    4. [Frage]Skript zur Steuerung ONVIF Kameras
    • smartboart
      smartboart last edited by smartboart
      Hi , habe das Script am Laufen mit ner Foscam FI9938P. funktioniert soweit alles , ausser der Zoom in beide Richtungen... Hat jremand ne Idee?
      Update: ist ein Firmware Fehler der Kamera...
      • Glasfaser
        Glasfaser @melodoi last edited by
        @melodoi
        Kenne deine Kamera nicht bzw. wurde nicht angegeben .
        Bei meinen PTZ Hikvision habe ich es so, hier einige Beispiele:
        links:
        http://user:passwort@IPadresse/PTZ/channels/1/PTZControl?command=PAN_LEFT&speed=2&mode=start
        rechts:
        http://user:passwort@IPadresse//PTZ/channels/1/PTZControl?command=PAN_RIGHT&speed=2&mode=start
        stop:
        http://user:passwort@IPadresse//PTZ/channels/1/PTZControl?/PTZ/channels/1/PTZControl?command=PAN_RIGHT&speed=1&mode=stop
        hier ein Widget davon :
        [{"tpl":"tplIconHttpGet","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"url":"http://user:passwort@IPadresse/PTZ/channels/1/PTZControl?command=PAN_RIGHT&speed=1&mode=stop","text":"","src":"/vis.0/Wohnen/audio_stop.png"},"style":{"left":"110px","top":"261px","width":"86px","height":"58px","z-index":"5"},"widgetSet":"jqui"}]
        smartboart 1 Reply Last reply Reply Quote 0
        • smartboart
          smartboart @Glasfaser last edited by
          Hat das Script schonmal jemand erweitert um ptz Bewegung obenlinks, obenrechts, untenlinks, untenrechts, und die Funktion zum autonmatischen Abfahren der voreingestelleten Presetpositionen?
          • smartboart
            smartboart @smartboart last edited by smartboart
            Das sollte gehen am Beispiel hoch rechts..
            das mit den verschiedenen presets abfahren wäre mittels skript auch kein problem..Die Kamera hat dies alerdings on board muesste also auch mittels onvif gehen oder..
            const idHochRechts = pfad + 'hochrechts';
            createState(idHochRechts, false, fC, {def: false,name: 'Kamera 1 PTZ obenrechts',desc: 'Bewegung nach obenrechts',type: 'boolean',role: 'switch'});
            on(idHochRechts, function (obj) {
               if (!obj.state.ack && obj.state.val) {
                  var stoppzeit = getState(idStoppzeit).val;
                  var speed = getState(idSpeed).val;
                  movePTZ(1 * speed , 0, 0, stoppzeit);
                  movePTZ(0, 1 * speed, 0, stoppzeit);
                  setStateDelayed(idHochRechts, false, 500);
            • smartboart
              noch ne Frage ..habe noch Probleme mit dem profiletoken.
              habe davon 2 in der Kamera... prof0 und prof1.
              die scheinen immer abwechselnd aktiv zu sein...Wenn die Presetfahrt nicht funktioniert muss ich im script den profiletoken wieder ändern dann gehts wieder.
              Wenn es wieder nicht geht wieder zurück zum anderen...Jemand ne Idee wie ich das lösen kann?
                         var ptz = device.services.ptz;
                         if (ptz) {
                             var params = {
                                 'ProfileToken': 'prof1',
                                 'PresetToken' : presetNumber.toString(),
                                 'Speed'       : {'x': 1, 'y': 1, 'z': 1}
              • Glasfaser
                Glasfaser @smartboart last edited by
                @smartboart
                Leider kann ich dir dazu nicht weiterhelfen ….
                Hatte es auch mal versucht es auf meine Hikvison PTZ Kameras umzustricken , aber bin mehr auf die Lösung zu den " http " Ansteuerungen umgeschwenkt . ( siehe oben )
                Es ist nur eine einmalige Sache gewesen die Buttons dazu zu belegen .
                Rechts - Links - Unten - Oben
                Oben links - oben rechts
                unten links - unten rechts
                Stop
                Zoom in - Zoom out
                4 x PTZ Anfahrten
                • smartboart
                  @Glasfaser danke, das funktioniert mit meiner cam leider nicht so...
                    dare last edited by
                    Hat da bitte wer eine Ahnung wo ich bei erfolgreicher installation des ONVIF Adapter die Status bzw. Steuerobjekte für die PTZ Cam finde ?
