    4. Test Adapter onvif-alt v0.1.x
    • Segway
      Segway @Jey Cee last edited by Segway
      @Jey-Cee
      Moin ich hänge mich hier auch rein.
      Hab die 0.0.2 Version installiert.
      Habe eine Scricam SP007 die nur einen rtsp stream liefert ohne benutzername und passwort.
      Leider findet der Adapter nichts:
      onvif.0	2020-01-01 12:18:12.756	debug	(5942) stateChange onvif.0.discoveryRunning {"val":false,"ack":true,"ts":1577877492727,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1577877486238}
      onvif.0	2020-01-01 12:18:12.754	debug	(5942) startCameras: []
      onvif.0	2020-01-01 12:18:12.716	debug	(5942) startCameras
      onvif.0	2020-01-01 12:18:12.679	info	(5942) starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.onvif, node: v12.14.0
      onvif.0	2020-01-01 12:18:08.143	debug	(2292) system.adapter.admin.0: logging true
      onvif.0	2020-01-01 12:18:08.083	info	(2292) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      onvif.0	2020-01-01 12:18:08.082	info	(2292) terminating
      onvif.0	2020-01-01 12:18:08.081	debug	(2292) cleaned everything up...
      onvif.0	2020-01-01 12:18:08.078	info	(2292) Got terminate signal TERMINATE_YOURSELF
      onvif.0	2020-01-01 12:18:06.248	debug	(2292) startCameras: []
      onvif.0	2020-01-01 12:18:06.242	debug	(2292) stateChange onvif.0.discoveryRunning {"val":false,"ack":true,"ts":1577877486238,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1577877486238}
      onvif.0	2020-01-01 12:18:06.236	debug	(2292) sendTo "discovery" to system.adapter.admin.0 from system.adapter.onvif.0
      onvif.0	2020-01-01 12:18:06.235	debug	(2292) Discovery finished
      onvif.0	2020-01-01 12:18:06.233	debug	(2292) startCameras
      onvif.0	2020-01-01 12:17:56.209	debug	(2292) stateChange onvif.0.discoveryRunning {"val":true,"ack":true,"ts":1577877476192,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1577877476192}
      onvif.0	2020-01-01 12:17:56.190	debug	(2292) a.b.c.d 554
      onvif.0	2020-01-01 12:17:56.188	debug	(2292) Received "discovery" event
      onvif.0	2020-01-01 12:17:42.237	debug	(2292) system.adapter.admin.0: logging false
      onvif.0	2020-01-01 12:17:35.228	debug	(2292) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.onvif.0
      über vlc kommt der stream per
      rtsp://a.b.c.d:554/onvif1
      • Jey Cee
        Jey Cee Developer @Segway last edited by
        @Segway Sorry die 0.0.2 ist nicht von mir, das ist eine von 2 Versionen die nicht mehr Weiterentwickelt wird und von meiner ersetzt werden soll. Die Version 0.1.0 ist eine Komplette neu Entwicklung.
        Deshalb kann ich dir da nicht weiterhelfen.
        Segway 2 Replies Last reply Reply Quote 0
        • Segway
          @Jey-Cee
          Oh, okay, verstanden. installiere das mal über die Katze / Github Link ! Melde mich 🙂
          • Segway
            @Jey-Cee
            okay, hat meine Kamera gefunden - und was nun ?
            • Jey Cee
              @Segway Benutzername und passwort der Kamera eingeben, Speicherund Schließen, dann holt er sich alles an Infos von der Cam was er kriegen kann. Da sollte auch der rtsp Stream Link dabei sein.
              • Segway
                @Jey-Cee
                Jo habe ich ja, aber die Cam hat keinen Benutzernamen und Passwort. Brauche ich in dem VLC Link wo es geht auch nicht eingeben.
                Als Objekte werden nur folgende angelegt:
                • Jey Cee
                  Jey Cee Developer @Knallochse last edited by
                  @Knallochse Danke, der Drucker benutzt das gleiche Protokoll um gefunden zu werden. Hab jetzt einen Filter eingebaut damit wirklich nur Kameras gefunden werden.
