    4. BackItUp - Fehler in Datenpunkt History
    SOLVED BackItUp - Fehler in Datenpunkt History
    • horos73
      horos73 @simatec last edited by
      @simatec
      [DEBUG] [history] start with {"type":"creator","time":"06:00","debugging":true,"everyXDays":"3","nameSuffix":"BackitUp_Backup","deleteBackupAfter":0,
      "ftp":{"enabled":true,"type":"storage","source":null,"host":"IP-Adresse-meines-NAS","debugging":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal",
      "dir":"ioBrokerBackups/StandardBU","dirMinimal":"ioBrokerBackups/StandardBU","user":"USERNAME","pass":"****","port":"85"},"dir":"/opt/iobroker",
      "redis":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"IP-Adresse-meines-NAS","debugging":true,"deleteOldBackup":false,
      "ownDir":true,"bkpType":"Minimal","dir":"ioBrokerBackups/StandardBU","dirMinimal":"ioBrokerBackups/StandardBU","user":"USERNAME","pass":"****","port":"85"},
      "cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":null,"mount":"IP-Adresse-meines-NAS","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup",
      "wakeOnLAN":false,"macAd":"XYZ","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/volume1/ioBrokerBackups",
      "dirMinimal":"volume1/USERNAME/ioBrokerBackups","user":"USERNAME","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,
      "accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":false,"type":"storage","source":null,
      "debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/var/lib/redis/dump.rdb"},
      "historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"IP-Adresse-meines-NAS","debugging":true,"deleteOldBackup":false,"ownDir":true,
      "bkpType":"Minimal","dir":"ioBrokerBackups/StandardBU","dirMinimal":"ioBrokerBackups/StandardBU","user":"USERNAME","pass":"****","port":"85"},"cifs":{"enabled":false,"mountType":"NFS",
      "type":"storage","source":null,"mount":"IP-Adresse-meines-NAS","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"XYZ",
      "wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/volume1/ioBrokerBackups","dirMinimal":"volume1/USERNAME/ioBrokerBackups",
      "user":"USERNAME","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,
      "bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****",
      "ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"media/usb/history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage",
      "source":null,"host":"IP-Adresse-meines-NAS","debugging":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"ioBrokerBackups/StandardBU","dirMinimal":"ioBrokerBackups/StandardBU",
      "user":"USERNAME","pass":"****","port":"85"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":null,"mount":"IP-Adresse-meines-NAS","debugging":true,
      "fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"XYZ","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":false,"ownDir":false,
      "bkpType":"Minimal","dir":"/volume1/ioBrokerBackups","dirMinimal":"volume1/USERNAME/ioBrokerBackups","user":"USERNAME","pass":"****"},"dropbox":{"enabled":false,"type":"storage",
      "source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},
      "googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir",
      "dirMinimal":"/backupDir/minimal"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"15. Januar 2020 um 12:23 Uhr"},
      "telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"MeinName",
      "onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"email.0","NoticeType":"longEmailNotice",
      "emailReceiver":"Email@Adresse.ABC","emailSender":"Email@Adresse.ABC","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram",
      "type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      Ich hoffe, ich habe alle sensiblen Daten erwischt 😉
      Danke, simatec, dass Du den Thread verfolgst und Dich meldest!!! 👍
        Coffeelover @simatec last edited by
        @simatec Derzeit steht bei mir:
        [ERROR] [iobroker] - (node:22070) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
        • simatec
          simatec Developer Most Active @horos73 last edited by
          @horos73
          Nein ich meine das Objekt "line" im Ordner "Output"
          horos73 1 Reply Last reply Reply Quote 0
          • horos73
            @simatec Hab Dir vorhin das kopiert, was hinten bei "Wert" steht.
            Hier der Screenshot:
              Coffeelover last edited by
              @simatec Meinen Eintrag siehst du oben. Aber bei mir läuft das Backup auch nicht durch. Folgendes steht im Log:
              backitup.0	2020-01-15 13:10:42.547	info	(2577) [iobroker] backup was activated at 02:10 every 1 day(s)
              backitup.0	2020-01-15 13:10:42.490	info	(2577) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.17.0
              backitup.0	2020-01-15 13:10:35.686	info	(2230) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
              backitup.0	2020-01-15 13:10:35.685	info	(2230) terminating
              backitup.0	2020-01-15 13:10:35.183	info	(2230) Got terminate signal TERMINATE_YOURSELF
              • simatec
                simatec Developer Most Active @Coffeelover last edited by
                @Coffeelover sagte in BackItUp - Fehler in Datenpunkt History:
                Ich sehe keinen Eintrag des Objektes "line" von dir.
