    4. FritzBox WLAN Passwort ändern
      chka last edited by Negalein
      Habe es hinbekommen
      // https://www.npmjs.com/package/qr-image
      var MySSID          = "GastNetz";  //  SSID Name
      var MyCrypt         = "WPA2";                //  [WEP|WPA|WPA2]
      var MyVisibility    = "n";                   //  Hidden SSID?
      var cronStr         = "* 1 * * *";           // Script wird jeden Tag um 03:01 Ausgeführt
      var idQRZiel = "javascript.0.QR-Code.Gast";  // Zieldatenpunkt für QR-Code
      var IdGPasswd = "node-red.0.sophos"; /*wlanGuestPassword*/
      if(MyVisibility == "y") {
          var MyHidden="H:true";
      else {
          MyHidden="";
      createState(idQRZiel, "", {
           name: 'QR-Code für Gastpasswort',
           desc: 'QR-Code für Gastpasswort',
           type: 'string',
           role: 'info'
      createQRcode();
      function createQRcode() {
          var qr = require('qr-image');
         var pass = getState(IdGPasswd).val;
               var svg_string = qr.imageSync('WIFI:S:'+MySSID+';T:'+MyCrypt+';P:'+pass+';'+MyHidden+';', { type: 'svg' });
          setState(idQRZiel, svg_string);
           log(svg_string);
          //setState(IdGPasswd, NewPasswd);
      // regelmässige Wiederholungen
      schedule(cronStr, createQRcode);
      Als Widget musste ich aber auchh ein anderes nehmen:
      [{"tpl":"tplValueStringRaw","data":{"hm_id":"80101","digits":"","factor":1,"min":0,"max":1,"step":0.01,"visibility-cond":"==","visibility-val":1,"oid":"javascript.0.QR-Code.Gast","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"978px","top":"183px","width":"152px","height":"153px","border":"2px solid rgb(255, 255, 255)","border-radius":"5px","z-index":"0","color":"","background":"#ffffff"},"widgetSet":"basic"}]
        jwerlsdf @a200 last edited by
        @a200
        ich habe noch ein paar Verständnisfragen:
        ich habe bereits Javascript als Adapter installiert und dort wie auf dem Bild qr-image hinzugefügt.
        Als nächstes soll ich ja das Javascript erstellen. Jetzt kommen meine Fragen:
        1. Wo genau muss ich das Javascript einfügen?
        2. Muss ich im Javascript noch irgendetwas ersetzen? z.B. MySSID = "Mein GAST WLAN Zugang" --> in die tatsächlich von mir in meiner Fritzbox hinterlegten Namen?
        3. Ich habe den tr-064-community-Adapter: reicht es, wenn ich im script dann so schreibe? --> IdGPasswd = "tr-064-community.0.states.wlanGuestPassword"; /wlanGuestPassword/
        4. Bei meiner Frage 3 steht "wlanGuestPassword" --> muss dieses ersetzt werden mit dem WLan2 Passwort, welches in der Fritzbox hinterlegt ist?
        Ich würde mich sehr freuen, wenn mir jemand weiterhelfen könnte 🙂
        a200 1 Reply Last reply Reply Quote 0
        • a200
          a200 @jwerlsdf last edited by
          @jwerlsdf sagte in FritzBox WLAN Passwort ändern:
          @a200
          Du Brauchst den "Script Engine" Adapter. Dort muss es muss unter Scripte erstellt und gestartet werden.
          1. Muss ich im Javascript noch irgendetwas ersetzen? z.B. MySSID = "Mein GAST WLAN Zugang" --> in die tatsächlich von mir in meiner Fritzbox hinterlegten Namen?
          Ja. Der QR-Code besteht aus den Namen des SSID, den Typ der Verschlüsselung, dem Passwort selbst und noch ein paar anderen Infos. Deshalb musst dort dein SSID-Name eingetragen werden.
          1. Ich habe den tr-064-community-Adapter: reicht es, wenn ich im script dann so schreibe? --> IdGPasswd = "tr-064-community.0.states.wlanGuestPassword"; /wlanGuestPassword/
          Wahrscheinlich ja. Nur nicht vergessen die Funktion in der Zeile 34 auch zu aktivieren:
          ist:
          soll
          1. Bei meiner Frage 3 steht "wlanGuestPassword" --> muss dieses ersetzt werden mit dem WLan2 Passwort, welches in der Fritzbox hinterlegt ist?
          Ich verstehe deine Frage nicht ganz. "/wlanGuestPassword/" ist nur ein Kommentar. und das davor der Verweis, wo dein Passwort gespeichert ist. Dort musst du nichts ändern.
          Aber bitte doch. 😉
            @a200 said in FritzBox WLAN Passwort ändern:
            Vielen Dank für deine Antwort!
