    4. XBox-Adapter Fehler
    SOLVED XBox-Adapter Fehler
    • foxriver76
      foxriver76 Developer @Negalein last edited by
      @Negalein schon mal gut. Ja pip ist nicht installiert, ich habe da was über node mit ausgeliefert falls pip nicht existiert. Ich schaue mal wenn ich am PC bin wie man die Version herausfindet und downgradet.
      Kannst nochmal ein reinstall des Adapters probieren, falls es an fehlenden Libs lag.
      • Negalein
        Negalein Global Moderator @foxriver76 last edited by
        @foxriver76 sagte in XBox-Adapter Fehler:
        noch immer viele Fehler
        $ ./iobroker url "https://github.com/foxriver76/ioBroker.xbox/tarball/master" xbox
        install https://github.com/foxriver76/ioBroker.xbox/tarball/master
        NPM version: 6.11.3
        npm install https://github.com/foxriver76/ioBroker.xbox/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
        In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Integer; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:29:66: warning: ‘v8::Local<v8::Integer> v8::Value::ToInteger() const’ is deprecated: Use maybe version [-Wdeprecated-declarations] To<v8::Integer>(v8::Handle<v8::Integer> i) { return i->ToInteger(); }        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10052:16: note: declared here Local<Integer> Value::ToInteger() const {                ^~~~~
        In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Int32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:34:64: error: no matching function for call to ‘v8::Integer::ToInt32()’ To<v8::Int32>(v8::Handle<v8::Integer> i)   { return i->ToInt32(); }        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note: candidate: v8::MaybeLocal<v8::Int32> v8::Value::ToInt32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Int32> ToInt32(Local<Context> context) const;                                           ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note: candidate: v8::Local<v8::Int32> v8::Value::ToInt32(v8::Isolate*) const                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note:   candidate expects 1 argument, 0 provided                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
        In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Uint32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:39:65: error: no matching function for call to ‘v8::Integer::ToUint32()’ To<v8::Uint32>(v8::Handle<v8::Integer> i)  { return i->ToUint32(); }        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note: candidate: v8::MaybeLocal<v8::Uint32> v8::Value::ToUint32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Uint32> ToUint32(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note:   candidate expects 1 argument, 0 provided
        In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::BooleanObject>::return_t NanIntern::Factory<v8::BooleanObject>::New(bool)’:../node_modules/nan/nan_implementation_12_inl.h:49:38: error: no matching function for call to ‘v8::BooleanObject::New(bool&)’   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                      ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note: candidate: static v8::Local<v8::Value> v8::BooleanObject::New(v8::Isolate*, bool)   static Local<Value> New(Isolate* isolate, bool value);                       ^~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note:   candidate expects 2 arguments, 1 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h:49:60: error: expected primary-expression before ‘>’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                            ^../node_modules/nan/nan_implementation_12_inl.h:49:62: error: expected primary-expression before ‘)’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                              ^
        ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::RegExp>::return_t NanIntern::Factory<v8::RegExp>::New(v8::Handle<v8::String>, v8::RegExp::Flags)’:../node_modules/nan/nan_implementation_12_inl.h:158:40: warning: ‘static v8::Local<v8::RegExp> v8::RegExp::New(v8::Local<v8::String>, v8::RegExp::Flags)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   return v8::RegExp::New(pattern, flags);                                        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5110:38: note: declared here                        Local<RegExp> New(Local<String> pattern, Flags flags));                                      ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:166:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:173:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^
        In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(const uint8_t*, int)’:../node_modules/nan/nan_implementation_12_inl.h:206:42: error: no matching function for call to ‘v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*&, v8::String::NewStringType, int&)’         v8::String::kNormalString, length);                                          ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note: candidate: static v8::MaybeLocal<v8::String> v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::NewStringType, int)   static V8_WARN_UNUSED_RESULT MaybeLocal<String> NewFromOneByte(                                                   ^~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note:   no known conversion for argument 3 from ‘v8::String::NewStringType’ to ‘v8::NewStringType’In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(v8::String::ExternalStringResource*)’:../node_modules/nan/nan_implementation_12_inl.h:217:66: error: no matching function for call to ‘v8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*&)’   return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note: candidate: static v8::Local<v8::String> v8::String::NewExternal(v8::Isolate*, v8::String::ExternalOneByteStringResource*)       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note:   no known conversion for argument 2 from ‘v8::String::ExternalStringResource*’ to ‘v8::String::ExternalOneByteStringResource*’       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~
        In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:237:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~
        ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:244:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~
        In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘uint32_t NanUInt32OptionValue(v8::Local<v8::Object>, v8::Handle<v8::String>, uint32_t)’:../node_modules/nan/nan.h:248:43: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]       ? optionsObj->Get(opt)->Uint32Value()                                           ^
        In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2477:47: note: declared here   V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);                                               ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:261:25: error: redefinition of ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Local<T>)’ NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Local<T> val) {                         ^~~~~~~~~~~~~~~../node_modules/nan/nan.h:256:25: note: ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Handle<T>)’ previously declared here NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Handle<T> val) {                         ^~~~~~~~~~~~~~~
        ../node_modules/nan/nan.h: In function ‘bool NanIdleNotification(int)’:../node_modules/nan/nan.h:289:39: error: ‘class v8::Isolate’ has no member named ‘IdleNotification’; did you mean ‘IdleNotificationDeadline’?     return v8::Isolate::GetCurrent()->IdleNotification(idle_time_in_ms);                                       ^~~~~~~~~~~~~~~~
        ../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:473:20: error: variable or field ‘NanAddGCEpilogueCallback’ declared void       v8::Isolate::GCEpilogueCallback callback                    ^~~~~~~~~~~~~~~~~~
        ../node_modules/nan/nan.h:473:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCEpilogueCallback callback       ^~../node_modules/nan/nan.h:474:18: error: expected primary-expression before ‘gc_type_filter’     , v8::GCType gc_type_filter = v8::kGCTypeAll) {                  ^~~~~~~~~~~~~~../node_modules/nan/nan.h:479:20: error: variable or field ‘NanRemoveGCEpilogueCallback’ declared void       v8::Isolate::GCEpilogueCallback callback) {                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:479:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCEpilogueCallback callback) {       ^~../node_modules/nan/nan.h:484:20: error: variable or field ‘NanAddGCPrologueCallback’ declared void       v8::Isolate::GCPrologueCallback callback                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:484:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCPrologueCallback callback       ^~../node_modules/nan/nan.h:485:18: error: expected primary-expression before ‘gc_type_filter’     , v8::GCType gc_type_filter = v8::kGCTypeAll) {                  ^~~~~~~~~~~~~~../node_modules/nan/nan.h:490:20: error: variable or field ‘NanRemoveGCPrologueCallback’ declared void       v8::Isolate::GCPrologueCallback callback) {                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:490:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCPrologueCallback callback) {       ^~
        ../node_modules/nan/nan.h:569:15: error: ‘WeakCallbackData’ in namespace ‘v8’ does not name a template type     const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {               ^~~~~~~~~~~~~~~~
        ../node_modules/nan/nan.h:569:31: error: expected ‘,’ or ‘...’ before ‘<’ token     const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {                               ^../node_modules/nan/nan.h: In function ‘void _NanWeakCallbackDispatcher(int)’:../node_modules/nan/nan.h:570:42: error: ‘data’ was not declared in this scope       _NanWeakCallbackInfo<T, P> *info = data.GetParameter();                                          ^~~~
        ../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared     , node::smalloc::FreeCallback callback             ^~~~~~~
        ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’     , node::smalloc::FreeCallback callback                                   ^~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(char*, size_t, int)’:../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                  ^~~~~~~~../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                            ^~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(const char*, uint32_t)’:../node_modules/nan/nan.h:672:67: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);        ^In file included from ../src/bufferutil.cc:10:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_buffer.h:68:40: note:   initializing argument 2 of ‘v8::MaybeLocal<v8::Object> node::Buffer::New(v8::Isolate*, char*, size_t)’ NODE_EXTERN v8::MaybeLocal<v8::Object> New(v8::Isolate* isolate,                                        ^~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h:672:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((char*)data), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(uint32_t)’:../node_modules/nan/nan.h:676:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanBufferUse(char*, uint32_t)’:../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’     return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);            ^~~~
        ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan.h:710:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’     return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);        ^
        In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>)’:../node_modules/nan/nan.h:717:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’     return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::UnboundScript>)’:../node_modules/nan/nan.h:723:48: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->BindToCurrentContext()->Run();                                                ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::Script>)’:../node_modules/nan/nan.h:729:24: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->Run();                        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
        In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::Function>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:738:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, func, argc, argv));                                                            ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:177:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::String>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:747:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, symbol, argc, argv));                                                              ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:170:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
        In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, const char*, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:756:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, method, argc, argv));                                                              ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:163:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
        In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In member function ‘v8::Handle<v8::Value> NanCallback::Call_(v8::Isolate*, v8::Handle<v8::Object>, int, v8::Handle<v8::Value>*) const’:../node_modules/nan/nan.h:1569:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]     ));     ^../node_modules/nan/nan.h:398:59: note: in definition of macro ‘NanEscapeScope’ # define NanEscapeScope(val) scope.Escape(_NanEnsureLocal(val))                                                           ^~~In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:177:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
        In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘void* _NanRawString(v8::Handle<v8::Value>, Nan::Encoding, size_t*, void*, size_t, int)’:../node_modules/nan/nan.h:2164:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
        In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h:2198:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
        In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In constructor ‘NanTap::NanTap(v8::Handle<v8::Value>)’:../node_modules/nan/nan.h:2292:41: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     NanAssignPersistent(t_, t->ToObject());                                         ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
        ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Initialize(v8::Handle<v8::Object>)’:../src/bufferutil.cc:30:52: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [7], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "unmask", BufferUtil::Unmask);                                                    ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,             ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,             ^~~~~~~~~~~~~~~../src/bufferutil.cc:31:48: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [5], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "mask", BufferUtil::Mask);                                                ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,             ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,             ^~~~~~~~~~~~~~~../src/bufferutil.cc:32:50: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [6], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "merge", BufferUtil::Merge);                                                  ^
        ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Merge(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/bufferutil.cc:49:49: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> bufferObj = args[0]->ToObject();                                                 ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc:56:51: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]       Local<Object> src = array->Get(i)->ToObject();                                                   ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc: In static member function ‘static void BufferUtil::Unmask(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/bufferutil.cc:67:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> buffer_obj = args[0]->ToObject();                                                  ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc:69:48: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> mask_obj = args[1]->ToObject();                                                ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
        ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Mask(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/bufferutil.cc:88:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> buffer_obj = args[0]->ToObject();                                                  ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
        ../src/bufferutil.cc:89:48: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> mask_obj = args[1]->ToObject();                                                ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc:91:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> output_obj = args[2]->ToObject();                                                  ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc:92:51: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     unsigned int dataOffset = args[3]->Int32Value();                                                   ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2478:46: note: declared here   V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);                                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/bufferutil.cc:93:47: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     unsigned int length = args[4]->Int32Value();                                               ^
        make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Fehler 1
        gyp
         ERR! build error
        gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:193:23)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
        gyp ERR! System Linux 4.4.59+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR!
