    4. Test Adapter fb-checkpresence v0.1.x
    • Z
      zahnheinrich @afuerhoff last edited by zahnheinrich
      @afuerhoff
      Hallo, hat schon jemand InfluxDB getestet?
      Jupp:
      Bekomme für beide devices: No history before this day is available (lastVal = null)
      obwohl der Adapter schon einige Tage rennt ohne Fehlermeldungen.
      Das debug-log:
      fb-checkpresence.0	2019-12-09 15:19:00.883	debug	state fb-checkpresence.0.TerrysSamsungS7.historyHtml changed: <table class="mdui-table"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div class="mdui-green-bg mdui-state mdui-car
      fb-checkpresence.0	2019-12-09 15:19:00.883	debug	state fb-checkpresence.0.TerrysSamsungS7.history changed: [{"Active":"true","Date":"2019.12.09 03:18:17"},{"Active":"true","Date":"2019.12.09 02:39:00"},{"Active":"false","Date":"2019.12.09 02:37:00"}
      fb-checkpresence.0	2019-12-09 15:19:00.883	debug	state fb-checkpresence.0.TerrysSamsungS7.absent.sum_day changed: 179 (ack = true)
      fb-checkpresence.0	2019-12-09 15:19:00.882	debug	state fb-checkpresence.0.TerrysSamsungS7.present.sum_day changed: 740 (ack = true)
      fb-checkpresence.0	2019-12-09 15:19:00.882	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.historyHtml {"val":"<table class=\"mdui-table\"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div cl
      fb-checkpresence.0	2019-12-09 15:19:00.881	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.history {"val":"[{\"Active\":\"true\",\"Date\":\"2019.12.09 03:18:17\"},{\"Active\":\"true\",\"Date\":\"2019.12.09 02:39:0
      fb-checkpresence.0	2019-12-09 15:19:00.881	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.absent.sum_day {"val":179,"ack":true,"ts":1575901140874,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.us
      fb-checkpresence.0	2019-12-09 15:19:00.881	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.present.sum_day {"val":740,"ack":true,"ts":1575901140873,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.u
      fb-checkpresence.0	2019-12-09 15:19:00.875	info	TerrysSamsungS7: No history before this day is available (lastVal = null)
      fb-checkpresence.0	2019-12-09 15:19:00.875	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"ack":true,"from":"system.adapter.influxdb.0","q
      fb-checkpresence.0	2019-12-09 15:19:00.860	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
      fb-checkpresence.0	2019-12-09 15:19:00.860	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"val":true,"ts":1575824521227},{"ack":true,"from
      fb-checkpresence.0	2019-12-09 15:19:00.860	debug	state fb-checkpresence.0.presence changed: true (ack = true)
      fb-checkpresence.0	2019-12-09 15:19:00.859	debug	state fb-checkpresence.0.presenceAll changed: true (ack = true)
      fb-checkpresence.0	2019-12-09 15:19:00.858	debug	state fb-checkpresence.0.html changed: <table class="mdui-table"><thead><tr><th>Name</th><th>Status</th><th>Kommt</th><th>Geht</th></tr></thead><tbody><tr><td>UlisSamsungS7</td><td><div class="mdui-gr
      fb-checkpresence.0	2019-12-09 15:19:00.858	debug	state fb-checkpresence.0.json changed: [{"Name":"UlisSamsungS7","Active":"true","Kommt":"2019.12.09 01:48:00","Geht":"2019.12.09 01:46:00"},{"Name":"TerrysSamsungS7","Active":"true","Kommt":"2019.12.0
      fb-checkpresence.0	2019-12-09 15:19:00.858	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.presence {"val":true,"ack":true,"ts":1575901140843,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":157589
      fb-checkpresence.0	2019-12-09 15:19:00.858	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.presenceAll {"val":true,"ack":true,"ts":1575901140843,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":157
