    4. Test Adapter Material Design Widgets v0.2.x
    • O
      Oli @Scrounger last edited by
      @Scrounger
      Chrome, sieht aus wie im geposteten Edit Modus
      [Deprecation] Application Cache was previously restricted to secure origins only from M70 on but now secure origin use is deprecated and will be removed in M82.  Please shift your use case over to Service Workers.
      vis.js:3163 Create inner vis object javascript.0.Rezepte.Rezeptsuche.Arbeitszeit
      vis.js:3163 Create inner vis object javascript.0.Rezepte.Rezeptsuche.Schwierigkeitsgrad
      vis.js:3163 Create inner vis object javascript.0.Rezepte.Rezeptsuche.Kalorien
      vis.js:3163 Create inner vis object javascript.0.Rezepte.Rezeptsuche.Zubereitung
      vis.js:3163 Create inner vis object javascript.0.Essensplan.save_rezept
      vis.js:3163 Create inner vis object javascript.0.Essensplan.vis_switch
      vis.js:3163 Create inner vis object tvspielfilm.0.json.tipps
      vis.js:3163 Create inner vis object javascript.0.TV.TVjetzt
      vis.js:3163 Create inner vis object javascript.0.TV.Schalter
      vis.js:3163 Create inner vis object javascript.0.TV.TVgleich
      vis.js:3163 Create inner vis object javascript.0.TV.TV20
      vis.js:3163 Create inner vis object javascript.0.TV.TV22
      vis.js:3163 Create inner vis object javascript.0.RSS-Feed.Bild.Tabelle
      vis.js:3163 Create inner vis object javascript.0.RSS-Feed.Tagesschau.Link_Tagesschau
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät1.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Anzahl
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät1.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät1.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät1.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät1.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät1.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät2.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät2.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät2.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät2.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät2.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät2.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät3.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät3.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät3.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät3.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät3.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät3.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät4.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät4.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät4.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät4.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät4.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät4.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät5.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät5.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät5.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät5.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät5.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät5.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät6.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät6.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät6.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät6.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät6.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät6.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät7.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät7.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät7.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät7.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät7.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät7.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät8.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät8.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät8.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät8.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät8.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät8.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät9.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät9.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät9.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät9.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät9.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät9.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät10.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät10.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät10.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät10.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät10.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät10.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät11.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät11.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät11.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät11.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät11.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät11.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät12.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät12.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät12.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät12.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät12.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät12.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät13.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät13.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät13.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät13.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät13.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät13.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät14.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät14.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät14.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät14.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät14.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät14.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät15.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät15.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät15.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät15.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät15.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät15.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät16.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät16.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät16.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät16.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät16.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät16.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät17.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät17.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät17.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät17.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät17.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät17.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät18.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät18.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät18.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät18.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät18.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät18.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät19.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät19.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät19.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät19.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät19.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät19.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät20.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät20.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät20.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät20.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät20.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät20.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät21.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät21.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät21.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät21.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät21.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät21.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät22.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät22.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät22.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät22.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät22.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät22.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät23.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät23.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät23.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät23.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät23.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät23.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät24.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät24.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät24.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät24.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät24.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät24.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät25.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät25.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät25.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät25.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät25.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät25.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät26.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät26.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät26.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät26.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät26.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät26.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät27.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät27.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät27.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät27.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät27.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät27.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät28.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät28.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät28.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät28.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät28.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät28.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät29.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät29.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät29.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät29.