         cwd /opt/iobroker/node_modules/bufferutilgyp ERR! node -v v10.17.0gyp ERR! node-gyp -v v5.0.3gyp ERR! not ok
        In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/validation.cc:15:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Integer; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:29:66: warning: ‘v8::Local<v8::Integer> v8::Value::ToInteger() const’ is deprecated: Use maybe version [-Wdeprecated-declarations] To<v8::Integer>(v8::Handle<v8::Integer> i) { return i->ToInteger(); }        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10052:16: note: declared here Local<Integer> Value::ToInteger() const {                ^~~~~
        In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/validation.cc:15:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Int32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:34:64: error: no matching function for call to ‘v8::Integer::ToInt32()’ To<v8::Int32>(v8::Handle<v8::Integer> i)   { return i->ToInt32(); }        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note: candidate: v8::MaybeLocal<v8::Int32> v8::Value::ToInt32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Int32> ToInt32(Local<Context> context) const;                                           ^~~~~~~
        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note: candidate: v8::Local<v8::Int32> v8::Value::ToInt32(v8::Isolate*) const                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note:   candidate expects 1 argument, 0 provided                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
        In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/validation.cc:15:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Uint32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:39:65: error: no matching function for call to ‘v8::Integer::ToUint32()’ To<v8::Uint32>(v8::Handle<v8::Integer> i)  { return i->ToUint32(); }        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note: candidate: v8::MaybeLocal<v8::Uint32> v8::Value::ToUint32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Uint32> ToUint32(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note:   candidate expects 1 argument, 0 provided
        In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::BooleanObject>::return_t NanIntern::Factory<v8::BooleanObject>::New(bool)’:../node_modules/nan/nan_implementation_12_inl.h:49:38: error: no matching function for call to ‘v8::BooleanObject::New(bool&)’   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                      ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note: candidate: static v8::Local<v8::Value> v8::BooleanObject::New(v8::Isolate*, bool)   static Local<Value> New(Isolate* isolate, bool value);                       ^~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note:   candidate expects 2 arguments, 1 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h:49:60: error: expected primary-expression before ‘>’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                            ^../node_modules/nan/nan_implementation_12_inl.h:49:62: error: expected primary-expression before ‘)’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                              ^
        ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::RegExp>::return_t NanIntern::Factory<v8::RegExp>::New(v8::Handle<v8::String>, v8::RegExp::Flags)’:../node_modules/nan/nan_implementation_12_inl.h:158:40: warning: ‘static v8::Local<v8::RegExp> v8::RegExp::New(v8::Local<v8::String>, v8::RegExp::Flags)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   return v8::RegExp::New(pattern, flags);                                        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5110:38: note: declared here                        Local<RegExp> New(Local<String> pattern, Flags flags));                                      ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:166:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:173:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(const uint8_t*, int)’:../node_modules/nan/nan_implementation_12_inl.h:206:42: error: no matching function for call to ‘v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*&, v8::String::NewStringType, int&)’         v8::String::kNormalString, length);                                          ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note: candidate: static v8::MaybeLocal<v8::String> v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::NewStringType, int)   static V8_WARN_UNUSED_RESULT MaybeLocal<String> NewFromOneByte(                                                   ^~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note:   no known conversion for argument 3 from ‘v8::String::NewStringType’ to ‘v8::NewStringType’In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(v8::String::ExternalStringResource*)’:../node_modules/nan/nan_implementation_12_inl.h:217:66: error: no matching function for call to ‘v8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*&)’   return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note: candidate: static v8::Local<v8::String> v8::String::NewExternal(v8::Isolate*, v8::String::ExternalOneByteStringResource*)       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note:   no known conversion for argument 2 from ‘v8::String::ExternalStringResource*’ to ‘v8::String::ExternalOneByteStringResource*’       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:237:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:244:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~
        In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘uint32_t NanUInt32OptionValue(v8::Local<v8::Object>, v8::Handle<v8::String>, uint32_t)’:../node_modules/nan/nan.h:248:43: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]       ? optionsObj->Get(opt)->Uint32Value()                                           ^
        In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2477:47: note: declared here   V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);                                               ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:261:25: error: redefinition of ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Local<T>)’ NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Local<T> val) {                         ^~~~~~~~~~~~~~~../node_modules/nan/nan.h:256:25: note: ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Handle<T>)’ previously declared here NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Handle<T> val) {                         ^~~~~~~~~~~~~~~
        ../node_modules/nan/nan.h:569:15: error: ‘WeakCallbackData’ in namespace ‘v8’ does not name a template type     const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {               ^~~~~~~~~~~~~~~~../node_modules/nan/nan.h:569:31: error: expected ‘,’ or ‘...’ before ‘<’ token     const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {                               ^../node_modules/nan/nan.h: In function ‘void _NanWeakCallbackDispatcher(int)’:../node_modules/nan/nan.h:570:42: error: ‘data’ was not declared in this scope       _NanWeakCallbackInfo<T, P> *info = data.GetParameter();                                          ^~~~
        ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’     , node::smalloc::FreeCallback callback                                   ^~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(char*, size_t, int)’:../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                  ^~~~~~~~../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                            ^~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(const char*, uint32_t)’:../node_modules/nan/nan.h:672:67: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);        ^In file included from ../src/validation.cc:10:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_buffer.h:68:40: note:   initializing argument 2 of ‘v8::MaybeLocal<v8::Object> node::Buffer::New(v8::Isolate*, char*, size_t)’ NODE_EXTERN v8::MaybeLocal<v8::Object> New(v8::Isolate* isolate,                                        ^~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h:672:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((char*)data), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(uint32_t)’:../node_modules/nan/nan.h:676:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanBufferUse(char*, uint32_t)’:../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’     return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);            ^~~~
        In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>)’:../node_modules/nan/nan.h:717:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’     return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::UnboundScript>)’:../node_modules/nan/nan.h:723:48: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->BindToCurrentContext()->Run();                                                ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::Script>)’:../node_modules/nan/nan.h:729:24: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->Run();                        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
        In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::Function>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:738:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, func, argc, argv));                                                            ^In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:177:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::String>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:747:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, symbol, argc, argv));                                                              ^In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:170:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
        In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, const char*, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:756:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, method, argc, argv));                                                              ^In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:163:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
        In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In member function ‘v8::Handle<v8::Value> NanCallback::Call_(v8::Isolate*, v8::Handle<v8::Object>, int, v8::Handle<v8::Value>*) const’:../node_modules/nan/nan.h:1569:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]     ));     ^../node_modules/nan/nan.h:398:59: note: in definition of macro ‘NanEscapeScope’ # define NanEscapeScope(val) scope.Escape(_NanEnsureLocal(val))                                                           ^~~
        In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘void* _NanRawString(v8::Handle<v8::Value>, Nan::Encoding, size_t*, void*, size_t, int)’:../node_modules/nan/nan.h:2164:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h:2198:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In constructor ‘NanTap::NanTap(v8::Handle<v8::Value>)’:../node_modules/nan/nan.h:2292:41: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     NanAssignPersistent(t_, t->ToObject());                                         ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
        ../src/validation.cc: In static member function ‘static void Validation::Initialize(v8::Handle<v8::Object>)’:../src/validation.cc:112:62: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [12], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "isValidUTF8", Validation::IsValidUTF8);                                                              ^In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,             ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,             ^~~~~~~~~~~~~~~
        ../src/validation.cc: In static member function ‘static void Validation::IsValidUTF8(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/validation.cc:132:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> buffer_obj = args[0]->ToObject();                                                  ^
        make: *** [Release/obj.target/validation/src/validation.o] Fehler 1
        gyp
         ERR! build error
        gyp ERR! System Linux 4.4.59+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validategyp ERR! node -v v10.17.0gyp ERR!
        ERROR: xbox-smartglass-core 1.0.12 has requirement urwid==2.0.1, but you'll have urwid 2.1.0 which is incompatible.
        upload [2] xbox.admin /opt/iobroker/node_modules/iobroker.xbox/admin/xbox.png xbox.png image/png
        upload [1] xbox.admin /opt/iobroker/node_modules/iobroker.xbox/admin/words.js words.js application/javascript
        upload [0] xbox.admin /opt/iobroker/node_modules/iobroker.xbox/admin/index_m.html index_m.html text/html
        process exited with code 0
        • foxriver76
          foxriver76 Developer @Negalein last edited by
          @Negalein
          Mach mal bitte eine händische Installation.
          1. rm -r /opt/iobroker/node_modules/iobroker.xbox/
          2. npm i iobroker.xbox --unsafe-perm --prefix /opt/iobroker --production
          • Negalein
            Negalein Global Moderator @foxriver76 last edited by
            @foxriver76 sagte in XBox-Adapter Fehler:
            da kommt bei Enter nur eine neue Zeile. Sonst keine Meldung.
            hier der Log (leider der Anfang abgeschnitten)
            ../node_modules/nan/nan.h:738:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ isdeprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
            ../node_modules/nan/nan.h:756:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated:Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
            ../node_modules/nan/nan.h:1569:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ isdeprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
            bufferutil.target.mk:105: die Regel für Ziel „Release/obj.target/bufferutil/src/bufferutil.o“ scheiterte
            make: Verzeichnis „/opt/iobroker/node_modules/bufferutil/build“ wird verlassen
            gyp ERR! build error
            gyp ERR! cwd /opt/iobroker/node_modules/bufferutil
            gyp ERR! not ok
            > utf-8-validate@1.1.0 install /opt/iobroker/node_modules/utf-8-validate
            > node-gyp rebuild
            make: Verzeichnis „/opt/iobroker/node_modules/utf-8-validate/build“ wird betreten
              CXX(target) Release/obj.target/validation/src/validation.o
            ../src/validation.cc:112:62: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [12], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’is ambiguous
            validation.target.mk:105: die Regel für Ziel „Release/obj.target/validation/src/validation.o“ scheiterte
            make: Verzeichnis „/opt/iobroker/node_modules/utf-8-validate/build“ wird verlassen
            gyp ERR! not ok
            > iobroker.xbox@0.5.12 install /opt/iobroker/node_modules/iobroker.xbox
            > npip install
            No python_modules directory; installing pip locally if needed.
            Successfully completed pip check.
