    4. Eurotronic Spirit ZigBee
      Hoffiheller @Freaknet last edited by
      @Freaknet
      meine bwm´s reagieren sehr gut aktuell, habe die Ikea bwm´s
        Freaknet last edited by Freaknet
        Also bei mir gehts es wieder nicht, wie gestern 😞
        Der Adapter wird grün und nach kurzer Zeit geht er rot und dann wieder grün...
        Update findet nicht statt bei Statuswechel. Erst wenn ich den Adapter neu starte setzt er das last updated auf den letzten Wert.
        Hier mal die Logs
        deconz.0	2020-01-15 22:17:11.306	debug	getGroupScenes for Groups.undefined: undefined
        deconz.0	2020-01-15 22:17:11.305	debug	getGroupScenes for Groups.undefined: undefined
        deconz.0	2020-01-15 22:17:11.305	debug	getGroupAttributes: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"b34fb912577592f63236eac4bf9c4499","
        deconz.0	2020-01-15 22:17:10.957	debug	getGroupScenes for Groups.6: []
        deconz.0	2020-01-15 22:17:10.957	debug	getGroupScenes for Groups.5: []
        deconz.0	2020-01-15 22:17:10.957	debug	getGroupScenes for Groups.2: []
        deconz.0	2020-01-15 22:17:10.957	debug	getDevices: {"statusCode":404,"body":"[]","headers":{"access-control-allow-origin":"*","content-type":"application/json; charset=utf-8","content-length":"2"},"request":{"uri":{"protocol":"http:","slas
        deconz.0	2020-01-15 22:17:10.957	debug	getAllGroups: {"2":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"b34fb912577592f63236eac4bf9c4499","i
        deconz.0	2020-01-15 22:17:10.955	debug	getAllSensors: {"10":{"config":{"battery":98,"duration":60,"on":true,"reachable":true,"temperature":2600},"ep":1,"etag":"4fe45f2d3b5ef6db611cc10dcd896651","manufacturername":"LUMI","modelid":"lumi.sen
        deconz.0	2020-01-15 22:17:10.451	debug	getAllLights: {"2":{"etag":"09ca9bad05dd1e4ca85da573af37f4c9","hascolor":false,"manufacturername":"OSRAM","modelid":"Plug 01","name":"Steckdose Schuppen","state":{"alert":"none","on":true,"reachable":
        deconz.0	2020-01-15 22:17:10.349	debug	API version: 1.16.0
        deconz.0	2020-01-15 22:17:10.014	info	starting. Version 1.2.3 in /opt/iobroker/node_modules/iobroker.deconz, node: v8.16.2
        deconz.0	2020-01-15 22:18:07.930	debug	NOTIFY {"protocol":"http","version":"1.1","method":"NOTIFY","path":"*","headers":{"host":"239.255.255.250:1900","cache-control":"max-age=100","location":"http://192.168.178.57:80/description.xml","ser
        deconz.0	2020-01-15 22:18:07.033	debug	Websocket message: {"config":{"battery":100,"on":true,"reachable":true,"temperature":2500},"e":"changed","id":"2","r":"sensors","t":"event","uniqueid":"00:15:8d:00:02:b0:50:a5-01-0006"}
        deconz.0	2020-01-15 22:18:07.032	debug	Websocket message: {"config":{"battery":100,"on":true,"reachable":true,"temperature":2500},"e":"changed","id":"2","r":"sensors","t":"event","uniqueid":"00:15:8d:00:02:b0:50:a5-01-0006"}
        deconz.0	2020-01-15 22:18:05.644	debug	Websocket message: {"e":"changed","id":"30","r":"sensors","state":{"lastupdated":"2020-01-15T21:18:05","temperature":2008},"t":"event","uniqueid":"00:15:8d:00:03:1b:04:c3-01-0402"}
        deconz.0	2020-01-15 22:18:05.611	debug	Websocket message: {"e":"changed","id":"32","r":"sensors","state":{"lastupdated":"2020-01-15T21:18:05","pressure":969},"t":"event","uniqueid":"00:15:8d:00:03:1b:04:c3-01-0403"}
        deconz.0	2020-01-15 22:18:05.610	debug	Websocket message: {"e":"changed","id":"32","r":"sensors","state":{"lastupdated":"2020-01-15T21:18:05","pressure":969},"t":"event","uniqueid":"00:15:8d:00:03:1b:04:c3-01-0403"}
        deconz.0	2020-01-15 22:18:05.597	debug	Websocket message: {"e":"changed","id":"31","r":"sensors","state":{"humidity":4620,"lastupdated":"2020-01-15T21:18:05"},"t":"event","uniqueid":"00:15:8d:00:03:1b:04:c3-01-0405"}
