    4. Flot Diagramm mit mehreren Balken nebeneinander
      Homoran Global Moderator Administrators @onkel-ede last edited by
      @onkel-ede
      Hab keine Idee mehr wo unsere Unterschiede sind.
      Hier mal mein Flot:
      http://192.168.123.456:8082/flot/index.html?l%5B0%5D%5Bid%5D=Messwerte.0.Stromzaehler.Summenwerte.Tagesendverbrauch&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=onchange&l%5B0%5D%5Bcolor%5D=%23FF0000&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Bmax%5D=30&l%5B0%5D%5Bthickness%5D=6&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5Bname%5D=Verbrauch&l%5B0%5D%5BchartType%5D=bar&l%5B0%5D%5BignoreNull%5D=false&l%5B0%5D%5BafterComma%5D=2&l%5B0%5D%5Bdashes%5D=false&l%5B0%5D%5BdashLength%5D=10&l%5B0%5D%5BspaceLength%5D=10&l%5B0%5D%5Byaxe%5D=right&l%5B0%5D%5Bxaxe%5D=bottom&l%5B0%5D%5Bpoints%5D=false&l%5B1%5D%5Bid%5D=Messwerte.0.Stromzaehler.Summenwerte.Tagesendeinspeisung&l%5B1%5D%5Boffset%5D=10000&l%5B1%5D%5Baggregate%5D=onchange&l%5B1%5D%5Bcolor%5D=%23ffcc00&l%5B1%5D%5Bthickness%5D=6&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Bname%5D=Einspeisung&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5Byaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BignoreNull%5D=false&l%5B1%5D%5BafterComma%5D=2&l%5B1%5D%5Bdashes%5D=false&l%5B1%5D%5BdashLength%5D=10&l%5B1%5D%5BspaceLength%5D=10&l%5B1%5D%5BchartType%5D=bar&l%5B1%5D%5Bpoints%5D=false&l%5B1%5D%5Bsmoothing%5D=0&l%5B2%5D%5Bid%5D=Messwerte.0.Stromzaehler.Summenwerte.Tagesendbezug&l%5B2%5D%5Boffset%5D=20000&l%5B2%5D%5Baggregate%5D=onchange&l%5B2%5D%5Bcolor%5D=%23FF00FF&l%5B2%5D%5Bthickness%5D=6&l%5B2%5D%5Bshadowsize%5D=3&l%5B2%5D%5Bname%5D=Bezug&l%5B2%5D%5Bxaxe%5D=off&l%5B2%5D%5Byaxe%5D=off&l%5B2%5D%5BcommonYAxis%5D=1&l%5B2%5D%5BafterComma%5D=2&l%5B2%5D%5Bdashes%5D=false&l%5B2%5D%5BdashLength%5D=10&l%5B2%5D%5BspaceLength%5D=10&l%5B2%5D%5BchartType%5D=bar&l%5B2%5D%5Bpoints%5D=false&l%5B2%5D%5BignoreNull%5D=false&timeType=relative&relativeEnd=now&range=10080&aggregateType=count&aggregateSpan=300&barColor=%23000000&barWidth=.06&legend=nw&hoverDetail=true&useComma=false&zoom=true&noedit=false&animation=0&bg=0&live=120&noBorder=noborder&grid_color=lightgrey&title=Tagesprofil+Strom&titlePos=top%3A35%3Bleft%3A50&titleColor=white&titleSize=20pt&legBgOpacity=.5&timeFormat=%25d.%25m.
      Vielleicht findest du was
      • O
        @Homoran
        Wenn ich Deinen Link in flot einbinde, die IP-Adresse und die Datenpunkte anpasse, sieht es so aus, wie es korrekt wäre.
        Ist allerdings schwer lesbar (bin mit Tablett unterwegs).
        Kann ich den Link so einbinden, dass die Einstellungen angepasst werden?
        Steht bei Dir bei Zeit Schritttyp „Anzahl“ und Schrittweite „300“?
          @onkel-ede sagte in Flot Diagramm mit mehreren Balken nebeneinander:
          Was ist nicht lesbar?
