    4. JavaScript
    5. Strom Geräte als HTML Tabelle - Vis - Iqontrol
      sigi234 Forum Testing Most Active @liv-in-sky last edited by sigi234
      @liv-in-sky sagte in Strom Geräte als HTML Tabelle - Vis - Iqontrol:
      @sigi234 @HeinrichB
      ich bekome da keinen fehler im script
      wandelt mal den befehl um in zeile 308 - kommt da immer noch ein fehler
       val4=getState(id.replace("totalNow","power")).val+ " W"     ;     log (val4)
      19:28:36.382	info	javascript.0 (392) Stop script script.js.Listen.Energy_Devices1
      19:28:36.388	info	javascript.0 (392) Start javascript script.js.Listen.Energy_Devices1
      19:28:36.394	info	javascript.0 (392) script.js.Listen.Energy_Devices1: 70.295 W
      19:28:36.395	error	javascript.0 (392) script.js.Listen.Energy_Devices1: script.js.Listen.Energy_Devices1:310
      19:28:36.395	error	javascript.0 (392) at script.js.Listen.Energy_Devices1:310:63
      19:28:36.395	error	javascript.0 (392) at writeHTML (script.js.Listen.Energy_Devices1:296:26)
      19:28:36.395	error	javascript.0 (392) at script.js.Listen.Energy_Devices1:358:2
      javascript.0	2020-01-18 19:30:00.032	error	(392) at tryOnTimeout (timers.js:300:5)
      javascript.0	2020-01-18 19:30:00.032	error	(392) at ontimeout (timers.js:436:11)
      javascript.0	2020-01-18 19:30:00.032	error	(392) at Timeout._onTimeout (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:501:7)
      javascript.0	2020-01-18 19:30:00.032	error	(392) at C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:543:11
      javascript.0	2020-01-18 19:30:00.031	error	(392) at Job.invoke (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:173:10)
      javascript.0	2020-01-18 19:30:00.031	error	(392) at Job.nodeSchedule.scheduleJob [as job] (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1319:34)
      javascript.0	2020-01-18 19:30:00.031	error	(392) at Object.<anonymous> (script.js.Listen.Energy_Devices1:355:2)
      javascript.0	2020-01-18 19:30:00.031	error	(392) at writeHTML (script.js.Listen.Energy_Devices1:296:26)
      javascript.0	2020-01-18 19:30:00.031	error	(392) at Object.result.each (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:846:29)
      javascript.0	2020-01-18 19:30:00.031	error	(392) at script.js.Listen.Energy_Devices1:310:63
      javascript.0	2020-01-18 19:30:00.031	error	(392) Error in callback: TypeError: getState(...).val.substring is not a function
        liv-in-sky @sigi234 last edited by liv-in-sky
        @sigi234 oh ich glaube falscher befehl - ich mach noch was anderes fertig und dann kommt update
          ok - versuch - alles ersetzen, was unter let myschedule steht
          @sigi234 @HeinrichB - bitte checken ob das jetzt geht
          homematic user
          werden die geräte gefunden ?
          //@liv-in-sky Januar 2020
          //HIER WIRD PFAD UND FILENAME DEFINIERT
          const path = "/htmlenergy.html";                   //FIlenamen definieren
          const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
          let   braucheEinFile=false;                          // bei true wird ein file geschrieben
          let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
          let dpVIS="controll-own.0.TABELLEN.ENERGY"         //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
          let dpAnzahl="controll-own.0.TABELLEN.AnzahlEnergiemesser";  //WICHTIG datenpunkt erstellen vom typ "number" - bei 0 kein alarm und größer 0 die anzahl der schlechten batterien
          let htmlColorDeviceUeberschrift="white"
          let triggerBySonoffPower=true;
          let mySchedule="  * * * * * ";
          let kwhPreis=0.29;
          var pow=true;
          var tuya=true;
          var hs100=true; //tplink
          var homematic=true;
          var gosundSP1x=true;
          var externalOhneInfo=false;  //noch nicht integriert
          var schalter2ch=true;
          var schalter3ch=true;
          //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 5
          var htmlFeld1='Device';       var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
          var htmlFeld2='Status';        var Feld2lAlign="center";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
          var htmlFeld3='Amp';         var Feld3lAlign="center";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
          var htmlFeld4='Volt';        var Feld4lAlign="center";                    // überschrift Tabellen Spalte4 und  Ausrichtung left,right or center
          var htmlFeld5='Power';        var Feld5lAlign="left";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
          var htmlFeld6='Schalter';        var Feld6lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
          var htmlFeld7='';        var Feld7lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
          var htmlFeld8='';        var Feld8lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
          var htmlFeld9='';        var Feld9lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
          var htmlFeld10='';        var Feld10lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
          //ÜBERSCHRIFT ÜBER TABELLE
          let   htmlUberschrift=true;                           // mit Überschrift über der tabelle
          let   htmlSignature=false;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
          const htmlFeldUeber='Energy Devices';              // Überschrift und Signature
          const htmlFarbUber="white";                         // Farbe der Überschrift
          const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
          const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
          //MEHRERE TABELLEN NEBENEINANDER
          let   mehrfachTabelle=1;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
          const htmlFarbZweiteTabelle="white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
