    4. JavaScript
    5. Script: Alexa Listen pflegen und Anzeigen
      liv-in-sky @Agria4800 last edited by liv-in-sky
      @Agria4800 ich versuche gerade eine neue version - damit kann man auch die abstände der zellen größer machen
      vielleicht auch interessant für deinen ausdruck
      beispiele
      • klein
      • grioßer zellabstand
      • großer zellabstand mit größerer schrift
      Agria4800 1 Reply Last reply Reply Quote 0
        sigi234 Forum Testing Most Active @liv-in-sky last edited by
        @liv-in-sky
          liv-in-sky @sigi234 last edited by
          @sigi234 schick mir doch mal das widget als export
            @liv-in-sky sagte in Script: Alexa Listen pflegen und Anzeigen:
            [{"tpl":"tplVis-materialdesign-Select-Value","data":{"oid":"javascript.0.Eigene_Datenpunkte.Alexa_ToDo_AuswahlDelete","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","values":"1","layout":"outlined","showValueOnRight":"true","vibrateOnMobilDevices":"50","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"z_index":"200","value0":"{javascript.0.Eigene_Datenpunkte.Alexa_ToDo_AuswahlDeleteAuswahl}","value1":"{javascript.0.Eigene_Datenpunkte.Alexa_ToDo_AuswahlDeleteWert}"},"style":{"left":"899px","top":"178px","width":"412px","height":"254px","z-index":"20"},"widgetSet":"materialdesign"}]
            liv-in-sky Scrounger 2 Replies Last reply Reply Quote 0
              @sigi234 genau das problem hatte ich auch damit - da muss man die werte anzahl eingeben (was ja evtl. nocvh mit einem binding geht - aber dann sind weiter unten im widget die einzelnen daten einzutragen - ich denke, das ist nicht mehr machbar
              frag lieber mal beim ersteller nach - ob man da was machen kann
              • Scrounger
                Scrounger Developer @sigi234 last edited by
                @sigi234 sagte in Script: Alexa Listen pflegen und Anzeigen:
                Das wird mit dem MaterialDesign Select Widget nicht gehen, da es keine dynamischen Daten unterstützt, die zum löschen notwendig wären. Das muss ich erst einbauen -> erstellt bitte nen issue dafür bzw. ich glaube das ist das gleiche?
                https://github.com/Scrounger/ioBroker.vis-materialdesign/issues/25
                darkiop created this issue in Scrounger/ioBroker.vis-materialdesign
                closed [Select] Objekt vom typ werteliste "koppeln" #25
                  liv-in-sky @Scrounger last edited by liv-in-sky
                  @Scrounger danke für deine antwort - denkstdu es ist überhaupt möglich, eiinen datenpunkt vom typ werteliste in ein widget einzubinden
                  ich denke, sie habe damit nicht gerechnet, das jmd diese datenpunkte dynamisch anspricht bzw ändert
                    @Agria4800 sagte in Script: Alexa Listen pflegen und Anzeigen:
                    @liv-in-sky Ich hab noch ne Frage: Wie bekomme ich den schwarzen Hintergrund in der html Datei weiß bzw. Transparent?
                    Der Grund hierfür ist, das ich mir die html als pdf umwandele und danach drucken kann.
                    Kann dazu gerne ein paar Infos einstellen, wenn Bedarf ist!
                    machst du die umwandlung von hand oder über eine api ?
                    • Scrounger
                      Scrounger Developer @liv-in-sky last edited by
                      Also Grundsätzlich geht alles, irgendwie 😉
                      Die Idee das Select Widget mit einer Werteliste zu koppeln, hab ich auch schon gehabt. Ob und wie es geht, muss ich aber erst anschauen und ausprobieren.