                  • Knallochse
                    Knallochse last edited by Knallochse
                    @Jey-Cee könnte man über onvif die RSSI Werte der WLAN Verbindung der Kameras auslesen?
                    Meine Kameras verbinden sich manchmal mit dem falschen Repeater (Sch... Mesh).
                    So könnte man auf Grund von schlechten Verbindungswerten einen Reboot starten.
                    Neuschwansteini Jey Cee 2 Replies Last reply Reply Quote 0
                    • Neuschwansteini
                      Neuschwansteini @Knallochse last edited by
                      @Knallochse hast du AVM Kisten?
                      Hatte mit dem "Mesh" auch so meine Probleme.. schau mal, so gehts bei mir sehr gut :
                      hab permanent zwischen 245 und 300 Geräte im Netz..
                      Knallochse 1 Reply Last reply Reply Quote 1
                      • Jey Cee
                        @Knallochse sagte in Test Adapter onvif v0.1.x:
                        Es gibt tatsächlich die Möglichkeit per onvif WLAN Informationen ab zu rufen, aber ich weis nicht ob RSSI Werte auch dabei sind. Zumindest sollte es möglich sein nach WLANs in Reichweite zu scannen wenn die Kamera das Unterstützt.
                        Knallochse 1 Reply Last reply Reply Quote 0
                        • Knallochse
                          Knallochse @Neuschwansteini last edited by
                          @ilovegym ja, Fitzbox 7580+3 AVM Repeater.
                          Ich habe mal deine Einstellungen übernommen. Jetzt beobachte ich das Verhalten der WLAN Geräte .
                          Vielen Dank und ein gesundes neues Jahr 👍
                          Neuschwansteini 1 Reply Last reply Reply Quote 0
                          • Neuschwansteini
                            @Knallochse Danke, auch frohes neues !
                            Hab 18 Kameras, und seitdem ist Ruhe, da das Mesh versucht hat, die Streams woanders hin zu connecten, was zu abrissen führte..
                            • Knallochse
                              Knallochse @Jey Cee last edited by
                              @Jey-Cee sagte in Test Adapter onvif v0.1.x:
                              Bei meinen Kameras kann man über das WebUI einen Suchlauf anleiern, und es werden alle erkannten Netzwerke aufgelistet.
                                ChrisXY last edited by
                                hm was ist wenn die cams unterschiedliche Logins haben ? Es wurden 3 gefunden auch mit Bild. Ohne Zugangsdaten. Schön wäre wenn man draufklicken kann und die Speziellen Login Daten der gefunden Cam einzutragen
                                • Jey Cee
                                  Jey Cee Developer @ChrisXY last edited by
                                  @ChrisXY sagte in Test Adapter onvif v0.1.x:
                                  Du meinst wenn eine Cam mehrere Logins hat? Das macht für mich keinen Sinn, ioBroker ist in meinen Cams der Administrator und kann damit alles machen. Warum sollte ich mehrere Benutzer anlegen wenn es auch einer tut.
                                  Vielleicht bau ich das irgendwann ein, aber das hat sehr niedrige Priorität.
                                  • Glasfaser
                                    Glasfaser @Dr. Bakterius last edited by Glasfaser
                                    @Dr-Bakterius
                                    Test mal hier , was als Log Ausgabe folgt .
                                    In der Instanz JavaScript , das Modul node-onvif eintragen
                                    JavaScript :
                                    /// ONVIF Ausgabe ioBroker 01.01.2020 Glasfaser
                                    const onvif = require('node-onvif');//
                                    console.log('Start the discovery process.');
                                    // Find the ONVIF network cameras.
                                    // It will take about 3 seconds.
                                    onvif.startProbe().then((device_info_list) => {
                                      console.log(device_info_list.length + ' devices were found.');
                                      // Show the device name and the URL of the end point.