          const htmlFarbTableColorUber="#BDBDBD";               // Überschrift in der tabelle - der einzelnen Spalten
          //GANZE TABELLE
          let abstandZelle="1";
          let weite="auto";                                     //Weite der Tabelle
          let zentriert=true;                                   //ganze tabelle zentriert
          const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
          const htmlSchriftart="Helvetica";
          const htmlSchriftgroesse="14px";
          //FELDER UND RAHMEN
          let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
          const htmlFarbFelderschrift="#BDBDBD";                  // SchriftFarbe der Felder
          const htmlFarbFelderschrift2="#D8D8D8";                 // SchriftFarbe der Felder für jede 2te Tabelle
          const htmlFarbTableColorGradient1="#424242";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
          const htmlFarbTableColorGradient2="#424242";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
          const htmlFarbTableBorderColor="gray";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
          let htmlRahmenLinien="cols";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
          const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
          // HIER NICHTS  ÄNDERN
          let borderHelpBottum;
          let borderHelpRight;
          let htmlcenterHelp;
          let htmlcenterHelp2;
          if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
          if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
          if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
          if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
          zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
          zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
          const htmlZentriert='<center>'
          const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                             "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                             " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                            // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                             " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                             " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                             "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                             " </style></head><body> <div>";
          //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
          const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                                "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
          const htmlTabUeber1="<tr style=\"color:"+htmlFarbTableColorUber+"; font-weight: bold\">";
          const htmlTabUeber3="</tr>";
          //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 5
          var htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td><td align="+Feld4lAlign+
                            ">&ensp;"+htmlFeld4+"&ensp;</td><td  align="+Feld5lAlign+">&ensp;"+htmlFeld5+"&ensp;</td><td  align="+Feld6lAlign+">&ensp;"+htmlFeld6+"&ensp;</td><td  align="+Feld7lAlign+">&ensp;"+htmlFeld7+"&ensp;</td><td  align="+Feld8lAlign+">&ensp;"+htmlFeld8+
                            "&ensp;</td><td  align="+Feld9lAlign+">&ensp;"+htmlFeld9+"&ensp;</td><td  align="+Feld10lAlign+">&ensp;"+htmlFeld10+"&ensp;</td>";
          var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+
                             "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld4+
                             "&ensp;</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\"&ensp;>"+htmlFeld5+"&ensp;</td><td align="+Feld6lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\"&ensp;>"+htmlFeld6+"&ensp;</td><td align="+Feld7lAlign+
                             " style=\"color:"+htmlFarbZweiteTabelle+"\"&ensp;>"+htmlFeld7+"&ensp;</td><td align="+Feld8lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\"&ensp;>"+htmlFeld8+"&ensp;</td><td  align="+Feld9lAlign+">&ensp;"+htmlFeld9+"&ensp;</td><td  align="+Feld10lAlign+">&ensp;"+htmlFeld10+"&ensp;</td>";
          let triggerBySonoffSwitch=false;
          var anzahl;
          var AkkuAlarm=[];
          var htmlOut="";
          var mix;
          var counter;
          var arrTrigger=[];
          var val1; var val2; var val0; var val3; var val4; var val5; var val6; var val7; var val8; var val9;
          var htmlTabUeber="";
          function writeHTML(){
          anzahl=0;
          htmlOut="";
          counter=-1;
          htmlTabUeber="";
          switch (mehrfachTabelle) {
             case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
             case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
             case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2+htmlTabUeber2+htmlTabUeber3; break;
             case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
          if (!UeberschriftSpalten) {htmlTabUeber=""}
          //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
          //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2,val3,val4!!!------------------------------------------------------------
          if (pow){
                       // UNTERTEILUNG - ÜBERSCHRIFT IN TABELLE
                tabelleAusbessern();
                counter=0;
                val0=""; val1=""; val2="";val3="";val4="";val5="";val6="";val7="";val8="";val9="";
                tabelleBind(); //HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT  - diese function muss als letztes in der eigenen schleife aufgerufen werden
                counter=0;
                val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>Pow (R2)</b>"; val1=""; val2="";val3="";val4="";
                val5="<font color=\""+htmlColorDeviceUeberschrift+"\">";