      fb-checkpresence.0	2019-12-09 15:19:00.857	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.html {"val":"<table class=\"mdui-table\"><thead><tr><th>Name</th><th>Status</th><th>Kommt</th><th>Geht</th></tr></thead><tbody><tr><td>Uli
      fb-checkpresence.0	2019-12-09 15:19:00.857	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.json {"val":"[{\"Name\":\"UlisSamsungS7\",\"Active\":\"true\",\"Kommt\":\"2019.12.09 01:48:00\",\"Geht\":\"2019.12.09 01:46:00\"},{\"Name\
      fb-checkpresence.0	2019-12-09 15:19:00.849	debug	checkPresence scheduled
      fb-checkpresence.0	2019-12-09 15:19:00.848	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
      fb-checkpresence.0	2019-12-09 15:19:00.847	debug	history start
      fb-checkpresence.0	2019-12-09 15:19:00.846	debug	state fb-checkpresence.0.TerrysSamsungS7.absent.since changed: 0 (ack = true)
      fb-checkpresence.0	2019-12-09 15:19:00.845	debug	state fb-checkpresence.0.TerrysSamsungS7.present.since changed: 40 (ack = true)
      fb-checkpresence.0	2019-12-09 15:19:00.844	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.absent.since {"val":0,"ack":true,"ts":1575901140834,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.a
      fb-checkpresence.0	2019-12-09 15:19:00.844	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.present.since {"val":40,"ack":true,"ts":1575901140834,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user
      fb-checkpresence.0	2019-12-09 15:19:00.843	debug	getActive [{"Name":"UlisSamsungS7","Active":"true","Kommt":"2019.12.09 01:48:00","Geht":"2019.12.09 01:46:00"},{"Name":"TerrysSamsungS7","Active":"true","Kommt":"2019.12.09 02:39:00","Geht":"2019.12.0
      fb-checkpresence.0	2019-12-09 15:19:00.834	debug	getActive TerrysSamsungS7 1
      fb-checkpresence.0	2019-12-09 15:19:00.833	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:
      fb-checkpresence.0	2019-12-09 15:19:00.801	debug	state fb-checkpresence.0.UlisSamsungS7.historyHtml changed: <table class="mdui-table"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div class="mdui-green-bg mdui-state mdui-card"
      fb-checkpresence.0	2019-12-09 15:19:00.801	debug	state fb-checkpresence.0.UlisSamsungS7.history changed: [{"Active":"true","Date":"2019.12.09 03:18:17"},{"Active":"true","Date":"2019.12.09 01:48:00"},{"Active":"false","Date":"2019.12.09 01:46:00"},{
      fb-checkpresence.0	2019-12-09 15:19:00.801	debug	state fb-checkpresence.0.UlisSamsungS7.absent.sum_day changed: 644 (ack = true)
      fb-checkpresence.0	2019-12-09 15:19:00.801	debug	state fb-checkpresence.0.UlisSamsungS7.present.sum_day changed: 275 (ack = true)
      fb-checkpresence.0	2019-12-09 15:19:00.800	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.historyHtml {"val":"<table class=\"mdui-table\"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div clas
      fb-checkpresence.0	2019-12-09 15:19:00.800	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.history {"val":"[{\"Active\":\"true\",\"Date\":\"2019.12.09 03:18:17\"},{\"Active\":\"true\",\"Date\":\"2019.12.09 01:48:00\
      fb-checkpresence.0	2019-12-09 15:19:00.800	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.absent.sum_day {"val":644,"ack":true,"ts":1575901140793,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user
      fb-checkpresence.0	2019-12-09 15:19:00.800	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.present.sum_day {"val":275,"ack":true,"ts":1575901140793,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.use
      fb-checkpresence.0	2019-12-09 15:19:00.794	info	UlisSamsungS7: No history before this day is available (lastVal = null)
      fb-checkpresence.0	2019-12-09 15:19:00.794	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"ack":true,"from":"system.adapter.influxdb.0","q
      fb-checkpresence.0	2019-12-09 15:19:00.779	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
