    4. JavaScript
    5. [Vorlage] Alias per Skript erzeugen
      paul53 @patti72 last edited by paul53
      @patti72 sagte:
      Die selbe Warnung im log.
      Die Warnung ist oben leider nicht vollständig. Bitte nochmal aus dem Reiter "Log" in Code tags posten.
        patti72 @paul53 last edited by
        Mehr kommt nicht, wenn ich das Script starte.
        2020-01-04 08:17:42.694 - debug: javascript.0 (2420) system.adapter.admin.0: logging false
        2020-01-04 08:17:43.293 - debug: javascript.0 (2420) system.adapter.admin.0: logging true
        2020-01-04 08:17:52.269 - debug: javascript.0 (2420) sendTo "loadTypings" to system.adapter.admin.0 from system.adapter.javascript.0
        2020-01-04 08:20:47.665 - debug: javascript.0 (2420) sendTo "loadTypings" to system.adapter.admin.0 from system.adapter.javascript.0
        2020-01-04 08:20:53.988 - info: javascript.0 (2420) Stop script script.js.common.alias_anlegen
        2020-01-04 08:20:56.554 - info: javascript.0 (2420) Start javascript script.js.common.alias_anlegen
        2020-01-04 08:20:56.569 - info: javascript.0 (2420) script.js.common.alias_anlegen: getObject(id=deconz.0.Lights.2.on, enumName=undefined) => {"type":"state","common":{"name":"Lampe1 on","type":"boolean","role":"switch","read":true,"write":true},"native":{},"from":"system.adapter.deconz.0","user":"system.user.admin","ts":1578087361576,"_id":"deconz.0.Lights.2.on"}
        2020-01-04 08:20:56.571 - warn: javascript.0 (2420) script.js.common.alias_anlegen: setObject(id=alias.0.lampe2, obj={"type":"state","common":{"name":"Lampe1 on","type":"boolean","role":"switch","read":true,"write":true,"alias":{"id":"deconz.0.Lights.2.on"}},"native":{}}) - was not executed, while debug mode is active
        2020-01-04 08:20:56.572 - info: javascript.0 (2420) script.js.common.alias_anlegen: registered 0 subscriptions and 0 schedules
        2020-01-04 08:28:45.983 - debug: javascript.0 (2420) system.adapter.admin.0: logging false
        2020-01-04 08:28:53.754 - info: info.0 (1408) Popup news was read...
        2020-01-04 08:28:55.246 - info: host.iobroker_oben Update repository "default" under "http://download.iobroker.net/sources-dist.json"
        2020-01-04 08:29:48.955 - debug: javascript.0 (2420) system.adapter.admin.0: logging true
          @patti72 sagte:
          Debug-Modus ausschalten !
            @paul53 von der JS Instanz oder im Script?
            paul53 1 Reply Last reply Reply Quote -1
              @patti72 sagte:
              Im Zweifel beide.
                @paul53 Tausend Dank. Hat geholfen.
                • XxJooO
                  XxJooO @XxJooO last edited by
                  @XxJooO sagte in [Vorlage] Alias per Skript erzeugen:
                  ja, der Ausgabewert soll bei true offen und bei false geschlossen ausgeben.
                  • Garfonso
                    Garfonso Developer @Markus84 last edited by
                    @Markus84 said in [Vorlage] Alias per Skript erzeugen:
                    Wenn ich Name, state oder role ändere, wird diese Änderung jedoch nicht mitsynchronisiert. Ist das normal? Falls dies normal ist, kann ich bedenkenlos diese Daten im Alias ändern (werden dann logischerweise zwar nicht synchronisiert) oder lässt man besser die Finger davon?
                    Es ist ja gerade die Idee von der Alias-Funktion, dass du am Alias-Objekt role, Name, Funktion, Raum usw. "schön" setzt. Die Objekte im Adapternamespace können sich ja beliebig ändern, wenn der Adapter das für richtig hält oder wenn mal ein Gerät ersetzt werden soll.
                      Markus84 @Garfonso last edited by
                      @Garfonso Danke für die Klarstellung! Wenn man einmal verstanden hat, wofür Alias-Objekte sind, ist es natürlich logisch. Es macht bestimmt eine riesen Arbeit die Alias-Objekte einmal einzurichten, aber das ist es auf lange Sicht definitiv Wert.
                      • Z
                        zahnheinrich @Markus84 last edited by
                        Ich möchte für meine Xiaomi Bewegungsmelder einen alias Datenpunkt erstellen.