                      • Agria4800
                        Agria4800 @liv-in-sky last edited by Agria4800
                        @liv-in-sky Ich steuere das per Blockly
                        Installiert habe ich folgendes zum umwandeln von html --> pdf:
                        apt-get install wkhtmltopdf
                        und das Blockly zum umwandeln, ausdrucken und danach löschen... (War gestern abend mal ein Schnellversuch, evtl. muss die pdf nicht gelöscht werden. (noch nicht ausprobiert)
                        [Blockly Import]
                          <variables>
                            <variable type="undefined" id="timeout">timeout</variable>
                            <variable type="undefined" id="timeout2">timeout2</variable>
                          </variables>
                          <block type="control" id="c!|n9vEor(R3@!C%c%BI" x="162" y="137">
                            <mutation delay_input="true"></mutation>
                            <field name="OID">javascript.0.Alexa.ToDo_Liste_drucken</field>
                            <field name="DELAY_MS">5</field>
                              <block type="logic_boolean" id="f(fc(dU9/6M~`l.FK$+w">
                              <block type="on" id="1Y[JfJ:@1lRAd|TIh9!w">
                                  <block type="exec" id="**kj|@E8(,hA(a*jRJ^E">
                                    <mutation with_statement="false"></mutation>
                                    <field name="WITH_STATEMENT">FALSE</field>
                                    <field name="LOG">log</field>
                                    <value name="COMMAND">
                                      <shadow type="text" id="3+:$$)c))?}xQ#5__[~p">
                                        <field name="TEXT">sensors</field>
                                      <block type="text" id="@N*;bdlF.vc7p[LeSy#{">
                                        <field name="TEXT">wkhtmltopdf /opt/iobroker/iobroker-data/files/vis.0/ToDo.html /opt/iobroker/iobroker-data/files/vis.0/ToDo.pdf</field>
                                      <block type="timeouts_settimeout" id="kL.TO7j/UgH{CD6.*|kr">
                                        <field name="DELAY">3</field>
                                          <block type="exec" id="7YQ=LZXR$TNnjt9,pim~">
                                              <shadow type="text" id="%s?Qz`(.Yayhqn6L4Ib[">
                                                <field name="TEXT"></field>
                                              <block type="text" id="XvWiFlFVlJQM|IiP5sK=">
                                                <field name="TEXT">lp /opt/iobroker/iobroker-data/files/vis.0/ToDo.pdf</field>
                                          <block type="control" id="W8_n`GJR%AszF4Sg(s!f">
                                              <block type="logic_boolean" id="k^V0.gv,BQAJ@Hk=VSM*">
                                              <block type="timeouts_settimeout" id="0Lq3cUR_-Q:H+EHf*X{n">
                                                <field name="DELAY">30</field>
                                                  <block type="exec" id="sOXd,DO~gt}u#l_-K,W)">
                                                      <block type="text" id="bDZgaiNkS(.@KNBso:c|">
                                                        <field name="TEXT">rm /opt/iobroker/iobroker-data/files/vis.0/ToDo.pdf</field>
                        • Agria4800
                          @liv-in-sky ja, daran bin ich interessiert 👍 😊
                            liv-in-sky last edited by liv-in-sky
                            es gibt ein update der scripte
                            • wer updaten will sollte sich eine kopie behalten, es muss alles ersetzt werden, da neue settings dazugekommen sind - aus der kopie kann man dann die farben und settings wieder rauskopieren
                            • dazu gekommen ist:
                              -ein etwa bessere html-definition für den browser (falls man sich ein file generieren läßt)
                              -tabellen weite
                              -größe der zellen
                              -das schedule ist jetzt oben einstellbar
                              das bedeuted, man könnte sich berichte über zustände zusammenstellen und diese über eine webseite ansehen (wenn man sich viel arbeit machen möchte 🙂 )
                              • Agria4800
                                ja, im Prinzip schon... ☺ machbar ist alles 😁
                                ich habe das für mich recht simple und zweckgebunden gesehen... mein Ziel war es per Knopfdruck die ToDo / Einkaufsliste zu bekommen...
                                "Einkaufsliste für meine Frau --> ToDo Liste für mich zum abarbeiten 🙂 "
                                  @Agria4800
                                  vielleicht probiere ich das mal aus - manchmal will man einfach papier in der hand haben
                                  ich habe oft nur ein paar wenige sachen - wenn ich dann vor meine standard geschäfte fahre (penny und so) , öffnet sich die webseite auf dem handy automatisch, wenn ich vor dem laden stehe und der motor ausgeht - dann zeigt es mir die 2-3 sachen zur erinnerung an und ich lass das handy einfach im auto - wollte mal etwas mit tasker auf android spielen !
