    4. JavaScript
    5. Strom Geräte als HTML Tabelle - Vis - Iqontrol
      liv-in-sky @Guest last edited by
      @HeinrichB wenn ich es richtig interpretiere hättest du keinen "power" datenpunkt ?
        hm-rpc.0.NEQ0116043.json hm-rpc.0.KEQ0966548.json
          sigi234 Forum Testing Most Active @liv-in-sky last edited by
          @liv-in-sky sagte in Strom Geräte als HTML Tabelle - Vis - Iqontrol:
          @sigi234
          probier das mal - stimmen da die werte ?
          javascript.0	2020-01-18 19:03:24.869	error	(392) at Script.runInContext (vm.js:133:20)
          javascript.0	2020-01-18 19:03:24.869	error	(392) at script.js.Listen.Energy_Devices1:358:2
          javascript.0	2020-01-18 19:03:24.869	error	(392) at writeHTML (script.js.Listen.Energy_Devices1:296:26)
          javascript.0	2020-01-18 19:03:24.869	error	(392) at Object.result.each (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:846:29)
          javascript.0	2020-01-18 19:03:24.869	error	(392) at script.js.Listen.Energy_Devices1:308:61
          javascript.0	2020-01-18 19:03:24.869	error	(392) TypeError: getState(...).val.substring is not a function
          javascript.0	2020-01-18 19:03:24.869	error	(392) ^
          javascript.0	2020-01-18 19:03:24.869	error	(392) val4=getState(id.replace("totalNow","power")).val.substring(0,4)+ " W" ;
          javascript.0	2020-01-18 19:03:24.869	error	(392) script.js.Listen.Energy_Devices1: script.js.Listen.Energy_Devices1:308
          javascript.0	2020-01-18 19:03:24.863	info	(392) Start javascript script.js.Listen.Energy_Devices1
          javascript.0	2020-01-18 19:03:24.113	info	(392) Stop script script.js.Listen.Energy_Devices1
          javascript.0	2020-01-18 19:03:01.810	error	(392) at Script.runInContext (vm.js:133:20)
          javascript.0	2020-01-18 19:03:01.810	error	(392) at script.js.Listen.Energy_Devices1:358:2
          javascript.0	2020-01-18 19:03:01.810	error	(392) at writeHTML (script.js.Listen.Energy_Devices1:296:26)
          javascript.0	2020-01-18 19:03:01.810	error	(392) at Object.result.each (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:846:29)
          javascript.0	2020-01-18 19:03:01.810	error	(392) at script.js.Listen.Energy_Devices1:308:61
          javascript.0	2020-01-18 19:03:01.810	error	(392) TypeError: getState(...).val.substring is not a function
          javascript.0	2020-01-18 19:03:01.810	error	(392) ^
          javascript.0	2020-01-18 19:03:01.810	error	(392) val4=getState(id.replace("totalNow","power")).val.substring(0,4)+ " W" ;
          javascript.0	2020-01-18 19:03:01.810	error	(392) script.js.Listen.Energy_Devices1: script.js.Listen.Energy_Devices1:308
            liv-in-sky @Homoran last edited by
            @Homoran das bedeutet:
            ich muss die folgenden werte nehmen:
              liv-in-sky @sigi234 last edited by
              @sigi234 der selbe fehler wie bei @HeinrichB - da muss ich wohl nochmal
                Homoran Global Moderator Administrators @liv-in-sky last edited by
                @liv-in-sky Denke ja, habe gerade Probleme mit Screenshots bei dual Screen - nimmt nur den Falschen Monitor 😞
                  @Homoran ich werde es mal mit diesen versuchen - die anderen datenpunkte von euch haben die ja auch
                    Homoran Global Moderator Administrators @liv-in-sky last edited by Homoran
                    @liv-in-sky Jetzt hat es geklappt:
                    Messsteckdose:
                    Schaltaktor für Hutschiene
                    Bei meinem HmIP-Aktor ist es Kanal 7:
                    Bild Text
                      liv-in-sky @liv-in-sky last edited by
                      @sigi234 @HeinrichB
                      ich bekome da keinen fehler im script
                      wandelt mal den befehl um in zeile 308 - kommt da immer noch ein fehler
                       val4=getState(id.replace("totalNow","power")).val+ " W"     ;     log (val4)
                        sigi234 Forum Testing Most Active @liv-in-sky last edited by sigi234
                        @sigi234 @HeinrichB
                        19:28:36.382	info	javascript.0 (392) Stop script script.js.Listen.Energy_Devices1
                        19:28:36.388	info	javascript.0 (392) Start javascript script.js.Listen.Energy_Devices1
                        19:28:36.394	info	javascript.0 (392) script.js.Listen.Energy_Devices1: 70.295 W
                        19:28:36.395	error	javascript.0 (392) script.js.Listen.Energy_Devices1: script.js.Listen.Energy_Devices1:310
                        19:28:36.395	error	javascript.0 (392) at script.js.Listen.Energy_Devices1:310:63
                        19:28:36.395	error	javascript.0 (392) at writeHTML (script.js.Listen.Energy_Devices1:296:26)
                        19:28:36.395	error	javascript.0 (392) at script.js.Listen.Energy_Devices1:358:2
                        javascript.0	2020-01-18 19:30:00.032	error	(392) at tryOnTimeout (timers.js:300:5)
                        javascript.0	2020-01-18 19:30:00.032	error	(392) at ontimeout (timers.js:436:11)
                        javascript.0	2020-01-18 19:30:00.032	error	(392) at Timeout._onTimeout (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:501:7)
                        javascript.0	2020-01-18 19:30:00.032	error	(392) at C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:543:11
                        javascript.0	2020-01-18 19:30:00.031	error	(392) at Job.invoke (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:173:10)
                        javascript.0	2020-01-18 19:30:00.031	error	(392) at Job.nodeSchedule.scheduleJob [as job] (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1319:34)
                        javascript.0	2020-01-18 19:30:00.031	error	(392) at Object.<anonymous> (script.js.Listen.Energy_Devices1:355:2)