      fb-checkpresence.0	2019-12-09 15:19:00.779	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"val":true,"ts":1575793020415},{"ack":true,"from
      fb-checkpresence.0	2019-12-09 15:19:00.773	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
      fb-checkpresence.0	2019-12-09 15:19:00.773	debug	history start
      fb-checkpresence.0	2019-12-09 15:19:00.766	debug	getActive [{"Name":"UlisSamsungS7","Active":"true","Kommt":"2019.12.09 01:48:00","Geht":"2019.12.09 01:46:00"},
      fb-checkpresence.0	2019-12-09 15:19:00.766	debug	state fb-checkpresence.0.UlisSamsungS7.absent.since changed: 0 (ack = true)
      fb-checkpresence.0	2019-12-09 15:19:00.766	debug	state fb-checkpresence.0.UlisSamsungS7.present.since changed: 91 (ack = true)
      fb-checkpresence.0	2019-12-09 15:19:00.766	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.absent.since {"val":0,"ack":true,"ts":1575901140761,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.adm
      fb-checkpresence.0	2019-12-09 15:19:00.766	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.present.since {"val":91,"ack":true,"ts":1575901140761,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.a
      fb-checkpresence.0	2019-12-09 15:19:00.760	debug	getActive UlisSamsungS7 1
      fb-checkpresence.0	2019-12-09 15:19:00.760	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:
      fb-checkpresence.0	2019-12-09 15:19:00.721	debug	state fb-checkpresence.0.guest changed: false (ack = true)
      fb-checkpresence.0	2019-12-09 15:19:00.719	debug	state fb-checkpresence.0.activeDevices changed: 67 (ack = true)
      fb-checkpresence.0	2019-12-09 15:19:00.719	debug	state fb-checkpresence.0.guest.count changed: 0 (ack = true)
      fb-checkpresence.0	2019-12-09 15:19:00.719	debug	state fb-checkpresence.0.guest.listJson changed: [] (ack = true)
      fb-checkpresence.0	2019-12-09 15:19:00.718	debug	state fb-checkpresence.0.guest.listHtml changed: <table class="mdui-table"><thead><tr><th>Hostname</th><th>IPAddress</th><th>MACAddress</th></tr></thead><tbody></body></table> (ack = true)
      fb-checkpresence.0	2019-12-09 15:19:00.718	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.guest {"val":false,"ack":true,"ts":1575901140709,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":15757421
      fb-checkpresence.0	2019-12-09 15:19:00.717	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.activeDevices {"val":67,"ack":true,"ts":1575901140708,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":157
      fb-checkpresence.0	2019-12-09 15:19:00.717	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.guest.count {"val":0,"ack":true,"ts":1575901140708,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":157574
      fb-checkpresence.0	2019-12-09 15:19:00.717	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.guest.listJson {"val":"[]","ack":true,"ts":1575901140707,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":
      fb-checkpresence.0	2019-12-09 15:19:00.717	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.guest.listHtml {"val":"<table class=\"mdui-table\"><thead><tr><th>Hostname</th><th>IPAddress</th><th>MACAddress</th></tr></thead><tbody></
      fb-checkpresence.0	2019-12-09 15:19:00.712	debug	getGuests: 67
      fb-checkpresence.0	2019-12-09 15:19:00.709	debug	getDeviceList: [{"Index":"1","IPAddress":"192.168.3.96","MACAddress":"34:EA:34:C7:C6:C6","Active":"0","HostName":"Broadlink","InterfaceType":"","X_AVM-DE_Port":"0","X_AVM-DE_Speed":"0","X_AVM-DE_Updat
      fb-checkpresence.0	2019-12-09 15:19:00.104	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:
      fb-checkpresence.0	2019-12-09 15:19:00.080	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:
      fb-checkpresence.0	2019-12-09 15:19:00.080	debug	state fb-checkpresence.0.info.lastUpdate changed: 2019-12-09T14:19:00.025Z (ack = true)