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät29.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät29.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät30.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät30.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät30.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät30.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät30.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät30.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät31.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät31.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät31.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät31.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät31.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät31.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät32.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät32.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät32.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät32.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät32.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät32.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät33.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät33.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät33.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät33.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät33.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät33.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät34.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät34.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät34.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät34.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät34.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät34.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät35.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät35.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät35.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät35.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät35.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät35.Update
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät36.NameGerät
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät36.UptimeStr
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät36.Status
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät36.IPAdresse
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät36.Bild
      vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät36.Update
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter1.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Anzahl
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter1.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter1.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter1.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter1.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter1.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter1.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter7.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter7.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter7.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter7.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter7.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter7.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter7.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter13.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter13.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter13.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter13.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter13.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter13.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter13.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter19.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter19.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter19.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter19.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter19.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter19.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter19.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter25.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter25.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter25.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter25.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter25.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter25.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter25.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter26.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter26.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter26.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter26.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter26.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter26.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter26.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter20.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter20.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter20.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter20.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter20.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter20.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter20.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter14.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter14.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter14.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter14.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter14.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter14.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter14.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter2.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter2.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter2.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter2.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter2.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter2.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter2.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter8.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter8.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter8.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter8.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter8.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter8.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter8.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter9.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter9.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter9.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter9.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter9.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter9.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter9.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter27.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter27.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter27.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter27.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter27.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter27.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter27.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter21.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter21.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter21.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter21.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter21.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter21.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter21.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter15.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter15.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter15.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter15.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter15.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter15.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter15.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter3.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter3.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter3.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter3.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter3.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter3.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter3.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter10.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter10.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter10.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter10.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter10.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter10.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter10.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter28.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter28.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter28.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter28.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter28.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter28.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter28.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter22.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter22.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter22.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter22.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter22.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter22.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter22.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter16.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter16.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter16.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter16.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter16.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter16.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter16.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter4.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter4.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter4.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter4.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter4.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter4.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter4.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter11.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter11.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter11.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter11.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter11.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter11.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter11.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter29.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter29.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter29.