                        javascript.0	2020-01-18 19:30:00.031	error	(392) at writeHTML (script.js.Listen.Energy_Devices1:296:26)
                        javascript.0	2020-01-18 19:30:00.031	error	(392) at Object.result.each (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:846:29)
                        javascript.0	2020-01-18 19:30:00.031	error	(392) at script.js.Listen.Energy_Devices1:310:63
                        javascript.0	2020-01-18 19:30:00.031	error	(392) Error in callback: TypeError: getState(...).val.substring is not a function
                          liv-in-sky @sigi234 last edited by liv-in-sky
                          @sigi234 oh ich glaube falscher befehl - ich mach noch was anderes fertig und dann kommt update
                            ok - versuch - alles ersetzen, was unter let myschedule steht
                            @sigi234 @HeinrichB - bitte checken ob das jetzt geht
                            homematic user
                            werden die geräte gefunden ?
                            //@liv-in-sky Januar 2020
                            //HIER WIRD PFAD UND FILENAME DEFINIERT
                            const path = "/htmlenergy.html";                   //FIlenamen definieren
                            const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
                            let   braucheEinFile=false;                          // bei true wird ein file geschrieben
                            let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
                            let dpVIS="controll-own.0.TABELLEN.ENERGY"         //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
                            let dpAnzahl="controll-own.0.TABELLEN.AnzahlEnergiemesser";  //WICHTIG datenpunkt erstellen vom typ "number" - bei 0 kein alarm und größer 0 die anzahl der schlechten batterien
                            let htmlColorDeviceUeberschrift="white"
                            let triggerBySonoffPower=true;
                            let mySchedule="  * * * * * ";
                            let kwhPreis=0.29;
                            var pow=true;
                            var tuya=true;
                            var hs100=true; //tplink
                            var homematic=true;
                            var gosundSP1x=true;
                            var externalOhneInfo=false;  //noch nicht integriert
                            var schalter2ch=true;
                            var schalter3ch=true;
                            //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 5
                            var htmlFeld1='Device';       var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
                            var htmlFeld2='Status';        var Feld2lAlign="center";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
                            var htmlFeld3='Amp';         var Feld3lAlign="center";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
                            var htmlFeld4='Volt';        var Feld4lAlign="center";                    // überschrift Tabellen Spalte4 und  Ausrichtung left,right or center
                            var htmlFeld5='Power';        var Feld5lAlign="left";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
                            var htmlFeld6='Schalter';        var Feld6lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
                            var htmlFeld7='';        var Feld7lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
                            var htmlFeld8='';        var Feld8lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
                            var htmlFeld9='';        var Feld9lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
                            var htmlFeld10='';        var Feld10lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
                            //ÜBERSCHRIFT ÜBER TABELLE
                            let   htmlUberschrift=true;                           // mit Überschrift über der tabelle
                            let   htmlSignature=false;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
                            const htmlFeldUeber='Energy Devices';              // Überschrift und Signature
                            const htmlFarbUber="white";                         // Farbe der Überschrift
                            const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
                            const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
                            //MEHRERE TABELLEN NEBENEINANDER
                            let   mehrfachTabelle=1;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
                            const htmlFarbZweiteTabelle="white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
                            const htmlFarbTableColorUber="#BDBDBD";               // Überschrift in der tabelle - der einzelnen Spalten
                            //GANZE TABELLE
                            let abstandZelle="1";
                            let weite="auto";                                     //Weite der Tabelle
                            let zentriert=true;                                   //ganze tabelle zentriert
                            const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
                            const htmlSchriftart="Helvetica";
                            const htmlSchriftgroesse="14px";
                            //FELDER UND RAHMEN
                            let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
                            const htmlFarbFelderschrift="#BDBDBD";                  // SchriftFarbe der Felder
                            const htmlFarbFelderschrift2="#D8D8D8";                 // SchriftFarbe der Felder für jede 2te Tabelle