        deconz.0	2020-01-15 22:18:05.596	debug	Websocket message: {"e":"changed","id":"31","r":"sensors","state":{"humidity":4620,"lastupdated":"2020-01-15T21:18:05"},"t":"event","uniqueid":"00:15:8d:00:03:1b:04:c3-01-0405"}
        deconz.0	2020-01-15 22:17:56.766	debug	Websocket message: {"e":"changed","id":"19","r":"sensors","state":{"humidity":4096,"lastupdated":"2020-01-15T21:17:56"},"t":"event","uniqueid":"00:15:8d:00:02:b5:41:eb-01-0405"}
        deconz.0	2020-01-15 22:17:56.766	debug	Websocket message: {"config":{"battery":95,"offset":0,"on":true,"reachable":true},"e":"changed","id":"19","r":"sensors","t":"event","uniqueid":"00:15:8d:00:02:b5:41:eb-01-0405"}
        deconz.0	2020-01-15 22:17:56.766	debug	Websocket message: {"e":"changed","id":"18","r":"sensors","state":{"lastupdated":"2020-01-15T21:17:56","temperature":2210},"t":"event","uniqueid":"00:15:8d:00:02:b5:41:eb-01-0402"}
        deconz.0	2020-01-15 22:17:56.766	debug	Websocket message: {"config":{"battery":95,"offset":0,"on":true,"reachable":true},"e":"changed","id":"18","r":"sensors","t":"event","uniqueid":"00:15:8d:00:02:b5:41:eb-01-0402"}
        deconz.0	2020-01-15 22:17:56.766	debug	Websocket message: {"e":"changed","id":"20","r":"sensors","state":{"lastupdated":"2020-01-15T21:17:56","pressure":970},"t":"event","uniqueid":"00:15:8d:00:02:b5:41:eb-01-0403"}
        deconz.0	2020-01-15 22:17:56.766	debug	Websocket message: {"config":{"battery":95,"on":true,"reachable":true},"e":"changed","id":"20","r":"sensors","t":"event","uniqueid":"00:15:8d:00:02:b5:41:eb-01-0403"}
        deconz.0	2020-01-15 22:17:56.765	debug	Websocket message: {"e":"changed","id":"20","r":"sensors","state":{"lastupdated":"2020-01-15T21:17:56","pressure":970},"t":"event","uniqueid":"00:15:8d:00:02:b5:41:eb-01-0403"}
        deconz.0	2020-01-15 22:17:56.765	debug	Websocket message: {"config":{"battery":95,"on":true,"reachable":true},"e":"changed","id":"20","r":"sensors","t":"event","uniqueid":"00:15:8d:00:02:b5:41:eb-01-0403"}
        deconz.0	2020-01-15 22:17:53.944	debug	Websocket message: {"e":"changed","id":"10","r":"sensors","state":{"lastupdated":"2020-01-15T21:17:53","presence":false},"t":"event","uniqueid":"00:15:8d:00:03:65:7d:0d-01-0406"}
        deconz.0	2020-01-15 22:17:53.944	debug	Websocket message: {"config":{"battery":100,"duration":60,"on":true,"reachable":true,"temperature":2600},"e":"changed","id":"10","r":"sensors","t":"event","uniqueid":"00:15:8d:00:03:65:7d:0d-01-0406"}
        deconz.0	2020-01-15 22:17:53.944	debug	Websocket message: {"e":"changed","id":"9","r":"sensors","state":{"dark":true,"daylight":false,"lastupdated":"2020-01-15T21:17:53","lightlevel":0,"lux":0},"t":"event","uniqueid":"00:15:8d:00:03:65:7d:
        deconz.0	2020-01-15 22:17:53.943	debug	Websocket message: {"config":{"battery":100,"on":true,"reachable":true,"temperature":2600,"tholddark":12000,"tholdoffset":7000},"e":"changed","id":"9","r":"sensors","t":"event","uniqueid":"00:15:8d:00
        deconz.0	2020-01-15 22:17:53.943	debug	Websocket message: {"e":"changed","id":"10","r":"sensors","state":{"lastupdated":"2020-01-15T21:17:53","presence":false},"t":"event","uniqueid":"00:15:8d:00:03:65:7d:0d-01-0406"}
        deconz.0	2020-01-15 22:17:53.943	debug	Websocket message: {"config":{"battery":100,"duration":60,"on":true,"reachable":true,"temperature":2600},"e":"changed","id":"10","r":"sensors","t":"event","uniqueid":"00:15:8d:00:03:65:7d:0d-01-0406"}
        deconz.0	2020-01-15 22:17:53.943	debug	Websocket message: {"e":"changed","id":"9","r":"sensors","state":{"dark":true,"daylight":false,"lastupdated":"2020-01-15T21:17:53","lightlevel":0,"lux":0},"t":"event","uniqueid":"00:15:8d:00:03:65:7d:
