    4. XBox-Adapter Fehler
    SOLVED XBox-Adapter Fehler
    • Negalein
      Negalein Global Moderator @foxriver76 last edited by
      @foxriver76 sagte in XBox-Adapter Fehler:
      Mal folgendes probieren: curl https://bootstrap.pypa.io/get-pip.py -o get-pip.py dann python get-pip.py dann pip install "urwid==2.0.1"
      root@iobroker:/opt/iobroker# curl https://bootstrap.pypa.io/get-pip.py -o get-pip.py
        % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                       Dload  Upload   Total   Spent    Left  Speed
      100 1734k  100 1734k    0     0  2644k      0 --:--:-- --:--:-- --:--:-- 2647k
      root@iobroker:/opt/iobroker# python get-pip.py
      DEPRECATION: Python 2.7 will reach the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 won't be maintained after that date. A future version of pip will drop support for Python 2.7. More details about Python 2 support in pip, can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support
      Collecting pip
        Downloading https://files.pythonhosted.org/packages/00/b6/9cfa56b4081ad13874b0c6f96af8ce16cfbc1cb06bedf8e9164ce5551ec1/pip-19.3.1-py2.py3-none-any.whl (1.4MB)
           |████████████████████████████████| 1.4MB 1.1MB/s
      Collecting setuptools
        Downloading https://files.pythonhosted.org/packages/f9/d3/955738b20d3832dfa3cd3d9b07e29a8162edb480bf988332f5e6e48ca444/setuptools-44.0.0-py2.py3-none-any.whl (583kB)
           |████████████████████████████████| 583kB 3.1MB/s
      Collecting wheel
        Downloading https://files.pythonhosted.org/packages/00/83/b4a77d044e78ad1a45610eb88f745be2fd2c6d658f9798a15e384b7d57c9/wheel-0.33.6-py2.py3-none-any.whl
      Installing collected packages: pip, setuptools, wheel
      Successfully installed pip-19.3.1 setuptools-44.0.0 wheel-0.33.6
      root@iobroker:/opt/iobroker# pip install "urwid==2.0.1"
      Collecting urwid==2.0.1
        Downloading https://files.pythonhosted.org/packages/c7/90/415728875c230fafd13d118512bde3184d810d7bf798a631abc05fac09d0/urwid-2.0.1.tar.gz (604kB)
           |████████████████████████████████| 614kB 1.2MB/s
      Building wheels for collected packages: urwid
        Building wheel for urwid (setup.py) ... done
        Created wheel for urwid: filename=urwid-2.0.1-cp27-none-any.whl size=223811 sha256=62989cc247db2deb465ac357ec891d2e89e4c03904d6c8288c414afca14b37db
        Stored in directory: /root/.cache/pip/wheels/34/06/50/24011714e101b5ad8518c69175d117a257413e3c15a92983f0
      Successfully built urwid
      Installing collected packages: urwid
      Successfully installed urwid-2.0.1
      Adapter weiterhin gelb
      xbox.0	2020-01-18 00:53:21.860	info	(8629) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      xbox.0	2020-01-18 00:53:21.859	info	(8629) terminating
      xbox.0	2020-01-18 00:53:21.858	info	(8629) [END] cleaned everything up...
      xbox.0	2020-01-18 00:53:21.844	info	(8629) [END] REST server stopped
      xbox.0	2020-01-18 00:53:21.830	debug	(8629) [LOGOUT] <=== Failed to logout: undefined
      xbox.0	2020-01-18 00:53:21.824	info	(8629) Got terminate signal TERMINATE_YOURSELF
      xbox.0	2020-01-18 00:53:21.653	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:53:21.653	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:53:20.649	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:53:20.648	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:53:20.557	debug	(8629) [CHECK] Auth is not established
      xbox.0	2020-01-18 00:53:20.555	debug	(8629) [CONNECT] Ping response, but provided LiveID has not been discovered until now
      xbox.0	2020-01-18 00:53:20.554	debug	(8629) [CONNECT] Check connection
      xbox.0	2020-01-18 00:53:20.553	error	(8629) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
      xbox.0	2020-01-18 00:53:20.547	debug	(8629) [DISCOVER] Searching for consoles
      xbox.0	2020-01-18 00:53:20.543	debug	(8629) [PING] Xbox online
      xbox.0	2020-01-18 00:53:19.640	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:53:19.640	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:53:18.637	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:53:18.637	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:53:17.634	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:53:17.633	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:53:16.630	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:53:16.629	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:53:15.627	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:53:15.627	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:53:14.624	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:53:14.623	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:53:14.547	debug	(8629) [CHECK] Auth is not established
      xbox.0	2020-01-18 00:53:14.546	debug	(8629) [CONNECT] Ping response, but provided LiveID has not been discovered until now
      xbox.0	2020-01-18 00:53:14.545	debug	(8629) [CONNECT] Check connection
      xbox.0	2020-01-18 00:53:14.544	error	(8629) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
      xbox.0	2020-01-18 00:53:14.541	debug	(8629) [DISCOVER] Searching for consoles
      xbox.0	2020-01-18 00:53:14.539	debug	(8629) [PING] Xbox online
      xbox.0	2020-01-18 00:53:13.621	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:53:13.621	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:53:12.618	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:53:12.617	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:53:11.615	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:53:11.615	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:53:10.612	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:53:10.611	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:53:09.608	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:53:09.599	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:53:08.596	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:53:08.595	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:53:08.549	debug	(8629) [CHECK] Auth is not established
      xbox.0	2020-01-18 00:53:08.547	debug	(8629) [CONNECT] Ping response, but provided LiveID has not been discovered until now
      xbox.0	2020-01-18 00:53:08.547	debug	(8629) [CONNECT] Check connection
      xbox.0	2020-01-18 00:53:08.546	error	(8629) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
      xbox.0	2020-01-18 00:53:08.543	debug	(8629) [DISCOVER] Searching for consoles
      xbox.0	2020-01-18 00:53:08.540	debug	(8629) [PING] Xbox online
      xbox.0	2020-01-18 00:53:07.593	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:53:07.593	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:53:06.590	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:53:06.589	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:53:05.586	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:53:05.585	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:53:04.583	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:53:04.582	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:53:03.580	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:53:03.580	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:53:02.577	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:53:02.577	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:53:02.561	debug	(8629) [CHECK] Auth is not established
      xbox.0	2020-01-18 00:53:02.559	warn	(8629) [CONNECT] Ping response, but provided LiveID has not been discovered until now
      xbox.0	2020-01-18 00:53:02.558	debug	(8629) [CONNECT] Check connection
      xbox.0	2020-01-18 00:53:02.556	error	(8629) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
      xbox.0	2020-01-18 00:53:02.552	debug	(8629) [DISCOVER] Searching for consoles
      xbox.0	2020-01-18 00:53:02.547	debug	(8629) [PING] Xbox online
      xbox.0	2020-01-18 00:53:01.575	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:53:01.575	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:53:00.572	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:53:00.572	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:52:59.568	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:52:59.568	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:52:58.564	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:52:58.563	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:52:57.560	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:52:57.559	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:52:56.554	warn	(8629) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-18 00:52:56.554	debug	(8629) Could not parse body
      xbox.0	2020-01-18 00:52:56.543	debug	(8629) [LOGOUT] <=== Failed to logout: undefined
      xbox.0	2020-01-18 00:52:54.718	debug	(8629) system.adapter.admin.0: logging true
      xbox.0	2020-01-18 00:52:51.805	error	(8629) [START] Restarting adapter in 30 seconds
      xbox.0	2020-01-18 00:52:51.804	error	SyntaxError: invalid syntax
      xbox.0	2020-01-18 00:52:51.804	error	^
      xbox.0	2020-01-18 00:52:51.804	error	cls, data, context=None, many=None, partial=None, unknown=None, *args, **kwargs,
      xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/marshmallow_objects/models.py", line 209
      xbox.0	2020-01-18 00:52:51.804	error	from marshmallow_objects.models import ( # noqa
      xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/marshmallow_objects/__init__.py", line 3, in <module>
      xbox.0	2020-01-18 00:52:51.804	error	from marshmallow_objects import Model, NestedModel, fields
      xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/stump/json_model.py", line 4, in <module>
      xbox.0	2020-01-18 00:52:51.804	error	from xbox.stump import json_model
      xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/stump/manager.py", line 13, in <module>
      xbox.0	2020-01-18 00:52:51.804	error	from xbox.stump.manager import StumpManager
      xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/consolewrap.py", line 6, in <module>
      xbox.0	2020-01-18 00:52:51.804	error	from ..consolewrap import ConsoleWrap
      xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/routes/device.py", line 6, in <module>
      xbox.0	2020-01-18 00:52:51.804	error	from .device import *
      xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/routes/__init__.py", line 6, in <module>
      xbox.0	2020-01-18 00:52:51.804	error	from .routes import routes
      xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/app.py", line 5, in <module>
      xbox.0	2020-01-18 00:52:51.804	error	from xbox.rest.app import app
      xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/scripts/rest_server.py", line 9, in <module>
      xbox.0	2020-01-18 00:52:51.804	error	from xbox.rest.scripts.rest_server import main
      xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server", line 5, in <module>
      xbox.0	2020-01-18 00:52:51.804	error	Traceback (most recent call last):
      xbox.0	2020-01-18 00:52:51.804	error	(8629) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
      xbox.0	2020-01-18 00:52:49.985	info	(8629) [START] Starting REST server
      xbox.0	2020-01-18 00:52:49.985	debug	(8629) [START] IP address is 10.0.1.83
      xbox.0	2020-01-18 00:52:49.962	info	(8629) starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.17.0
      xbox.0	2020-01-18 00:52:47.961	debug	(8629) States connected to redis: 0.0.0.0:9000
      xbox.0	2020-01-18 00:52:47.909	debug	(8629) statesDB connected
      xbox.0	2020-01-18 00:52:47.908	debug	(8629) States create PubSub Client
      xbox.0	2020-01-18 00:52:47.898	debug	(8629) Objects connected to redis: 0.0.0.0:9001
      xbox.0	2020-01-18 00:52:47.896	debug	(8629) Redis States: Use Redis connection: 0.0.0.0:9000
      xbox.0	2020-01-18 00:52:47.894	debug	(8629) objectDB connected
      xbox.0	2020-01-18 00:52:47.883	debug	(8629) Objects client initialize lua scripts
      xbox.0	2020-01-18 00:52:47.882	debug	(8629) Objects create PubSub Client
      xbox.0	2020-01-18 00:52:47.873	debug	(8629) Objects client ready ... initialize now
      xbox.0	2020-01-18 00:52:47.840	debug	(8629) Redis Objects: Use Redis connection: 0.0.0.0:9001
      • foxriver76
        foxriver76 Developer @Negalein last edited by
        @Negalein braucht gerade immer ein reinstall sorry: npm i iobroker.xbox --unsafe-perm --prefix /opt/iobroker --production
        • Negalein
                           from ../node_modules/nan/nan.h:82,
                           from ../src/bufferutil.cc:16:
          ../node_modules/nan/nan_implementation_12_inl.h:49:60: error: expected primary-expression before ‘>’ token
             return v8::BooleanObject::New(value).As<v8::BooleanObject>();
          ../node_modules/nan/nan_implementation_12_inl.h:49:62: error: expected primary-expression before ‘)’ token
          ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::RegExp>::return_t NanIntern::Factory<v8::RegExp>::New(v8::Handle<v8::String>, v8::RegExp::Flags)’:
          ../node_modules/nan/nan_implementation_12_inl.h:158:40: warning: ‘static v8::Local<v8::RegExp> v8::RegExp::New(v8::Local<v8::String>, v8::RegExp::Flags)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             return v8::RegExp::New(pattern, flags);
          In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,
                           from ../src/bufferutil.cc:7:
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5110:38: note: declared here
                                  Local<RegExp> New(Local<String> pattern, Flags flags));
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
             declarator __attribute__((deprecated(message)))
          In file included from ../node_modules/nan/nan_new.h:189:0,
          ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>)’:
          ../node_modules/nan/nan_implementation_12_inl.h:166:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’
             return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);
          In file included from ../src/bufferutil.cc:7:0:
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)
             static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 provided
          ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
          ../node_modules/nan/nan_implementation_12_inl.h:173:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’
          ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(const uint8_t*, int)’:
          ../node_modules/nan/nan_implementation_12_inl.h:206:42: error: no matching function for call to ‘v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*&, v8::String::NewStringType, int&)’
                   v8::String::kNormalString, length);
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note: candidate: static v8::MaybeLocal<v8::String> v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::NewStringType, int)
             static V8_WARN_UNUSED_RESULT MaybeLocal<String> NewFromOneByte(
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note:   no known conversion for argument 3 from ‘v8::String::NewStringType’ to ‘v8::NewStringType’
          ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(v8::String::ExternalStringResource*)’:
          ../node_modules/nan/nan_implementation_12_inl.h:217:66: error: no matching function for call to ‘v8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*&)’
             return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note: candidate: static v8::Local<v8::String> v8::String::NewExternal(v8::Isolate*, v8::String::ExternalOneByteStringResource*)
                 Local<String> NewExternal(Isolate* isolate,
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’
           #define V8_DEPRECATE_SOON(message, declarator) declarator
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note:   no known conversion for argument 2 from ‘v8::String::ExternalStringResource*’ to ‘v8::String::ExternalOneByteStringResource*’
          ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>)’:
          ../node_modules/nan/nan_implementation_12_inl.h:237:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’
             return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);
          ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
          ../node_modules/nan/nan_implementation_12_inl.h:244:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’
          In file included from ../src/bufferutil.cc:16:0:
          ../node_modules/nan/nan.h: In function ‘uint32_t NanUInt32OptionValue(v8::Local<v8::Object>, v8::Handle<v8::String>, uint32_t)’:
          ../node_modules/nan/nan.h:248:43: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                 ? optionsObj->Get(opt)->Uint32Value()
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2477:47: note: declared here
             V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
          ../node_modules/nan/nan.h: At global scope:
          ../node_modules/nan/nan.h:261:25: error: redefinition of ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Local<T>)’
           NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Local<T> val) {
          ../node_modules/nan/nan.h:256:25: note: ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Handle<T>)’ previously declared here
           NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Handle<T> val) {
          ../node_modules/nan/nan.h: In function ‘bool NanIdleNotification(int)’:
          ../node_modules/nan/nan.h:289:39: error: ‘class v8::Isolate’ has no member named ‘IdleNotification’; did you mean ‘IdleNotificationDeadline’?
