    4. Neue Installationsroutine (für Linux)
      mpa last edited by mpa
      ich versuche gerade iobroker auf einer VM mit Ubuntu LTS 18.04.3 zu installieren.
      Mittlerweile habe ich jetzt mehrmals die Anleitung https://www.iobroker.net/#de/documentation/install/linux.md durchgeackert aber bekomme es leider nicht hin.
      Beim Schritt "Installing ioBroker" bekomme ich immer folgende Fehlermeldungen:
          Installing ioBroker (3/4)
      ../src/unix_dgram.cc: In function ‘void {anonymous}::OnRecv({anonymous}::SocketContext*)’:
      ../src/unix_dgram.cc:121:25: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                           argv);
      In file included from ../src/unix_dgram.cc:5:0:
      ../../nan/nan.h:1024:46: note: declared here
         NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
      ../src/unix_dgram.cc: In function ‘void {anonymous}::OnWritable({anonymous}::SocketContext*)’:
      ../src/unix_dgram.cc:129:28: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                           0, NULL);
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Socket(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:189:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         domain      = info[0]->Int32Value();
      In file included from /root/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,
                       from /root/.cache/node-gyp/10.17.0/include/node/node.h:63,
                       from ../../nan/nan.h:54,
      /root/.cache/node-gyp/10.17.0/include/node/v8.h:2478:46: note: declared here
         V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
      /root/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
         declarator __attribute__((deprecated(message)))
      ../src/unix_dgram.cc:190:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         type        = info[1]->Int32Value();
      ../src/unix_dgram.cc:191:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         protocol    = info[2]->Int32Value();
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:230:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         fd = info[0]->Int32Value();
      ../src/unix_dgram.cc:231:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
         String::Utf8Value path(info[1]);
      /root/.cache/node-gyp/10.17.0/include/node/v8.h:2892:28: note: declared here
                         explicit Utf8Value(Local<v8::Value> obj));
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::SendTo(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:258:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc:259:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         buf = info[1]->ToObject();
      In file included from /root/.cache/node-gyp/10.17.0/include/node/node.h:63:0,
      /root/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here
       Local<Object> Value::ToObject() const {
      ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         offset = info[2]->Uint32Value();
      /root/.cache/node-gyp/10.17.0/include/node/v8.h:2477:47: note: declared here
         V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
      ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         length = info[3]->Uint32Value();
      ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
         String::Utf8Value path(info[4]);
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc:303:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Connect(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Close(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      Könnte mir hier bitte jemand weiterhelfen?
      Vielen Dank!
        apollon77 last edited by
        Alles nur Warnungen, ignorieren. Wichtig ist was die letzten Zeilen der gesamten Ausgabe sind ... wenn da steht das alles ok ist dann ist alles ok
          mpa @apollon77 last edited by
          @apollon77 da kommt dann leider nichts mehr, da sich die VM aufhängt und Putty dadurch die Verbindung verliert.
            A Former User last edited by
            Ich versuche gerade, den ioBroker unter Lubuntu zum Laufen zu bringen.
            Hierzu habe ich mich an die folgende Anleitung gehalten:
            Es sei wohl auch alles erfolgreich installiert worden.
            Nur komme ich mit dem Browser nicht auf die Oberfläche.
            http://<iplocalhost>:8081
            Es kommt, Seite ist nicht erreichbar
            ioborker habe ich mit iobroker stop/start als auch restart probiert neu zu starten
            Ich habe dann mal probiert
            iobroker start admin
            Dann kommt:
            module.js:549
            throw err;
            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Function.Module._resolveFilename (module.js:547:15)
            AlCalzone Homoran 2 Replies Last reply Reply Quote 0
            • AlCalzone
              AlCalzone Developer @Guest last edited by
              @Alina sagte in Neue Installationsroutine (für Linux):
              Das sieht mir nicht nach einer erfolgreichen Installation aus. Probiere es bitte nochmal und zeig uns dann die Ausgabe der Installation.
                Homoran Global Moderator Administrators @Guest last edited by
                @Alina
                Wieso zwei Threads dazu?
                Habe dir in dem anderen / älteren geantwortet
                  debianatoe last edited by
                  Kann man die neue Linux-Installationsroutine auch in buildroot-Systemen ausführen? buildroot ist ja ein besonders platzsparendes Linux. Das hätte dann insbesondere auf kleinen raspi-Systemen den Vorteil, daß man mehr RAM für den iobroker zur Verfügung hätte.
                    apollon77 @debianatoe last edited by
                    @debianatoe @AlCalzone ?!
                    • AlCalzone
                      AlCalzone Developer @apollon77 last edited by
                      @apollon77 @debianatoe
                      Probier es aus. Ich hab keine Ahnung und bisher nicht davon gehört.
                        Homoran Global Moderator Administrators @apollon77 last edited by
                        @apollon77 Ich denke eher nicht.
