    4. Anfrage Tahoma/Somfy IO Adapter
      thoemmes86 last edited by thoemmes86
      und hier das Nikolausgeschenk von mir. Funktionalität ist wieder vollumfänglich enthalten.
      PLUS: Jetzt werden auch Szenarien unterstützt. Die sind im Objektbaum unter 'actionGroups' zu finden.
      Viele Grüße
      var request = require('request');
      // enable debugging mode
      //request.debug = true;
      var lastEventTime = new Date().getTime();
      var rawDeviceData = false;
      var tahomaJar = request.jar();
      var baseRequest = request.defaults({
        headers: {
              'User-Agent': 'Mozilla/5.0 (Macintosh; Intel Mac OS X 10_7_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/49.0.2623.112 Safari/537.36'},
        jar: tahomaJar
      var tahomaDevices = {};
      var tahomaActionGroups = {};
      var Map_DeviceURL2StateName = {};
      var userName = "xxxUSERNAMExxx";
      var passWord = "xxxPASSWORTxxx";
      var baseURL = 'https://www.tahomalink.com/enduser-mobile-web/enduserAPI/';
      var isConnectedInternal = false;
      let loginInProgress = false;
      var eventRegisterID = '-1';
      createState('tahoma.connected', false, {
        read: true,
        write: true,
        name: "connection status of tahoma",
        type: "boolean",
        def: false
      createOrUpdateState('tahoma.update', false, {
          read: true,
          write: true,
          role: "button"
      on('javascript.0.tahoma.update', function(obj)
          //log("tahoma refresh states requested: " + obj);
          if (obj.newState.val)
              getAllStates();
      function isConnected()
          return isConnectedInternal;
      function setConnected(connected)
          isConnectedInternal = connected;
          setState('javascript.0.tahoma.connected', connected, true);
      function getCreateStateOptions4Widget(widget)
          if (widget === 'PositionableRollerShutter')
              return {
                      "role":  "blind",
          if (widget === 'LuminanceSensor')
              return {
                  "role":  "sensor"
          return {
                      read: true,
                      write: false,
                      role: "state"
      function getCreateStateOptions4State(widget, stateName)
          if (stateName === "core:ClosureState" || stateName === "core:TargetClosureState")
              return {
                      "type":  "number",               // optional,  default "number"
                      "read":  true,                   // mandatory, default true
                      "write": true,                   // mandatory, default true
                      "min":   0,                      // optional,  default 0
                      "max":   100,                    // optional,  default 100
                      "unit":  "%",                    // optional,  default %
                      "role":  "level.blind"           // mandatory
          if (stateName === "core:SlateOrientationState")
              return {
                      "role":  "level.blind.orientation"           // mandatory
          if (stateName === "core:LuminanceState")
              return {
                      "write": false,                   // mandatory, default true
                      "max":   100000,                    // optional,  default 100
                      "unit":  "Lux",                    // optional,  default %
                      "role":  "level.color.luminance"           // mandatory
          return {
                      read: true,
                      write: false,
                      role: "state"
      function sendPOST(requestPath, payload, callback)
          login(function(err,data)
              if (err)
                  return callback(err, data);
              sendInternalPOST(requestPath, payload, callback);
      function sendGET(requestPath, payload, callback)
              if (err)
              sendInternalGET(requestPath, payload, callback);
      function sendInternalGET(requestPath, payload, callback){
          var url = baseURL + requestPath;
          var formPayload = null;
          var jsonPayload = null;
          jsonPayload = payload;
          log("perform " + requestPath + " with payload:" + JSON.stringify(payload), 'debug');
          baseRequest.get(
                  url:    url,
                  json:   jsonPayload,
                  form:   formPayload
              function(error, response, body)
                  if (!error && response.statusCode === 200)
                      callback(false, body);
                  else if (response && (response.statusCode === 401 || response.statusCode === 403))
                      log("error during tahomalink request: " + response.statusText + " ->" + response.statusCode + " retry "  + requestPath, 'error');
                      // session expired?