               return v8::Isolate::GetCurrent()->IdleNotification(idle_time_in_ms);
          ../node_modules/nan/nan.h:473:20: error: variable or field ‘NanAddGCEpilogueCallback’ declared void
                 v8::Isolate::GCEpilogueCallback callback
          ../node_modules/nan/nan.h:473:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
          ../node_modules/nan/nan.h:474:18: error: expected primary-expression before ‘gc_type_filter’
               , v8::GCType gc_type_filter = v8::kGCTypeAll) {
          ../node_modules/nan/nan.h:479:20: error: variable or field ‘NanRemoveGCEpilogueCallback’ declared void
                 v8::Isolate::GCEpilogueCallback callback) {
          ../node_modules/nan/nan.h:479:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
          ../node_modules/nan/nan.h:484:20: error: variable or field ‘NanAddGCPrologueCallback’ declared void
                 v8::Isolate::GCPrologueCallback callback
          ../node_modules/nan/nan.h:484:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
          ../node_modules/nan/nan.h:485:18: error: expected primary-expression before ‘gc_type_filter’
          ../node_modules/nan/nan.h:490:20: error: variable or field ‘NanRemoveGCPrologueCallback’ declared void
                 v8::Isolate::GCPrologueCallback callback) {
          ../node_modules/nan/nan.h:490:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
          ../node_modules/nan/nan.h:569:15: error: ‘WeakCallbackData’ in namespace ‘v8’ does not name a template type
               const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {
          ../node_modules/nan/nan.h:569:31: error: expected ‘,’ or ‘...’ before ‘<’ token
          ../node_modules/nan/nan.h: In function ‘void _NanWeakCallbackDispatcher(int)’:
          ../node_modules/nan/nan.h:570:42: error: ‘data’ was not declared in this scope
                 _NanWeakCallbackInfo<T, P> *info = data.GetParameter();
          ../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared
               , node::smalloc::FreeCallback callback
          ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’
          ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(char*, size_t, int)’:
          ../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope
                   v8::Isolate::GetCurrent(), data, length, callback, hint);
          ../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope
          ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(const char*, uint32_t)’:
          ../node_modules/nan/nan.h:672:67: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]
               return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);
          In file included from ../src/bufferutil.cc:10:0:
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/node_buffer.h:68:40: note:   initializing argument 2 of ‘v8::MaybeLocal<v8::Object> node::Buffer::New(v8::Isolate*, char*, size_t)’
           NODE_EXTERN v8::MaybeLocal<v8::Object> New(v8::Isolate* isolate,
          ../node_modules/nan/nan.h:672:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((char*)data), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’
          ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(uint32_t)’:
          ../node_modules/nan/nan.h:676:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’
               return node::Buffer::New(v8::Isolate::GetCurrent(), size);
          ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanBufferUse(char*, uint32_t)’:
          ../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’
               return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);
          ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
          ../node_modules/nan/nan.h:710:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’
               return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);
          ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>)’:
          ../node_modules/nan/nan.h:717:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’
          ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::UnboundScript>)’:
          ../node_modules/nan/nan.h:723:48: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               return script->BindToCurrentContext()->Run();
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here
             V8_DEPRECATED("Use maybe version", Local<Value> Run());
          ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::Script>)’:
          ../node_modules/nan/nan.h:729:24: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               return script->Run();
          ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::Function>, int, v8::Handle<v8::Value>*)’:
          ../node_modules/nan/nan.h:738:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ isdeprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                   v8::Isolate::GetCurrent(), target, func, argc, argv));
          In file included from ../src/bufferutil.cc:8:0:
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:177:50: note: declared here
                           NODE_EXTERN v8::Local<v8::Value> MakeCallback(
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
               __attribute__((deprecated(message))) declarator
          ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::String>, int, v8::Handle<v8::Value>*)’:
          ../node_modules/nan/nan.h:747:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                   v8::Isolate::GetCurrent(), target, symbol, argc, argv));
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:170:50: note: declared here
          ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, const char*, int, v8::Handle<v8::Value>*)’:
          ../node_modules/nan/nan.h:756:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated:Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                   v8::Isolate::GetCurrent(), target, method, argc, argv));
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:163:50: note: declared here
          ../node_modules/nan/nan.h: In member function ‘v8::Handle<v8::Value> NanCallback::Call_(v8::Isolate*, v8::Handle<v8::Object>, int, v8::Handle<v8::Value>*) const’:
          ../node_modules/nan/nan.h:1569:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ isdeprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
          ../node_modules/nan/nan.h:398:59: note: in definition of macro ‘NanEscapeScope’
           # define NanEscapeScope(val) scope.Escape(_NanEnsureLocal(val))
          ../node_modules/nan/nan.h: In function ‘void* _NanRawString(v8::Handle<v8::Value>, Nan::Encoding, size_t*, void*, size_t, int)’:
          ../node_modules/nan/nan.h:2164:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                   v8::String::Value value(toStr);
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here
               V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));
          ../node_modules/nan/nan.h:2198:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
          ../node_modules/nan/nan.h: In constructor ‘NanTap::NanTap(v8::Handle<v8::Value>)’:
          ../node_modules/nan/nan.h:2292:41: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               NanAssignPersistent(t_, t->ToObject());
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here
           Local<Object> Value::ToObject() const {
          ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Initialize(v8::Handle<v8::Object>)’:
          ../src/bufferutil.cc:30:52: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [7], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
               NODE_SET_METHOD(t, "unmask", BufferUtil::Unmask);
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback)
           inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback)
           inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,
          ../src/bufferutil.cc:31:48: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [5], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
               NODE_SET_METHOD(t, "mask", BufferUtil::Mask);
          ../src/bufferutil.cc:32:50: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [6], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
               NODE_SET_METHOD(t, "merge", BufferUtil::Merge);
          ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Merge(const v8::FunctionCallbackInfo<v8::Value>&)’:
          ../src/bufferutil.cc:49:49: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               Local<Object> bufferObj = args[0]->ToObject();
          ../src/bufferutil.cc:56:51: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                 Local<Object> src = array->Get(i)->ToObject();
          ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Unmask(const v8::FunctionCallbackInfo<v8::Value>&)’:
          ../src/bufferutil.cc:67:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               Local<Object> buffer_obj = args[0]->ToObject();
          ../src/bufferutil.cc:69:48: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               Local<Object> mask_obj = args[1]->ToObject();
          ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Mask(const v8::FunctionCallbackInfo<v8::Value>&)’:
          ../src/bufferutil.cc:88:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
          ../src/bufferutil.cc:89:48: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
          ../src/bufferutil.cc:91:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               Local<Object> output_obj = args[2]->ToObject();
          ../src/bufferutil.cc:92:51: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               unsigned int dataOffset = args[3]->Int32Value();
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2478:46: note: declared here
             V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
          ../src/bufferutil.cc:93:47: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               unsigned int length = args[4]->Int32Value();
          bufferutil.target.mk:105: die Regel für Ziel „Release/obj.target/bufferutil/src/bufferutil.o“ scheiterte
          make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Fehler 1
          make: Verzeichnis „/opt/iobroker/node_modules/bufferutil/build“ wird verlassen
          gyp ERR! build error
          gyp ERR! stack Error: `make` failed with exit code: 2
          gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:193:23)
          gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
          gyp ERR! System Linux 4.4.59+
          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
          gyp ERR! cwd /opt/iobroker/node_modules/bufferutil
          gyp ERR! node -v v10.17.0
          gyp ERR! node-gyp -v v5.0.3
          gyp ERR! not ok
          > utf-8-validate@1.1.0 install /opt/iobroker/node_modules/utf-8-validate
          > node-gyp rebuild
          make: Verzeichnis „/opt/iobroker/node_modules/utf-8-validate/build“ wird betreten
            CXX(target) Release/obj.target/validation/src/validation.o
          In file included from ../node_modules/nan/nan.h:82:0,
                           from ../src/validation.cc:15:
          ../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Integer; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:
          ../node_modules/nan/nan_new.h:29:66: warning: ‘v8::Local<v8::Integer> v8::Value::ToInteger() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           To<v8::Integer>(v8::Handle<v8::Integer> i) { return i->ToInteger(); }
          In file included from ../src/validation.cc:7:0:
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10052:16: note: declared here
           Local<Integer> Value::ToInteger() const {
          ../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Int32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:
          ../node_modules/nan/nan_new.h:34:64: error: no matching function for call to ‘v8::Integer::ToInt32()’
           To<v8::Int32>(v8::Handle<v8::Integer> i)   { return i->ToInt32(); }
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note: candidate: v8::MaybeLocal<v8::Int32> v8::Value::ToInt32(v8::Local<v8::Context>) const
             V8_WARN_UNUSED_RESULT MaybeLocal<Int32> ToInt32(Local<Context> context) const;
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note:   candidate expects 1 argument, 0 provided
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note: candidate: v8::Local<v8::Int32> v8::Value::ToInt32(v8::Isolate*) const
                           Local<Int32> ToInt32(Isolate* isolate) const);
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note:   candidate expects 1 argument, 0 provided
          ../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Uint32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:
          ../node_modules/nan/nan_new.h:39:65: error: no matching function for call to ‘v8::Integer::ToUint32()’
           To<v8::Uint32>(v8::Handle<v8::Integer> i)  { return i->ToUint32(); }
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note: candidate: v8::MaybeLocal<v8::Uint32> v8::Value::ToUint32(v8::Local<v8::Context>) const
             V8_WARN_UNUSED_RESULT MaybeLocal<Uint32> ToUint32(
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note:   candidate expects 1 argument, 0 provided
          ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::BooleanObject>::return_t NanIntern::Factory<v8::BooleanObject>::New(bool)’:
          ../node_modules/nan/nan_implementation_12_inl.h:49:38: error: no matching function for call to ‘v8::BooleanObject::New(bool&)’
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note: candidate: static v8::Local<v8::Value> v8::BooleanObject::New(v8::Isolate*, bool)
             static Local<Value> New(Isolate* isolate, bool value);
          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note:   candidate expects 2 arguments, 1 provided
          In file included from ../src/validation.cc:15:0:
          In file included from ../src/validation.cc:10:0:
          In file included from ../src/validation.cc:8:0:
          ../src/validation.cc: In static member function ‘static void Validation::Initialize(v8::Handle<v8::Object>)’:
          ../src/validation.cc:112:62: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [12], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’is ambiguous
               NODE_SET_METHOD(t, "isValidUTF8", Validation::IsValidUTF8);
          ../src/validation.cc: In static member function ‘static void Validation::IsValidUTF8(const v8::FunctionCallbackInfo<v8::Value>&)’:
          ../src/validation.cc:132:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
          validation.target.mk:105: die Regel für Ziel „Release/obj.target/validation/src/validation.o“ scheiterte
          make: *** [Release/obj.target/validation/src/validation.o] Fehler 1
          make: Verzeichnis „/opt/iobroker/node_modules/utf-8-validate/build“ wird verlassen
          gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validate
          gyp ERR! not ok
          > iobroker.xbox@0.5.12 install /opt/iobroker/node_modules/iobroker.xbox
          > npip install
          No python_modules directory; installing pip locally if needed.