                val6="<font color=\""+htmlColorDeviceUeberschrift+"\">kWh Heute";
                val7="<font color=\""+htmlColorDeviceUeberschrift+"\">kWh Gesamt";
                val8="<font color=\""+htmlColorDeviceUeberschrift+"\"><i>Preis Heute<\/i>";
                val9="<font color=\""+htmlColorDeviceUeberschrift+"\"><i>Preis Gesamt<\/i>";
                counter=-1
          //sonoff.0.SonoffPow1.INFO.Module
           $('sonoff.*.*.INFO.Module').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                if (getState(id).val=="Sonoff Pow" || getState(id).val=="Sonoff Pow R2") {
                   // log (id)
                   anzahl++;
                  var ida = id.split('.');
                    counter++;
                      //log("dad   "+getState(id.replace("Info.Module","alive")).val + " ----" +id.replace("Info.Module","alive"))
                    val1=getState(id.replace("INFO.Module","alive")).val;                   //sonoff.0.SonoffPow1.alive          sonoff.0.SonoffPow1.INFO.Module
                    val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]).common.name ;
                    val4=getState(id.replace("INFO.Module","ENERGY_Power")).val.toString()+ " W"                       //sonoff.0.SonoffPow2.ENERGY_Power
                    val2=getState(id.replace("INFO.Module","ENERGY_Current")).val.toFixed(2)+ " A";   //sonoff.0.SonoffPow1.Wifi_RSSIsonoff.0.SonoffPow1.POWER
                    val3=getState(id.replace("INFO.Module","ENERGY_Voltage")).val.toString()+" V";
                    let val7_1=getState(id.replace("INFO.Module","POWER")).val;
                    val7_1 ? val5=(" <font color=\"lightgreen\"> ")+"ON" : val5=(" <font color=\"red\"> ")+"OFF";
                    val6=getState(id.replace("INFO.Module","ENERGY_Today")).val.toFixed(2)+ " kWh";
                    val7=getState(id.replace("INFO.Module","ENERGY_Total")).val.toFixed(2)+ " kWh";
                    val8=(getState(id.replace("INFO.Module","ENERGY_Today")).val*kwhPreis).toFixed(1)+" €";
                    val9=(getState(id.replace("INFO.Module","ENERGY_Total")).val*kwhPreis).toFixed(1)+" €";
                    if (!getState(id.replace("INFO.Module","alive")).val) {
                        val1="❌";
                        val4=(" <font color=\"red\"> ")+val1;
                        val2=(" <font color=\"red\"> ")+val2;
                        val3=(" <font color=\"red\"> ")+" 0 %";
                        val5=(" <font color=\"red\"> ")+" --- ";
                        val6=(" <font color=\"red\"> ")+" --- ";
                        val7=(" <font color=\"red\"> ")+" --- ";
                        val0=(" <font color=\"red\"> ")+val0}
                    else{
                        val1="✅";
                       // val1=(" <font color=\"lightgreen\"> ")+val1
                       // val2=(" <font color=\"green\"> ")+val2
                       // val3=(" <font color=\"green\"> ")+val3
                       // val0=(" <font color=\"green\"> ")+val0
            } }); //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
          } //ende fritzdect
           if (gosundSP1x){
                counter=0;
                val0=val0=""; val1=""; val2="";val3="";val4="";val5="";val6="";val7="";
                counter=0;
               val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>Gosund</b>"; val1=""; val2="";val3="";val4="";
                counter=-1
                if (getState(id).val.includes("Gosund SP1")) {
                   // log (id)
                   anzahl++;
                     counter++;
                        val1="❌";
                    else{
                        val1="✅";
          } //ende fritzdect
           if (hs100){
                counter=0;
                counter=0;
                val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>HS100</b>"; val1=""; val2="";val3="";val4="";
                val6="<font color=\""+htmlColorDeviceUeberschrift+"\">kWh Now";
                val7="<font color=\""+htmlColorDeviceUeberschrift+"\">kWh Monat";
                val8="<font color=\""+htmlColorDeviceUeberschrift+"\"><i>Preis Now<\/i>";
                val9="<font color=\""+htmlColorDeviceUeberschrift+"\"><i>Preis Monat<\/i>";
                counter=-1
           $('hs100.0.*.totalNow').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                   // log (id)
                   anzahl++;
                    counter++;
                   var valVersion=getState(id.replace("totalNow","hw_ver")).val;
                    val1=getState(id.replace("totalNow","state")).val;
                    val0=getObject(id).common.name ;
                    val4=getState(id.replace("totalNow","power")).val.substr(0,4)+ " W"     ;    // log (val4)       //.substring(0,4)
                    if(valVersion=="1.0")  {val2=getState(id.replace("totalNow","current")).val.substr(0,5)+ " A";} else {val2=getState(id.replace("totalNow","current")).val+ " mA";}
                    val3=getState(id.replace("totalNow","voltage")).val.substring(0,3)+" V";
                    val5=" - "; // let val7_1=getState(id.replace("INFO.Module","POWER")).val;
                    //val7_1 ? val5=(" <font color=\"lightgreen\"> ")+"ON" : val5=(" <font color=\"red\"> ")+"OFF";
                    val6=getState(id).val.substring(0,5)+ " kWh";
                    val7=getState(id.replace("totalNow","totalMonthNow")).val.substr(0,5)+ " kWh";
                    val8=(parseFloat(getState(id).val)*kwhPreis).toFixed(2)+" €";
                    val9=(parseFloat(getState(id.replace("totalNow","totalMonthNow")).val)*kwhPreis).toFixed(2)+" €";
                    if (!val1) {
                        val1="❌";
                    else{
                        val1="✅";
          } //ende fritzdect
           if (homematic){
                counter=0;
                counter=0;