                                      device_info_list.forEach((info) => {
                                        console.log('- ' + info.urn);
                                        console.log('  - ' + info.name);
                                        console.log('  - ' + info.xaddrs[0]);
                                    }).catch((error) => {
                                      console.error(error);
                                    So sieht es dann aus :
                                    • Glasfaser
                                      Glasfaser @Jey Cee last edited by Glasfaser
                                      @Glasfaser sagte in Test Adapter onvif v0.1.x:
                                      Laut Doku von onvif-nvt ,
                                      Auf die habe ich gehört, deswegen hat es auch nicht funktioniert. Die Doku sagt callback geht und so hatte ich es versucht, aber tatsächlich geht nur der Promise weg.
                                      Hab heute nacht noch viel probiert, aber auf das bin ich erst heute morgen gekommen.
                                      Habe sonst dieses Script für eine Cam genutzt , was auch gut funktioniert.
                                      (War hier aus dem Forum)
                                      Dort wird Preset auch angesprochen , vielleicht kannst du damit etwas anfangen !???
                                      Instanz Javascript Modul eintragen : node-onvif
                                      Ab Zeile 219 anpassen // Create an OnvifDevice object
                                      xaddr :http://deineIP/onvif/device_service
                                      user :
                                      pass :
                                      const fC = false;
                                      const logging = false;
                                      const pfad = 'javascript.' + instance + '.VIS.Kamera.1.PTZ.';
                                      const idSpeed     = pfad + 'Geschwindigkeit';
                                      const idStoppzeit = pfad + 'Stoppzeit';
                                      const idStopp =     pfad + 'Stopp';
                                      const idRechts =    pfad + 'rechts';
                                      const idLinks =     pfad + 'links';
                                      const idHoch =      pfad + 'hoch';
                                      const idRunter =    pfad + 'runter';
                                      const idZoomIn =    pfad + 'ZoomIn';
                                      const idZoomOut =   pfad + 'ZoomOut';
                                      const idGotoPreset =   pfad + 'gotoPreset';
                                      const fs = require('fs');
                                      createState(idSpeed, 1, fC, {
                                        def: 1,
                                        min: 0,
                                        max: 1,
                                        name: 'Kamera 1 PTZ Geschwindkeit bei Bewegung',
                                        desc: 'Geschwindigkeit von 0-1 bei der Bewegung',
                                        type: 'number'
                                      createState(idStoppzeit, 1, fC, {
                                        def: 0,
                                        min: 0,
                                        name: 'Kamera 1 PTZ Stoppzeit',
                                        desc: 'Dauer in Sekunden bis zum Stopp der Bewegung',
                                        type: 'number',
                                        unit: 's'
                                      createState(idStopp, false, fC, {
                                        def: false,
                                        name: 'Kamera 1 PTZ Stopp',
                                        desc: 'Sofortiger Stopp der Bewegung',
                                        type: 'boolean',
                                        role: 'switch'
                                      createState(idRechts, false, fC, {
                                        def: false,
                                        name: 'Kamera 1 PTZ rechts',
                                        desc: 'Bewegung nach rechts',
                                        type: 'boolean',
                                        role: 'switch'
                                      createState(idLinks, false, fC, {
                                        def: false,
                                        name: 'Kamera 1 PTZ links',
                                        desc: 'Bewegung nach links',
                                        type: 'boolean',
                                        role: 'switch'
                                      createState(idHoch, false, fC, {
                                        def: false,
                                        name: 'Kamera 1 PTZ oben',
                                        desc: 'Bewegung nach oben',
                                        type: 'boolean',
                                        role: 'switch'
                                      createState(idRunter, false, fC, {
                                        def: false,
                                        name: 'Kamera 1 PTZ unten',
                                        desc: 'Bewegung nach unten',
                                        type: 'boolean',
                                        role: 'switch'
                                      createState(idZoomIn, false, fC, {
                                        def: false,
                                        name: 'Kamera 1 PTZ Zoom in',
                                        desc: 'Bild vergößern',
                                        type: 'boolean',
                                        role: 'switch'
                                      createState(idZoomOut, false, fC, {
                                        def: false,
                                        name: 'Kamera 1 PTZ Zoom out',