          Successfully completed pip check.
          Collecting xbox-smartglass-rest>=0.9.8
            Using cached https://files.pythonhosted.org/packages/4d/4f/f035df8a2ec5742b9e772071e006ea21aae3fc3bd0963753cfc1045d6fda/xbox_smartglass_rest-0.9.8-py2.py3-none-any.whl
          Collecting xbox-smartglass-stump>=0.9.5
            Using cached https://files.pythonhosted.org/packages/34/f0/a75667f67ce6251b96a6989b8169eb9f2e25407ce2b0888e544b8caa98fe/xbox_smartglass_stump-0.9.5-py2.py3-none-any.whl
          Collecting Flask
            Using cached https://files.pythonhosted.org/packages/9b/93/628509b8d5dc749656a9641f4caf13540e2cdec85276964ff8f43bbb1d3b/Flask-1.1.1-py2.py3-none-any.whl
          Collecting xbox-smartglass-core>=1.0.12
            Using cached https://files.pythonhosted.org/packages/13/c8/2ffce1ddabe5b73422c7c46e808e4b02dbbc9362d2ecd2aee2a65e6e30a5/xbox_smartglass_core-1.0.12-py2.py3-none-any.whl
          Collecting xbox-webapi>=1.1.7
            Using cached https://files.pythonhosted.org/packages/2d/bf/aaf24cc78184393c5c2472e822c0e145b793e346a8085bee02e89a3428ba/xbox_webapi-1.1.7-py2.py3-none-any.whl
          Collecting marshmallow-objects
            Using cached https://files.pythonhosted.org/packages/4d/1c/fe15bc370707e8f8db09ab0edead45ab413b75795a8be523ca6482152183/marshmallow_objects-2.0.0-py2.py3-none-any.whl
          Collecting Jinja2>=2.10.1
            Using cached https://files.pythonhosted.org/packages/65/e0/eb35e762802015cab1ccee04e8a277b03f1d8e53da3ec3106882ec42558b/Jinja2-2.10.3-py2.py3-none-any.whl
          Collecting click>=5.1
            Using cached https://files.pythonhosted.org/packages/fa/37/45185cb5abbc30d7257104c434fe0b07e5a195a6847506c074527aa599ec/Click-7.0-py2.py3-none-any.whl
          Collecting itsdangerous>=0.24
            Using cached https://files.pythonhosted.org/packages/76/ae/44b03b253d6fade317f32c24d100b3b35c2239807046a4c953c7b89fa49e/itsdangerous-1.1.0-py2.py3-none-any.whl
          Collecting Werkzeug>=0.15
            Using cached https://files.pythonhosted.org/packages/ce/42/3aeda98f96e85fd26180534d36570e4d18108d62ae36f87694b476b83d6f/Werkzeug-0.16.0-py2.py3-none-any.whl
          Collecting gevent==1.3.7
            Using cached https://files.pythonhosted.org/packages/87/c4/9afb40b4a8b9186787d477aa6ebcfa17ead40ecbf83d5a1ed53dadd4f6ef/gevent-1.3.7-cp35-cp35m-manylinux1_x86_64.whl
          Processing /home/iobroker/.cache/pip/wheels/13/cd/02/acabe4bfa9899d53c3e3b13675610d2e2dcb9ae110359d4f61/construct-2.9.41-cp35-none-any.whl
          Collecting cryptography==2.3.1
            Using cached https://files.pythonhosted.org/packages/59/32/92cade62c645756a83598edf56289e9b19aae5370642a7ce690cd06bc72f/cryptography-2.3.1-cp34-abi3-manylinux1_x86_64.whl
          Collecting appdirs==1.4.3
            Using cached https://files.pythonhosted.org/packages/56/eb/810e700ed1349edde4cbdc1b2a21e28cdf115f9faf263f6bbf8447c1abf3/appdirs-1.4.3-py2.py3-none-any.whl
          Processing /home/iobroker/.cache/pip/wheels/0a/5f/3c/e0ffceb6554711f12a7101384f29ec13b85136dfcf1f692b8f/dpkt-1.9.1-cp35-none-any.whl
          Processing /home/iobroker/.cache/pip/wheels/34/06/50/24011714e101b5ad8518c69175d117a257413e3c15a92983f0/urwid-2.0.1-cp35-none-any.whl
          Collecting aenum==2.1.2; python_version <= "3.5"
            Using cached https://files.pythonhosted.org/packages/0d/46/5b6a6c13fee40f9dfaba84de1394bfe082c0c7d95952ba0ffbd56ce3a3f7/aenum-2.1.2-py3-none-any.whl
          Processing /home/iobroker/.cache/pip/wheels/c5/d2/ab/a54fb5ea53ac3badba098160e8452fa126a51febda80440ded/demjson-2.2.4-cp35-none-any.whl
          Collecting requests
            Using cached https://files.pythonhosted.org/packages/51/bd/23c926cd341ea6b7dd0b2a00aba99ae0f828be89d72b2190f27c11d4b7fb/requests-2.22.0-py2.py3-none-any.whl
          Collecting marshmallow>=3.0.0
            Using cached https://files.pythonhosted.org/packages/6e/76/01224f14737627166b94eb3bf0e334372c014edca781e39db320ce977755/marshmallow-3.3.0-py2.py3-none-any.whl
          Collecting MarkupSafe>=0.23
            Using cached https://files.pythonhosted.org/packages/6e/57/d40124076756c19ff2269678de7ae25a14ebbb3f6314eb5ce9477f191350/MarkupSafe-1.1.1-cp35-cp35m-manylinux1_x86_64.whl
          Collecting greenlet>=0.4.14; platform_python_implementation == "CPython"
            Using cached https://files.pythonhosted.org/packages/2e/65/27f35497cc0102a792390d056e793e064da95fc9eae45d75ae0ba49c0a0d/greenlet-0.4.15-cp35-cp35m-manylinux1_x86_64.whl
          Collecting idna>=2.1
            Using cached https://files.pythonhosted.org/packages/14/2c/cd551d81dbe15200be1cf41cd03869a46fe7226e7450af7a6545bfc474c9/idna-2.8-py2.py3-none-any.whl
          Collecting asn1crypto>=0.21.0
            Using cached https://files.pythonhosted.org/packages/e9/51/1db4a60049fb7390959be586b6eb743098e6cea3f6b2d3ed9e17fec62ba2/asn1crypto-1.3.0-py2.py3-none-any.whl
          Collecting cffi!=1.11.3,>=1.7
            Using cached https://files.pythonhosted.org/packages/a8/8d/986e0c4e2aa3b24db56a0affc50d1a379150e3c4da45d51d549dc2697d53/cffi-1.13.2-cp35-cp35m-manylinux1_x86_64.whl
          Collecting six>=1.4.1
            Using cached https://files.pythonhosted.org/packages/65/eb/1f97cb97bfc2390a276969c6fae16075da282f5058082d4cb10c6c5c1dba/six-1.14.0-py2.py3-none-any.whl
          Collecting certifi>=2017.4.17
            Using cached https://files.pythonhosted.org/packages/b9/63/df50cac98ea0d5b006c55a399c3bf1db9da7b5a24de7890bc9cfd5dd9e99/certifi-2019.11.28-py2.py3-none-any.whl
          Collecting chardet<3.1.0,>=3.0.2
            Using cached https://files.pythonhosted.org/packages/bc/a9/01ffebfb562e4274b6487b4bb1ddec7ca55ec7510b22e4c51f14098443b8/chardet-3.0.4-py2.py3-none-any.whl
          Collecting urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1
            Using cached https://files.pythonhosted.org/packages/b4/40/a9837291310ee1ccc242ceb6ebfd9eb21539649f193a7c8c86ba15b98539/urllib3-1.25.7-py2.py3-none-any.whl
          Processing /home/iobroker/.cache/pip/wheels/f2/9a/90/de94f8556265ddc9d9c8b271b0f63e57b26fb1d67a45564511/pycparser-2.19-py2.py3-none-any.whl
          Installing collected packages: marshmallow, marshmallow-objects, greenlet, gevent, construct, idna, asn1crypto, pycparser, cffi, six, cryptography, appdirs, demjson, urwid, certifi, chardet, urllib3, requests, xbox-webapi, dpkt, aenum, xbox-smartglass-core, xbox-smartglass-stump, MarkupSafe, Jinja2, click, itsdangerous, Werkzeug, Flask, xbox-smartglass-rest
          Successfully installed Flask-1.1.1 Jinja2-2.10.3 MarkupSafe-1.1.1 Werkzeug-0.16.0 aenum-2.1.2 appdirs-1.4.3 asn1crypto-1.3.0 certifi-2019.11.28 cffi-1.13.2 chardet-3.0.4 click-7.0 construct-2.9.41 cryptography-2.3.1 demjson-2.2.4 dpkt-1.9.1 gevent-1.3.7 greenlet-0.4.15 idna-2.8 itsdangerous-1.1.0 marshmallow-3.3.0 marshmallow-objects-2.0.0 pycparser-2.19 requests-2.22.0 six-1.14.0 urllib3-1.25.7 urwid-2.0.1 xbox-smartglass-core-1.0.12 xbox-smartglass-rest-0.9.8 xbox-smartglass-stump-0.9.5 xbox-webapi-1.1.7
          npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/iobroker.type-detector'
          npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.
          npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 (node_modules/bufferutil):
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 install: `node-gyp rebuild`
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 (node_modules/utf-8-validate):
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 install: `node-gyp rebuild`
          + iobroker.xbox@0.5.12
          updated 1 package in 68.765s
          Adapter gelb
          xbox.0	2020-01-18 01:22:32.977	info	(28813) [START] Starting REST server
          xbox.0	2020-01-18 01:22:32.977	debug	(28813) [START] IP address is 10.0.1.83
          xbox.0	2020-01-18 01:22:32.956	info	(28813) starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.17.0
          xbox.0	2020-01-18 01:22:26.538	info	(28335) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          xbox.0	2020-01-18 01:22:26.537	info	(28335) terminating
          xbox.0	2020-01-18 01:22:26.536	info	(28335) [END] cleaned everything up...
