    4. Zigbee Schalter schaltet weitere Geräte
    UNSOLVED Zigbee Schalter schaltet weitere Geräte
      DocGame @arteck last edited by
      @arteck
      Hier mal alles was er zwischen dem Stoppen (mit ausziehen) und Neustart so bringt:
      zigbee.0	2019-12-31 17:10:03.951	error	at Timer.processTimers (timers.js:223:10))
      zigbee.0	2019-12-31 17:10:03.951	error	at listOnTimeout (timers.js:263:5)
      zigbee.0	2019-12-31 17:10:03.951	error	at tryOnTimeout (timers.js:300:5)
      zigbee.0	2019-12-31 17:10:03.951	error	at ontimeout (timers.js:436:11)
      zigbee.0	2019-12-31 17:10:03.951	error	at Timeout.object.timer.setTimeout [as _onTimeout] (C:\Iobroker\SmartHome\node_modules\iobroker.zigbee\node_modules\zigbee-herdsman\dist\utils\waitress.js:44:24)
      zigbee.0	2019-12-31 17:10:03.951	error	(10348) Failed to configure 0x0017880104f18654 RWL021, attempt 1 (Error: AREQ - ZDO - bindRsp after 10000ms
      zigbee.0	2019-12-31 17:09:53.941	info	(10348) Configuring 0x0017880104f18654 RWL021
      zigbee.0	2019-12-31 17:09:53.938	error	at Timer.processTimers (timers.js:223:10))
      zigbee.0	2019-12-31 17:09:53.938	error	at listOnTimeout (timers.js:263:5)
      zigbee.0	2019-12-31 17:09:53.938	error	at tryOnTimeout (timers.js:300:5)
      zigbee.0	2019-12-31 17:09:53.938	error	at ontimeout (timers.js:436:11)
      zigbee.0	2019-12-31 17:09:53.938	error	at Timeout.object.timer.setTimeout [as _onTimeout] (C:\Iobroker\SmartHome\node_modules\iobroker.zigbee\node_modules\zigbee-herdsman\dist\utils\waitress.js:44:24)
      zigbee.0	2019-12-31 17:09:53.938	error	(10348) Failed to configure 0x04cf8cdf3c75b44a lumi.remote.b686opcn01, attempt 1 (Error: AREQ - ZDO - bindRsp after 10000ms
      sonoff.0	2019-12-31 17:09:44.628	info	(11124) Client [Sonoff Messtation] reconnected. Old secret 1577808521766_4821. New secret 1577808584624_7809
      zigbee.0	2019-12-31 17:09:43.922	info	(10348) Configuring 0x04cf8cdf3c75b44a lumi.remote.b686opcn01
      zigbee.0	2019-12-31 17:09:43.920	error	at Timer.processTimers (timers.js:223:10))
      zigbee.0	2019-12-31 17:09:43.920	error	at listOnTimeout (timers.js:263:5)
      zigbee.0	2019-12-31 17:09:43.920	error	at tryOnTimeout (timers.js:300:5)
      zigbee.0	2019-12-31 17:09:43.920	error	at ontimeout (timers.js:436:11)
      zigbee.0	2019-12-31 17:09:43.920	error	at Timeout.object.timer.setTimeout [as _onTimeout] (C:\Iobroker\SmartHome\node_modules\iobroker.zigbee\node_modules\zigbee-herdsman\dist\utils\waitress.js:44:24)
      zigbee.0	2019-12-31 17:09:43.920	error	(10348) Failed to configure 0x04cf8cdf3c75c2c5 lumi.remote.b486opcn01, attempt 1 (Error: AREQ - ZDO - bindRsp after 10000ms
      zigbee.0	2019-12-31 17:09:33.925	info	(10348) Zigbee started
      zigbee.0	2019-12-31 17:09:33.924	info	(10348) 0x00124b00199448e7 (addr 40353): GL-C-008 - Gledopto Zigbee LED controller RGB + CCT (Router)
      zigbee.0	2019-12-31 17:09:33.923	info	(10348) 0x00158d00028f7bcd (addr 3601): WXKG03LM - Xiaomi Aqara single key wireless wall switch (EndDevice)
      zigbee.0	2019-12-31 17:09:33.923	info	(10348) 0x00158d00028f7b08 (addr 52037): WXKG03LM - Xiaomi Aqara single key wireless wall switch (EndDevice)
      zigbee.0	2019-12-31 17:09:33.922	info	(10348) 0x00158d0002ca09bc (addr 3962): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      zigbee.0	2019-12-31 17:09:33.922	info	(10348) 0x00158d0002d40924 (addr 2026): WXKG02LM - Xiaomi Aqara double key wireless wall switch (EndDevice)
      zigbee.0	2019-12-31 17:09:33.921	info	(10348) 0x00158d0003e748be (addr 10895): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      zigbee.0	2019-12-31 17:09:33.921	info	(10348) 0x0017880104f18654 (addr 41473): 324131092621 - Philips Hue dimmer switch (EndDevice)
      zigbee.0	2019-12-31 17:09:33.920	info	(10348) 0xec1bbdfffe972085 (addr 30871): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
      zigbee.0	2019-12-31 17:09:33.920	info	(10348) 0x00158d0002a523d7 (addr 56309): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice)
      zigbee.0	2019-12-31 17:09:33.919	info	(10348) 0x00158d0002238339 (addr 145): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
      zigbee.0	2019-12-31 17:09:33.919	info	(10348) 0x00158d0002c8ca73 (addr 26364): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
      zigbee.0	2019-12-31 17:09:33.918	info	(10348) 0xccccccfffe9734b3 (addr 44088): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
      zigbee.0	2019-12-31 17:09:33.918	info	(10348) 0x04cf8cdf3c75b44a (addr 16081): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
      zigbee.0	2019-12-31 17:09:33.917	info	(10348) 0x00158d000255dc96 (addr 32480): WXKG02LM - Xiaomi Aqara double key wireless wall switch (EndDevice)
