    4. Test Adapter deConz v1.2.x Github
    • haselchen
      haselchen Most Active @Jey Cee last edited by
      @Jey-Cee
      Beim Update von 1.1.2 auf 1.2.1 über die Katze und Upload danach gab es diesen Fehler:
        Pischleuder last edited by
        Moin,
        beim mir startet der Adapter erst gar nicht, d.h. der Status wechselt von gelb auf rot und so weiter.
        code_text
        deconz.0	2020-01-07 20:27:33.970	info	(11462) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        deconz.0	2020-01-07 20:27:33.967	info	(11462) terminating
        deconz.0	2020-01-07 20:27:33.757	debug	(11462) getGroupScenes for Groups.undefined: undefined
        deconz.0	2020-01-07 20:27:33.744	debug	(11462) getGroupScenes for Groups.undefined: undefined
        deconz.0	2020-01-07 20:27:33.729	debug	(11462) getGroupScenes for Groups.undefined: undefined
        deconz.0	2020-01-07 20:27:33.715	debug	(11462) getGroupScenes for Groups.undefined: undefined
        deconz.0	2020-01-07 20:27:33.700	debug	(11462) getGroupScenes for Groups.undefined: undefined
        deconz.0	2020-01-07 20:27:33.686	debug	(11462) getGroupScenes for Groups.undefined: undefined
        deconz.0	2020-01-07 20:27:33.672	debug	(11462) getGroupScenes for Groups.undefined: undefined
        deconz.0	2020-01-07 20:27:33.657	debug	(11462) getGroupScenes for Groups.undefined: undefined
        deconz.0	2020-01-07 20:27:33.641	debug	(11462) getGroupScenes for Groups.undefined: undefined
        deconz.0	2020-01-07 20:27:33.625	debug	(11462) getGroupAttributes: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"5b499b6d677d768fa4cfefd024c
        deconz.0	2020-01-07 20:27:33.579	debug	(11462) NOTIFY {"protocol":"http","version":"1.1","method":"NOTIFY","path":"*","headers":{"host":"239.255.255.250:1900","cache-control":"max-age=100","location":"http://192.168.178.89:80/description.x
        deconz.0	2020-01-07 20:27:33.568	debug	(11462) getGroupScenes for Groups.1: []
        deconz.0	2020-01-07 20:27:33.553	info	(11462) Got terminate signal TERMINATE_YOURSELF
        • haselchen
          haselchen Most Active last edited by
          Ich bekomme den Terminated due SIGTERM nicht weg.
          Er startet und beendet die Instanz permanent.
          • coyote
            coyote Most Active last edited by
            Bei mir leider auch das gleiche Problem
            • Jey Cee
              Jey Cee Developer @haselchen last edited by
              Da läuft noch eine Instanz, iobroker stoppen sollte helfen.
              • haselchen
                @Jey-Cee
                Alles durch.
                Stoppen , Neustart....
