    4. Test Adapter MercedesMe v0.0.x
    • lighu36
      lighu36 @tombox last edited by
      @tombox 5b299641-dfa9-43f0-b459-9b7e3c8f330d-image.png 我从新安装了一个适配器 现在提示没有找到车辆
      • lighu36
        lighu36 last edited by Homoran
        mercedesme.1	2019-12-16 16:10:14.788	warn	(17172) No vehicles found
        mercedesme.1	2019-12-16 16:09:57.309	info	(17172) starting. Version 0.0.18 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.mercedesme, node: v10.16.3
        mercedesme.1	2019-12-16 16:09:57.234	info	(17172) States connected to socket.io: 127.0.0.1
        mercedesme.1	2019-12-16 16:02:08.732	warn	(10908) No vehicles found
        mercedesme.1	2019-12-16 16:01:51.886	info	(10908) starting. Version 0.0.18 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.mercedesme, node: v10.16.3
        mercedesme.1	2019-12-16 16:01:51.746	info	(10908) States connected to socket.io: 127.0.0.1
        mercedesme.1	2019-12-16 16:01:23.864	error	(17748) Login Failed. Please try to login manually.
          tombox @lighu36 last edited by
          @lighu36 Can you put the instance in debug and send me the log file after restart instance
          lighu36 1 Reply Last reply Reply Quote 0
          • lighu36
            lighu36 @tombox last edited by lighu36
            是我的车有问题吗? 我的汽车购买已经超过3年了,
            您是要这个日志吗
              @lighu36
              Which smartphone app your are using for your car?
              I added in the current github version options to change the country code or accept-language.
              In which country the car is registered?
              • lighu36
                中国
                  tombox @lighu36 last edited by tombox
                  @lighu36 sagte in Test Adapter MercedesMe v0.0.x:
                  中国
                  You can try to use in the mercedesme instance options in the bottom after reinstalling via github link (first post in this thread):
                  accept language zh_CN
                  and
                  country code CN
                  • lighu36
                    @tombox 好的
                      hajuerue last edited by
                      auf wieviel habt ihr die Aktualisierung stehen in Sekunden?
                      Hatte es auf 300, dann kommen aber die Meldungen wenn man Pech hat erst nach 5 Minuten 😉
                      Was ist das zu empfehlende kleinste, so das man nicht vom Server gesperrt wird? (habs mal auf 30 gestellt)
                      Gibt es schon Neuigkeiten ob das mit der Vorklimatisierung nun auch gehen sollte.
                      Wie am 3ten geschrieben, stellt er bei mir die Zeit nun zwar nichtmehr auf 23:59, dafür aber auf die Zeit in der Vergangenheit, und somit denkt dass System dass man erst am nächsten Tag die Klima braucht 😉
                      Gruss
                      HaJueRue
                        tombox @hajuerue last edited by tombox
                        @hajuerue ich habemal ein delay in die github version gebaut. Installiern via github. Instanz neustarten und remote option VorklimaDelay setzen.
                        30sek sollte kein Problem sein, da der Adapter nur Änderungen bekommt wenn wirklich welche bei mercedes vorliegen. Die app verhält sich ähnlich
                          mouk last edited by
                          Hallo.
                          Ich habe das Modul eben das erste Mal versucht zu installieren. Bekomme aber folgende Fehler.
                          Kann mir jemand weiterhelfen?
                          JS-Controller ist 2.2.7
                          MercedesME Module aus dem Github is 0.0.19
                          Vielen Dank
                          Mouk
                            tombox @mouk last edited by tombox
                            @mouk scheint so als hättest du eine alte node Version
                            Update mal auf 10
                            https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten
                            Bzw npm rebuild ausführen wie in der Anleitung
                              mouk last edited by
                              Danke für den Hinweis.
                              Hatte zwar schon 10 drauf, habe aber eben die Installation nochmal durchgeführt.
                              Leider immer noch der gleiche Fehler.
                              Node.js v10.18.0
                              NPM 6.13.4
                              JS 2.2.7
                              Noch eine Idee vielleicht?
                              Mouk
                                @mouk npm rebuild im opt/IoBroker Ordner ausgeführt? Bzw Mercedes Adapter nochmal neuinstallieren
                                  mouk last edited by
                                  Ich habe es gelöst.
                                  Musste Canvas 2.6.0 im Mercedes me Ordner installieren.
                                  Keine Ahnung warum.
                                  d.h.
                                  den Befehl:
                                  sudo npm install canvas@2.6.0 --unsafe-perm=true
                                  im Ordner /opt/iobroker/node_modules/iobroker.mercedesme
                                  ausführen.
                                  Jetzt teste ich erstmal etwas herum.
                                  Danke trotzdem
                                    JürgenB last edited by
                                    hatte bisher die Version 0.0.16 installiert gehabt und dort war das Model im Bereich Details richtig vorhanden.
                                    Nach dem Update auf Version 0.0.20 wird hier zwar der vordere Teil richtig dargestellt aber der hintere Teil fehlt bzw. wird mit Estate angezeigt.
                                    Woran könnte das liegen?
                                    Jürgen
                                      tombox @JürgenB last edited by
                                      @JürgenB Es kann sein das Mercedes jetzt die veränderten Informationen liefert wenn du zurück auf die 16 gehst und da die anderen information angezeigt werden War vielleicht durch die Umstellung von Webseiten daten auf daten aus der Mercedes Me App das da unterschiedliche informationen. zurückgegeben werden
                                        JürgenB @tombox last edited by
                                        @tombox
                                        Danke für die Antwort.
                                        Dann werd ich wohl vorerst bei der Version 16 bleiben.
                                          hab gestern auch die 0.0.20 installiert.
                                          Hatte gehofft das ich damit dann die Vorklimatisierung nutzen kann.
                                          Leider ist das aber noch genauso wie bei den vorhergehenden Versionen.
                                          Die Zeit wird auf die aktuelle gesetzt, und somit geht Mercedes davon aus, dass man den nächsten Tag meint.
                                          Gibts da evtl ne Einstellung die ich irgendwo übersehen habe.
                                          Bei meinem BED, muss die Zeit >15 Minuten in der Zukunft liegen, sonst geht er vom nächsten Tag aus.
                                          Gruss
                                          HaJueRueiobroker_mercedesme_remote_080120.png MercedesMe_Zeit-zu-knapp_080120.png
                                            @hajuerue dann bei vorklima delay auf 15 setzten
                                            mercedes
                                            120
                                            929
                                            230136