                                        desc: 'Bild verkleinern',
                                        type: 'boolean',
                                        role: 'switch'
                                      createState(idGotoPreset, 0, fC, {
                                        def:  0,
                                        name: 'Kamera 1 PTZ Preset Wähler',
                                        desc: 'Preset auswählen (Zahlen von 1 bis X)',
                                        type: 'number'
                                      //Find the ONVIF network cameras
                                      onvif.startDiscovery((info) => {
                                      // Stop the discovery process in 3 seconds
                                      setTimeout(() => {
                                      onvif.stopDiscovery(() => {
                                        log('Stopped the discovery process.');
                                      {1}
                                      }, 3000);
                                      const device = new onvif.OnvifDevice({
                                        xaddr: 'http://deineIP/onvif/device_service',
                                        user : 'xxxxxxxxx',
                                        pass : 'xxxxxxxxx'
                                      function movePTZ (ptz_x, ptz_y, ptz_z, stoptime) {
                                        // https://github.com/futomi/node-onvif#ptzmoveparams-callback
                                        device.init((error) => {
                                            if (error) {
                                                log('[ERROR] ' + error.message);
                                                return;
                                            } else {
                                                // +++ CONTROL via PTZ
                                                var ptzlog = '';
                                                ptz_x = (ptz_x <=1 && ptz_x >=-1) ? ptz_x : 0;
                                                ptz_y = (ptz_y <=1 && ptz_y >=-1) ? ptz_y : 0;
                                                ptz_z = (ptz_z <=1 && ptz_z >=-1) ? ptz_z : 0;
                                                if (ptz_x > 0) ptzlog = 'Schwenk nach rechts';
                                                if (ptz_x < 0) ptzlog = 'Schwenk nach links';
                                                if (ptz_y > 0) ptzlog = 'Schwenk nach oben';
                                                if (ptz_y < 0) ptzlog = 'Schwenk nach unten';
                                                if (ptz_z > 0) ptzlog = 'Zoom in';
                                                if (ptz_z < 0) ptzlog = 'Zoom out';
                                                ptzlog += ' für ' + stoptime + 's';
                                                if (logging) log(ptzlog);
                                                // Create the parameters
                                                var params = {
                                                    'speed': {
                                                        x: ptz_x, // Speed of pan (in the range of -1 to 1.0)
                                                        y: ptz_y, // Speed of tilt (in the range of -1 to 1.0)
                                                        z: ptz_z  // Speed of zoom (in the range of -1 to 1.0)
                                                    'timeout': 30 // seconds
                                                // Move the camera
                                                device.ptzMove(params, (error) => {
                                                    if (error) {
                                                        log(error.message, 'error');
                                                    } else {
                                                        log('Camera moved!');
                                                // Stop to the PTZ in X seconds
                                                setTimeout(() => {
                                                    device.ptzStop((error) => {
                                                        if (error) {
                                                        } else {
                                                            log('Succeeded to stop after ' + stoptime + ' seconds.');
                                                }, stoptime * 1000);  // stopzeit
                                      function stopMoving () {
                                            if (error) {
                                            } else {
                                                log('Succeeded to stop.');
                                      // https://github.com/futomi/node-onvif#gotopresetparams-callback-method
                                      function gotoPreset (presetNumber) { // 1,2,3 kommt als ganze Zahl
                                        if (presetNumber > 0) {
                                                if (error) {
                                                    log('[ERROR] ' + error.message, 'error');
                                                    return;
                                                } /*else {*/
                                                // The OnvifServicePtz object
                                                var ptz = device.services.ptz;
                                                if (ptz) {
                                                    var profile = device.getCurrentProfile(); // debug
                                                    log(JSON.stringify(profile, null, '  ')); // debug log
                                                    var params = {
                                                        'ProfileToken': profile['token'],
                                                        'PresetToken' : presetNumber.toString(),
                                                        'Speed'       : {'x': 1, 'y': 1, 'z': 1}