            Collecting xbox-smartglass-rest>=0.9.8
              Using cached https://files.pythonhosted.org/packages/4d/4f/f035df8a2ec5742b9e772071e006ea21aae3fc3bd0963753cfc1045d6fda/xbox_smartglass_rest-0.9.8-py2.py3-none-any.whl
            Collecting xbox-webapi>=1.1.7
              Using cached https://files.pythonhosted.org/packages/2d/bf/aaf24cc78184393c5c2472e822c0e145b793e346a8085bee02e89a3428ba/xbox_webapi-1.1.7-py2.py3-none-any.whl
            Collecting xbox-smartglass-core>=1.0.12
              Using cached https://files.pythonhosted.org/packages/13/c8/2ffce1ddabe5b73422c7c46e808e4b02dbbc9362d2ecd2aee2a65e6e30a5/xbox_smartglass_core-1.0.12-py2.py3-none-any.whl
            Collecting xbox-smartglass-stump>=0.9.5
              Using cached https://files.pythonhosted.org/packages/34/f0/a75667f67ce6251b96a6989b8169eb9f2e25407ce2b0888e544b8caa98fe/xbox_smartglass_stump-0.9.5-py2.py3-none-any.whl
            Collecting Flask
              Using cached https://files.pythonhosted.org/packages/9b/93/628509b8d5dc749656a9641f4caf13540e2cdec85276964ff8f43bbb1d3b/Flask-1.1.1-py2.py3-none-any.whl
            Processing /home/iobroker/.cache/pip/wheels/49/b5/ad/7355506059779337473b8eeb49384c9c0a9d45d34c8211a96d/urwid-2.1.0-cp35-cp35m-linux_x86_64.whl
            Collecting appdirs
              Using cached https://files.pythonhosted.org/packages/56/eb/810e700ed1349edde4cbdc1b2a21e28cdf115f9faf263f6bbf8447c1abf3/appdirs-1.4.3-py2.py3-none-any.whl
            Collecting requests
              Using cached https://files.pythonhosted.org/packages/51/bd/23c926cd341ea6b7dd0b2a00aba99ae0f828be89d72b2190f27c11d4b7fb/requests-2.22.0-py2.py3-none-any.whl
            Processing /home/iobroker/.cache/pip/wheels/c5/d2/ab/a54fb5ea53ac3badba098160e8452fa126a51febda80440ded/demjson-2.2.4-cp35-none-any.whl
            Processing /home/iobroker/.cache/pip/wheels/13/cd/02/acabe4bfa9899d53c3e3b13675610d2e2dcb9ae110359d4f61/construct-2.9.41-cp35-none-any.whl
            Collecting cryptography==2.3.1
              Using cached https://files.pythonhosted.org/packages/59/32/92cade62c645756a83598edf56289e9b19aae5370642a7ce690cd06bc72f/cryptography-2.3.1-cp34-abi3-manylinux1_x86_64.whl
            Collecting gevent==1.3.7
              Using cached https://files.pythonhosted.org/packages/87/c4/9afb40b4a8b9186787d477aa6ebcfa17ead40ecbf83d5a1ed53dadd4f6ef/gevent-1.3.7-cp35-cp35m-manylinux1_x86_64.whl
            Collecting aenum==2.1.2; python_version <= "3.5"
              Using cached https://files.pythonhosted.org/packages/0d/46/5b6a6c13fee40f9dfaba84de1394bfe082c0c7d95952ba0ffbd56ce3a3f7/aenum-2.1.2-py3-none-any.whl
            Processing /home/iobroker/.cache/pip/wheels/0a/5f/3c/e0ffceb6554711f12a7101384f29ec13b85136dfcf1f692b8f/dpkt-1.9.1-cp35-none-any.whl
            Collecting marshmallow-objects
              Using cached https://files.pythonhosted.org/packages/4d/1c/fe15bc370707e8f8db09ab0edead45ab413b75795a8be523ca6482152183/marshmallow_objects-2.0.0-py2.py3-none-any.whl
            Collecting Werkzeug>=0.15
              Using cached https://files.pythonhosted.org/packages/ce/42/3aeda98f96e85fd26180534d36570e4d18108d62ae36f87694b476b83d6f/Werkzeug-0.16.0-py2.py3-none-any.whl
            Collecting Jinja2>=2.10.1
              Using cached https://files.pythonhosted.org/packages/65/e0/eb35e762802015cab1ccee04e8a277b03f1d8e53da3ec3106882ec42558b/Jinja2-2.10.3-py2.py3-none-any.whl
            Collecting click>=5.1
              Using cached https://files.pythonhosted.org/packages/fa/37/45185cb5abbc30d7257104c434fe0b07e5a195a6847506c074527aa599ec/Click-7.0-py2.py3-none-any.whl
            Collecting itsdangerous>=0.24
              Using cached https://files.pythonhosted.org/packages/76/ae/44b03b253d6fade317f32c24d100b3b35c2239807046a4c953c7b89fa49e/itsdangerous-1.1.0-py2.py3-none-any.whl
            Collecting chardet<3.1.0,>=3.0.2
              Using cached https://files.pythonhosted.org/packages/bc/a9/01ffebfb562e4274b6487b4bb1ddec7ca55ec7510b22e4c51f14098443b8/chardet-3.0.4-py2.py3-none-any.whl
            Collecting urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1
              Using cached https://files.pythonhosted.org/packages/b4/40/a9837291310ee1ccc242ceb6ebfd9eb21539649f193a7c8c86ba15b98539/urllib3-1.25.7-py2.py3-none-any.whl
            Collecting idna<2.9,>=2.5
              Using cached https://files.pythonhosted.org/packages/14/2c/cd551d81dbe15200be1cf41cd03869a46fe7226e7450af7a6545bfc474c9/idna-2.8-py2.py3-none-any.whl
            Collecting certifi>=2017.4.17
              Using cached https://files.pythonhosted.org/packages/b9/63/df50cac98ea0d5b006c55a399c3bf1db9da7b5a24de7890bc9cfd5dd9e99/certifi-2019.11.28-py2.py3-none-any.whl
            Collecting cffi!=1.11.3,>=1.7
              Using cached https://files.pythonhosted.org/packages/a8/8d/986e0c4e2aa3b24db56a0affc50d1a379150e3c4da45d51d549dc2697d53/cffi-1.13.2-cp35-cp35m-manylinux1_x86_64.whl
            Collecting asn1crypto>=0.21.0
              Using cached https://files.pythonhosted.org/packages/e9/51/1db4a60049fb7390959be586b6eb743098e6cea3f6b2d3ed9e17fec62ba2/asn1crypto-1.3.0-py2.py3-none-any.whl
            Collecting six>=1.4.1
              Using cached https://files.pythonhosted.org/packages/65/eb/1f97cb97bfc2390a276969c6fae16075da282f5058082d4cb10c6c5c1dba/six-1.14.0-py2.py3-none-any.whl
            Collecting greenlet>=0.4.14; platform_python_implementation == "CPython"
              Using cached https://files.pythonhosted.org/packages/2e/65/27f35497cc0102a792390d056e793e064da95fc9eae45d75ae0ba49c0a0d/greenlet-0.4.15-cp35-cp35m-manylinux1_x86_64.whl
            Collecting marshmallow>=3.0.0
              Using cached https://files.pythonhosted.org/packages/6e/76/01224f14737627166b94eb3bf0e334372c014edca781e39db320ce977755/marshmallow-3.3.0-py2.py3-none-any.whl
            Collecting MarkupSafe>=0.23
              Using cached https://files.pythonhosted.org/packages/6e/57/d40124076756c19ff2269678de7ae25a14ebbb3f6314eb5ce9477f191350/MarkupSafe-1.1.1-cp35-cp35m-manylinux1_x86_64.whl
            Processing /home/iobroker/.cache/pip/wheels/f2/9a/90/de94f8556265ddc9d9c8b271b0f63e57b26fb1d67a45564511/pycparser-2.19-py2.py3-none-any.whl
            Installing collected packages: urwid, appdirs, chardet, urllib3, idna, certifi, requests, demjson, xbox-webapi, construct, pycparser, cffi, asn1crypto, six, cryptography, greenlet, gevent, aenum, dpkt, xbox-smartglass-core, marshmallow, marshmallow-objects, xbox-smartglass-stump, Werkzeug, MarkupSafe, Jinja2, click, itsdangerous, Flask, xbox-smartglass-rest
            Successfully installed Flask-1.1.1 Jinja2-2.10.3 MarkupSafe-1.1.1 Werkzeug-0.16.0 aenum-2.1.2 appdirs-1.4.3 asn1crypto-1.3.0 certifi-2019.11.28 cffi-1.13.2 chardet-3.0.4 click-7.0 construct-2.9.41 cryptography-2.3.1 demjson-2.2.4 dpkt-1.9.1 gevent-1.3.7 greenlet-0.4.15 idna-2.8 itsdangerous-1.1.0 marshmallow-3.3.0 marshmallow-objects-2.0.0 pycparser-2.19 requests-2.22.0 six-1.14.0 urllib3-1.25.7 urwid-2.1.0 xbox-smartglass-core-1.0.12 xbox-smartglass-rest-0.9.8 xbox-smartglass-stump-0.9.5 xbox-webapi-1.1.7
            npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/iobroker.type-detector'
            npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.
            npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 (node_modules/bufferutil):
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 install: `node-gyp rebuild`
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 (node_modules/utf-8-validate):
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 install: `node-gyp rebuild`
            + iobroker.xbox@0.5.12
            added 3 packages from 3 contributors in 72.319s
            Adapter bleibt gelb
            xbox.0	2020-01-17 23:55:17.849	warn	(1910) [LOGIN] Connection refused, will try again
            xbox.0	2020-01-17 23:55:17.848	debug	(1910) Could not parse body
            xbox.0	2020-01-17 23:55:16.846	warn	(1910) [LOGIN] Connection refused, will try again
            xbox.0	2020-01-17 23:55:16.845	debug	(1910) Could not parse body
            xbox.0	2020-01-17 23:55:15.842	warn	(1910) [LOGIN] Connection refused, will try again
            xbox.0	2020-01-17 23:55:15.842	debug	(1910) Could not parse body
            xbox.0	2020-01-17 23:55:14.839	warn	(1910) [LOGIN] Connection refused, will try again
            xbox.0	2020-01-17 23:55:14.839	debug	(1910) Could not parse body
            xbox.0	2020-01-17 23:55:13.836	warn	(1910) [LOGIN] Connection refused, will try again
            xbox.0	2020-01-17 23:55:13.836	debug	(1910) Could not parse body
            xbox.0	2020-01-17 23:55:13.803	debug	(1910) [CHECK] Auth is not established
            xbox.0	2020-01-17 23:55:13.800	debug	(1910) [CONNECT] Ping response, but provided LiveID has not been discovered until now
            xbox.0	2020-01-17 23:55:13.799	debug	(1910) [CONNECT] Check connection
            xbox.0	2020-01-17 23:55:13.789	error	(1910) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
            xbox.0	2020-01-17 23:55:13.784	debug	(1910) [DISCOVER] Searching for consoles
            xbox.0	2020-01-17 23:55:13.781	debug	(1910) [PING] Xbox online
            xbox.0	2020-01-17 23:55:12.833	warn	(1910) [LOGIN] Connection refused, will try again
            xbox.0	2020-01-17 23:55:12.832	debug	(1910) Could not parse body
            xbox.0	2020-01-17 23:55:11.830	warn	(1910) [LOGIN] Connection refused, will try again
            xbox.0	2020-01-17 23:55:11.830	debug	(1910) Could not parse body
            xbox.0	2020-01-17 23:55:10.827	warn	(1910) [LOGIN] Connection refused, will try again
            xbox.0	2020-01-17 23:55:10.827	debug	(1910) Could not parse body
            xbox.0	2020-01-17 23:55:09.824	warn	(1910) [LOGIN] Connection refused, will try again
            xbox.0	2020-01-17 23:55:09.823	debug	(1910) Could not parse body
            xbox.0	2020-01-17 23:55:08.821	warn	(1910) [LOGIN] Connection refused, will try again
            xbox.0	2020-01-17 23:55:08.821	debug	(1910) Could not parse body
            xbox.0	2020-01-17 23:55:07.818	warn	(1910) [LOGIN] Connection refused, will try again
            xbox.0	2020-01-17 23:55:07.818	debug	(1910) Could not parse body
            xbox.0	2020-01-17 23:55:07.811	warn	(1910) [CONNECT] Ping response, but provided LiveID has not been discovered until now
            xbox.0	2020-01-17 23:55:07.811	debug	(1910) [CONNECT] Check connection
            xbox.0	2020-01-17 23:55:07.809	error	(1910) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
            xbox.0	2020-01-17 23:55:07.806	debug	(1910) [CHECK] Auth is not established
            xbox.0	2020-01-17 23:55:07.800	debug	(1910) [DISCOVER] Searching for consoles
            xbox.0	2020-01-17 23:55:07.791	debug	(1910) [PING] Xbox online
            xbox.0	2020-01-17 23:55:06.813	warn	(1910) [LOGIN] Connection refused, will try again
            xbox.0	2020-01-17 23:55:06.813	debug	(1910) Could not parse body
            xbox.0	2020-01-17 23:55:05.810	warn	(1910) [LOGIN] Connection refused, will try again
            xbox.0	2020-01-17 23:55:05.809	debug	(1910) Could not parse body
            xbox.0	2020-01-17 23:55:04.806	warn	(1910) [LOGIN] Connection refused, will try again
            xbox.0	2020-01-17 23:55:04.805	debug	(1910) Could not parse body
            xbox.0	2020-01-17 23:55:03.802	warn	(1910) [LOGIN] Connection refused, will try again
            xbox.0	2020-01-17 23:55:03.801	debug	(1910) Could not parse body
            xbox.0	2020-01-17 23:55:02.797	warn	(1910) [LOGIN] Connection refused, will try again
            xbox.0	2020-01-17 23:55:02.797	debug	(1910) Could not parse body
            xbox.0	2020-01-17 23:55:01.794	warn	(1910) [LOGIN] Connection refused, will try again
            xbox.0	2020-01-17 23:55:01.794	debug	(1910) Could not parse body
            xbox.0	2020-01-17 23:55:01.784	debug	(1910) [LOGOUT] <=== Failed to logout: undefined
            xbox.0	2020-01-17 23:54:56.949	error	(1910) [START] Restarting adapter in 30 seconds
            xbox.0	2020-01-17 23:54:56.949	error	(1910) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found Traceback (most recent call last): File "/opt/iobroke
            xbox.0	2020-01-17 23:54:55.208	info	(1910) [START] Starting REST server
            xbox.0	2020-01-17 23:54:55.208	debug	(1910) [START] IP address is 10.0.1.83
            xbox.0	2020-01-17 23:54:55.182	info	(1910) starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.17.0
            • foxriver76
              @Negalein sagte in XBox-Adapter Fehler:
              Evtl liegt es nur daran. Mal folgendes probieren: curl https://bootstrap.pypa.io/get-pip.py -o get-pip.py dann python get-pip.py dann pip install "urwid==2.0.1". Trotzdem strange, dass urwid in der falschen Version drauf ist wobei nicht mal pip installiert ist und somit vermutlich keine Konflikte existieren sollten. Vermutlich könnten die Jungs vom Xbox-Rest-Server auch mit >=2.0.1 kompatibel sein.