          xbox.0	2020-01-18 01:22:26.522	info	(28335) [END] REST server stopped
          xbox.0	2020-01-18 01:22:26.508	debug	(28335) [LOGOUT] <=== Failed to logout: undefined
          xbox.0	2020-01-18 01:22:26.500	info	(28335) Got terminate signal TERMINATE_YOURSELF
          xbox.0	2020-01-18 01:22:26.413	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:26.413	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:25.410	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:25.410	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:25.316	debug	(28335) [CONNECT] Ping response, but provided LiveID has not been discovered until now
          xbox.0	2020-01-18 01:22:25.315	debug	(28335) [CONNECT] Check connection
          xbox.0	2020-01-18 01:22:25.315	error	(28335) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
          xbox.0	2020-01-18 01:22:25.314	debug	(28335) [CHECK] Auth is not established
          xbox.0	2020-01-18 01:22:25.309	debug	(28335) [DISCOVER] Searching for consoles
          xbox.0	2020-01-18 01:22:25.306	debug	(28335) [PING] Xbox online
          xbox.0	2020-01-18 01:22:24.407	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:24.406	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:23.399	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:23.399	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:22.396	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:22.396	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:21.393	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:21.393	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:20.390	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:20.390	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:19.387	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:19.386	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:19.311	debug	(28335) [CONNECT] Ping response, but provided LiveID has not been discovered until now
          xbox.0	2020-01-18 01:22:19.310	debug	(28335) [CONNECT] Check connection
          xbox.0	2020-01-18 01:22:19.309	error	(28335) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
          xbox.0	2020-01-18 01:22:19.308	debug	(28335) [CHECK] Auth is not established
          xbox.0	2020-01-18 01:22:19.305	debug	(28335) [DISCOVER] Searching for consoles
          xbox.0	2020-01-18 01:22:19.303	debug	(28335) [PING] Xbox online
          xbox.0	2020-01-18 01:22:18.384	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:18.384	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:17.381	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:17.380	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:16.378	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:16.377	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:15.374	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:15.373	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:14.371	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:14.370	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:13.358	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:13.358	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:13.314	debug	(28335) [CHECK] Auth is not established
          xbox.0	2020-01-18 01:22:13.312	debug	(28335) [CONNECT] Ping response, but provided LiveID has not been discovered until now
          xbox.0	2020-01-18 01:22:13.312	debug	(28335) [CONNECT] Check connection
          xbox.0	2020-01-18 01:22:13.311	error	(28335) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
          xbox.0	2020-01-18 01:22:13.308	debug	(28335) [DISCOVER] Searching for consoles
          xbox.0	2020-01-18 01:22:13.305	debug	(28335) [PING] Xbox online
          xbox.0	2020-01-18 01:22:12.355	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:12.355	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:11.351	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:11.351	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:10.348	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:10.347	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:09.345	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:09.345	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:08.341	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:08.341	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:07.337	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:07.337	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:07.325	debug	(28335) [CHECK] Auth is not established
          xbox.0	2020-01-18 01:22:07.323	warn	(28335) [CONNECT] Ping response, but provided LiveID has not been discovered until now
          xbox.0	2020-01-18 01:22:07.322	debug	(28335) [CONNECT] Check connection
          xbox.0	2020-01-18 01:22:07.320	error	(28335) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
          xbox.0	2020-01-18 01:22:07.315	debug	(28335) [DISCOVER] Searching for consoles
          xbox.0	2020-01-18 01:22:07.311	debug	(28335) [PING] Xbox online
          xbox.0	2020-01-18 01:22:06.335	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:06.334	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:05.332	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:05.332	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:04.328	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:04.328	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:03.324	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:03.324	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:02.321	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:02.321	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:01.318	warn	(28335) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 01:22:01.318	debug	(28335) Could not parse body
          xbox.0	2020-01-18 01:22:01.308	debug	(28335) [LOGOUT] <=== Failed to logout: undefined
          xbox.0	2020-01-18 01:21:58.846	debug	(28335) system.adapter.admin.0: logging true
          xbox.0	2020-01-18 01:21:56.483	error	(28335) [START] Restarting adapter in 30 seconds
          xbox.0	2020-01-18 01:21:56.482	error	SyntaxError: invalid syntax
          xbox.0	2020-01-18 01:21:56.482	error	^
          xbox.0	2020-01-18 01:21:56.482	error	cls, data, context=None, many=None, partial=None, unknown=None, *args, **kwargs,
          xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/marshmallow_objects/models.py", line 209
          xbox.0	2020-01-18 01:21:56.482	error	from marshmallow_objects.models import ( # noqa
          xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/marshmallow_objects/__init__.py", line 3, in <module>
          xbox.0	2020-01-18 01:21:56.482	error	from marshmallow_objects import Model, NestedModel, fields
          xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/stump/json_model.py", line 4, in <module>
          xbox.0	2020-01-18 01:21:56.482	error	from xbox.stump import json_model
          xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/stump/manager.py", line 13, in <module>
          xbox.0	2020-01-18 01:21:56.482	error	from xbox.stump.manager import StumpManager
          xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/consolewrap.py", line 6, in <module>
          xbox.0	2020-01-18 01:21:56.482	error	from ..consolewrap import ConsoleWrap
          xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/routes/device.py", line 6, in <module>
          xbox.0	2020-01-18 01:21:56.482	error	from .device import *
          xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/routes/__init__.py", line 6, in <module>
          xbox.0	2020-01-18 01:21:56.482	error	from .routes import routes
          xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/app.py", line 5, in <module>
          xbox.0	2020-01-18 01:21:56.482	error	from xbox.rest.app import app
          xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/scripts/rest_server.py", line 9, in <module>
          xbox.0	2020-01-18 01:21:56.482	error	from xbox.rest.scripts.rest_server import main
          xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server", line 5, in <module>
          xbox.0	2020-01-18 01:21:56.482	error	Traceback (most recent call last):
          xbox.0	2020-01-18 01:21:56.482	error	(28335) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          xbox.0	2020-01-18 01:21:54.708	info	(28335) [START] Starting REST server
          xbox.0	2020-01-18 01:21:54.707	debug	(28335) [START] IP address is 10.0.1.83
          xbox.0	2020-01-18 01:21:54.688	info	(28335) starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.17.0
          xbox.0	2020-01-18 01:21:52.313	debug	(28335) States connected to redis: 0.0.0.0:9000
          xbox.0	2020-01-18 01:21:52.260	debug	(28335) statesDB connected
          xbox.0	2020-01-18 01:21:52.259	debug	(28335) States create PubSub Client
          xbox.0	2020-01-18 01:21:52.250	debug	(28335) Objects connected to redis: 0.0.0.0:9001
          xbox.0	2020-01-18 01:21:52.247	debug	(28335) Redis States: Use Redis connection: 0.0.0.0:9000
          xbox.0	2020-01-18 01:21:52.245	debug	(28335) objectDB connected
          xbox.0	2020-01-18 01:21:52.232	debug	(28335) Objects client initialize lua scripts
          xbox.0	2020-01-18 01:21:52.231	debug	(28335) Objects create PubSub Client
          xbox.0	2020-01-18 01:21:52.223	debug	(28335) Objects client ready ... initialize now
          xbox.0	2020-01-18 01:21:52.164	debug	(28335) Redis Objects: Use Redis connection: 0.0.0.0:9001
          • foxriver76
            foxriver76 Developer @Negalein last edited by foxriver76
            @Negalein sagte in XBox-Adapter Fehler:
            marshmallow_objects
            Jetzt mal bitte pip show marshmallow-objects Ausgabe zeigen und falls da nix kommt oder 2.0.0 kommt mal pip install "marshmallow-objects==1.0.23" dann rm -r /opt/iobroker/node_modules/iobroker.xbox und nochmal npm i iobroker.xbox --unsafe-perm --production --prefix /opt/iobroker
            • Negalein
              Negalein Global Moderator @foxriver76 last edited by Negalein
              root@iobroker:/opt/iobroker# pip show marshmallow-objects
              WARNING: Package(s) not found: marshmallow-objects
              root@iobroker:/opt/iobroker# pip install "marshmallow-objects==1.0.23"
              Collecting marshmallow-objects==1.0.23
                Downloading https://files.pythonhosted.org/packages/2d/e2/05eebaa3d7f54349547792f82710c59457d3dc19dffd5ab9c11cfed3a421/marshmallow_objects-1.0.23-py2.py3-none-any.whl
                Downloading https://files.pythonhosted.org/packages/e3/07/c7a12d21619abeedf5fca7381f4cf3fa798a26e8d92ad66bc73f5fc58fc1/marshmallow-2.20.5-py2.py3-none-any.whl (50kB)
                   |████████████████████████████████| 51kB 475kB/s
              Successfully installed marshmallow-2.20.5 marshmallow-objects-1.0.23
              root@iobroker:/opt/iobroker# rm -r /opt/iobroker/node_modules/iobroker.xbox
              gyp ERR! not ok
              > node-gyp rebuild
              gyp ERR! not ok
              > npip install
              Collecting Flask
              Collecting requests
              Processing /home/iobroker/.cache/pip/wheels/49/b5/ad/7355506059779337473b8eeb49384c9c0a9d45d34c8211a96d/urwid-2.1.0-cp35-cp35m-linux_x86_64.whl
              Collecting appdirs
              Collecting idna<2.9,>=2.5
              ERROR: xbox-smartglass-core 1.0.12 has requirement urwid==2.0.1, but you'll have urwid 2.1.0 which is incompatible.
              Installing collected packages: marshmallow, marshmallow-objects, chardet, certifi, urllib3, idna, requests, demjson, urwid, appdirs, xbox-webapi, greenlet, gevent, construct, asn1crypto, six, pycparser, cffi, cryptography, aenum, dpkt, xbox-smartglass-core, xbox-smartglass-stump, MarkupSafe, Jinja2, itsdangerous, click, Werkzeug, Flask, xbox-smartglass-rest
              Successfully installed Flask-1.1.1 Jinja2-2.10.3 MarkupSafe-1.1.1 Werkzeug-0.16.0 aenum-2.1.2 appdirs-1.4.3 asn1crypto-1.3.0 certifi-2019.11.28 cffi-1.13.2 chardet-3.0.4 click-7.0 construct-2.9.41 cryptography-2.3.1 demjson-2.2.4 dpkt-1.9.1 gevent-1.3.7 greenlet-0.4.15 idna-2.8 itsdangerous-1.1.0 marshmallow-3.3.0 marshmallow-objects-2.0.0 pycparser-2.19 requests-2.22.0 six-1.14.0 urllib3-1.25.7 urwid-2.1.0 xbox-smartglass-core-1.0.12 xbox-smartglass-rest-0.9.8 xbox-smartglass-stump-0.9.5 xbox-webapi-1.1.7
              added 3 packages from 3 contributors in 69.941s
              Adapter gelb
              xbox.0	2020-01-18 01:44:23.875	warn	(11600) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:44:23.874	debug	(11600) Could not parse body
              xbox.0	2020-01-18 01:44:22.872	warn	(11600) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:44:22.872	debug	(11600) Could not parse body
              xbox.0	2020-01-18 01:44:22.852	debug	(11600) [CHECK] Auth is not established
              xbox.0	2020-01-18 01:44:22.850	warn	(11600) [CONNECT] Ping response, but provided LiveID has not been discovered until now
              xbox.0	2020-01-18 01:44:22.849	debug	(11600) [CONNECT] Check connection
              xbox.0	2020-01-18 01:44:22.847	error	(11600) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
              xbox.0	2020-01-18 01:44:22.843	debug	(11600) [DISCOVER] Searching for consoles
              xbox.0	2020-01-18 01:44:22.838	debug	(11600) [PING] Xbox online
              xbox.0	2020-01-18 01:44:21.870	warn	(11600) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:44:21.869	debug	(11600) Could not parse body
              xbox.0	2020-01-18 01:44:20.866	warn	(11600) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:44:20.865	debug	(11600) Could not parse body
              xbox.0	2020-01-18 01:44:19.862	warn	(11600) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:44:19.862	debug	(11600) Could not parse body
              xbox.0	2020-01-18 01:44:18.859	warn	(11600) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:44:18.859	debug	(11600) Could not parse body
              xbox.0	2020-01-18 01:44:17.855	warn	(11600) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:44:17.854	debug	(11600) Could not parse body
              xbox.0	2020-01-18 01:44:16.851	warn	(11600) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:44:16.850	debug	(11600) Could not parse body
              xbox.0	2020-01-18 01:44:16.840	debug	(11600) [LOGOUT] <=== Failed to logout: undefined
              xbox.0	2020-01-18 01:44:12.016	error	(11600) [START] Restarting adapter in 30 seconds
              xbox.0	2020-01-18 01:44:12.015	error	(11600) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found Traceback (most recent call last): File "/opt/iobrok
              xbox.0	2020-01-18 01:44:11.076	debug	(11600) system.adapter.admin.0: logging true
              xbox.0	2020-01-18 01:44:10.252	info	(11600) [START] Starting REST server
              xbox.0	2020-01-18 01:44:10.251	debug	(11600) [START] IP address is 10.0.1.83
              xbox.0	2020-01-18 01:44:10.194	info	(11600) starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.17.0
              xbox.0	2020-01-18 01:44:07.537	debug	(11600) States connected to redis: 0.0.0.0:9000
              xbox.0	2020-01-18 01:44:07.483	debug	(11600) statesDB connected
              xbox.0	2020-01-18 01:44:07.482	debug	(11600) States create PubSub Client
              xbox.0	2020-01-18 01:44:07.473	debug	(11600) Objects connected to redis: 0.0.0.0:9001
              xbox.0	2020-01-18 01:44:07.471	debug	(11600) Redis States: Use Redis connection: 0.0.0.0:9000
              xbox.0	2020-01-18 01:44:07.469	debug	(11600) objectDB connected
              xbox.0	2020-01-18 01:44:07.457	debug	(11600) Objects client initialize lua scripts
              xbox.0	2020-01-18 01:44:07.456	debug	(11600) Objects create PubSub Client
              xbox.0	2020-01-18 01:44:07.448	debug	(11600) Objects client ready ... initialize now
              xbox.0	2020-01-18 01:44:07.415	debug	(11600) Redis Objects: Use Redis connection: 0.0.0.0:9001
              • foxriver76
                @Negalein brauche das install log mal von Anfang an. Habe bei mir mal noch mal geupdated von alter Version, da kommen die ganzen C Geschichten gar nicht. Dachte das war schon damals so.
