    3. Entwicklung
    4. [Projekt] ioGo # Smarthome to go 2.0
      A Former User @DocGame last edited by
      @DocGame die GitHub Version wird nicht gehen. Nimm bitte eine offizielle Version aus stable/latest und poste das Log vom Start der Instanz.
        DocGame @Guest last edited by DocGame
        @nis Hier der Log:
        2019-12-22 11:32:57.668 - info: host.IOBroker(SmartHome) instance system.adapter.iogo.0 started with pid 23344
        2019-12-22 11:33:00.082 - debug: iogo.0 (23344) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2019-12-22 11:33:00.129 - debug: iogo.0 (23344) Objects client ready ... initialize now
        2019-12-22 11:33:00.138 - debug: iogo.0 (23344) Objects create PubSub Client
        2019-12-22 11:33:00.139 - debug: iogo.0 (23344) Objects client initialize lua scripts
        2019-12-22 11:33:00.159 - debug: iogo.0 (23344) objectDB connected
        2019-12-22 11:33:00.162 - debug: iogo.0 (23344) Redis States: Use Redis connection: 127.0.0.1:9000
        2019-12-22 11:33:00.167 - debug: iogo.0 (23344) Objects connected to redis: 127.0.0.1:9001
        2019-12-22 11:33:00.179 - debug: iogo.0 (23344) States create PubSub Client
        2019-12-22 11:33:00.180 - debug: iogo.0 (23344) statesDB connected
        2019-12-22 11:33:00.199 - debug: iogo.0 (23344) States connected to redis: 127.0.0.1:9000
        2019-12-22 11:33:00.357 - info: iogo.0 (23344) starting. Version 0.4.17 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.iogo, node: v10.17.0
        2019-12-22 11:33:00.471 - info: iogo.0 (23344) triggered listener removed
        2019-12-22 11:33:01.129 - info: iogo.0 (23344) licence key found. licence valid until 2020-12-20 13:45:41
        2019-12-22 11:33:01.129 - info: iogo.0 (23344) logged in as: XXXXXXXXXXXXXXXXXXXXX <= please keep this uid as your secret
        2019-12-22 11:33:01.140 - info: iogo.0 (23344) initialize app devices
        2019-12-22 11:33:01.828 - info: iogo.0 (23344) device c-m1q6RyiHE captured
        2019-12-22 11:33:01.829 - info: iogo.0 (23344) device eB-OoFFaDeQ captured
        2019-12-22 11:33:01.830 - info: iogo.0 (23344) calcDeviceAlive is: false all devices {"iogo.0.c-m1q6RyiHE.alive":false}
        2019-12-22 11:33:01.830 - info: iogo.0 (23344) calcDeviceAlive is: true all devices {"iogo.0.c-m1q6RyiHE.alive":false,"iogo.0.eB-OoFFaDeQ.alive":true}
        2019-12-22 11:33:01.889 - info: iogo.0 (23344) checksummap geladen
        2019-12-22 11:33:01.890 - info: iogo.0 (23344) uploading host
        2019-12-22 11:33:01.891 - info: iogo.0 (23344) uploading instance
        2019-12-22 11:33:01.892 - info: iogo.0 (23344) uploading enum
        2019-12-22 11:33:01.893 - info: iogo.0 (23344) uploading state
        2019-12-22 11:33:01.910 - info: iogo.0 (23344) uploading adapter
        2019-12-22 11:33:02.426 - info: iogo.0 (23344) device update received: {"alive":false,"batteryCharging":true,"batteryLevel":92,"token":"c-m1q6RyiHE:APA91bFMrV8yhAQ_R2OQoNCn8evfAWAXWUnYyucur8W95y4Lf5aHDwc8wNkQKcf5NlryB0I0MLGalSVhDL6IaKyw7QbAM6se2zpW-Wy2ygWj7kw7RTLFt89CW77mhz2nfiW8C-B3WMIv","ts":1577009651543}
        2019-12-22 11:33:02.430 - info: iogo.0 (23344) device update received: {"alive":true,"batteryCharging":false,"batteryLevel":86,"name":"S10+","token":"eB-OoFFaDeQ:APA91bEBKaLh0YqovhdAqTpJCm3qmI-FswOMeAxf1TlNP-5hApZPG4kCp8RoxzCTJTk_X8Z8T6W4IkK8bZVhC2H1jniC7-Zho1-E9ijMllB97KsgUdHYc9MmK5MdPG0ssu6IL8RDLvNn","ts":1576962806545}
        2019-12-22 11:33:02.977 - debug: iogo.0 (23344) uploading host start
        2019-12-22 11:33:02.986 - debug: iogo.0 (23344) uploading host end
        2019-12-22 11:33:03.004 - debug: iogo.0 (23344) uploading instance start
        2019-12-22 11:33:03.008 - debug: iogo.0 (23344) uploading instance: system_adapter_iogo_0
        2019-12-22 11:33:03.015 - debug: iogo.0 (23344) uploading instance end
        2019-12-22 11:33:03.024 - debug: iogo.0 (23344) uploading enum start
