclient.zip___</uipethernet.h> `
                        Haus last edited by
                        Твой код без изменений, PubSubClient.h 2.4, ошибка Kitchen_Mqtt:16: error: 'callback' was not declared in this scope.
                        Если в коде две строчки переставить в другое место всё компилится
                        ! // Serial.print(topic);
                        ! // Serial.print("=");
                        ! String strPayload = String((char*)payload);
                        ! // Serial.println(strPayload);
                        ! callback_iobroker(strTopic, strPayload);
                        ! void setup() {
                        ! //Serial.begin(57600);
                        ! // Serial.println("start");
                        • I
                          Там проект состоит из двух файлов они должны быть в одном каталоге, если в среде ардуино не появляется вторая вкладка то добавь в проект файл с функциями.
                            Haus last edited by
                            Два файла есть, когда две строчки как писал переставляю в другое место то проект компилируется и работает. Правильно ли это?
                            • I
                              @Haus:
                              Два файла есть, когда две строчки как писал переставляю в другое место то проект компилируется и работает. Правильно ли это? `
                              Выложить свои библиотеки
                                Haus last edited by
                                @instalator:
                                @Haus:
                                Два файла есть, когда две строчки как писал переставляю в другое место то проект компилируется и работает. Правильно ли это? Выложить свои библиотеки
                                #include <spi.h>1.0.0
                                #include <ethernet.h>1.1.1
                                #include <pubsubclient.h>2.4.0
                                #include <servo.h>1.1.1
                                #include <dht.h>DHTlib
                                #include <onewire.h>2.3.1
                                #include <dallastemperature.h>3.7.5
                                Arduino 1.6.6
                                Проблема в чём то другом…..</dallastemperature.h></onewire.h></dht.h></servo.h></pubsubclient.h></ethernet.h></spi.h>
                                • I
                                  @Haus:
                                  @instalator:
                                  @Haus:
                                  Arduino 1.6.6
                                  Проблема в чём то другом…..</dallastemperature.h></onewire.h></dht.h></servo.h></pubsubclient.h></ethernet.h></spi.h> `
                                  Я имел ввиду именно твои библиотеки от твоего проекта.
                                  у меня Arduino 1.6.4
                                  А ты выкинул колбэк из кода у тебя при изменении переменной в iob ардуина реагирует?
                                    @instalator:
                                    А ты выкинул колбэк из кода у тебя при изменении переменной в iob ардуина реагирует? `
                                    Я несколько сообщений назад уже спрашивал, ответа не получил))
                                    @electric69:
                                    @Haus:
                                    А как обстоят дела с подпиской? Данные от ioBroker передаются в ардуину? `
                                      Haus last edited by
                                      Чего то мы не разберёмся. Вот это твой проект который у меня не компилируется. Я в нём сделал изменение в строке 15, 16 (закомментировал) и добавил строку 72, 73(перенёс сюда строку 15, 16) при таком положение всё компилируется. Если тебя не затруднит проверить этот код и ответить на один вопрос, имеет ли какое то значение где расположены по коду эти две строчки? Я в коде дуб :oops:
                                      443_kitchen_mqtt_haus.zip
                                        Haus last edited by
                                        @electric69:
                                        @instalator:
                                        @electric69:
                                        @Haus:
                                        Извини что пропустил вопрос, просто тема про выкинутое слово callbak из строчки сам понял что дурак. :roll:
                                        Сейчас большая проблема с ENC28J60 точней с библиотекой <uipethernet.h>в arduino nano сжирает всю память.</uipethernet.h>
                                        • I
                                          @Haus:
                                          filename="Kitchen_Mqtt_HAUS.zip" index="0">~~ `
                                          У меня компилится и так и так, вообще не пойму что за ошибка у тебя может быть.
                                          А вообще должно все работать так как ты перенес, может в что в новой версии ардуиновкой среды намутили, ща обновлю проверю
                                          • I
                                            Ну да точно, намудрили в 1.6.4 версии. Если вызываеш функцию то она должна быть объявлена до вызова.
                                            Перенеси участок кода````
                                            выше, поставь перед строками:
                                            Хотя можешь оставить как ты сделал, все должно работать норм.
                                            244
                                            71659