      fb-checkpresence.0	2019-12-09 15:19:00.080	debug	state fb-checkpresence.0.info.connection changed: true (ack = true)
      fb-checkpresence.0	2019-12-09 15:19:00.079	debug	state fb-checkpresence.0.devices changed: 108 (ack = true)
      fb-checkpresence.0	2019-12-09 15:19:00.079	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.info.lastUpdate {"val":"2019-12-09T14:19:00.025Z","ack":true,"ts":1575901140061,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"s
      fb-checkpresence.0	2019-12-09 15:19:00.079	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.info.connection {"val":true,"ack":true,"ts":1575901140061,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc"
      fb-checkpresence.0	2019-12-09 15:19:00.079	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.devices {"val":"108","ack":true,"ts":1575901140060,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":157589
      fb-checkpresence.0	2019-12-09 15:19:00.063	debug	getHostNo: 108
      fb-checkpresence.0	2019-12-09 15:19:00.062	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:
      fb-checkpresence.0	2019-12-09 15:18:18.770	debug	state fb-checkpresence.0.TerrysSamsungS7.historyHtml changed: <table class="mdui-table"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div class="mdui-green-bg mdui-state mdui-ca
      fb-checkpresence.0	2019-12-09 15:18:18.770	debug	state fb-checkpresence.0.TerrysSamsungS7.history changed: [{"Active":"true","Date":"2019.12.09 03:18:17"},{"Active":"true","Date":"2019.12.09 02:39:00"},{"Active":"false","Date":"2019.12.09 02:37:00"
      fb-checkpresence.0	2019-12-09 15:18:18.770	debug	state fb-checkpresence.0.TerrysSamsungS7.absent.sum_day changed: 178 (ack = true)
      fb-checkpresence.0	2019-12-09 15:18:18.770	debug	state fb-checkpresence.0.TerrysSamsungS7.present.sum_day changed: 740 (ack = true)
      fb-checkpresence.0	2019-12-09 15:18:18.770	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.historyHtml {"val":"<table class=\"mdui-table\"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div c
      fb-checkpresence.0	2019-12-09 15:18:18.769	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.history {"val":"[{\"Active\":\"true\",\"Date\":\"2019.12.09 03:18:17\"},{\"Active\":\"true\",\"Date\":\"2019.12.09 02:39:
      fb-checkpresence.0	2019-12-09 15:18:18.769	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.absent.sum_day {"val":178,"ack":true,"ts":1575901098764,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.u
      fb-checkpresence.0	2019-12-09 15:18:18.768	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.present.sum_day {"val":740,"ack":true,"ts":1575901098763,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.
      fb-checkpresence.0	2019-12-09 15:18:18.758	info	TerrysSamsungS7: No history before this day is available (lastVal = null)
      fb-checkpresence.0	2019-12-09 15:18:18.757	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"ack":true,"from":"system.adapter.influxdb.0","
      fb-checkpresence.0	2019-12-09 15:18:18.744	debug	state fb-checkpresence.0.presence changed: true (ack = true)
      fb-checkpresence.0	2019-12-09 15:18:18.743	debug	state fb-checkpresence.0.presenceAll changed: true (ack = true)
      fb-checkpresence.0	2019-12-09 15:18:18.743	debug	state fb-checkpresence.0.html changed: <table class="mdui-table"><thead><tr><th>Name</th><th>Status</th><th>Kommt</th><th>Geht</th></tr></thead><tbody><tr><td>UlisSamsungS7</td><td><div class="mdui-g
      fb-checkpresence.0	2019-12-09 15:18:18.743	debug	state fb-checkpresence.0.json changed: [{"Name":"UlisSamsungS7","Active":"true","Kommt":"2019.12.09 01:48:00","Geht":"2019.12.09 01:46:00"},{"Name":"TerrysSamsungS7","Active":"true","Kommt":"2019.12.