                            const htmlFarbTableColorGradient1="#424242";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
                            const htmlFarbTableColorGradient2="#424242";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                            const htmlFarbTableBorderColor="gray";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
                            let htmlRahmenLinien="cols";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
                            const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
                            // HIER NICHTS  ÄNDERN
                            let borderHelpBottum;
                            let borderHelpRight;
                            let htmlcenterHelp;
                            let htmlcenterHelp2;
                            if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
                            if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
                            if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
                            if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
                            zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
                            zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
                            const htmlZentriert='<center>'
                            const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                                               "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                                               " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                                              // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                                               " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                                               " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                                               "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                                               " </style></head><body> <div>";
                            //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
                            const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                                                  "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
                            const htmlTabUeber1="<tr style=\"color:"+htmlFarbTableColorUber+"; font-weight: bold\">";
                            const htmlTabUeber3="</tr>";
                            //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 5
                            var htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td><td align="+Feld4lAlign+
                                              ">&ensp;"+htmlFeld4+"&ensp;</td><td  align="+Feld5lAlign+">&ensp;"+htmlFeld5+"&ensp;</td><td  align="+Feld6lAlign+">&ensp;"+htmlFeld6+"&ensp;</td><td  align="+Feld7lAlign+">&ensp;"+htmlFeld7+"&ensp;</td><td  align="+Feld8lAlign+">&ensp;"+htmlFeld8+
                                              "&ensp;</td><td  align="+Feld9lAlign+">&ensp;"+htmlFeld9+"&ensp;</td><td  align="+Feld10lAlign+">&ensp;"+htmlFeld10+"&ensp;</td>";
                            var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+
                                               "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld4+
                                               "&ensp;</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\"&ensp;>"+htmlFeld5+"&ensp;</td><td align="+Feld6lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\"&ensp;>"+htmlFeld6+"&ensp;</td><td align="+Feld7lAlign+
                                               " style=\"color:"+htmlFarbZweiteTabelle+"\"&ensp;>"+htmlFeld7+"&ensp;</td><td align="+Feld8lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\"&ensp;>"+htmlFeld8+"&ensp;</td><td  align="+Feld9lAlign+">&ensp;"+htmlFeld9+"&ensp;</td><td  align="+Feld10lAlign+">&ensp;"+htmlFeld10+"&ensp;</td>";
                            let triggerBySonoffSwitch=false;
                            var anzahl;
                            var AkkuAlarm=[];
                            var htmlOut="";
                            var mix;
                            var counter;
                            var arrTrigger=[];
                            var val1; var val2; var val0; var val3; var val4; var val5; var val6; var val7; var val8; var val9;
                            var htmlTabUeber="";
                            function writeHTML(){
                            anzahl=0;
                            htmlOut="";
                            counter=-1;
                            htmlTabUeber="";
                            switch (mehrfachTabelle) {
                               case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
                               case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                               case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2+htmlTabUeber2+htmlTabUeber3; break;
                               case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                            if (!UeberschriftSpalten) {htmlTabUeber=""}
                            //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
                            //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2,val3,val4!!!------------------------------------------------------------
                            if (pow){
                                         // UNTERTEILUNG - ÜBERSCHRIFT IN TABELLE
                                  tabelleAusbessern();
                                  counter=0;
                                  val0=""; val1=""; val2="";val3="";val4="";val5="";val6="";val7="";val8="";val9="";