      zigbee.0	2019-12-31 17:09:33.917	info	(10348) 0x00158d000289e4c9 (addr 9335): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
      zigbee.0	2019-12-31 17:09:33.917	info	(10348) 0x7cb03eaa0a050960 (addr 10321): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
      zigbee.0	2019-12-31 17:09:33.916	info	(10348) 0x7cb03eaa0a036286 (addr 21019): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
      zigbee.0	2019-12-31 17:09:33.916	info	(10348) 0x00158d0002c63f59 (addr 24390): ZNLDP12LM - Xiaomi Aqara smart LED bulb (Router)
      zigbee.0	2019-12-31 17:09:33.916	info	(10348) 0x7cb03eaa0a07b27e (addr 610): AB3257001NJ - OSRAM Smart+ plug (Router)
      zigbee.0	2019-12-31 17:09:33.915	info	(10348) 0x7cb03eaa0a07a4d6 (addr 48749): AB3257001NJ - OSRAM Smart+ plug (Router)
      zigbee.0	2019-12-31 17:09:33.915	info	(10348) 0x84182600000e8d75 (addr 5135): AB3257001NJ - OSRAM Smart+ plug (Router)
      zigbee.0	2019-12-31 17:09:33.915	info	(10348) 0x7cb03eaa0a07cf0e (addr 18295): AB3257001NJ - OSRAM Smart+ plug (Router)
      zigbee.0	2019-12-31 17:09:33.914	info	(10348) 0x7cb03eaa0a016776 (addr 31854): AB3257001NJ - OSRAM Smart+ plug (Router)
      zigbee.0	2019-12-31 17:09:33.914	info	(10348) 0x04cf8cdf3c75c2c5 (addr 40615): WXCJKG12LM - Xiaomi Aqara Opple switch 2 bands (EndDevice)
      zigbee.0	2019-12-31 17:09:33.913	info	(10348) 0x841826000010673d (addr 31563): AB3257001NJ - OSRAM Smart+ plug (Router)
      zigbee.0	2019-12-31 17:09:33.913	info	(10348) 0x84182600000e47bf (addr 9577): AB3257001NJ - OSRAM Smart+ plug (Router)
      zigbee.0	2019-12-31 17:09:33.912	info	(10348) 0x7cb03eaa0a07b6c8 (addr 48471): AB3257001NJ - OSRAM Smart+ plug (Router)
      zigbee.0	2019-12-31 17:09:33.911	info	(10348) 0x7cb03eaa00acad07 (addr 22913): AB3257001NJ - OSRAM Smart+ plug (Router)
      zigbee.0	2019-12-31 17:09:33.906	info	(10348) Configuring 0x04cf8cdf3c75c2c5 lumi.remote.b486opcn01
      zigbee.0	2019-12-31 17:09:33.902	info	(10348) Currently 28 devices are joined:
      zigbee.0	2019-12-31 17:09:33.870	info	(10348) Unable to disable LED, unsupported function.
      zigbee.0	2019-12-31 17:09:33.855	info	(10348) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20191106}}
      zigbee.0	2019-12-31 17:09:32.435	info	(10348) Starting Zigbee...
      zigbee.0	2019-12-31 17:09:32.397	info	(10348) starting. Version 1.0.0-b in C:/Iobroker/SmartHome/node_modules/iobroker.zigbee, node: v10.16.3
      host.IOBroker(SmartHome)	2019-12-31 17:09:28.706	info	instance system.adapter.zigbee.0 started with pid 10348
      host.IOBroker(SmartHome)	2019-12-31 17:09:27.092	info	instance system.adapter.zigbee.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
      zigbee.0	2019-12-31 17:09:26.533	info	(6712) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      zigbee.0	2019-12-31 17:09:26.527	info	(6712) terminating
      zigbee.0	2019-12-31 17:09:26.468	debug	(6712) Wrong device 00158d0002ca09bc
      zigbee.0	2019-12-31 17:09:26.209	debug	(6712) Publish available for 0x00124b00199448e7 = false
      zigbee.0	2019-12-31 17:09:26.208	debug	(6712) Publish available for 0x00158d00028f7bcd = false
      zigbee.0	2019-12-31 17:09:26.208	debug	(6712) Publish available for 0x00158d00028f7b08 = false
      zigbee.0	2019-12-31 17:09:26.207	debug	(6712) Publish available for 0x00158d0002ca09bc = false
      zigbee.0	2019-12-31 17:09:26.206	debug	(6712) Publish available for 0x00158d0002d40924 = false
      zigbee.0	2019-12-31 17:09:26.205	debug	(6712) Publish available for 0x00158d0003e748be = false
      zigbee.0	2019-12-31 17:09:26.205	debug	(6712) Publish available for 0x0017880104f18654 = false
      zigbee.0	2019-12-31 17:09:26.204	debug	(6712) Publish available for 0xec1bbdfffe972085 = false
      zigbee.0	2019-12-31 17:09:26.203	debug	(6712) Publish available for 0x00158d0002a523d7 = false
      zigbee.0	2019-12-31 17:09:26.202	debug	(6712) Publish available for 0x00158d0002238339 = false
      zigbee.0	2019-12-31 17:09:26.202	debug	(6712) Publish available for 0x00158d0002c8ca73 = false
      zigbee.0	2019-12-31 17:09:26.201	debug	(6712) Publish available for 0xccccccfffe9734b3 = false
      zigbee.0	2019-12-31 17:09:26.200	debug	(6712) Publish available for 0x04cf8cdf3c75b44a = false
      zigbee.0	2019-12-31 17:09:26.199	debug	(6712) Publish available for 0x00158d000255dc96 = false
      zigbee.0	2019-12-31 17:09:26.199	debug	(6712) Publish available for 0x00158d000289e4c9 = false
      zigbee.0	2019-12-31 17:09:26.198	debug	(6712) Publish available for 0x7cb03eaa0a050960 = false
      zigbee.0	2019-12-31 17:09:26.197	debug	(6712) Publish available for 0x7cb03eaa0a036286 = false
