    4. JavaScript
    5. Script fürTabelle der Batterie Zustände
    • Meister Mopper
      Meister Mopper @Homoran last edited by Meister Mopper
      Irgendwas scheint bei mir schief zu laufen. Das Skript läuft nicht und es wirft folgende Fehler:
      avascript.0	2020-01-16 10:02:34.223	info	(24965) Stop script script.js.java.sonstige.Batterien
      javascript.0	2020-01-16 10:02:29.340	error	(24965) at process._tickCallback (internal/process/next_tick.js:68:7)
      javascript.0	2020-01-16 10:02:29.340	error	(24965) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      javascript.0	2020-01-16 10:02:29.339	error	(24965) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      javascript.0	2020-01-16 10:02:29.339	error	(24965) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:581:17)
      javascript.0	2020-01-16 10:02:29.338	error	(24965) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:855:17)
      javascript.0	2020-01-16 10:02:29.338	error	(24965) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1264:17)
      javascript.0	2020-01-16 10:02:29.337	error	(24965) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1211:37)
      javascript.0	2020-01-16 10:02:29.337	error	(24965) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:988:28)
      javascript.0	2020-01-16 10:02:29.336	error	(24965) at Object.createScript (vm.js:277:10)
      javascript.0	2020-01-16 10:02:29.336	error	(24965) at new Script (vm.js:83:7)
      javascript.0	2020-01-16 10:02:29.336	error	(24965) SyntaxError: Identifier 'mySchedule' has already been declared
      javascript.0	2020-01-16 10:02:29.335	error	(24965) ^
      javascript.0	2020-01-16 10:02:29.335	error	(24965) let mySchedule=" * * * * * "; //jede minute
      javascript.0	2020-01-16 10:02:29.334	error	at script.js.java.sonstige.Batterien:73
      javascript.0	2020-01-16 10:02:29.334	error	(24965) script.js.java.sonstige.Batterien compile failed:
      javascript.0	2020-01-16 10:02:29.331	info	(24965) Start javascript script.js.java.sonstige.Batterien
      Der Datenpunkt wird auch nicht mehr gefüllt.
        liv-in-sky @Meister Mopper last edited by
        @Meister-Mopper es scheint als ob myschedule zweimal im script ist - bitte prüfen
        • Meister Mopper
          Meister Mopper @liv-in-sky last edited by
          @liv-in-sky Das taucht im Skript nur zweimal auf:
          und
            @Meister-Mopper das ist seltsam da steht was von promise - das nutze ich hier nicht
            kannst du bitte nochmal das script vom ersten post neu adaptieren - das jetztige script stoppen und ein neues anlegen - die beiden datenpunkte wieder richtig konfigurieren und bevor du das neue script startest, mal die javascript-instanz neu starten - wegen des promise fehlers
            • Meister Mopper
              @liv-in-sky Hier die Meldungen (Datenpunkt nicht befüllt):
              javascript.0	2020-01-16 13:28:09.633	info	(897) Stop script script.js.java.sonstige.Batterien
              javascript.0	2020-01-16 13:28:00.076	error	(897) at tryOnTimeout (timers.js:300:5)
              javascript.0	2020-01-16 13:28:00.076	error	(897) at ontimeout (timers.js:436:11)
              javascript.0	2020-01-16 13:28:00.076	error	(897) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
              javascript.0	2020-01-16 13:28:00.075	error	(897) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
              javascript.0	2020-01-16 13:28:00.075	error	(897) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
              javascript.0	2020-01-16 13:28:00.075	error	(897) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1319:34)
              javascript.0	2020-01-16 13:28:00.075	error	(897) at Object.<anonymous> (script.js.java.sonstige.Batterien:1151:1)
              javascript.0	2020-01-16 13:28:00.074	error	(897) at writeHTML (script.js.java.sonstige.Batterien:751:27)
              javascript.0	2020-01-16 13:28:00.074	error	(897) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:846:29)
              javascript.0	2020-01-16 13:28:00.074	error	(897) at script.js.java.sonstige.Batterien:781:33
              javascript.0	2020-01-16 13:28:00.073	error	(897) Error in callback: TypeError: Cannot read property 'split' of undefined
              javascript.0	2020-01-16 13:27:21.074	error	(897) at Script.runInContext (vm.js:133:20)
              javascript.0	2020-01-16 13:27:21.074	error	(897) at script.js.java.sonstige.Batterien:1157:1
              javascript.0	2020-01-16 13:27:21.074	error	(897) at writeHTML (script.js.java.sonstige.Batterien:751:27)
              javascript.0	2020-01-16 13:27:21.073	error	(897) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:846:29)
              javascript.0	2020-01-16 13:27:21.073	error	(897) at script.js.java.sonstige.Batterien:781:33
              javascript.0	2020-01-16 13:27:21.073	error	(897) TypeError: Cannot read property 'split' of undefined
              javascript.0	2020-01-16 13:27:21.072	error	(897) ^
              javascript.0	2020-01-16 13:27:21.072	error	(897) var ida = val0.split('.');
              javascript.0	2020-01-16 13:27:21.072	error	(897) script.js.java.sonstige.Batterien: script.js.java.sonstige.Batterien:781
              javascript.0	2020-01-16 13:27:21.003	info	(897) Start javascript script.js.java.sonstige.Batterien
                @Meister-Mopper der srste fehler soll in zeile 781 sein - diese zeile habe ich nicht in meinem script - endet bei 664
                daher weiß ich nicht -wo de fehler liegt
                probieren wir es mal so
                hier nochmal das script - diesmal über file
                Batterien-tabelle.txt
                wenn du das kopierst und in iobroker einfügst - wieviele zeilen hast du dann im script ?
                • Meister Mopper
                  Meister Mopper @liv-in-sky last edited by Meister Mopper
                  @liv-in-sky Nach dem Import sind es 664 Zeilen. Nach Start des Scripts sind es 1.329. Keine Ahnung warum. Hier der Code nach dem Start:
                  //f          ür spezialisten bei devices mit über 3 volt batterien
                  var bigBattAlarm=3.3; var bigBattWarn=3.6; //WICHTIG bei bigAlarm nicht unter 3.3 gehen !!!!!!!!
                  var symbolOK="?";
                  var symbolKO="?";     //z.b. auch "<font color=\"red\"><b>X</b>" für ein rotes kreuz
                  var symbolWARN="??";
                  var filterArray=["hm-rpc.0.LEQ0242145.0.LOWBAT", "hm-rpc.0.LEQ0242152.0.LOWBAT","hm-rpc.1.OEQ0473764.0.LOWBAT"]; //hier den ganzenpfad von ungewünschten LOW_BAT werten eingeben - diese werden dann gefiltert
                  //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 3
                  var htmlFeld1='Device';      var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
                  var htmlFeld2='V bzw. %';        var Feld2lAlign="center";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
                  var htmlFeld3='Status';         var Feld3lAlign="center";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
                  //------------------------------hier werden die styles für die tabelle definiert
                  //ÜBERSCHRIFT ÜBER TABELLE
                  let   htmlUberschrift=false;                           // mit Überschrift über der tabelle
                  let   htmlSignature=true;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
                  const htmlFeldUeber='Batterie Zustand Sensoren';              // Überschrift und Signature
                  const htmlFarbUber="white";                         // Farbe der Überschrift
                  const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
                  const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
                  //MEHRERE TABELLEN NEBENEINANDER
                  let   mehrfachTabelle=4;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
                  const htmlFarbZweiteTabelle="white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
                  const htmlFarbTableColorUber="#BDBDBD";               // Überschrift in der tabelle - der einzelnen Spalten
                  //GANZE TABELLE
                  let abstandZelle="1";
                  let weite="auto";                                     //Weite der Tabelle
                  let zentriert=true;                                   //ganze tabelle zentriert
                  const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
                  const htmlSchriftart="Helvetica";
                  const htmlSchriftgroesse="14px";
                  //FELDER UND RAHMEN
                  let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
                  const htmlFarbFelderschrift="#BDBDBD";                  // SchriftFarbe der Felder
                  const htmlFarbFelderschrift2="#D8D8D8";                 // SchriftFarbe der Felder für jede 2te Tabelle
                  const htmlFarbTableColorGradient1="#424242";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
                  const htmlFarbTableColorGradient2="#424242";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                  const htmlFarbTableBorderColor="gray";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
                  let htmlRahmenLinien="cols";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
                  const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
                  // AB HIER NICHTS  ÄNDERN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                  let borderHelpBottum;
                  let borderHelpRight;
                  let htmlcenterHelp;
                  let htmlcenterHelp2;
                  if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
                  if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
                  if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
                  if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
                  zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
                  zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
                  const htmlZentriert='<center>'
                  const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                                    "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                                    " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                                   // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                                    " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                                    " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                                    "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                                    " </style></head><body> <div>";
                  //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
                  const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                                       "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
                  const htmlTabUeber1="<tr style=\"color:"+htmlFarbTableColorUber+"; font-weight: bold\">";
                  const htmlTabUeber3="</tr>";
                  //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 3
                    	var htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td>";
                  var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+"  align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld2+
                                    "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td>";
                  var htmlTabUeber="";
                  var htmlOut="";
                  var mix;
                  var counter;
                  var AkkuAlarm=[];
                  //HIER SIND DIE  WERTE, DIE IN DER SCHLEIFE GEFILTERET WER%DEN - Jede spalte einen wert - jeder valx muss in dieser schleife gesetzt werden !!
