    4. Test Adapter lovelace v0.2.x
      AhleWurscht75 last edited by
      Hallo liebe Community,
      bekomme seit kurzem folgende Fehlermeldung durch den Adapter. Kann mir jemand helfen?
      Danke...
      2019-12-30 14:27:27.387 - info: host.ioBroker instance system.adapter.lovelace.0 terminated with code 0 (NO_ERROR)
      2019-12-30 14:27:27.387 - info: host.ioBroker Restart adapter system.adapter.lovelace.0 because enabled
      2019-12-30 14:27:57.408 - info: host.ioBroker instance system.adapter.lovelace.0 started with pid 21446
      2019-12-30 14:28:03.281 - info: lovelace.0 (21446) starting. Version 1.0.7 in /opt/iobroker/node_modules/iobroker.lovelace, node: v8.12.0
      2019-12-30 14:28:03.361 - info: lovelace.0 (21446) http server listening on port 8099
      2019-12-30 14:28:04.588 - error: lovelace.0 (21446) uncaught exception: Cannot read property 'val' of null
      2019-12-30 14:28:04.589 - error: lovelace.0 (21446) TypeError: Cannot read property 'val' of null
      at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:1638:88)
      at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:483:33)
      at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      at
      at process._tickCallback (internal/process/next_tick.js:189:7)
      2019-12-30 14:28:04.591 - info: lovelace.0 (21446) cleaned everything up...
      2019-12-30 14:28:04.602 - error: lovelace.0 (21446) uncaught exception: Cannot read property 'val' of null
      2019-12-30 14:28:04.603 - error: lovelace.0 (21446) TypeError: Cannot read property 'val' of null
      at
      2019-12-30 14:28:04.657 - info: lovelace.0 (21446) terminating
      2019-12-30 14:28:04.659 - info: lovelace.0 (21446) Terminated (NO_ERROR): Without reason
      2019-12-30 14:28:06.218 - error: host.ioBroker Caught by controller[0]: TypeError: Cannot read property 'val' of null
      2019-12-30 14:28:06.219 - error: host.ioBroker Caught by controller[0]: at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:1638:88)
      2019-12-30 14:28:06.219 - error: host.ioBroker Caught by controller[0]: at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:483:33)
      2019-12-30 14:28:06.219 - error: host.ioBroker Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      2019-12-30 14:28:06.219 - error: host.ioBroker Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      2019-12-30 14:28:06.220 - error: host.ioBroker Caught by controller[0]: at
      2019-12-30 14:28:06.220 - error: host.ioBroker Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:189:7)
      2019-12-30 14:28:06.220 - error: host.ioBroker Caught by controller[1]: TypeError: Cannot read property 'val' of null
      2019-12-30 14:28:06.221 - error: host.ioBroker Caught by controller[1]: at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:1638:88)
      2019-12-30 14:28:06.221 - error: host.ioBroker Caught by controller[1]: at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:483:33)
      2019-12-30 14:28:06.221 - error: host.ioBroker Caught by controller[1]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      2019-12-30 14:28:06.221 - error: host.ioBroker Caught by controller[1]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      2019-12-30 14:28:06.222 - error: host.ioBroker Caught by controller[1]: at process._tickCallback (internal/process/next_tick.js:189:7)
      2019-12-30 14:28:06.222 - info: host.ioBroker instance system.adapter.lovelace.0 terminated with code 0 (NO_ERROR)
      2019-12-30 14:28:06.222 - info: host.ioBroker Restart adapter system.adapter.lovelace.0 because enabled
      • marcuskl
        marcuskl @Garfonso last edited by
        @Garfonso sagte in Test Adapter lovelace v0.2.x:
        Hm.. die Controls sehen aber doch ok aus.. grübel. Noch ein paar Fragen:
        1. Wenn du im ioBroker schaltest bzw. dimmst oder Farbe änderst -> kommt das in lovelace an?
        Ja kommt alles an, Helligkeit, Farbe etc.
        1. Wenn du in Lovelace was machst, gibt es dann einen Fehler im Log? Oder überhaupt eine Meldung? Beim Anschalten müsste eigentlich sowas auftauchen:
        2019-12-30 13:13:03.854  - debug: lovelace.1 (17812) No additional data in service call -> only turn on.