        deconz.0	2020-01-15 22:17:53.942	debug	Websocket message: {"config":{"battery":100,"on":true,"reachable":true,"temperature":2600,"tholddark":12000,"tholdoffset":7000},"e":"changed","id":"9","r":"sensors","t":"event","uniqueid":"00:15:8d:00
        deconz.0	2020-01-15 22:17:47.928	debug	NOTIFY {"protocol":"http","version":"1.1","method":"NOTIFY","path":"*","headers":{"host":"239.255.255.250:1900","cache-control":"max-age=100","location":"http://192.168.178.57:80/description.xml","ser
        deconz.0	2020-01-15 22:17:27.931	debug	NOTIFY {"protocol":"http","version":"1.1","method":"NOTIFY","path":"*","headers":{"host":"239.255.255.250:1900","cache-control":"max-age=100","location":"http://192.168.178.57:80/description.xml","ser
        deconz.0	2020-01-15 22:17:11.308	debug	getGroupScenes for Groups.undefined: undefined
        deconz.0	2020-01-15 22:19:37.468	debug	Websocket message: {"e":"changed","id":"37","r":"sensors","state":{"humidity":3957,"lastupdated":"2020-01-15T21:19:37"},"t":"event","uniqueid":"00:15:8d:00:02:b8:82:6e-01-0405"}
        deconz.0	2020-01-15 22:19:37.403	debug	Websocket message: {"e":"changed","id":"36","r":"sensors","state":{"lastupdated":"2020-01-15T21:19:37","temperature":2306},"t":"event","uniqueid":"00:15:8d:00:02:b8:82:6e-01-0402"}
        deconz.0	2020-01-15 22:19:37.402	debug	Websocket message: {"e":"changed","id":"36","r":"sensors","state":{"lastupdated":"2020-01-15T21:19:37","temperature":2306},"t":"event","uniqueid":"00:15:8d:00:02:b8:82:6e-01-0402"}
        deconz.0	2020-01-15 22:19:27.927	debug	NOTIFY {"protocol":"http","version":"1.1","method":"NOTIFY","path":"*","headers":{"host":"239.255.255.250:1900","cache-control":"max-age=100","location":"http://192.168.178.57:80/description.xml","ser
        deconz.0	2020-01-15 22:19:26.579	debug	system.adapter.admin.0: logging true
        deconz.0	2020-01-15 22:19:22.294	debug	Websocket message: {"e":"changed","id":"26","r":"sensors","state":{"lastupdated":"2020-01-15T21:19:22","pressure":970},"t":"event","uniqueid":"00:15:8d:00:03:1b:05:72-01-0403"}
        deconz.0	2020-01-15 22:19:22.290	debug	Websocket message: {"e":"changed","id":"26","r":"sensors","state":{"lastupdated":"2020-01-15T21:19:22","pressure":970},"t":"event","uniqueid":"00:15:8d:00:03:1b:05:72-01-
        deconz.0	2020-01-15 22:27:53.921	debug	getDevices: {"statusCode":404,"body":"[]","headers":{"access-control-allow-origin":"*","content-type":"application/json; charset=utf-8","content-length":"2"},"request":{"uri":{"protocol":"http:","slas
        deconz.0	2020-01-15 22:27:53.921	debug	getAllGroups: {"2":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"b34fb912577592f63236eac4bf9c4499","i
        deconz.0	2020-01-15 22:27:53.921	debug	getAllSensors: {"10":{"config":{"battery":100,"duration":60,"on":true,"reachable":true,"temperature":2600},"ep":1,"etag":"314ddc1881c39cc7afecb4ff90c0f9c2","manufacturername":"LUMI","modelid":"lumi.se
        deconz.0	2020-01-15 22:27:53.920	debug	getAllLights: {"2":{"etag":"09ca9bad05dd1e4ca85da573af37f4c9","hascolor":false,"manufacturername":"OSRAM","modelid":"Plug 01","name":"Steckdose Schuppen","state":{"alert":"none","on":true,"reachable":
        deconz.0	2020-01-15 22:27:53.031	info	starting. Version 1.2.3 in /opt/iobroker/node_modules/iobroker.deconz, node: v8.16.2
        deconz.0	2020-01-15 22:27:52.979	debug	statesDB connected
        deconz.0	2020-01-15 22:27:52.941	debug	objectDB connected
        host.debian-iobroker	2020-01-15 22:27:51.622	info	instance system.adapter.deconz.0 started with pid 27295
        deconz.0	2020-01-15 22:27:53.432	debug	API version: 1.16.0