                                  tabelleBind(); //HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT  - diese function muss als letztes in der eigenen schleife aufgerufen werden
                                  counter=0;
                                  val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>Pow (R2)</b>"; val1=""; val2="";val3="";val4="";
                                  val5="<font color=\""+htmlColorDeviceUeberschrift+"\">";
                                  val6="<font color=\""+htmlColorDeviceUeberschrift+"\">kWh Heute";
                                  val7="<font color=\""+htmlColorDeviceUeberschrift+"\">kWh Gesamt";
                                  val8="<font color=\""+htmlColorDeviceUeberschrift+"\"><i>Preis Heute<\/i>";
                                  val9="<font color=\""+htmlColorDeviceUeberschrift+"\"><i>Preis Gesamt<\/i>";
                                  counter=-1
                            //sonoff.0.SonoffPow1.INFO.Module
                             $('sonoff.*.*.INFO.Module').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                  if (getState(id).val=="Sonoff Pow" || getState(id).val=="Sonoff Pow R2") {
                                     // log (id)
                                     anzahl++;
                                    var ida = id.split('.');
                                      counter++;
                                        //log("dad   "+getState(id.replace("Info.Module","alive")).val + " ----" +id.replace("Info.Module","alive"))
                                      val1=getState(id.replace("INFO.Module","alive")).val;                   //sonoff.0.SonoffPow1.alive          sonoff.0.SonoffPow1.INFO.Module
                                      val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]).common.name ;
                                      val4=getState(id.replace("INFO.Module","ENERGY_Power")).val.toString()+ " W"                       //sonoff.0.SonoffPow2.ENERGY_Power
                                      val2=getState(id.replace("INFO.Module","ENERGY_Current")).val.toFixed(2)+ " A";   //sonoff.0.SonoffPow1.Wifi_RSSIsonoff.0.SonoffPow1.POWER
                                      val3=getState(id.replace("INFO.Module","ENERGY_Voltage")).val.toString()+" V";
                                      let val7_1=getState(id.replace("INFO.Module","POWER")).val;
                                      val7_1 ? val5=(" <font color=\"lightgreen\"> ")+"ON" : val5=(" <font color=\"red\"> ")+"OFF";
                                      val6=getState(id.replace("INFO.Module","ENERGY_Today")).val.toFixed(2)+ " kWh";
                                      val7=getState(id.replace("INFO.Module","ENERGY_Total")).val.toFixed(2)+ " kWh";
                                      val8=(getState(id.replace("INFO.Module","ENERGY_Today")).val*kwhPreis).toFixed(1)+" €";
                                      val9=(getState(id.replace("INFO.Module","ENERGY_Total")).val*kwhPreis).toFixed(1)+" €";
                                      if (!getState(id.replace("INFO.Module","alive")).val) {
                                          val1="❌";
                                          val4=(" <font color=\"red\"> ")+val1;
                                          val2=(" <font color=\"red\"> ")+val2;
                                          val3=(" <font color=\"red\"> ")+" 0 %";
                                          val5=(" <font color=\"red\"> ")+" --- ";
                                          val6=(" <font color=\"red\"> ")+" --- ";
                                          val7=(" <font color=\"red\"> ")+" --- ";
                                          val0=(" <font color=\"red\"> ")+val0}
                                      else{
                                          val1="✅";
                                         // val1=(" <font color=\"lightgreen\"> ")+val1
                                         // val2=(" <font color=\"green\"> ")+val2
                                         // val3=(" <font color=\"green\"> ")+val3
                                         // val0=(" <font color=\"green\"> ")+val0
                              } }); //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
                            } //ende fritzdect
                             if (gosundSP1x){
                                  counter=0;
                                  val0=val0=""; val1=""; val2="";val3="";val4="";val5="";val6="";val7="";
                                  counter=0;
                                 val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>Gosund</b>"; val1=""; val2="";val3="";val4="";
                                  counter=-1
                                  if (getState(id).val.includes("Gosund SP1")) {
                                     // log (id)
                                     anzahl++;
                                       counter++;
                                          val1="❌";
                                      else{
                                          val1="✅";
                            } //ende fritzdect
                             if (hs100){
                                  counter=0;
                                  counter=0;
                                  val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>HS100</b>"; val1=""; val2="";val3="";val4="";
                                  val6="<font color=\""+htmlColorDeviceUeberschrift+"\">kWh Now";
                                  val7="<font color=\""+htmlColorDeviceUeberschrift+"\">kWh Monat";
                                  val8="<font color=\""+htmlColorDeviceUeberschrift+"\"><i>Preis Now<\/i>";
                                  val9="<font color=\""+htmlColorDeviceUeberschrift+"\"><i>Preis Monat<\/i>";
                                  counter=-1
