    3. Entwicklung
    4. Zigbee Adapter mit neuem Converter
      Jan1 @LSchulze last edited by
      @LSchulze
      Da wird Serial angemeckert. Hast den Port vom Stick eingetragen und hat das vorher schon mal funktioniert?
      LSchulze 1 Reply Last reply Reply Quote 0
      • LSchulze
        LSchulze @Jan1 last edited by
        @Jan1
        Ja.
        Vorher hatte ich auch mal den direkten pfad drin, dieser link zeigt aber richtig.
        npm list führt ein paar Fehler auf. Wie kann ich diese lösen?
        npm list
        └── zigbee-herdsman-converters@11.2.0
        npm ERR! extraneous: @serialport/binding-mock@8.0.6 /opt/iobroker/node_modules/@serialport/binding-mock
        npm ERR! extraneous: @serialport/stream@8.0.6 /opt/iobroker/node_modules/@serialport/stream
        npm ERR! extraneous: axios@0.18.1 /opt/iobroker/node_modules/axios
        npm ERR! extraneous: express-fileupload@0.4.1 /opt/iobroker/node_modules/express-fileupload
        npm ERR! extraneous: mdns-discovery@0.2.6 /opt/iobroker/node_modules/mdns-discovery
        npm ERR! extraneous: netmask@1.0.6 /opt/iobroker/node_modules/netmask
        npm ERR! extraneous: prebuild-install@5.3.3 /opt/iobroker/node_modules/prebuild-install
        npm ERR! extraneous: systeminformation@4.18.0 /opt/iobroker/node_modules/systeminformation
        npm ERR! peer dep missing: bufferutil@^4.0.1, required by ws@7.2.1
        npm ERR! peer dep missing: utf-8-validate@^5.0.2, required by ws@7.2.1
        npm ERR! peer dep missing: ajv@^5.0.0, required by ajv-keywords@2.1.1
        npm ERR! extraneous: @babel/cli@7.7.4 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/cli
        npm ERR! extraneous: @babel/plugin-proposal-class-properties@7.7.4 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/plugin-proposal-class-properties
        npm ERR! extraneous: @babel/preset-env@7.7.4 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-env
        npm ERR! extraneous: @babel/preset-typescript@7.7.4 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript
        npm ERR! extraneous: @types/debug@4.1.5 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debug
        npm ERR! extraneous: @types/jest@24.0.23 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/jest
        npm ERR! extraneous: @types/nedb@1.8.9 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/nedb
        npm ERR! extraneous: @types/serialport@7.0.4 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/serialport
        npm ERR! extraneous: @typescript-eslint/eslint-plugin@2.8.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin
        npm ERR! extraneous: @typescript-eslint/parser@2.8.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser
        npm ERR! extraneous: eslint@6.7.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/eslint
        npm ERR! extraneous: jest@24.9.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/jest
        npm ERR! extraneous: regenerator-runtime@0.13.3 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/regenerator-runtime
        npm ERR! extraneous: tmp@0.1.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/tmp
        npm ERR! extraneous: typedoc@0.15.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc
        npm ERR! extraneous: typedoc-plugin-markdown@2.2.11 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown
        npm ERR! extraneous: typedoc-plugin-no-inherit@1.1.10 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit
        npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.4 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url
          @LSchulze
          Das ist falsch und deshalb geht das wohl nicht.
            @LSchulze
            Gib mal das in der Konsole ein:
            ls /dev/serial/by-id/
            Und trag das Ergebnis wie folgt ein:
            /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001xxxxxxxx-if00
            • LSchulze
              @Jan1 said in Zigbee Adapter mit neuem Converter:
              @LSchulze
              Ändert nix.
              host.ioBroker	2020-01-11 22:30:52.581	info	Restart adapter system.adapter.zigbee.0 because enabled
              host.ioBroker	2020-01-11 22:30:52.581	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.ioBroker	2020-01-11 22:30:52.580	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
              host.ioBroker	2020-01-11 22:30:52.580	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
              host.ioBroker	2020-01-11 22:30:52.579	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
              host.ioBroker	2020-01-11 22:30:52.579	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:787:10)
              host.ioBroker	2020-01-11 22:30:52.579	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:776:30)
              host.ioBroker	2020-01-11 22:30:52.578	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/seriallist.js:3:25)
              host.ioBroker	2020-01-11 22:30:52.578	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
              host.ioBroker	2020-01-11 22:30:52.577	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:690:17)
              host.ioBroker	2020-01-11 22:30:52.577	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:562:25)
              host.ioBroker	2020-01-11 22:30:52.577	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
              host.ioBroker	2020-01-11 22:30:52.576	error	Caught by controller[0]: Error: Cannot find module 'zigbee-herdsman/dist/adapter/serialPortUtils'
              host.ioBroker	2020-01-11 22:30:52.576	error	Caught by controller[0]: ^
              host.ioBroker	2020-01-11 22:30:52.575	error	Caught by controller[0]: throw err;
              host.ioBroker	2020-01-11 22:30:52.574	error	Caught by controller[0]: internal/modules/cjs/loader.js:638
              • MathiasJ
                MathiasJ last edited by MathiasJ
                Zigbee auf dem Slave nur gelb.