                    Bei den Objekten sehe ich ledglich den Ordner ONVIV 0 und den Unterordner mit der IP der CAM -> connection = true
                    Die Cam ist eine H.VIEW HV-PTZ500. Mit dem Onfiv Device Manager kann ich die Cam steuern liveBild sehen usw...
                    Was mache ich hier falsch bzw. braucht man zur Steuerung der Cam noch zusätzlich zu dem Onvif Adapter etwas
                    BG dare
                      Alexxx2005 last edited by
                      @pix
                      ist es möglich die 5MP Dome Kamera von YoLuke einzubinden ?
                      Habe es versucht mit deinem Skript , auch dem Port auf 80
                      geändert aber er meldet mir :
                      javascript.0
                      2020-01-13 20:37:49.336
                      info
                      (9808) script.js.common.PTZ_Kamera: [ERROR] Failed to initialize the device: Error: 404 Not Found
                      javascript.0
                      2020-01-13 20:37:48.309
                      info
                      javascript.0
                      2020-01-13 20:37:24.672
                      info
                      (9808) script.js.common.PTZ_Kamera: registered 15 subscriptions and 0 schedules
                      Beim Aufruf im Browser : http://192.168.86.34:80/onvif/device_service
                      meldet er mir :
                      Error 404: Not Found
                      File not found
                      Grüße Alex
                      • Glasfaser
                        Glasfaser @Alexxx2005 last edited by
                        @Alexxx2005
                        Hast du ONVIF in der Kamera freigegeben !?
                        Hiermit kannst du es testen , ob ein ONVIF im Netzwerk vorhanden ist .
                        Die Ausgabe erfolgt im LOG .
                        /// ONVIF Ausgabe ioBroker 01.01.2020 Glasfaser
                        const onvif = require('node-onvif');//
                        console.log('Start the discovery process.');
                        // Find the ONVIF network cameras.
                        // It will take about 3 seconds.
                        onvif.startProbe().then((device_info_list) => {
                         console.log(device_info_list.length + ' devices were found.');
                         // Show the device name and the URL of the end point.
                         device_info_list.forEach((info) => {
                           console.log('- ' + info.urn);
                           console.log('  - ' + info.name);
                           console.log('  - ' + info.xaddrs[0]);
                        }).catch((error) => {
                         console.error(error);
                          Alexxx2005 @Glasfaser last edited by Alexxx2005
                          @Glasfaser
                          tolles Skript von dir , ja er meldet bei mir das er etwas findet allerdings unter 8080
                          javascript.0
                          2020-01-13 21:04:04.629
                          info
                          (9808) script.js.common.Onvif_testen: - http://192.168.86.34:8080/onvif/device_service
                          javascript.0
                          info
                          (9808) script.js.common.Onvif_testen: - IPCAM
                          Habe jetzt mal das WebInterface der Kamera geöffnet wenn ich dann die
                          Kamera im VIS bewege , bewegt sie sich auch im WebInterface , ich verstehe
                          nur nicht warum das Widget kein Bild anzeigt , als Quelle wird hier auf :
                          {javascript.0.Xeoma.Kamera.1.IP} verwiesen , benötige ich ein weiteres Skript
                          zum Bild anzeigen ?
                          Grüße Alex
                            Ich vermute das hat mit diesem hier noch zu tun :
                            const dest_path = 'C:/Program Files/iobroker/SmartHome/iobroker-data/webcam/'; // OS X Pfad
                            const pfad = 'javascript.' + instance + '.VIS.Kamera.1.PTZ.';
                            hier meckert er noch das der Pfad auch nicht stimmt 😕
                            • Glasfaser
                              Glasfaser @Alexxx2005 last edited by Glasfaser
                              @Alexxx2005
                              Er hat doch Windows ... du nicht 😉
                              Nimm das erstmal als Füller ... :
                              const dest_path = '/opt/iobroker/iobroker-data/files/vis.0/snapsonvif.jpg';
                              @Alexxx2005 sagte in [Frage]Skript zur Steuerung ONVIF Kameras:
                              @Glasfaser
                              zum Bild anzeigen ?