      zigbee.0	2019-12-31 17:09:26.196	debug	(6712) Publish available for 0x00158d0002c63f59 = false
      zigbee.0	2019-12-31 17:09:26.196	debug	(6712) Publish available for 0x7cb03eaa0a07b27e = false
      zigbee.0	2019-12-31 17:09:26.195	debug	(6712) Publish available for 0x7cb03eaa0a07a4d6 = false
      zigbee.0	2019-12-31 17:09:26.194	debug	(6712) Publish available for 0x84182600000e8d75 = false
      zigbee.0	2019-12-31 17:09:26.193	debug	(6712) Publish available for 0x7cb03eaa0a07cf0e = false
      zigbee.0	2019-12-31 17:09:26.193	debug	(6712) Publish available for 0x7cb03eaa0a016776 = false
      zigbee.0	2019-12-31 17:09:26.192	debug	(6712) Publish available for 0x04cf8cdf3c75c2c5 = false
      zigbee.0	2019-12-31 17:09:26.191	debug	(6712) Publish available for 0x841826000010673d = false
      zigbee.0	2019-12-31 17:09:26.190	debug	(6712) Publish available for 0x84182600000e47bf = false
      zigbee.0	2019-12-31 17:09:26.189	debug	(6712) Publish available for 0x7cb03eaa0a07b6c8 = false
      zigbee.0	2019-12-31 17:09:26.188	debug	(6712) Publish available for 0x7cb03eaa00acad07 = false
      zigbee.0	2019-12-31 17:09:26.188	info	(6712) Zigbee: disabling joining new devices.
      zigbee.0	2019-12-31 17:09:26.185	info	(6712) cleaned everything up...
      host.IOBroker(SmartHome)	2019-12-31 17:09:26.172	info	stopInstance system.adapter.zigbee.0 send kill signal
      zigbee.0	2019-12-31 17:09:26.184	info	(6712) Got terminate signal TERMINATE_YOURSELF
      host.IOBroker(SmartHome)	2019-12-31 17:09:26.170	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
      zigbee.0	2019-12-31 17:09:23.379	info	(6712) Configuring 0x04cf8cdf3c75b44a lumi.remote.b686opcn01
      zigbee.0	2019-12-31 17:09:23.379	debug	(6712) Yes!
      Sind immer die gleichen 3 Geräte Opple 2x, Opple 3x und Ein Philipsdimmer
        DocGame @DocGame last edited by
        @artck @FredF
        ich denke hier tut sich heute nichts mehr. Wünsche euch einen guten Rutsch ins neue Jahr.
        Im neuen Jahr gehts wieder weiter....🥂 🎉
        • FredF
          FredF Most Active Forum Testing @DocGame last edited by FredF
          @DocGame
          Also mit Adapter stoppen, stick raus-rein und adapter starten gabs keine Änderung.
          Habe mal den debug log vom Adapter stop bis zu den ersten Geräte pings angehängt. zigbeelog.txt
          Ob du @arteck da was herauslesen kannst? 🤔
          Edit: Was mich gerade iritiert sind die Redis infos... Der Zigbee Adapter läuft auf einem Slave und lt. log wird eine redis connection zum Master genutzt. Ich nutze gar kein Redis...
          Edit2: Auch das ablernen und neu anlernen eines von den Xiaomi schaltern die mitschalten hat nichts gebracht.
            DocGame @FredF last edited by
            @FredF
            hast du mittlerweile was rausgefunden?
            Hier wird ja das Bindingverhalten diskutiert: Github/zigbee2mqtt/issues/782
            Ich blicke es nur nicht so recht. Die wollen Binding und ich eben nicht. Irgendwie müsste ein längeres Drücken beim einlernen das Binding verursachen. Habs zigmal versucht. Drücken bis die LED blinkt und dann gleich loslassen. Immer das selbe Ergebnis. Es wird ein automatisches Binding zu mehreren Osram Plugs hergestellt.
            FredF Asgothian 2 Replies Last reply Reply Quote 0
              @FredF .... das seh ich erst jetzt.. nach dem du das Log gepostet hast...
              das Aqara Opple ist ein Zigbee 3 .. du hast die Firmware 1.2 das geht damit nicht.. deshalb bekommt du es nicht konfiguriert..
              @DocGame hier müsste es gehen..
              • FredF
                @DocGame nein, leider nicht. Habe leider erst ende der Woche wieder Zeit...
                Bin am überlegen ob ich den Stick neu flashe und neu anlerne. Mit den Problem schalter würde ich anfangen.... sind 40 Geräte...
                @arteck was meinst du?
                • Asgothian
                  Asgothian Developer @DocGame last edited by Asgothian
                  @DocGame sagte in Zigbee Schalter schaltet weitere Geräte:
                  Es ist denkbar das hier zwei unterschiedliche Modi gleichzeitig aktiviert werden. Ich habe leider die Zigbee-Spezifikationen nicht hier so das ich nicht mit den "korrekten" Benennungen arbeiten kann, deswegen kann ich das nur mit dem Verhalten der Ikea FB beschreiben.
                  Zur Sicherheit einmal vorweg: Die Ikea Fernbedienungen lassen sich auf 2 unterschiedliche Arten koppeln. Zum einen ist da die Koppelung an einen Zigbee-Koordinator. Das ist das was wir als Pairing bezeichnen. Zum anderen gibt es die Koppelung an eine (oder mehrere) (Ikea) Lichtquellen. Bei der Ikea FB werden diese beiden Aktionen durch unterschiedliche Tastendrücke an der FB aktiviert.