                ich bin heute auf Proxmox umgestiegen und habe deshalb den Zigbee-Adaptere auf einem Slave ausgelagert.
                Der Zigbee-Adapter bekommt keine Verbindung zum Zigbee-Dongle, dehalb ist der gelb.
                Ich habe den mit der neuen Hardware.
                Als ich den Zigbee-Dongle auf dem (ehemaligen) Master hatte, war alles gut.
                Als log bekomme ich das:
                zigbee.0	2020-01-12 22:59:22.776	error	(4914) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00 ' at Znp.<anonymous> (/opt/iobroker/n
                zigbee.0	2020-01-12 22:59:22.774	error	(4914) Failed to start Zigbee
                Ich habe nochmal kontolliert:
                ich bekam als Ausgabe:
                usb-Texas_Instruments_CC2538_USB_CDC-if00 -> ../../ttyACM0
                nachdem ich
                ls -la /dev/serial/by-id/
                eingegeben habe.
                Gruß,
                Mathias
                  Kueppert @MathiasJ last edited by
                  @MathiasJ Hi, hast du also schon den Stick via proxmox an die vm durch gereicht? Geht unter Hardware und dort USB meine ich.
                  MathiasJ 1 Reply Last reply Reply Quote 0
                  • MathiasJ
                    MathiasJ @Kueppert last edited by MathiasJ
                    @Kueppert
                    nein, der hängt am Slave, weil es am Master wenig Sinn macht.
                    IObroker wurde nicht als VM, sondern als LXC-Container angelegt. Da gibt es keine Hardware
                    Der Master ist außerdem im Keller.
                    Gruß,
                    Mathias
                    • FredF
                      FredF Most Active Forum Testing @MathiasJ last edited by
                      @MathiasJ
                      Kann es sein, das mit deinem Stick was nicht stimmt oder neu geflasht werden muss? Zwischen CDC und if00 kommen bei mir noch 18 Stellen...
                      Vielleicht auch mal den Adapter stoppen, Stick rausnehmen, warten wieder rein und Adapter Starten.
                        dimaiv @FredF last edited by dimaiv
                        @FredF sagte in Zigbee Adapter mit neuem Converter:
                        @MathiasJ
                        Die Ausgabe ist Ok.
                        Und so sieht es im Adapter aus:
                        • Moe
                          Moe last edited by Moe
                          Leider wird meine TRADFRI bulb E27 WS opal 1000lm nicht richtig erkannt.
                          Sie wird in den Objekten nur als Objekt angezeigt nicht als Ordner mit Struktur. Im Controller selber nur mit ?.
                          Beim Verbinden aber dieser Text
                          zigbee.0 2020-01-13 18:02:14.172 info (2154) Device '0xccccccfffe338366' is supported, identified as: IKEA TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white (LED1732G11)
                          zigbee.0 2020-01-13 18:02:14.172 info (2154) Successfully interviewed '0xccccccfffe338366', device has succesfully been paired
                          zigbee.0 2020-01-13 18:02:14.169 error (2154) Device ccccccfffe338366 "TRADFRI bulb E27 WS opal 1000lm" not described in statesMapping.
                          zigbee.0 2020-01-13 18:02:14.002 error (2154) Device ccccccfffe338366 "TRADFRI bulb E27 WS opal 1000lm" not described in statesMapping.
                          zigbee.0 2020-01-13 18:02:13.914 error (2154) Device ccccccfffe338366 "TRADFRI bulb E27 WS opal 1000lm" not described in statesMapping.
                          zigbee.0 2020-01-13 18:02:13.691 error (2154) Device ccccccfffe338366 "TRADFRI bulb E27 WS opal 1000lm" not described in statesMapping.
                          zigbee.0 2020-01-13 18:02:02.971 info (2154) Starting interview of '0xccccccfffe338366'
                          zigbee.0 2020-01-13 18:01:50.334 info (2154) Zigbee: allowing new devices to join
                          M arteck 2 Replies Last reply Reply Quote 0
                          • MathiasJ
                            Habe den Slave neu gestartet.