                      setConnected(false);
                      // perform login and send again
                      sendGET(requestPath, payload, callback);
                  else
                      log("error during tahomalink request: " + response.statusCode + ": " + error +
                          ", request path: " + requestPath + " with payload:" + JSON.stringify(payload), 'error');
                      var result = {};
                      result.error = error;
                      if(typeof response !== "undefined")
                          log("response status: " + response.statusCode + " " + response.statusText,'debug');
                          result.responseStatusCode = response.statusCode;
                          result.responseStatusText = response.statusText;
                      callback(true, result);
      function sendInternalPOST(requestPath, payload, callback)
          if (requestPath.endsWith("apply"))
              url = baseURL + requestPath + "/highPriority";
          if (requestPath === 'login')
              formPayload = payload;
          else
          baseRequest.post(
                  url:    url,
                  json:   jsonPayload,
                  form:   formPayload
                          callback(false, JSON.parse(body));
                      else
                  else if (response && requestPath !== 'logout'
                      // session expired?
                      sendPOST(requestPath, payload, callback);
                  else
                      var result = {};
      function logout(callback)
          var performLogout = isConnected();
          if (performLogout)
              sendInternalPOST("logout", {}, function (err, data)
          else
              callback(false, {});
      function login(callback)
          if (isConnected())
               return;
          // check for login already started but not yet finished
          if (loginInProgress)
              //log("login in progress, wait 100 msec");
              setTimeout(function()
                  login(callback);
              }, 1500);
              return;
          loginInProgress = true;
          var payload = {'userId': userName, 'userPassword': passWord};
          var result = sendInternalPOST("login", payload, function (err, data)
              if (err || !data.success)
                  return callback(true, data);
              setConnected(true);
              getUserInfo(function (err,data)
                  if (!err)
                      return getSetup(callback);
      function getUserInfo(callback)
          sendGET('enduser/mainAccount', {},function (err, data)
              if (!err)
                  updateData('userdata', data.endUser);
                  callback(false, data);
              else
                  log("enduser/mainAccount failed!", 'error');
      function updateGateWayData(gateways)
          for (var i in gateways)
              var gateway = gateways[i];
              updateData(gateway.gatewayId, gateway);
      function updateDevices(devices)
          tahomaDevices = devices;
          for (var i in devices)
              var device = devices[i];
              // just set the raw data from tahoma
              updateDevice('devices.' + device.label, device);
      function updateDevice(name, deviceData)
          createOrUpdateState('tahoma.' + name, '',
              getCreateStateOptions4Widget(deviceData.widget));
          // device URL
          createOrUpdateState('tahoma.' + name + '.deviceURL', deviceData.deviceURL);
          // states
          for (var stateKey in deviceData.states)
              var state = deviceData.states[stateKey];
              createOrUpdateState('tahoma.' + name + '.states.' + state.name,
                  mapValueTahoma2ioBroker(state.name, state.value),
                  getCreateStateOptions4State(deviceData.widget, state.name));
           // commands
          for (var commandKey in deviceData.definition.commands)
              var command = deviceData.definition.commands[commandKey];
              if (command.nparams === 0)
                  createOrUpdateState('tahoma.' + name + '.commands.' + command.commandName, false, {
                      read: true,
                      write: true,
                      role: "button"
          // raw data
          if (rawDeviceData)
              for (var p in deviceData)
                  var value = deviceData[p];
                  if (typeof(value) === 'object')
                      updateData('raw.' + name + '.' + p, value);
                  else
                      createOrUpdateState('tahoma.raw.' + name + '.' + p, value);
      function updateActionGroups(actionGroups)
          tahomaActionGroups = actionGroups;
          for (var i in actionGroups)
              var actionGroup = actionGroups[i];
              updateActionGroup('actionGroups.' + actionGroup.label, actionGroup);
      function updateActionGroup(actionGroup, actionGroupData)