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter29.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter29.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter29.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter29.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter23.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter23.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter23.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter23.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter23.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter23.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter23.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter17.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter17.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter17.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter17.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter17.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter17.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter17.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter5.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter5.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter5.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter5.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter5.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter5.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter5.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter12.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter12.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter12.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter12.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter12.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter12.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter12.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter30.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter30.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter30.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter30.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter30.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter30.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter30.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter24.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter24.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter24.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter24.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter24.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter24.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter24.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter18.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter18.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter18.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter18.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter18.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter18.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter18.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter6.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter6.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter6.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter6.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter6.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter6.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter6.Uptime
      vis.js:3163 Create inner vis object 0
      vis.js:3163 Create inner vis object 100
      vis.js:3163 Create inner vis object 250
      vis.js:3163 Create inner vis object javascript.0.Adapter.AdapterNummer
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter31.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter31.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter31.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter31.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter31.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter31.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter37.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter37.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter37.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter37.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter37.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter37.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter43.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter43.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter43.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter43.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter43.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter43.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter49.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter49.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter49.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter49.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter49.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter49.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter55.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter55.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter55.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter55.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter55.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter55.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter56.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter56.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter56.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter56.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter56.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter56.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter50.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter50.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter50.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter50.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter50.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter50.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter44.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter44.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter44.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter44.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter44.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter44.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter32.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter32.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter32.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter32.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter32.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter32.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter38.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter38.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter38.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter38.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter38.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter38.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter39.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter39.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter39.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter39.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter39.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter39.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter57.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter57.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter57.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter57.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter57.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter57.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter51.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter51.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter51.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter51.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter51.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter51.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter45.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter45.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter45.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter45.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter45.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter45.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter33.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter33.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter33.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter33.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter33.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter33.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter40.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter40.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter40.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter40.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter40.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter40.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter58.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter58.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter58.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter58.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter58.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter58.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter52.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter52.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter52.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter52.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter52.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter52.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter46.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter46.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter46.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter46.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter46.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter46.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter34.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter34.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter34.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter34.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter34.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter34.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter41.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter41.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter41.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter41.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter41.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter41.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter59.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter59.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter59.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter59.