              • Negalein
                root@iobroker:/opt/iobroker# curl https://bootstrap.pypa.io/get-pip.py -o get-pip.py
                  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                                 Dload  Upload   Total   Spent    Left  Speed
                100 1734k  100 1734k    0     0  2644k      0 --:--:-- --:--:-- --:--:-- 2647k
                root@iobroker:/opt/iobroker# python get-pip.py
                DEPRECATION: Python 2.7 will reach the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 won't be maintained after that date. A future version of pip will drop support for Python 2.7. More details about Python 2 support in pip, can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support
                Collecting pip
                  Downloading https://files.pythonhosted.org/packages/00/b6/9cfa56b4081ad13874b0c6f96af8ce16cfbc1cb06bedf8e9164ce5551ec1/pip-19.3.1-py2.py3-none-any.whl (1.4MB)
                     |████████████████████████████████| 1.4MB 1.1MB/s
                Collecting setuptools
                  Downloading https://files.pythonhosted.org/packages/f9/d3/955738b20d3832dfa3cd3d9b07e29a8162edb480bf988332f5e6e48ca444/setuptools-44.0.0-py2.py3-none-any.whl (583kB)
                     |████████████████████████████████| 583kB 3.1MB/s
                Collecting wheel
                  Downloading https://files.pythonhosted.org/packages/00/83/b4a77d044e78ad1a45610eb88f745be2fd2c6d658f9798a15e384b7d57c9/wheel-0.33.6-py2.py3-none-any.whl
                Installing collected packages: pip, setuptools, wheel
                Successfully installed pip-19.3.1 setuptools-44.0.0 wheel-0.33.6
                root@iobroker:/opt/iobroker# pip install "urwid==2.0.1"
                Collecting urwid==2.0.1
                  Downloading https://files.pythonhosted.org/packages/c7/90/415728875c230fafd13d118512bde3184d810d7bf798a631abc05fac09d0/urwid-2.0.1.tar.gz (604kB)
                     |████████████████████████████████| 614kB 1.2MB/s
                Building wheels for collected packages: urwid
                  Building wheel for urwid (setup.py) ... done
                  Created wheel for urwid: filename=urwid-2.0.1-cp27-none-any.whl size=223811 sha256=62989cc247db2deb465ac357ec891d2e89e4c03904d6c8288c414afca14b37db
                  Stored in directory: /root/.cache/pip/wheels/34/06/50/24011714e101b5ad8518c69175d117a257413e3c15a92983f0
                Successfully built urwid
                Successfully installed urwid-2.0.1
                Adapter weiterhin gelb
                xbox.0	2020-01-18 00:53:21.860	info	(8629) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                xbox.0	2020-01-18 00:53:21.859	info	(8629) terminating
                xbox.0	2020-01-18 00:53:21.858	info	(8629) [END] cleaned everything up...
                xbox.0	2020-01-18 00:53:21.844	info	(8629) [END] REST server stopped
                xbox.0	2020-01-18 00:53:21.830	debug	(8629) [LOGOUT] <=== Failed to logout: undefined
                xbox.0	2020-01-18 00:53:21.824	info	(8629) Got terminate signal TERMINATE_YOURSELF
                xbox.0	2020-01-18 00:53:21.653	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:53:21.653	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:53:20.649	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:53:20.648	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:53:20.557	debug	(8629) [CHECK] Auth is not established
                xbox.0	2020-01-18 00:53:20.555	debug	(8629) [CONNECT] Ping response, but provided LiveID has not been discovered until now
                xbox.0	2020-01-18 00:53:20.554	debug	(8629) [CONNECT] Check connection
                xbox.0	2020-01-18 00:53:20.553	error	(8629) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
                xbox.0	2020-01-18 00:53:20.547	debug	(8629) [DISCOVER] Searching for consoles
                xbox.0	2020-01-18 00:53:20.543	debug	(8629) [PING] Xbox online
                xbox.0	2020-01-18 00:53:19.640	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:53:19.640	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:53:18.637	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:53:18.637	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:53:17.634	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:53:17.633	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:53:16.630	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:53:16.629	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:53:15.627	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:53:15.627	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:53:14.624	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:53:14.623	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:53:14.547	debug	(8629) [CHECK] Auth is not established
                xbox.0	2020-01-18 00:53:14.546	debug	(8629) [CONNECT] Ping response, but provided LiveID has not been discovered until now
                xbox.0	2020-01-18 00:53:14.545	debug	(8629) [CONNECT] Check connection
                xbox.0	2020-01-18 00:53:14.544	error	(8629) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
                xbox.0	2020-01-18 00:53:14.541	debug	(8629) [DISCOVER] Searching for consoles
                xbox.0	2020-01-18 00:53:14.539	debug	(8629) [PING] Xbox online
                xbox.0	2020-01-18 00:53:13.621	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:53:13.621	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:53:12.618	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:53:12.617	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:53:11.615	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:53:11.615	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:53:10.612	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:53:10.611	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:53:09.608	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:53:09.599	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:53:08.596	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:53:08.595	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:53:08.549	debug	(8629) [CHECK] Auth is not established
                xbox.0	2020-01-18 00:53:08.547	debug	(8629) [CONNECT] Ping response, but provided LiveID has not been discovered until now
                xbox.0	2020-01-18 00:53:08.547	debug	(8629) [CONNECT] Check connection
                xbox.0	2020-01-18 00:53:08.546	error	(8629) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
                xbox.0	2020-01-18 00:53:08.543	debug	(8629) [DISCOVER] Searching for consoles
                xbox.0	2020-01-18 00:53:08.540	debug	(8629) [PING] Xbox online
                xbox.0	2020-01-18 00:53:07.593	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:53:07.593	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:53:06.590	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:53:06.589	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:53:05.586	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:53:05.585	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:53:04.583	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:53:04.582	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:53:03.580	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:53:03.580	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:53:02.577	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:53:02.577	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:53:02.561	debug	(8629) [CHECK] Auth is not established
                xbox.0	2020-01-18 00:53:02.559	warn	(8629) [CONNECT] Ping response, but provided LiveID has not been discovered until now
                xbox.0	2020-01-18 00:53:02.558	debug	(8629) [CONNECT] Check connection
                xbox.0	2020-01-18 00:53:02.556	error	(8629) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
                xbox.0	2020-01-18 00:53:02.552	debug	(8629) [DISCOVER] Searching for consoles
                xbox.0	2020-01-18 00:53:02.547	debug	(8629) [PING] Xbox online
                xbox.0	2020-01-18 00:53:01.575	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:53:01.575	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:53:00.572	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:53:00.572	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:52:59.568	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:52:59.568	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:52:58.564	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:52:58.563	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:52:57.560	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:52:57.559	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:52:56.554	warn	(8629) [LOGIN] Connection refused, will try again
                xbox.0	2020-01-18 00:52:56.554	debug	(8629) Could not parse body
                xbox.0	2020-01-18 00:52:56.543	debug	(8629) [LOGOUT] <=== Failed to logout: undefined
                xbox.0	2020-01-18 00:52:54.718	debug	(8629) system.adapter.admin.0: logging true
                xbox.0	2020-01-18 00:52:51.805	error	(8629) [START] Restarting adapter in 30 seconds
                xbox.0	2020-01-18 00:52:51.804	error	SyntaxError: invalid syntax
                xbox.0	2020-01-18 00:52:51.804	error	^
                xbox.0	2020-01-18 00:52:51.804	error	cls, data, context=None, many=None, partial=None, unknown=None, *args, **kwargs,
                xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/marshmallow_objects/models.py", line 209
                xbox.0	2020-01-18 00:52:51.804	error	from marshmallow_objects.models import ( # noqa
                xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/marshmallow_objects/__init__.py", line 3, in <module>
                xbox.0	2020-01-18 00:52:51.804	error	from marshmallow_objects import Model, NestedModel, fields
                xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/stump/json_model.py", line 4, in <module>
                xbox.0	2020-01-18 00:52:51.804	error	from xbox.stump import json_model
                xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/stump/manager.py", line 13, in <module>
                xbox.0	2020-01-18 00:52:51.804	error	from xbox.stump.manager import StumpManager
                xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/consolewrap.py", line 6, in <module>
                xbox.0	2020-01-18 00:52:51.804	error	from ..consolewrap import ConsoleWrap
                xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/routes/device.py", line 6, in <module>
                xbox.0	2020-01-18 00:52:51.804	error	from .device import *
                xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/routes/__init__.py", line 6, in <module>
                xbox.0	2020-01-18 00:52:51.804	error	from .routes import routes
                xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/app.py", line 5, in <module>
                xbox.0	2020-01-18 00:52:51.804	error	from xbox.rest.app import app
                xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/scripts/rest_server.py", line 9, in <module>
                xbox.0	2020-01-18 00:52:51.804	error	from xbox.rest.scripts.rest_server import main
                xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server", line 5, in <module>
                xbox.0	2020-01-18 00:52:51.804	error	Traceback (most recent call last):
                xbox.0	2020-01-18 00:52:51.804	error	(8629) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
                xbox.0	2020-01-18 00:52:49.985	info	(8629) [START] Starting REST server
                xbox.0	2020-01-18 00:52:49.985	debug	(8629) [START] IP address is 10.0.1.83
                xbox.0	2020-01-18 00:52:49.962	info	(8629) starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.17.0
                xbox.0	2020-01-18 00:52:47.961	debug	(8629) States connected to redis: 0.0.0.0:9000
                xbox.0	2020-01-18 00:52:47.909	debug	(8629) statesDB connected
                xbox.0	2020-01-18 00:52:47.908	debug	(8629) States create PubSub Client
                xbox.0	2020-01-18 00:52:47.898	debug	(8629) Objects connected to redis: 0.0.0.0:9001
                xbox.0	2020-01-18 00:52:47.896	debug	(8629) Redis States: Use Redis connection: 0.0.0.0:9000
                xbox.0	2020-01-18 00:52:47.894	debug	(8629) objectDB connected
                xbox.0	2020-01-18 00:52:47.883	debug	(8629) Objects client initialize lua scripts
                xbox.0	2020-01-18 00:52:47.882	debug	(8629) Objects create PubSub Client
                xbox.0	2020-01-18 00:52:47.873	debug	(8629) Objects client ready ... initialize now
                xbox.0	2020-01-18 00:52:47.840	debug	(8629) Redis Objects: Use Redis connection: 0.0.0.0:9001
                • foxriver76
                  @Negalein braucht gerade immer ein reinstall sorry: npm i iobroker.xbox --unsafe-perm --prefix /opt/iobroker --production
                  • Negalein
                                     from ../src/bufferutil.cc:16:
                    In file included from ../src/bufferutil.cc:16:0:
                    ../node_modules/nan/nan.h: In function ‘bool NanIdleNotification(int)’:
                    ../node_modules/nan/nan.h:289:39: error: ‘class v8::Isolate’ has no member named ‘IdleNotification’; did you mean ‘IdleNotificationDeadline’?
