    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Драйвер sayit
    Драйвер sayit
    • Bluefox
      Bluefox last edited by
      @instalator:
      Свалился с ошибкой
      ! sayit.0 2015-12-26 16:36:42 error Error: EBUSY, open 'c:\iobroker\node_modules\iobroker.sayit\say.mp3'
      ! sayit.0 2015-12-26 16:36:42 error uncaught exception: EBUSY, open 'c:\iobroker\node_modules\iobroker.sayit\say.mp3'
      Свалился и в папке \iobroker\node_modules\iobroker.sayit\ снова пусто. :shock:
      ! 2015-12-26 16:36:42.233 - error: uncaught exception: EBUSY, open 'c:\iobroker\n
      ! ode_modules\iobroker.sayit\say.mp3'
      ! 2015-12-26 16:36:42.243 - error: Error: EBUSY, open 'c:\iobroker\node_modules\i
      ! obroker.sayit\say.mp3'
      ! npm ERR! iobroker.sayit@0.3.16 install: node main.js –install
      ! npm ERR! Exit status 6
      ! npm ERR!
      ! npm ERR! Failed at the iobroker.sayit@0.3.16 install script.
      ! npm ERR! This is most likely a problem with the iobroker.sayit package,
      ! npm ERR! not with npm itself.
      ! npm ERR! Tell the author that this fails on your system:
      ! npm ERR! node main.js --install
      ! npm ERR! You can get their info via:
      ! npm ERR! npm owner ls iobroker.sayit
      ! npm ERR! There is likely additional logging output above.
      ! npm ERR! System Windows_NT 6.1.7601
      ! npm ERR! command "C:\Program Files\nodejs\\node.exe" "C:\Program Files\nod
      ! ejs\node_modules\npm\bin\npm-cli.js" "install" "iobroker.sayit"
      ! npm ERR! cwd c:\iobroker
      ! npm ERR! node -v v0.10.35
      ! npm ERR! npm -v 1.4.28
      ! npm ERR! code ELIFECYCLE
      ! npm ERR! error rolling back Error: EPERM, unlink 'c:\iobroker\node_modules\iobro
      ! ker.sayit\say.mp3'
      ! npm ERR! error rolling back { [Error: EPERM, unlink 'c:\iobroker\node_modules\i
      ! obroker.sayit\say.mp3']
      ! npm ERR! error rolling back errno: 50,
      ! npm ERR! error rolling back code: 'EPERM',
      ! npm ERR! error rolling back path: 'c:\iobroker\node_modules\iobroker.sayit
      ! \say.mp3' }
      ! npm ERR! not ok code 0 `
      Посмотри, что я поменял: https://github.com/ioBroker/ioBroker.sa … 412dca8cb6
      Практически ничего :lol:
      Видать установка не прошла.
      • I
        instalator last edited by
        @Bluefox:
        @instalator:
        Свалился с ошибкой
        ! npm ERR!
        ! \say.mp3' }
        Видать установка не прошла. `
        НУ раз не прошла это ладно, я же вручную 2 раза пробовал ставить не проходит.
        зависает на строке 2015-12-26 16:07:14.245 - info: sayit.0 Upload announce mp3 files
        Но до этого видимо фалы скаыивает и в папке в с драйвером все файлы и папки появляются, в этот момент ребутнул iobroker, чтобы установку не отменилась и не удалила снова все фалйлы, сам драйвер пока работает.
          kID last edited by
          Нарисовалась еще одна проблема - драйвер text to speech ничего не говорит. Т.е он отсылает запрос на конвертацию, получает mp3
          и направляет его на mpg321, а тот уже отвечает
          sayit-0	2016-01-10 19:00:03	error	Can't find a suitable libao driver. (Is device in use?)
          sayit-0	2016-01-10 19:00:03	error	MPEG 2.0 layer III, 64 kbit/s, 16000 Hz mono
          sayit-0	2016-01-10 19:00:03	error	Playing MPEG stream from say.mp3 ...
          sayit-0	2016-01-10 19:00:03	error	Directory: /opt/iobroker/node_modules/iobroker.sayit
          sayit-0	2016-01-10 19:00:03	error	tcgetattr(): Inappropriate ioctl for device
          sayit-0	2016-01-10 19:00:03	error	THIS SOFTWARE COMES WITH ABSOLUTELY NO WARRANTY! USE AT YOUR OWN RISK!
          sayit-0	2016-01-10 19:00:03	error	Uses code from various people. See 'README' for more!
          sayit-0	2016-01-10 19:00:03	error	now maintained by Nanakos Chrysostomos and others.
          sayit-0	2016-01-10 19:00:03	error	Version 0.3.2-1 (2012/03/25). Written and copyrights by Joe Drew,
          sayit-0	2016-01-10 19:00:03	error	Cannot play:Error: Command failed: High Performance MPEG 1.0/2.0/2.5 Audio Player for Layer 1, 2, and 3.
          При этом сигналы оповещения играет на ура.