                                  muss mal schauen, ob ich das html file auch zu tasker rüber bekomme - dann ein link auf den desktop und die alexa app bleibt zu
                                  ps: in den neuen scripts ist die größe der zellen und natürlich die schriftgröße einstellbar - dann kannst du am layout deiner pdf's arbeiten
                                    helfi9999 @liv-in-sky last edited by
                                    @liv-in-sky bekomme immer folgenden Fehler:
                                    31.12.2019, 12:41:48.027 [info ]: javascript.0 (25077) script.js.Test.Skript_1: false
                                    31.12.2019, 12:42:00.312 [info ]: javascript.0 (25077) script.js.Test.Skript_1:
                                    31.12.2019, 12:42:04.736 [info ]: javascript.0 (25077) Stop script script.js.Test.Skript_1
                                    31.12.2019, 12:45:55.304 [info ]: javascript.0 (25077) Start javascript script.js.Test.Skript_1
                                    31.12.2019, 12:45:55.355 [warn ]: javascript.0 (25077) at writeHTML (script.js.Test.Skript_1:108:2)
                                    31.12.2019, 12:45:55.355 [warn ]: javascript.0 (25077) at script.js.Test.Skript_1:228:1
                                    31.12.2019, 12:45:55.362 [info ]: javascript.0 (25077) script.js.Test.Skript_1: registered 2 subscriptions and 1 schedule
                                    31.12.2019, 12:45:55.385 [info ]: javascript.0 (25077) script.js.Test.Skript_1: NaN
                                    31.12.2019, 12:45:55.391 [info ]: javascript.0 (25077) script.js.Test.Skript_1:
                                    31.12.2019, 12:45:55.760 [info ]: javascript.0 (25077) script.js.Test.Skript_1: 0:choose ...;1:test;2:seife;3:seife für lena;4:test;5:neuer Start;
                                    31.12.2019, 12:46:00.008 [warn ]: javascript.0 (25077) at writeHTML (script.js.Test.Skript_1:108:2)
                                    31.12.2019, 12:46:00.009 [warn ]: javascript.0 (25077) at Object.<anonymous> (script.js.Test.Skript_1:225:2)
                                    31.12.2019, 12:47:00.232 [warn ]: javascript.0 (25077) at writeHTML (script.js.Test.Skript_1:108:2)
                                    31.12.2019, 12:47:00.232 [warn ]: javascript.0 (25077) at Object.<anonymous> (script.js.Test.Skript_1:225:2)
                                    31.12.2019, 12:47:56.112 [info ]: javascript.0 (25077) script.js.Test.Skript_1: test111
                                    31.12.2019, 12:47:58.124 [warn ]: javascript.0 (25077) at writeHTML (script.js.Test.Skript_1:144:12)
                                    31.12.2019, 12:47:58.124 [warn ]: javascript.0 (25077) at Object.<anonymous> (script.js.Test.Skript_1:248:4)
                                    31.12.2019, 12:47:58.147 [info ]: javascript.0 (25077) script.js.Test.Skript_1:
                                    31.12.2019, 12:47:58.528 [info ]: javascript.0 (25077) script.js.Test.Skript_1: 0:choose ...;1:test;2:seife;3:test111;4:seife für lena;5:test;6:neuer Start;
                                    31.12.2019, 12:48:38.989 [info ]: javascript.0 (25077) script.js.Test.Skript_1: werew
                                    31.12.2019, 12:48:41.003 [warn ]: javascript.0 (25077) at writeHTML (script.js.Test.Skript_1:144:12)
                                    31.12.2019, 12:48:41.003 [warn ]: javascript.0 (25077) at Object.<anonymous> (script.js.Test.Skript_1:248:4)
                                    31.12.2019, 12:48:41.025 [info ]: javascript.0 (25077) script.js.Test.Skript_1:
                                    31.12.2019, 12:48:41.408 [info ]: javascript.0 (25077) script.js.Test.Skript_1: 0:choose ...;1:test;2:seife;3:test111;4:werew;5:seife für lena;6:test;7:neuer Start;
                                    31.12.2019, 12:49:00.416 [info ]: javascript.0 (25077) script.js.Test.Skript_1: werewwwww
                                    31.12.2019, 12:49:02.433 [warn ]: javascript.0 (25077) at writeHTML (script.js.Test.Skript_1:144:12)
                                    31.12.2019, 12:49:02.433 [warn ]: javascript.0 (25077) at Object.<anonymous> (script.js.Test.Skript_1:248:4)
                                    31.12.2019, 12:49:02.449 [info ]: javascript.0 (25077) script.js.Test.Skript_1:
                                    31.12.2019, 12:49:02.835 [info ]: javascript.0 (25077) script.js.Test.Skript_1: 0:choose ...;1:test;2:seife;3:test111;4:werew;5:seife für lena;6:test;7:neuer Start;8:werewwwww;
                                    31.12.2019, 12:51:00.224 [warn ]: javascript.0 (25077) at writeHTML (script.js.Test.Skript_1:144:12)
                                    31.12.2019, 12:51:00.224 [warn ]: javascript.0 (25077) at Object.<anonymous> (script.js.Test.Skript_1:225:2)
                                    31.12.2019, 12:51:00.627 [info ]: javascript.0 (25077) script.js.Test.Skript_1: 0:choose ...;1:seife für lena;2:test;3:neuer Start;4:werewwwww;