                        Im Xiaomi ist der Datenpunkt vom Typ number und zeigt die verstrichene Zeit in Sekunden seit der letzten Auslösung an:
                        "_id": "mihome.0.devices.motion_158d00013f7666.no_motion",
                        "common": {
                        "name": "Last motion",
                        "role": "state",
                        "write": false,
                        "read": true,
                        "type": "number",
                        "unit": "seconds",
                        "desc": "Last motion for at least X seconds"
                        "type": "state",
                        "native": {},
                        "from": "system.adapter.mihome.0",
                        "ts": 1545432495106,
                        "acl": {
                        "object": 1636,
                        "state": 1636,
                        "owner": "system.user.admin",
                        Der alias Datenpunkt soll ein boolean sein, der bei (Xiaomi = 0) true und sonst (Xiaomi > 0) false ist.
                        Dein Skript am Fredanfang habe ich so angepasst:
                        // Original-Datenpunkt
                        const idOrigin = 'mihome.0.devices.motion_158d00013f7666.no_motion';
                        // Alias-Datenpunkt
                        const idAlias = 'BWM.Raeumchen.MOTION';
                        var typeAlias, read, write, nameAlias, role, desc, min, max, unit, states;
                        // Folgende kommentieren, wenn keine Änderung der Eigenschaft erforderlich
                        //typeAlias = 'number'; // typeAlias = 'boolean'; // oder 'number'
                        read = "val == '0' ? true : false"; // Erkennung "Aus" --> false erfolgt automatisch
                        //write = "val ? 'Ein' : 'Aus'";
                        nameAlias = 'BWM Räumchen';
                        role = 'sensor.motion';
                        desc = 'per Script erstellt';
                        //min = 0; // nur Zahlen
                        //max = 100; // nur Zahlen
                        unit = ''; // nur für Zahlen
                        //states = {0: 'true', 60: 'false'}; // Zahlen (Multistate) oder Logikwert (z.B. Aus/Ein)
                        Bekomme aber den Datenpunkt so angelegt:
                        Was mache ich falsch?
                        Vielen Dank im Voraus!
                        Ulrich
                          paul53 @zahnheinrich last edited by
                          @zahnheinrich sagte:
                          Wie sieht die RAW-Ansicht des Alias-Objektes aus (bitte in Code tags (</>) posten) ?
                          • Z
                            zahnheinrich @paul53 last edited by
                            Bitteschön:
                              "type": "state",
                              "common": {
                                "name": "BWM Räumchen",
                                "role": "sensor.motion",
                                "write": false,
                                "read": true,
                                "type": "boolean",
                                "unit": "seconds",
                                "desc": "per Script erstellt",
                                "alias": {
                                  "id": "mihome.0.devices.motion_158d00013f7666.no_motion",
                                  "read": "val == '0' ? true : false"
                              "native": {},
                              "user": "system.user.admin",
                              "ts": 1578589323783,
                              "_id": "alias.0.BWM.Raeumchen.MOTION",
                              "acl": {
                                "object": 1636,
                                "state": 1636,
                              paul53 @zahnheinrich last edited by paul53
                              @zahnheinrich
                              Lösche mal Zeile 9 (unit) raus und ändere "read"
                                    "read": "val == 0 ? true : false"
                              oder
                                    "read": "val ? false : true"
                              oder
                                    "read": "!val"
                              • Z
                                @paul53 sagte in [Vorlage] Alias per Skript erzeugen:
                                Danke!
                                "read": "!val"
                                funktioniert.
                                Bei "unit" hatte ich im script "" eingetragen. Das führte aber nicht zur gewünschten Unterdrückung jeglicher Einheit im Alias.
                                Muss ich das dann immer händisch löschen, oder?
                                Vielen Dank für deine Mühe, hatte stundenlang alle Konbinationen ohne Erfolg durchprobiert!
                                  if(unit) liefert bei einem Leerstring false, die Einheit wurde also nicht überschrieben. Ein Leerzeichen " " hätte sie unsichtbar gemacht.
                                  Z 2 Replies Last reply Reply Quote 0
                                  • Z
                                    Dankeschön, wieder etwas gelernt 🕶
                                    • Z
                                      Kurioserweise bekomme ich ab jetzt bei einem neuen Datenpunkt ein Infosymbol :
                                      Was sagt mir das?
                                      paul53 crunchip 2 Replies Last reply Reply Quote 0
                                        Was sagt mir das?
                                        ?? Habe ich noch nicht gesehen.
                                        • Z
                                          Da bin ich aber froh 😂
                                          Ich nämlich auch nicht!
                                            crunchip Forum Testing Most Active @zahnheinrich last edited by crunchip
                                            @zahnheinrich hab vor kurzen einen neuen Schalter am Gateway angelernt, nachdem dieser in IoBroker erschien, kam auch dieses Symbol. Hat also nichts mit dem Alias zu tun. Hängt wahrscheinlich eher mit dem Adapter zusammen, bzw eher mit Admin/Js-Controller
                                            314
                                            60841