                  Bei der Koppelung der FB mit einer Lichtquelle muss die FB sehr nahe an der Lichtquelle positioniert sein, damit diese erfolgreich ist. Bis zu einem Abstand von 50 cm hat dieses bei den Ikea Leuchtmitteln funktioniert, darüber nicht.
                  Bei einem dieser Koppelversuche ist aufgefallen das sich eine Osram Steckdose die sich in ca. 1 m Abstand befunden hat mit gekoppelt wurde. Weitere Steckdosen in grösserer Entfernung dagegen nicht.
                  Ausgehend davon würde ich dich Bitten den folgenden Versuch zu machen:
                  • Den Aquara Switch zurück setzen
                  • Mindestens 2 Osram Steckdosen zurück setzen
                  • Beide Osram Steckdosen wieder mit dem Zigbee Netz pairen
                  • eine der beiden Osram Steckdosen stromlos machen.
                  • Den Aquara Switch pairen
                  • die 2. Osram Steckdose wieder mit dem Strom verbinden
                  Wenn jetzt nur eine der beiden Osram Steckdosen auf den Schalt-Event reagiert, dann findet tatsächlich beim Anlegen ein automatisches Binding statt. Dieses müssen wir in der Folge identifizieren um es entfernen zu können.
                  Wenn weiterhin beide Steckdosen reagieren, dann sendet die Aquara FB einen Befehl der zu einem in der Osram FW hinterlegten Muster passt. In diesem Fall sehe ich keinen realistischen Weg das zu unterbinden.
                  A.
                  Nachtrag - @arteck sagte mir gerade das bei dem Aquara Switch das Verhalten über einen Konfigurationsbefehl abgeschaltet werden kann - das sollte im aktuellen Zigbee Adapter auch schon integriert sein - geht aber nur wenn der Switch seine Konfiguration vom Koordinator auch bekommt.
                  A.
                    arteck Developer Most Active @FredF last edited by
                    @FredF am was cc2531 ..wird nicht gehen mit den 40 Geräten dazu müsstest du die 3-er version flashen und die ist nur alpha soweit ich weiss.. der Stick hat zu wenig speicher.. kanns ein das es kurzfristig geht.. und dann eben nicht..
                    • FredF
                      FredF Most Active Forum Testing @arteck last edited by
                      @arteck Weiss ich schon das am Stick nur 15 Geräte gehen, ich habe aber insgesamt 10 Geräte als Router. 5 davon sind die aquara wall switches die nun vom Ikea schalter geschaltet werden....
                        arteck Developer Most Active @FredF last edited by arteck
                        @FredF nein ... du hast die Firmware 1.2 auf dem Stick... diese ist inkompatibel zu dem Aqara Opple schalter
                        für diesen brauchst du die ZStack 3 version also ne andere Frimware und die ist im Alpha stadium.. es hat nix mit routern zu tun
                        ich glaube wir vermischen hier 2 Themen.. wie ich das geerade sehe .. du hast ein Problem mit dem Tradfri
                        der @DocGame ist der mit dem Opple
                        • FredF
                          @arteck nicht den Oppel switch, QBKG12LM - Xiaomi Aqara double key wired wall switch (Router) habe ich
                            @FredF schon gesehen
                              DocGame @Asgothian last edited by DocGame
                              @Asgothian
                              Ich habe es genau so gemacht wie du oben beschrieben hast.
                              Zuallererst ist mir aufgefallen, dass alle 3 gelöschten Geräte (2x Osram Switch und ein Opple 2fach) noch als undefined in der Geräteliste stehen. Hier bekomme ich sie auch nicht rausgelöscht.
                              Nach dem Pairen in der von dir vorgegebenen Reihenfolge sind alle Geräte wieder sichtbar. Leider schalten auch beide bei Tastendruck auf den Opple.
                              Was kann man da noch tun?
                              2020-01-06 14:12:16.836 - info: host.IOBroker(SmartHome) stopInstance system.adapter.zigbee.0 send kill signal
                              2020-01-06 14:12:16.887 - info: zigbee.0 (2768) cleaned everything up...
                              2020-01-06 14:12:16.889 - info: zigbee.0 (2768) Zigbee: disabling joining new devices.
                              2020-01-06 14:12:17.118 - info: zigbee.0 (2768) terminating
                              2020-01-06 14:12:17.119 - info: zigbee.0 (2768) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-01-06 14:12:17.670 - info: host.IOBroker(SmartHome) instance system.adapter.zigbee.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                              2020-01-06 14:12:19.389 - info: host.IOBroker(SmartHome) instance system.adapter.zigbee.0 started with pid 2148
                              2020-01-06 14:12:23.425 - info: zigbee.0 (2148) starting. Version 1.0.0-c in C:/Iobroker/SmartHome/node_modules/iobroker.zigbee, node: v10.16.3
                              2020-01-06 14:12:23.452 - info: zigbee.0 (2148) Starting Zigbee...
                              2020-01-06 14:12:24.897 - info: zigbee.0 (2148) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20191106}}
                              2020-01-06 14:12:24.907 - info: zigbee.0 (2148) Unable to disable LED, unsupported function.