            Ich habe jetzt folgendes gemacht:
            Javascript; Neues Skript hinzugefügt:
            Mappe: root-Verzeichnis
            Das Skript habe ich dann eingefügt mit folgenden Änderungen:
            Zeile 3 MySSID --> in den namen meines GastWLans geändert
            Zeile 4 var MyCrypt --> WPA2
            Zeile 10: var IdGPasswd = "tr-064-community.0.states.wlanGuestPassword"; /wlanGuestPassword/
            Das wars. Wenn ich das Skript jetzt aktiviere, dann bekomme ich folgenden Fehler:
            error javascript.0 (8405) script.js.qr-image: script.js.qr-image:34
            error javascript.0 (8405) at createQRcode (script.js.qr-image:34:25)
            error javascript.0 (8405) at script.js.qr-image:26:1
            Bei "Objekte" -- "tr-064-community.0" --> "States" --> "wlanGuestPassword" dort auf bearbeiten geklickt und bei "Nativ" "func" das passwort aus der Fritzbox hinterlegt.
            Bei "Objekte" -- "tr-064-community.0" --> "States" --> "wlanGuest" dort auf bearbeiten geklickt und bei "Nativ" "func" den SSID Name hinterlegt.
            Aber wie gesagt es geht leider noch nicht...
            Glasfaser 2 Replies Last reply Reply Quote 0
            • Glasfaser
              Glasfaser @jwerlsdf last edited by
              @jwerlsdf
              Hier im Adapter Javascript , qr-image eintragen !?
                jwerlsdf @Glasfaser last edited by
                @Glasfaser
                ja habe ich gemacht
                • Glasfaser
                  @jwerlsdf
                  Zeige mal dein Script !
                  hier reinpacken !!
                    jwerlsdf @Glasfaser last edited by Negalein
                    @Glasfaser
                    var MySSID          = "MTL Gastzugang";  //  SSID Name
                    var IdGPasswd = "tr-064-community.0.states.wlanGuestPassword"; /*wlanGuestPassword*/
                    else {
                        MyHidden="";
                         type: 'string',
                         role: 'info'
                    createQRcode();
                         log(svg_string);
                    sigi234 Glasfaser 2 Replies Last reply Reply Quote 0
                      sigi234 Forum Testing Most Active @jwerlsdf last edited by
                      @jwerlsdf
                      Bitte benutzt die Code Tags Funktion -> </>
                      Hier gehts zur Hilfe.
                      • Glasfaser
                        @jwerlsdf
                        Du hast ein paar Fehler eingebaut .
                        Nimm das :
                        var cronStr         = "3 1 * * *"           // Script wird jeden Tag um 01:03 Ausgeführt
                        else {
                           MyHidden="";
                            type: 'string',
                            role: 'value'
                        function randomString(length) {         // Methode zur Erstellung eines Random-Passworts kann angepasst werden
                           return Math.round((Math.pow(36, length + 1) - Math.random() * Math.pow(36, length))).toString(36).slice(1);
                           var NewPasswd = randomString(16);       // 16 Stelliges Passwort
                           var svg_string = qr.imageSync('WIFI:S:'+MySSID+';T:'+MyCrypt+';P:'+NewPasswd+';'+MyHidden+';', { type: 'svg' });
                           console.log('+++ Wlan Gast QR-Code neu erstellt +++');
                        • Glasfaser
                          Hast du die Objekteeigenschaften geändert , dort bitte nichts verändern !??
                          Lösche bitte diese beiden Datenpunkte sicherheitshalber und lasse sie vom tr.064 Adapter neu anlegen .
                            @Glasfaser Oh großer Meister!!!! Vielen, vielen Dank!!! Es geht nun!!!! 🙂
                            • GuLi69
                              GuLi69 last edited by GuLi69
                              Sorry ... erledigt
                              • Glasfaser
                                Glasfaser @GuLi69 last edited by
                                @GuLi69
                                Nimm mal das …
                                [{"tpl":"tplValueStringRaw","data":{"hm_id":"80101","digits":"","factor":1,"min":0,"max":1,"step":0.01,"visibility-cond":"==","visibility-val":1,"oid":"javascript.0.QR-Code.Gast","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"156px","top":"640px","width":"125px","height":"125px","border":"2px solid rgb(255, 255, 255)","border-radius":"5px","z-index":"44","color":"","background":"#ffffff","font-family":"Jura-DemiBold"},"widgetSet":"basic"}]
                                GuLi69 1 Reply Last reply Reply Quote 0
                                • GuLi69
                                  GuLi69 @Glasfaser last edited by
                                  @Glasfaser
                                  Sorry wo würde ich diesen Code einfügen?