      fb-checkpresence.0	2019-12-09 15:18:18.742	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.presence {"val":true,"ack":true,"ts":1575901098738,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":15758
      fb-checkpresence.0	2019-12-09 15:18:18.742	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.presenceAll {"val":true,"ack":true,"ts":1575901098737,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":15
      fb-checkpresence.0	2019-12-09 15:18:18.741	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.html {"val":"<table class=\"mdui-table\"><thead><tr><th>Name</th><th>Status</th><th>Kommt</th><th>Geht</th></tr></thead><tbody><tr><td>Ul
      fb-checkpresence.0	2019-12-09 15:18:18.741	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.json {"val":"[{\"Name\":\"UlisSamsungS7\",\"Active\":\"true\",\"Kommt\":\"2019.12.09 01:48:00\",\"Geht\":\"2019.12.09 01:46:00\"},{\"Name
      fb-checkpresence.0	2019-12-09 15:18:18.740	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
      fb-checkpresence.0	2019-12-09 15:18:18.739	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"val":true,"ts":1575824521227},{"ack":true,"fro
      fb-checkpresence.0	2019-12-09 15:18:18.700	debug	checkPresence first run
      fb-checkpresence.0	2019-12-09 15:18:18.700	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
      fb-checkpresence.0	2019-12-09 15:18:18.699	debug	history start
      fb-checkpresence.0	2019-12-09 15:18:18.698	debug	state fb-checkpresence.0.TerrysSamsungS7.absent.since changed: 0 (ack = true)
      fb-checkpresence.0	2019-12-09 15:18:18.697	debug	state fb-checkpresence.0.TerrysSamsungS7.present.since changed: 39 (ack = true)
      fb-checkpresence.0	2019-12-09 15:18:18.696	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.absent.since {"val":0,"ack":true,"ts":1575901098687,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.
      fb-checkpresence.0	2019-12-09 15:18:18.695	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.present.since {"val":39,"ack":true,"ts":1575901098686,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.use
      fb-checkpresence.0	2019-12-09 15:18:18.693	debug	getActive [{"Name":"UlisSamsungS7","Active":"true","Kommt":"2019.12.09 01:48:00","Geht":"2019.12.09 01:46:00"},{"Name":"TerrysSamsungS7","Active":"true","Kommt":"2019.12.09 02:39:00","Geht":"2019.12.
      fb-checkpresence.0	2019-12-09 15:18:18.684	debug	getActive TerrysSamsungS7 1
      fb-checkpresence.0	2019-12-09 15:18:18.682	debug	</s:Envelope>
      fb-checkpresence.0	2019-12-09 15:18:18.682	debug	</s:Body>
      fb-checkpresence.0	2019-12-09 15:18:18.682	debug	</u:GetSpecificHostEntryResponse>
      fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<NewHostName>TerrysSamsungS7</NewHostName>
      fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<NewActive>1</NewActive>
      fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<NewInterfaceType>802.11</NewInterfaceType>
      fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<NewLeaseTimeRemaining>864000</NewLeaseTimeRemaining>
      fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<NewAddressSource>DHCP</NewAddressSource>
      fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<NewIPAddress>192.168.3.131</NewIPAddress>
      fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<u:GetSpecificHostEntryResponse xmlns:u="urn:dslforum-org:service:Hosts:1">
      fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<s:Body>
      fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
      fb-checkpresence.0	2019-12-09 15:18:18.682	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s
      fb-checkpresence.0	2019-12-09 15:18:18.590	debug	state fb-checkpresence.0.UlisSamsungS7.historyHtml changed: <table class="mdui-table"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div class="mdui-green-bg mdui-state mdui-card
      fb-checkpresence.0	2019-12-09 15:18:18.590	debug	state fb-checkpresence.0.UlisSamsungS7.history changed: [{"Active":"true","Date":"2019.12.09 03:18:17"},{"Active":"true","Date":"2019.12.09 01:48:00"},{"Active":"false","Date":"2019.12.09 01:46:00"},
      fb-checkpresence.0	2019-12-09 15:18:18.590	debug	state fb-checkpresence.0.UlisSamsungS7.absent.sum_day changed: 643 (ack = true)
      fb-checkpresence.0	2019-12-09 15:18:18.589	debug	state fb-checkpresence.0.UlisSamsungS7.present.sum_day changed: 275 (ack = true)
      fb-checkpresence.0	2019-12-09 15:18:18.589	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.historyHtml {"val":"<table class=\"mdui-table\"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div cla