                  var val1; var val0; var val2;
                  function writeHTML(){
                    AkkuAlarm=[];
                  htmlOut="";
                  counter=-1;
                  htmlTabUeber="";
                  switch (mehrfachTabelle) {
                    case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
                    case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                    case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber3; break;
                    case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                  if (!UeberschriftSpalten) {htmlTabUeber=""}
                  //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
                  //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2 !!!---------------------------------------------------------------------
                  var myColl=[];
                  var val1help;
                     if (fritzDect){
                                // UNTERTEILUNG - ÜBERSCHRIFT IN TABELLE
                                  tabelleAusbessern();
                                  counter=0;
                                    val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>FRITZDECT THERMOSTATE</b>"; val1=""; val2="";
                                  tabelleBind();
                                  counter=-1;
                    $('fritzdect.*.*.battery').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                           var ida = id.split('.');
                             counter++;
                           //  val0=ida[2]+"."+ida[3];
                             val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]).common.name ;
                             val1help=parseFloat((getState(id).val));
                             if (val1help<=battAlarm) {val1=(" <font color=\"red\"> ")+val1help.toString()} else{val1=(" <font color=\"green\"> ")+val1help.toString()}
                             if (val1help>battAlarm && val1help<=battAlarmWarning) {val1=(" <font color=\"yellow\"> ")+val1help.toString()}
                             if (getState(id).val==null) {val2="never used"}; //log(id)};
                             if (val1help<=battAlarm) {val2=symbolKO} else{val2=symbolOK}
                             if (val1help>battAlarm && val1help<=battAlarmWarning) val2=symbolWARN;
                             if (val1help<=battAlarm) AkkuAlarm.push(1);
                        tabelleBind(); //HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT  - diese function muss als letztes in der eigenen schleife aufgerufen werden
                      }); //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
                   } //ende fritzdect
                    if (xiaomi){
                         counter=0;
                         val0=""; val1=""; val2="";
                         counter=0;
                         val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>XIAOMI DEVICES</b>"; val1=""; val2="";
                         counter=-1
                  $('mihome.*.devices.*.percent').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                             counter++;                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                           //  val0=ida[3];
                             val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]+"."+ida[3]).common.name ;
                           // log(val0+"   "+id);
                             if (val1help<=battAlarm) {val1=(" <font color=\"red\"> ")+val1help.toString()+" %"} else{val1=(" <font color=\"green\"> ")+val1help.toString()+" %"}
                             if (val1help>battAlarm && val1help<=battAlarmWarning) {val1=(" <font color=\"yellow\"> ")+val1help.toString()+" %"}
                    } //ende xiaomi
                   if (hue){
                         counter=0;
                         counter=0;
                         val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>HUE DEVICES</b>"; val1=""; val2="";
                         counter=-1
                  $('hue.*.*.battery').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                            counter++;
                             val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]+"."+ida[3]).common.name ;   val0=val0.replace("Philips_hue.",""); val0=val0.replace(/_/g," ");                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                    }  //ende hue
                   if (hueExt){
                         counter=0;
                         counter=0;
                         val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>HUE EXTENDED</b>"; val1=""; val2="";
                         counter=-1
                  $('hue-extended.*.*.*.config.battery').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                     } //ende hue-extended
                   if (tradfri){
                         counter=0;
                         counter=0;
                         val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>IKEA TRADFRI</b>"; val1=""; val2="";
                         counter=-1
                  $('tradfri.*.*.batteryPercentage').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                           val1help=getState(id).val;
                   if (homematic){
                         counter=0;
                         counter=0;
                         val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>HOMEMATIC</b>"; val1=""; val2="";
                         counter=-1
                  $('hm-rpc.*.*.0.LOWBAT').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                         //var ida = id.split('.');
                          if (!filterArray.includes(id)){
                            val0=getObject(id).common.name ; //ida[2]+"."+ida[3];
                            val0=ida[0].replace(/:.+/g,"");
