    4. [Neuer Adapter] LinkedDevices
      jack99n last edited by
      Hat sich leider nicht geändert.
      linkeddevices.0	2019-12-15 18:33:55.371	info	(17341) [createAllLinkedObjects] count of active linkedObjects: 1
      linkeddevices.0	2019-12-15 18:33:55.356	error	at process._tickCallback (internal/process/next_tick.js:189:7)
      linkeddevices.0	2019-12-15 18:33:55.356	error	at <anonymous>
      linkeddevices.0	2019-12-15 18:33:55.356	error	at Linkeddevices.getConvertedValue (/opt/iobroker/node_modules/iobroker.linkeddevices/main.js:1653:20)
      linkeddevices.0	2019-12-15 18:33:55.356	error	(17341) [createLinkedObject] stack: TypeError: value.replace is not a function
      linkeddevices.0	2019-12-15 18:33:55.354	error	(17341) [createLinkedObject] parentObject 'mqtt.0.h801.switch.ESPURNA_318C6C.brightness.set', linkedObject 'linkeddevices.0.LED-Level.set' error: value.replace is not a function
      linkeddevices.0	2019-12-15 18:33:54.651	info	(17341) [initialObjects] started...
      linkeddevices.0	2019-12-15 18:33:54.626	info	(17341) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.linkeddevices, node: v8.16.2
      • Scrounger
        Scrounger Developer @jack99n last edited by
        @jack99n
        stell den adapter mal bitte auf debug modus, starte ihn neu und poste das gesamte log.
          linkeddevices.0	2019-12-15 19:31:43.201	info	(19155) [initialObjects] finished
          linkeddevices.0	2019-12-15 19:31:43.197	debug	(19155) [initialObjects] 'dicLinkedObjectsStatus' items count: 1
          linkeddevices.0	2019-12-15 19:31:43.196	debug	(19155) [createAllLinkedObjects] active linkedObjects {"mqtt.0.h801.switch.ESPURNA_318C6C.brightness.set":"linkeddevices.0.LED-Level.set"}
          linkeddevices.0	2019-12-15 19:31:43.196	info	(19155) [createAllLinkedObjects] count of active linkedObjects: 1
          linkeddevices.0	2019-12-15 19:31:43.195	debug	(19155) [createAllLinkedObjects] 'dicLinkedObjectsStatus' items count: 1
          linkeddevices.0	2019-12-15 19:31:43.179	error	at process._tickCallback (internal/process/next_tick.js:189:7)
          linkeddevices.0	2019-12-15 19:31:43.179	error	at <anonymous>
          linkeddevices.0	2019-12-15 19:31:43.179	error	at Linkeddevices.getConvertedValue (/opt/iobroker/node_modules/iobroker.linkeddevices/main.js:1653:20)
          linkeddevices.0	2019-12-15 19:31:43.179	error	(19155) [createLinkedObject] stack: TypeError: value.replace is not a function
          linkeddevices.0	2019-12-15 19:31:43.178	error	(19155) [createLinkedObject] parentObject 'mqtt.0.h801.switch.ESPURNA_318C6C.brightness.set', linkedObject 'linkeddevices.0.LED-Level.set' error: value.replace is not a function
          linkeddevices.0	2019-12-15 19:31:43.115	debug	(19155) [createLinkedObject] native data set for 'linkeddevices.0.LED-Level.set' ("native":{"topic":"/h801/switch/ESPURNA_318C6C/brightness/set"})
          linkeddevices.0	2019-12-15 19:31:43.115	debug	(19155) [getCustomData] custom expert settings for 'linkeddevices.0.LED-Level.set': {"mergeSettingsOnRestart":true}
          linkeddevices.0	2019-12-15 19:31:43.082	debug	(19155) [getCommonData] common expert settings for 'linkeddevices.0.LED-Level.set': {"type":"number"}
          linkeddevices.0	2019-12-15 19:31:43.079	debug	(19155) [createLinkedObjectChannel] channel 'linkeddevices.0.LED-Level' already exist!