      fb-checkpresence.0	2019-12-09 15:18:18.588	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.history {"val":"[{\"Active\":\"true\",\"Date\":\"2019.12.09 03:18:17\"},{\"Active\":\"true\",\"Date\":\"2019.12.09 01:48:00
      fb-checkpresence.0	2019-12-09 15:18:18.587	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.absent.sum_day {"val":643,"ack":true,"ts":1575901098579,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.use
      fb-checkpresence.0	2019-12-09 15:18:18.584	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.present.sum_day {"val":275,"ack":true,"ts":1575901098578,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.us
      fb-checkpresence.0	2019-12-09 15:18:18.574	info	UlisSamsungS7: No history before this day is available (lastVal = null)
      fb-checkpresence.0	2019-12-09 15:18:18.569	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"ack":true,"from":"system.adapter.influxdb.0","
      fb-checkpresence.0	2019-12-09 15:18:18.558	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
      fb-checkpresence.0	2019-12-09 15:18:18.555	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"val":true,"ts":1575793020415},{"ack":true,"fro
      fb-checkpresence.0	2019-12-09 15:18:18.542	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
      fb-checkpresence.0	2019-12-09 15:18:18.541	debug	history start
      fb-checkpresence.0	2019-12-09 15:18:18.317	debug	state fb-checkpresence.0.UlisSamsungS7.absent.since changed: 0 (ack = true)
      fb-checkpresence.0	2019-12-09 15:18:18.316	debug	state fb-checkpresence.0.UlisSamsungS7.present.since changed: 90 (ack = true)
      fb-checkpresence.0	2019-12-09 15:18:18.316	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.absent.since {"val":0,"ack":true,"ts":1575901098303,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.ad
      fb-checkpresence.0	2019-12-09 15:18:18.315	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.present.since {"val":90,"ack":true,"ts":1575901098299,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.
      fb-checkpresence.0	2019-12-09 15:18:18.313	debug	getActive [{"Name":"UlisSamsungS7","Active":"true","Kommt":"2019.12.09 01:48:00","Geht":"2019.12.09 01:46:00"},
      fb-checkpresence.0	2019-12-09 15:18:18.296	debug	getActive UlisSamsungS7 1
      fb-checkpresence.0	2019-12-09 15:18:18.293	debug	</s:Envelope>
      fb-checkpresence.0	2019-12-09 15:18:18.293	debug	</s:Body>
      fb-checkpresence.0	2019-12-09 15:18:18.293	debug	</u:GetSpecificHostEntryResponse>
      fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<NewHostName>UlisSamsungS7</NewHostName>
      fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<NewActive>1</NewActive>
      fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<NewInterfaceType>802.11</NewInterfaceType>
      fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<NewLeaseTimeRemaining>0</NewLeaseTimeRemaining>
      fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<NewAddressSource>DHCP</NewAddressSource>
      fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<NewIPAddress>192.168.3.136</NewIPAddress>
      fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<u:GetSpecificHostEntryResponse xmlns:u="urn:dslforum-org:service:Hosts:1">
      fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<s:Body>
      fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
      fb-checkpresence.0	2019-12-09 15:18:18.293	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s
      fb-checkpresence.0	2019-12-09 15:18:18.251	debug	state fb-checkpresence.0.guest changed: false (ack = true)
      fb-checkpresence.0	2019-12-09 15:18:18.251	debug	state fb-checkpresence.0.activeDevices changed: 68 (ack = true)
      fb-checkpresence.0	2019-12-09 15:18:18.250	debug	state fb-checkpresence.0.guest.count changed: 0 (ack = true)
      fb-checkpresence.0	2019-12-09 15:18:18.250	debug	state fb-checkpresence.0.guest.listJson changed: [] (ack = true)
      fb-checkpresence.0	2019-12-09 15:18:18.250	debug	state fb-checkpresence.0.guest.listHtml changed: <table class="mdui-table"><thead><tr><th>Hostname</th><th>IPAddress</th><th>MACAddress</th></tr></thead><tbody></body></table> (ack = true)
      fb-checkpresence.0	2019-12-09 15:18:18.249	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.guest {"val":false,"ack":true,"ts":1575901098240,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":1575742
      afuerhoff 2 Replies Last reply Reply Quote 0
      • afuerhoff
        afuerhoff Developer @zahnheinrich last edited by
        @zahnheinrich
        Hallo, was wird denn in der Historie zu einem der Datenpunkte angezeigt? Kannst Du mal den aktuellen und den Tag davor posten. Falls vorhanden.