                Der Log sagt nix aus. Stelle die Instanz mal auf debug (siehe meiner Signatur)
                • horos73
                  horos73 @simatec last edited by horos73
                  @simatec Bei mir sieht das Log (debug) aktuell so aus:
                  backitup.0	2020-01-15 12:23:45.008	debug	[iobroker] exec: done
                  backitup.0	2020-01-15 12:23:45.007	debug	[iobroker/history] backitup.0.history.html
                  backitup.0	2020-01-15 12:23:44.999	debug	[iobroker/telegram] done
                  backitup.0	2020-01-15 12:23:44.999	debug	[iobroker/telegram] [iobroker] used Telegram-Instance: telegram.0
                  backitup.0	2020-01-15 12:23:44.995	debug	[iobroker/clean] done
                  backitup.0	2020-01-15 12:23:44.993	debug	[iobroker/ftp] done
                  backitup.0	2020-01-15 12:23:44.812	debug	[iobroker/ftp] Send iobroker_2020_01_15-12_23_38_BackitUp_Backup_backupiobroker.tar.gz
                  backitup.0	2020-01-15 12:23:44.812	debug	[iobroker/ftp] FTP connected.
                  backitup.0	2020-01-15 12:23:44.464	debug	[iobroker/iobroker] done
                  backitup.0	2020-01-15 12:23:44.449	debug	[iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_01_15-12_23_38_BackitUp_Backup_backupiobroker.tar.gz
                  backitup.0	2020-01-15 12:23:35.745	debug	sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"12345678":"MeinName"}
                  backitup.0	2020-01-15 12:23:03.713	debug	system.adapter.admin.0: logging true
                  Sieht - für mich - ja OK aus..
                  • simatec
                    @horos73 sagte in BackItUp - Fehler in Datenpunkt History:
                    Da wird das Backup nicht sauber beendet.
                    Das ist ein Eintrag der history.
                    Kannst du mal den Inhalt des Objektes posten.
                    • horos73
                      @simatec der Output war der, den ich Dir vorhin gepostet habe (drunter schrieb ich "hoffe ich habe alle sensiblen .. erwischt". Oder meinst Du: Objekt bearbeiten/RAW ?:
                        "common": {
                          "name": "Used for debug outputs",
                          "role": "state",
                          "type": "string",
                          "def": "",
                          "read": true,
                          "write": false
                        "native": {},
                        "acl": {
                          "object": 1636,
                          "owner": "system.user.admin",
                          "state": 1636
                        "_id": "backitup.0.output.line",
                        "type": "state"
                      • simatec
                        html
                        History wird nicht beendet. Was hast du als "Anzahl der History-Einträge" eingetragen?
                        • horos73
                          @simatec Hmm, nutze history nicht - zumindest nicht bewusst. Wo stelle ich das ein?
                          • simatec
                            @horos73
                            Nein bitte den Wert des Objektes posten. Ich sehe den im Screenshot nur abgeschnitten.
                              @horos73 Habe gerade iobroker komplett neu gestartet. Backup läuft wieder durch. Jetzt habe ich im Objekt lines folgenden Eintrag:
                              [DEBUG] [history] start with {"type":"creator","time":"02:10","debugging":true,"everyXDays":"1","nameSuffix":"iobrokerRevival","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.188.xx","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"/backupDir/minimal","user":"Homee","pass":"****","port":"21"},"dropbox":{"enabled":true,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.188.xx","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"/backupDir/minimal","user":"Homee","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"ftp","mount":"192.168.188.xx","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":true,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.188.xx","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"/backupDir/minimal","user":"Homee","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"ftp","mount":"192.168.188.xx","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"xxxx","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":true,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"media/usb/history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.188.xx","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"/backupDir/minimal","user":"Homee","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"ftp","mount":"192.168.188.xx","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:2xxx","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":true,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"15. Januar 2020 um 13:17 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"Raimund","onlyError":false,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                              Das sieht ziemlich ähnlich zu Holger aus.
                              • simatec
                                In den Haupteinstellungen von backitup
                                • horos73
                                  @simatec
                                  Screenshot von den history Einstellungen des Adapters:
                                    @simatec Ich nutze History in den Einstellungen auch nicht. Die Anzahl steht auf Default 25.
                                    • horos73
                                      horos73 @Coffeelover last edited by horos73
                                      @Coffeelover @simatec bei mir auch auf 25/default
                                      PS: muss mich bis heute Abend hier ausklinken (ein bissel arbeiten 😉
                                      Bis später!
                                      • simatec
                                        Welchen js-controller habt ihr laufen?
                                        Nutzt ihr backitup im Compact-Modus?
                                        Probiert mal die Anzahl der Historydaten in den Einstellungen auf 20 zu setzen und lasst mal bitte den Installer Fix (siehe Signatur) drüberlaufen.
                                          Coffeelover @simatec last edited by Coffeelover
                                          @simatec jscontroller 2.2.7.
                                          Was ist der compact mode?
                                          Fix lasse ich gleich mal laufen und dann Backup mit 20 bei History.
                                          Update:
                                          • Habe 20 bei Anzahl der History-Einträge eingetragen (sonst nichts verändert)
                                          • Habe den Fix durchlaufen lassen
                                          • Backup wird weiterhin durchgeführt (file liegt auf NAS ab), DP backitup.0.history.iobrokerSuccess steht auf false, DP backitup.0.history.iobrokerLastTime zeigt "error: 15. Januar 2020 um 13:59 Uhr"
                                          Gibt es eigentlich einen Grund, warum das Full-Backup nicht mehr vorhanden ist?
                                          • simatec
                                            @Coffeelover
                                            Irgendwas ist da an eurem System nicht korrekt ... Eventuell irgendwas beim node Update oder der gleichen schief gelaufen.
                                            Sichere mal bitte über die Pfeilbutton in den Haupteinstellungen von Backitup deine Backitup Config und deinstalliere mal Backitup in den Instanzen und im Anschluss auch im Tab Adapter deinstallieren.
                                            Starte danach mal dein System neu und installiere Backitup wieder.
                                            Danach kannst du deine Config über die Pfeilbutton wieder zurückschieben.
                                            backitup
                                            3320