        2019-12-30 13:12:55.988  - debug: lovelace.1 (17812) turn_off alias.0.lamps.Josephine_Decke.state
        Ich glaube ich guck mal, ob ich nicht auch ein manuelles konfigurieren der attribute einbauen kann... das scheint mir irgendwie weniger Ärger zu machen. grübel
        Es kommt dieser Fehler wenn ich Einschalte:
        shelly.0	2019-12-30 14:39:46.683	error	(1253) Datatype for SHRGBW2#5A38A7#1.color.white differs from expected, ignore state change! Please write correct datatype (number)
        Das hier habe ich alle paar Minuten im Log:
        lovelace.0	2019-12-30 14:31:50.049	warn	(1328) Duplicates found for light.Switch
        lovelace.0	2019-12-30 14:31:50.048	warn	(1328) Duplicates found for light.LED_Strips_Wohnzimmer
        lovelace.0	2019-12-30 14:31:50.047	warn	(1328) Could not add shelly.0.SHRGBW2#5A38A7#1.color of type rgbSingle -> no on/off control found.
        • marcuskl
          marcuskl last edited by
          @Garfonso Was mir auch aufgefallen ist, es wird beim Shelly der weiß Dimmwert, wie es aussieht als Schalter erkannt (setzt diesen auf true/false, obwohl es ein Wert 0-100 ist) und der level.color.red als Brightness erkannt:
          • Garfonso
            Garfonso Developer @marcuskl last edited by
            @marcuskl
            ok, jetzt hab ich endlich verstanden, was das Problem ist... hatte das schonmal aber irgendwie ist der Fix etwas rausgeflogen...
            Also, was passiert ist, dass der shelly zweimal erkannt wird, einmal mit richtigem an/aus, Farben und "gain" als Dimmer. Damit sind die States "verbraucht" für die Autoerkennung. Aber "white" ist noch übrig und wird nochmal als Dimmer erkannt, allerdings ohne an/aus und Farbe und da die ID dieselbe ist, wird das Gerät an einer Stelle überschrieben... das ist relativ anfällig für solche Fehler und das würde ich gerne reparieren, würde das aber gerne mit dem ursprünglichen Autor besprechen, da ich aktuell da noch nicht genug verstanden habe.
            Egal, wenn du jetzt nochmal von dem tratschtante-Link installierst, dann sollte das so nicht mehr auftreten und das zweite Gerät ohne an/aus Schalter korrekt ignoriert werden. Wenn es dann der "falsche" Dimmer ist (also du lieber white zum dimmen hättest), dann müsstest du bei gain mal die Rolle ändern oder sowas... zwei Dimmer sind in lovelace nicht vorgesehen... wäre es sinnvoll beide zu setzen mit den %? Oder ist das schon richtig so? Vermutlich ist das aber ein Sonderfall, den der adapter automatisch nicht abdecken sollte..
            marcuskl 1 Reply Last reply Reply Quote 0
            • Garfonso
              Garfonso Developer @Moe last edited by
              @Moe
              Hast du bei dem State manuell Einstellungen vor Lovelace vorgenommen? Dann wird das nicht besser gehen. Die Idee des Adapters ist aktuell, dass du für das ganze Gerät (also im Grunde den "Ordner" in dem die dazugehörigen States liegen) einen Raum und eine Funktion vergibst und der sich dann automatisch zusammenbastelt, wie das passen muss.
              Dazu müssen die States allerdings "richtig" konfiguriert sein, besonders die "role" und der "type". Danach werden die erkannt: https://github.com/ioBroker/ioBroker.type-detector/blob/master/index.js#L299
              Der lovelace adapter unterstützt dann an/aus, aktuelle Temperatur, Luftfeuchtigkeit und Zieltemperatur als Werte/Attribute.
              @AhleWurscht75 said in Test Adapter lovelace v0.2.x:
              Du hast anscheinend einen manuell angelegten entity vom Typ "input_boolean" der keinen state bzw. "null" als state zurück liefert. Da crasht der Adapter. Das müsste man bei den manuellen entities überall noch abfangen, wie es aussieht..
              Aber vielleicht hilft dir das ja schon bei der Fehlersuche.