                              2020-01-06 14:12:24.944 - info: zigbee.0 (2148) Currently 27 devices are joined:
                              2020-01-06 14:12:24.950 - info: zigbee.0 (2148) Configuring 0x04cf8cdf3c75b44a lumi.remote.b686opcn01
                              2020-01-06 14:12:24.956 - info: zigbee.0 (2148) 0x7cb03eaa00acad07 (addr 22913): AB3257001NJ - OSRAM Smart+ plug (Router)
                              2020-01-06 14:12:24.957 - info: zigbee.0 (2148) 0xccccccfffe9734b3 (addr 35392): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                              2020-01-06 14:12:24.957 - info: zigbee.0 (2148) 0x84182600000e47bf (addr 64286): AB3257001NJ - OSRAM Smart+ plug (Router)
                              2020-01-06 14:12:24.958 - info: zigbee.0 (2148) 0x841826000010673d (addr 31563): AB3257001NJ - OSRAM Smart+ plug (Router)
                              2020-01-06 14:12:24.958 - info: zigbee.0 (2148) 0x7cb03eaa0a016776 (addr 55532): AB3257001NJ - OSRAM Smart+ plug (Router)
                              2020-01-06 14:12:24.959 - info: zigbee.0 (2148) 0x7cb03eaa0a07cf0e (addr 18295): AB3257001NJ - OSRAM Smart+ plug (Router)
                              2020-01-06 14:12:24.959 - info: zigbee.0 (2148) 0x84182600000e8d75 (addr 5135): AB3257001NJ - OSRAM Smart+ plug (Router)
                              2020-01-06 14:12:24.959 - info: zigbee.0 (2148) 0x7cb03eaa0a07a4d6 (addr 62882): AB3257001NJ - OSRAM Smart+ plug (Router)
                              2020-01-06 14:12:24.960 - info: zigbee.0 (2148) 0x7cb03eaa0a07b27e (addr 610): AB3257001NJ - OSRAM Smart+ plug (Router)
                              2020-01-06 14:12:24.960 - info: zigbee.0 (2148) 0x00158d0002c63f59 (addr 24390): ZNLDP12LM - Xiaomi Aqara smart LED bulb (Router)
                              2020-01-06 14:12:24.961 - info: zigbee.0 (2148) 0x7cb03eaa0a036286 (addr 21019): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
                              2020-01-06 14:12:24.961 - info: zigbee.0 (2148) 0x7cb03eaa0a050960 (addr 10321): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
                              2020-01-06 14:12:24.961 - info: zigbee.0 (2148) 0x00158d000289e4c9 (addr 9335): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                              2020-01-06 14:12:24.962 - info: zigbee.0 (2148) 0x00158d000255dc96 (addr 5485): WXKG02LM - Xiaomi Aqara double key wireless wall switch (EndDevice)
                              2020-01-06 14:12:24.962 - info: zigbee.0 (2148) 0x04cf8cdf3c75b44a (addr 16081): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                              2020-01-06 14:12:24.963 - info: zigbee.0 (2148) 0x7cb03eaa0a07b6c8 (addr 39560): AB3257001NJ - OSRAM Smart+ plug (Router)
                              2020-01-06 14:12:24.963 - info: zigbee.0 (2148) 0x00158d0002c8ca73 (addr 26364): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
                              2020-01-06 14:12:24.964 - info: zigbee.0 (2148) 0x00158d0002238339 (addr 145): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                              2020-01-06 14:12:24.964 - info: zigbee.0 (2148) 0x00158d0002a523d7 (addr 49822): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice)
                              2020-01-06 14:12:24.965 - info: zigbee.0 (2148) 0xec1bbdfffe972085 (addr 37276): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
                              2020-01-06 14:12:24.965 - info: zigbee.0 (2148) 0x0017880104f18654 (addr 41473): 324131092621 - Philips Hue dimmer switch (EndDevice)
                              2020-01-06 14:12:24.966 - info: zigbee.0 (2148) 0x00158d0003e748be (addr 10895): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                              2020-01-06 14:12:24.966 - info: zigbee.0 (2148) 0x00158d0002d40924 (addr 2026): WXKG02LM - Xiaomi Aqara double key wireless wall switch (EndDevice)
                              2020-01-06 14:12:24.967 - info: zigbee.0 (2148) 0x00158d0002ca09bc (addr 65376): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                              2020-01-06 14:12:24.968 - info: zigbee.0 (2148) 0x00158d00028f7b08 (addr 52037): WXKG03LM - Xiaomi Aqara single key wireless wall switch (EndDevice)
                              2020-01-06 14:12:24.968 - info: zigbee.0 (2148) 0x00158d00028f7bcd (addr 3601): WXKG03LM - Xiaomi Aqara single key wireless wall switch (EndDevice)
                              2020-01-06 14:12:24.969 - info: zigbee.0 (2148) 0x00124b00199448e7 (addr 40353): GL-C-008 - Gledopto Zigbee LED controller RGB + CCT (Router)
                              2020-01-06 14:12:24.970 - info: zigbee.0 (2148) Zigbee started
                              2020-01-06 14:12:34.964 - error: zigbee.0 (2148) Failed to configure 0x04cf8cdf3c75b44a lumi.remote.b686opcn01, attempt 1 (Error: AREQ - ZDO - bindRsp after 10000ms
                              2020-01-06 14:12:34.966 - info: zigbee.0 (2148) Configuring 0x0017880104f18654 RWL021
                              2020-01-06 14:12:42.039 - warn: zigbee.0 (2148) Failed to execute LQI for '0x7cb03eaa00acad07'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
                              2020-01-06 14:12:44.984 - error: zigbee.0 (2148) Failed to configure 0x0017880104f18654 RWL021, attempt 1 (Error: AREQ - ZDO - bindRsp after 10000ms
                              2020-01-06 14:12:52.046 - warn: zigbee.0 (2148) Failed to execute routing table for '0x7cb03eaa00acad07'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
                              2020-01-06 14:13:02.155 - warn: zigbee.0 (2148) Failed to execute LQI for '0x84182600000e47bf'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
                              2020-01-06 14:13:07.022 - info: sonoff.0 (9932) Client [Sonoff Messtation] connection closed: Error: read ECONNRESET
                              2020-01-06 14:13:12.156 - warn: zigbee.0 (2148) Failed to execute routing table for '0x84182600000e47bf'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