                             $('hs100.0.*.totalNow').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                     // log (id)
                                     anzahl++;
                                      counter++;
                                     var valVersion=getState(id.replace("totalNow","hw_ver")).val;
                                      val1=getState(id.replace("totalNow","state")).val;
                                      val0=getObject(id).common.name ;
                                      val4=getState(id.replace("totalNow","power")).val.substr(0,4)+ " W"     ;    // log (val4)       //.substring(0,4)
                                      if(valVersion=="1.0")  {val2=getState(id.replace("totalNow","current")).val.substr(0,5)+ " A";} else {val2=getState(id.replace("totalNow","current")).val+ " mA";}
                                      val3=getState(id.replace("totalNow","voltage")).val.substring(0,3)+" V";
                                      val5=" - "; // let val7_1=getState(id.replace("INFO.Module","POWER")).val;
                                      //val7_1 ? val5=(" <font color=\"lightgreen\"> ")+"ON" : val5=(" <font color=\"red\"> ")+"OFF";
                                      val6=getState(id).val.substring(0,5)+ " kWh";
                                      val7=getState(id.replace("totalNow","totalMonthNow")).val.substr(0,5)+ " kWh";
                                      val8=(parseFloat(getState(id).val)*kwhPreis).toFixed(2)+" €";
                                      val9=(parseFloat(getState(id.replace("totalNow","totalMonthNow")).val)*kwhPreis).toFixed(2)+" €";
                                      if (!val1) {
                                          val1="❌";
                                      else{
                                          val1="✅";
                            } //ende fritzdect
                             if (homematic){
                                  counter=0;
                                  counter=0;
                                  val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>Homematic</b>"; val1=""; val2="";val3="";val4="";
                                  counter=-1
                             $('hm-rpc.*.*.*.ENERGY_COUNTER').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                     // log (id)
                                     anzahl++;
                                      counter++;
                                  //   var valVersion=getState(id.replace("totalNow","hw_ver")).val;
                                      val1=" - "; //getState(id.replace("ENERGY_COUNTER","STATE")).val;
                                      val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]).common.name ;  //val0=getObject(id).common.name ;
                                      val4=getState(id.replace("ENERGY_COUNTER","POWER")).val+ " W"     ;     //log (val4)       //.substring(0,4)
                                      val2=getState(id.replace("ENERGY_COUNTER","CURRENT")).val.toFixed(0)+ " mA";
                                      val3=getState(id.replace("ENERGY_COUNTER","VOLTAGE")).val.toFixed(0)+" V";
                                      val6=" - "; // getState(id).val.substring(0,5)+ " kWh";
                                      val7=" - "; // getState(id.replace("totalNow","totalMonthNow")).val.substring(0,5)+ " kWh";
                                      val8=" - "; // (parseFloat(getState(id).val)*kwhPreis).toFixed(2)+" €";
                                      val9=" - "; // (parseFloat(getState(id.replace("totalNow","totalMonthNow")).val)*kwhPreis).toFixed(2)+" €";
                                      if (!val1) {
                                          val1="❌";
                                      else{
                                          val1="✅";
                            } //ende fritzdect
                            //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                                  tabelleFinish(); // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
                                // log(anzahl.toString());
                                      setState(dpAnzahl,anzahl);
                            } // function ende
                            //MAIN:
                            schedule(mySchedule,  function () {
                             writeHTML();
                             if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                             writeHTML();
                               				 function tabelleBind(){
                                 //HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT - hat man oben 5 Felder definiert, braucht man hier 5 Werte
                                     case 1:                    htmlOut=htmlOut+"<tr><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td></tr>"; break;
                                    case 2:  if(counter%2==0)  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td>"; }
                                                          else {htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td></tr>";} break;
                                    case 3: if(counter%3==0 )  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td>"; }
                                                          else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td>";}
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td></tr>";}
        } break;
                                    case 4: if(counter%4==0)  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td>"; }
                                                              else {if(counter%2==1 )  { htmlOut = htmlOut+"<td  align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td>";}
        else    {if(counter%2==1 && counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td></tr>";}