          // Action Group OID
          createOrUpdateState('tahoma.' + actionGroup + '.oid', actionGroupData.oid);
          createOrUpdateState('tahoma.' + actionGroup + '.commands.' + 'execute', false, {
              read: true,
              write: true,
              role: "button"
      function mapValueTahoma2ioBroker(stateName, stateValue)
          if (stateName === 'core:ClosureState' ||
              stateName === 'core:TargetClosureState' ||
              stateName === "core:SlateOrientationState" ||
              stateValue = parseInt(stateValue,10);
          return stateValue;
      function mapValueioBroker2Tahoma(stateName, stateValue)
          if (stateName === 'core:ClosureState' || stateName === 'core:TargetClosureState')
              //stateValue = parseInt(stateValue,10);
          return stateValue;
      function updateData(type, data)
          for (var p in data)
              var value = data[p];
                  updateData(type + '.' + p, value);
              else
                  createOrUpdateState('tahoma.' + type + '.' + p, value);
      function createOrUpdateState(key, value, options)
          key = key.replace(' ' , '_');
          var state = getState("javascript.0." + key);
          var typeName = "string";
          if (value === "true" || value === "false")
              value = value == "true";
              typeName = "boolean";
          else if (Number.isInteger(value))
              value = parseInt(value,10);
              typeName = "number";
          else if (!isNaN(value))
              value = Number(value);
              typeName="number";
          if (state.notExist)
              if (typeof(options) === 'undefined')
                  options = {
                      read: true,
                      write: false,
                      type: typeName
              // create state
              createState(key, value, 0, options);
          else
              setState("javascript.0." + key, value, true);
      function getSetup(callback)
          sendGET('setup', {},function (err, data)
              if (!err)
                  updateGateWayData(data.gateways);
                  updateData('location', data.location);
                  updateDevices(data.devices);
                  // delete old devices
                  deleteOldDevices();
                  // update mapping table device URL to state key with label
                  $('javascript.0.tahoma.devices.*.deviceURL').each(function (id, i)
                      var state = getState(id);
                      Map_DeviceURL2StateName[state.val] = id.substr(0, id.indexOf(".deviceURL"));
                      //log("set mapping deviceURL to name: " + state.val + " -> " + id.substr(0, id.indexOf(".deviceURL")),'debug');
                  // refresh
                  refresh(callback);
              else
                  log("setup failed!",'error');
                  callback(err, {});
          sendGET('actionGroups', {},function (err, data)
              if (!err)
                  updateActionGroups(data);
              else
                  log("actionGroups failed!",'error');
                  callback(err, {});
      function refresh(callback){
          sendPOST('/setup/devices/states/refresh', {}, function (err,data)
                      if (err)
                          log("refresh device state failed", 'error');
                      callback(err, {});
      function refresh(){
                      if (err)
      function getAllStates()
          login(function (err, data)
              if (err)
                  return;
          if(eventRegisterID === '-1'){
              sendPOST("events/register", {}, function (err,data)
                  if (err)
                      log("events/register failed", 'error');
                      return;
                  eventRegisterID = data.id;
                  log ("eventRegisterID = " + eventRegisterID);
                  fetchEvents();
          else {
              fetchEvents();
      function fetchEvents(){
          refresh();
          sendPOST("events/" + eventRegisterID + "/fetch", {}, function (err,data)
              if (err)
                  return;
              var callback;
              log ("events/" + eventRegisterID + "/fetch" + "Fetched Data" + data, 'debug');
              updateDeviceStateFromEvent(data);
      function updateDeviceStateFromEvent(events)
          for (var i in events)
              var event = events[i];
              if (event.name === 'DeviceStateChangedEvent')
                  updateDeviceState(event);
      function updateDeviceState(event)
          var deviceURL = event.deviceURL;
          var states = event.deviceStates;
          var devicePath = Map_DeviceURL2StateName[deviceURL];
          // tahoma.devices.XXX
          // tahoma.devices.XXX.states.Y
          log("got event for device " + devicePath, 'debug');
          for (var i in event.deviceStates)
              var state = event.deviceStates[i];
              var name = state.name;