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter59.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter59.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter53.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter53.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter53.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter53.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter53.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter53.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter47.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter47.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter47.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter47.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter47.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter47.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter35.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter35.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter35.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter35.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter35.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter35.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter42.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter42.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter42.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter42.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter42.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter42.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter60.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter60.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter60.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter60.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter60.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter60.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter54.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter54.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter54.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter54.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter54.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter54.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter48.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter48.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter48.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter48.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter48.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter48.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter36.Bild
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter36.Connected
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter36.MemRSS
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter36.MemUsed
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter36.MemTotal
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter36.Uptime
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter60.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter59.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter58.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter57.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter56.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter55.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter54.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter53.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter52.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter51.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter50.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter49.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter48.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter47.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter46.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter45.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter44.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter43.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter42.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter41.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter40.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter39.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter38.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter37.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter36.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter35.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter34.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter33.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter32.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter31.NameAdapter
      vis.js:3163 Create inner vis object javascript.0.Status.Speed-Test.download
      vis.js:3163 Create inner vis object javascript.0.Status.Speed-Test.upload
      vis.js:3163 Create inner vis object javascript.0.Status.Speed-Test.ping
      vis.js:3163 Create inner vis object javascript.0.homee.Anzahl_Geräte
      vis.js:3163 Create inner vis object javascript.0.homee.Anzahl_Batterie
      vis.js:3163 Create inner vis object javascript.0.homee.Anzahl_ohne_Batterie
      vis.js:3163 Create inner vis object javascript.0.homee.Anzahl_homeegramme
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät1.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät1.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät1.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät1.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät2.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät2.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät2.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät2.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät3.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät3.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät3.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät3.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät4.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät4.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät4.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät4.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät5.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät5.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät5.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät5.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät6.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät6.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät6.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät6.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät7.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät7.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät7.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät7.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät8.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät8.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät8.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät8.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät9.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät9.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät9.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät9.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät10.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät10.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät10.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät10.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät11.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät11.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät11.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät11.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät12.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät12.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät12.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät12.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät13.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät13.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät13.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät13.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät14.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät14.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät14.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät14.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät15.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät15.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät15.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät15.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät16.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät16.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät16.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät16.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät17.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät17.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät17.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät17.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät34.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät34.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät34.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät34.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät33.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät33.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät33.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät33.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät32.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät32.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät32.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät32.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät31.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät31.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät31.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät31.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät30.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät30.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät30.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät30.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät29.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät29.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät29.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät29.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät28.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät28.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät28.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät28.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät27.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät27.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät27.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät27.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät26.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät26.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät26.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät26.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät25.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät25.