                         return v8::Isolate::GetCurrent()->IdleNotification(idle_time_in_ms);
                    ../node_modules/nan/nan.h:473:20: error: variable or field ‘NanAddGCEpilogueCallback’ declared void
                           v8::Isolate::GCEpilogueCallback callback
                    ../node_modules/nan/nan.h:473:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
                    ../node_modules/nan/nan.h:474:18: error: expected primary-expression before ‘gc_type_filter’
                         , v8::GCType gc_type_filter = v8::kGCTypeAll) {
                    ../node_modules/nan/nan.h:479:20: error: variable or field ‘NanRemoveGCEpilogueCallback’ declared void
                           v8::Isolate::GCEpilogueCallback callback) {
                    ../node_modules/nan/nan.h:479:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
                    ../node_modules/nan/nan.h:484:20: error: variable or field ‘NanAddGCPrologueCallback’ declared void
                           v8::Isolate::GCPrologueCallback callback
                    ../node_modules/nan/nan.h:484:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
                    ../node_modules/nan/nan.h:485:18: error: expected primary-expression before ‘gc_type_filter’
                    ../node_modules/nan/nan.h:490:20: error: variable or field ‘NanRemoveGCPrologueCallback’ declared void
                           v8::Isolate::GCPrologueCallback callback) {
                    ../node_modules/nan/nan.h:490:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
                    ../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared
                    In file included from ../src/bufferutil.cc:10:0:
                    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
                    ../node_modules/nan/nan.h:710:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’
                    In file included from ../src/bufferutil.cc:8:0:
                    ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Initialize(v8::Handle<v8::Object>)’:
                    ../src/bufferutil.cc:30:52: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [7], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
                         NODE_SET_METHOD(t, "unmask", BufferUtil::Unmask);
                    ../src/bufferutil.cc:31:48: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [5], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
                         NODE_SET_METHOD(t, "mask", BufferUtil::Mask);
                    ../src/bufferutil.cc:32:50: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [6], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
                         NODE_SET_METHOD(t, "merge", BufferUtil::Merge);
                    ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Merge(const v8::FunctionCallbackInfo<v8::Value>&)’:
                    ../src/bufferutil.cc:49:49: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                         Local<Object> bufferObj = args[0]->ToObject();
                    ../src/bufferutil.cc:56:51: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                           Local<Object> src = array->Get(i)->ToObject();
                    ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Unmask(const v8::FunctionCallbackInfo<v8::Value>&)’:
                    ../src/bufferutil.cc:67:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                    In file included from ../src/bufferutil.cc:7:0:
                    ../src/bufferutil.cc:69:48: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                         Local<Object> mask_obj = args[1]->ToObject();
                    ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Mask(const v8::FunctionCallbackInfo<v8::Value>&)’:
                    ../src/bufferutil.cc:88:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                    ../src/bufferutil.cc:89:48: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                    ../src/bufferutil.cc:91:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                         Local<Object> output_obj = args[2]->ToObject();
                    ../src/bufferutil.cc:92:51: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                         unsigned int dataOffset = args[3]->Int32Value();
                    /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2478:46: note: declared here
                       V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                    ../src/bufferutil.cc:93:47: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                         unsigned int length = args[4]->Int32Value();
                    make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Fehler 1
                    gyp ERR! stack Error: `make` failed with exit code: 2
                    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:193:23)
                    gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                    gyp ERR! node-gyp -v v5.0.3
                    gyp ERR! not ok
                    > node-gyp rebuild
                    ../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Integer; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:
                    ../node_modules/nan/nan_new.h:29:66: warning: ‘v8::Local<v8::Integer> v8::Value::ToInteger() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     To<v8::Integer>(v8::Handle<v8::Integer> i) { return i->ToInteger(); }
                    /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10052:16: note: declared here
                     Local<Integer> Value::ToInteger() const {
                    ../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Int32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:
                    ../node_modules/nan/nan_new.h:34:64: error: no matching function for call to ‘v8::Integer::ToInt32()’
                     To<v8::Int32>(v8::Handle<v8::Integer> i)   { return i->ToInt32(); }
                    /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note: candidate: v8::MaybeLocal<v8::Int32> v8::Value::ToInt32(v8::Local<v8::Context>) const
                       V8_WARN_UNUSED_RESULT MaybeLocal<Int32> ToInt32(Local<Context> context) const;
                    /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note:   candidate expects 1 argument, 0 provided
                    gyp ERR! not ok
                    > npip install
                    Collecting Flask
                    Collecting appdirs==1.4.3
                    Processing /home/iobroker/.cache/pip/wheels/34/06/50/24011714e101b5ad8518c69175d117a257413e3c15a92983f0/urwid-2.0.1-cp35-none-any.whl
                    Collecting requests
                    Collecting idna>=2.1
                    Installing collected packages: marshmallow, marshmallow-objects, greenlet, gevent, construct, idna, asn1crypto, pycparser, cffi, six, cryptography, appdirs, demjson, urwid, certifi, chardet, urllib3, requests, xbox-webapi, dpkt, aenum, xbox-smartglass-core, xbox-smartglass-stump, MarkupSafe, Jinja2, click, itsdangerous, Werkzeug, Flask, xbox-smartglass-rest
                    Successfully installed Flask-1.1.1 Jinja2-2.10.3 MarkupSafe-1.1.1 Werkzeug-0.16.0 aenum-2.1.2 appdirs-1.4.3 asn1crypto-1.3.0 certifi-2019.11.28 cffi-1.13.2 chardet-3.0.4 click-7.0 construct-2.9.41 cryptography-2.3.1 demjson-2.2.4 dpkt-1.9.1 gevent-1.3.7 greenlet-0.4.15 idna-2.8 itsdangerous-1.1.0 marshmallow-3.3.0 marshmallow-objects-2.0.0 pycparser-2.19 requests-2.22.0 six-1.14.0 urllib3-1.25.7 urwid-2.0.1 xbox-smartglass-core-1.0.12 xbox-smartglass-rest-0.9.8 xbox-smartglass-stump-0.9.5 xbox-webapi-1.1.7
                    updated 1 package in 68.765s
                    Adapter gelb
                    xbox.0	2020-01-18 01:22:32.977	info	(28813) [START] Starting REST server
                    xbox.0	2020-01-18 01:22:32.977	debug	(28813) [START] IP address is 10.0.1.83
                    xbox.0	2020-01-18 01:22:32.956	info	(28813) starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.17.0
                    xbox.0	2020-01-18 01:22:26.538	info	(28335) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    xbox.0	2020-01-18 01:22:26.537	info	(28335) terminating
                    xbox.0	2020-01-18 01:22:26.536	info	(28335) [END] cleaned everything up...
                    xbox.0	2020-01-18 01:22:26.522	info	(28335) [END] REST server stopped
                    xbox.0	2020-01-18 01:22:26.508	debug	(28335) [LOGOUT] <=== Failed to logout: undefined
                    xbox.0	2020-01-18 01:22:26.500	info	(28335) Got terminate signal TERMINATE_YOURSELF
                    xbox.0	2020-01-18 01:22:26.413	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:26.413	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:25.410	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:25.410	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:25.316	debug	(28335) [CONNECT] Ping response, but provided LiveID has not been discovered until now
                    xbox.0	2020-01-18 01:22:25.315	debug	(28335) [CONNECT] Check connection
                    xbox.0	2020-01-18 01:22:25.315	error	(28335) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
                    xbox.0	2020-01-18 01:22:25.314	debug	(28335) [CHECK] Auth is not established
                    xbox.0	2020-01-18 01:22:25.309	debug	(28335) [DISCOVER] Searching for consoles
                    xbox.0	2020-01-18 01:22:25.306	debug	(28335) [PING] Xbox online
                    xbox.0	2020-01-18 01:22:24.407	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:24.406	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:23.399	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:23.399	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:22.396	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:22.396	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:21.393	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:21.393	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:20.390	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:20.390	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:19.387	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:19.386	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:19.311	debug	(28335) [CONNECT] Ping response, but provided LiveID has not been discovered until now
                    xbox.0	2020-01-18 01:22:19.310	debug	(28335) [CONNECT] Check connection
                    xbox.0	2020-01-18 01:22:19.309	error	(28335) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
                    xbox.0	2020-01-18 01:22:19.308	debug	(28335) [CHECK] Auth is not established
                    xbox.0	2020-01-18 01:22:19.305	debug	(28335) [DISCOVER] Searching for consoles
                    xbox.0	2020-01-18 01:22:19.303	debug	(28335) [PING] Xbox online
                    xbox.0	2020-01-18 01:22:18.384	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:18.384	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:17.381	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:17.380	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:16.378	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:16.377	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:15.374	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:15.373	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:14.371	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:14.370	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:13.358	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:13.358	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:13.314	debug	(28335) [CHECK] Auth is not established
                    xbox.0	2020-01-18 01:22:13.312	debug	(28335) [CONNECT] Ping response, but provided LiveID has not been discovered until now
                    xbox.0	2020-01-18 01:22:13.312	debug	(28335) [CONNECT] Check connection
                    xbox.0	2020-01-18 01:22:13.311	error	(28335) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
                    xbox.0	2020-01-18 01:22:13.308	debug	(28335) [DISCOVER] Searching for consoles
                    xbox.0	2020-01-18 01:22:13.305	debug	(28335) [PING] Xbox online
                    xbox.0	2020-01-18 01:22:12.355	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:12.355	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:11.351	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:11.351	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:10.348	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:10.347	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:09.345	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:09.345	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:08.341	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:08.341	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:07.337	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:07.337	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:07.325	debug	(28335) [CHECK] Auth is not established
                    xbox.0	2020-01-18 01:22:07.323	warn	(28335) [CONNECT] Ping response, but provided LiveID has not been discovered until now
                    xbox.0	2020-01-18 01:22:07.322	debug	(28335) [CONNECT] Check connection
                    xbox.0	2020-01-18 01:22:07.320	error	(28335) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
                    xbox.0	2020-01-18 01:22:07.315	debug	(28335) [DISCOVER] Searching for consoles
                    xbox.0	2020-01-18 01:22:07.311	debug	(28335) [PING] Xbox online
                    xbox.0	2020-01-18 01:22:06.335	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:06.334	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:05.332	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:05.332	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:04.328	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:04.328	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:03.324	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:03.324	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:02.321	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:02.321	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:01.318	warn	(28335) [LOGIN] Connection refused, will try again
                    xbox.0	2020-01-18 01:22:01.318	debug	(28335) Could not parse body
                    xbox.0	2020-01-18 01:22:01.308	debug	(28335) [LOGOUT] <=== Failed to logout: undefined
                    xbox.0	2020-01-18 01:21:58.846	debug	(28335) system.adapter.admin.0: logging true
                    xbox.0	2020-01-18 01:21:56.483	error	(28335) [START] Restarting adapter in 30 seconds
                    xbox.0	2020-01-18 01:21:56.482	error	SyntaxError: invalid syntax
                    xbox.0	2020-01-18 01:21:56.482	error	^
                    xbox.0	2020-01-18 01:21:56.482	error	cls, data, context=None, many=None, partial=None, unknown=None, *args, **kwargs,
                    xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/marshmallow_objects/models.py", line 209
                    xbox.0	2020-01-18 01:21:56.482	error	from marshmallow_objects.models import ( # noqa
                    xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/marshmallow_objects/__init__.py", line 3, in <module>
                    xbox.0	2020-01-18 01:21:56.482	error	from marshmallow_objects import Model, NestedModel, fields
                    xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/stump/json_model.py", line 4, in <module>
                    xbox.0	2020-01-18 01:21:56.482	error	from xbox.stump import json_model
                    xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/stump/manager.py", line 13, in <module>
                    xbox.0	2020-01-18 01:21:56.482	error	from xbox.stump.manager import StumpManager
                    xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/consolewrap.py", line 6, in <module>
                    xbox.0	2020-01-18 01:21:56.482	error	from ..consolewrap import ConsoleWrap
                    xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/routes/device.py", line 6, in <module>
                    xbox.0	2020-01-18 01:21:56.482	error	from .device import *
                    xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/routes/__init__.py", line 6, in <module>
                    xbox.0	2020-01-18 01:21:56.482	error	from .routes import routes
                    xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/app.py", line 5, in <module>
                    xbox.0	2020-01-18 01:21:56.482	error	from xbox.rest.app import app
                    xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/scripts/rest_server.py", line 9, in <module>
                    xbox.0	2020-01-18 01:21:56.482	error	from xbox.rest.scripts.rest_server import main
                    xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server", line 5, in <module>
                    xbox.0	2020-01-18 01:21:56.482	error	Traceback (most recent call last):
                    xbox.0	2020-01-18 01:21:56.482	error	(28335) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
                    xbox.0	2020-01-18 01:21:54.708	info	(28335) [START] Starting REST server
                    xbox.0	2020-01-18 01:21:54.707	debug	(28335) [START] IP address is 10.0.1.83
                    xbox.0	2020-01-18 01:21:54.688	info	(28335) starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.17.0
                    xbox.0	2020-01-18 01:21:52.313	debug	(28335) States connected to redis: 0.0.0.0:9000
                    xbox.0	2020-01-18 01:21:52.260	debug	(28335) statesDB connected
                    xbox.0	2020-01-18 01:21:52.259	debug	(28335) States create PubSub Client