              var value = mapValueTahoma2ioBroker(name, state.value);
              log("found " + devicePath + '.states.' + name + " -> " + value, 'debug');
              setState(devicePath + '.states.' + name, value, true);
      function deleteOldDevices()
          var currentTime = new Date().getTime();
          $('javascript.0.tahoma.devices.*.lastUpdateTime').each(function (id, i)
              var device = id.substr(0, id.indexOf(".lastUpdateTime"));
              if (currentTime - state.ts > 5 * 60 * 1000)
                  // update older than 1 minute -> drop
                  log ("found old " + device + " -> " + new Date(state.ts),'debug');
                  $(device + '.*').each(function (id, i)
                      log("delete state:" + id, 'debug');
                      deleteState(id);
      on(/^javascript\.0\.tahoma\.devices.*\.commands/,function(obj)
          if (obj.state.val)
            var id = obj.id;
            log("button pressed: " + id + " -> " + JSON.stringify(obj), 'debug');
            var commandName = id.substr(id.lastIndexOf(".")+1);
            var deviceURL = getState(id.substr(0, id.indexOf(".commands.")) + ".deviceURL").val;
            var payload = {'label':'command ' + commandName + ' from ioBroker',
                'actions':[{
          		'deviceURL': deviceURL,
              	'commands':	[{
          			'name': commandName,
              	    'parameters': []
              sendPOST("exec/apply", payload, function(err, data)
                  // reset state
                  setState(obj.id, !obj.state.val);
      on(/^javascript\.0\.tahoma\.devices.*\.states.core:ClosureState/,function(obj)
          onClosureStateChange(obj);
      on(/^javascript\.0\.tahoma\.devices.*\.states.core:TargetClosureState/,function(obj)
      function onClosureStateChange(obj)
          if (!obj.newState.ack)
              var id = obj.id;
                //log("closure state changed: " + id + " -> " + JSON.stringify(obj));
                var commandName = "setClosure";
                var deviceURL = getState(id.substr(0, id.indexOf(".states.")) + ".deviceURL").val;
                var stateValue = obj.newState.val;
                var roomName = id.substr(id.indexOf('.devices.')+9);
                roomName = roomName.substr(0,roomName.indexOf('.states'));
                var payload = {'label': roomName + ' - Positioniere auf ' + stateValue + ' % - ioBroker',
                    'actions':[{
                  	'commands':	[{
                  	    'parameters': [ mapValueioBroker2Tahoma('core:ClosureState', stateValue) ]
                      // reset state
                      //setState(obj.id, !obj.state.val);
      on(/^javascript\.0\.tahoma\.devices.*\.states.core:SlateOrientationState/,function(obj)
              var id = obj.id;
            var commandName = "setOrientation";
            //log("slate orientation changed: " + roomName + " -> " + stateValue);
            var payload = {'label':roomName + ' - Ausrichtung ' + stateValue + ' % - ioBroker',
                'actions':[{
              	'commands':	[{
              	    'parameters': [ mapValueioBroker2Tahoma('core:SlateOrientationState', stateValue) ]
                  // reset state
      on({id: /^javascript\.0\.tahoma\.actionGroups.*\.commands.execute/, valNe: false}, function (obj) {
          if (obj.state.val)
              var id = obj.id;
              var oid = getState(id.substr(0, id.indexOf(".commands.")) + ".oid").val;
              log(baseURL + "exec/" + oid);
              sendPOST("exec/" + oid, "", function(err, data)
                  if (err)
                      log(baseURL + "exec/" + oid, "error");
                      return;
      // if connected, update state all 5 seconds
      //schedule("*/5 * * * * *", function ()
      // if connected, update state all 10 seconds
      schedule("*/10 * * * * *", function ()
          // if connected, update states
          if (isConnected())
              getAllStates();
              if (new Date().getTime() - lastEventTime > 5 * 60 * 1000)
                  // no events within last 60 seconds
                  logout(function () {});
      // update state all 10 minutes
      schedule("*/10 * * * *", function ()
          if (new Date().getTime() - lastEventTime > 9 * 60 * 1000)
              log("update tahoma all 10 minutes");
              getAllStates();
      onStop(function (callback) {
          logout(function (err, data)
                  callback();
      }, 10000 /*ms*/);
      // start script
      getAllStates();
      K integer63 G 3 Replies Last reply Reply Quote 2
        kassmann @blackeagle998 last edited by
        @blackeagle998
        👍🏼 Erledigt
          kassmann @thoemmes86 last edited by
          @thoemmes86 sagte in Anfrage Tahoma/Somfy IO Adapter:
          Viele Grüße
          Na das war mal ein schönes Nikolausgeschenk. 😁
          Tausend Dank 👏 👏
            Ich habe gerade das Skript in meinem letzten Post aktualisiert.