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät25.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät25.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät24.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät24.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät24.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät24.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät23.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät23.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät23.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät23.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät22.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät22.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät22.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät22.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät21.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät21.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät21.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät21.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät20.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät20.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät20.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät20.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät19.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät19.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät19.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät19.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät18.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät18.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät18.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät18.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Anzahl_Aktivierte_homeegramme
      vis.js:3163 Create inner vis object javascript.0.homee.Anzahl_deaktivierte_homeegramme
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät42.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät42.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät42.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät42.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät41.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät41.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät41.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät41.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät40.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät40.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät40.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät40.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät39.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät39.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät39.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät39.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät38.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät38.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät38.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät38.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät37.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät37.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät37.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät37.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät36.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät36.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät36.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät36.NameGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät35.BatterieLevel
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät35.BatterieStand
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät35.BezeichnungGerät
      vis.js:3163 Create inner vis object javascript.0.homee.Gerät35.NameGerät
      vis.js:3163 Create inner vis object info.0.sysinfo.os.versions.npm
      vis.js:3163 Create inner vis object info.0.sysinfo.os.versions.node
      vis.js:3163 Create inner vis object info.0.sysinfo.os.versions.git
      vis.js:3163 Create inner vis object snmp.0.192_168_2_115.Freier_Speicher RAM
      vis.js:3163 Create inner vis object info.0.newsfeed_filtered
      vis.js:3163 Create inner vis object javascript.0.Ressourcen.iobroker.iobroker_ram_usage
      vis.js:3163 Create inner vis object info.0.sysinfo.cpu.currentLoad.currentload
      vis.js:3163 Create inner vis object backitup.0.history.iobrokerLastTime
      vis.js:3163 Create inner vis object info.0.sysinfo.os.processes.all
      vis.js:3163 Create inner vis object info.0.sysinfo.os.versions.kernel
      vis.js:3163 Create inner vis object info.0.sysinfo.system.hardware.model
      vis.js:3163 Create inner vis object info.0.sysinfo.os.info.platform
      vis.js:3163 Create inner vis object info.0.sysinfo.os.processes.list
      vis.js:3163 Create inner vis object javascript.0.Chart.history.timeInterval
      vis.js:3163 Create inner vis object system.adapter.admin.0.memRss
      vis.js:3163 Create inner vis object javascript.0.ioBroker.ioBroker_Updates
      vis.js:3163 Create inner vis object backitup.0.oneClick.iobroker
      vis.js:3163 Create inner vis object backitup.0.history.html
      vis.js:3163 Create inner vis object backitup.0.output.line
      vis.js:3163 Create inner vis object javascript.0.Backup.Backupgröße
      vis.js:3163 Create inner vis object info.0.sysinfo.cpu.info.brand
      vis.js:3163 Create inner vis object info.0.sysinfo.disks.fsSize.fs0.use
      vis.js:3163 Create inner vis object javascript.0.Ressourcen.qnap.qnap_gesamtspeicher
      vis.js:3163 Create inner vis object javascript.0.Ressourcen.qnap.qnap_freier_speicher
      vis.js:3163 Create inner vis object snmp.0.192_168_2_115.Gesamtspeicher_RAM
      vis.js:3163 Create inner vis object javascript.0.Ressourcen.pc.win10_ram_free
      vis.js:3163 Create inner vis object javascript.0.Ressourcen.pc.uptime
      vis.js:3163 Create inner vis object javascript.0.Ressourcen.pc.win10_ram_usage
      vis.js:3163 Create inner vis object javascript.0.Ressourcen.pc.win10_cpu_usage
      vis.js:3163 Create inner vis object javascript.0.Ressourcen.pc.win10_c_usage
      vis.js:3163 Create inner vis object javascript.0.Ressourcen.pc.win10_d_usage
      vis.js:3163 Create inner vis object javascript.0.Ressourcen.pc.win10_f_usage
      vis.js:3163 Create inner vis object javascript.0.Ressourcen.pc.win10_totalsize
      vis.js:3163 Create inner vis object javascript.0.Ressourcen.pc.win10_freespace
      vis.js:3163 Create inner vis object javascript.0.Ressourcen.pc.win10_ram_total
      vis.js:3163 Create inner vis object javascript.0.Ressourcen.laptop.win10_ram_free
      vis.js:3163 Create inner vis object javascript.0.Ressourcen.laptop.uptime
      vis.js:3163 Create inner vis object javascript.0.Ressourcen.laptop.win10_ram_usage
      vis.js:3163 Create inner vis object javascript.0.Ressourcen.laptop.win10_cpu_usage
      vis.js:3163 Create inner vis object javascript.0.Ressourcen.laptop.win10_c_usage
      vis.js:3163 Create inner vis object javascript.0.Ressourcen.laptop.win10_totalsize
      vis.js:3163 Create inner vis object javascript.0.Ressourcen.laptop.win10_freespace
      vis.js:3163 Create inner vis object javascript.0.Ressourcen.laptop.win10_ram_total
      vis.js:3163 Create inner vis object javascript.0.Log-Script.Loganzeige
      vis.js:3163 Create inner vis object javascript.0.Log-Script.logError.clearJSON
      vis.js:3163 Create inner vis object javascript.0.Log-Script.Stand
      vis.js:3163 Create inner vis object javascript.0.Log-Script.logInfo.logJSONcount
      vis.js:3163 Create inner vis object javascript.0.Log-Script.logWarn.logJSONcount
      vis.js:3163 Create inner vis object javascript.0.Log-Script.logError.logJSONcount
      vis.js:3163 Create inner vis object javascript.0.Log-Script.logInfo.LetzterEintrag
      vis.js:3163 Create inner vis object javascript.0.Log-Script.logWarn.LetzterEintrag
      vis.js:3163 Create inner vis object javascript.0.Log-Script.logError.LetzterEintrag
      vis.js:3163 Create inner vis object javascript.0.Log-Script.logInfo.ClearDate
      vis.js:3163 Create inner vis object javascript.0.Log-Script.logWarn.ClearDate
      vis.js:3163 Create inner vis object javascript.0.Log-Script.logError.ClearDate
      vis.js:3163 Create inner vis object javascript.0.Log-Script.logWarn.clearJSON
      vis.js:3163 Create inner vis object javascript.0.Log-Script.logInfo.clearJSON
      vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.OrdnerCheck
      vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.LatestChangeDP_Factor
      vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.HTMLTable
      vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.RunSuccessful
      vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.MonsterSearch
      vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.ObjectAnzahlCheck
      vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.ohneInstanzAnzeige
      vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.JavaInstanzCheck
      vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.CheckAliase
      vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.RunScript
      vis.js:3163 Create inner vis object controll-own.0.mount.CPULuefter
      vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.TypeAnalyse
      vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.WertAnalyse
      vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.SmartHomeAnalyse
      vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.HistoryAnalyse
      vis.js:3163 Create inner vis object yamaha.0.input
      vis.js:3163 Create inner vis object yamaha.0.Realtime.TUN.PRESET
      vis.js:3163 Create inner vis object yamaha.0.power
      vis.js:3163 Create inner vis object yamaha.0.Realtime.MAIN.VOL
      vis.js:3163 Create inner vis object yamaha.0.Realtime.MAIN.INP
      vis.js:3163 Create inner vis object yamaha.0.Realtime.TUN.AVAIL
      vis.js:3163 Create inner vis object yamaha.0.Realtime.MAIN.PWR
      vis.js:3163 Create inner vis object hm-rega.0.22425.ProgramExecute
      vis.js:3163 Create inner vis object hm-rega.0.22436.ProgramExecute
      vis.js:3163 Create inner vis object musiccast.0.RX-V481_08125F03.netusb.presetrecallnumber
      vis.js:3163 Create inner vis object musiccast.0.RX-V481_08125F03.netusb.albumart_url
      vis.js:3163 Create inner vis object yamaha.0.Commands.skip
      vis.js:3163 Create inner vis object yamaha.0.Commands.stop
      vis.js:3163 Create inner vis object yamaha.0.Commands.toggleMute
      vis.js:3163 Create inner vis object yamaha.0.Commands.rewind
      vis.js:3163 Create inner vis object yamaha.0.Realtime.SERVER.ELAPSEDTIME
      vis.js:3163 Create inner vis object yamaha.0.Realtime.SERVER.PLAYBACKINFO
      vis.js:3163 Create inner vis object yamaha.0.Realtime.NETRADIO.ELAPSEDTIME
      vis.js:3163 Create inner vis object yamaha.0.Realtime.NETRADIO.AVAIL
      vis.js:3163 Create inner vis object yamaha.0.Realtime.TUN.FMFREQ
      vis.js:3163 Create inner vis object yamaha.0.Realtime.NETRADIO.PLAYBACKINFO
      vis.js:3163 Create inner vis object ping.0.ioBroker.192_168_2_108
      vis.js:3163 Create inner vis object yamaha.0.Realtime.NETRADIO.MAXLINE
      vis.js:3163 Create inner vis object denon.0.info.friendlyName
      vis.js:3163 Create inner vis object yaTUN.AVAILmaha.0.Realtime.