          linkeddevices.0	2019-12-15 19:31:42.691	debug	(19155) [resetAllLinkedObjectsStatus] 'dicLinkedObjectsStatus' items count: 1
          linkeddevices.0	2019-12-15 19:31:42.691	debug	(19155) [resetLinkedObjectStatus] 'isLinked' status reseted for 'linkeddevices.0.LED-Level.set'
          linkeddevices.0	2019-12-15 19:31:42.356	debug	(19155) [getSystemConfig] system configs successful loaded: '{"language":"de","dateFormat":"DD.MM.YYYY","durationFormat":"dd[T] hh[h] mm[m]"}'
          linkeddevices.0	2019-12-15 19:31:42.310	info	(19155) [initialObjects] started...
          linkeddevices.0	2019-12-15 19:31:42.309	debug	(19155) [onReady] deleteDeadLinkedObjects: 'true'
          linkeddevices.0	2019-12-15 19:31:42.283	info	(19155) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.linkeddevices, node: v8.16.2
          linkeddevices.0	2019-12-15 19:31:41.502	debug	(19155) States connected to redis: 127.0.0.1:9000
          linkeddevices.0	2019-12-15 19:31:41.448	debug	(19155) statesDB connected
          linkeddevices.0	2019-12-15 19:31:41.447	debug	(19155) States create PubSub Client
          linkeddevices.0	2019-12-15 19:31:41.441	debug	(19155) Objects connected to redis: 127.0.0.1:9001
          linkeddevices.0	2019-12-15 19:31:41.438	debug	(19155) Redis States: Use Redis connection: 127.0.0.1:9000
          linkeddevices.0	2019-12-15 19:31:41.435	debug	(19155) objectDB connected
          linkeddevices.0	2019-12-15 19:31:41.420	debug	(19155) Objects client initialize lua scripts
          linkeddevices.0	2019-12-15 19:31:41.419	debug	(19155) Objects create PubSub Client
          linkeddevices.0	2019-12-15 19:31:41.414	debug	(19155) Objects client ready ... initialize now
          linkeddevices.0	2019-12-15 19:31:41.369	debug	(19155) Redis Objects: Use Redis connection: 127.0.0.1:9001
          host.home	2019-12-15 19:31:39.894	info	instance system.adapter.linkeddevices.0 started with pid 19155
          host.home	2019-12-15 19:31:37.912	info	instance system.adapter.linkeddevices.0 terminated with code 156 (156)
          linkeddevices.0	2019-12-15 19:31:37.394	info	(17341) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          linkeddevices.0	2019-12-15 19:31:37.393	info	(17341) terminating
          linkeddevices.0	2019-12-15 19:31:37.392	info	(17341) cleaned everything up...
          linkeddevices.0	2019-12-15 19:31:37.389	info	(17341) Got terminate signal TERMINATE_YOURSELF
          host.home	2019-12-15 19:31:37.384	info	stopInstance system.adapter.linkeddevices.0 send kill signal
          • Scrounger
            @jack99n
            Nächster Versuch, bitte den aktuellen master testen.
            Wenn das auch nicht geht, bitte mal auf nodejs 10 updaten, da ich den fehler nicht reproduzieren kann.
              Cool jetzt geht es, danke für deine Mühe!
                enricoh831 last edited by
                Hi Scrounger,
                Toller Adapter hat mir jetzt schon mal weiter geholfen, die Temperatur Werte für Alexa dürfen keine nach Komma stellen haben. Ich hab das immer in einem Script umgerechnet jetzt kann ich einfach ein Link erstellen der automatisch umrechnet.
                Ich habe alle Eingänge und Ausgänge als MQTT Geräte da bekommt man schlecht Struktur rein. Mit deinem Adapter wird das einfacher.