              A marcuskl 2 Replies Last reply Reply Quote 2
                AhleWurscht75 @Garfonso last edited by
                @Garfonso ja, perfekt - Danke, das isse's 👍
                • marcuskl
                  @Garfonso
                  @marcuskl
                  In Ordnung, habe ich verstanden
                  Ich habe von deinem Link nochmal installiert und es ist immer noch das Problem vorhanden.
                  Und es kommt jetzt noch dieser Error im Log:
                  lovelace.0	2019-12-30 18:01:30.710	error	at funcs.forEach.funcId (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:2767:41)
                  lovelace.0	2019-12-30 18:01:30.710	error	at Array.forEach (<anonymous>)
                  lovelace.0	2019-12-30 18:01:30.710	error	at func.common.members.forEach.id (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:2768:31)
                  lovelace.0	2019-12-30 18:01:30.710	error	at rooms.forEach.roomId (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:2788:38)
                  lovelace.0	2019-12-30 18:01:30.710	error	at WebServer._processIobState (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:2671:26)
                  lovelace.0	2019-12-30 18:01:30.710	error	at controls.forEach.control (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:2673:70)
                  lovelace.0	2019-12-30 18:01:30.710	error	at WebServer._processLightAdvanced (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:1867:28)
                  lovelace.0	2019-12-30 18:01:30.710	error	at WebServer._getLightStateControl (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:1657:19)
                  lovelace.0	2019-12-30 18:01:30.710	error	(2964) [Type-Detector] Cannot process "shelly.0.SHRGBW2#5A38A7#1.color": TypeError: Cannot read property 'type' of undefined stack: TypeError: Cannot read property 'type' of undefined
                  • marcuskl
                    marcuskl @Garfonso last edited by marcuskl
                    @Garfonso Jetzt geht meine ganze Lovelace Ui nicht mehr, kommt ein Error (Cannot get /)
                    Sind plötzlich alle Entitäten weg
                    • Garfonso
                      @marcuskl
                      Ja, sorry, dummer Fehler... crasht leider beim Start... 😞
                      Nochmal neu installieren bitte.
                        Hallo liebe Leute,
                        ich habe mal zwei, wahrscheinlich doofe, Fragen, bzw. Fragen die für euch einfach zu beantworten sind.
                        Wo lege ich den Pictur im .png format ab um sie in den cards anzeigen zu lassen und wie kann ich mir einen gefilterten state (z.B. "true") in einer card mit einem anderen Text anzeigen lassen.
                        Thx for help und guten Rutsch euch allen!
                        • leszy l
                          leszy l last edited by
                          Hi als erstes muss ich sagen super das iobroker Lovelace unterstützt. ich habe gerade alle komplett neu auf und habe zu iobroker tendiert allerdings HA hatte den Vorteil Lovelace. Das vis ist zwar mächtiger fand es sehr kompliziert.
                          Bis habe ich schon geschafft und mich hier durch das ganz auch durchgelesen allerdings scheitert ich an einer Rolläden Steuerung mit Shelly. Ich kriege zwar mit input_number ohne Problem ein Slider hin wurde allerdings gerne noch ein toggel haben um eben direkt hoch zu machen die Rolläden. Am schönsten wäre so eine Card
                          Die kriege ich allerdings nicht hin. Gibt zwar eine spanische Anleitung für HA die kriege ich aber irgendwie nicht auf iobroker umgesetzt https://hassiohelp.eu/2019/05/24/shelly25/
                          Jemand eine Idee wie man es am besten hinkriegt?
                          • marcuskl
                            @Garfonso Kein Problem, hatte zum glück ein Snapshot gemacht 🙂
                            Habe es neu installiert, aber es klappt immer noch nicht mit dem Shelly, der Gain weiß wird immernoch als Switch erkannt 😕
                              Ph4t0n last edited by
                              Moin zusammen!
                              erstmal vielen Dank für die tolle Arbeit!
                              Ich habe gerade ein Problem beim einrichten meiner Sonos Boxen bzw. wollte diese in Lovelace über mini-media-player anzeigen lassen.
                              Das Problem ist, dass mein Lovelace Adapter die Sonos nicht über autodetect gefunden hat.
                              Ich weiß jetzt nicht welche ID aus dem Sonos-Adapter ich als "media_player" definieren muss, sodass ich diese Entity mit dem mini-media-player verwenden kann.
                              Kann mir hier jemand helfen?