            War beim Ausführen von Szenarien noch ein Fehler drin. Jedes Szenario konnte nur genau einmal ausgeführt werden. 😵
            • integer63
              integer63 @thoemmes86 last edited by
              @thoemmes86 Was soll ich sagen - DANKE!
              Funktioniert wieder wie vorher 🙂 Und genau zu diesem "vorher" hätte ich eine Frage: Ich habe das Phänomen, dass wenn ich die Behanghöhe auf einen bestimmten Prozentwert stelle (über core:ClosureState) und der Screen auf diese Position gefahren ist (z. B. von 0% auf 50%), er dann ein paar Sekunden später auf eine andere Position fährt, an der er gerade eben vorbeigefahren ist (z. B. 46%) - wobei dieses "ein Stück zurückfahren" immer ein etwas anderer Wert ist. Ich vermute, dass durch das Abfragen der States noch während der Fahrt, der ClosureState aktualisiert wird und den neuen Wert dann gleich wieder als Auslöser nimmt und ihn anfährt. Könnte das sein? Übrigens ich habe keinen Datenpunkt core:TargetClosureState. Habe nur ich dieses Problem?
                smartysmart last edited by
                ioBroker ist im kommen und hat schon Systeme verdrängt die länger auf dem Markt sind.
                Warum ?
                Weil ioBroker eine geile Community hat und die Bedienung sehr inuitiv ist.
                Es wird eine Menge unterstützt und es gibt zig verschiedene Videos zu verschiedenen Themen.
                Für mich ist und bleibt ioBroker #1.
                Ein Somfy Adapter darf meiner Meinung nach nicht fehlen. Somfy und Velux sind zwei sehr bekannte Hersteller in ihrem Gebiet, und wir wollen ja noch weiter wachsen, also sollten wir es neuen Usern schmackhaft machen ioBroker zu nutzen.
                Dadurch das Somfy die API öffentlich gemacht hat sollte es für den Developer auch eine machbare Sache sein und der Aufwand sich in Grenzen halten.
                Wenn ein Developer Zeit und Lust hat, dann soll er sich melden. Im Zweifel starten wir noch eine Spendenaktion und versuchen so für den Developer das maximum an Dankbarkeit für seine Leistung zu erbringen.
                  gammler2003 @thoemmes86 last edited by
                  @thoemmes86 Genial, vielen Dank für deine Mühe! Das Skript ist genau das, was ich immer gesucht habe.
                  Jedoch ist es so, dass es permanent Warnmeldungen in meinen Log schreibt. Nachfolgend ein kleiner Auszug davon. Kannst du dir erklären, an was das liegt? Was mache ich falsch?