                            //log(val0+"   "+id);
                           if (val1help) {val1=(" <font color=\"red\"> ")+"low bat"} else{val1=(" <font color=\"green\"> ")+"full bat"}
                           if (val1help) {val2=symbolKO} else{val2=symbolOK}
                           if (val1help) AkkuAlarm.push(1);
                          } // ende filterArr
                       } //ende hm
                   if (homematicIp ){
                          counter=0;
                          counter=0;
                          val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>HOMEMATIC IP</b>"; val1=""; val2="";
                          counter=-1
                  $('hm-rpc.*.*.0.LOW_BAT').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                         var arrFilt=[];
                             $(ida[0]+"."+ida[1]+"."+ida[2]+"."+ida[3]+".*").each(function(id, i) {   // kontrolliere ob OPERATING_VOLTAGE vorhanden
                                 var idc = id.split('.');
                              arrFilt.push(idc[4])
                        if (arrFilt.includes("OPERATING_VOLTAGE")) {
                                    var  val1helper=getState(id.replace("LOW_BAT","OPERATING_VOLTAGE")).val;
                                    //bigBatterien
                                    //log (val1helper.toFixed(1))
                                    if (val1helper>3.2){
                                           if (val1helper<=bigBattAlarm) {val2=symbolKO} else if (val1helper<=bigBattWarn && val1helper>bigBattAlarm)
                                              {val2=symbolWARN} else{val2=symbolOK};
                                           if (val1helper<=bigBattAlarm) {val1=(" <font color=\"red\"> ")+val1helper.toFixed(1)+" V"} else if (val1helper<=bigBattWarn && val1helper>bigBattAlarm)
                                              {val1=(" <font color=\"yellow\"> ")+val1helper.toFixed(1)+" V"} else{val1=(" <font color=\"green\"> ")+(val1helper.toFixed(1))+" V"};
                                           if (val1helper<bigBattAlarm) AkkuAlarm.push(1);
                                    else {
                                          if (val1helper<2.2) {val2=symbolKO} else if (val1helper<=2.5 && val1helper>=2.2)
                                          if (val1helper<2.2) {val1=(" <font color=\"red\"> ")+val1helper.toFixed(1)+" V"} else if (val1helper<=2.5 && val1helper>=2.2)
                                             {val1=(" <font color=\"yellow\"> ")+val1helper.toFixed(1)+" V"} else{val1=(" <font color=\"green\"> ")+val1helper.toFixed(1)+" V"};
                                          if (val1helper<2.2) AkkuAlarm.push(1);}
                          } else {
                    }  //ende hm-ip
                    if (fullyBrowser){
                         counter=0;
                         counter=0;
                         val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>FULLYBROWSER</b>"; val1=""; val2="";
                         counter=-1
                  $('fullybrowser.*.*.Info.batteryLevel').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                             val0=getState(id.replace("batteryLevel","deviceName")).val;
                    } //ende fullybrowser
                    if (iogo){
                         counter=0;
                         counter=0;
                         val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>HANDY über IOGO</b>"; val1=""; val2="";
                         counter=-1
                  $('iogo.*.*.battery.level').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                          //   val0=ida[3];
                    } //ende iogo
                     if (handy1){
                             counter=0;
                             counter=0;
                             val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>HANDYs</b>"; val1=""; val2="";
                             counter=-1
                          $('controll-own.0.HANDY.*batt*').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                           val0=ida[3];
                     } //ende handy1
                     if (handy2){
                              $('controll-own.0.HANDY.*Batt*').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                           val0=ida[3];
                     } //ende handy2
                  //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                       tabelleFinish(); // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
                       if (AkkuAlarm.length >=1 ) {setState(dpAlarm,AkkuAlarm.length)} else {setState(dpAlarm,AkkuAlarm.length)}
                       log("BATTERIE Alarm     : "+AkkuAlarm.length.toString());
                  } // function ende
                  //MAIN:
                  schedule(mySchedule,  function () {
                  writeHTML();
                  if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                  writeHTML();
                  if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}                                 //     <tdalign
                  function tabelleBind(){
                          case 1:                    htmlOut=htmlOut+"<tr><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;
                          case 2:  if(counter%2==0)  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
                                                else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} break;
                          case 3: if(counter%3==0 )  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
                                                else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";}
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>";}
                                                           } break;
