    5. Blockly Script für Gartenbewässerung
      Aidan last edited by
      Hoi,
      Ventile habe ich eingefügt
        <variables>
          <variable type="" id="K=%c_0B}iX@a)yyvhTjm">aktive_ventile</variable>
        </variables>
        <block type="on_ext" id="WJT!M.5iMM(K/%YaLDWc" x="37" y="-13">
          <mutation items="6"></mutation>
          <value name="OID0">
            <shadow type="field_oid" id="i`YTdsA5J4~IxKs@ya14">
              <field name="oid">hm-rpc.1.PEQ0506191.2.STATE</field>
          <value name="OID1">
            <shadow type="field_oid" id="[2a%d;;aM4b5=sTPfPnK">
              <field name="oid">hm-rpc.1.PEQ0506191.3.STATE</field>
          <value name="OID2">
            <shadow type="field_oid" id="0bXn71k|q5D%*[W#M$zP">
              <field name="oid">hm-rpc.1.PEQ0506191.4.STATE</field>
          <value name="OID3">
            <shadow type="field_oid" id="B5n8INn;,H.ugUQ,=cv{">
              <field name="oid">hm-rpc.1.PEQ0506191.5.STATE</field>
          <value name="OID4">
            <shadow type="field_oid" id="R==OsbjQ3xkOJK3lp$J`">
              <field name="oid">hm-rpc.1.PEQ0506191.6.STATE</field>
          <value name="OID5">
            <shadow type="field_oid" id="Jyp,uUZVH}aNauWD_fP2">
              <field name="oid">hm-rpc.1.PEQ0506191.7.STATE</field>
            <block type="controls_if" id=";]qP-e}iXX}tUsLwqDfw">
                <block type="logic_compare" id="%a]jy|ZWVJWQr{1=lw:o">
                  <field name="OP">EQ</field>
                    <block type="get_value" id="v94ZPj+8|J[e2#?igxYX">
                      <field name="OID">hm-rpc.1.PEQ0506191.2.STATE</field>
                    <block type="logic_boolean" id="hs+/E99If37Qw/d]MLJ7">
                <block type="math_change" id="hYW}*EMY*`urX1_kV%jw">
                  <field name="VAR" id="K=%c_0B}iX@a)yyvhTjm" variabletype="">aktive_ventile</field>
                  <value name="DELTA">
                    <shadow type="math_number" id="N+v8T!wM,DSXakio`}%/">
                      <field name="NUM">1</field>
                <block type="controls_if" id="f%3zwbK#Gn}}5JZE;i]_">
                    <block type="logic_compare" id="6$2Ni[R}xX,CsL1/=kZ[">
                        <block type="get_value" id="2G[Kub_uTY^@;Xl^DTHB">
                          <field name="OID">hm-rpc.1.PEQ0506191.3.STATE</field>
                        <block type="logic_boolean" id="?xP|wr{?72j=N}#PkG-:">
                    <block type="math_change" id="6}ERfIq$sE:VC6,nn)zQ">
                        <shadow type="math_number" id="/ET(H^tJZn~()|QnVi%z">
                    <block type="controls_if" id="%8/4IftD+7ULjT#iTX~u">
                        <block type="logic_compare" id="son/Fa~[7SihrLufo1@F">
                            <block type="get_value" id="R$naA_`5ux9ima6Y)-qA">
                              <field name="OID">hm-rpc.1.PEQ0506191.4.STATE</field>
                            <block type="logic_boolean" id="#,f~[Q_y?kx_$!PwK*wi">
                        <block type="math_change" id="-]:-RbDZRTi.hre]5Z8S">
                            <shadow type="math_number" id="mGCvV(MHtHzr`#CEQr5H">
                        <block type="controls_if" id="BiEk91}$.Q_5V#XbB|DM">
                            <block type="logic_compare" id="USN`rlzsyESKeizx/gwt">
                                <block type="get_value" id="yOJ,WL-deI8Kp~=jMOvr">