                Lass es am besten mal in ein File schreiben da es ja sonst abgeschnitten wird npm i iobroker.xbox --unsafe-perm --prefix /opt/iobroker --production &> xbox-logfile. Und mir das File dann mal hochladen o. Inhalt posten.
                • Negalein
                  @foxriver76 sagte in XBox-Adapter Fehler:
                  xbox-logfile.txt
                  • foxriver76
                    @Negalein fangen wir mal oben an. Da fangen die ganzen C-Geschichten an.
                    bufferutil@1.1.0 install /opt/iobroker/node_modules/bufferutil
                    node-gyp rebuild
                    make: Verzeichnis „/opt/iobroker/node_modules/bufferutil/build“ wird betreten
                    Das Package sollte mit Xbox nix zu tun haben. Taucht bei mir in der Package Lock JSON nicht auf. Schauen wir mal ob es überhaupt jemand braucht npm ls bufferutil
                    • Negalein
                      npm ls bufferutil
                      iobroker.inst@1.1.2 /opt/iobroker
                      └─┬ iobroker.kodi@1.0.0
                        └─┬ kodi-ws@2.4.0
                          └─┬ ws@0.7.2
                            └── UNMET OPTIONAL DEPENDENCY bufferutil@1.1.x
                      Kodi könnte ich deinstallieren. Läuft nur ab und an zu Testzwecken.
                      • foxriver76
                        @Negalein die Dep ist sowieso nur optional, da sie ja anscheinend gar nicht gebaut werden kann. Können mal probieren ob npm dann Ruhe gibt rm -r /opt/iobroker/node_modules/bufferutil dann nochmal den Befehl von oben mit Xbox install ins File.
                        • Negalein
                          root@iobroker:/opt/iobroker# rm -r /opt/iobroker/node_modules/bufferutil
                          rm: das Entfernen von '/opt/iobroker/node_modules/bufferutil' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                          • foxriver76
                            @Negalein Anscheinend kommt das von der veralteten Abhängigkeit auf ws https://github.com/instalator/kodi-ws/blob/bde03ec364c022f61e167a83733ef70873b7df73/package.json#L29 da gibt es mittlerweile Version 7.X. 😆
                            Naja, gut allerdings sollte es die Xbox Adapter Installation nicht beeinflussen - ist halt nur äußerst unschick, da theoretisch bei jeder Installation via npm das Logging auftauchen wird und versucht wird die Dep nachzuinstallieren.
                            Dann bleibt eigentlich nur das für den Adapter Install an Logging:
                            > npip install
                            Collecting Flask
                            Collecting requests
                            Installing collected packages: appdirs, demjson, urllib3, certifi, chardet, idna, requests, urwid, xbox-webapi, asn1crypto, pycparser, cffi, six, cryptography, dpkt, aenum, construct, greenlet, gevent, xbox-smartglass-core, Werkzeug, itsdangerous, click, MarkupSafe, Jinja2, Flask, marshmallow, marshmallow-objects, xbox-smartglass-stump, xbox-smartglass-rest
                            updated 1 package in 69.394s
                            Und das schaut eigentlich echt gut aus, bis noch auf die Warning mit dem Link auf sich selbst:
                            npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/iobroker.type-detector' sollte allerdings auch keine Rolle spielen. Hierfür kann man mal ls -lah /opt/iobroker/node_modules machen um nachzuschauen.
                            Xbox loggt ja:
                            xbox.0	2020-01-18 01:44:12.015	error	(11600) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found Traceback (most recent call last): File "/opt/iobrok..
                            Was kommt denn bei ls -lah /opt/iobroker/node_modules/iobroker.xbox/node_modules/nopy/src raus? Und was bei ls -lah /opt/iobroker/node_modules/nopy/src?
                            • Negalein
                              root@iobroker:/opt/iobroker# ls -lah /opt/iobroker/node_modules/iobroker.xbox/node_modules/nopy/src
                              ls: Zugriff auf '/opt/iobroker/node_modules/iobroker.xbox/node_modules/nopy/src' nicht möglich: Datei oder Verzeichnis nicht gefunden
                              root@iobroker:/opt/iobroker# ls -lah /opt/iobroker/node_modules/nopy/src
                              insgesamt 1,6M
                              drwxr-xr-x 1 iobroker iobroker  110 Nov 27 13:52 .
                              drwxr-xr-x 1 iobroker iobroker   98 Nov 27 13:52 ..
                              -rw-r--r-- 1 iobroker iobroker 7,5K Okt 26  1985 api.js
                              -rw-r--r-- 1 iobroker iobroker 1,6M Okt 26  1985 get-pip.py
                              -rwxr-xr-x 1 iobroker iobroker  530 Okt 26  1985 nopenv.js
                              -rwxr-xr-x 1 iobroker iobroker  397 Okt 26  1985 nopy.js
                              -rwxr-xr-x 1 iobroker iobroker 2,3K Okt 26  1985 npip.js
                              -rw-r--r-- 1 iobroker iobroker  313 Okt 26  1985 promisify.js
                              drwxr-xr-x 1 iobroker iobroker   36 Nov 27 13:52 test
                              • foxriver76
                                @Negalein Passt eigentlich auch.
                                Was passiert bei /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js /opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server || /opt/iobroker/node_modules/iobroker.xbox/lib/../../nopy/src/nopy.js /opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server
                                Ist 1 zu 1 das Kommando, dass der Adapter ausführt zum den Server zu starten. Er wird sagen Datei nicht gefunden für das erste und dann greift die Alternative die eigentlich passen sollte.
                                • Negalein
                                  ist das 1 Befehl? Also alles auf 1x kopieren und ausführen?
                                  Wenn Ja, dann kommt das:
                                  root@iobroker:/opt/iobroker# /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js /opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xboxr || /opt/iobroker/node_modules/iobroker.xbox/lib/../../nopy/src/nopy.js /opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server
                                  bash: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: Datei oder Verzeichnis nicht gefunden
                                  • foxriver76
                                    @Negalein Jop passt perfekt, danke. Also sind wir letztendlich wieder bei der Vermutung vom Anfang, mit dieser marhsmallow-objects Depdendency. Bin dran: https://github.com/SVilgelm/marshmallow-objects/issues/70
                                    foxriver76 created this issue in SVilgelm/marshmallow-objects
                                    closed Python support <=3.6 dropped with 2.0? #70
                                    • Negalein
                                      Perfekt!
                                      Dann warte ich mal auf News von dir! 😁
                                      • foxriver76
                                        @Negalein installier Mal neu. Angeblich gefixt mit 2.0.1
                                        • Negalein
                                          $ ./iobroker url "https://github.com/foxriver76/ioBroker.xbox/tarball/master" xbox --debug
                                          install https://github.com/foxriver76/ioBroker.xbox/tarball/master
                                          NPM version: 6.11.3
                                          npm install https://github.com/foxriver76/ioBroker.xbox/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
                                          > iobroker.xbox@0.5.12 preinstall /opt/iobroker/node_modules/iobroker.xbox> dpkg --help > /dev/null && dpkg -s build-essential | grep -q '' && dpkg -s libssl-dev | grep -q '' && dpkg -s libffi-dev | grep -q '' && dpkg -s python3-dev | grep -q '' && echo -e '[INFO] Required Debian packages are already installed!' || apt install -y build-essential libssl-dev libffi-dev python3-dev || echo -e '[INFO] Cannot install build-essential libssl-dev libffi-dev python3-dev Debian packages. If you are on a Linux system, try installing the package via: sudo npm i iobroker.xbox --unsafe-perm, otherwise you have to manage package installation by yourself. If you are not running on Linux, you can ignore this INFO.'
                                          -e [INFO] Required Debian packages are already installed!