                  Vielen Dank vorab an alle,
                  Steven
                  2020-01-11 10:17:00.157 - warn: javascript.0 (1930) at updateDeviceState (script.js.Produktion.Tahoma-Script:701:9)
                  2020-01-11 10:17:00.157 - warn: javascript.0 (1930) at updateDeviceStateFromEvent (script.js.Produktion.Tahoma-Script:678:13)
                  2020-01-11 10:17:00.158 - warn: javascript.0 (1930) at script.js.Produktion.Tahoma-Script:665:9
                  2020-01-11 10:17:00.158 - warn: javascript.0 (1930) at Request._callback (script.js.Produktion.Tahoma-Script:252:21)
                  2020-01-11 10:17:00.158 - warn: javascript.0 (1930) at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                  2020-01-11 10:17:00.158 - warn: javascript.0 (1930) at Request.emit (events.js:210:5)
                  2020-01-11 10:17:00.158 - warn: javascript.0 (1930) at Request. (/opt/iobroker/node_modules/request/request.js:1161:10)
                  2020-01-11 10:17:00.159 - warn: javascript.0 (1930) at Request.emit (events.js:210:5)
                  2020-01-11 10:17:00.159 - warn: javascript.0 (1930) at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1083:12)
                  2020-01-11 10:17:00.159 - warn: javascript.0 (1930) at Object.onceWrapper (events.js:299:28)
                  2020-01-11 10:17:00.159 - warn: javascript.0 (1930) at IncomingMessage.emit (events.js:215:7)
                  2020-01-11 10:17:00.159 - warn: javascript.0 (1930) at endReadableNT (_stream_readable.js:1184:12)
                  2020-01-11 10:17:00.160 - warn: javascript.0 (1930) at processTicksAndRejections (internal/process/task_queues.js:80:21)
                  2020-01-11 10:17:00.160 - warn: javascript.0 (1930) State "undefined.states.core:RSSILevelState" not found
                  2020-01-11 10:17:00.162 - warn: javascript.0 (1930) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
                  2020-01-11 10:17:00.162 - warn: javascript.0 (1930) at updateDeviceState (script.js.Produktion.Tahoma-Script:701:9)
                  2020-01-11 10:17:00.162 - warn: javascript.0 (1930) at updateDeviceStateFromEvent (script.js.Produktion.Tahoma-Script:678:13)
                  2020-01-11 10:17:00.162 - warn: javascript.0 (1930) at script.js.Produktion.Tahoma-Script:665:9
                  2020-01-11 10:17:00.162 - warn: javascript.0 (1930) at Request._callback (script.js.Produktion.Tahoma-Script:252:21)
                  2020-01-11 10:17:00.163 - warn: javascript.0 (1930) at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                  2020-01-11 10:17:00.163 - warn: javascript.0 (1930) at Request.emit (events.js:210:5)
                  2020-01-11 10:17:00.163 - warn: javascript.0 (1930) at Request. (/opt/iobroker/node_modules/request/request.js:1161:10)
                  2020-01-11 10:17:00.163 - warn: javascript.0 (1930) at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1083:12)
                  2020-01-11 10:17:00.163 - warn: javascript.0 (1930) at Object.onceWrapper (events.js:299:28)
                  2020-01-11 10:17:00.164 - warn: javascript.0 (1930) at IncomingMessage.emit (events.js:215:7)
                  2020-01-11 10:17:00.164 - warn: javascript.0 (1930) at endReadableNT (_stream_readable.js:1184:12)
                  2020-01-11 10:17:00.164 - warn: javascript.0 (1930) at processTicksAndRejections (internal/process/task_queues.js:80:21)
                  2020-01-11 10:17:00.164 - warn: javascript.0 (1930) State "undefined.states.core:RSSILevelState" not found
                  2020-01-11 10:17:00.166 - warn: javascript.0 (1930) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
                  2020-01-11 10:17:00.166 - warn: javascript.0 (1930) at updateDeviceState (script.js.Produktion.Tahoma-Script:701:9)
                  2020-01-11 10:17:00.166 - warn: javascript.0 (1930) at updateDeviceStateFromEvent (script.js.Produktion.Tahoma-Script:678:13)
                  2020-01-11 10:17:00.167 - warn: javascript.0 (1930) at script.js.Produktion.Tahoma-Script:665:9
                  2020-01-11 10:17:00.167 - warn: javascript.0 (1930) at Request._callback (script.js.Produktion.Tahoma-Script:252:21)
                  2020-01-11 10:17:00.171 - warn: javascript.0 (1930) at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                  2020-01-11 10:17:00.171 - warn: javascript.0 (1930) at Request.emit (events.js:210:5)
                  2020-01-11 10:17:00.171 - warn: javascript.0 (1930) at Request. (/opt/iobroker/node_modules/request/request.js:1161:10)
                  2020-01-11 10:17:00.172 - warn: javascript.0 (1930) at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1083:12)