        2019-12-22 11:33:03.031 - debug: iogo.0 (23344) uploading enum end
        2019-12-22 11:33:03.032 - info: iogo.0 (23344) uploading values
        2019-12-22 11:33:03.313 - debug: iogo.0 (23344) uploading state start
        2019-12-22 11:33:03.322 - info: iogo.0 (23344) custom found for id:shelly.0.SHSW-1#4A595C#1.Relay0.Switch
        2019-12-22 11:33:03.327 - info: iogo.0 (23344) custom found for id:zigbee.0.00158d0002d40924.left_click
        2019-12-22 11:33:03.327 - info: iogo.0 (23344) custom found for id:zigbee.0.7cb03eaa0a050960.state
        2019-12-22 11:33:03.328 - info: iogo.0 (23344) custom found for id:linkeddevices.0.Kinderdecke.brightness
        2019-12-22 11:33:03.328 - info: iogo.0 (23344) custom found for id:linkeddevices.0.Kinderdecke.state
        2019-12-22 11:33:03.332 - debug: iogo.0 (23344) uploading state end
        2019-12-22 11:33:03.337 - debug: iogo.0 (23344) uploading adapter start
        2019-12-22 11:33:03.344 - debug: iogo.0 (23344) uploading adapter end
        2019-12-22 11:33:03.356 - debug: iogo.0 (23344) instance system.adapter.telegram.0.alive updated successfully
        2019-12-22 11:33:03.357 - debug: iogo.0 (23344) instance system.adapter.telegram.0.connected updated successfully
        2019-12-22 11:33:03.602 - debug: iogo.0 (23344) instance system.adapter.telegram.0.memRss updated successfully
        2019-12-22 11:33:03.603 - debug: iogo.0 (23344) instance system.adapter.telegram.0.memHeapTotal updated successfully
        2019-12-22 11:33:03.604 - debug: iogo.0 (23344) instance system.adapter.telegram.0.memHeapUsed updated successfully
        2019-12-22 11:33:03.803 - debug: iogo.0 (23344) uploading values start
        2019-12-22 11:33:03.817 - debug: iogo.0 (23344) uploading state values
        2019-12-22 11:33:03.836 - debug: iogo.0 (23344) uploading instance values
        2019-12-22 11:33:03.847 - debug: iogo.0 (23344) uploading host values
        2019-12-22 11:33:03.849 - debug: iogo.0 (23344) uploading values end
        2019-12-22 11:33:03.854 - debug: iogo.0 (23344) instance system.adapter.linkeddevices.0.alive updated successfully
        2019-12-22 11:33:03.855 - debug: iogo.0 (23344) instance system.adapter.linkeddevices.0.connected updated successfully
        2019-12-22 11:33:03.856 - debug: iogo.0 (23344) instance system.adapter.linkeddevices.0.memRss updated successfully
        2019-12-22 11:33:03.857 - debug: iogo.0 (23344) instance system.adapter.linkeddevices.0.memHeapTotal updated successfully
        2019-12-22 11:33:03.858 - debug: iogo.0 (23344) instance system.adapter.linkeddevices.0.memHeapUsed updated successfully
        2019-12-22 11:33:03.998 - info: iogo.0 (23344) database initialized with 67 state values
        2019-12-22 11:33:04.071 - info: iogo.0 (23344) database initialized with 32 instance values
        2019-12-22 11:33:04.074 - info: iogo.0 (23344) database initialized with 1 host values
        2019-12-22 11:33:05.104 - debug: iogo.0 (23344) instance system.adapter.admin.0.memHeapTotal updated successfully
          @DocGame Und wie sieht es nun in der App aus? Was passiert wenn du dort in der "Info" Ansicht den Button "Sync Objects" klickst?
            @nis Jetzt habe ich wieder den Zustand, den ich heute nacht schon mal hatte. Da ging es auch kurz. Nach umschalten des Servers ioBroker.iogo auf ioBroker.web war die Datenbank wider leer und nichts ging mehr. Im Moment geht es.
            Allerdings sieht es nach viel Arbeit aus. Ich habe mit der Visualisierung auf dem Handy mit Material angefangen. Das hat super geklappt, wurde aber leider nicht weiter verfolgt. Dann ist IQontrol gekommen und hiermit ist ebenfalls gut zu arbeiten. ich bin davon ausgegangen, das du ebenfalls den vergebenen Name der jeweiligen ID für die States verwenden würdest. So wie es aussieht geschied dies ja leider nicht. Ich habe hunderte von Geräten, was ein editieren jedes States für mich quasi unmöglich macht. Gibt es hier noch einen Trick?