        deconz.0	2020-01-15 22:27:53.086	info	starting. Version 1.2.3 in /opt/iobroker/node_modules/iobroker.deconz, node: v8.16.2
        • Jey Cee
          Jey Cee Developer @Freaknet last edited by
          @Freaknet Danke für die vielen Log abschnitte. Die sehen alle gut aus, daraus kann ich nix ableiten.
          Deiner Beschreibung nach müsste der Adapter immer wieder neu starten, in den Logs sehe ich aber kein "terminated with code".
          Das einzige was ich sehen kann ist das du noch node v8 installiert hast, vielleicht es was damit zu tun. Falls ich morgen die Zeit finde installiere ich mal ioBroker mit node v8.
            Freaknet @Jey Cee last edited by
            @Jey-Cee
            Ja, da hab ich wohl zu schnell reagiert, war dann dauerhaft grün der adapter.
            Weiß nicht ob es an node.js liegt...
            Wäre natürlich noch ne Idee... wollte eh auf 10.x.x upgraden, aber wollte da noch warten 😉
            Alles klar, installiere jetzt mal wieder 1.1.2 damit wieder alles funzt.
            Danke und bis morgen 😉
              Freaknet @Jey Cee last edited by Freaknet
              @Jey-Cee
              Jetzt bekomm ich 1.1.2 auch nicht mehr zu laufen oh mann 😞
              Update: Kommando zurück. Nach Reboot des Systems geht jetzt wieder alles mit 1.1.2
              Aber die Logs sehen schon anders aus wie mit 1.2.3
              deconz.0	2020-01-15 22:51:27.737	info	options: {"url":"http://127.0.0.1:80/api/292F1976DA/sensors/66/config","method":"PUT","headers":"Content-Type\" : \"application/json","body":"{ \"duration\": \"15\" }"}
              deconz.0	2020-01-15 22:51:27.735	info	options: {"url":"http://127.0.0.1:80/api/292F1976DA/sensors/69/config","method":"PUT","headers":"Content-Type\" : \"application/json","body":"{ \"duration\": \"15\" }"}
              deconz.0	2020-01-15 22:51:27.734	info	options: {"url":"http://127.0.0.1:80/api/292F1976DA/sensors/7/config","method":"PUT","headers":"Content-Type\" : \"application/json","body":"{ \"duration\": \"15\" }"}
              deconz.0	2020-01-15 22:51:27.732	info	options: {"url":"http://127.0.0.1:80/api/292F1976DA/sensors/16/config","method":"PUT","headers":"Content-Type\" : \"application/json","body":"{ \"duration\": \"45\" }"}
              deconz.0	2020-01-15 22:51:27.731	info	options: {"url":"http://127.0.0.1:80/api/292F1976DA/sensors/66/config","method":"PUT","headers":"Content-Type\" : \"application/json","body":"{ \"duration\": \"15\" }"}
              deconz.0	2020-01-15 22:51:27.729	info	options: {"url":"http://127.0.0.1:80/api/292F1976DA/sensors/69/config","method":"PUT","headers":"Content-Type\" : \"application/json","body":"{ \"duration\": \"15\" }"}
              deconz.0	2020-01-15 22:51:27.727	info	options: {"url":"http://127.0.0.1:80/api/292F1976DA/sensors/7/config","method":"PUT","headers":"Content-Type\" : \"application/json","body":"{ \"duration\": \"15\" }"}
              deconz.0	2020-01-15 22:51:27.696	info	options: {"url":"http://127.0.0.1:80/api/292F1976DA/sensors/16/config","method":"PUT","headers":"Content-Type\" : \"application/json","body":"{ \"duration\": \"45\" }"}
              deconz.0	2020-01-15 22:51:27.692	info	setSensorParameters: { "duration": "15" } 66 deconz.0.Sensors.66.duration
              deconz.0	2020-01-15 22:51:27.690	info	setSensorParameters: { "duration": "15" } 69 deconz.0.Sensors.69.duration
              deconz.0	2020-01-15 22:51:27.688	info	setSensorParameters: { "duration": "15" } 7 deconz.0.Sensors.7.duration
              deconz.0	2020-01-15 22:51:27.687	info	setSensorParameters: { "duration": "45" } 16 deconz.0.Sensors.16.duration