                                    31.12.2019, 12:52:00.018 [warn ]: javascript.0 (25077) at writeHTML (script.js.Test.Skript_1:144:12)
                                    31.12.2019, 12:52:00.018 [warn ]: javascript.0 (25077) at Object.<anonymous> (script.js.Test.Skript_1:225:2)
                                    31.12.2019, 12:52:00.421 [info ]: javascript.0 (25077) script.js.Test.Skript_1: 0:choose ...;
                                    31.12.2019, 13:01:32.493 [info ]: javascript.0 (25077) Stop script script.js.Test.Skript_1
                                    Was habe ich verkehrt eingestellt.
                                    Hier noch das Script:
                                    //HIER WIRD PFAD UND FILENAME DEFINIERT
                                    const path = "/htmlexample.html"; //FIlenamen definieren
                                    const home ='vis.0' //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
                                    let braucheEinFile=false; // bei true wird ein file geschrieben - für iqontrol
                                    let braucheEinVISWidget=true; // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
                                    let dpVIS="javascript.0.TabletVis.Einkauf.Vis" //WICHTIG wenn "braucheEinVISWidget" auf true gesetzt !! dp zusätzlich für VIS-HTML-Basic-Widget
                                    let dPDELETE="javascript.0.TabletVis.Einkauf.Delete";
                                    let dPDELETEWert="javascript.0.TabletVis.Einkauf.Delete_Wert";
                                    let dPDELETEAuswahl="javascript.0.TabletVis.Einkauf.Delete_Auswahl";
                                    let dpANLEGEN="javascript.0.TabletVis.Einkauf.Anlegen";
                                    let mySchedule=" * * * * * "; //jede minute
                                    //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 4
                                    var htmlFeld1='Einkaufen'; // überschrift Tabellen Spalte1
                                    var htmlFeld2='Finished'; // überschrift Tabellen Spalte2
                                    var htmlFeld3='Created'; // überschrift Tabellen Spalte3
                                    var htmlFeld4='Since...'; // überschrift Tabellen Spalte4
                                    //hier werden die styles für die tabelle definiert
                                    //ÜBERSCHRIFT ÜBER TABELLE
                                    let htmlUberschrift=true; // mit Überschrift über der tabelle
                                    const htmlFeldUeber="ALEXA Einkauf"; // Überschrift
                                    const htmlFarbUber="white"; // Farbe der Überschrift
                                    //MEHRERE TABELLEN NEBENEINANDER
                                    let mehrfachTabelle=1; // bis zu 4 Tabellen werden nebeneinander geschrieben- verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
                                    const htmlFarbZweiteTabelle="black"; // Farbe der Überschrift bei jeder 2.ten Tabelle
                                    const htmlFarbTableColorUber="black"; // Überschrift in der tabelle - der einzelnen Spalten
                                    //GANZE TABELLE
                                    const backgroundAll="#000000";
                                    const htmlSchriftart="Helvetica";
                                    const htmlSchriftgroesse="13px";
                                    //FELDER UND RAHMEN
                                    const htmlFarbFelderschrift="white"; // SchriftFarbe der Felder
                                    const htmlFarbFelderschrift2="white"; // SchriftFarbe der Felder für jede 2te Tabelle
                                    const htmlFarbTableColorGradient1="#66b8ea"; // Gradient - Hintergrund der Tabelle - Verlauffarbe
                                    const htmlFarbTableColorGradient2="#5f85cf"; // Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                                    const htmlFarbTableBorderColor="#2C7FB6"; // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
                                    const htmlRahmenLinien=1; // Format für Rahmen(Gitter)linien 1=alle - 2=nur vertikal - 3= nur horizontal - 4=keine
                                    // HIER NICHTS ÄNDERN
                                    const htmlEnd= '</table></body>';
                                    const htmlStart= "<!DOCTYPE html><html lang="de"><head><title>Vorlage</title><meta http-equiv="content-type" content="text/html; charset=utf-8"></head><body bgcolor=""+backgroundAll+"">";
                                    //const htmlUeber= "<p style="color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold">"+htmlFeldUeber+"</p>";