                                          > bufferutil@1.1.0 install /opt/iobroker/node_modules/bufferutil> node-gyp rebuild
                                            CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
                                          In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Integer; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:29:66: warning: ‘v8::Local<v8::Integer> v8::Value::ToInteger() const’ is deprecated: Use maybe version [-Wdeprecated-declarations] To<v8::Integer>(v8::Handle<v8::Integer> i) { return i->ToInteger(); }        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10052:16: note: declared here Local<Integer> Value::ToInteger() const {                ^~~~~
                                          In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Int32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:34:64: error: no matching function for call to ‘v8::Integer::ToInt32()’ To<v8::Int32>(v8::Handle<v8::Integer> i)   { return i->ToInt32(); }        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note: candidate: v8::MaybeLocal<v8::Int32> v8::Value::ToInt32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Int32> ToInt32(Local<Context> context) const;                                           ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note: candidate: v8::Local<v8::Int32> v8::Value::ToInt32(v8::Isolate*) const                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note:   candidate expects 1 argument, 0 provided                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
                                          In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Uint32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:39:65: error: no matching function for call to ‘v8::Integer::ToUint32()’ To<v8::Uint32>(v8::Handle<v8::Integer> i)  { return i->ToUint32(); }        ^
                                          In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note: candidate: v8::MaybeLocal<v8::Uint32> v8::Value::ToUint32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Uint32> ToUint32(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note:   candidate expects 1 argument, 0 provided
                                          In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::BooleanObject>::return_t NanIntern::Factory<v8::BooleanObject>::New(bool)’:../node_modules/nan/nan_implementation_12_inl.h:49:38: error: no matching function for call to ‘v8::BooleanObject::New(bool&)’   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                      ^
                                          In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note: candidate: static v8::Local<v8::Value> v8::BooleanObject::New(v8::Isolate*, bool)   static Local<Value> New(Isolate* isolate, bool value);                       ^~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note:   candidate expects 2 arguments, 1 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h:49:60: error: expected primary-expression before ‘>’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                            ^../node_modules/nan/nan_implementation_12_inl.h:49:62: error: expected primary-expression before ‘)’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                              ^
                                          ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::RegExp>::return_t NanIntern::Factory<v8::RegExp>::New(v8::Handle<v8::String>, v8::RegExp::Flags)’:../node_modules/nan/nan_implementation_12_inl.h:158:40: warning: ‘static v8::Local<v8::RegExp> v8::RegExp::New(v8::Local<v8::String>, v8::RegExp::Flags)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   return v8::RegExp::New(pattern, flags);                                        ^
                                          In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5110:38: note: declared here                        Local<RegExp> New(Local<String> pattern, Flags flags));                                      ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
                                          In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:166:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:173:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^
                                          In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(const uint8_t*, int)’:../node_modules/nan/nan_implementation_12_inl.h:206:42: error: no matching function for call to ‘v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*&, v8::String::NewStringType, int&)’         v8::String::kNormalString, length);                                          ^
                                          In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note: candidate: static v8::MaybeLocal<v8::String> v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::NewStringType, int)   static V8_WARN_UNUSED_RESULT MaybeLocal<String> NewFromOneByte(                                                   ^~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note:   no known conversion for argument 3 from ‘v8::String::NewStringType’ to ‘v8::NewStringType’In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(v8::String::ExternalStringResource*)’:../node_modules/nan/nan_implementation_12_inl.h:217:66: error: no matching function for call to ‘v8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*&)’   return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);        ^
                                          In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note: candidate: static v8::Local<v8::String> v8::String::NewExternal(v8::Isolate*, v8::String::ExternalOneByteStringResource*)       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note:   no known conversion for argument 2 from ‘v8::String::ExternalStringResource*’ to ‘v8::String::ExternalOneByteStringResource*’       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~
                                          In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:237:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:244:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~
                                          In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘uint32_t NanUInt32OptionValue(v8::Local<v8::Object>, v8::Handle<v8::String>, uint32_t)’:../node_modules/nan/nan.h:248:43: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]       ? optionsObj->Get(opt)->Uint32Value()                                           ^
                                          In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2477:47: note: declared here   V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);                                               ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:261:25: error: redefinition of ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Local<T>)’ NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Local<T> val) {                         ^~~~~~~~~~~~~~~../node_modules/nan/nan.h:256:25: note: ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Handle<T>)’ previously declared here NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Handle<T> val) {                         ^~~~~~~~~~~~~~~
                                          ../node_modules/nan/nan.h: In function ‘bool NanIdleNotification(int)’:../node_modules/nan/nan.h:289:39: error: ‘class v8::Isolate’ has no member named ‘IdleNotification’; did you mean ‘IdleNotificationDeadline’?     return v8::Isolate::GetCurrent()->IdleNotification(idle_time_in_ms);                                       ^~~~~~~~~~~~~~~~
                                          ../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:473:20: error: variable or field ‘NanAddGCEpilogueCallback’ declared void       v8::Isolate::GCEpilogueCallback callback                    ^~~~~~~~~~~~~~~~~~
                                          ../node_modules/nan/nan.h:473:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCEpilogueCallback callback       ^~../node_modules/nan/nan.h:474:18: error: expected primary-expression before ‘gc_type_filter’     , v8::GCType gc_type_filter = v8::kGCTypeAll) {                  ^~~~~~~~~~~~~~../node_modules/nan/nan.h:479:20: error: variable or field ‘NanRemoveGCEpilogueCallback’ declared void       v8::Isolate::GCEpilogueCallback callback) {                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:479:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCEpilogueCallback callback) {       ^~../node_modules/nan/nan.h:484:20: error: variable or field ‘NanAddGCPrologueCallback’ declared void       v8::Isolate::GCPrologueCallback callback                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:484:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCPrologueCallback callback       ^~../node_modules/nan/nan.h:485:18: error: expected primary-expression before ‘gc_type_filter’     , v8::GCType gc_type_filter = v8::kGCTypeAll) {                  ^~~~~~~~~~~~~~../node_modules/nan/nan.h:490:20: error: variable or field ‘NanRemoveGCPrologueCallback’ declared void       v8::Isolate::GCPrologueCallback callback) {                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:490:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCPrologueCallback callback) {       ^~
                                          ../node_modules/nan/nan.h:569:15: error: ‘WeakCallbackData’ in namespace ‘v8’ does not name a template type     const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {               ^~~~~~~~~~~~~~~~
                                          ../node_modules/nan/nan.h:569:31: error: expected ‘,’ or ‘...’ before ‘<’ token     const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {                               ^../node_modules/nan/nan.h: In function ‘void _NanWeakCallbackDispatcher(int)’:../node_modules/nan/nan.h:570:42: error: ‘data’ was not declared in this scope       _NanWeakCallbackInfo<T, P> *info = data.GetParameter();                                          ^~~~
                                          ../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared     , node::smalloc::FreeCallback callback             ^~~~~~~../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’     , node::smalloc::FreeCallback callback                                   ^~~~~~~~
                                          ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(char*, size_t, int)’:../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                  ^~~~~~~~../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                            ^~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(const char*, uint32_t)’:../node_modules/nan/nan.h:672:67: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);        ^In file included from ../src/bufferutil.cc:10:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_buffer.h:68:40: note:   initializing argument 2 of ‘v8::MaybeLocal<v8::Object> node::Buffer::New(v8::Isolate*, char*, size_t)’ NODE_EXTERN v8::MaybeLocal<v8::Object> New(v8::Isolate* isolate,                                        ^~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h:672:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((char*)data), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(uint32_t)’:../node_modules/nan/nan.h:676:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                          ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanBufferUse(char*, uint32_t)’:../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’     return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);            ^~~~
                                          ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan.h:710:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’     return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);        ^
                                          In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>)’:../node_modules/nan/nan.h:717:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’     return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::UnboundScript>)’:../node_modules/nan/nan.h:723:48: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->BindToCurrentContext()->Run();                                                ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
                                          In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::Script>)’:../node_modules/nan/nan.h:729:24: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->Run();                        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::Function>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:738:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, func, argc, argv));                                                            ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:177:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
                                          In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::String>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:747:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, symbol, argc, argv));                                                              ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:170:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
                                          In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, const char*, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:756:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, method, argc, argv));                                                              ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:163:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
                                          In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In member function ‘v8::Handle<v8::Value> NanCallback::Call_(v8::Isolate*, v8::Handle<v8::Object>, int, v8::Handle<v8::Value>*) const’:../node_modules/nan/nan.h:1569:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]     ));     ^../node_modules/nan/nan.h:398:59: note: in definition of macro ‘NanEscapeScope’ # define NanEscapeScope(val) scope.Escape(_NanEnsureLocal(val))                                                           ^~~
                                          In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘void* _NanRawString(v8::Handle<v8::Value>, Nan::Encoding, size_t*, void*, size_t, int)’:../node_modules/nan/nan.h:2164:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^
                                          In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
                                          In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h:2198:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
                                          In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In constructor ‘NanTap::NanTap(v8::Handle<v8::Value>)’:../node_modules/nan/nan.h:2292:41: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     NanAssignPersistent(t_, t->ToObject());                                         ^
                                          In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
                                          ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Initialize(v8::Handle<v8::Object>)’:../src/bufferutil.cc:30:52: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [7], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "unmask", BufferUtil::Unmask);                                                    ^
                                          In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,             ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,             ^~~~~~~~~~~~~~~../src/bufferutil.cc:31:48: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [5], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "mask", BufferUtil::Mask);                                                ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,             ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,             ^~~~~~~~~~~~~~~../src/bufferutil.cc:32:50: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [6], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "merge", BufferUtil::Merge);                                                  ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,             ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,             ^~~~~~~~~~~~~~~
                                          ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Merge(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/bufferutil.cc:49:49: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> bufferObj = args[0]->ToObject();                                                 ^
                                          In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc:56:51: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]       Local<Object> src = array->Get(i)->ToObject();                                                   ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
                                          ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Unmask(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/bufferutil.cc:67:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> buffer_obj = args[0]->ToObject();                                                  ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
                                          ../src/bufferutil.cc:69:48: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> mask_obj = args[1]->ToObject();                                                ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
                                          ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Mask(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/bufferutil.cc:88:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> buffer_obj = args[0]->ToObject();                                                  ^
                                          In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc:89:48: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> mask_obj = args[1]->ToObject();                                                ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc:91:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> output_obj = args[2]->ToObject();                                                  ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
                                          ../src/bufferutil.cc:92:51: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     unsigned int dataOffset = args[3]->Int32Value();                                                   ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2478:46: note: declared here   V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);                                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/bufferutil.cc:93:47: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     unsigned int length = args[4]->Int32Value();                                               ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2478:46: note: declared here   V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);                                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