      vis.js:3163 Create inner vis object yamaha.0.Realtime.TUN.RDSCLOCK
      vis.js:3163 Create inner vis object hm-rpc.0.MEQ0251193.4.AUTO_MODE
      vis.js:3163 Create inner vis object hm-rpc.0.MEQ0251193.4.BOOST_MODE
      vis.js:3163 Create inner vis object hm-rpc.0.MEQ0251193.4.SET_TEMPERATURE
      vis.js:3163 Create inner vis object hm-rpc.0.MEQ0251193.4.ACTUAL_TEMPERATURE
      vis.js:3163 Create inner vis object hm-rpc.0.MEQ0251193.4.VALVE_STATE
      vis.js:3163 Create inner vis object hm-rpc.0.MEQ0251193.4.MANU_MODE
      vis.js:3163 Create inner vis object hm-rpc.0.MEQ0251193.4.CONTROL_MODE
      vis.js:3163 Create inner vis object hm-rpc.0.MEQ0250683.4.VALVE_STATE
      vis.js:3163 Create inner vis object hm-rpc.0.MEQ0250683.4.ACTUAL_TEMPERATURE
      vis.js:3163 Create inner vis object hm-rpc.0.MEQ0251193.4.BOOST_STATE
      hqwidgets.js:902 Version vis-hqwidgets: 1.1.2
      jquery-1.11.2.min.js:4 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
      send @ jquery-1.11.2.min.js:4
      jquery-1.11.2.min.js:4 Failed to load resource: the server responded with a status of 404 (Not Found)
      conn.js:1142 Error: can't render tplMusiccastAlbumArt w03368 on "400_Denon":
      conn.js:1142 Error: 0 - Error: can.view: No template or empty template:tplMusiccastAlbumArt.ejsError: can.view: No template or empty template:tplMusiccastAlbumArt.ejs
      conn.js:1142 Error: 1 -     at u (http://192.168.2.120:8082/vis/lib/js/can.custom.min.js:58:256)
      conn.js:1142 Error: 2 -     at Object.error (http://192.168.2.120:8082/vis/lib/js/can.custom.min.js:58:953)
      conn.js:1142 Error: 3 -     at j (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:2:27295)
      conn.js:1142 Error: 4 -     at Object.fireWith [as rejectWith] (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:2:28108)
      conn.js:1142 Error: 5 -     at x (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:4:22086)
      conn.js:1142 Error: 6 -     at b (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:4:25980)
      conn.js:1142 Error: 7 -     at Object.send (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:4:26084)
      conn.js:1142 Error: 8 -     at Object.ajax (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:4:21520)
      conn.js:1142 Error: 9 -     at o (http://192.168.2.120:8082/vis/lib/js/can.custom.min.js:58:899)
      conn.js:1142 Error: 10 -     at http://192.168.2.120:8082/vis/lib/js/can.custom.min.js:46:3358
      conn.js:1142 Error: can't render tplBarNavigator w03370 on "400_Denon":
      conn.js:1142 Error: 0 - Error: can.view: No template or empty template:tplBarNavigator.ejsError: can.view: No template or empty template:tplBarNavigator.ejs
      conn.js:1142 Error: can't render tplkodiButton w03371 on "400_Denon":
      conn.js:1142 Error: 0 - Error: can.view: No template or empty template:tplkodiButton.ejsError: can.view: No template or empty template:tplkodiButton.ejs
      translate.js:20 "Resolution assistant": {"en": "Resolution assistant", "de": "Resolution assistant", "ru": "Resolution assistant"},
      translate.js:20 "width of resolution": {"en": "width of resolution", "de": "width of resolution", "ru": "width of resolution"},
      translate.js:20 "used rule": {"en": "used rule", "de": "used rule", "ru": "used rule"},
      translate.js:20 "number of columns": {"en": "number of columns", "de": "number of columns", "ru": "number of columns"},
      translate.js:20 "distance between views": {"en": "distance between views", "de": "distance between views", "ru": "distance between views"},
      transparens.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
      2:8082/icons-mfd-svg/status_light_low.svg:1 Failed to load resource: the server responded with a status of 404 (Not Found)
      Edge sieht jetzt auch aus wie es soll
      Alle
      Fehler
      Warnungen
      Info
      Protokolle
      Protokoll beibehalten
      Ziel
      SCRIPT7016: SCRIPT7016: XMLHttpRequest wird nicht mehr verwendet, während das synchronous-Kennzeichen auf TRUE festgelegt ist, weil die Websiteleistung für den Benutzer beeinträchtigt wird.