        Nach Meldung dürften keine Historien Einträge vor dem aktuellen Tag vorhanden sein.
        • afuerhoff
          afuerhoff Developer last edited by
          zur Info! Ich habe eine neue Version zum Testen auf Github hochgeladen -> v0.2.0
          • afuerhoff
            afuerhoff Developer @afuerhoff last edited by
            @afuerhoff sagte in Test Adapter fb-checkpresence v0.1.x:
            @ple
            Ich hab schon überlegt, ob ich eine Abfrage der in der Fritzbox hinterlegten Dienste mit einbaue und nach Verfügbarkeit dann Funktionen hinzu nehme + Hinweis im Log.
            Hallo, in der neuen Version 0.2.0 habe ich eine Abfrage hierzu integriert. Vielleicht kannst Du die nochmal mit Deiner Fritzbox testen, ob im Log entsprechende Hinweise zum Support der Funktionen kommen.
            • afuerhoff
              afuerhoff Developer @Scrounger last edited by
              @Scrounger sagte in Test Adapter fb-checkpresence v0.1.x:
              @afuerhoff
              Also ich finde deinen Adapter Klasse 👍
              Hab lange den tr-064 Adapter verwendet, aber immer wieder Probleme gehabt, weil der eigenständig die Datenpunkt umbenennt -> siehe Fehlerbeschreibung
              Mit deinem funktioniert meine Anwesenheitserkennung wieder stabil - ok die letzten drei Tage 😉
              Wäre super wenn du den Adapter noch publishen könntest, damit er im latest verfügbar wird und man Änderungen automatisch mitbekommt.
              @sigi234 sagte in [Neuer Adapter] iobroker.checkpresence:
              Schau dir das mal an:
              https://forum.iobroker.net/topic/4538/anwesenheitscontrol-basierend-auf-tr64-adapter-script
              Wenn das gehen würde könnte mir das Skript einsparen.........
              Das wäre natürlich sehr nice.
              Hallo, hast Du schon die neue Version 0.2.0 gesehen. Falls Du noch den Adapter verwendest bitte testen. Ich möchte diesen Stand gerne veröffentlichen.
              • afuerhoff
                @zahnheinrich sagte in Test Adapter fb-checkpresence v0.1.x:
                @afuerhoff
                Jupp:
                Hallo, hast Du immer noch diese Meldung im Log? Ich habe inzwischen eine neue Version 0.2.0 in der Testrubrik gepostet. Falls Interesse bitte testen.
                Z 3 Replies Last reply Reply Quote 0
                • Z
                  @afuerhoff
                  Danke für den Hinweis.
                  Teste ich und melde mich.
                  Grüße Ulrich
                  • Z
                    @afuerhoff
                    Noch eine Frage zum Verständnis:
                    Muss ich und wenn ja welche spezielle(n) Datenpunkte in InfluxDB loggen?
                    afuerhoff 1 Reply Last reply Reply Quote 0
                    • afuerhoff
                      @afuerhoff
                      Der Adapter stellt die History selber ein. Du musst nur in der Konfiguration den History Adapter auswählen.