              deconz.0	2020-01-15 22:51:27.685	info	setSensorParameters: { "duration": "15" } 66 deconz.0.Sensors.66.duration
              deconz.0	2020-01-15 22:51:27.684	info	setSensorParameters: { "duration": "15" } 69 deconz.0.Sensors.69.duration
              deconz.0	2020-01-15 22:51:27.682	info	setSensorParameters: { "duration": "15" } 7 deconz.0.Sensors.7.duration
              deconz.0	2020-01-15 22:51:27.681	info	setSensorParameters: { "duration": "45" } 16 deconz.0.Sensors.16.duration
              deconz.0	2020-01-15 22:51:27.679	info	setSensorParameters: { "duration": "15" } 66 deconz.0.Sensors.66.duration
              deconz.0	2020-01-15 22:51:27.677	info	setSensorParameters: { "duration": "15" } 69 deconz.0.Sensors.69.duration
              deconz.0	2020-01-15 22:51:27.676	info	setSensorParameters: { "duration": "15" } 7 deconz.0.Sensors.7.duration
              deconz.0	2020-01-15 22:51:27.674	info	setSensorParameters: { "duration": "45" } 16 deconz.0.Sensors.16.duration
              deconz.0	2020-01-15 22:51:27.672	info	setSensorParameters: { "duration": "15" } 66 deconz.0.Sensors.66.duration
              deconz.0	2020-01-15 22:51:27.670	info	setSensorParameters: { "duration": "15" } 69 deconz.0.Sensors.69.duration
              deconz.0	2020-01-15 22:51:27.669	info	setSensorParameters: { "duration": "15" } 7 deconz.0.Sensors.7.duration
              deconz.0	2020-01-15 22:51:27.667	info	setSensorParameters: { "duration": "45" } 16 deconz.0.Sensors.16.duration
              deconz.0	2020-01-15 22:51:27.642	info	setSensorParameters: { "duration": "15" } 66 deconz.0.Sensors.66.duration
              deconz.0	2020-01-15 22:51:27.640	info	setSensorParameters: { "duration": "15" } 69 deconz.0.Sensors.69.duration
              deconz.0	2020-01-15 22:51:27.635	info	setSensorParameters: { "duration": "15" } 7 deconz.0.Sensors.7.duration
              deconz.0	2020-01-15 22:51:27.634	info	setSensorParameters: { "duration": "45" } 16 deconz.0.Sensors.16.duration
              deconz.0	2020-01-15 22:51:27.632	info	setSensorParameters: { "duration": "15" } 66 deconz.0.Sensors.66.duration
              deconz.0	2020-01-15 22:51:27.630	info	setSensorParameters: { "duration": "15" } 69 deconz.0.Sensors.69.duration
              deconz.0	2020-01-15 22:51:27.619	info	setSensorParameters: { "duration": "15" } 7 deconz.0.Sensors.7.duration
              deconz.0	2020-01-15 22:51:27.618	info	setSensorParameters: { "duration": "45" } 16 deconz.0.Sensors.16.duration
              deconz.0	2020-01-15 22:51:27.616	info	setSensorParameters: { "duration": "15" } 66 deconz.0.Sensors.66.duration
              deconz.0	2020-01-15 22:51:27.608	info	setSensorParameters: { "duration": "15" } 69 deconz.0.Sensors.69.duration
              deconz.0	2020-01-15 22:51:27.606	info	setSensorParameters: { "duration": "15" } 7 deconz.0.Sensors.7.duration
              deconz.0	2020-01-15 22:51:27.604	info	setSensorParameters: { "duration": "45" } 16 deconz.0.Sensors.16.duration
              deconz.0	2020-01-15 22:51:27.602	info	setSensorParameters: { "duration": "15" } 66 deconz.0.Sensors.66.duration
              deconz.0	2020-01-15 22:51:27.600	info	setSensorParameters: { "duration": "15" } 69 deconz.0.Sensors.69.duration
              deconz.0	2020-01-15 22:51:27.571	info	setSensorParameters: { "duration": "15" } 7 deconz.0.Sensors.7.duration
              deconz.0	2020-01-15 22:51:27.556	info	setSensorParameters: { "duration": "45" } 16 deconz.0.Sensors.16.duration
              deconz.0	2020-01-15 22:51:25.439	info	starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.deconz, node: v8.16.2
              • Jey Cee
                @Freaknet was läuft den bei dir für eine js-controller version?