                                          bufferutil.target.mk:105: die Regel für Ziel „Release/obj.target/bufferutil/src/bufferutil.o“ scheiterte
                                          make: Verzeichnis „/opt/iobroker/node_modules/bufferutil/build“ wird verlassen
                                          make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Fehler 1
                                          gyp
                                           ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:193:23)gyp ERR!
                                          stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.4.59+gyp
                                           ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/bufferutilgyp ERR! node -v v10.17.0gyp ERR! node-gyp -v v5.0.3gyp
                                           ERR! not ok
                                          > utf-8-validate@1.1.0 install /opt/iobroker/node_modules/utf-8-validate> node-gyp rebuild
                                          make: Verzeichnis „/opt/iobroker/node_modules/utf-8-validate/build“ wird betreten
                                            CXX(target) Release/obj.target/validation/src/validation.o
                                          In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/validation.cc:15:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Integer; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:29:66: warning: ‘v8::Local<v8::Integer> v8::Value::ToInteger() const’ is deprecated: Use maybe version [-Wdeprecated-declarations] To<v8::Integer>(v8::Handle<v8::Integer> i) { return i->ToInteger(); }        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10052:16: note: declared here Local<Integer> Value::ToInteger() const {                ^~~~~
                                          In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/validation.cc:15:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Int32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:34:64: error: no matching function for call to ‘v8::Integer::ToInt32()’ To<v8::Int32>(v8::Handle<v8::Integer> i)   { return i->ToInt32(); }        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note: candidate: v8::MaybeLocal<v8::Int32> v8::Value::ToInt32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Int32> ToInt32(Local<Context> context) const;                                           ^~~~~~~
                                          /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note: candidate: v8::Local<v8::Int32> v8::Value::ToInt32(v8::Isolate*) const                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note:   candidate expects 1 argument, 0 provided                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
                                          In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/validation.cc:15:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Uint32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:39:65: error: no matching function for call to ‘v8::Integer::ToUint32()’ To<v8::Uint32>(v8::Handle<v8::Integer> i)  { return i->ToUint32(); }        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note: candidate: v8::MaybeLocal<v8::Uint32> v8::Value::ToUint32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Uint32> ToUint32(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note:   candidate expects 1 argument, 0 provided
                                          In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::BooleanObject>::return_t NanIntern::Factory<v8::BooleanObject>::New(bool)’:../node_modules/nan/nan_implementation_12_inl.h:49:38: error: no matching function for call to ‘v8::BooleanObject::New(bool&)’   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                      ^
                                          In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note: candidate: static v8::Local<v8::Value> v8::BooleanObject::New(v8::Isolate*, bool)   static Local<Value> New(Isolate* isolate, bool value);                       ^~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note:   candidate expects 2 arguments, 1 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h:49:60: error: expected primary-expression before ‘>’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                            ^../node_modules/nan/nan_implementation_12_inl.h:49:62: error: expected primary-expression before ‘)’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                              ^
                                          In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5110:38: note: declared here                        Local<RegExp> New(Local<String> pattern, Flags flags));                                      ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
                                          In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:166:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 provided
                                          In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:173:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 provided
                                          In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(const uint8_t*, int)’:../node_modules/nan/nan_implementation_12_inl.h:206:42: error: no matching function for call to ‘v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*&, v8::String::NewStringType, int&)’         v8::String::kNormalString, length);                                          ^
                                          In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note: candidate: static v8::MaybeLocal<v8::String> v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::NewStringType, int)   static V8_WARN_UNUSED_RESULT MaybeLocal<String> NewFromOneByte(                                                   ^~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note:   no known conversion for argument 3 from ‘v8::String::NewStringType’ to ‘v8::NewStringType’In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(v8::String::ExternalStringResource*)’:../node_modules/nan/nan_implementation_12_inl.h:217:66: error: no matching function for call to ‘v8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*&)’   return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note: candidate: static v8::Local<v8::String> v8::String::NewExternal(v8::Isolate*, v8::String::ExternalOneByteStringResource*)       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note:   no known conversion for argument 2 from ‘v8::String::ExternalStringResource*’ to ‘v8::String::ExternalOneByteStringResource*’       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~
                                          In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:237:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:244:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~
                                          In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘uint32_t NanUInt32OptionValue(v8::Local<v8::Object>, v8::Handle<v8::String>, uint32_t)’:../node_modules/nan/nan.h:248:43: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]       ? optionsObj->Get(opt)->Uint32Value()                                           ^
                                          In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2477:47: note: declared here   V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);                                               ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:261:25: error: redefinition of ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Local<T>)’ NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Local<T> val) {                         ^~~~~~~~~~~~~~~../node_modules/nan/nan.h:256:25: note: ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Handle<T>)’ previously declared here NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Handle<T> val) {                         ^~~~~~~~~~~~~~~
                                          ../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:473:20: error: variable or field ‘NanAddGCEpilogueCallback’ declared void       v8::Isolate::GCEpilogueCallback callback                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:473:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCEpilogueCallback callback       ^~../node_modules/nan/nan.h:474:18: error: expected primary-expression before ‘gc_type_filter’     , v8::GCType gc_type_filter = v8::kGCTypeAll) {                  ^~~~~~~~~~~~~~../node_modules/nan/nan.h:479:20: error: variable or field ‘NanRemoveGCEpilogueCallback’ declared void       v8::Isolate::GCEpilogueCallback callback) {                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:479:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCEpilogueCallback callback) {       ^~../node_modules/nan/nan.h:484:20: error: variable or field ‘NanAddGCPrologueCallback’ declared void       v8::Isolate::GCPrologueCallback callback                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:484:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCPrologueCallback callback       ^~../node_modules/nan/nan.h:485:18: error: expected primary-expression before ‘gc_type_filter’     , v8::GCType gc_type_filter = v8::kGCTypeAll) {                  ^~~~~~~~~~~~~~../node_modules/nan/nan.h:490:20: error: variable or field ‘NanRemoveGCPrologueCallback’ declared void       v8::Isolate::GCPrologueCallback callback) {                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:490:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCPrologueCallback callback) {       ^~
                                          ../node_modules/nan/nan.h:569:15: error: ‘WeakCallbackData’ in namespace ‘v8’ does not name a template type     const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {               ^~~~~~~~~~~~~~~~../node_modules/nan/nan.h:569:31: error: expected ‘,’ or ‘...’ before ‘<’ token     const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {                               ^../node_modules/nan/nan.h: In function ‘void _NanWeakCallbackDispatcher(int)’:../node_modules/nan/nan.h:570:42: error: ‘data’ was not declared in this scope       _NanWeakCallbackInfo<T, P> *info = data.GetParameter();                                          ^~~~
                                          ../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared     , node::smalloc::FreeCallback callback             ^~~~~~~../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’     , node::smalloc::FreeCallback callback                                   ^~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(char*, size_t, int)’:../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                  ^~~~~~~~../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                            ^~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(const char*, uint32_t)’:../node_modules/nan/nan.h:672:67: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);        ^In file included from ../src/validation.cc:10:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_buffer.h:68:40: note:   initializing argument 2 of ‘v8::MaybeLocal<v8::Object> node::Buffer::New(v8::Isolate*, char*, size_t)’ NODE_EXTERN v8::MaybeLocal<v8::Object> New(v8::Isolate* isolate,                                        ^~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h:672:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((char*)data), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(uint32_t)’:../node_modules/nan/nan.h:676:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanBufferUse(char*, uint32_t)’:../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’     return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);            ^~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan.h:710:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’     return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>)’:../node_modules/nan/nan.h:717:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’     return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::UnboundScript>)’:../node_modules/nan/nan.h:723:48: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->BindToCurrentContext()->Run();                                                ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::Script>)’:../node_modules/nan/nan.h:729:24: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->Run();                        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::Function>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:738:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, func, argc, argv));                                                            ^In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:177:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
                                          In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::String>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:747:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, symbol, argc, argv));                                                              ^In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:170:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, const char*, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:756:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, method, argc, argv));                                                              ^In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:163:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
                                          In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In member function ‘v8::Handle<v8::Value> NanCallback::Call_(v8::Isolate*, v8::Handle<v8::Object>, int, v8::Handle<v8::Value>*) const’:../node_modules/nan/nan.h:1569:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]     ));     ^../node_modules/nan/nan.h:398:59: note: in definition of macro ‘NanEscapeScope’ # define NanEscapeScope(val) scope.Escape(_NanEnsureLocal(val))                                                           ^~~In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:177:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
                                          In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘void* _NanRawString(v8::Handle<v8::Value>, Nan::Encoding, size_t*, void*, size_t, int)’:../node_modules/nan/nan.h:2164:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h:2198:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In constructor ‘NanTap::NanTap(v8::Handle<v8::Value>)’:../node_modules/nan/nan.h:2292:41: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     NanAssignPersistent(t_, t->ToObject());                                         ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/validation.cc: In static member function ‘static void Validation::Initialize(v8::Handle<v8::Object>)’:../src/validation.cc:112:62: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [12], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "isValidUTF8", Validation::IsValidUTF8);                                                              ^In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,             ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,             ^~~~~~~~~~~~~~~../src/validation.cc: In static member function ‘static void Validation::IsValidUTF8(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/validation.cc:132:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> buffer_obj = args[0]->ToObject();                                                  ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
                                          validation.target.mk:105: die Regel für Ziel „Release/obj.target/validation/src/validation.o“ scheitertemake: Verzeichnis „/opt/iobroker/node_modules/utf-8-validate/build“ wird verlassenmake: *** [Release/obj.target/validation/src/validation.o] Fehler 1gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:193:23)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp
                                          ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.4.59+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validategyp ERR! node -v v10.17.0gyp ERR! node-gyp -v v5.0.3gyp ERR! not ok
                                          > iobroker.xbox@0.5.12 install /opt/iobroker/node_modules/iobroker.xbox> npip install
                                          No python_modules directory; installing pip locally if needed.
                                          Successfully completed pip check.
                                          Collecting xbox-smartglass-rest>=0.9.8
                                            Using cached https://files.pythonhosted.org/packages/4d/4f/f035df8a2ec5742b9e772071e006ea21aae3fc3bd0963753cfc1045d6fda/xbox_smartglass_rest-0.9.8-py2.py3-none-any.whl
                                          Collecting xbox-smartglass-stump>=0.9.5
                                            Using cached https://files.pythonhosted.org/packages/34/f0/a75667f67ce6251b96a6989b8169eb9f2e25407ce2b0888e544b8caa98fe/xbox_smartglass_stump-0.9.5-py2.py3-none-any.whl
                                          Collecting xbox-smartglass-core>=1.0.12
                                            Using cached https://files.pythonhosted.org/packages/13/c8/2ffce1ddabe5b73422c7c46e808e4b02dbbc9362d2ecd2aee2a65e6e30a5/xbox_smartglass_core-1.0.12-py2.py3-none-any.whl
                                          Collecting xbox-webapi>=1.1.7
                                            Using cached https://files.pythonhosted.org/packages/2d/bf/aaf24cc78184393c5c2472e822c0e145b793e346a8085bee02e89a3428ba/xbox_webapi-1.1.7-py2.py3-none-any.whl
                                          Collecting Flask
                                            Using cached https://files.pythonhosted.org/packages/9b/93/628509b8d5dc749656a9641f4caf13540e2cdec85276964ff8f43bbb1d3b/Flask-1.1.1-py2.py3-none-any.whl
                                          Collecting marshmallow-objects
                                            Downloading https://files.pythonhosted.org/packages/8e/51/65733d6411bc2623922df2e0ac86c2620374620ddd62e108bb454e3412e2/marshmallow_objects-2.0.1-py2.py3-none-any.whl
                                          Processing /home/iobroker/.cache/pip/wheels/13/cd/02/acabe4bfa9899d53c3e3b13675610d2e2dcb9ae110359d4f61/construct-2.9.41-cp35-none-any.whl
                                          Collecting aenum==2.1.2; python_version <= "3.5"
                                            Using cached https://files.pythonhosted.org/packages/0d/46/5b6a6c13fee40f9dfaba84de1394bfe082c0c7d95952ba0ffbd56ce3a3f7/aenum-2.1.2-py3-none-any.whl