                          case 4: if(counter%4==0)  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
                                                    else {if(counter%2==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";}
        else    {if(counter%2==1 && counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";}
        else    {htmlOut = htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}}
                                                           } break; } //switch ende
                  function tabelleAusbessern() {
                          case 1:    break;
                          case 2:    mix=Math.abs(((counter+1)%2)-mehrfachTabelle);
                                     if(mix==1)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                     break;
                          case 3:    mix =Math.abs(((counter+1)%3)-mehrfachTabelle);
                                     if(mix==2)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                     break;
                          case 4:    mix=Math.abs(((counter+1)%4)-mehrfachTabelle);
                                     if(mix==3)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                     break; }
                  function tabelleFinish() {
                          case 1:    break;
                                     break;
                                     break;
                                     break; }
                          var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
                        var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>";
                         if (!htmlSignature) htmlUnter="";
                           //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                            var htmlOutVIS="";
                          //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                             if (htmlUberschrift)
                                 { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter ;
                               } else {
                                zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter;
                   // log("bin raus aus tabelleBind");
                            if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
                            //console.log dpVIS;
                  var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                  var htmlEnd="</table>"+htmlUnter+"</div></body>";
                  //mit oder ohne überschrift - zentriert oder links
                  htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
                  //log(htmlOut);
                  • Meister Mopper
                    Meister Mopper @Meister Mopper last edited by Meister Mopper
                    @liv-in-sky Hier der Editor:
                    liv-in-sky Chaot 2 Replies Last reply Reply Quote 0
                      @Meister-Mopper mach doch bitte ein editor bild (mit zeilen), wo der fehelr bei dir ist
                      was da ist, weiß ich nicht - welche js version hast du
                      • Chaot
                        Chaot @Meister Mopper last edited by
                        @Meister-Mopper Kopierst du das Script mit Firefox?
                        Bei mir sind dann jede Menge Leerzeilen drin. Mit Chrome geht das besser.
                        • Meister Mopper
                          Meister Mopper @Chaot last edited by
                          @liv-in-sky Script Engine 4.1.12 und js-controller 2.2.7.
                            @Meister-Mopper was steht bei dir unter
                            bitte bild
                            • Meister Mopper
                              @liv-in-sky
                                @Meister-Mopper mach mal das in zeile 69
                                var filterArray=[];
                                daraus - den inhalt ganz löschen
                                • Meister Mopper
                                  @liv-in-sky nach wie vor die gleichen Meldungen. Ich werde nachher mal alles neu starten.
                                    @Meister-Mopper ich hätte auch noch eine andere idee - falls der neustart nix bringt
                                    zeige mir mal bitte den raw wert von einem datenpunkt der ....LOW_BAT heißt
                                    z.b.
                                      liv-in-sky @Meister Mopper last edited by liv-in-sky
                                      @Meister-Mopper
                                      odr probiere mal dieses script
                                      //@liv-in-sky Januar 2020
                                      //HIER WIRD PFAD UND FILENAME DEFINIERT
                                      const path = "/htmlakku.html";                   //FIlenamen definieren
                                      const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
                                      let   braucheEinFile=false;                          // bei true wird ein file geschrieben
                                      let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
                                      let dpVIS="controll-own.0.TABELLEN.AKKU"         //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
                                      let dpAlarm="controll-own.0.TABELLEN.AkkuAlarm";  //WICHTIG datenpunkt erstellen vom typ "number" - bei 0 kein alarm und größer 0 die anzahl der schlechten batterien
                                      let htmlColorDeviceUeberschrift="#00BFFF"
                                      var battAlarm=30;                                     //alarm batterie wert
                                      var battAlarmWarning=55;                                     //warnungen batterie wert
                                      // ------------------------    hier einstellen, was man für adapter hat - die nicht gebraucht werden auf false setzen !!!