                  2020-01-11 10:17:00.172 - warn: javascript.0 (1930) at Object.onceWrapper (events.js:299:28)
                  2020-01-11 10:17:00.172 - warn: javascript.0 (1930) at IncomingMessage.emit (events.js:215:7)
                  2020-01-11 10:17:00.172 - warn: javascript.0 (1930) at endReadableNT (_stream_readable.js:1184:12)
                  2020-01-11 10:17:00.172 - warn: javascript.0 (1930) at processTicksAndRejections (internal/process/task_queues.js:80:21)
                  2020-01-11 10:17:00.173 - warn: javascript.0 (1930) State "undefined.states.core:RSSILevelState" not found
                  2020-01-11 10:17:00.174 - warn: javascript.0 (1930) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
                  2020-01-11 10:17:00.175 - warn: javascript.0 (1930) at updateDeviceState (script.js.Produktion.Tahoma-Script:701:9)
                  2020-01-11 10:17:00.175 - warn: javascript.0 (1930) at updateDeviceStateFromEvent (script.js.Produktion.Tahoma-Script:678:13)
                  2020-01-11 10:17:00.175 - warn: javascript.0 (1930) at script.js.Produktion.Tahoma-Script:665:9
                  2020-01-11 10:17:00.175 - warn: javascript.0 (1930) at Request._callback (script.js.Produktion.Tahoma-Script:252:21)
                  2020-01-11 10:17:00.175 - warn: javascript.0 (1930) at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                  2020-01-11 10:17:00.176 - warn: javascript.0 (1930) at Request.emit (events.js:210:5)
                  2020-01-11 10:17:00.176 - warn: javascript.0 (1930) at Request. (/opt/iobroker/node_modules/request/request.js:1161:10)
                  2020-01-11 10:17:00.176 - warn: javascript.0 (1930) at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1083:12)
                  2020-01-11 10:17:00.176 - warn: javascript.0 (1930) at Object.onceWrapper (events.js:299:28)
                  2020-01-11 10:17:00.176 - warn: javascript.0 (1930) at IncomingMessage.emit (events.js:215:7)
                  2020-01-11 10:17:00.177 - warn: javascript.0 (1930) at endReadableNT (_stream_readable.js:1184:12)
                  2020-01-11 10:17:00.177 - warn: javascript.0 (1930) at processTicksAndRejections (internal/process/task_queues.js:80:21)
                  snookerap 1 Reply Last reply Reply Quote 0
                  • snookerap
                    snookerap @gammler2003 last edited by snookerap
                    @gammler2003
                    @thoemmes86
                    selbiges bei mir auch
                    Wie muss man es richtig einstellen, damit es funktioniert?
                    • StrathCole
                      StrathCole last edited by
                      Soweit ich das mit den Warnungen richtig sehe, ist das ein Problem mit den deviceURLs. Er scheint da etwas nicht zu finden.
                      Ich habe auf Basis des Skripts jetzt einen Adapter entwickelt und dabei auch einige Bugs gefixt (vermutlich auch neue eingebaut 😉 ).
                      https://github.com/StrathCole/ioBroker.tahoma
                      K E 3 Replies Last reply Reply Quote 3
                      • snookerap
                        snookerap last edited by
                        Top, klasse Arbeit!!!
                        Direkt mal instaliert, habe bisher die Rollos über den HAM-Adapter gesteuert.
                        -> dieser hier bringt mir natürlich deutlich mehr Objekt-Werte in den ioBroker
                        Vielen Dank
                          kassmann @StrathCole last edited by
                          @StrathCole das ist ja mal eine tolle Überraschung, gleich installiert 😊 👍
                            el_malto @StrathCole last edited by
                            @StrathCole coole Sache.
                            Ist das Skript denn auf der Basis der API die jetzt von Somfy veröffentlich wurde?
                            https://www.somfy.de/ueber-somfy/-so-open-mit-somfy
                            https://developer.somfy.com/somfy-open-api/apis
                            Es macht doch für die Zukunft mehr Sinn gleich die offizielle API zu verwenden.
                            Auf GitHub gibt es auch schon eine Implementierung von der API in Phyton 3. Hilft ja vielleicht auch weiter.
                            https://github.com/tetienne/somfy-open-api
                            Leider habe ich davon überhaupt keine Ahnung.
                            StrathCole 1 Reply Last reply Reply Quote 0
                              @StrathCole
                              Ich bin einfach mal so frei und verlinke auch dein Thread zum testen hier. Nicht das Feedback dann hier landet und untergeht.