              @DocGame Schön dass die Verbindung nun klappt. Ein ständiger Wechsel zwischen den Adaptern iogo/web ist nicht sinnvoll. Die App nutzt zur Anzeige den obj.common.name des State. Wie sieht das RAW von einem deiner States aus?
                @nis Das mit dem Wechseln habe ich ja nur zu Testzwecken gemacht.
                Da der Screenshot von Fenstersensoren war schicke ich dir mal 2 RAWs von Fenstersensoren. Ca 30 von denen habe ich noch an Mi-Hubs hängen. Mit diesen werde ich nach und nach auf den Zigbee-Adapter umziehen, nachdem ich den neuen CC1352P-2 am laufen habe.
                Fenstersensor MiHome-Adapter:
                  "from": "system.adapter.mihome.0",
                  "user": "system.user.admin",
                  "ts": 1567094089506,
                  "common": {
                    "name": "TS Bürofenster",
                    "icon": "/icons/sensor_magnet_aq2.png"
                  "native": {
                    "sid": "158d00023709d9",
                    "type": "sensor_magnet.aq2"
                  "acl": {
                    "object": 1638,
                    "owner": "system.user.admin",
                  "_id": "mihome.0.devices.magnet_158d00023709d9",
                  "type": "channel"
                Fenstersensor Zigbee-Adapter:
                  "from": "system.adapter.zigbee.0",
                  "ts": 1576681290185,
                  "common": {
                    "name": "TS Wohnzimmer hinten rechts",
                    "type": "lumi.sensor_magnet.aq2",
                    "icon": "img/sensor_magnet_aq2.png"
                  "native": {
                    "id": "00158d0003e748be"
                  "acl": {
                    "object": 1638,
                  "_id": "zigbee.0.00158d0003e748be",
                  "type": "device"
                Ich könnte dir auch noch Deconz, MQTT, Yelight usw. schicken..... denke aber, das die Problematik immer die selbe ist.
                  @DocGame Die beiden RAW sind keine States, sondern einmal Channel und einmal Device. Die App synchronisiert nur States. Es gab schon mehrmals den Wunsch den auch Channel/Device zu berücksichtigen. Ist auch noch auf meiner Liste zur Umsetzung, siehe auch: https://github.com/nisiode/iogo-android/issues/45
                  D crunchip 2 Replies Last reply Reply Quote 0
                    @nis Das wäre toll. Ich habe mehrerer Hundert Devices eingebunden. Diese habe wiederum zig States. IQControl macht es schon relativ clever und sucht sich unter dem angewählten Device viele verfügbare States raus. Von Hand bekomme ich das nie in einer angemessenen Zeit hin.
                    Da ich (gerade bei Schaltern und Sensoren) von einem System auf das andere umgestiegen wechsle (z.B. Zigbee nehme ich Deconz, MiHub oder CC1352P-2 je nach Anwendungsfall und jeweilige Unterstützung der Adapter) habe ich angefangen erste Geräte als LinkedDevices anzulegen, damit bei einem Wechsel die Scripts usw. passen. Das ist auch eine ziemliche Arbeit. Vor lauter Konfigurieren komme ich sonst zu nichts mehr anderem.
                    Bei meinen ersten Versuchen mit IoGo habe ich festgestellt das LinkedDevices eh noch nicht unterstützt wird.
                    Ich glaube da heisst es erst mal abwarten was die nächste Zeit so kommt.
                      coto last edited by
                      Hi ich habe meinen Iogo Adapter und APP zum laufen bekommen.
                      Jetzt wollte ich mich dem versenden von Nachrichten zu wenden. Leider hab ich in Blockly unter SendTo kein Blockly von Iogo.
                      Email und Telegram Blockly ist jedoch vorhanden.
                      Eine Neuinstallation des Iogo Adapters hat bisher nicht geholfen.
                      Hat jemand einen Tipp was da noch helfen könnte.
                        A Former User @coto last edited by
                        @coto Hi, das ist einfacher, als gedacht, du nimmst den ersten "sendTo" block und änderst von "admin.0" auf iogo.0 - dann kannst du direkt per Blockly an die App senden.
                        Siehe in der Adapter-Beschreibung (RTFM ) ;-)))
                        https://github.com/nisiode/ioBroker.iogo
                          coto last edited by
                          @ilovegym das war auch mein erster Ansatz, nur hab ich keine Möglichkeit gefunden die Parameter zu erweitern.