                  @Jey-Cee
                  Aktuell bis ich node.js update die 1.5.14
                  Hat bisher alles funktioniert und man sagt ja "Never Chance a running System" 😉
                  Was ich so noch sehe ist, das diese NOTIFY Meldungen nicht kommen unter 1.1.2
                  Schaut wirklich kpl. anders aus wie bei 1.2.3
                  deconz.0	2020-01-15 23:01:03.677	debug	Websocket message: {"config":{"battery":98,"offset":0,"on":true,"reachable":true},"e":"changed","id":"21","r":"sensors","t":"event","uniqueid":"00:15:8d:00:02:b5:7b:76-01-0402"}
                  deconz.0	2020-01-15 23:00:10.144	debug	getLightState: {"etag":"cde08c26bb6e086a0668bde230838c6e","hascolor":false,"manufacturername":"OSRAM","modelid":"Plug 01","name":"Steckdose Schuppen","state":{"alert":"none","on":true,"reachable":true
                  deconz.0	2020-01-15 23:00:10.134	debug	Websocket message: {"e":"changed","id":"2","r":"lights","state":{"alert":null,"on":true,"reachable":true},"t":"event","uniqueid":"7c:b0:3e:aa:00:b0:db:f9-03"}
                  deconz.0	2020-01-15 23:00:10.134	debug	setLightState BODY: [{"success":{"/lights/2/state/on":true}}]
                  deconz.0	2020-01-15 23:00:10.134	info	options: {"url":"http://127.0.0.1:80/api/292F1976DA/lights/2/state","method":"PUT","headers":"Content-Type\" : \"application/json","body":"{\"on\": true}"}
                  deconz.0	2020-01-15 23:00:10.134	debug	STATUS: 200
                  deconz.0	2020-01-15 23:00:10.116	info	setLightState: {"on": true} 2 deconz.0.Lights.2.on
                  deconz.0	2020-01-15 23:00:10.105	debug	dp: on; id:Lights.2
                  deconz.0	2020-01-15 23:00:10.104	debug	stateChange deconz.0.Lights.2.on {"val":true,"ack":false,"ts":1579125610100,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1579125610100}
                  deconz.0	2020-01-15 23:00:09.924	debug	system.adapter.admin.0: logging true
                  deconz.0	2020-01-15 23:00:00.231	debug	getLightState: {"etag":"ca122bd6b4e39e5ba83b4460d537e663","hascolor":false,"manufacturername":"OSRAM","modelid":"Plug 01","name":"Steckdose Schuppen","state":{"alert":"none","on":false,"reachable":tr
                  deconz.0	2020-01-15 23:00:00.201	debug	Websocket message: {"e":"changed","id":"2","r":"lights","state":{"alert":null,"on":false,"reachable":true},"t":"event","uniqueid":"7c:b0:3e:aa:00:b0:db:f9-03"}
                  deconz.0	2020-01-15 23:00:00.199	debug	setLightState BODY: [{"success":{"/lights/2/state/on":false}}]
                  deconz.0	2020-01-15 23:00:00.194	info	options: {"url":"http://127.0.0.1:80/api/292F1976DA/lights/2/state","method":"PUT","headers":"Content-Type\" : \"application/json","body":"{\"on\": false}"}
                  deconz.0	2020-01-15 23:00:00.194	debug	STATUS: 200
                  deconz.0	2020-01-15 23:00:00.175	info	setLightState: {"on": false} 2 deconz.0.Lights.2.on
                  deconz.0	2020-01-15 23:00:00.141	debug	dp: on; id:Lights.2
                  deconz.0	2020-01-15 23:00:00.140	debug	stateChange deconz.0.Lights.2.on {"val":false,"ack":false,"ts":1579125600138,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1579125600138}
                  deconz.0	2020-01-15 22:59:03.519	debug	Websocket message: {"e":"changed","id":"33","r":"sensors","state":{"lastupdated":"2020-01-15T21:59:03","temperature":2108},"t":"event","uniqueid":"00:15:8d:00:02:e9:27:e6-01-0402"}