                Aber einen Verbesserungsvorschlag habe ich:
                in der Adapter Einstellung müsste man noch für die verlinkungen den Smartdevice namen einstellen können am besten alles gleich so machen das man nicht mehr in den Cloud Adapter muss. wenn man da 40 Geräte anlegen müsste würde man einen tag brauchen.
                Kannst ja mal gucken ob du sowas mit rein bekommst.
                Schöne Grüße
                Enrico
                Scrounger 1 Reply Last reply Reply Quote 1
                  Habe einen Bug gefunden....
                  hatte bei "Präfix für ID des verlinkten Objektes" den namen Flur EG eingetragen.
                  danach lief kein JS Script mehr.
                  nach ändereung auf Flur_EG klappe es.
                  der Device adapter macht automatisch bei leerzeile einen _.
                  • Scrounger
                    Scrounger Developer @enricoh831 last edited by
                    @enricoh831 sagte in [Neuer Adapter] LinkedDevices:
                    Kannst du mir hier mal ein genaues Beispiel geben, z.B. raw Daten wie das aussehen sollte, dann kann ich das sicher mit einbauen. Ich selber nutze den Cloud Adapter nicht und kenne das deshalb überhaupt nicht.
                    Mhhh, dachte ich hab das eingebaut, ok werd ich mir anschauen.
                      Ich habe das im RAW auch schon mal von Hand eingetragen aber Die Objekte erscheinen dann nicht im Cloud adapter.
                      da muss es noch etwas anderes geben.
                      Da müssten wir mal Bluefox fragen der hat den ja glaube ich geschrieben.
                        Mike Hellracer last edited by
                        Hallo. Ich bekomme es einfach nicht hin die linkeddevices in der Material-ui anzeigen zu lassen. Habe schon sämtliche dp wie das original angelegt. Das original wird als Tür angezeigt aber das Link device wird nicht angezeigt.kann mir jemand helfen?
                        • Ivan Andric
                          Ivan Andric last edited by
                          Frage eines Anfängers...
                          Soweit funktioniert linkeddevices bei mir gut. Habe jedoch jetzt einen Shelly Sensor bei dem ich den Wert für die Luftfeuchtigkeit anpassen muss. Dazu habe ich im Feld "Umrechnung für verlinktes 'read' Objekt" einfach ein "-12" eingetragen. Der Link wird angelegt jedoch erfolgt keine Umrechnung. Der Sensor selber ist "read only".
                          Was mache ich da falsch...?
                          Vielen Dank!
                          Anbei der RAW-Auszug:
                            "from": "system.adapter.shelly.0",
                            "user": "system.user.admin",
                            "ts": 1580067822367,
                            "common": {
                              "name": "Relative humidity",
                              "type": "number",
                              "role": "value.humidity",
                              "unit": "%",
                              "min": 0,
                              "max": 100,
                              "read": true,
                              "write": false,
                              "custom": {
                                "linkeddevices.0": {
                                  "enabled": true,
                                  "number_unit": "%",
                                  "linkedId": "TempSensoren.Wanne.humidity",
                                  "name": "Luftfeuchtigkeit",
                                  "role": "",
                                  "mergeSettingsOnRestart": false,
                                  "expertSettings": true,
                                  "number_convertTo": "",
                                  "number_maxDecimal": 1,
                                  "number_min": "",
                                  "number_max": "",
                                  "number_calculation": "",
                                  "number_calculation_readOnly": -12,
                                  "number_to_boolean_condition": "",
                                  "number_to_boolean_value_true": "",
                                  "number_to_boolean_value_false": "",
                                  "number_to_string_condition": "",
                                  "number_to_duration_convert_seconds": "",
                                  "number_to_duration_format": "",
                                  "number_to_datetime_convert_seconds": "",
                                  "number_to_datetime_format": "",
                                  "number_to_multi_condition": "",
                                  "boolean_convertTo": "",
                                  "boolean_to_string_value_true": "",
                                  "boolean_to_string_value_false": "",
                                  "string_convertTo": "",