                            Zigbee ist gelb 😞
                              Matdos @Moe last edited by
                              @Moe
                              So wie es aussieht wurde die nicht richtig konfiguriert, war bei mir auch ab und zu das kein Ordner oder keine Datenpunkten erzeugt wurden obwohl das Gerät anscheinend eingebunden war.
                              In Adapter rein das Gerät löschen, bzw auf löschen klicken( vermutlich wird das erst mal nicht gelöscht bzw die Kachel verschwindet nicht).
                              Raus aus dem Adapter und stoppen, Lampe reseten, Adapter starten und öffnen ( nun sollte die Kachel vom Gerät weg sein, wenn nicht noch mal löschen und Adapter noch mal neu durchstarten) sollte sich die Kachel nicht löschen lassen Gerät einfach neu anlernen und schauen ob es dann klappt. Ansonsten noch mal löschen und reseten.
                                arteck Developer Most Active @Moe last edited by
                                @Moe installier nochmal neu ..sollte jetzt gehen
                                Moe 1 Reply Last reply Reply Quote 0
                                • MathiasJ
                                  so, habe die Instanz Zigbee.0 deinstalliert, Adapter Zigbee deinstalliert,
                                  Adapter Zigbee auf 1.0.0 angehoben.
                                  Instanz Zigbee installiert,
                                  USB-Port getauscht,
                                  Ausgabe immer noch
                                  zigbee.0	2020-01-14 08:37:31.364	error	(759) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00 ' at Znp.<anonymous> (/opt/iobroker/no
                                  zigbee.0	2020-01-14 08:37:31.362	error	(759) Failed to start Zigbee
                                  Edit:
                                  Wieder was dazu gelernt.
                                  Das alte System wieder aufgebaut mit Raspberry PI3B+ als CCU3 und Raspberry PI4B
                                  Zigbee-Dongle rein, hochgefahren, geht.
                                  Meine Frage:
                                  Ist es vllt möglich, dass der Zigbee-Dongle unbedingt im Master stecken muß?
                                  Gruß,
                                  Mathias
                                    arteck Developer Most Active @MathiasJ last edited by arteck
                                    @MathiasJ
                                    ich sollte geld für verlangen echt..
                                    /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00 '<--- da ist am ende ein space
                                    kontrolliere nochmal die Einstellung... es darf kein space vorne und hinten vorhanden sein
                                    bitte peniebel drauf achten wie die Schnittstelle heisst und was kopiert wird
                                    und nein es muss nicht im Master stecken.. warum auch..
                                    • Moe
                                      Moe @arteck last edited by
                                      @arteck Ja einmal Update über Github rüber laufen lassen schon ging sie. Ohne das ich sie neu anlernen musste 🙂
                                      ThomasPB 1 Reply Last reply Reply Quote 0
                                      • MathiasJ
                                        MathiasJ @arteck last edited by MathiasJ
                                        @arteck
                                        Für was solltest Du Geld verlangen?
                                        Sag mal, für wie dumm hältst Du mich eigentlich?
                                        Es hätte gleich funktionieren müssen, sobald das Backup drin ist. Hat es aber nicht.
                                        Wenn ich das Device Deiner Meinung nach falsch eingegeben habe, warum funktioniert es dann im vorherigem Setup?
                                        Ach ja, nur noch die Feuermelder ummelden, dann ist das Gateway Geschichte.
                                        Selbstverständlich habe ich jetzt auch die Sicherung der Zigbee-Datenbank in backmeup aktiviert.
                                        Dass ich das Update des Zigbee-Adapters auf 1.0.0 gemacht habe, steht weiter oben.
                                        Auf Deine Antwort bin ich jetzt mal gespannt.
                                        Alles angelernt, nur die Aqara Rauchmelder wollen nicht 😞
                                        Edit:
                                        Die Rauchmelder sind jetzt teilweise auch drin.
                                        • ThomasPB
                                          ThomasPB @Moe last edited by
                                          Hi @Moe , du musst in der Datei: /opt/iobroker/node_modules/iobroker.zigbee/lib/devstates.js
                                          Die folgende Zeile:
                                          3491 wie folgt ersetzen: 'TRADFRI bulb E27 WW 806lm', 'TRADFRI bulb E27 WS opal 1000lm'],
                                          Dann neu starten und dann funktioniert es auch richtig.
                                          arteck R 2 Replies Last reply Reply Quote 0
                                            arteck Developer Most Active @ThomasPB last edited by
                                            @ThomasPB oder Adapter neu istallieren.. hab es nachgepflegt gestern
                                            herdsman shpeherd zigbee adapter
                                            58
                                            498
                                            99625