                        die CCU baut auf buildroot auf - wenn ich mich richtig erinnere hat sich Jens Maus da schon dran versucht
                          debianatoe @Homoran last edited by
                          @Homoran Ja, die CCU baut auf buildroot auf. Aber buildroot läßt sich sehr variabel konfigurieren. Insofern wäre es denkbar, daß sich ein spezielles iobroker-buildroot, das mit dem CCU-buildroot nur wenig gemeinsam hat, bauen ließe. Wenn sich allerdings Jens Maus daran schon vergeblich (?) versucht hat, klingt das nach erheblichem Aufwand ...
                          Da wäre aus meiner Sicht ein iobroker-Installationsprofi gefragt, der genau weiß, welche Betriebssystem- und library-Bedingungen Voraussetzung sind.
                            @debianatoe Am Ende stht alles im install.sh drin was auf Github steht ... alles ws fehlt wird nachinstalliert aktuell per apt oder yum
                            • AlCalzone
                              @apollon77 sagte in Neue Installationsroutine (für Linux):
                              Das bezieht sich aber auf das, was wir von "normalen" Linux-Systemen kennen und wissen. Ggf muss bei buildroot noch mehr installiert werden.
                                debianatoe @AlCalzone last edited by
                                @AlCalzone sagte in Neue Installationsroutine (für Linux):
                                So ist es leider. Im buildroot-Linux gibt es meines Wissens nach weder apt noch yum. Deshalb kann install.sh in dieser Form leider nicht funktionieren bzw. alles, was fehlt, nachinstallieren. Stand jetzt wäre das eine Menge Handarbeit.
                                • AlCalzone
                                  AlCalzone Developer @debianatoe last edited by
                                  @debianatoe Wie installiert man dann auf buildroot einen Package-Manager?
                                  Wenn du die nötigen Schritte ermitteln kannst, was zusätzlich nötig ist, lässt sich das sicher in den Installer einbauen.
                                    @AlCalzone Also da bin ich leider überfragt.
                                    • xadox
                                      xadox last edited by xadox
                                      Können die folgenden Warnings bei der Installation auf Ubuntu 20.10, 20.04 oder Debian 10 ignoriert werden?
                                      In file included from ../../nan/nan.h:56,
                                                       from ../src/main.cpp:3:
                                      /root/.cache/node-gyp/10.23.0/include/node/node.h:573:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
                                             (node::addon_register_func) (regfunc),                          \
                                      /root/.cache/node-gyp/10.23.0/include/node/node.h:607:3: note: in expansion of macro 'NODE_MODULE_X'
                                         NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                                      ../src/main.cpp:42:1: note: in expansion of macro 'NODE_MODULE'
                                       NODE_MODULE(diskusage, Init)
                                      In file included from /root/.cache/node-gyp/10.23.0/include/node/node.h:63,
                                      /root/.cache/node-gyp/10.23.0/include/node/v8.h: In instantiation of 'void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]':
                                      /root/.cache/node-gyp/10.23.0/include/node/node_object_wrap.h:84:78:   required from here
                                      /root/.cache/node-gyp/10.23.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from 'v8::WeakCallbackInfo<node::ObjectWrap>::Callback' {aka 'void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)'} to 'Callback' {aka 'void (*)(const v8::WeakCallbackInfo<void>&)'} [-Wcast-function-type]
                                                      reinterpret_cast<Callback>(callback), type);
                                      /root/.cache/node-gyp/10.23.0/include/node/v8.h: In instantiation of 'void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]':
                                      ../../nan/nan_object_wrap.h:65:61:   required from here
                                      /root/.cache/node-gyp/10.23.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from 'v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback' {aka 'void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)'} to 'Callback' {aka 'void (*)(const v8::WeakCallbackInfo<void>&)'} [-Wcast-function-type]
                                      ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
                                       NODE_MODULE(unix_dgram, Initialize)
                                        Homoran Global Moderator Administrators @xadox last edited by
                                        @xadox ich denke ja, aber leider hast du die Ursache für die Warnings abgeschnitten.
                                        Es sit nur noch zu sehen, in welchen Teilen diese unbekannte Ursache auftritt
                                          Thomas Braun Most Active @xadox last edited by Thomas Braun
                                          @xadox Da läuft was mit den Usern falsch. Nie als root anmelden! Immer einen normalen User verwenden!
                                          In /root/.cache/ darf eigentlich nichts passieren.
                                          xadox 1 Reply Last reply Reply Quote 0
                                          • xadox
                                            xadox @Thomas Braun last edited by
                                            @Thomas-Braun Das wird es dann wohl sein. Da ich auf einer LXC installiere.
                                            Dort ist man im default ja erstmal mit "root" unterwegs.
                                            ich werde dann mal einen neuen User erzeugen und es erneut versuchen.
                                            @Homoran viel abgeschnitten habe ich dort eigentlich nicht:
                                            installation
                                            64
                                            415
                                            114493