                              Meinst du das :
                              Dort kannst du deine URL auch eingeben (Snapshot )
                              http://user:passwort@.......
                                @Glasfaser said in [Frage]Skript zur Steuerung ONVIF Kameras:
                                snapsonvif.jpg';
                                Okay ja ich benötige einen Windows Pfad da iobroker bei mir auf einem
                                Nuc mit Windows läuft.
                                Verstehe jetzt nur nicht ob die Klammern \ oder so / hin müssen normal ja :
                                C:\Program Files\iobroker\SmartHome\iobroker-data\files\vis.0\snap.jpg
                                Das nächste große Problem ist wie finde ich die Snapshot URL heraus
                                da es sich um eine Kamera handelt die nicht so gängig ist (5MP YoLuke
                                PTZ) , habe ich mit dem Programm Ispy64 hunderte URL`s ermittelt aber
                                die wo ich mal getestet haben gehen nicht :
                                rtsp://admin:admin@192.168.86.34:554/1
                                rtsp://192.168.86.34/12:
                                http://admin:admin@192.168.86.34/snap.jpg?JpegCam=0
                                Kennst du zufällig Möglichkeiten oder gibt es ein Skript sowas auszulesen ?
                                Danke, Grüße Alex
                                • Glasfaser
                                  @Alexxx2005
                                  Mit dem Windows Pfad kann ich dir nicht helfen ….
                                  Von Jey Cee der Adapter onvif v0.1.x , ist sehr gut !
                                    @Glasfaser
                                    habe nun festgestellt das nach einem Iobroker neustart die URL
                                    http://<IP>/web/tmpfs/snap.jpg
                                    http://Name:PW@<IP>/snap.jpg?JpegCam=1
                                    funktioniert.
                                    Was noch nicht funktioniert ist der PTZ Present ist es möglich diese
                                    Steuerung im Skript anzupassen ?
                                    Nach Stundenlangen Googeln kam ich auf diesen Pfad was durch ändern
                                    der Number=1 die verschiedenen Postionen anfährt.
                                    http://<IP>/cgi-bin/hi3510/param.cgi?cmd=preset&-act=goto&-status=1&-number=2
                                    Grüße Alex
                                      BamBam89 last edited by
                                      ich möchte mich gerne hier mit ran hängen.
                                      Auch ich möchte meine Cams gerne mit VIS visualisieren.
                                      Allerdings bin ich noch recht neu in der Materie und an der ein oder anderen Stelle hakt es noch ein wenig.
                                      Eine Stelle an der es gewaltig hakt, ist die Einbindung der CAMS.
                                      Ich habe mir den Adapter Onvif Support geladen. Die Kameras gesucht und auch gefunden.
                                      Allerdings komme ich nun nicht weiter. Unter den Objekten wird mir die Kamera angezeigt
                                      Aber wie komme ich nun an die Bilder?
                                      Danke euch und schönes Wochenende
                                      Gruß BamBam89
                                      • Glasfaser
                                        Glasfaser @BamBam89 last edited by Glasfaser
                                        @BamBam89
                                        Du hast den offiziellen Onvif Adapter installiert ...
                                        Nimm den Test Adapter onvif v0.1.x ,dazu kann man sagen , er funktioniert .
                                        ( aber vorher den Adapter komplett deinstallieren )
                                        • Wiednitz
                                          Wiednitz @pix last edited by Wiednitz
                                          @pix
                                          Grüsse,
                                          ich habe das Script auch am Laufen. Funktioniert soweit, wenn ich die States direkt in den Objekten ändere, zum Beispiel gotopreset auf 7, Kamera geht auf Position 7. Wenn ich den State jedoch durch Blockly ändere, Datenpunkt steuern oder aktualisieren, dann wird zwar die Zahl eingetragen, aber die Kamera bewegt sich nicht !?
                                          Wo ist der Fehler ?
                                          Wiednitz 1 Reply Last reply Reply Quote 0
                                          • Wiednitz
                                            Wiednitz @Wiednitz last edited by
                                            @wiednitz
                                            Ich antworte mir mal selbst....
                                            Nachdem ich alles aus dem Skript außer die gotopreset Funktion gelöscht habe, funktioniert es mit dem Blockly steuere Befehl.
                                            79
                                            23283