          Du hast doch nach dem Anpassen einen eigenen - was meinst du?
          Meist du Schritttyp = Anzahl und Anzahl = 300?
          Das dürfte bei Balken irrelevant sein
          • O
            @Homoran
            Ich meine, im Editor ist schwer zu finden, wo die Unterschiede liegen.
            Wenn ich Deinen Link in das Feld „Link“ kopiere, ändern sich ja die Einstellungen bei mir nicht.
              @onkel-ede nicht kopieren, sondern mit .../flot/edit.html/... aufrufen
              • O
                @Homoran
                Wenn ich Deinen Link entsprechend anpasse und in edit öffne, sieht es so aus, wie es soll.
                Habe alles identisch zu Dir eingestellt.
                Einzig der x-offset ist unterschiedlich.
                Der oberste Datenpunkt hat bei Dir 0s und die beiden anderen sind leer.
                Dies kann ich bei mir jedoch nicht auswählen:
                  Nein, da stand was.
                  Trage irgend etwas ein und ändere diese Zahlen im Link auf 0, 10000, und 20000
                  • O
                    @Homoran
                    Mit der Anpassung direkt im Link funktioniert es.
                    Besten Dank für Deine Hilfe.
                      @onkel-ede und jetzt noch die Linienstärke anheben (auch im Link)
                      • Nashra
                        Moin, hänge mich mal mit rein 🙂
                        Hatte schon des öfteren versucht Balken anzuzeigen aber es klappte einfach nicht 😞
                        Dank dir @Homoran und deinem Flot-Link habe ich es nun auch hinbekommen.
                        Einzigst was mir nicht gefällt ist das die Balken keine Füllfarbe haben,
                        aber da hattest Du ja geschrieben das dies wohl etwas dauert, bin gespannt.
                          Homoran Global Moderator Administrators @Nashra last edited by
                          @Nashra sagte in Flot Diagramm mit mehreren Balken nebeneinander:
                          ich habe das mit "Füllen" nicht hinbekommen.
                          Aber indem ich die Linienbreite so lange erhöht habe bis sie so dick war, dass sich die rechte und linke Linie berührten 😉
                          Dies aber bitte im Link ändern.
                          Beim erneuten einlesen in den Editor wird sonst wieder der Abstand auf 0 gesetzt
                          • O
                            Habe gerade mal probiert, Füllen wieder auf 1 zu setzen:
                            Mal noch eine andere Frage. Kann man mit flot Balken auch stapeln oder muss man dazu auf andere Technologien umsteigen?
                            • Peoples
                              Peoples last edited by
                              Das ist eine wirklich gute Frage
                              • Nashra
                                Nashra Most Active Forum Testing @Homoran last edited by
                                @Homoran sagte in Flot Diagramm mit mehreren Balken nebeneinander:
                                Linienbreite erhöhen das war es
                                Kapier ich jetzt nicht. Habe es gespeichert und neu geladen, siehe Bild oben.
                                Oder meinst du den Abstand der Balken? Wenn ja, welcher Eintrag ist das?
                                  ja!
                                  offset=xxx
                                  Sieht aber doch bei dir brauchbar aus, da würde ich nichts ändern
                                  • Nashra
                                    Ah ok.
                                    Gefällt mir trotzdem nicht so richtig. Wollte Grafana mal probieren, aber ich bekomme das in der Proxmox VM
                                    einfach nicht installiert. Damit lässt sich sicher vieles einfacher anzeigen.
                                      So passt es
                                      • Nashra
                                        So passt es
                                        Naja, man könnte auch sagen: besser 😁
                                        • O
                                          Was muss ich einstellen, um als Balken nur den aktuellsten Wert eines Datenpunktes als Balken anzuzeigen? Dieser liegt z.B. vor aus dem Sourceanalytics-Adapter (current day).
                                          • Peoples
                                            Gabs eine Antwort auf die Frage wegen dem stapeln der Balken? Oder hab ich das überlesen
                                            flot adapter vis
                                            6325