                                  <field name="OID">hm-rpc.1.PEQ0506191.5.STATE</field>
                                <block type="logic_boolean" id="pVFqcJ*@GdD6e%F~pmaO">
                            <block type="math_change" id="|`O*^!znkJJKJb~8AS6P">
                                <shadow type="math_number" id="biBVsJSlm5Kr~7-(B:2a">
                            <block type="controls_if" id="DtOy*K@RX2{aD?:(HBmC">
                                <block type="logic_compare" id="L4K)g)B%A!WYHRP9$Nhf">
                                    <block type="get_value" id="c:6^LsT!liF~bfdrMhay">
                                      <field name="OID">hm-rpc.1.PEQ0506191.6.STATE</field>
                                    <block type="logic_boolean" id="=4eC}R/QKE[T?l+GmbW}">
                                <block type="math_change" id="hv89HK-8XnUZ{}Dz;SP^">
                                    <shadow type="math_number" id="RcG0Z{;X}v7^a$J-b.Os">
                                <block type="controls_if" id="F/rF/2`GT:.l96KQ5SN$">
                                    <block type="logic_compare" id="0alr6`x/eUcaT63xp-tl">
                                        <block type="get_value" id="VI8;=b%cyQ9)rLg5.tK)">
                                          <field name="OID">hm-rpc.1.PEQ0506191.7.STATE</field>
                                        <block type="logic_boolean" id="sbasj+%b*k5TTH%F?(}J">
                                    <block type="math_change" id="S(CE!duDkCxVgo4JHE?_">
                                        <shadow type="math_number" id="E4:)QCB7mjxU+=lQ,7IH">
                                    <block type="update" id="Wo]7[OhCt^?4i!QIJg0N">
                                      <field name="OID">javascript.0.Eigene_Datenpunkte.Garten.Gartenbewässerung aktive Ventile</field>
                                        <block type="variables_get" id="0;FJi[1?rS-TDxM+C5[k">
      • dslraser
        dslraser Forum Testing Most Active @Aidan last edited by dslraser
        @Aidan
        von diesen Steuerbausteinen habe ich auch nur Dein Ventil 1.
        Mach mal alle 6 und stelle den Export davon hier rein.
        <block xmlns="http://www.w3.org/1999/xhtml" type="control" id="{8Y`Sriz(L.,p7L3D1A!" x="164.0329132080078" y="404">
         <mutation delay_input="true"></mutation>
         <field name="DELAY_MS">1000</field>
         <field name="UNIT">ms</field>
           <block type="logic_boolean" id="Kj{zF=cNfh=+7aptKrvr">
        Oder Du fügst die fehlenden hier über all selbst ein.
        https://forum.iobroker.net/post/358066
        • dslraser
          @Aidan
          hier ist alles drinn. Du musst nur noch die deaktivierten Ventile "reinklicken" und auswählen. Danach noch die Bausteine aktivieren. (alte Datenpunkte vor dem Blocklystart nochmal löschen. Dann Blockly starten und ausprobieren.
          Bewaesserung-Aidan.txt
          Edit: ich hatte noch was vergessen, jetzt ist es im Export drinn. Falls Du es schon importiert hattest, dann mußt Du nur ganz unten im letzten Block noch das einfügen.
          setze aktive_ventile auf 0 (hatte ich vergessen, ist jetzt aber drinn)
            du bist schnell, habe gerade die text datei importiert und mir Ventile1 Block ausgedruckt-)
            Wollte gerade die Ventile einbauen.
            Ich probiere es mal selber, ob ich es hin bekomme-)
            Ventil 1 funzt aufjedenfall.