                              Feedback also immer hier posten -> https://forum.iobroker.net/topic/28956/test-adapter-somfy-tahoma-v0-1-x-github
                              • StrathCole
                                StrathCole @el_malto last edited by StrathCole
                                @el_malto sagte in Anfrage Tahoma/Somfy IO Adapter:
                                Nein, ist es nicht. Es verwendet die API, die auch die tahomalink Homepage verwendet.
                                Die offizielle API liefert leider auch viel weniger Infos zu den einzelnen Rollläden und Geräten, beispielsweise scheint die Signalstärke (Funk) zu fehlen.
                                Auch gibt es keine Möglichkeit, die ich gesehen hätte, via API auf die "my" Position zu fahren usw.
                                Daher würde ich persönlich derzeit nicht diese API nutzen.
                                @StrathCole
                                Danke, hatte ich vergessen.
                                  @StrathCole
                                  Wirklich super, dass du diesen Adapter erstellt hast.
                                  Nachdem das Skript nicht mehr lauffähig war, habe ich alles auf den HAM Adapter geändert.
                                  Ich habe deinen Adapter installiert und er läuft fehlerfrei, die Datenpunkte sind alle da.
                                  Testen konnte ich bisher noch nicht wirklich, ich muss das jetzt erstmal alles wieder zurück ändern bzw. ein Parallelskript anlegen ☺
                                  Bisher war mein Problem immer, dass ich nur Befehle für 9 Rollläden auf einmal senden konnte und danach einen Timeout einbauen musste, um die restlichen zu steuern. Ab dem 10ten Rollladen gab es immer einen Fehler im Log, irgendwas mit Payload..., mal sehen wie sich das jetzt verhält.
                                    tristan last edited by
                                    Servus!
                                    Ich war die ganze Zeit auf der Fährte meine Somfy und Velux Rollläden mit dem KLF 200 zu steuern und freue mich sehr, dass ich hier jetzt noch eine Alternative gefunden habe!
                                    Was mir noch nicht ganz klar ist:
                                    • Welche Hardware brauche ich bzw. welche eignet sich?
                                    • Wie sind die Aussichten irgendwann ohne Cloud auszukommen?
                                    Grüße!
                                    integer63 1 Reply Last reply Reply Quote 0
                                    • integer63
                                      integer63 @tristan last edited by
                                      @tristan sagte in Anfrage Tahoma/Somfy IO Adapter:
                                      KLF 200
                                      Hallo tristan, so wie ich den KLF 200 verstehe, kann man damit nur rudimentär steuern: "Einfache Auf-Stopp-Zu-Ansteuerung von 5 Produkten oder 5 Produktgruppen ... 5 potentialfreie Eingänge sind frei belegbar"
                                      Für den ioBroker Adapter brauchst du entweder eine Tahoma oder eine Connexoon von Somfy - leider alles über Cloud. Aber damit kannst du dann jeden Rollladen/Markise beliebig ansteuern und sehr genau die gewünschte Position anfahren. Also ich bin begeistert (merkt man so gar nicht, oder 😉
                                        tristan @integer63 last edited by
                                        @integer63 said in Anfrage Tahoma/Somfy IO Adapter:
                                        Danke integer63!
                                        Gabs denn bei anderen Cloud-Produkten schon den Ansatz die Cloud lokal zu simulieren, indem Anfragen nach draußen umgeleitet und beantwortet werden?
                                        integer63 StrathCole 2 Replies Last reply Reply Quote 0
                                        • integer63
                                          @tristan Tut mir leid, aber ich bin kein Entwickler, sondern nur ambitionierter Anwender und kann zu diesem speziellen Thema leider nichts beitragen.
                                          • StrathCole
                                            StrathCole @tristan last edited by
                                            @tristan bei bestimmten Produkten mit sehr einfacher API gab es das (zB Sonoff). Bei Tahoma dürfte das sehr schwierig sein, denn die Box kommuniziert wohl nicht nur via http(s), sondern auch mit UDP-Paketen. Das alles herauszufinden und lokal nachzubilden dürfte eine Herkulesaufgabe sein.
                                            605
                                            157467
