    4. Test Adapter Digitalstrom 0.2.x
      cb187 last edited by
      smartmeter.0 2020-01-17 18:06:45.188 info (4504) Received 10 values, 3 updated
      digitalstrom.0 2020-01-17 18:06:44.987 info (7889) INVALID Zone Sensor update: 0.sensors.16
      digitalstrom.0 2020-01-17 18:06:44.987 debug (7889) EVENT: zoneSensorValue: {"name":"zoneSensorValue","properties":{"sensorValueFloat":"1.925","originDSID":"f0f037817b745ce880fb04dbe785216400","sensorType":"16","sensorValue":"77"},"source":{"set
      digitalstrom.0 2020-01-17 18:06:44.910 debug (7889) state digitalstrom.0.devices.73f7e3d7e8545ceac0c926707f75af7200.f0f037817b745ce880fb04dbe785216400.sensors.3 changed: 1.92156872153 (ack = true)
      digitalstrom.0 2020-01-17 18:06:44.900 debug (7889) EVENT: deviceSensorValue: {"name":"deviceSensorValue","properties":{"contextTimestamp":"2020-01-17T17:06:44.893Z","contextMsg":"","contextId":"0","sensorValueFloat":"1.92156872153","sensorIndex
      smartmeter.0 2020-01-17 18:06:41.834 warn (4504) Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 1b1b1b1b010101017607001602bc13c4620062007263010176010107001605835bec0b0901454d4800005d83520101635e8b00760700160
      smartmeter.0 2020-01-17 18:06:41.832 info (4504) Error: Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 1b1b1b1b010101017607001602bc13c4620062007263010176010107001605835bec0b0901454d4800005d83520101635e8b0076
      smartmeter.0 2020-01-17 18:06:39.261 info (4504) Received 10 values, 3 updated
      digitalstrom.0 2020-01-17 18:06:38.549 debug (7889) state digitalstrom.0.devices.302ed89f43f0000000000e40000077be00.303505d7f800000000000f00000afb9400.shadePositionOutside changed: 20 (ack = false)
      Mehr als das kommt nicht.
        apollon77 @cb187 last edited by
        @cb187 dann bitte log vom Adapter Start schicken. iobroker@fischer-ka.de
          cb187 @apollon77 last edited by
          @apollon77 wo finde ich die log?
            @cb187 Platte im iobroker Verzeichnis unter log
              ist raus.
              apollon77 2 Replies Last reply Reply Quote 0
                @cb187 I see I see ... Fix kommt
                  @cb187 Versuch mal die 0.4.8 vom GitHub. Die sollte:
                  • windgust anzeigen (wo kommt dieser wettersensor wert her? Der Name ist offiziell nicht definiert)
                  • Binary Input types sollten jetzt vollständiger sein. Da ist was mit Gruppe 6 drin die auch nicht deifniert ist so wirklich (die heisst "reserved1" intern ... hm ...) Was sind denn das für sensoren? Device devices.73f7e3d7e8545ceac0c926707f75af7200.6346952005c15b848007dbf9ef95331002
                  • Shaders sollten jetzt was steuern ... Bitte nochmal testen und ggf log posten wie oben (das "kurze" während der Aktion reicht
                  Wenn das bei Dir passt geht es dann für alle morgen raus.
                    Der Windsensor kommt über die Plan44 rein.Sonst habe ich nur noch 3 VDC laufen.Probier es nachher aus.
                      @cb187 der windsensor sendet windgust als wert. Die definierten Sensoren sind aber gustspeed und gustdirection. Wäre ein bugreport bei plan44 wert ;-))
                        Also ich muss das jetzt nicht haben.Benutze das nur in DS.
                          @cb187 naja der Adapter zeigt es jetzt mit an 😉
                            Ist ja nicht schlimm😂😁
                              AHab nochmal was optimiert ... 0.4.9 auf GitHub ... Schaut mal rein bitte und wenns tut kommts dann nachher auf npm
                                Das ist nen Enocean Fenstergriff von Soda.:-)
                                  @cb187 dem fehlten vorher ein paar binary inputs. Jetzt sind die da 😉
                                    das kommt wenn. ich das Rollo shades veränder
                                      Das sind die eigentlichen Werte vom Fenstergriff dazu kämen noch zwei normal button die man frei verwenden kann.:)
                                      Vielleicht interessiert dich das noch.
                                        @cb187 kannst du in der dss web Oberfläche unter Hardware - Gerätewert ändern das ändern und es tut? (Nicht per min/Max sondern da Prozentwert)?
                                        Er sagt der Wert wäre ungültig aber das war ja ein offizielles graues Rollo gerät oder?! Sollte damit passen. Da ist nix gesperrt oder so?!
                                          in der DS Web Oberfläche kann ich den Wert ändern zb 80% und das Rollo fährt.
                                            @cb187 Versuch mit dem Adapter mal bitte 1, 2 und 3%. Schau was dann im log steht. Und falls es tut schau dann mal in der dss welchen Wert sie anzeigen. Ich könnte mir nur vorstellen das -warum auch immer- der geteuerte Wertebereich bei dir nur 0..255 ist anstelle 0..65535
                                            31.7k
                                            79.8k
                                            digitalstrom
                                            10
                                            154
                                            14064