        else    {htmlOut = htmlOut = htmlOut+"<td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td>&ensp;"+val1+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td>";}}
        } break;
                                 } //switch ende
                            function tabelleAusbessern() {
                                     case 1:    break;
                                     case 2:    mix=Math.abs(((counter+1)%2)-mehrfachTabelle);
                                                if(mix==1)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                                break;
                                     case 3:    mix =Math.abs(((counter+1)%3)-mehrfachTabelle);
                                                if(mix==2)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                                break;
                                     case 4:    mix=Math.abs(((counter+1)%4)-mehrfachTabelle);
                                                if(mix==3)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                                break; }
                            function tabelleFinish() {
                                  // tabelle fertigstellen
                                     case 1:    break;
                                                break;
                                                break;
                                                break; }
                                                var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
                                   var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                                    if (!htmlSignature) htmlUnter="";
                                      //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                                       var htmlOutVIS="";
                                     //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                                        if (htmlUberschrift)
                                            { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter ;
                                          } else {
                                           zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter;
                            // log("bin raus aus tabelleBind");
                                       if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
                             var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                             var htmlEnd="</table>"+htmlUnter+"</div></body>";
                             //mit oder ohne überschrift - zentriert oder links
                            htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
                             //log(htmlOut);
                            sigi234 ? Glasfaser Homoran 4 Replies Last reply Reply Quote 0
                              @liv-in-sky
                              javascript.0	2020-01-18 19:43:00.030	error	(392) at tryOnTimeout (timers.js:300:5)
                              javascript.0	2020-01-18 19:43:00.030	error	(392) at ontimeout (timers.js:436:11)
                              javascript.0	2020-01-18 19:43:00.030	error	(392) at Timeout._onTimeout (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:501:7)
                              javascript.0	2020-01-18 19:43:00.029	error	(392) at C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:543:11
                              javascript.0	2020-01-18 19:43:00.029	error	(392) at Job.invoke (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:173:10)
                              javascript.0	2020-01-18 19:43:00.029	error	(392) at Job.nodeSchedule.scheduleJob [as job] (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1319:34)
                              javascript.0	2020-01-18 19:43:00.029	error	(392) at Object.<anonymous> (script.js.Listen.Energy_Devices1:424:2)
                              javascript.0	2020-01-18 19:43:00.029	error	(392) at writeHTML (script.js.Listen.Energy_Devices1:297:26)
                              javascript.0	2020-01-18 19:43:00.029	error	(392) at Object.result.each (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:846:29)
                              javascript.0	2020-01-18 19:43:00.029	error	(392) at script.js.Listen.Energy_Devices1:309:61
                              javascript.0	2020-01-18 19:43:00.028	error	(392) Error in callback: TypeError: getState(...).val.substr is not a function
                              javascript.0	2020-01-18 19:42:53.808	error	(392) at Script.runInContext (vm.js:133:20)
                              javascript.0	2020-01-18 19:42:53.808	error	(392) at script.js.Listen.Energy_Devices1:427:2
                              javascript.0	2020-01-18 19:42:53.808	error	(392) at writeHTML (script.js.Listen.Energy_Devices1:297:26)
                              javascript.0	2020-01-18 19:42:53.808	error	(392) at Object.result.each (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:846:29)
                              javascript.0	2020-01-18 19:42:53.808	error	(392) at script.js.Listen.Energy_Devices1:309:61
                              javascript.0	2020-01-18 19:42:53.808	error	(392) TypeError: getState(...).val.substr is not a function
                              javascript.0	2020-01-18 19:42:53.808	error	(392) ^
                              javascript.0	2020-01-18 19:42:53.808	error	(392) val4=getState(id.replace("totalNow","power")).val.substr(0,4)+ " W" ; // log (val4) //.substring(0,4)
                              javascript.0	2020-01-18 19:42:53.808	error	(392) script.js.Listen.Energy_Devices1: script.js.Listen.Energy_Devices1:309
                                A Former User @liv-in-sky last edited by
                                @liv-in-sky