                              2020-01-06 14:13:16.187 - info: javascript.0 (4440) script.js.Bot-Scripts.Batterie_Telegramm: {"id":"mihome.0.devices.magnet_158d0002e9e3c9.percent","newState":{"val":71.6,"ts":1578316396191,"ack":true,"lc":1578316396191,"from":"system.adapter.mihome.0","q":0},"oldState":{"val":69.7,"ts":1578313380585,"ack":true,"lc":1578313380585,"from":"system.adapter.mihome.0","q":0},"state":{"val":71.6,"ts":1578316396191,"ack":true,"lc":1578316396191,"from":"system.adapter.mihome.0","q":0}}
                              2020-01-06 14:13:17.754 - warn: meross.0 (7940) Can not get Abilities for Device 1909026636379339089948e1e95136a7: Error: Timeout
                              2020-01-06 14:13:22.174 - warn: zigbee.0 (2148) Failed to execute LQI for '0x841826000010673d'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
                              2020-01-06 14:13:32.187 - warn: zigbee.0 (2148) Failed to execute routing table for '0x841826000010673d'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
                              2020-01-06 14:13:44.100 - warn: zigbee.0 (2148) Failed to execute LQI for '0x7cb03eaa0a016776'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
                              2020-01-06 14:13:54.101 - warn: zigbee.0 (2148) Failed to execute routing table for '0x7cb03eaa0a016776'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
                              2020-01-06 14:14:04.385 - warn: zigbee.0 (2148) Failed to execute routing table for '0x7cb03eaa0a07cf0e'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
                              2020-01-06 14:14:14.771 - warn: zigbee.0 (2148) Failed to execute routing table for '0x84182600000e8d75'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
                              2020-01-06 14:14:24.758 - warn: zigbee.0 (2148) Failed to execute LQI for '0x7cb03eaa0a07a4d6'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
                              2020-01-06 14:14:34.761 - warn: zigbee.0 (2148) Failed to execute routing table for '0x7cb03eaa0a07a4d6'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
                              2020-01-06 14:14:45.325 - warn: zigbee.0 (2148) Failed to execute routing table for '0x7cb03eaa0a07b27e'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
                              2020-01-06 14:14:56.308 - warn: zigbee.0 (2148) Failed to execute routing table for '0x7cb03eaa0a036286'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
                              2020-01-06 14:15:06.605 - warn: zigbee.0 (2148) Failed to execute routing table for '0x7cb03eaa0a050960'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
                              2020-01-06 14:15:16.841 - warn: zigbee.0 (2148) Failed to execute routing table for '0x7cb03eaa0a07b6c8'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\iobroker.zigbee\\node_modules\\zigbee-herdsman\\dist\\utils\\waitress.js:44:24)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"
                                da ist doch das wovon ich rede...
                                der bekommt kein configure.. wie nah/weit hast du den am Board ?? kannst du den mal bei adapter start ganz nah bringen (der ist doch magnetisch)
                                  DocGame @arteck last edited by DocGame
                                  @arteck
                                  habe ich nicht mitbekommen, das das Configure nicht stattgefunden hat, da die kachel ja da war und in Netzwerkkarte der Opple auch blau aufblinkt bei klick.
                                  Ich habe 5-6 mal Paiten mussen bis es geklappt hat (Der Schalter lag auf dem Coordinatorgehäuse). Das Configure hat ja geklappt wen im Log "Successfully interviewed" kommt. Oder?
                                  zigbee.0	2020-01-06 20:07:16.014	info	(2148) Device '0x04cf8cdf3c75b44a' is supported, identified as: Xiaomi Aqara Opple switch 3 bands (WXCJKG13LM)
                                  zigbee.0	2020-01-06 20:07:16.014	info	(2148) Successfully interviewed '0x04cf8cdf3c75b44a', device has succesfully been paired
                                  zigbee.0	2020-01-06 20:06:59.126	info	(2148) Starting interview of '0x04cf8cdf3c75b44a'
                                  Leider schaltet er immer noch alle Osram Switchs(und wie ich gerade enddeckt habe auch E27 und GU19 Lampen....) Scheinbar alles was als Router fungiert 😵
                                  Im Log erscheinen immer noch Fehlermeldungen:
                                  zigbee.0	2020-01-06 21:59:12.384	warn	(10536) Failed to execute routing table for '0x7cb03eaa0a07b6c8'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_m
                                  zigbee.0	2020-01-06 21:59:02.379	warn	(10536) Failed to execute LQI for '0x7cb03eaa0a07b6c8'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\io
                                  zigbee.0	2020-01-06 21:58:52.369	warn	(10536) Failed to execute routing table for '0x7cb03eaa0a050960'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_m
                                  zigbee.0	2020-01-06 21:58:42.355	warn	(10536) Failed to execute LQI for '0x7cb03eaa0a050960'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\io
                                  zigbee.0	2020-01-06 21:58:32.128	warn	(10536) Failed to execute routing table for '0x7cb03eaa0a036286'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_m
                                  zigbee.0	2020-01-06 21:58:19.458	warn	(10536) Failed to execute routing table for '0x7cb03eaa0a07b27e'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_m
                                  zigbee.0	2020-01-06 21:58:09.159	warn	(10536) Failed to execute routing table for '0x84182600000e8d75'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_m
                                  zigbee.0	2020-01-06 21:57:56.688	warn	(10536) Failed to execute routing table for '0x7cb03eaa0a07cf0e'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_m
                                  zigbee.0	2020-01-06 21:57:46.418	warn	(10536) Failed to execute routing table for '0x7cb03eaa0a016776'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_m