                    xbox.0	2020-01-18 01:21:52.250	debug	(28335) Objects connected to redis: 0.0.0.0:9001
                    xbox.0	2020-01-18 01:21:52.247	debug	(28335) Redis States: Use Redis connection: 0.0.0.0:9000
                    xbox.0	2020-01-18 01:21:52.245	debug	(28335) objectDB connected
                    xbox.0	2020-01-18 01:21:52.232	debug	(28335) Objects client initialize lua scripts
                    xbox.0	2020-01-18 01:21:52.231	debug	(28335) Objects create PubSub Client
                    xbox.0	2020-01-18 01:21:52.223	debug	(28335) Objects client ready ... initialize now
                    xbox.0	2020-01-18 01:21:52.164	debug	(28335) Redis Objects: Use Redis connection: 0.0.0.0:9001
                    • foxriver76
                      foxriver76 Developer @Negalein last edited by foxriver76
                      marshmallow_objects
                      Jetzt mal bitte pip show marshmallow-objects Ausgabe zeigen und falls da nix kommt oder 2.0.0 kommt mal pip install "marshmallow-objects==1.0.23" dann rm -r /opt/iobroker/node_modules/iobroker.xbox und nochmal npm i iobroker.xbox --unsafe-perm --production --prefix /opt/iobroker
                      • Negalein
                        Negalein Global Moderator @foxriver76 last edited by Negalein
                        root@iobroker:/opt/iobroker# pip show marshmallow-objects
                        WARNING: Package(s) not found: marshmallow-objects
                        root@iobroker:/opt/iobroker# pip install "marshmallow-objects==1.0.23"
                        Collecting marshmallow-objects==1.0.23
                          Downloading https://files.pythonhosted.org/packages/2d/e2/05eebaa3d7f54349547792f82710c59457d3dc19dffd5ab9c11cfed3a421/marshmallow_objects-1.0.23-py2.py3-none-any.whl
                          Downloading https://files.pythonhosted.org/packages/e3/07/c7a12d21619abeedf5fca7381f4cf3fa798a26e8d92ad66bc73f5fc58fc1/marshmallow-2.20.5-py2.py3-none-any.whl (50kB)
                             |████████████████████████████████| 51kB 475kB/s
                        Successfully installed marshmallow-2.20.5 marshmallow-objects-1.0.23
                        root@iobroker:/opt/iobroker# rm -r /opt/iobroker/node_modules/iobroker.xbox
                        ../node_modules/nan/nan_implementation_12_inl.h:49:60: error: expected primary-expression before ‘>’ token
                           return v8::BooleanObject::New(value).As<v8::BooleanObject>();
                        ../node_modules/nan/nan_implementation_12_inl.h:49:62: error: expected primary-expression before ‘)’ token
                        ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::RegExp>::return_t NanIntern::Factory<v8::RegExp>::New(v8::Handle<v8::String>, v8::RegExp::Flags)’:
                        ../node_modules/nan/nan_implementation_12_inl.h:158:40: warning: ‘static v8::Local<v8::RegExp> v8::RegExp::New(v8::Local<v8::String>, v8::RegExp::Flags)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                           return v8::RegExp::New(pattern, flags);
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5110:38: note: declared here
                                                Local<RegExp> New(Local<String> pattern, Flags flags));
                        In file included from ../node_modules/nan/nan_new.h:189:0,
                                         from ../node_modules/nan/nan.h:82,
                        ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>)’:
                        ../node_modules/nan/nan_implementation_12_inl.h:166:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’
                           return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);
                        ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
                        ../node_modules/nan/nan_implementation_12_inl.h:173:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’
                        ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(const uint8_t*, int)’:
                        ../node_modules/nan/nan_implementation_12_inl.h:206:42: error: no matching function for call to ‘v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*&, v8::String::NewStringType, int&)’
                                 v8::String::kNormalString, length);
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note: candidate: static v8::MaybeLocal<v8::String> v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::NewStringType, int)
                           static V8_WARN_UNUSED_RESULT MaybeLocal<String> NewFromOneByte(
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note:   no known conversion for argument 3 from ‘v8::String::NewStringType’ to ‘v8::NewStringType’
                        ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(v8::String::ExternalStringResource*)’:
                        ../node_modules/nan/nan_implementation_12_inl.h:217:66: error: no matching function for call to ‘v8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*&)’
                           return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note: candidate: static v8::Local<v8::String> v8::String::NewExternal(v8::Isolate*, v8::String::ExternalOneByteStringResource*)
                               Local<String> NewExternal(Isolate* isolate,
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’
                         #define V8_DEPRECATE_SOON(message, declarator) declarator
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note:   no known conversion for argument 2 from ‘v8::String::ExternalStringResource*’ to ‘v8::String::ExternalOneByteStringResource*’
                        ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>)’:
                        ../node_modules/nan/nan_implementation_12_inl.h:237:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’
                           return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);
                        ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
                        ../node_modules/nan/nan_implementation_12_inl.h:244:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’
                        ../node_modules/nan/nan.h: In function ‘uint32_t NanUInt32OptionValue(v8::Local<v8::Object>, v8::Handle<v8::String>, uint32_t)’:
                        ../node_modules/nan/nan.h:248:43: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                               ? optionsObj->Get(opt)->Uint32Value()
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2477:47: note: declared here
                           V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
                        ../node_modules/nan/nan.h: At global scope:
                        ../node_modules/nan/nan.h:261:25: error: redefinition of ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Local<T>)’
                         NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Local<T> val) {
                        ../node_modules/nan/nan.h:256:25: note: ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Handle<T>)’ previously declared here
                         NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Handle<T> val) {
                        ../node_modules/nan/nan.h:569:15: error: ‘WeakCallbackData’ in namespace ‘v8’ does not name a template type
                             const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {
                        ../node_modules/nan/nan.h:569:31: error: expected ‘,’ or ‘...’ before ‘<’ token
                        ../node_modules/nan/nan.h: In function ‘void _NanWeakCallbackDispatcher(int)’:
                        ../node_modules/nan/nan.h:570:42: error: ‘data’ was not declared in this scope
                               _NanWeakCallbackInfo<T, P> *info = data.GetParameter();
                             , node::smalloc::FreeCallback callback
                        ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’
                        ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(char*, size_t, int)’:
                        ../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope
                                 v8::Isolate::GetCurrent(), data, length, callback, hint);
                        ../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope
                        ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(const char*, uint32_t)’:
                        ../node_modules/nan/nan.h:672:67: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]
                             return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/node_buffer.h:68:40: note:   initializing argument 2 of ‘v8::MaybeLocal<v8::Object> node::Buffer::New(v8::Isolate*, char*, size_t)’
                         NODE_EXTERN v8::MaybeLocal<v8::Object> New(v8::Isolate* isolate,
                        ../node_modules/nan/nan.h:672:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((char*)data), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’
                        ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(uint32_t)’:
                        ../node_modules/nan/nan.h:676:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’
                             return node::Buffer::New(v8::Isolate::GetCurrent(), size);
                        ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanBufferUse(char*, uint32_t)’:
                        ../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’
                             return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);
                             return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)
                           static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 provided
                        ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>)’:
                        ../node_modules/nan/nan.h:717:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’
                        ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::UnboundScript>)’:
                        ../node_modules/nan/nan.h:723:48: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                             return script->BindToCurrentContext()->Run();
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here
                           V8_DEPRECATED("Use maybe version", Local<Value> Run());
                        ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::Script>)’:
                        ../node_modules/nan/nan.h:729:24: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                             return script->Run();
                        In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                           declarator __attribute__((deprecated(message)))
                        ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::Function>, int, v8::Handle<v8::Value>*)’:
                                 v8::Isolate::GetCurrent(), target, func, argc, argv));
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:177:50: note: declared here
                                         NODE_EXTERN v8::Local<v8::Value> MakeCallback(
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
                             __attribute__((deprecated(message))) declarator
                        ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::String>, int, v8::Handle<v8::Value>*)’:
                        ../node_modules/nan/nan.h:747:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                                 v8::Isolate::GetCurrent(), target, symbol, argc, argv));
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:170:50: note: declared here
                        ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, const char*, int, v8::Handle<v8::Value>*)’:
                                 v8::Isolate::GetCurrent(), target, method, argc, argv));
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:163:50: note: declared here
                        ../node_modules/nan/nan.h: In member function ‘v8::Handle<v8::Value> NanCallback::Call_(v8::Isolate*, v8::Handle<v8::Object>, int, v8::Handle<v8::Value>*) const’:
                        ../node_modules/nan/nan.h:398:59: note: in definition of macro ‘NanEscapeScope’
                         # define NanEscapeScope(val) scope.Escape(_NanEnsureLocal(val))
                        ../node_modules/nan/nan.h: In function ‘void* _NanRawString(v8::Handle<v8::Value>, Nan::Encoding, size_t*, void*, size_t, int)’:
                        ../node_modules/nan/nan.h:2164:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                                 v8::String::Value value(toStr);
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here
                             V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));
                        ../node_modules/nan/nan.h:2198:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                        ../node_modules/nan/nan.h: In constructor ‘NanTap::NanTap(v8::Handle<v8::Value>)’:
                        ../node_modules/nan/nan.h:2292:41: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                             NanAssignPersistent(t_, t->ToObject());
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here
                         Local<Object> Value::ToObject() const {
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback)
                         inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback)
                         inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,
                             Local<Object> buffer_obj = args[0]->ToObject();
                        gyp ERR! System Linux 4.4.59+
                        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                        gyp ERR! node -v v10.17.0
                        gyp ERR! not ok
                        > node-gyp rebuild
                        In file included from ../node_modules/nan/nan.h:82:0,
                                         from ../src/validation.cc:15:
                        In file included from ../src/validation.cc:7:0:
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note: candidate: v8::Local<v8::Int32> v8::Value::ToInt32(v8::Isolate*) const
                                         Local<Int32> ToInt32(Isolate* isolate) const);
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note:   candidate expects 1 argument, 0 provided
                        ../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Uint32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:
                        ../node_modules/nan/nan_new.h:39:65: error: no matching function for call to ‘v8::Integer::ToUint32()’
                         To<v8::Uint32>(v8::Handle<v8::Integer> i)  { return i->ToUint32(); }
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note: candidate: v8::MaybeLocal<v8::Uint32> v8::Value::ToUint32(v8::Local<v8::Context>) const
                           V8_WARN_UNUSED_RESULT MaybeLocal<Uint32> ToUint32(
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note:   candidate expects 1 argument, 0 provided
                        ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::BooleanObject>::return_t NanIntern::Factory<v8::BooleanObject>::New(bool)’:
                        ../node_modules/nan/nan_implementation_12_inl.h:49:38: error: no matching function for call to ‘v8::BooleanObject::New(bool&)’
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note: candidate: static v8::Local<v8::Value> v8::BooleanObject::New(v8::Isolate*, bool)
                           static Local<Value> New(Isolate* isolate, bool value);
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note:   candidate expects 2 arguments, 1 provided
                        In file included from ../src/validation.cc:15:0:
                        In file included from ../src/validation.cc:10:0:
                        ../node_modules/nan/nan.h:738:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ isdeprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                        In file included from ../src/validation.cc:8:0:
                        ../node_modules/nan/nan.h:756:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated:Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                        ../node_modules/nan/nan.h:1569:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ isdeprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                        ../src/validation.cc: In static member function ‘static void Validation::Initialize(v8::Handle<v8::Object>)’:
                        ../src/validation.cc:112:62: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [12], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’is ambiguous
                             NODE_SET_METHOD(t, "isValidUTF8", Validation::IsValidUTF8);
                        ../src/validation.cc: In static member function ‘static void Validation::IsValidUTF8(const v8::FunctionCallbackInfo<v8::Value>&)’:
                        ../src/validation.cc:132:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                        validation.target.mk:105: die Regel für Ziel „Release/obj.target/validation/src/validation.o“ scheiterte
                        make: *** [Release/obj.target/validation/src/validation.o] Fehler 1
                        make: Verzeichnis „/opt/iobroker/node_modules/utf-8-validate/build“ wird verlassen
                        gyp ERR! build error
                        gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validate
                        gyp ERR! not ok
                        > iobroker.xbox@0.5.12 install /opt/iobroker/node_modules/iobroker.xbox
                        > npip install
                        No python_modules directory; installing pip locally if needed.