                Es kommt bei mir immer der SIGTERM Fehler
                  bei mir auch - nur etwas anderer error:
                  deconz.0	2020-01-07 20:59:51.584	info	(16866) Got terminate signal TERMINATE_YOURSELF
                  deconz.0	2020-01-07 20:59:51.334	debug	(16866) getDevices: {"statusCode":404,"body":"[]","headers":{"access-control-allow-origin":"*","content-type":"application/json; charset=utf-8","content-length":"2"},"request":{"uri":{"protocol":"http
                  deconz.0	2020-01-07 20:59:51.331	debug	(16866) getAllGroups: {}
                  deconz.0	2020-01-07 20:59:51.327	error	(16866) RangeError: Invalid time value at Date.toISOString (<anonymous>) at UTCtoLocal (/opt/iobroker/node_modules/iobroker.deconz/main.js:1712:35) at new setObjectAndState (/opt/iobroker/
                  deconz.0	2020-01-07 20:59:51.326	error	(16866) uncaught exception: Invalid time value
                  deconz.0	2020-01-07 20:59:51.308	debug	(16866) getAllSensors: {"1":{"config":{"configured":false,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":null,"manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"dark"
                  deconz.0	2020-01-07 20:59:51.303	debug	(16866) getAllLights: {}
                  deconz.0	2020-01-07 20:59:51.280	info	(16866) Got terminate signal TERMINATE_YOURSELF
                  deconz.0	2020-01-07 20:59:51.210	debug	(16866) API version: 1.16.0
                  deconz.0	2020-01-07 20:59:51.144	debug	(16866) M-SEARCH from 192.168.178.89 for "urn:schemas-upnp-org:device:basic:1"
                  deconz.0	2020-01-07 20:59:51.031	info	(16866) Auto discovery
                  deconz.0	2020-01-07 20:59:50.960	info	(16866) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.18.0
                  deconz.0	2020-01-07 20:59:42.484	info	(16736) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  deconz.0	2020-01-07 20:59:42.481	info	(16736) terminating
                  deconz.0	2020-01-07 20:59:42.075	info	(16736) Got terminate signal TERMINATE_YOURSELF
                  • Jey Cee
                    Jey Cee Developer @Pischleuder last edited by
                    @Pischleuder bei dir gibt es ein Problem mit lastupdated.
                    @all könnt ihr mir bitte eure Logs, aus der Datei nicht im Admin, zeigen.
                      Pischleuder @Jey Cee last edited by
                      @Jey-Cee
                      mir ist nicht ganz klar, was du möchtest 🙂
                      • coyote
                        Irgendwie seltsam, bekomme jetzt nach einem Downgrade auch die "alte" Version nicht mehr zum Laufen...
                        host.debian	2020-01-07 21:38:02.643	info	instance system.adapter.deconz.0 terminated with code 156 (156)
                        host.debian	2020-01-07 21:38:02.446	warn	instance system.adapter.deconz.0 already running with pid 17549
                        deconz.0	2020-01-07 21:38:01.023	info	(17549) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        deconz.0	2020-01-07 21:38:01.019	info	(17549) terminating
                        host.debian	2020-01-07 21:38:00.945	info	stopInstance system.adapter.deconz.0 killing pid 17549
                        host.debian	2020-01-07 21:38:00.914	info	stopInstance system.adapter.deconz.0 killing pid 17549
                        deconz.0	2020-01-07 21:38:00.386	info	(17549) Got terminate signal TERMINATE_YOURSELF
                        deconz.0	2020-01-07 21:38:00.374	info	(17549) Got terminate signal TERMINATE_YOURSELF
                        host.debian	2020-01-07 21:37:59.945	info	stopInstance system.adapter.deconz.0 send kill signal
                        host.debian	2020-01-07 21:37:59.930	info	stopInstance system.adapter.deconz.0 (force=false, process=true)
                        host.debian	2020-01-07 21:37:59.894	info	stopInstance system.adapter.deconz.0 send kill signal
                        host.debian	2020-01-07 21:37:59.849	info	stopInstance system.adapter.deconz.0 (force=false, process=true)
                        deconz.0	2020-01-07 21:37:59.651	info	(17549) Auto discovery
                        deconz.0	2020-01-07 21:37:59.613	info	(17549) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.17.0
                        host.debian	2020-01-07 21:37:57.792	info	instance system.adapter.deconz.0 started with pid 17549
                        host.debian	2020-01-07 21:37:57.749	info	instance system.adapter.deconz.0 terminated with code 156 (156)
                        host.debian	2020-01-07 21:37:56.070	info	stopInstance system.adapter.deconz.0 killing pid 17532
                        host.debian	2020-01-07 21:37:55.917	info	stopInstance system.adapter.deconz.0 killing pid 17532
                        deconz.0	2020-01-07 21:37:55.589	info	(17532) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        deconz.0	2020-01-07 21:37:55.588	info	(17532) terminating
                        deconz.0	2020-01-07 21:37:55.444	info	(17532) Got terminate signal TERMINATE_YOURSELF
                        host.debian	2020-01-07 21:37:55.070	info	stopInstance system.adapter.deconz.0 send kill signal
                        host.debian	2020-01-07 21:37:55.058	info	stopInstance system.adapter.deconz.0 (force=false, process=true)
                        deconz.0	2020-01-07 21:37:54.966	info	(17532) Got terminate signal TERMINATE_YOURSELF
                        host.debian	2020-01-07 21:37:54.912	info	stopInstance system.adapter.deconz.0 send kill signal
                        host.debian	2020-01-07 21:37:54.897	info	stopInstance system.adapter.deconz.0 (force=false, process=true)
                        deconz.0	2020-01-07 21:37:54.735	info	(17532) Auto discovery
                        deconz.0	2020-01-07 21:37:54.682	info	(17532) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.17.0
                          Pischleuder last edited by Pischleuder
                          ja, hatte ich auch - du musst dann ganz zurück auf die 1.0.1 - so war es zumindest bei mir.
