    4. BackItUp - Fehler in Datenpunkt History
    SOLVED BackItUp - Fehler in Datenpunkt History
    • simatec
      simatec Developer Most Active @horos73 last edited by
      @horos73
      Nein bitte den Wert des Objektes posten. Ich sehe den im Screenshot nur abgeschnitten.
      horos73 1 Reply Last reply Reply Quote 0
        Coffeelover last edited by
        @horos73 Habe gerade iobroker komplett neu gestartet. Backup läuft wieder durch. Jetzt habe ich im Objekt lines folgenden Eintrag:
        [DEBUG] [history] start with {"type":"creator","time":"02:10","debugging":true,"everyXDays":"1","nameSuffix":"iobrokerRevival","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.188.xx","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"/backupDir/minimal","user":"Homee","pass":"****","port":"21"},"dropbox":{"enabled":true,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.188.xx","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"/backupDir/minimal","user":"Homee","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"ftp","mount":"192.168.188.xx","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":true,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.188.xx","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"/backupDir/minimal","user":"Homee","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"ftp","mount":"192.168.188.xx","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"xxxx","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":true,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"media/usb/history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.188.xx","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"/backupDir/minimal","user":"Homee","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"ftp","mount":"192.168.188.xx","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:2xxx","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":true,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"15. Januar 2020 um 13:17 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"Raimund","onlyError":false,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
        Das sieht ziemlich ähnlich zu Holger aus.
        • simatec
          @horos73 sagte in BackItUp - Fehler in Datenpunkt History:
          @simatec Hmm, nutze history nicht - zumindest nicht bewusst. Wo stelle ich das ein?
          In den Haupteinstellungen von backitup
          • horos73
            horos73 @simatec last edited by
            @simatec
            [DEBUG] [history] start with {"type":"creator","time":"06:00","debugging":true,"everyXDays":"3","nameSuffix":"BackitUp_Backup","deleteBackupAfter":0,
            "ftp":{"enabled":true,"type":"storage","source":null,"host":"IP-Adresse-meines-NAS","debugging":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal",
            "dir":"ioBrokerBackups/StandardBU","dirMinimal":"ioBrokerBackups/StandardBU","user":"USERNAME","pass":"****","port":"85"},"dir":"/opt/iobroker",
            "redis":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"IP-Adresse-meines-NAS","debugging":true,"deleteOldBackup":false,
            "ownDir":true,"bkpType":"Minimal","dir":"ioBrokerBackups/StandardBU","dirMinimal":"ioBrokerBackups/StandardBU","user":"USERNAME","pass":"****","port":"85"},
            "cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":null,"mount":"IP-Adresse-meines-NAS","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup",
            "wakeOnLAN":false,"macAd":"XYZ","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/volume1/ioBrokerBackups",
            "dirMinimal":"volume1/USERNAME/ioBrokerBackups","user":"USERNAME","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,
            "accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":false,"type":"storage","source":null,
            "debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/var/lib/redis/dump.rdb"},
            "historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"IP-Adresse-meines-NAS","debugging":true,"deleteOldBackup":false,"ownDir":true,
            "bkpType":"Minimal","dir":"ioBrokerBackups/StandardBU","dirMinimal":"ioBrokerBackups/StandardBU","user":"USERNAME","pass":"****","port":"85"},"cifs":{"enabled":false,"mountType":"NFS",
            "type":"storage","source":null,"mount":"IP-Adresse-meines-NAS","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"XYZ",
            "wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/volume1/ioBrokerBackups","dirMinimal":"volume1/USERNAME/ioBrokerBackups",
            "user":"USERNAME","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,
            "bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****",
            "source":null,"host":"IP-Adresse-meines-NAS","debugging":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"ioBrokerBackups/StandardBU","dirMinimal":"ioBrokerBackups/StandardBU",
            "user":"USERNAME","pass":"****","port":"85"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":null,"mount":"IP-Adresse-meines-NAS","debugging":true,
            "fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"XYZ","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":false,"ownDir":false,
            "bkpType":"Minimal","dir":"/volume1/ioBrokerBackups","dirMinimal":"volume1/USERNAME/ioBrokerBackups","user":"USERNAME","pass":"****"},"dropbox":{"enabled":false,"type":"storage",
            "source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},
            "googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir",
            "dirMinimal":"/backupDir/minimal"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"15. Januar 2020 um 12:23 Uhr"},
            "telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"MeinName",
            "onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"email.0","NoticeType":"longEmailNotice",
            "emailReceiver":"Email@Adresse.ABC","emailSender":"Email@Adresse.ABC","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram",
            "type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
            Screenshot von den history Einstellungen des Adapters:
              Coffeelover @simatec last edited by
              @simatec Ich nutze History in den Einstellungen auch nicht. Die Anzahl steht auf Default 25.