      Error: 1 -    at u (http://192.168.2.120:8082/vis/lib/js/can.custom.min.js:58:250)
      Error: 2 -    at error (http://192.168.2.120:8082/vis/lib/js/can.custom.min.js:58:953)
      Error: 3 -    at j (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:2:27287)
      Error: 4 -    at k.fireWith (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:2:28044)
      Error: 5 -    at x (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:4:21630)
      Error: 6 -    at b (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:4:25977)
      Error: 7 -    at send (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:4:25630)
      Error: 8 -    at ajax (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:4:21514)
      Error: 9 -    at o (http://192.168.2.120:8082/vis/lib/js/can.custom.min.js:58:890)
      Error: 10 -    at Anonymous function (http://192.168.2.120:8082/vis/lib/js/can.custom.min.js:46:3349)
      HTTP404: NICHT GEFUNDEN: Der Server hat keine Übereinstimmungen für den angeforderten URI (Uniform Resource Identifier) gefunden.
      GET - http://192.168.2.120:8082/vis.0/transparens.png
      GET - http://192.168.2.120:8082/icons-mfd-svg/status_light_low.svg
      (XHR)GET - http://192.168.2.120:8082/vis/tplMusiccastAlbumArt.ejs
      (XHR)GET - http://192.168.2.120:8082/vis/tplBarNavigator.ejs
      (XHR)GET - http://192.168.2.120:8082/vis/tplkodiButton.ejs
      (XHR)GET - http://192.168.2.120:8082/icons-mfd-svg/status_light_low.svg
      XML5619: Fehlerhafte Syntax in einem Dokument.
      index.html (1,1)
      [1579019015685] Request 8 states.
      [1579019015762] Request 1 states.
      [1579019015813] Request 4 states.
      [1579019015864] Request 1 states.
      [1579019015938] Request 1 states.
      [1579019015981] Request 5 states.
      [1579019016115] Request 9 states.
      [1579019016238] Request 12 states.
      [1579019016383] Request 8 states.
      [1579019016464] Request 3 states.
      [1579019016502] Request 3 states.
      [1579019016564] Request 6 states.
      Unlocalized string: vs_editor_contrib_find_browser_findWidget_13
      • Scrounger
        Scrounger Developer @Oli last edited by Scrounger
        @Oli sagte in Test Adapter Material Design Widgets v0.2.x:
        @Scrounger
        Chrome, sieht aus wie im geposteten Edit Modus
        Also log sieht gut aus. Chrome ist allerdings bissle schwierig vorallem in Grenzfällen. Versuch mal die Höhe der eingebundenen Views um 1-2px zu erhöhen bzw. zu reduzieren. Oder ordne die views anders an, also änder die Reihenfolge.
        Wenn das auch nichts bringt, kannst mal per css noch folgendes versuchen:
        .materialdesign-masonry-container{
          orphans: 1 !important;
          widows: 1 !important;
        Beide Werte gleich erhöhen. Damit steuert man bei chrome wieviele zeilen mindestens angzeigt werden müssen.
        Oder du machst mir ein Beispielprojekt, weil ich kann den Fehler nicht reproduzieren, ist zu speziell 😉
          sigi234 Forum Testing Most Active @Scrounger last edited by sigi234
          @Scrounger sagte in Test Adapter Material Design Widgets v0.2.x:
          Auf vielfachen Wunsch, Input Widget ist fertig -> master testen v0.2.40
          Coole , Danke.