                                          Collecting cryptography==2.3.1
                                            Using cached https://files.pythonhosted.org/packages/59/32/92cade62c645756a83598edf56289e9b19aae5370642a7ce690cd06bc72f/cryptography-2.3.1-cp34-abi3-manylinux1_x86_64.whl
                                          Processing /home/iobroker/.cache/pip/wheels/0a/5f/3c/e0ffceb6554711f12a7101384f29ec13b85136dfcf1f692b8f/dpkt-1.9.1-cp35-none-any.whl
                                          Collecting appdirs==1.4.3
                                            Using cached https://files.pythonhosted.org/packages/56/eb/810e700ed1349edde4cbdc1b2a21e28cdf115f9faf263f6bbf8447c1abf3/appdirs-1.4.3-py2.py3-none-any.whl
                                          Processing /home/iobroker/.cache/pip/wheels/34/06/50/24011714e101b5ad8518c69175d117a257413e3c15a92983f0/urwid-2.0.1-cp35-none-any.whl
                                          Collecting gevent==1.3.7
                                            Using cached https://files.pythonhosted.org/packages/87/c4/9afb40b4a8b9186787d477aa6ebcfa17ead40ecbf83d5a1ed53dadd4f6ef/gevent-1.3.7-cp35-cp35m-manylinux1_x86_64.whl
                                          Collecting requests
                                            Using cached https://files.pythonhosted.org/packages/51/bd/23c926cd341ea6b7dd0b2a00aba99ae0f828be89d72b2190f27c11d4b7fb/requests-2.22.0-py2.py3-none-any.whl
                                          Processing /home/iobroker/.cache/pip/wheels/c5/d2/ab/a54fb5ea53ac3badba098160e8452fa126a51febda80440ded/demjson-2.2.4-cp35-none-any.whl
                                          Collecting click>=5.1
                                            Using cached https://files.pythonhosted.org/packages/fa/37/45185cb5abbc30d7257104c434fe0b07e5a195a6847506c074527aa599ec/Click-7.0-py2.py3-none-any.whl
                                          Collecting Werkzeug>=0.15
                                            Using cached https://files.pythonhosted.org/packages/ce/42/3aeda98f96e85fd26180534d36570e4d18108d62ae36f87694b476b83d6f/Werkzeug-0.16.0-py2.py3-none-any.whl
                                          Collecting itsdangerous>=0.24
                                            Using cached https://files.pythonhosted.org/packages/76/ae/44b03b253d6fade317f32c24d100b3b35c2239807046a4c953c7b89fa49e/itsdangerous-1.1.0-py2.py3-none-any.whl
                                          Collecting Jinja2>=2.10.1
                                            Using cached https://files.pythonhosted.org/packages/65/e0/eb35e762802015cab1ccee04e8a277b03f1d8e53da3ec3106882ec42558b/Jinja2-2.10.3-py2.py3-none-any.whl
                                          Collecting marshmallow>=3.0.0
                                            Using cached https://files.pythonhosted.org/packages/6e/76/01224f14737627166b94eb3bf0e334372c014edca781e39db320ce977755/marshmallow-3.3.0-py2.py3-none-any.whl
                                          Collecting cffi!=1.11.3,>=1.7
                                            Using cached https://files.pythonhosted.org/packages/a8/8d/986e0c4e2aa3b24db56a0affc50d1a379150e3c4da45d51d549dc2697d53/cffi-1.13.2-cp35-cp35m-manylinux1_x86_64.whl
                                          Collecting idna>=2.1
                                            Using cached https://files.pythonhosted.org/packages/14/2c/cd551d81dbe15200be1cf41cd03869a46fe7226e7450af7a6545bfc474c9/idna-2.8-py2.py3-none-any.whl
                                          Collecting six>=1.4.1
                                            Using cached https://files.pythonhosted.org/packages/65/eb/1f97cb97bfc2390a276969c6fae16075da282f5058082d4cb10c6c5c1dba/six-1.14.0-py2.py3-none-any.whl
                                          Collecting asn1crypto>=0.21.0
                                            Using cached https://files.pythonhosted.org/packages/e9/51/1db4a60049fb7390959be586b6eb743098e6cea3f6b2d3ed9e17fec62ba2/asn1crypto-1.3.0-py2.py3-none-any.whl
                                          Collecting greenlet>=0.4.14; platform_python_implementation == "CPython"
                                            Using cached https://files.pythonhosted.org/packages/2e/65/27f35497cc0102a792390d056e793e064da95fc9eae45d75ae0ba49c0a0d/greenlet-0.4.15-cp35-cp35m-manylinux1_x86_64.whl
                                          Collecting certifi>=2017.4.17
                                            Using cached https://files.pythonhosted.org/packages/b9/63/df50cac98ea0d5b006c55a399c3bf1db9da7b5a24de7890bc9cfd5dd9e99/certifi-2019.11.28-py2.py3-none-any.whl
                                          Collecting urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1
                                            Using cached https://files.pythonhosted.org/packages/b4/40/a9837291310ee1ccc242ceb6ebfd9eb21539649f193a7c8c86ba15b98539/urllib3-1.25.7-py2.py3-none-any.whl
                                          Collecting chardet<3.1.0,>=3.0.2
                                            Using cached https://files.pythonhosted.org/packages/bc/a9/01ffebfb562e4274b6487b4bb1ddec7ca55ec7510b22e4c51f14098443b8/chardet-3.0.4-py2.py3-none-any.whl
                                          Collecting MarkupSafe>=0.23
                                            Using cached https://files.pythonhosted.org/packages/6e/57/d40124076756c19ff2269678de7ae25a14ebbb3f6314eb5ce9477f191350/MarkupSafe-1.1.1-cp35-cp35m-manylinux1_x86_64.whl
                                          Processing /home/iobroker/.cache/pip/wheels/f2/9a/90/de94f8556265ddc9d9c8b271b0f63e57b26fb1d67a45564511/pycparser-2.19-py2.py3-none-any.whl
                                          Installing collected packages: construct, aenum, pycparser, cffi, idna, six, asn1crypto, cryptography, dpkt, appdirs, urwid, certifi, urllib3, chardet, requests, demjson, xbox-webapi, greenlet, gevent, xbox-smartglass-core, marshmallow, marshmallow-objects, xbox-smartglass-stump, click, Werkzeug, itsdangerous, MarkupSafe, Jinja2, Flask, xbox-smartglass-rest
                                          Successfully installed Flask-1.1.1 Jinja2-2.10.3 MarkupSafe-1.1.1 Werkzeug-0.16.0 aenum-2.1.2 appdirs-1.4.3 asn1crypto-1.3.0 certifi-2019.11.28 cffi-1.13.2 chardet-3.0.4 click-7.0 construct-2.9.41 cryptography-2.3.1 demjson-2.2.4 dpkt-1.9.1 gevent-1.3.7 greenlet-0.4.15 idna-2.8 itsdangerous-1.1.0 marshmallow-3.3.0 marshmallow-objects-2.0.1 pycparser-2.19 requests-2.22.0 six-1.14.0 urllib3-1.25.7 urwid-2.0.1 xbox-smartglass-core-1.0.12 xbox-smartglass-rest-0.9.8 xbox-smartglass-stump-0.9.5 xbox-webapi-1.1.7
                                          + iobroker.xbox@0.5.12updated 1 package in 72.846s
                                          upload [2] xbox.admin /opt/iobroker/node_modules/iobroker.xbox/admin/xbox.png xbox.png image/png
                                          upload [1] xbox.admin /opt/iobroker/node_modules/iobroker.xbox/admin/words.js words.js application/javascript
                                          upload [0] xbox.admin /opt/iobroker/node_modules/iobroker.xbox/admin/index_m.html index_m.html text/html
                                          Update "system.adapter.xbox.0"
                                          process exited with code 0
                                          Adapter ist grün 😁
                                          xbox.0	2020-01-18 21:21:59.327	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
                                          xbox.0	2020-01-18 21:21:59.317	debug	(5900) [CONNECT] Still connected
                                          xbox.0	2020-01-18 21:21:59.311	debug	(5900) [CONNECT] Check connection
                                          xbox.0	2020-01-18 21:21:59.310	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_status
                                          xbox.0	2020-01-18 21:21:59.303	debug	(5900) [UPDATE] Check console status
                                          xbox.0	2020-01-18 21:21:59.301	debug	(5900) [PING] Xbox online
                                          xbox.0	2020-01-18 21:21:53.320	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
                                          xbox.0	2020-01-18 21:21:53.314	debug	(5900) [CONNECT] Still connected
                                          xbox.0	2020-01-18 21:21:53.312	debug	(5900) [CONNECT] Check connection
                                          xbox.0	2020-01-18 21:21:53.309	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_status
                                          xbox.0	2020-01-18 21:21:53.304	debug	(5900) [UPDATE] Check console status
                                          xbox.0	2020-01-18 21:21:53.301	debug	(5900) [PING] Xbox online
                                          xbox.0	2020-01-18 21:21:52.035	debug	(5900) system.adapter.admin.0: logging true
                                          xbox.0	2020-01-18 21:21:47.317	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
                                          xbox.0	2020-01-18 21:21:47.311	debug	(5900) [CONNECT] Still connected
                                          xbox.0	2020-01-18 21:21:47.309	debug	(5900) [CONNECT] Check connection
                                          xbox.0	2020-01-18 21:21:47.308	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_statu
                                          xbox.0	2020-01-18 21:21:47.303	debug	(5900) [UPDATE] Check console status
                                          xbox.0	2020-01-18 21:21:47.301	debug	(5900) [PING] Xbox online
                                          xbox.0	2020-01-18 21:21:41.325	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
                                          xbox.0	2020-01-18 21:21:41.319	debug	(5900) [CONNECT] Still connected
                                          xbox.0	2020-01-18 21:21:41.315	debug	(5900) [CONNECT] Check connection
                                          xbox.0	2020-01-18 21:21:41.315	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_statu
                                          xbox.0	2020-01-18 21:21:41.307	debug	(5900) [UPDATE] Check console status
                                          xbox.0	2020-01-18 21:21:41.303	debug	(5900) [PING] Xbox online
                                          xbox.0	2020-01-18 21:21:35.324	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
                                          xbox.0	2020-01-18 21:21:35.316	debug	(5900) [CONNECT] Still connected
                                          xbox.0	2020-01-18 21:21:35.313	debug	(5900) [CONNECT] Check connection
                                          xbox.0	2020-01-18 21:21:35.312	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_statu
                                          xbox.0	2020-01-18 21:21:35.304	debug	(5900) [UPDATE] Check console status
                                          xbox.0	2020-01-18 21:21:35.303	debug	(5900) [PING] Xbox online
                                          xbox.0	2020-01-18 21:21:29.331	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
                                          xbox.0	2020-01-18 21:21:29.321	debug	(5900) [CONNECT] Still connected
                                          xbox.0	2020-01-18 21:21:29.317	debug	(5900) [CONNECT] Check connection
                                          xbox.0	2020-01-18 21:21:29.316	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_statu
                                          xbox.0	2020-01-18 21:21:29.305	debug	(5900) [UPDATE] Check console status
                                          xbox.0	2020-01-18 21:21:29.301	debug	(5900) [PING] Xbox online
                                          xbox.0	2020-01-18 21:21:23.356	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
                                          xbox.0	2020-01-18 21:21:23.351	debug	(5900) [CONNECT] Still connected
                                          xbox.0	2020-01-18 21:21:23.311	debug	(5900) [CONNECT] Check connection
                                          xbox.0	2020-01-18 21:21:23.310	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_statu
                                          xbox.0	2020-01-18 21:21:23.303	debug	(5900) [UPDATE] Check console status
                                          xbox.0	2020-01-18 21:21:23.302	debug	(5900) [PING] Xbox online
                                          xbox.0	2020-01-18 21:21:17.318	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
                                          xbox.0	2020-01-18 21:21:17.308	debug	(5900) [CONNECT] Still connected
                                          xbox.0	2020-01-18 21:21:17.307	debug	(5900) [CONNECT] Check connection
                                          xbox.0	2020-01-18 21:21:17.306	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_statu
                                          xbox.0	2020-01-18 21:21:17.301	debug	(5900) [UPDATE] Check console status
                                          xbox.0	2020-01-18 21:21:17.300	debug	(5900) [PING] Xbox online
                                          xbox.0	2020-01-18 21:21:11.355	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
                                          xbox.0	2020-01-18 21:21:11.348	debug	(5900) [CONNECT] Still connected
                                          xbox.0	2020-01-18 21:21:11.308	debug	(5900) [CONNECT] Check connection
                                          xbox.0	2020-01-18 21:21:11.307	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_statu
                                          xbox.0	2020-01-18 21:21:11.300	debug	(5900) [UPDATE] Check console status
                                          xbox.0	2020-01-18 21:21:11.298	debug	(5900) [PING] Xbox online
                                          xbox.0	2020-01-18 21:21:05.314	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
                                          xbox.0	2020-01-18 21:21:05.308	debug	(5900) [CONNECT] Still connected
                                          xbox.0	2020-01-18 21:21:05.306	debug	(5900) [CONNECT] Check connection
                                          xbox.0	2020-01-18 21:21:05.306	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_statu
                                          xbox.0	2020-01-18 21:21:05.300	debug	(5900) [UPDATE] Check console status
                                          xbox.0	2020-01-18 21:21:05.298	debug	(5900) [PING] Xbox online
                                          xbox.0	2020-01-18 21:21:02.349	debug	(5900) system.adapter.admin.0: logging false
                                          xbox.0	2020-01-18 21:20:59.323	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
                                          xbox.0	2020-01-18 21:20:59.317	debug	(5900) [CONNECT] Still connected
                                          xbox.0	2020-01-18 21:20:59.312	debug	(5900) [CONNECT] Check connection
                                          xbox.0	2020-01-18 21:20:59.312	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_statu
                                          xbox.0	2020-01-18 21:20:59.304	debug	(5900) [UPDATE] Check console status
                                          xbox.0	2020-01-18 21:20:59.298	debug	(5900) [PING] Xbox online
                                          xbox.0	2020-01-18 21:20:54.449	debug	(5900) [STATUS] Set {"Home":"2cb9057f","Idlescreen":"32bd6e88"}
                                          xbox.0	2020-01-18 21:20:53.312	debug	(5900) [CONNECT] Still connected
                                          xbox.0	2020-01-18 21:20:53.310	debug	(5900) [CONNECT] Check connection
                                          xbox.0	2020-01-18 21:20:53.310	debug	(5900) [UPDATE] <=== {"device":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Connected","console_users_allowed":false,"device_statu
                                          xbox.0	2020-01-18 21:20:53.302	debug	(5900) [UPDATE] Check console status
                                          xbox.0	2020-01-18 21:20:53.298	debug	(5900) [PING] Xbox online
                                          xbox.0	2020-01-18 21:20:50.423	info	(5900) [CONNECT] <=== Successfully connected to FD001101536384EE (10.0.1.83)
                                          xbox.0	2020-01-18 21:20:49.834	debug	(5900) [CONNECT] Check connection
                                          xbox.0	2020-01-18 21:20:49.833	debug	(5900) [DISCOVER] <=== {"FD001101536384EE":{"address":"10.0.1.83","anonymous_connection_allowed":true,"authenticated_users_allowed":true,"connection_state":"Disconnected","console_users_allowed":fals
                                          xbox.0	2020-01-18 21:20:47.309	debug	(5900) [DISCOVER] Searching for consoles
                                          xbox.0	2020-01-18 21:20:47.305	debug	(5900) [PING] Xbox online
                                          xbox.0	2020-01-18 21:20:44.423	info	(5900) [LOGIN] <=== Successfully logged in as: Negalein2901
                                          xbox.0	2020-01-18 21:20:41.314	debug	(5900) [LOGOUT] <=== Successfully logged out
                                          xbox.0	2020-01-18 21:20:39.588	debug	(5900) system.adapter.admin.0: logging true
                                          xbox.0	2020-01-18 21:20:34.726	info	(5900) [START] Starting REST server
                                          xbox.0	2020-01-18 21:20:34.726	debug	(5900) [START] IP address is 10.0.1.83
                                          xbox.0	2020-01-18 21:20:34.699	info	(5900) starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.17.0
                                          xbox.0	2020-01-18 21:20:32.119	debug	(5900) States connected to redis: 0.0.0.0:9000
                                          xbox.0	2020-01-18 21:20:32.067	debug	(5900) statesDB connected
                                          xbox.0	2020-01-18 21:20:32.065	debug	(5900) States create PubSub Client
                                          xbox.0	2020-01-18 21:20:32.056	debug	(5900) Objects connected to redis: 0.0.0.0:9001
                                          xbox.0	2020-01-18 21:20:32.053	debug	(5900) Redis States: Use Redis connection: 0.0.0.0:9000
                                          xbox.0	2020-01-18 21:20:32.051	debug	(5900) objectDB connected
                                          xbox.0	2020-01-18 21:20:32.040	debug	(5900) Objects client initialize lua scripts
                                          xbox.0	2020-01-18 21:20:32.039	debug	(5900) Objects create PubSub Client
                                          xbox.0	2020-01-18 21:20:32.028	debug	(5900) Objects client ready ... initialize now
                                          xbox.0	2020-01-18 21:20:31.994	debug	(5900) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                          DANKE
                                          • foxriver76
                                            foxriver76 Developer @Negalein last edited by
                                            @Negalein perfekt. Gerne.
                                            xbox
                                            7246
