    5. Tastendruck via Blockly simulieren/ auslösen
    • haselchen
      haselchen Most Active @oberfragger last edited by haselchen
      @oberfragger
      steuere clear mit wahr
      aktualisiere clear mit wahr ( funktioniert bei mir auch)
      • dslraser
        dslraser Forum Testing Most Active @haselchen last edited by
        @haselchen
        wollte ich gerade schreiben....
        haselchen 1 Reply Last reply Reply Quote 1
        • haselchen
          haselchen Most Active @dslraser last edited by
          @dslraser
          Erster Erster 😂😂
          oberfragger 1 Reply Last reply Reply Quote 0
          • oberfragger
            oberfragger @haselchen last edited by oberfragger
            @haselchen @dslraser
            Funktioniert nun mit ausschalten, wirft aber jede Menge Warnings.
            javascript.0	2020-01-09 23:19:06.035	info	(24059) script.js.common.Ambilight: aus
            javascript.0	2020-01-09 23:19:06.033	warn	(24059) at processImmediate (timers.js:658:5)
            javascript.0	2020-01-09 23:19:06.033	warn	(24059) at tryOnImmediate (timers.js:676:5)
            javascript.0	2020-01-09 23:19:06.032	warn	(24059) at runCallback (timers.js:705:18)
            javascript.0	2020-01-09 23:19:06.030	warn	(24059) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4848:37)
            javascript.0	2020-01-09 23:19:06.029	warn	(24059) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
            javascript.0	2020-01-09 23:19:06.029	warn	(24059) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
            hyperion.0	2020-01-09 23:19:06.044	info	(7950) Clearing prio on hyperion!
            javascript.0	2020-01-09 23:19:06.028	warn	(24059) at Object.<anonymous> (script.js.common.Ambilight:10:5)
            javascript.0	2020-01-09 23:19:06.028	warn	(24059) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
            javascript.0	2020-01-09 23:19:06.026	warn	(24059) You are assigning a boolean to the state "hyperion.0.control.clear" which expects a state. Please fix your code to use a state or change the state type to boolean. This warning might become an
            javascript.0	2020-01-09 23:19:06.025	warn	(24059) at processImmediate (timers.js:658:5)
            javascript.0	2020-01-09 23:19:06.025	warn	(24059) at tryOnImmediate (timers.js:676:5)
            javascript.0	2020-01-09 23:19:06.024	warn	(24059) at runCallback (timers.js:705:18)
            javascript.0	2020-01-09 23:19:06.024	warn	(24059) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4848:37)
            javascript.0	2020-01-09 23:19:06.023	warn	(24059) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
            javascript.0	2020-01-09 23:19:06.023	warn	(24059) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
            javascript.0	2020-01-09 23:19:06.022	warn	(24059) at Object.<anonymous> (script.js.common.Ambilight:9:5)
            javascript.0	2020-01-09 23:19:06.022	warn	(24059) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
            javascript.0	2020-01-09 23:19:06.020	warn	(24059) You are assigning a boolean to the state "hyperion.0.control.clear" which expects a state. Please fix your code to use a state or change the state type to boolean. This warning might become an
            hyperion.0	2020-01-09 23:19:01.946	info	(7950) Set Color: 0,143,21
            hyperion.0	2020-01-09 23:19:01.940	info	(7950) Setting color to0,143,21
            hyperion.0	2020-01-09 23:19:01.598	info	(7950) Set Color: 0,117,18
            hyperion.0	2020-01-09 23:19:01.590	info	(7950) Setting color to0,117,18
            hyperion.0	2020-01-09 23:19:01.437	info	(7950) Set Color: 0,122,18
            hyperion.0	2020-01-09 23:19:01.424	info	(7950) Setting color to0,122,18
            javascript.0	2020-01-09 23:18:58.130	info	(24059) script.js.common.Ambilight: an
            • haselchen
              @oberfragger
              Eines von beiden.
              Entweder nur steuere oder nur aktualisiere
              • oberfragger
                @haselchen Das hatte ich ja schon... aber weiter die Warnings.
                Das muss doch irgendwie "sauber" gehen...!?!
                  paul53 @oberfragger last edited by
                  @oberfragger sagte:
                  Einen unsauber erstellten Datenpunkt kann man nicht sauber steuern. Datenpunkttyp "state" ist ungültig !
                  oberfragger 1 Reply Last reply Reply Quote 1
                  • oberfragger
                    oberfragger @paul53 last edited by
                    @paul53 Da der Datenpunkt "direkt" aus dem Adapter kommt, habe ich da keine Chanche, außer ein Issue zu erzeugen, oder?
                      @oberfragger sagte:
                      Ja, mach das.
                      • ruhigundrelaxed
                        ruhigundrelaxed last edited by
                        Ja, hoppla, da bin ich. Sry.
                        Dieser Fehler geht auf einen PR von Paul53 zurück, der den Typ von "switch" auf "boolean" geändert hat.
                        https://github.com/ruhigundrelaxed/ioBroker.hyperion/pull/29/commits/f9ac8a2f735805ae3ce5c3ccff2a6ad8e65ed8af
                        Er hatte wohl Fehler im Log...
                        paul53 created this issue in ruhigundrelaxed/ioBroker.hyperion
                        closed common.type switch --> boolean #29
                        ruhigundrelaxed paul53 2 Replies Last reply Reply Quote 0
                        • ruhigundrelaxed
                          ruhigundrelaxed @ruhigundrelaxed last edited by
                          @ruhigundrelaxed said in Tastendruck via Blockly simulieren/ auslösen:
                          Quatsch.... Das war der activator, ihr habt das bei clear all bzw. clearall? Ich checke..
                            paul53 @ruhigundrelaxed last edited by paul53
                            @ruhigundrelaxed sagte:
                            Der PR wurde nie übernommen. Es gibt einige falsche Typ-Zuweisungen im Code.
                            Zulässig sind nur
                            • string
                            • number
                            • boolean
                            • object
                            • array
                            • ruhigundrelaxed
                              Ok. Ich sehe nun meinen Fehler. Ich fixe das.
                              • ruhigundrelaxed
                                So, das sollte gefixed sein. (0.0.16) Ich habe den common type auf jeweils einen der von dir oben aufgezählten Typen geändert. @Paul53 ich hatte deinen PR gesehen. Ich dachte auch, dass ich den gemerged hatte...
                                  Zeile 290 enthält noch common.type: 'text'
                                  • oberfragger
                                    @paul53 Er ist gerade am frickeln. Sagt er hat ne alte Version hochgeladen.
                                    Ich warte mal ab.
                                    • ruhigundrelaxed
                                      ja, er hat gefrickelt. danke, für die zeile 290, hab ich übersehen. mir wird irgendwie schlecht, wenn ich meinen alten code sehe... ich muss den mal grundlegend neu bauen...
                                      3032