                            crunchip Forum Testing Most Active @Guest last edited by
                            @nis sagte in [Projekt] ioGo # Smarthome to go 2.0:
                            @nis da wollt ich auch mal fragen
                            nicht vorhandenen/ gelöschte Geräte werden aber scheinbar nicht erkannt. App synchronisiert, auch Adapter neu gestartet.
                            Habe z.b Raum "Garten"
                            die App zeigt mir an, es wären 12 Elemente hinterlegt. Tatsächlich sind es aber nur 6. Es waren in dem Fall Xiaomi Bluetooth Sensoren im Garten, die aber leider nicht mehr funktionieren. Diese sind im IoBroker gelöscht und als Datenpunkt auch nicht mehr vorhanden. Dieses Problem betrifft auch andere Räume und Funktionen.
                            Als Beispiel
                            hatte per Pulscounter(Wemos) Gas/Wasser/Strom Messwerte hinterlegt. Dieses Gerät hat eine neue IP Adresse bekommen und somit wurden neue Datenpunkte angelegt. Die alten wurden gelöscht. Jedoch werden die Gelöschten weiterhin als "Element" mit aufgezählt.
                              @coto wie bei den anderen Blockly auch, aufs blaue Zahnrad klicken, dann kannst du erweitern bis zum vergasen.. 🙂 ( das steht aber nirgends.. da hast du recht..) 🙂
                                coto last edited by
                                Das hatte ich auch schon vermutet. Bin aber irgendwie zu blöd dafür. Es wird nix geändert wenn ich im zahnrad was anwähle.
                                Ich muss mir da wohl mal ne blockly Anleitung suchen
                                  @coto du klickst aufs Zahnrad, dann poppt ein Fenster auf, und da ziehst du dann die Teile dahin, wo du sie brauchst..
                                    coto @Guest last edited by
                                    @ilovegym danke das sind alles logische schritte die ich bereits versucht hatte. hab es gerade noch mal versucht. Ich hab immer versucht ins Hauptfenster zu verschieben. Gerade stell ich fest das ich nur im sich öffnenden Dialog von links nach rechts schieben muss.
                                    Typischer Layer 8 Fehler.
                                    Danke für deine Hilfe
                                      coto last edited by
                                      Funktioniert doch noch nicht.
                                      Was trage ich bei User ein?
                                        MGK last edited by
                                        @nis Ich möchte nun mit der App meine Vaillant Heizung steuern.
                                        Für die Steuerung habe ich mir 3 Datenpunkte angelegt (Temperatur Tag, Temperatur Nacht und Heizkurve).
                                        Die Temperatur Datenpunkte haben die Rolle "level.temperature" und werden mir auch schon in der App angezeigt.
                                        Leider kann ich die Temperatur aber nur in vollen Grad Schritten (21, 22, 23, ...) verstellen.
                                        Meine Vaillant Heizung kann aber auch 0,5 Grad Schritte, was auch sehr nützlich ist, da ich meistens 22,5 Grad eingestellt habe.
                                        Gibt es eine Möglichkeit auch 0,5 Grad Schritte einzustellen?
                                        Hier mal die RAW Daten von einem Temperatur Datenpunkt:
                                          "from": "system.adapter.cloud.0",
                                          "ts": 1578043728317,
                                          "common": {
                                            "name": "Temperatur Tag",
                                            "role": "level.temperature",
                                            "type": "number",
                                            "desc": "Manuell erzeugt",
                                            "unit": "°C",
                                            "min": 5,
                                            "max": 30,
                                            "def": 5,
                                            "read": true,
                                            "write": true
                                          "native": {},
                                          "acl": {
                                            "object": 1638,
                                            "state": 1638
                                          "_id": "javascript.0.Temperatur_Tag",
                                          "type": "state"
                                        Das nächste Problem habe ich dann mit Datenpunkt Heizkurve, dieser benötigt ein Verstellbereich von 0.1 bis 2.0 in 0.05 Schritten.
                                        Aktuell ist die Heizkurve auf 0.15 eingestellt.
                                        Hast du eine Idee wie ich den Datenpunkt mit dem Verstellbereich in die App bekommen?
                                          MGK last edited by
                                          @nis Ich habe jetzt gerade erst gesehen das du mir wegen dem 0,5 Grad Schritten schon in einem anderem Thread geantwortet hast. Dann ist jetzt nur noch das Thema Heizkurve nicht beantwortet.
                                            A Former User @MGK last edited by
                                            @MGK ist das nicht die gleiche Frage? Die App kann die Schrittweite nirgends draus erkennen. Gibt es Erfahrung wie das in anderen Visualisierungen gelöst wurde?
                                            android app iogo
                                            21
                                            223
                                            30979