          Я понимаю что это проблемы не брокера а mpg321, потому как при попытке запуска из командной строки (mpg321 + имя файла) все повторяется.
          Подозреваю, что что-то не доставил, а что понять не могу. Haus ты же тоже на Debian 8.2 ставишь, нет в этом разделе особенностей?
          Только что выяснилось что mp3 играют из под юзера а из под рута не играют (adduser root audio сделал) так же из под рута не работает speaker-test :x
            Haus last edited by
            Такая ошибка иногда проскакивает на sistem, в браузер не замечал. Я всегда под root, установлен mpg321, и набор alsa-utils alsa-base alsa-tools. Тест speaker-test, aplay /usr/share/sounds/alsa/*.wav работает.
            Вчера издох ноутбук скоро да делаю гляну в шпаргалки может чего забыл.
            Так выглядит моя ошибка Длительность извещения (сек): 3 , сейчас поставил 5 будем посмотреть.
            sayit-0	2016-01-10 22:40:24	error	Can't find a suitable libao driver. (Is device in use?)
            sayit-0	2016-01-10 22:40:24	error	ALSA lib pcm_dmix.c:1022:(snd_pcm_dmix_open) unable to open slave
            sayit-0	2016-01-10 22:40:24	error	MPEG 2.0 layer III, 48 kbit/s, 22050 Hz mono
            sayit-0	2016-01-10 22:40:24	error	Playing MPEG stream from f8ac3c849fde60319f0fd02c43789260.mp3 ...
            sayit-0	2016-01-10 22:40:24	error	Directory: /opt/iobroker/cache
            sayit-0	2016-01-10 22:40:24	error	tcgetattr(): Inappropriate ioctl for device
            sayit-0	2016-01-10 22:40:24	error	THIS SOFTWARE COMES WITH ABSOLUTELY NO WARRANTY! USE AT YOUR OWN RISK!
            sayit-0	2016-01-10 22:40:24	error	Uses code from various people. See 'README' for more!
            sayit-0	2016-01-10 22:40:24	error	now maintained by Nanakos Chrysostomos and others.
            sayit-0	2016-01-10 22:40:24	error	Version 0.3.2-1 (2012/03/25). Written and copyrights by Joe Drew,
            sayit-0	2016-01-10 22:40:24	error	Cannot play:Error: Command failed: High Performance MPEG 1.0/2.0/2.5 Audio Player for Layer 1, 2, and 3.
            sayit-0	2016-01-10 22:40:24	info	saying: Василий. Уже дома!
            sayit-0	2016-01-10 22:40:22	info	saying: /opt/iobroker/node_modules/iobroker.sayit/gong.mp3
            javascript-0	2016-01-10 22:40:22	info	script.js.Ping_2_say: Василий. Уже дома!
            У меня похоже в этом проблема и была.
            Настройки
            • V
              vtec last edited by
              Поиграйтесь с длительностью извещения. начните от 10 сек и по одной секунде уменьшайте пока не дойдете до ошибки.
              Это скорее всего у вас аудио порт не успевает освободиться от проигрывания оповещения.
              4191_testbeschreibung_version_21-b03.docx
              4191_iobroker_21b03_mit_delay.log
              4191_iobroker_21b03_ohne_delay.log
              4191_heizungsscript_21b03_test.txt
              • I
                Валятся ошибки, не корректно работает драйвер.
                ! Server-PC 2016-01-12 20:01:16 error host.Server-PC instance system.adapter.sayit.0 terminated with code 6 (uncaught exception)
                ! sayit.0 2016-01-12 20:01:15 error Error: EBUSY, open 'C:\ioBroker\node_modules\iobroker.sayit\say.mp3'
                ! sayit.0 2016-01-12 20:01:15 error uncaught exception: EBUSY, open 'C:\ioBroker\node_modules\iobroker.sayit\say.mp3'
                Повторюсь. (ведь длительность файла можно узнать из тегов mp3'шки)
                @Bluefox:
                Проблема в том, что я не могу оценить длинну фразы. И если размер файла маленький, а фраза длинная (например тишина), то получаются накладки. Пока не знаю, как решить это. Есть библиотеки в Cи, но тогда для Windows будет требоватся VS2015.. `
                А для чего оценивать длину фразы? можно ведь получить длительность mp3 файла.
                читаем из буфера фраз строку, отправляем ее на "озвучку", получаем файл, узнаем его продолжительность и отправляем на воспроизведение, ставим какой нибудь флаг. Проверяем буфер, нет ли там еще чего, если есть отправляем на озвучку, получаем файл, узнаем время, проверяем предыдущий флаг (времени) если больше продолжительности первого файла то отправляем текущий на воспроизведение.
                или я что то не понимаю
                • Bluefox
                  @instalator:
                  @Bluefox:
                  или я что то не понимаю `
                  Под длиной фразы я имел ввиду длину длительность mp3 файла.
                  Как??? Linux, OSX, windows?