                  deconz.0	2020-01-15 22:59:03.519	debug	Websocket message: {"config":{"battery":81,"offset":0,"on":true,"reachable":true},"e":"changed","id":"33","r":"sensors","t":"event","uniqueid":"00:15:8d:00:02:e9:27:e6-01-0402"}
                  deconz.0	2020-01-15 22:59:03.518	debug	Websocket message: {"e":"changed","id":"35","r":"sensors","state":{"lastupdated":"2020-01-15T21:59:03","pressure":970},"t":"event","uniqueid":"00:15:8d:00:02:e9:27:e6-01-0403"}
                  deconz.0	2020-01-15 22:59:03.509	debug	Websocket message: {"config":{"battery":81,"on":true,"reachable":true},"e":"changed","id":"35","r":"sensors","t":"event","uniqueid":"00:15:8d:00:02:e9:27:e6-01-0403"}
                  deconz.0	2020-01-15 22:59:03.507	debug	Websocket message: {"e":"changed","id":"34","r":"sensors","state":{"humidity":4410,"lastupdated":"2020-01-15T21:59:03"},"t":"event","uniqueid":"00:15:8d:00:02:e9:27:e6-01-0405"}
                  • Jey Cee
                    @Freaknet hm dachte ich mir, im log wurde eine Funktion als unbekannt deklariert. Deshalb läuft der Adapter bei dir wohl auch nicht. Die Entwicklung hab ich auf JS-controller 2 gemacht.
                    @Freaknet sagte in Eurotronic Spirit ZigBee:
                    Ja die sind bestandteil der Erkennung ob deConz noch erreichbar ist.
                      @Jey-Cee
                      Ok... also doch update auf JS-Controller 2.x.x ?
                      Dazu ist ja zum empfehlen node.js auch auf min. 10.x.x zu bringen was ich so gelesen habe.
                      Dann warte ich heute Nacht mal mein Backup ab und wenn ich dazu komme mach ich alle nötigen Updates und versuch es nochmal.
                      @Hoffiheller
                      Hast Du auch JS-Controller 2.x.x am laufen?
                        Hoffiheller @Freaknet last edited by Hoffiheller
                        @Freaknet
                        ja ich habe JS-Controller 2.2.7 und node.js 10.18.1 am laufen und soweit ich es beurteilen kann Problemfrei.
                        Edit: siehe Post 32
                          Freaknet @Hoffiheller last edited by
                          @Hoffiheller
                          Alles klar, dann wird es daran wohl liegen.
                          Hatte nicht´s gelesen das ich JS-Controller 2.x.x benötige 😉
                          Aber Ihr habt mir jetzt sehr geholfen. Mal sehn ob ich die Woche noch dazu komme das System auf den neusten Stand zu bringen.
                          Danke auch an @Jey-Cee und @Asgothian
                          Vielleicht hilft es, wenn man in gitHub den Hinweis für den JS-Controller irgendwo mit hinterlegt.
                          Melde mich wenn alles wieder läuft und der Adapter drauf ist.
                            @Jey-Cee
                            Hey, also alles läuft perfekt jetzt mit 1.2.4.
                            Nach Update auf JS-Controller 2.x.x und node.js auf 10.x.x passt das jetzt.
                            Was für eine Geburt 😉
                            Hab gesehen das Du den Hinweis bereits auf gitHub hinterlegt hast 👍
                            Danke nochmal für die ganze Hilfe und Unterstützung!
                            1.0k
                            58
                            9756