                                      var tradfri=true;
                                      var hue=true;
                                      var hueExt=true;
                                      var homematic=false;
                                      var homematicIp=true;
                                      var xiaomi=true;                                                // mihome.0
                                      var fritzDect=true;
                                      var iogo=true;                                                 // iogo - adapter - hat batterie abfrage
                                      var fullyBrowser=true;                                         // fullybrowser - adapter - hat batterie abfrage
                                      var handy1=false;                                              // sind einzelne datenpunkte,
                                      var handy2=false;
                                      var symbolOK="✅";
                                      var symbolKO="❌";     //z.b. auch "<font color=\"red\"><b>X</b>" für ein rotes kreuz
                                      var symbolWARN="⚠️";
                                      var filterArray=[]; //hier den ganzenpfad von ungewünschten LOW_BAT werten eingeben - diese werden dann gefiltert
        // BEISPIEL var filterArray=["hm-rpc.0.LEQ0242145.0.LOWBAT", "hm-rpc.0.LEQ0242152.0.LOWBAT","hm-rpc.1.OEQ0473764.0.LOWBAT"];
                                      //GANZE TABELLE
                                      //FELDER UND RAHMEN
                                      let htmlcenterHelp;
                                      var htmlOut="";
                                      var mix;
                                      var counter;
                                      var AkkuAlarm=[];
                                       AkkuAlarm=[];
                                      htmlOut="";
                                      counter=-1;
                                      htmlTabUeber="";
                                      var myColl=[];
                                      var val1help;
                                        if (fritzDect){
                                                     counter=0;
                                                     tabelleBind();
                                                     counter=-1;
                                                counter++;
                                      } //ende fritzdect
                                       if (xiaomi){
                                            counter=0;
                                            counter=0;
                                            counter=-1
                                              //  val0=ida[3];
                                       } //ende xiaomi
                                      if (hue){
                                            counter=0;
                                            counter=0;
                                            counter=-1
                                               counter++;
                                       }  //ende hue
                                      if (hueExt){
                                            counter=0;
                                            counter=0;
                                            counter=-1
                                      if (tradfri){
                                            counter=0;
                                            counter=0;
                                            counter=-1
                                      if (homematic){
                                            counter=0;
                                            counter=0;
                                            counter=-1
                                               //log(val0+"   "+id);
                                             } // ende filterArr
                                          } //ende hm
                                      if (homematicIp ){
                                             counter=0;
                                             counter=0;
                                             counter=-1
                                            var arrFilt=[];
                                             log(arrFilt.toString());
                                                     //  val0=getObject(id).common.name ;
                                                       //bigBatterien
                                                       else {
                                             } else {
                                       }  //ende hm-ip
                                       if (fullyBrowser){
                                            counter=0;
                                            counter=0;
                                            counter=-1
                                       if (iogo){
                                            counter=0;
                                            counter=0;
                                            counter=-1
                                             //   val0=ida[3];
                                       } //ende iogo
                                        if (handy1){
                                                counter=0;
                                                counter=0;
                                                counter=-1
                                              val0=ida[3];
                                        } //ende handy1
                                        if (handy2){
                                              val0=ida[3];
                                        } //ende handy2
                                      } // function ende
                                      //MAIN:
                                      writeHTML();
                                      writeHTML();
        } break;
                                             case 1:    break;
                                                        break;
                                                        break;
                                                        break; }
                                             case 1:    break;
                                                        break;
                                                        break;
                                                        break; }
                                               var htmlOutVIS="";
                                                  } else {
                                      //log(htmlOut);
                                      Meister Mopper Homoran 2 Replies Last reply Reply Quote 0
                                      • Meister Mopper
                                        @liv-in-sky Es geht doch nichts über einen gepflegten Neustart. Jetzt läufts. Aber, warum werden die HomematicIP als lowbat angezeigt, obwohl sie das in den Objekten nicht sind:
                                        Das ist ein Objekt:
                                          @Meister-Mopper weil wir entschieden haben, dass wir die spannung nehmen, wenn im selben ordner ein OPERATION_VOLTAGE wert ist - LOW_BAT wird dann angezeigt nur, wenn dieser VOLTAGE wert nicht existiert
                                            @Meister-Mopper die anzeige ist genau so, wie sie sein soll
                                            homematic hat nur low oder full batt
                                            und die hm-ip haben zum teil die valtage anzeige und zum anderen low oder fullbatt
                                            javascript monitoring template
                                            67
                                            1379
                                            484121