              • horos73
                horos73 @Coffeelover last edited by horos73
                @Coffeelover @simatec bei mir auch auf 25/default
                PS: muss mich bis heute Abend hier ausklinken (ein bissel arbeiten 😉
                Bis später!
                • simatec
                  @Coffeelover sagte in BackItUp - Fehler in Datenpunkt History:
                  Welchen js-controller habt ihr laufen?
                  Nutzt ihr backitup im Compact-Modus?
                  Probiert mal die Anzahl der Historydaten in den Einstellungen auf 20 zu setzen und lasst mal bitte den Installer Fix (siehe Signatur) drüberlaufen.
                    Coffeelover @simatec last edited by Coffeelover
                    @simatec jscontroller 2.2.7.
                    Was ist der compact mode?
                    Fix lasse ich gleich mal laufen und dann Backup mit 20 bei History.
                    Update:
                    • Habe 20 bei Anzahl der History-Einträge eingetragen (sonst nichts verändert)
                    • Habe den Fix durchlaufen lassen
                    • Backup wird weiterhin durchgeführt (file liegt auf NAS ab), DP backitup.0.history.iobrokerSuccess steht auf false, DP backitup.0.history.iobrokerLastTime zeigt "error: 15. Januar 2020 um 13:59 Uhr"
                    Gibt es eigentlich einen Grund, warum das Full-Backup nicht mehr vorhanden ist?
                    • simatec
                      simatec Developer Most Active @Coffeelover last edited by
                      @Coffeelover
                      Irgendwas ist da an eurem System nicht korrekt ... Eventuell irgendwas beim node Update oder der gleichen schief gelaufen.
                      Sichere mal bitte über die Pfeilbutton in den Haupteinstellungen von Backitup deine Backitup Config und deinstalliere mal Backitup in den Instanzen und im Anschluss auch im Tab Adapter deinstallieren.
                      Starte danach mal dein System neu und installiere Backitup wieder.
                      Danach kannst du deine Config über die Pfeilbutton wieder zurückschieben.
                        @simatec Ich konnte zwar die Config nicht wieder einspielen, aber ich bin ansonsten deinem Vorschlag gefolgt. Habe den Adapter aus GIT installiert, eine Instanz mit den Einstellungen gefüttert und jetzt passt es tatsächlich.
                        Bleibt nur die Frage: Warum ist das Full-Backup entfallen?
                        Vielen Dank
                          Homoran Global Moderator Administrators @Coffeelover last edited by
                          weil es nur Probleme durch Falschnutzung machte.
                          Das ioBroker Backup ist genauso vollständig
                          • horos73
                            Schönen Abend,
                            @Coffeelover: freut mich, dass @simatec 's Lösung bei Dir geholfen hat, bei mir leider nicht.
                            Aber, mein System läuft noch mit js-controller 1.4.2 und Node 8.12.0 . Ich habe vor knapp zwei Wochen zwar das Upgrade gewagt, jedoch ließ sich der Lightify-Adapter nicht mehr zur "Farbe Grün" bewegen, da habe ich wenigstens 1 weiteren Leidensgenossen: Osram Lightyfy Adapter Problem
                            Ich konnte mit einem Snapshot zum Glück wieder zurück, habe - auch mangels Zeit - das Projekt "Upgrade" erstmal liegen lassen. Wenn ich in den nächsten Tagen Zeit finde, versuche ich es mit einer neuen VM und einer frischen, aktuellen Installation und einem Minimal-Backup. Vielleicht lösen sich beide Probleme dann...