                        Successfully completed pip check.
                        Collecting xbox-smartglass-rest>=0.9.8
                          Using cached https://files.pythonhosted.org/packages/4d/4f/f035df8a2ec5742b9e772071e006ea21aae3fc3bd0963753cfc1045d6fda/xbox_smartglass_rest-0.9.8-py2.py3-none-any.whl
                        Collecting xbox-smartglass-stump>=0.9.5
                          Using cached https://files.pythonhosted.org/packages/34/f0/a75667f67ce6251b96a6989b8169eb9f2e25407ce2b0888e544b8caa98fe/xbox_smartglass_stump-0.9.5-py2.py3-none-any.whl
                        Collecting xbox-webapi>=1.1.7
                          Using cached https://files.pythonhosted.org/packages/2d/bf/aaf24cc78184393c5c2472e822c0e145b793e346a8085bee02e89a3428ba/xbox_webapi-1.1.7-py2.py3-none-any.whl
                        Collecting Flask
                          Using cached https://files.pythonhosted.org/packages/9b/93/628509b8d5dc749656a9641f4caf13540e2cdec85276964ff8f43bbb1d3b/Flask-1.1.1-py2.py3-none-any.whl
                        Collecting xbox-smartglass-core>=1.0.12
                          Using cached https://files.pythonhosted.org/packages/13/c8/2ffce1ddabe5b73422c7c46e808e4b02dbbc9362d2ecd2aee2a65e6e30a5/xbox_smartglass_core-1.0.12-py2.py3-none-any.whl
                          Using cached https://files.pythonhosted.org/packages/4d/1c/fe15bc370707e8f8db09ab0edead45ab413b75795a8be523ca6482152183/marshmallow_objects-2.0.0-py2.py3-none-any.whl
                        Collecting requests
                          Using cached https://files.pythonhosted.org/packages/51/bd/23c926cd341ea6b7dd0b2a00aba99ae0f828be89d72b2190f27c11d4b7fb/requests-2.22.0-py2.py3-none-any.whl
                        Processing /home/iobroker/.cache/pip/wheels/c5/d2/ab/a54fb5ea53ac3badba098160e8452fa126a51febda80440ded/demjson-2.2.4-cp35-none-any.whl
                        Processing /home/iobroker/.cache/pip/wheels/49/b5/ad/7355506059779337473b8eeb49384c9c0a9d45d34c8211a96d/urwid-2.1.0-cp35-cp35m-linux_x86_64.whl
                        Collecting appdirs
                          Using cached https://files.pythonhosted.org/packages/56/eb/810e700ed1349edde4cbdc1b2a21e28cdf115f9faf263f6bbf8447c1abf3/appdirs-1.4.3-py2.py3-none-any.whl
                        Collecting Jinja2>=2.10.1
                          Using cached https://files.pythonhosted.org/packages/65/e0/eb35e762802015cab1ccee04e8a277b03f1d8e53da3ec3106882ec42558b/Jinja2-2.10.3-py2.py3-none-any.whl
                        Collecting itsdangerous>=0.24
                          Using cached https://files.pythonhosted.org/packages/76/ae/44b03b253d6fade317f32c24d100b3b35c2239807046a4c953c7b89fa49e/itsdangerous-1.1.0-py2.py3-none-any.whl
                        Collecting click>=5.1
                          Using cached https://files.pythonhosted.org/packages/fa/37/45185cb5abbc30d7257104c434fe0b07e5a195a6847506c074527aa599ec/Click-7.0-py2.py3-none-any.whl
                        Collecting Werkzeug>=0.15
                          Using cached https://files.pythonhosted.org/packages/ce/42/3aeda98f96e85fd26180534d36570e4d18108d62ae36f87694b476b83d6f/Werkzeug-0.16.0-py2.py3-none-any.whl
                        Collecting gevent==1.3.7
                          Using cached https://files.pythonhosted.org/packages/87/c4/9afb40b4a8b9186787d477aa6ebcfa17ead40ecbf83d5a1ed53dadd4f6ef/gevent-1.3.7-cp35-cp35m-manylinux1_x86_64.whl
                        Processing /home/iobroker/.cache/pip/wheels/13/cd/02/acabe4bfa9899d53c3e3b13675610d2e2dcb9ae110359d4f61/construct-2.9.41-cp35-none-any.whl
                        Collecting cryptography==2.3.1
                          Using cached https://files.pythonhosted.org/packages/59/32/92cade62c645756a83598edf56289e9b19aae5370642a7ce690cd06bc72f/cryptography-2.3.1-cp34-abi3-manylinux1_x86_64.whl
                        Collecting aenum==2.1.2; python_version <= "3.5"
                          Using cached https://files.pythonhosted.org/packages/0d/46/5b6a6c13fee40f9dfaba84de1394bfe082c0c7d95952ba0ffbd56ce3a3f7/aenum-2.1.2-py3-none-any.whl
                        Processing /home/iobroker/.cache/pip/wheels/0a/5f/3c/e0ffceb6554711f12a7101384f29ec13b85136dfcf1f692b8f/dpkt-1.9.1-cp35-none-any.whl
                        Collecting marshmallow>=3.0.0
                          Using cached https://files.pythonhosted.org/packages/6e/76/01224f14737627166b94eb3bf0e334372c014edca781e39db320ce977755/marshmallow-3.3.0-py2.py3-none-any.whl
                        Collecting chardet<3.1.0,>=3.0.2
                          Using cached https://files.pythonhosted.org/packages/bc/a9/01ffebfb562e4274b6487b4bb1ddec7ca55ec7510b22e4c51f14098443b8/chardet-3.0.4-py2.py3-none-any.whl
                        Collecting certifi>=2017.4.17
                          Using cached https://files.pythonhosted.org/packages/b9/63/df50cac98ea0d5b006c55a399c3bf1db9da7b5a24de7890bc9cfd5dd9e99/certifi-2019.11.28-py2.py3-none-any.whl
                        Collecting urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1
                          Using cached https://files.pythonhosted.org/packages/b4/40/a9837291310ee1ccc242ceb6ebfd9eb21539649f193a7c8c86ba15b98539/urllib3-1.25.7-py2.py3-none-any.whl
                        Collecting idna<2.9,>=2.5
                          Using cached https://files.pythonhosted.org/packages/14/2c/cd551d81dbe15200be1cf41cd03869a46fe7226e7450af7a6545bfc474c9/idna-2.8-py2.py3-none-any.whl
                        Collecting MarkupSafe>=0.23
                          Using cached https://files.pythonhosted.org/packages/6e/57/d40124076756c19ff2269678de7ae25a14ebbb3f6314eb5ce9477f191350/MarkupSafe-1.1.1-cp35-cp35m-manylinux1_x86_64.whl
                        Collecting greenlet>=0.4.14; platform_python_implementation == "CPython"
                          Using cached https://files.pythonhosted.org/packages/2e/65/27f35497cc0102a792390d056e793e064da95fc9eae45d75ae0ba49c0a0d/greenlet-0.4.15-cp35-cp35m-manylinux1_x86_64.whl
                        Collecting asn1crypto>=0.21.0
                          Using cached https://files.pythonhosted.org/packages/e9/51/1db4a60049fb7390959be586b6eb743098e6cea3f6b2d3ed9e17fec62ba2/asn1crypto-1.3.0-py2.py3-none-any.whl
                        Collecting six>=1.4.1
                          Using cached https://files.pythonhosted.org/packages/65/eb/1f97cb97bfc2390a276969c6fae16075da282f5058082d4cb10c6c5c1dba/six-1.14.0-py2.py3-none-any.whl
                        Collecting cffi!=1.11.3,>=1.7
                          Using cached https://files.pythonhosted.org/packages/a8/8d/986e0c4e2aa3b24db56a0affc50d1a379150e3c4da45d51d549dc2697d53/cffi-1.13.2-cp35-cp35m-manylinux1_x86_64.whl
                        Processing /home/iobroker/.cache/pip/wheels/f2/9a/90/de94f8556265ddc9d9c8b271b0f63e57b26fb1d67a45564511/pycparser-2.19-py2.py3-none-any.whl
                        ERROR: xbox-smartglass-core 1.0.12 has requirement urwid==2.0.1, but you'll have urwid 2.1.0 which is incompatible.