          Frage, gibt es eine Möglichkeit mehrere vordefinierte Texte zu erstellen?
          • Scrounger
            Scrounger Developer @sigi234 last edited by
            @sigi234 sagte in Test Adapter Material Design Widgets v0.2.x:
            Versteh ich nciht wie du das genau meinst
            O sigi234 2 Replies Last reply Reply Quote 0
            • O
              Oli @Scrounger last edited by
              @Scrounger
              mit Google scheint gar nichts richtig zu funktionieren, der erkennt nicht mal die aktuelle Spaltenanzahl
              • Scrounger
                @Oli
                Das bezweifle ich, da ich das selbst mit Chrome hoch und runter getestet habe.
                Hast du meine oben angemerkten Punkte mal probiert?!
                Mach doch einfach ein Beispiel Projekt, wo das Problem auftritt, dann kann ich mir es anschauen.
                  Sowie ein select value list
                  • Scrounger
                    Du meinst autocomplete?
                      @Scrounger
                      Jupp, autocomplete
                      • Scrounger
                        @sigi234
                        Klar würde gehen. Ich selber hab aber keine Anwendungsfall dafür. Außer du gibts mir jetzt ne zündende idee 😉
                        sigi234 O 3 Replies Last reply Reply Quote 0
                          @sigi234
                          Ich nehme dein Widget für die Anfrage an einen Echo-Dot. Da habe ich immer die selben eingaben.
                          Also:
                          Wie ist das Wetter
                          Wie spät ist es
                          Wie ist der Verkehr
                          Usw....
                          • O
                            Oli @Scrounger last edited by Oli
                            @Scrounger
                            würde ich dir gerne, ist aber zu groß, sind 16Mb
                              sigi234 Forum Testing Most Active @Oli last edited by
                              Als Zip?
                              • O
                                Oli @sigi234 last edited by
                                @sigi234
                                die 16Mb sind ja schon als Zip, weis gar nicht was da so groß ist
                                • O
                                  @Scrounger
                                  hier mein Beispiel Projekt, auch mit den Button die unter der Navigation nicht funktionieren
                                  2020-01-14-Wetter.zip
                                  • Scrounger
                                    Scrounger Developer @sigi234 last edited by Scrounger
                                    Also:
                                    Wie ist das Wetter
                                    Wie spät ist es
                                    Wie ist der Verkehr
                                    Usw....
                                    Wieso machst des nicht per Spracheingabe? Bzw. das Select Widget ist doch super dafür. Daneben packst dann noch das Input Widget, falls du mal andere eingaben tätigen willst.
                                    Du siehst schon noch nicht die zündende Idee für mich 😉
                                    @intruder7 sagte in Test Adapter Material Design Widgets v0.2.x:
                                    eingetragen um Bytes in MegaBytes umzurechnen. Dieses führte allerdings zu einem NaN.😞
                                    Habs korrigiert, aktuellen master testen
                                      darkiop Most Active last edited by
                                      Danke für das Input Widget, schau ich mir die Tage auch mal an 🙂
                                      Beim Slider ist mir aufgefallen, das der vorangestellte Text nicht über die Widget Optionen gefärbt werden kann. Unter 'Beschriftung' gibt es auch aktuell keine Option für die Schriftfarbe. Ich kann das über CSS überschreiben, aber ist das so gewollt?
                                      • Scrounger
                                        Scrounger Developer @darkiop last edited by
                                        @darkiop
                                        Stimmt Bau ich ein
                                          Maverick78 @Scrounger last edited by
                                          @Scrounger said in Test Adapter Material Design Widgets v0.2.x:
                                          Geht auch per binding, z.B.
                                          Zum thema binding, am besten hier mal einlesen https://github.com/ioBroker/ioBroker.vis
                                          und im Forum suchen, gibt sehr viele Beispiele.
                                          Das habe ich bereits probiert, funktioniert aber nicht.
                                          • Scrounger
                                            Scrounger Developer @Maverick78 last edited by
                                            @Maverick78
                                            bindings werden nur zur runtime angezeigt und nicht im Editor.
                                            adapater material vis visualization widget
                                            77
                                            902
                                            204101