                            (mein Setup läuft so seit Dez. 2018, noch mithilfe veraltete Installationsanleitungen eingerichtet.)
                            Ich frage mich aber, ob die aktuell erstellten minimal-Backups in Ordnung sind. Wie kann ich (mehr oder weniger Anfänger) das überprüfen, @simatec @Homoran ?
                            Schöne Grüße und danke für Eure Unterstützung!
                            Homoran simatec 2 Replies Last reply Reply Quote 0
                              Homoran Global Moderator Administrators @horos73 last edited by
                              zum Beispiel, wenn du es:
                              versuchst.
                              Ansonsten ist das Backup eine gepackte Datei, die du z.B. mit 7zip öffnen kannst.
                              Darin befindet sich eine backup-json, die alle Konfigurationen deiner Instanzen und deines Systems enthält, soiwe die vis-views.json mit allen views
                              • horos73
                                horos73 @Homoran last edited by
                                @Homoran Danke, Rainer für die Erläuterung (hab's auch direkt mit der exportierten Config des Adapters und Notepad++ ausprobiert 😁 .
                                Ich hab morgen frei und werde das Projekt "Pimp my Iobroker" in Angriff nehmen. Mal sehen, wie's wird. Ich melde mich dann hier nochmal.
                                Einen schönen Abend wünsche ich Euch allen!
                                • simatec
                                  Schönen Abend,
                                  Hast du auch Instanz und den Adapter gelöscht?
                                  Nur die Instanz reicht nicht aus
                                  • horos73
                                    @simatec Sch...ade, nein ich Nasenbär hatte nur die Instanz gelöscht, habs nun richtig gemacht, aber der Fehler bleibt dennoch bei beiden Backup-Varianten bestehen.
                                    Ich mach morgen ne neue VM und seh mal, ob sich was ändert..
                                    • flenny
                                      flenny last edited by flenny
                                      @simatec Für was steht eigentlich "Anzahl der History-Einträge" genau? Was schreib ich da rein, wenn ich meinen kompletten history.0 Ordner sichern will? Vielen Dank für deine tolle Arbeit! 👍
                                      Und was passiert hier genau?
                                      (677) sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"{meine Telegram ID}":"{mein Telegram-Name}"}
                                      Eine Nachricht in den Telegram Bot erhalte ich nicht.
                                      • simatec
                                        simatec Developer Most Active @flenny last edited by
                                        @Oliver-Gut
                                        Das hat nichts mit dem Backup zu tun.
                                        Die history Einträge sind für deine VIS.
                                        Dort kannst du einstellen, wie viele Einträge der letzten Backups in deiner VIS angezeigt werden sollen.
                                        • horos73
                                          @simatec
                                          Hallo, entschuldige die späte Rückmeldung, aber ich komme nur nach und nach dazu, die neue VM einzurichten. Ich habe jetzt auf debian10-Basis iobroker neu installiert (JS-Controller 2.1.1, Node.js 10.18.1, NPM 6.13.4). Es sind nur wenige Adapter installiert (Backitup, email Telegram, Zigbee und der Lightify, der aber rot bleibt). Auch in dieser frischen und aktuellen Installation steht nach einem per Hand angestoßenen Backitup-Backup die weiter oben im Thread erwähnte "error" - Meldung. Das Backup landet dennoch brav auf dem NAS. Ich habe heute schon mehrfach den Fixer (mit Erfolgsmeldung) durchlaufen lassen. Achso, ich habe nach der Backitup-Installation (Version 1.3.6 übrigens) die Konfig vom alten System importiert und nur die Backup-Pfade verändert. History steht auf 15.
                                          Könnte sich durch den Konfig-Import der Fehler von der alten auf die neue Installation übertragen haben?
                                          • simatec
                                            @horos73
                                            Lösche mal Backitup in den Instanzen und in den Adaptern.
                                            Danach installiere es mal komplett neu ohne die alte Config.
                                            Ich kann den Fehler leider nicht reproduzieren
                                            backitup
                                            3318