            Sollte es nicht klappen, dann sag ich es-)
              Aidan @dslraser last edited by
              @dslraser said in Blockly Script für Gartenbewässerung:
                <block type="comment" id="r{v_MnGsGVAG=[-ib%So" x="413" y="187">
                  <field name="COMMENT">Pumpe</field>
                    <block type="control" id="F}RoJ?NQI),YCv7/CIx.">
                      <field name="OID">hm-rpc.1.PEQ0506191.1.STATE</field>
                        <block type="logic_boolean" id="A+F3QWsG=^V@]@Y!1mVz">
                        <block type="comment" id="`GBsJH-.l9U*b{=/]i|*">
                          <field name="COMMENT">Ventil1</field>
                            <block type="control" id="iuC.K5L+33O2AB8L?18D">
                                <block type="logic_boolean" id="]6JWch55iN:HVQ,h/iZJ">
                                <block type="comment" id="UiZBjs]=4oIAwwVC7_C4">
                                  <field name="COMMENT">Ventil2</field>
                                    <block type="control" id="Lv-mkTSl?SnZd~s+7D)H">
                                        <block type="logic_boolean" id="i?A/tqWdACd1RZ4,2Q4|">
                                        <block type="comment" id="Y([oAz:{s4o*MWs.nJHr">
                                          <field name="COMMENT">Ventil3</field>
                                            <block type="control" id="w@fmcwxKhjj_S-#D`j8G">
                                                <block type="logic_boolean" id="lR=_SSrAv5xbdDnBEe!A">
                                                <block type="comment" id="7`x!sL,qSq06vC~;oH4n">
                                                  <field name="COMMENT">Ventil4</field>
                                                    <block type="control" id="E4DC9n5OckSjsy1rZi?w">
                                                        <block type="logic_boolean" id="V1|8)[E.!O%}T21FqQl)">
                                                        <block type="comment" id="Q^cmp*GWbV8e(t@Az|nG">
                                                          <field name="COMMENT">Ventil5</field>
                                                            <block type="control" id="bz}kjjpR2tlJSj{e}({_">
        <block type="logic_boolean" id="j]HuVMN@||,Bgb}Z?hF_">
        <block type="comment" id="Li%rhoiVT=XF+]HV.Bdt">
        <field name="COMMENT">Ventil6</field>
        <block type="control" id="kz2z+:k:(Bw(q*d$%^*x">
        <block type="logic_boolean" id="K(gHYY9um#x#99_KRo5j">
              Hier meine Ventile
              • dslraser
                @Aidan
                Blockly komplett
                  Habe mal die ersten beiden Ventile eingebaut,
                  gleiches Symtom Kanal1 an, dann Kanal2 an. Kanal 1 aus Pumpe mit aus Ventil 2 bleibt offen.
                  Hätte nicht der Datenpunkt "aktive Ventile" hochzählen müssen? Ich hätte da eine "2" erwartet.
                  dslraser 3 Replies Last reply Reply Quote 0
                  • dslraser
                    @Aidan sagte in Blockly Script für Gartenbewässerung:
                    Was meinst Du mit gleiches Symtom ?
                    ja, der sollte eigentlich hochzählen. Browser Fenster mal aktualisiert ?
                    Hattest Du vor dem Import und Blocklystart auch mal alles gelöscht ?
                    Einen Post über Deinem habe ich das Blockly komplett fertig zusammengesteckt.
                    • dslraser
                      @Aidan
                      bei mir sieht es so aus
                        ich hatte 2 Skripte angelegt, einmal für "aktive Ventile" und für die Steuerung.
                        zusammengefügt, dann ging es ..
                        ich nehme mal das komplette von Dir und gebe rückinfo.
                        • dslraser
                          ah, jetzt verstehe ich was Du meinst. Das passiert wahrscheinlich weil nicht hochgezählt wurde. Deshalb wollte ich das verwenden. Also, solange noch Ventile aktiv sind, soll die Pumpe nicht ausgeschaltet werden. Aber vielleicht ist auch noch irgendwo ein Denkfehler drinn...
                            Bei mir fehlt das Ventil 1 bei der kompletten Version
                            der Blockly startet ab Ventil2
                            • dslraser
                              ähm, wirklich ? oder ist das blos zu geklappt ?
                                äh, ok wusste nicht das mach auch zu klappen kann.
                                doch ist drin
                                • dslraser
                                  doch ist drin
                                    Datenpunkte gelöscht, das komplette Blockly eingefügt.
                                    Zum Test Kanal 1 und 2 in Vis eingebunden.
                                    Kanal 1 an = Pumpe an + Ventil auf
                                    Kanal2 an = Ventil auf
                                    Kanal1 zu = Ventil zu
                                    Kanal2 zu = Ventil zu
                                    Pumpe bleibt an
                                    • dslraser
                                      @Aidan
                                      hm..., dann ist noch irgendwo ein Fehler drinn, oder die Verzögerung ist zu kurz.
                                        Schalte ich Kanal1 nochmal an und wieder aus, geht die Pumpe auch aus
                                        dslraser A 2 Replies Last reply Reply Quote 0
                                          Schalte ich Kanal2 an und aus, bleibt die Pumpe an
                                          • dslraser
                                            @Aidan
                                            ich schau nochmal durch, aber vielleicht siehst Du auch was. Das Prinzip ist aber rüber gekommen, oder ?
                                            6434