                                  • Glasfaser
                                    @GuLi69
                                    • GuLi69
                                      @Glasfaser
                                      PERFEKT !!!
                                      VIELEN DANK Glasfaser !!!
                                      VG
                                      Günter
                                      • jolic
                                        jolic last edited by jolic
                                        Hi, habe hier was kurioses gefunden, nichts tragisches 😉
                                        Nutze das Script seit langem und lasse alle 24h das WLAN Passwort für Gast ändern.
                                        Nur bei einem Neustart des Raspi zickt das Script etwas.
                                        Das Passwort steht wie gehabt als Wert im Objekt "tr-064.0.states.wlanGuestPassword".
                                        Wenn dann das Script per cronjob ein neues Passwort generiert, wird der Wert gelöscht und erst nach dem nächsten Durchlauf (bei mir also 24h) wieder eingetragen. Dann funktioniert alles wieder so wie es soll und alle 24h wird ein neues Passwort generiert und als Wert dort eingetragen.
                                        Im Log sehe ich kein Fehler oder Hinweis warum dieser Wert gelöscht wird.
                                        Das ist nichts tragisches, da der QR-Code immer richtig erstellt wird. Benutze den Wert zur Kontrolle und für Gäste die den QR nicht scannen können.
                                        Frage: Kann das jemand nachvollziehen?
                                        Evtl. liegt es an der Fritz Labor Version. Diese benötige ich dringend wegen der SMB2+3 Unterstützung.
                                        Meine derzeitige Konfiguration:
                                        • Raspberry Pi 4 (BCM2835) mit Linux Kernel 4.19.118
                                        • ioBroker.admin 4.1.1
                                        • Node.js: v12.18.1
                                        • NPM: 6.14.5
                                        • TR-064 Adapter 4.0.8
                                        • FitzBox 7490 mit Labor Version: 07.19-79773
                                        // Quelle:
                                        // https://forum.iobroker.net/topic/4574/fritzbox-wlan-passwort-%C3%A4ndern/49
                                        var MySSID          = "Gast24h";                            // SSID Name
                                        var MyCrypt         = "WPA2 + WPA3";                        // [WEP|WPA|WPA2|WPA3]
                                        var cronStr         = "* 2 * * *"                           // Script wird jeden Tag um 2 Uhr ausgeführt
                                        //var cronStr         = "* * * * *"                        // jede Minute, nur zum Testen!
                                        var IdGPasswd = "tr-064.0.states.wlanGuestPassword";              // wlanGuestPassword
                                        else {
                                           MyHidden="";
                                            type: 'string',
                                            role: 'value'
                                           var NewPasswd = randomString(10);   // 10 Stelliges Passwort
                                           console.log('WLAN Gast QR-Code neu erstellt: ' + NewPasswd);
                                        jolic
                                          Chrunchy @jolic last edited by
                                          @jolic Ich vermute es liegt hier beim Neustart ein Timing-Problem vor.
                                          Ich hatte ähnliches bei einem Script, was mir beim Neustart vom iobrkoer Lichter eingeschaltet hat.
                                          Ich habe es dadurch gelöst, dass ich dem Script einen Timeout von 1 Minute voran gestellt habe, welcher nur beim ersten durchlauf, also beim Starten des Scripts greift.
                                          Damit hatten dann alle Adapter die Chance sauber zu laufen, bevor der Javascript-Adapter die ganzen Scripte ausgeführt hat.
                                          Vielleicht hilft es ja auch bei dir.
                                          • jolic
                                            @Chrunchy: Danke für deinen Hinweis. Tipps und Hinweise sind immer willkommen.
                                            Denke nicht das es ein Timeout Problem ist. Sorry, vielleicht habe ich mich etwas unklar ausgedrückt.
                                            • Script wird genau nach Plan ausgeführt (habe auch andere Zeiten probiert)
                                            • zur Kontrolle logge ich den Wert (wurde korrekt generiert), steht aber erst am 2ten Tag in "tr-064.0.states.wlanGuestPassword" als Wert
                                            • die Fritz nimmt immer das neue Passwort an und der QR-Code stimmt auch immer ab dem ersten Tag (so wie es sein soll)
                                            Das rennt Wochen lang so, bis ich ein Kernel Update mache und den Raspi neu starte (sudo restart). Sonst wäre mir das nicht aufgefallen.
                                            Siehe Bild, der Wert wurde um 9 Uhr von "javascript.0/admin" ab dem 2 Tag korrekt eingetragen
                                            Wie schon erwähnt, nichts tragisches, kann damit gut leben. Würde mich dennoch interessieren was da falsch rennt.
                                            Werde das weiter beobachten... 👁
                                            jolic
                                            jolic 1 Reply Last reply Reply Quote 0
                                            61
                                            9929