                              Viele Grüße
                              • Garfonso
                                Garfonso Developer @Ph4t0n last edited by
                                @Ph4t0n said in Test Adapter lovelace v0.2.x:
                                Moin zusammen!
                                Viele Grüße
                                Manuell wird das nicht gehen, soweit ich das im Code sehe... da wirst du vermutlich die Objekte entsprechend bearbeiten müssen (am besten dann als Aliase) um die Autoerkennung zu triggern. Raum & Funktion hast du aber vergeben?
                                Wie die Types & Roles aussehen sollten, steht hier: https://github.com/ioBroker/ioBroker.type-detector/blob/master/index.js#L102
                                @marcuskl said in Test Adapter lovelace v0.2.x:
                                Aber er crasht nicht mehr? grübel Und es gibt nur das eine Entity?
                                Versuch nochmal neu zu installieren, indem du als URL das hier eingibst (ohne http oder so davor):
                                Garfonso/iobroker.lovelace#rgb
                                Damit müsste die neueste Version auch direkt von Github gehen (ging bei mir, aber guck mal ob da bei der Installation Fehler kommen).
                                marcuskl P 2 Replies Last reply Reply Quote 0
                                • marcuskl
                                  @Garfonso hatte es gestern nochmal installiert, von deinem tratschtante link und jetzt funktioniert es mit dem Shelly 👍 👍
                                  Super Arbeit!
                                  Aber es kommt komischerweise immer noch dieser Warn im Log:
                                  lovelace.0	2020-01-05 10:23:12.857	warn	(32294) Duplicates found for light.Switch
                                  lovelace.0	2020-01-05 10:23:12.853	warn	(32294) Duplicates found for light.Switch
                                  lovelace.0	2020-01-05 10:23:12.839	warn	(32294) Could not add shelly.0.SHRGBW2#5A38A7#1.color of type dimmer -> no on/off control found.
                                  lovelace.0	2020-01-05 10:23:12.838	warn	(32294) Could not add shelly.0.SHRGBW2#5A38A7#1.color of type rgbSingle -> no on/off control found.
                                  Nein, crashen tut er nicht mehr.
                                  Ja, über diesen Dateipfad lässt es sich installieren. 👍
                                  • Garfonso
                                    Garfonso Developer @marcuskl last edited by Garfonso
                                    @marcuskl
                                    Super. 🙂
                                    Dann kann ich in meinen PR ja reinschreiben, dass es zwei erfolgreiche Tester gab.
                                    Ja, die Warnung kommt immer bei der Erkennung. Vielleicht nehme ich die raus oder mach die nur debug.
                                    Edit: Ok, hab's jetzt rausgenommen und das git etwas aufgeräumt (dabei allerdings auch ein paar Branches gelöscht). Neuer Installationurl ist:
                                    https://github.com/Garfonso/ioBroker.lovelace
                                    • marcuskl
                                      @Garfonso Gibt es die Möglichkeit den weißen Gain auch über Lovelace zu steuern ?
                                        Ph4t0n @Garfonso last edited by
                                        @Garfonso
                                        Einen Raum hatte die Sonos zugewiesen aber bei der Function konnte ich nichts wirklich sinnvolles eintragen (da stand mir nur battery, color, heating und security zu Verfügung)
                                        • Garfonso
                                          @Ph4t0n
                                          Dann erstell einfach zusätzliche Funktionen. Im Admin auf "Aufzählungen" gehen.
                                          Die Frage ist, was da passieren soll, bzw. wie... wenn du es einzeln steuern willst, kannst du den natürlich manuell als input_number hinzufügen. Oder soll mit dimmen beides gesetzt werden? Ich hab so etwas bei keiner meiner Lampen und weiß nicht, welches Verhalten sinnvoll ist und was da ggf. Seiteneffekte sein könnten.
                                          • marcuskl
                                            @Garfonso es wäre nicht schlecht, wenn es noch ein extra Slider gäbe, wie bei der Helligkeit, wo man den white.gain von 0 bis 100 Dimmen kann.
                                            So sieht es auf der Shelly Oberfläche aus:
                                            Der obere Dimmer ist für die Color LED's und der untere ist für die White LED's.
                                            So ähnlich könnte man es ja auch in Lovelace Lösen.
                                            call for action lovelace test visualisierung
                                            131
                                            1051
                                            376272