                      Gruß Achim
                      • Z
                        @afuerhoff
                        Ok danke.
                        Dachte ich mir zwar, aber sicher ist sicher...
                        • Z
                          @afuerhoff
                          Leider ja!
                          Adapter (neueste Vers.) läuft seit einigen Tagen, trotzdem kommt:
                          fb-checkpresence.0	2020-01-09 15:03:00.890	info	(27205) TerrysSamsungS50: No history before this day is available (lastVal = null)
                          fb-checkpresence.0	2020-01-09 15:03:00.829	info	(27205) UlisSamsungS50: No history before this day is available (lastVal = null)
                          • afuerhoff
                            @zahnheinrich
                            Kannst du die Historienwerte aus der ioBroker Objeksicht von einem Familienmitglied einmal hier posten.
                            • Z
                              @afuerhoff
                              Bitteschön:
                              false	true	fb-checkpresence.0	2020-01-07 13:07:17.038
                              false	true	fb-checkpresence.0	2020-01-08 11:25:00.879
                              true	true	fb-checkpresence.0	2020-01-08 11:28:00.765
                              false	true	fb-checkpresence.0	2020-01-08 15:26:00.820
                              true	true	fb-checkpresence.0	2020-01-08 16:24:00.894
                              false	true	fb-checkpresence.0	2020-01-08 17:16:00.835
                              true	true	fb-checkpresence.0	2020-01-08 17:18:00.754
                              false	true	fb-checkpresence.0	2020-01-09 01:22:00.764
                              true	true	fb-checkpresence.0	2020-01-09 09:49:01.226
                              false	true	fb-checkpresence.0	2020-01-09 14:04:00.847
                              true	true	fb-checkpresence.0	2020-01-09 14:50:00.974
                              • afuerhoff
                                @zahnheinrich
                                Die Historie sieht gut aus. Da muss noch ein Fehler in der Auswertung sein. Werden denn die Objekte mit den richtigen Werten beschrieben, oder fehlt da was?
                                • O
                                  onkel-ede last edited by
                                  ich habe bei der Visualisierung des Zeitpunktes einen Versatz von 1 Stunde. Wo finde ich eine Einstellmöglichkeit, dies zu korrigieren:
                                  onkel-ede
                                  • afuerhoff
                                    afuerhoff Developer @cvidal last edited by
                                    @cvidal sagte in Test Adapter fb-checkpresence v0.1.x:
                                    Ich würde mir noch den History Adapter Influxdb wünschen
                                    Hallo, es gibt inzwischen eine Version 0.2.0 die Influxdb enthält. Bitte testen.
                                    cvidal 1 Reply Last reply Reply Quote 0
                                    • afuerhoff
                                      afuerhoff Developer @onkel-ede last edited by
                                      @onkel-ede sagte in Test Adapter fb-checkpresence v0.1.x:
                                      Hallo, du kannst im VIS Timestamp (basic Widget) verwenden. Damit sollte es so angezeigt werden, wie du es formatierst.
                                      • cvidal
                                        cvidal Forum Testing @afuerhoff last edited by
                                        Hab ich jetzt installiert, lief ohne Probleme.
                                        Ich lasse es jetzt mal ein Paar Tage laufen und werde berichten.
                                        Besten Dank
                                        • O
                                          @afuerhoff: Danke für den Tipp mit VIS Timestamp (basic Widget), hat funktioniert. Version 0.2.0 teste ich ebenfalls.
                                          • afuerhoff
                                            afuerhoff Developer @cvidal last edited by afuerhoff
                                            @cvidal @onkel-ede
                                            Ergebnisse dann bitte unter 0.2.0 posten.
                                            31.7k
                                            79.8k
                                            fb-checkpresence adapter
                                            30
                                            346
                                            44086