                          Interessant ist, dass bei dem 1.2.1, obwohl der Status immer zwischen rot und gelb wechselt. dennoch die richtigen Daten in die Knotenpunkte geschrieben werden.
                          • lobomau
                            lobomau last edited by lobomau
                            Bei mir die gleiche Fehlermeldung wie bei coyote, Wechsel zw. gelb und rot. Aber Daten scheinen richtig geschrieben und aktualisert zu werden.
                            Edit: der Adapter erhöht bei mir die CPU-Last für ioBroker von 22% auf knapp 60% . Ich habe erstmal den Adapter gestoppt.
                            • Jey Cee
                              Jey Cee Developer @coyote last edited by
                              @coyote Adapter komplett gelöscht und dann neu Installiert?
                              @lobomau sagte in Test Adapter deConz v1.2.x Github:
                              Ja das Liegt daran das er immer wieder neu startet, deswegen werden auch die Daten von deConz gelesen.
                              • haselchen
                                @Jey-Cee
                                Sind für Version 1.2.1 bestimmte Versions-Voraussetzungen nötig?
                                JSController, NodeJS?
                                Ich bin erstmal wieder auf die 1.1.2 zurück.
                                • coyote
                                  @Jey-Cee ja, komplett gelöscht hatte ich auch.
                                  Habe jetzt 1.0.1 nochmal installiert und wieder Update auf die letzte Version gemacht, ist jetzt wieder grün.
                                  • Jey Cee
                                    Jey Cee Developer last edited by Jey Cee
                                    @haselchen @coyote @lobomau Problem gefunden, Lösung erfordert etwas mehr Arbeit dauert also.
                                    @Pischleuder @Marco-Laser bei euch gibt es noch ein anderes Problem darum kann ich mich erst kümmern wenn das andere erledigt ist.
                                    Momentan NICHT Installieren, es gibt ein Schwerwiegendes Problem
                                    1 Reply Last reply Reply Quote 4
                                      👍 gute Dinge benötigen Zeit 🙂
                                      Dennoch, obwohl der Adapter die ganze Nacht hindurch zwischen gelb und rot gewechselt hat, sind alle Daten permanent korrekt geschrieben worden - strange.
                                        Alex975 last edited by
                                        wie komme ich jetzt eigentlich an die version 1.2.0 ran? Wenn ich über "aus eigener Url" auswähle wird ja nur die 1.2.1 installiert.
                                        habe jetzt die 1.1.2 drauf (Adapter bleibt aber gelb)
                                          du schaltest im Admin Bereich bei den Adaptern oben den Expertenmodus an (das Piktogramm mit dem Bild), daraufhin erscheint neben den jeweiligen Adpatern ein + Zeichen. Hier kannst du nun eine bestimmte Version auswählen.
                                          • Jey Cee
                                            @Pischleuder geht in dem fall nicht,die 1.2.0 ost nicht auf npm.
                                            A 2 Replies Last reply Reply Quote 0
                                            31.7k
                                            79.8k
                                            deconz hue zigbee
                                            30
                                            250
                                            28479
