    5. Xiaomi Bewegungsmelder und Sonoff
      Jan1 @deta last edited by Jan1
      @deta
      doch ist gleich der erste Block
       <variables>
         <variable type="" id="b6C.}5i;irmub]HRd:F3">durch Bewegung aktiviert</variable>
         <variable type="undefined" id="timeout">timeout</variable>
       </variables>
       <block type="on" id="gh9^ZFXoO2V`xl}0(:32" x="-812" y="-612">
         <field name="OID">zigbee.0.00158d0002ea07ac.occupancy</field>
           <block type="controls_if" id="b1-mpyGFJCyUO0@KXDES">
               <block type="logic_compare" id="i6,DcT*Fo),2#VckyV8s">
                 <field name="OP">LT</field>
                   <block type="get_value" id="oq]9w#ZU2:v9lUe}LBaS">
                     <field name="OID">zigbee.0.00158d0002ea07ac.illuminance</field>
                   <block type="math_number" id="N?+P},RB!X-%OS/!,m5i">
                     <field name="NUM">20</field>
               <block type="control" id="=]3-?D2/rVEd+K=:mYw7">
                 <field name="OID">sonoff.0.Sonoff-Flur_1.POWER</field>
                   <block type="logic_boolean" id="CUC6y~|6/(LK)@Q::yrW">
                   <block type="variables_set" id=";3gjqI.v=oXV-Xn;_Wv#">
                     <field name="VAR" id="b6C.}5i;irmub]HRd:F3" variabletype="">durch Bewegung aktiviert</field>
                       <block type="logic_boolean" id="gxsnpYVLC~LIp@,61Uy{">
           <block type="on" id="CE3nUa2,Td/5hbLxX@z=">
             <field name="OID">zigbee.0.00158d0002ea07ac.no_motion</field>
               <block type="timeouts_cleartimeout" id="-t[sG.^RSc]4e7N6al_c">
                   <block type="timeouts_settimeout" id="otU|AoV+X~ngM49?pFDA">
                     <field name="DELAY">9</field>
                       <block type="controls_if" id="nJOmgtQ;vS7}*ZBlnQZ5">
                           <block type="logic_operation" id="f^r|)cn|g`2/0%bN.W5P" inline="false">
                             <field name="OP">AND</field>
                               <block type="logic_compare" id="S/JnAFH=NEJIJ,Lc_lWD">
                                 <field name="OP">GT</field>
                                   <block type="on_source" id=":EOf@^5K?=/R!y6Um5,~">
                                   <block type="math_number" id="swf{T/Z9r$eXwK^q*];g">
                                     <field name="NUM">30</field>
                               <block type="variables_get" id="q9_C8GOti4,cZ^]hZ$7q">
                           <block type="control" id=":u#0[0}`(^e7C:(HJ8Lz">
                               <block type="logic_boolean" id=",XF`s(J3#U|;=)W`|HFf">
                               <block type="variables_set" id="o}(6GL7LHjalNsf^Ghmn">
                                   <block type="logic_boolean" id="n+f/xY2~o.7@RfTUEPw+">
      Ich habe keine Begrenzung für die Uhrzeit mit drin, da wenn ich über die Helligkeit abfrage ja automatisch immer Licht habe wenn es zu dunkel ist und ich es für meine Bedürfnisse überflüssig finde. Kann man aber leicht mit ner UND Verknüpfung implementieren.
      So läuft das bei mir und lediglich wenn der blöde Kater nachts im Flur wandert, geht eben mal das Licht an😊
        deta Most Active last edited by
        Danke, dein Skript funktioniert 🙂
        Klasse. Dann kann ich das die Tage mal intigieren....
        Wo hast du die BWM installiert?
          deta Most Active @Jan1 last edited by
          @Jan1 sagte in Xiaomi Bewegungsmelder und Sonoff:
          HAHA, genau das hat meine Frau auch gesagt, wenn die Katze durch den Raum läuft geht dann immer auch Nachts das Licht an 🙄
            @deta
            Die BWM sind nicht gerade die besten, weil erstens der Lux Wert nur bei Bewegung übermittelt wird, sie zwar sehr schnell auf Bewegung reagieren, aber wenn im Zielbereich weiter hin Bewegung herrscht, diese auch sehr deutlich sein muss. Also nur bisschen rum stehen ist keine Bewegung.
            Wo ich die installiert habe? am Ende des Flur an der Decke.
            Das mit der Katze stört mich nicht wirklich, da der Kater meine Holde so erzogen hat, dass sie aufsteht und ihn rauslässt wenn er das möchte. Wenn Licht angeht und das keiner merkt, steht er eh 5 Minuten später schreiend im Schlafzimmer und dann ist eh rum.
            haselchen D 2 Replies Last reply Reply Quote 0
            • haselchen
              haselchen Most Active @Jan1 last edited by
              @Jan1
              Wir haben 3 von den Fellnasen. Besser kannst du Anwesenheit nicht simulieren als mit nem BWM, Licht und 3 Katzen 😂😂😂
                Jan1 @haselchen last edited by
                @haselchen
                OT:
                Meiner ist Freigänger und zu Hause bewegt er sich nur von seinem Kratzbaum runter, wenn er raus will (er muss mal), oder er hat Hunger. Sonst bewegt er sich kein Meter. So bekommst keine Simulation zu Stande 😎
                haselchen 1 Reply Last reply Reply Quote 1
                • haselchen
                  @Jan1
                  Hahahahahahaha , der ist ja fast wie ich 😎😉
                    @haselchen
                    Komisch das mein Frauchen auch über mich, "Du bist wie der Kater".
                      @Jan1 Das mit dem BWM wollte ich im Keller erst mal installieren. Bis jetzt geht das Licht noch per schalter, aber es wird immer wieder vergessen unten das Licht auszumachen, vor allen die Kinder... Oder im Bad , Toilette ....
                      Mit dem Radius muss ich mal sehen dann vom BWM ggf. muss ich im Keller 2 Stück installieren davon.
                      Oben an der Treppe und unten einen.
                      Na wir haben nur eine Katze, werde ich dann sehen.. Geht ja dann wieder alleine aus 😂
                        @deta
                        Da musst aufpassen bei den Dingern, wenn keine Bewegung erkannt wird und abgeschaltet wird, dann dauert es 10 Sekunden, bis die wieder reagieren. Das habe ich mit dem 9 Sekunden Timeout und dem DP occupancy_timeout auf 10 Sekunden abgefangen. So dauert es nur 1 Sekunde, was zwar immer noch blöd ist, aber ne besser Lösung ist mir nicht eingefallen.
                        Also wenn das einer besser lösen kann, ich bin interessiert.
                          crunchip Forum Testing Most Active @deta last edited by
                          @deta hab das noch gefunden, vllt wäre das auch interessant Automatisches Licht
                          587