                                Hier mein Log
                                19:42:17.908	info	javascript.0 (8084) Stop script script.js.Stromgeräte_Tabelle
                                19:42:19.869	info	javascript.0 (8084) Start javascript script.js.Stromgeräte_Tabelle
                                19:42:19.902	error	javascript.0 (8084) script.js.Stromgeräte_Tabelle: script.js.Stromgeräte_Tabelle:309
                                19:42:19.903	error	javascript.0 (8084) at script.js.Stromgeräte_Tabelle:309:61
                                19:42:19.903	error	javascript.0 (8084) at writeHTML (script.js.Stromgeräte_Tabelle:297:26)
                                19:42:19.904	error	javascript.0 (8084) at script.js.Stromgeräte_Tabelle:427:2
                                19:42:25.451	info	javascript.0 (8084) Stop script script.js.Stromgeräte_Tabelle
                                Hier meine angelegten DP zur Zeit und zwei Screens von zwei Geräten mit Verbrauch (HS110 und Sonoff POWR2)
                                Bildschirmfoto 2020-01-18 um 19.40.36.JPG Bildschirmfoto 2020-01-18 um 19.41.04.JPG
                                  liv-in-sky @Guest last edited by liv-in-sky
                                  @HeinrichB @sigi234
                                  ich checke es nicht - ist der selbe fehler bei euch beiden - bei mir geht es - irgendwie sind unsere datenpunkte verschieden , denn den befehl gibt es aber anscheinend ist er bei euch nicht auf den datenpunkt anwendbar
                                  der datenpunkt hs100.0.*.power ist doch eine dp mit typ zeichenkette (string) - genauso wie ..voltage und ...current
                                    Ja
                                    Stimmt das?
                                    • Glasfaser
                                      Glasfaser @liv-in-sky last edited by
                                      homematic user
                                      Jipp ...HMIP
                                        @sigi234 bitte teste mal - danke für deine geduld
                                        let kwhPreis=0.29;
                                        var pow=true;
                                        var tuya=true;
                                        var homematic=true;
                                        //GANZE TABELLE
                                        //FELDER UND RAHMEN
                                        let htmlcenterHelp;
                                        var anzahl;
                                        var AkkuAlarm=[];
                                        var htmlOut="";
                                        var mix;
                                        var counter;
                                        var arrTrigger=[];
                                        anzahl=0;
                                        htmlOut="";
                                        counter=-1;
                                        htmlTabUeber="";
                                        if (pow){
                                              counter=0;
                                              counter=0;
                                              counter=-1
                                                 // log (id)
                                                 anzahl++;
                                                  counter++;
                                                      val1="❌";
                                                  else{
                                                      val1="✅";
                                        } //ende fritzdect
                                         if (gosundSP1x){
                                              counter=0;
                                              counter=0;
                                              counter=-1
                                                 // log (id)
                                                 anzahl++;
                                                   counter++;
                                                      val1="❌";
                                                  else{
                                                      val1="✅";
                                        } //ende fritzdect
                                         if (hs100){
                                              counter=0;
                                              counter=0;
                                              counter=-1
                                         $('hs100.*.*.totalNow').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                                 // log (id)
                                                 anzahl++;
                                                  counter++;
                                                  val1=getState(id.replace("totalNow","state")).val;          //    hs100.0.192_168_178_43.power
                                                  val4=(getState(id.replace("totalNow","power")).val).substr(0,4) + " W"     ;    // log (val4)       //.substring(0,4)
                                                  if(valVersion=="1.0")  {val2=(getState(id.replace("totalNow","current")).val).substr(0,5)+ " A";} else {val2=getState(id.replace("totalNow","current")).val+ " mA";}
                                                  val3=(getState(id.replace("totalNow","voltage")).val).substring(0,3)+" V";
                                                  val7=(getState(id.replace("totalNow","totalMonthNow")).val).substr(0,5)+ " kWh";
                                                  if (!val1) {
                                                      val1="❌";
                                                  else{
                                                      val1="✅";
                                        } //ende fritzdect