                                  zigbee.0	2020-01-06 21:57:36.097	warn	(10536) Failed to execute routing table for '0x841826000010673d'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_m
                                  zigbee.0	2020-01-06 21:57:26.091	warn	(10536) Failed to execute LQI for '0x841826000010673d'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_modules\\io
                                  zigbee.0	2020-01-06 21:57:15.950	warn	(10536) Failed to execute routing table for '0x84182600000e47bf'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_m
                                  zigbee.0	2020-01-06 21:57:05.636	warn	(10536) Failed to execute routing table for '0x7cb03eaa00acad07'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (C:\\Iobroker\\SmartHome\\node_m
                                  zigbee.0	2020-01-06 21:55:49.152	error	(10536) Failed to configure 0x0017880104f18654 RWL021, attempt 1 (Error: AREQ - ZDO - bindRsp after 10000ms at
                                  zigbee.0	2020-01-06 21:55:39.148	info	(10536) Configuring 0x0017880104f18654 RWL021
                                  zigbee.0	2020-01-06 21:55:39.143	error	(10536) Failed to configure 0x04cf8cdf3c75b44a lumi.remote.b686opcn01, attempt 1 (Error: AREQ - ZDO - bindRsp after 10000ms at Timeout.object.timer.setTimeout [as _onTimeout] (C:\Iobroker\SmartHom
                                  zigbee.0	2020-01-06 21:55:29.147	info	(10536) Zigbee started
                                  zigbee.0	2020-01-06 21:55:29.147	info	(10536) 0x04cf8cdf3c75c2c5 (addr 28089): WXCJKG12LM - Xiaomi Aqara Opple switch 2 bands (EndDevice)
                                  zigbee.0	2020-01-06 21:55:29.147	info	(10536) 0x00124b00199448e7 (addr 40353): GL-C-008 - Gledopto Zigbee LED controller RGB + CCT (Router)
                                  zigbee.0	2020-01-06 21:55:29.146	info	(10536) 0x00158d00028f7bcd (addr 3601): WXKG03LM - Xiaomi Aqara single key wireless wall switch (EndDevice)
                                  zigbee.0	2020-01-06 21:55:29.146	info	(10536) 0x00158d00028f7b08 (addr 52037): WXKG03LM - Xiaomi Aqara single key wireless wall switch (EndDevice)
                                  zigbee.0	2020-01-06 21:55:29.146	info	(10536) 0x00158d0002ca09bc (addr 65376): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                  zigbee.0	2020-01-06 21:55:29.146	info	(10536) 0x00158d0002d40924 (addr 2026): WXKG02LM - Xiaomi Aqara double key wireless wall switch (EndDevice)
                                  zigbee.0	2020-01-06 21:55:29.145	info	(10536) 0x00158d0003e748be (addr 10895): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                  zigbee.0	2020-01-06 21:55:29.145	info	(10536) 0x0017880104f18654 (addr 41473): 324131092621 - Philips Hue dimmer switch (EndDevice)
                                  zigbee.0	2020-01-06 21:55:29.145	info	(10536) 0xec1bbdfffe972085 (addr 24782): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
                                  zigbee.0	2020-01-06 21:55:29.145	info	(10536) 0x00158d0002a523d7 (addr 49822): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice)
                                  zigbee.0	2020-01-06 21:55:29.144	info	(10536) 0x00158d0002238339 (addr 145): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                                  zigbee.0	2020-01-06 21:55:29.144	info	(10536) 0x00158d0002c8ca73 (addr 26364): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
                                  zigbee.0	2020-01-06 21:55:29.144	info	(10536) 0x7cb03eaa0a07b6c8 (addr 39560): AB3257001NJ - OSRAM Smart+ plug (Router)
                                  zigbee.0	2020-01-06 21:55:29.144	info	(10536) 0x00158d000255dc96 (addr 5485): WXKG02LM - Xiaomi Aqara double key wireless wall switch (EndDevice)
                                  zigbee.0	2020-01-06 21:55:29.143	info	(10536) 0x00158d000289e4c9 (addr 9335): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                                  zigbee.0	2020-01-06 21:55:29.143	info	(10536) 0x7cb03eaa0a050960 (addr 10321): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
                                  zigbee.0	2020-01-06 21:55:29.143	info	(10536) 0x7cb03eaa0a036286 (addr 21019): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
                                  zigbee.0	2020-01-06 21:55:29.142	info	(10536) 0x00158d0002c63f59 (addr 24390): ZNLDP12LM - Xiaomi Aqara smart LED bulb (Router)
                                  zigbee.0	2020-01-06 21:55:29.142	info	(10536) 0x7cb03eaa0a07b27e (addr 610): AB3257001NJ - OSRAM Smart+ plug (Router)
                                  zigbee.0	2020-01-06 21:55:29.142	info	(10536) 0x04cf8cdf3c75b44a (addr 44313): WXCJKG13LM - Xiaomi Aqara Opple switch 3 bands (EndDevice)
                                  zigbee.0	2020-01-06 21:55:29.142	info	(10536) 0x84182600000e8d75 (addr 5135): AB3257001NJ - OSRAM Smart+ plug (Router)
                                  zigbee.0	2020-01-06 21:55:29.142	info	(10536) 0x7cb03eaa0a07cf0e (addr 18295): AB3257001NJ - OSRAM Smart+ plug (Router)
                                  zigbee.0	2020-01-06 21:55:29.141	info	(10536) 0x7cb03eaa0a016776 (addr 55532): AB3257001NJ - OSRAM Smart+ plug (Router)
                                  zigbee.0	2020-01-06 21:55:29.141	info	(10536) 0x841826000010673d (addr 31563): AB3257001NJ - OSRAM Smart+ plug (Router)
                                  zigbee.0	2020-01-06 21:55:29.141	info	(10536) 0x84182600000e47bf (addr 64286): AB3257001NJ - OSRAM Smart+ plug (Router)
                                  zigbee.0	2020-01-06 21:55:29.141	info	(10536) 0xccccccfffe9734b3 (addr 35392): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                  zigbee.0	2020-01-06 21:55:29.140	info	(10536) 0x7cb03eaa00acad07 (addr 22913): AB3257001NJ - OSRAM Smart+ plug (Router)
                                  zigbee.0	2020-01-06 21:55:29.136	info	(10536) Configuring 0x04cf8cdf3c75b44a lumi.remote.b686opcn01
                                  zigbee.0	2020-01-06 21:55:29.133	info	(10536) Currently 27 devices are joined:
                                  zigbee.0	2020-01-06 21:55:29.106	info	(10536) Unable to disable LED, unsupported function.