                    Haus last edited by
                    @Bluefox:
                    @vtec:
                    Bluefox, зачем происходит копирование?
                    sayit.0 Copied file '/opt/iobroker/node_modules/iobroker.sayit/../../cache/2c2b2b43621c06034a72137bf6425bff.mp3' to '/opt/iobroker/node_modules/iobroker.sayit/say.mp3' `
                    Осталось с ccu.io. Убрал.
                    Добавил динг-донг `
                    Bluefox сдесь вы пишите что убрали, у меня раз через рас появляется или это так надо?
                    sayit-0	2016-01-12 18:00:05	info	Copied file '/opt/iobroker/node_modules/iobroker.sayit/say.mp3' to '/opt/iobroker/cache/7ba33c20541b1791a00a4b4097b3002b.mp3'
                    sayit-0	2016-01-12 18:00:04	info	saying: 18:00
                    yr-0	2016-01-12 18:00:02	info	got weather data from yr.no
                    yr-0	2016-01-12 18:00:02	info	starting. Version 0.1.9 in /opt/iobroker/node_modules/iobroker.yr
                    sayit-0	2016-01-12 18:00:00	info	saying: /opt/iobroker/node_modules/iobroker.sayit/gong.mp3
                    javascript-0	2016-01-12 18:00:00	info	script.js.Time_say: Будни 2
                    • I
                      @Bluefox:
                      @instalator:
                      @Bluefox:
                      Как??? Linux, OSX, windows? `
                      ID3 тег прочитать не получится?
                      • Bluefox
                        @Haus:
                        @Bluefox:
                        @vtec:
                        Добавил динг-донг `
                        Я теперь не копирую из кэша в /opt/iobroker/node_modules/iobroker.sayit/say.mp3
                        А в кэш надо по-прежнему копировать.
                        4191_testbeschreibung_version_21-b05_profile.docx
                        4191_iobroker_21b05_profile_2.log
                        • I
                          @Bluefox:
                          https://jsfiddle.net/derickbailey/s4P2v/
                          https://github.com/apsdehal/mp3-length
                          https://github.com/aadsm/JavaScript-ID3-Reader
                          https://www.npmjs.com/package/id3-parser
                          это не то?
                          • Bluefox
                            Возвращаемый гуглом файл не имеет ID3 тега.
                            https://jsfiddle.net/derickbailey/s4P2v/ - не работает
                            https://github.com/apsdehal/mp3-length - только linux
                            https://github.com/aadsm/JavaScript-ID3-Reader - не работает
                            https://www.npmjs.com/package/id3-parser - не работает
                            • I
                              @Bluefox:
                              https://www.npmjs.com/package/id3-parser - не работает `
                              по первой ссылке работает, скармливал ему mp3 от драйвера
                              • I
                                @instalator:
                                @Bluefox:
                                https://www.npmjs.com/package/id3-parser - не работает по первой ссылке работает, скармливал ему mp3 от драйвера
                                PS я IVONой пользуюсь
                                  Haus last edited by
                                  В Changelog ошибка
                                  443_screencapture-github-com-iobroker-iobroker-sayit-blob-master-readme-md-1452861968928.png
                                  • aurodionov
                                    aurodionov last edited by
                                    Снова перестал говорить через браузеры мобильных устройств.
                                    И вопрос скорей в виз, почему у браузеров один и тот-же ид браузера, что на бб что на мобильных устройствах.
                                      RDim last edited by
                                      @aurodionov:
                                      И вопрос скорей в виз, почему у браузеров один и тот-же ид браузера, что на бб что на мобильных устройствах. `
                                      Вроде болтает.
                                      Чтобы узнать ИД нужного браузера, нужно открыть на том устройстве где мы хотим слышать голос, закладку "Инструменты" в редакторе виз ip:8082/vis/edit.html#….. , там и указывается ИД, затем указать в настройках драйвера sayit. Болтать будет только на этом устройстве.
                                      • aurodionov
                                        В том и дело, что к меня один и тот- же ид на разных устройствах. Проекты разные, вот и пытаюсь понять почему. Н буке звук через браузер есть, на мобильных устройств ах нет.
                                        Пишу с пульта….
                                        • Bluefox
                                          @aurodionov:
                                          Пишу с пульта…. `
                                          Мобильные броузеры не всегда поддерживают HTML5 play.
                                          • V
                                            Vlad_k last edited by
                                            не могу добиться вывода звука через андроид планшет, на нем же и брокер пашет, все проговаривается на ноуте, по идее же должно болтать на всех устройствах где виз открыт, хотя обычная веб болталка
                                            ! function speak_txt( data ){
                                            ! var speech = new SpeechSynthesisUtterance();
                                            ! speech.lang = 'ru-RU';
                                            ! speech.rate = 1.5;
                                            ! speech.pitch = 2;
                                            ! speech.volume = 1;
                                            ! speech.txt = "тест голоса"; //document.getElementById( "q" ).value
                                            ! window.speechSynthesis.speak( speech );
                                            пашет исключительно под андроидом а на ноуте молчит
                                            178
                                            53175