                                    const htmlTabStyleCol= "<table bordercolor=""+htmlFarbTableBorderColor+"" border="3" cellspacing="3" cellpadding="3" rules="cols" style="color:"+htmlFarbFelderschrift+"; font-size:"+htmlSchriftgroesse+
                                    "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");">";
                                    const htmlTabStyleRow= "<table bordercolor=""+htmlFarbTableBorderColor+"" border="3" cellspacing="3" cellpadding="3" rules="rows" style="color:"+htmlFarbFelderschrift+"; font-size:"+htmlSchriftgroesse+
                                    const htmlTabStyleAll= "<table bordercolor=""+htmlFarbTableBorderColor+"" border="3" cellspacing="3" cellpadding="3" rules="all" style="color:"+htmlFarbFelderschrift+"; font-size:"+htmlSchriftgroesse+
                                    const htmlTabStyleNone= "<table bordercolor=""+htmlFarbTableBorderColor+"" border="3" cellspacing="3" cellpadding="3" rules="none" style="color:"+htmlFarbFelderschrift+"; font-size:"+htmlSchriftgroesse+
                                    const htmlTabUeber1="<tr style="color:"+htmlFarbTableColorUber+"; font-weight: bold">";
                                    const htmlTabUeber3="</tr>";
                                    //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 4
                                    var htmlTabUeber2="<td align=center> "+htmlFeld1+" </td><td align=center> "+htmlFeld2+" </td><td align=center> "+htmlFeld3+" </td><td align=center> "+htmlFeld4+" </td>";
                                    var htmlTabUeber2_1="<td align=center style="color:"+htmlFarbZweiteTabelle+""> "+htmlFeld1+" </td><td align=center style="color:"+htmlFarbZweiteTabelle+""> "+htmlFeld2+
                                    " </td><td align=center style="color:"+htmlFarbZweiteTabelle+""> "+htmlFeld3+" </td><td align=center style="color:"+htmlFarbZweiteTabelle+""> "+htmlFeld4+
                                    " </td>";
                                    var htmlOut="";
                                    var mix;
                                    var counter;
                                    var myIDArr=[];
                                    var warte;
                                    var myRememberList="";
                                    function writeHTML(){
                                     var htmlTabStyle;
                                    switch (+htmlRahmenLinien) {
                                    case 1: htmlTabStyle=htmlTabStyleAll; break;
                                    case 2: htmlTabStyle=htmlTabStyleCol; break;
                                    case 3: htmlTabStyle=htmlTabStyleRow; break;
                                    case 4: htmlTabStyle=htmlTabStyleNone; break;
                                    htmlOut="";
                                    counter=-1;
                                    var htmlTabUeber="";
                                    switch (mehrfachTabelle) {
                                    case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3; break;
                                    case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                                    case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2+htmlTabUeber2+htmlTabUeber3; break;
                                    case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                                    //HIER SIND DIE § WERTE, DIE IN DER SCHLEIFE GEFILTERET WER%DEN - Jede spalte einen wert
                                    var val1; var val2; var val0; var val3; var valSort; var valID; var myListWerte=""; var myListAuswahl="";
                                    setState(dPDELETE,0);
                                    var myArr=[]; var myList=""; var myListArr=[]; myIDArr=[];
                                    myListArr.push('0'+":"+'choose ...'+";");
                                    myListWerte=myListWerte+"choose ..."+";";
                                    myListAuswahl=myListAuswahl+(0+";");
                                    myIDArr.push("dummy");
                                    $('alexa2.0.Lists.SHOPPING_LIST.items.*.value').each(function(id, i) { // hier eigene schleife definierenalexa2.0.Lists.SHOPPING_LIST.items.0f43141e-029c-4860-bcd0-828702b0dc86.value
                                           val0=getState(id).val;
                                           val1=getState(id.replace("value","completed")).val;
                                           val2=valSort=getState(id.replace("value","updatedDateTime")).val;
                                           valID=getState(id.replace("value","id")).val;
                                           myIDArr.push(valID);
                                           var yy= (Math.round((new Date()).getTime() / 1000))-Math.round(val2/1000);
                                           val2=formatDate(getDateObject(val2), "TT.MM - SS:mm:ss")