                                  zigbee.0	2020-01-06 21:55:29.097	info	(10536) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20191106}}
                                  zigbee.0	2020-01-06 21:55:27.689	info	(10536) Starting Zigbee...
                                    arteck Developer Most Active @DocGame last edited by arteck
                                    @DocGame da scheint was faul zu sein
                                    also nochmal
                                    adapter stopp
                                    lösche folgende Ordner
                                    /opt/iobroker/node_modules/zigbee-herdsman-converters
                                    kontrlle ob diese ordner nicht nochmal im /opt/iobroker/node_modules/iobroker.zigbee/node_modules da sind
                                    wenn nicht alles OK wenn doch löschen
                                    jetzt installierst du den Adapter von GIT nochmal (die gelöschten Ordner werden automatisch erstellt)
                                    adapter start
                                      @arteck
                                      die Ordner "node_modules/zigbee-herdsman-converters" und "node_modules/zigbee-herdsman" waren nicht da.
                                      Im Ordner "node_modules/iobroker.zigbee/node_modules" waren sie und ich habe sie gelöscht.
                                      Nach mehrmaligen Versuchen hat er dann gepairt.
                                      Was mir aufgefallen ist:
                                      Ich habe den Opple der nicht drinnen war vor dem neuen Anlernen erstmal löschen wollen.
                                      Das geht beim besten willen nicht. Die Kachel mit den "Undefined" verschwindet nicht.
                                      Beim missglückten Anlernversuchen (er kam nicht bis zu dem "Interview") war die Kachel mit allem korrekt gefüllt (bis auf den Batteriestand).
                                      Nach dem komplett funktionierenden Pairen war auch der Batteriestand da. Kann aber auch Zufall sein. Meine Fragen:
                                      1. Wie kann ich ein Gerät komplett löschen (Ohne das die Undefined-Kackel bleibt)?
                                      2. Wie kann ich feststellen, ob bei den anderen Geräten das Konfigurieren komplett ist, da ja die Kachel auch bei nicht kompletten gut aussieht und die Geräte auch z.T. funktionieren? Bei den weiteren Geräte, die ich anlerne werde ich aufpassen, bei den Bestehenden würde ich das aber gerne bestätigt wissen.
                                        Ich werde das ganze mal beobachten und Berichten (nach meinem 1 wöchigen Urlaub)
                                      • FredF
                                        FredF Most Active Forum Testing last edited by FredF
                                        Nachdem die hier gemachten Vorschläge alle nichts gebracht habe und ich einen CC26x2r1 bekommen habe, dachte ich mach mal alles neu (eigentlich bin ich be... bei 40 Geräten 🤒) und habe natürlich die beiden Problemkinder Ikea Schalter und Xiaomi Wall switch als erstes angelernt - und wieder schaltet der Ikea den Xiaomi.
                                        Ich hab jetzt mal ein Issue aufgemacht...
                                        • hsteinme
                                          hsteinme @arteck last edited by
                                          @arteck sagte in Zigbee Schalter schaltet weitere Geräte:
                                          euer Problem hat nix mit Binding zu tun..
                                          der Schalter bekommt keine Konfiguration.. deshalb schaltet der alles..
                                          Vielleicht hilft Euch der folgende Hinweis weiter:
                                          Ich hatte dasselbe Problem mit mehreren Opple Switches, die über ConBee II "angeschlossen" waren. Beim Betätigen der obersten Wippe wurden alle ZigBee Leuchten geschaltet. Der Hintergrund des Problems war ein unvollständiger Paarungsvorgang mit dem Gateway, der zu einer fehlenden Konfiguartion in deConz führte.
                                          Abhilfe: Opple Switch wie folgt erneut paaren:
                                          • Reset-Taste an der Rückseite mehrere Sekunden lang drücken bis die Kontrollleuchte an der Vorderseite blinkt
                                          • einige Sekunden abwarten
                                          • dann blinken einige oder alle Zigbee-Leuchten
                                          • die Reset-Taste einmal kurz drücken
                                          Danach konnte ich meine Opple Switches problemfrei den jeweiligen Leuchten zuordnen und korrekt nutzen.
                                          Viel Erfolg!
                                          B R 2 Replies Last reply Reply Quote 2
                                            Blauhorn @hsteinme last edited by
                                            als Fremdling aus der FHEM-Welt habe ich ebenfalls mit so etwas zu kämpfen.
                                            Meine Konfig sieht so aus:
                                            • ein cc2530+cc2591 als Koordinator, darauf die Sourcerouting-Firmware vom 19.6.2019
                                            • einige IKEA-Tradfri-Lampen, einige INNR-Lampen, ein paar Lidl-Smartplugs,
                                            • viele Aqara-Fensterkontakte, viele Aqara-Temperatur/Feuchtigkeitssensoren
                                            • reichlich Taster, die meisten von Aqara, aber auch 2 IKEA-Fernbedienungen
                                              Dabei sind auch die beschriebenen OPPLE-6-fach-Taster, von denen genau einer die hier dargestellten Sperenzchen macht.
                                              Das Rücksetzen von @hsteinme hat nichts gebracht. Zwar konnte ich den Taster von allen Lampen trennen, er hat dann erwartungsgemäß gar nichs mehr geschaltet. Listigerweise habe ich die betreffenden Lampen dann beim Neu-Pairing rausgedreht. Das Pairen hat hier zwar geklappt aber gleich nach dem Wieder-reindrehen der Lampen hat der Taster sich sofort wieder mit allen auffindbaren Lampen verheiratet.
                                              Es scheint so, als hätte sich da in den Lampen etwas festgesetzt.
                                              Ist jemand irgendwie weiter gekommen bei diesem Chaos?
                                            Gruß vom Blauhorn
                                            herdsman zigbee-adapter
                                            4387
