    4. BLE adapter startet nicht mehr
    SOLVED BLE adapter startet nicht mehr
      Joker971 @haselchen last edited by
      @haselchen
      Jetzt startet der Adapter nicht mehr weil er die node Version anmeckert:
      ble.0	2020-01-07 22:00:07.588	info	the module (for instance, using `npm rebuild` or `npm install`).
      ble.0	2020-01-07 22:00:07.588	info	NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
      ble.0	2020-01-07 22:00:07.588	info	NODE_MODULE_VERSION 57. This version of Node.js requires
      ble.0	2020-01-07 22:00:07.588	info	was compiled against a different Node.js version using
      ble.0	2020-01-07 22:00:07.588	info	(30128) Terminated (ADAPTER_REQUESTED_TERMINATION): The module '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node'
      ble.0	2020-01-07 22:00:07.586	error	the module (for instance, using `npm rebuild` or `npm install`).
      ble.0	2020-01-07 22:00:07.586	error	NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
      ble.0	2020-01-07 22:00:07.586	error	NODE_MODULE_VERSION 57. This version of Node.js requires
      ble.0	2020-01-07 22:00:07.586	error	was compiled against a different Node.js version using
      ble.0	2020-01-07 22:00:07.586	error	(30128) Terminating because The module '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node'
      ble.0	2020-01-07 22:00:07.222	info	(30128) monitoring all services
      ble.0	2020-01-07 22:00:07.218	info	(30128) enabled plugins: Xiaomi, _default
      ble.0	2020-01-07 22:00:07.214	info	(30128) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
      ble.0	2020-01-07 22:00:07.060	info	(30128) starting. Version 0.9.2 in /opt/iobroker/node_modules/iobroker.ble, node: v10.18.0
      • haselchen
        haselchen Most Active @Joker971 last edited by
        @Joker971
        Joa, vermutlich haut mich @AlCalzone
        aber ich würde entweder dannVersion 0.10.0 nehmen oder 0.10.1 oder die NodeJS Version downgraden.
        Wie du an meiner Sigantur erkennst habe ich die 8er Version und 0.10.1 als Adapter Version und alles läuft.
          arnold last edited by
          @haselchen
          • haselchen
            haselchen Most Active @arnold last edited by haselchen
            @arnold
            Dir rate ich das gleiche. Du hast Node 10.18
            Ich kann nur von meiner Konfig ausgehen und wie ich es gemacht habe.
              @haselchen
              ich glaub bis ich das mache probiere ich noch etwas herum. Das wäre für mich das letzte Mittel. Notfalls verzichte ich auf den Blumensensor. Ist ne nette Spielerei aber mehr auch nicht 😉
              Erstmal vielen Dank für deine Hilfe! Immerhin läuft Bluetooth wenigstens wieder 🙂
              • haselchen
                haselchen Most Active @Joker971 last edited by haselchen
                @Joker971
                Okay , kann ich verstehen.
                Da ich nen Spielkalb bin, würde ich nen Backup machen und Nodejs downgraden 🙂
                Hier kannst du vielleicht noch eine Lösung finden.
                Habe es überflogen, ein paar Mal wird dein Fall auch genannt.
                https://forum.iobroker.net/topic/7500/aufruf-ble-adapter-testen-v0-6-0?page=1&lang=en-GB
                  @haselchen
                  was meinst du die NodeJS Version downgraden (Nodejs 8.16.2) oder ble.0 0.10....?nehmen
                  mein ble.0 it running ,
                  • haselchen
                    @arnold
                    HI,
                    was läuft denn dann bei dir nicht?
                      Ble.0 010.1
                      Node -v 10.18.0
                      mpn 6.13.14
                      Nodejs -v 10.18.0
                        was soll ich ändern ?
                        ich habe am Rpi3 xiaomi temp/feucht gefunden oder ?
                          @haselchen
                          So ich habe eine Lösung gefunden :
                          Klick
                          Aber erst als ich die letzte Zeile aus dem Therad installiert hatte ging es!
                          Scheinbar war das nicht das richtige Treiberpaket für einen Raspi.
                          haselchen 1 Reply Last reply Reply Quote 1
                            nur iobroker nicht
                            • haselchen
                              @Joker971
                              Supi.
                              Nun läuft dein Adapter?
                              Driver State Powered On?
                              • haselchen
                                @arnold
                                Was willst du denn einbinden für ein Gerät?
                                Stell mal den Intervall auf 60000.
                                  ich will xiaomi temp/feucht sensor mit display (bluetooth nicht die zigbee)
                                  wie Matthias in video
                                  https://youtu.be/sobxUG92lpU
                                  • haselchen
                                    @arnold
                                    Hast du alles exakt wie im Video gemacht?
                                      ja ,
                                      der hat auch schon den pflanzen Sensor gemacht vor 1/2 jahr hat auch bei mir nicht geklapt
                                        @haselchen
                                        @haselchen sagte in BLE adapter startet nicht mehr:
                                        @Joker971
                                        Supi.
                                        Jep...alles tutti 🙂
                                        • haselchen
                                          @arnold
                                          Dann geh die Befehle wie bei Joker971 nochmal durch.
                                          Er hat zum Schluss (so vermute ich)
                                          sudo apt-get install pi-bluetooth
                                          eingegeben.
                                            sudo systemctl start bluetooth.service
                                            sudo systemctl enable bluetooth.service
                                            die befehle ???
                                            ble adapter startet nicht
                                            11
                                            69
                                            6292