                        Installing collected packages: marshmallow, marshmallow-objects, chardet, certifi, urllib3, idna, requests, demjson, urwid, appdirs, xbox-webapi, greenlet, gevent, construct, asn1crypto, six, pycparser, cffi, cryptography, aenum, dpkt, xbox-smartglass-core, xbox-smartglass-stump, MarkupSafe, Jinja2, itsdangerous, click, Werkzeug, Flask, xbox-smartglass-rest
                        Successfully installed Flask-1.1.1 Jinja2-2.10.3 MarkupSafe-1.1.1 Werkzeug-0.16.0 aenum-2.1.2 appdirs-1.4.3 asn1crypto-1.3.0 certifi-2019.11.28 cffi-1.13.2 chardet-3.0.4 click-7.0 construct-2.9.41 cryptography-2.3.1 demjson-2.2.4 dpkt-1.9.1 gevent-1.3.7 greenlet-0.4.15 idna-2.8 itsdangerous-1.1.0 marshmallow-3.3.0 marshmallow-objects-2.0.0 pycparser-2.19 requests-2.22.0 six-1.14.0 urllib3-1.25.7 urwid-2.1.0 xbox-smartglass-core-1.0.12 xbox-smartglass-rest-0.9.8 xbox-smartglass-stump-0.9.5 xbox-webapi-1.1.7
                        npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/iobroker.type-detector'
                        npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.
                        npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 (node_modules/bufferutil):
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 install: `node-gyp rebuild`
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 (node_modules/utf-8-validate):
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 install: `node-gyp rebuild`
                        + iobroker.xbox@0.5.12
                        added 3 packages from 3 contributors in 69.941s
                        Adapter gelb
                        xbox.0	2020-01-18 01:44:23.875	warn	(11600) [LOGIN] Connection refused, will try again
                        xbox.0	2020-01-18 01:44:23.874	debug	(11600) Could not parse body
                        xbox.0	2020-01-18 01:44:22.872	warn	(11600) [LOGIN] Connection refused, will try again
                        xbox.0	2020-01-18 01:44:22.872	debug	(11600) Could not parse body
                        xbox.0	2020-01-18 01:44:22.852	debug	(11600) [CHECK] Auth is not established
                        xbox.0	2020-01-18 01:44:22.850	warn	(11600) [CONNECT] Ping response, but provided LiveID has not been discovered until now
                        xbox.0	2020-01-18 01:44:22.849	debug	(11600) [CONNECT] Check connection
                        xbox.0	2020-01-18 01:44:22.847	error	(11600) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
                        xbox.0	2020-01-18 01:44:22.843	debug	(11600) [DISCOVER] Searching for consoles
                        xbox.0	2020-01-18 01:44:22.838	debug	(11600) [PING] Xbox online
                        xbox.0	2020-01-18 01:44:21.870	warn	(11600) [LOGIN] Connection refused, will try again
                        xbox.0	2020-01-18 01:44:21.869	debug	(11600) Could not parse body
                        xbox.0	2020-01-18 01:44:20.866	warn	(11600) [LOGIN] Connection refused, will try again
                        xbox.0	2020-01-18 01:44:20.865	debug	(11600) Could not parse body
                        xbox.0	2020-01-18 01:44:19.862	warn	(11600) [LOGIN] Connection refused, will try again
                        xbox.0	2020-01-18 01:44:19.862	debug	(11600) Could not parse body
                        xbox.0	2020-01-18 01:44:18.859	warn	(11600) [LOGIN] Connection refused, will try again
                        xbox.0	2020-01-18 01:44:18.859	debug	(11600) Could not parse body
                        xbox.0	2020-01-18 01:44:17.855	warn	(11600) [LOGIN] Connection refused, will try again
                        xbox.0	2020-01-18 01:44:17.854	debug	(11600) Could not parse body
                        xbox.0	2020-01-18 01:44:16.851	warn	(11600) [LOGIN] Connection refused, will try again
                        xbox.0	2020-01-18 01:44:16.850	debug	(11600) Could not parse body
                        xbox.0	2020-01-18 01:44:16.840	debug	(11600) [LOGOUT] <=== Failed to logout: undefined
                        xbox.0	2020-01-18 01:44:12.016	error	(11600) [START] Restarting adapter in 30 seconds
                        xbox.0	2020-01-18 01:44:12.015	error	(11600) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found Traceback (most recent call last): File "/opt/iobrok
                        xbox.0	2020-01-18 01:44:11.076	debug	(11600) system.adapter.admin.0: logging true
                        xbox.0	2020-01-18 01:44:10.252	info	(11600) [START] Starting REST server
                        xbox.0	2020-01-18 01:44:10.251	debug	(11600) [START] IP address is 10.0.1.83
                        xbox.0	2020-01-18 01:44:10.194	info	(11600) starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.17.0
                        xbox.0	2020-01-18 01:44:07.537	debug	(11600) States connected to redis: 0.0.0.0:9000
                        xbox.0	2020-01-18 01:44:07.483	debug	(11600) statesDB connected
                        xbox.0	2020-01-18 01:44:07.482	debug	(11600) States create PubSub Client
                        xbox.0	2020-01-18 01:44:07.473	debug	(11600) Objects connected to redis: 0.0.0.0:9001
                        xbox.0	2020-01-18 01:44:07.471	debug	(11600) Redis States: Use Redis connection: 0.0.0.0:9000
                        xbox.0	2020-01-18 01:44:07.469	debug	(11600) objectDB connected
                        xbox.0	2020-01-18 01:44:07.457	debug	(11600) Objects client initialize lua scripts
                        xbox.0	2020-01-18 01:44:07.456	debug	(11600) Objects create PubSub Client
                        xbox.0	2020-01-18 01:44:07.448	debug	(11600) Objects client ready ... initialize now
                        xbox.0	2020-01-18 01:44:07.415	debug	(11600) Redis Objects: Use Redis connection: 0.0.0.0:9001
                        • foxriver76
                          @Negalein brauche das install log mal von Anfang an. Habe bei mir mal noch mal geupdated von alter Version, da kommen die ganzen C Geschichten gar nicht. Dachte das war schon damals so.
                          Lass es am besten mal in ein File schreiben da es ja sonst abgeschnitten wird npm i iobroker.xbox --unsafe-perm --prefix /opt/iobroker --production &> xbox-logfile. Und mir das File dann mal hochladen o. Inhalt posten.
                          • Negalein
                            @foxriver76 sagte in XBox-Adapter Fehler:
                            xbox-logfile.txt
                            • foxriver76
                              @Negalein fangen wir mal oben an. Da fangen die ganzen C-Geschichten an.
                              bufferutil@1.1.0 install /opt/iobroker/node_modules/bufferutil
                              node-gyp rebuild
                              make: Verzeichnis „/opt/iobroker/node_modules/bufferutil/build“ wird betreten
                              Das Package sollte mit Xbox nix zu tun haben. Taucht bei mir in der Package Lock JSON nicht auf. Schauen wir mal ob es überhaupt jemand braucht npm ls bufferutil
                              • Negalein
                                npm ls bufferutil
                                iobroker.inst@1.1.2 /opt/iobroker
                                └─┬ iobroker.kodi@1.0.0
                                  └─┬ kodi-ws@2.4.0
                                    └─┬ ws@0.7.2
                                      └── UNMET OPTIONAL DEPENDENCY bufferutil@1.1.x
                                Kodi könnte ich deinstallieren. Läuft nur ab und an zu Testzwecken.
                                • foxriver76
                                  @Negalein die Dep ist sowieso nur optional, da sie ja anscheinend gar nicht gebaut werden kann. Können mal probieren ob npm dann Ruhe gibt rm -r /opt/iobroker/node_modules/bufferutil dann nochmal den Befehl von oben mit Xbox install ins File.
                                  • Negalein
                                    root@iobroker:/opt/iobroker# rm -r /opt/iobroker/node_modules/bufferutil
                                    rm: das Entfernen von '/opt/iobroker/node_modules/bufferutil' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                                    • foxriver76
                                      @Negalein Anscheinend kommt das von der veralteten Abhängigkeit auf ws https://github.com/instalator/kodi-ws/blob/bde03ec364c022f61e167a83733ef70873b7df73/package.json#L29 da gibt es mittlerweile Version 7.X. 😆
                                      Naja, gut allerdings sollte es die Xbox Adapter Installation nicht beeinflussen - ist halt nur äußerst unschick, da theoretisch bei jeder Installation via npm das Logging auftauchen wird und versucht wird die Dep nachzuinstallieren.
                                      Dann bleibt eigentlich nur das für den Adapter Install an Logging:
                                      > npip install
                                      Collecting Flask
                                      Collecting requests
                                      Installing collected packages: appdirs, demjson, urllib3, certifi, chardet, idna, requests, urwid, xbox-webapi, asn1crypto, pycparser, cffi, six, cryptography, dpkt, aenum, construct, greenlet, gevent, xbox-smartglass-core, Werkzeug, itsdangerous, click, MarkupSafe, Jinja2, Flask, marshmallow, marshmallow-objects, xbox-smartglass-stump, xbox-smartglass-rest
                                      updated 1 package in 69.394s
                                      Und das schaut eigentlich echt gut aus, bis noch auf die Warning mit dem Link auf sich selbst:
                                      npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/iobroker.type-detector' sollte allerdings auch keine Rolle spielen. Hierfür kann man mal ls -lah /opt/iobroker/node_modules machen um nachzuschauen.
                                      Xbox loggt ja:
                                      xbox.0	2020-01-18 01:44:12.015	error	(11600) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found Traceback (most recent call last): File "/opt/iobrok..
                                      Was kommt denn bei ls -lah /opt/iobroker/node_modules/iobroker.xbox/node_modules/nopy/src raus? Und was bei ls -lah /opt/iobroker/node_modules/nopy/src?
                                      • Negalein
                                        root@iobroker:/opt/iobroker# ls -lah /opt/iobroker/node_modules/iobroker.xbox/node_modules/nopy/src
                                        ls: Zugriff auf '/opt/iobroker/node_modules/iobroker.xbox/node_modules/nopy/src' nicht möglich: Datei oder Verzeichnis nicht gefunden
                                        root@iobroker:/opt/iobroker# ls -lah /opt/iobroker/node_modules/nopy/src
                                        insgesamt 1,6M
                                        drwxr-xr-x 1 iobroker iobroker  110 Nov 27 13:52 .
                                        drwxr-xr-x 1 iobroker iobroker   98 Nov 27 13:52 ..
                                        -rw-r--r-- 1 iobroker iobroker 7,5K Okt 26  1985 api.js
                                        -rw-r--r-- 1 iobroker iobroker 1,6M Okt 26  1985 get-pip.py
                                        -rwxr-xr-x 1 iobroker iobroker  530 Okt 26  1985 nopenv.js
                                        -rwxr-xr-x 1 iobroker iobroker  397 Okt 26  1985 nopy.js
                                        -rwxr-xr-x 1 iobroker iobroker 2,3K Okt 26  1985 npip.js
                                        -rw-r--r-- 1 iobroker iobroker  313 Okt 26  1985 promisify.js
                                        drwxr-xr-x 1 iobroker iobroker   36 Nov 27 13:52 test
                                        • foxriver76
                                          @Negalein Passt eigentlich auch.
                                          Was passiert bei /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js /opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server || /opt/iobroker/node_modules/iobroker.xbox/lib/../../nopy/src/nopy.js /opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server
                                          Ist 1 zu 1 das Kommando, dass der Adapter ausführt zum den Server zu starten. Er wird sagen Datei nicht gefunden für das erste und dann greift die Alternative die eigentlich passen sollte.
                                          • Negalein
                                            ist das 1 Befehl? Also alles auf 1x kopieren und ausführen?
                                            Wenn Ja, dann kommt das:
                                            root@iobroker:/opt/iobroker# /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js /opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xboxr || /opt/iobroker/node_modules/iobroker.xbox/lib/../../nopy/src/nopy.js /opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server
                                            bash: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: Datei oder Verzeichnis nicht gefunden
                                            xbox
                                            7245