                                           val3=(Math.floor( ((yy)/60/60/24) )+"d "+ Math.floor(((yy)/60/60) % 24) +"h "+ Math.floor( ((yy)/60) % 60 )+" m")
                                           if (val1==false) {val1="❌"} else{val1="✅"}
                                           myArr.push([val0,val1,val2,val3,valSort]);
                                           val0=val0.replace(/,/g,'-');
                                           myListArr.push((i+1)+":"+val0+";");
                                           myListWerte=myListWerte+val0+";";
                                           myListAuswahl=myListAuswahl+(i+1)+";";
                                        //log (myListArr.toString());
                                       for (var x=0;x<myListArr.length;x++){
                                         myList=myList.concat(myListArr[x]);
                                        // log(myListArr[x]);
                                         //log(myList);
                                       //log("-----------myList : "+myList)
                                       if(myList!=myRememberList){
                                           setState(dPDELETEWert,myListWerte);
                                           setState(dPDELETEAuswahl,myListAuswahl);
                                         var timeout = setTimeout(function () {
                                            var obj = getObject(dPDELETE);
                                            obj.common.states=myList;
                                            myRememberList=myList;
                                            log(myList);
                                            setObject(dPDELETE, obj);
                                         }, 400);
                                    //SORT
                                    myArr.sort(function (alpha, beta) {
                                    if (alpha[4] > beta[4])
                                    return -11;
                                    if (beta[4] > alpha[4])
                                    return 1;
                                    return 0;
                                    for (var x=0 ; x<myArr.length ; x++) {
                                    counter++;
                                    //HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT - hat man oben 2 Felder definiert, braucht man hier 2 Werte
                                    val0=myArr[x][0];
                                    val1=myArr[x][1];
                                    val2=myArr[x][2];
                                    val3=myArr[x][3];
                                     //HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT - hat man oben 4 Felder definiert, braucht man hier 4 Werte
                                         case 1:                    htmlOut=htmlOut+"<tr><td>&ensp;"+val0+"&ensp;</td><td align=center>&ensp;"+val1+"&ensp;</td><td align=center>&ensp;"+val2+"&ensp;</td><td align=center>&ensp;"+val3+"&ensp;</td></tr>"; break;
                                        case 2:  if(counter%2==0)  {htmlOut = htmlOut+"<tr><td>&ensp;"+val0+"&ensp;</td><td align=center>&ensp;"+val1+"&ensp;</td><td align=center>&ensp;"+val2+"&ensp;</td><td align=center>&ensp;"+val3+"&ensp;</td>"; }
                                                              else {htmlOut = htmlOut+"<td style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td></tr>";} break;
                                        case 3: if(counter%3==0 )  {htmlOut = htmlOut+"<tr><td>&ensp;"+val0+"&ensp;</td><td align=center>&ensp;"+val1+"&ensp;</td><td align=center>&ensp;"+val2+"&ensp;</td><td align=center>&ensp;"+val3+"&ensp;</td>"; }
                                                              else { if(counter%3==1 )  { htmlOut = htmlOut+"<td style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td>";}
        else    {htmlOut = htmlOut+"<td>&ensp;"+val0+"&ensp;</td><td align=center>&ensp;&ensp;"+val1+"&ensp;</td><td align=center>&ensp;"+val2+"&ensp;</td><td align=center>&ensp;"+val3+"&ensp;</td></tr>";}
        } break;
                                        case 4: if(counter%4==0)  {htmlOut = htmlOut+"<tr><td>&ensp;"+val0+"&ensp;</td><td align=center>&ensp;"+val1+"&ensp;</td><td align=center>&ensp;"+val2+"&ensp;</td><td align=center>&ensp;"+val3+"&ensp;</td>"; }
        else {if(counter%2==1 )  { htmlOut = htmlOut+"<td style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td>";}
        else    {if(counter%2==1 && counter%4==3)  { htmlOut= htmlOut+"<td style=\"color:"+htmlFarbFelderschrift2+"\"&ensp;>"+val0+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td></tr>";}
        else    {htmlOut = htmlOut = htmlOut+"<td>&ensp;"+val0+"&ensp;</td><td>&ensp;"+val1+"&ensp;</td><td align=center>&ensp;"+val2+"&ensp;</td><td align=center>&ensp;"+val3+"&ensp;</td>";}}
        } break;
                                     } //switch ende
                                    }; //Schleifen ende
                                    // tabelle fertigstellen