                                                    device.services.ptz.gotoPreset(params, (error, result) => {
                                                        if (error) {
                                                        } else {
                                                            if (logging) log('Preset: ' + JSON.stringify(result.data, null, '  ')); // statt result.['data']
                                                            log('Camera moved to Preset #' + presetNumber.toString());
                                                } else {
                                                    log('[ERROR] Your ONVIF network camera does not support the PTZ service.');
                                        } else {
                                            log('Preset für Kamera 1 kein valider Preset-Wert'); // debug log
                                      // Links
                                      on({id: idLinks, val: true},function (obj) {
                                        if (!obj.state.ack && obj.state.val) {
                                           var stoppzeit = getState(idStoppzeit).val;
                                           var speed = getState(idSpeed).val;
                                           movePTZ(-1 * speed , 0, 0, stoppzeit);
                                           setStateDelayed(idLinks, false, 500); // ggf , 500 + (stoppzeit * 1000)
                                      // rechts
                                      on({id: idRechts, val: true}, function (obj) {
                                           movePTZ(1 * speed , 0, 0, stoppzeit);
                                           setStateDelayed(idRechts, false, 500);
                                      // oben
                                      on({id: idHoch, val: true}, function (obj) {
                                           movePTZ(0, 1 * speed, 0, stoppzeit);
                                           setStateDelayed(idHoch, false, 500, 500);
                                      // runter
                                      on({id: idRunter, val: true}, function (obj) {
                                           movePTZ(0, -1 * speed, 0, stoppzeit);
                                           setStateDelayed(idRunter, false, 500);
                                      // vergrößern
                                      on({id: idZoomIn, val: true}, function (obj) {
                                           movePTZ(0, 0, 1 * speed, stoppzeit);
                                           setStateDelayed(idZoomIn, false, 500);
                                      // verkleinern
                                      on({id:idZoomOut, val: true}, function (obj) {
                                           movePTZ(0, 0, -1 * speed, stoppzeit);
                                           setStateDelayed(idZoomOut, false, 500);
                                      // sofortiger Stopp
                                      on(idStopp, function (obj) {
                                           stopMoving();
                                           setStateDelayed(idStopp, false, 500);
                                           setState(idGotoPreset, 0);
                                      on({
                                        id: [idStopp, idZoomOut, idZoomIn, idRunter, idHoch, idRechts, idLinks],
                                        change: 'any'
                                      }, function (obj) {
                                      // zum bereits gespeicherten Preset X fahren (Ganze Zahl, kommt aus VIS, Scenes oder Script)
                                      on(idGotoPreset, function (obj) {
                                           gotoPreset(parseInt(obj.state.val,10)); // vorher 10 wird später zu einem String gewandelt
                                           setStateDelayed(idGotoPreset, 0, 500); // reset
                                      /// Test hochrechts
                                      const idHochRechts = pfad + 'hochrechts';
                                      createState(idHochRechts, false, fC, {def: false,name: 'Kamera 1 PTZ obenrechts',desc: 'Bewegung nach obenrechts',type: 'boolean',role: 'switch'});
                                      on(idHochRechts, function (obj) {
                                           setStateDelayed(idHochRechts, false, 500);
                                        steimi last edited by
                                        @Jey-Cee kannst du die Objekt-Struktur dahingehend anpassen, dass statt IPC-model_xxx die IP-Adresse in Form von 192_168_1_1 verwenden wird? Steigert mMn die Übersichtlichkeit. Und wäre es möglich im Adapter die Liste der Cam sortierbar zu machen?
                                        Thx Steimi
                                        • Jey Cee
                                          Jey Cee Developer @steimi last edited by Jey Cee
                                          @steimi Also die IP zu nutzen ist sicher keine gute Idee, die kann sich ändern. Alternativ kann ich die urn benutzen, die ändert sich nicht: 88d87a05-d7f77e45-b1e9-00626E51E215
                                          @steimi sagte in Test Adapter onvif v0.1.x:
                                          Ich werde es mir merken, ist aber gerade niedrige Priorität.
                                          Edit: Wonach soll denn Sortiert werden können?
                                            Wie oft ändern man den die IP-Adresse der Cam's? Beim 'wiffi-wz'-Adapter funktioniert dies ganz gut. Vlt geht aber auch ein frei vergebbarer Name für den Objektbaum.
                                            Es muss nicht sortierbar sein, allerdings sollte zumindest nach der Erkennen nach etwas sortiert sein (IP-Adresse?).
                                            31.7k
                                            79.8k
                                            onvif
                                            33
                                            271
                                            30695