                                  "string_prefix": "",
                                  "string_suffix": "",
                                  "string_to_boolean_value_true": "",
                                  "string_to_boolean_value_false": "",
                                  "string_to_number_unit": "",
                                  "string_to_number_maxDecimal": "",
                                  "string_to_number_calculation": "",
                                  "string_to_number_calculation_readOnly": "",
                                  "string_to_duration_format": "",
                                  "string_to_datetime_parser": "",
                                  "string_to_datetime_format": ""
                            "native": {},
                            "acl": {
                              "object": 1638,
                              "owner": "system.user.admin",
                              "state": 1638
                            "_id": "shelly.0.SHHT-1#F3ADBB#1.hum.value",
                            "type": "state"
                            paul53 @Ivan Andric last edited by
                            @Ivan-Andric sagte:
                            Hast Du es so manuell in die RAW-Ansicht eingetragen ? Der Adapter macht es so:
                                    "number_calculation_readOnly": "-12",
                            Ivan Andric 1 Reply Last reply Reply Quote 0
                            • Ivan Andric
                              Ivan Andric @paul53 last edited by
                              @paul53 Nein, ich habe nichts manuell in der RAW-Ansicht angepasst. Habe es jetzt gemacht und es funktioniert. Habe es mal bei einem anderen Sensor ausprobiert und da gab es keine Probleme. Weshalb die Anführungszeichen gefehlt haben kann ich mir nicht erklären. Ich schaue mal was bei den nächsten Sensoren passiert.
                              Vielen Dank!
                                Ich kann die Raw Daten mit dem Handy leider nicht kopieren.
                                Ich habe im übergeordneten Knoten den Type von Channel auf Device geändert. So werden die Geräte auch von dynamischen Abfragen wie Material Ui und anderen gefunden.
                                • Scrounger
                                  Scrounger Developer @Ivan Andric last edited by Scrounger
                                  @Ivan-Andric
                                  Das liegt dran weil der Adapter bei '-12' das als zahl interpretiert, ist wohl ein bug.
                                  Wenn man *1 -12 eingibt dann funktioniert es.
                                  @Mike-Hellracer sagte in [Neuer Adapter] LinkedDevices:
                                  Ok dann schau ich mal ib das geht.
                                    e-s @Scrounger last edited by
                                    @Scrounger
                                    Wollte heute mal ca 20 links auf einmal löschen, unter instances einstellungen habe ich bei denen dann link entfernen gedrückt und speichern und schließen. Leider waren anschließend noch alle links da. Löschen funktioniert also nicht.
                                    Habe auch den haken ganz unten mal rein und mal ausgewählt, macht aber keinen unterschied.
                                    • Scrounger
                                      Scrounger Developer @e-s last edited by
                                      @e-s sagte in [Neuer Adapter] LinkedDevices:
                                      @Scrounger
                                      Stimmt ist bei mir auch so, da hab ich wohl was kaputt gemacht. Schau ich mir an.
                                        Berchemer last edited by
                                        Irgendwie werde ich nicht so ganz schlau draus...
                                        Darf ich kurz fragen welchen Unterschied es zwischen diesem Adapter und den Alias-Geschichten in ioBroker gibt???
                                        arteck ldittmar 2 Replies Last reply Reply Quote 1
                                          arteck Developer Most Active @Berchemer last edited by arteck
                                          @Berchemer zuerst kam der adapter dann der alias.. ich habe mit dem linked adapter schon sachen in meinem System drin und es währe ne motz arbeit das auf alias umzumogeln.. also bleib ich bei.. mehr ist das nich
                                          • ldittmar
                                            ldittmar Developer @Berchemer last edited by
                                            @Berchemer Alias ist im ioBroker integriert. Man braucht also kein Adapter damit es läuft. Das ist eigentlich der Hauptunterschied.
                                            adapter
                                            68
                                            464
                                            94365