                                    case 1: break;
                                    case 2: mix=Math.abs(((counter+1)%2)-mehrfachTabelle);
                                    if(mix==1) htmlOut = htmlOut.replace(/</td>$/, '</td><td> </td><td> </td><td> </td><td> </td></tr>');
                                    break;
                                    case 3: mix =Math.abs(((counter+1)%3)-mehrfachTabelle);
                                    if(mix==2) htmlOut = htmlOut.replace(/</td>$/, '</td><td> </td><td> </td><td> </td><td> </td><td> </td><td> </td><td> </td><td> </td></tr>');
                                    break;
                                    case 4: mix=Math.abs(((counter+1)%4)-mehrfachTabelle);
                                    if(mix==3) htmlOut = htmlOut.replace(/</td>$/, '</td><td> </td><td> </td><td> </td><td> </td><td> </td><td> </td><td> </td><td> </td><td> </td><td> <td> </td><td> </td></td></tr>');
                                    break; }
                                          //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                                           var htmlOutVIS="";
                                           const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"&ensp;&ensp;&ensp;"+(counter+1)+"</p>";
                                           htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"
                                           //log(htmlOutVIS);
                                           if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
                                    //mit oder ohne überschrift
                                    htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
                                    //log(htmlOut);
                                    setState(dpANLEGEN,"");
                                    } // function ende
                                    //hier wird schleife gestartet und das file geschrieben
                                    schedule(mySchedule, function () {
                                    writeHTML();
                                    if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/ });}
                                    writeHTML();
                                    on({id: dPDELETE, ack: false, change: "ne"}, function (obj) {
                                    let a=getState(dPDELETE).val;
                                    if (a!=0){
                                    let toDelete=myIDArr[getState(dPDELETE).val];
                                    var stateHelp="alexa2.0.Lists.SHOPPING_LIST.items."+toDelete+".#delete"
                                    setState(stateHelp,true);
                                    writeHTML(); }, 2000);
                                    log(a+stateHelp)
                                    on({id: dpANLEGEN, ack: false, change: "ne"}, function (obj) {
                                    log(getState(dpANLEGEN).val);
                                    if(getState(dpANLEGEN).val!="") {
                                    setState("alexa2.0.Lists.SHOPPING_LIST.#New",getState(dpANLEGEN).val)
                                    Hoffe du kannst mir helfen
                                      liv-in-sky @helfi9999 last edited by
                                      @helfi9999 erste vermutung
                                      hast du den datenpunkt (dpDELETE) mit typ werteliste als datenpunkt angelegt ?
                                      • Agria4800
                                        @Agria4800
                                        Das ist natürlich auch ne prima Sache, aber nix für meine Frau...da geht nur das gute alte Papier 😉
                                        Ich bin grad unter Zeitdruck, wollte nur mal schnell testen,... die Größe der Tabelle und die Schrift ändern geht... aber der Hintergrund außerhalb der Tabelle bleibt schwarz bei mir... (Vielleicht mache ich auf die schnelle was falsch)
                                        geändert habe ich :
                                        35 I const backgroundAll="white"; #ffffff will auch nicht....
                                        Geh heute Abend nochmal in Ruhe dran
                                          @helfi9999
                                          bitte stelle die scripts mit dem code tag ins forum - also zuerst spoiler - dann im spoiler den code tag
                                          https://forum.iobroker.net/post/348376
                                              -tabellen weite
                                              -größe der zellen
                                            Puh, gerade mit der Vis fertig geworden. Umbauen.
                                            javascript template
                                            29
                                            409
                                            78408