                                         if (homematic){
                                              counter=0;
                                              counter=0;
                                              counter=-1
                                                 // log (id)
                                                 anzahl++;
                                                  counter++;
                                                  if (!val1) {
                                                      val1="❌";
                                                  else{
                                                      val1="✅";
                                        } //ende fritzdect
                                        } // function ende
                                        //MAIN:
                                         writeHTML();
                                         writeHTML();
        } break;
        } break;
                                             } //switch ende
                                                 case 1:    break;
                                                            break;
                                                            break;
                                                            break; }
                                                 case 1:    break;
                                                            break;
                                                            break;
                                                            break; }
                                                   var htmlOutVIS="";
                                                      } else {
                                         //log(htmlOut);
                                          liv-in-sky @Glasfaser last edited by
                                          @Glasfaser hast du eine ahnung warum das nicht geht - datenpunkt ist ein string
                                          val4=getState(id.replace("totalNow","power")).val.substr(0,4) + " W"
                                            @liv-in-sky
                                            Skript wird kurz Grün und geht dann auf Gelb (Pause)
                                            javascript.0	2020-01-18 20:03:00.017	error	(7176) at tryOnTimeout (timers.js:300:5)
                                            javascript.0	2020-01-18 20:03:00.017	error	(7176) at ontimeout (timers.js:436:11)
                                            javascript.0	2020-01-18 20:03:00.017	error	(7176) at Timeout._onTimeout (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:501:7)
                                            javascript.0	2020-01-18 20:03:00.017	error	(7176) at C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:543:11
                                            javascript.0	2020-01-18 20:03:00.016	error	(7176) at Job.invoke (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:173:10)
                                            javascript.0	2020-01-18 20:03:00.016	error	(7176) at Job.nodeSchedule.scheduleJob [as job] (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1319:34)
                                            javascript.0	2020-01-18 20:03:00.016	error	(7176) at Object.<anonymous> (script.js.Listen.Energy_Devices1:424:2)
                                            javascript.0	2020-01-18 20:03:00.016	error	(7176) at writeHTML (script.js.Listen.Energy_Devices1:297:26)
                                            javascript.0	2020-01-18 20:03:00.016	error	(7176) at Object.result.each (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:846:29)
                                            javascript.0	2020-01-18 20:03:00.016	error	(7176) at script.js.Listen.Energy_Devices1:309:63
                                            javascript.0	2020-01-18 20:03:00.015	error	(7176) Error in callback: TypeError: getState(...).val.substr is not a function
                                            javascript.0	2020-01-18 20:02:51.025	error	(7176) at Script.runInContext (vm.js:133:20)
                                            javascript.0	2020-01-18 20:02:51.025	error	(7176) at script.js.Listen.Energy_Devices1:427:2
                                            javascript.0	2020-01-18 20:02:51.025	error	(7176) at writeHTML (script.js.Listen.Energy_Devices1:297:26)
                                            javascript.0	2020-01-18 20:02:51.025	error	(7176) at Object.result.each (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:846:29)
                                            javascript.0	2020-01-18 20:02:51.025	error	(7176) at script.js.Listen.Energy_Devices1:309:63
                                            javascript.0	2020-01-18 20:02:51.025	error	(7176) TypeError: getState(...).val.substr is not a function
                                            javascript.0	2020-01-18 20:02:51.025	error	(7176) ^
                                            javascript.0	2020-01-18 20:02:51.024	error	(7176) val4=(getState(id.replace("totalNow","power")).val).substr(0,4) + " W" ; // log (val4) //.substring(0,4)
                                            javascript.0	2020-01-18 20:02:51.024	error	(7176) script.js.Listen.Energy_Devices1: script.js.Listen.Energy_Devices1:309
                                            javascript.0	2020-01-18 20:02:51.016	info	(7176) Start javascript script.js.Listen.Energy_Devices1
                                            javascript.0	2020-01-18 20:02:49.790	info	(7176) Stop script script.js.Listen.Energy_Devices1
                                            1.0k
                                            javascript
                                            13
                                            289
                                            35458