                val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>Homematic</b>"; val1=""; val2="";val3="";val4="";
                counter=-1
           $('hm-rpc.*.*.*.ENERGY_COUNTER').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                   // log (id)
                   anzahl++;
                    counter++;
                //   var valVersion=getState(id.replace("totalNow","hw_ver")).val;
                    val1=" - "; //getState(id.replace("ENERGY_COUNTER","STATE")).val;
                    val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]).common.name ;  //val0=getObject(id).common.name ;
                    val4=getState(id.replace("ENERGY_COUNTER","POWER")).val+ " W"     ;     //log (val4)       //.substring(0,4)
                    val2=getState(id.replace("ENERGY_COUNTER","CURRENT")).val.toFixed(0)+ " mA";
                    val3=getState(id.replace("ENERGY_COUNTER","VOLTAGE")).val.toFixed(0)+" V";
                    val6=" - "; // getState(id).val.substring(0,5)+ " kWh";
                    val7=" - "; // getState(id.replace("totalNow","totalMonthNow")).val.substring(0,5)+ " kWh";
                    val8=" - "; // (parseFloat(getState(id).val)*kwhPreis).toFixed(2)+" €";
                    val9=" - "; // (parseFloat(getState(id.replace("totalNow","totalMonthNow")).val)*kwhPreis).toFixed(2)+" €";
                    if (!val1) {
                        val1="❌";
                    else{
                        val1="✅";
          } //ende fritzdect
          //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                tabelleFinish(); // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
              // log(anzahl.toString());
                    setState(dpAnzahl,anzahl);
          } // function ende
          //MAIN:
          schedule(mySchedule,  function () {
           writeHTML();
           if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
           writeHTML();
             				 function tabelleBind(){
               //HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT - hat man oben 5 Felder definiert, braucht man hier 5 Werte
                   case 1:                    htmlOut=htmlOut+"<tr><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td></tr>"; break;
                  case 2:  if(counter%2==0)  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td>"; }
                                        else {htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td></tr>";} break;
                  case 3: if(counter%3==0 )  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td>"; }
                                        else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td>";}
                                                         else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td></tr>";}
                                                   } break;
                  case 4: if(counter%4==0)  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td>"; }
                                            else {if(counter%2==1 )  { htmlOut = htmlOut+"<td  align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td>";}
                                                         else    {if(counter%2==1 && counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td></tr>";}
        else    {htmlOut = htmlOut = htmlOut+"<td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td>&ensp;"+val1+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td>";}}
                                                   } break;
               } //switch ende
          function tabelleAusbessern() {
                   case 1:    break;
                   case 2:    mix=Math.abs(((counter+1)%2)-mehrfachTabelle);
                              if(mix==1)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                              break;
                   case 3:    mix =Math.abs(((counter+1)%3)-mehrfachTabelle);
                              if(mix==2)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                              break;
                   case 4:    mix=Math.abs(((counter+1)%4)-mehrfachTabelle);
                              if(mix==3)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                              break; }
          function tabelleFinish() {
                // tabelle fertigstellen
                   case 1:    break;
                              break;
                              break;
                              break; }
                              var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
                 var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                  if (!htmlSignature) htmlUnter="";
                    //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                     var htmlOutVIS="";
                   //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                      if (htmlUberschrift)
                          { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter ;
                        } else {
                         zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter;
          // log("bin raus aus tabelleBind");
                     if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
           var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
           var htmlEnd="</table>"+htmlUnter+"</div></body>";
           //mit oder ohne überschrift - zentriert oder links
          htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
           //log(htmlOut);
          sigi234 ? Glasfaser Homoran 4 Replies Last reply Reply Quote 0
            @liv-in-sky
            javascript.0	2020-01-18 19:43:00.030	error	(392) at tryOnTimeout (timers.js:300:5)
            javascript.0	2020-01-18 19:43:00.030	error	(392) at ontimeout (timers.js:436:11)
            javascript.0	2020-01-18 19:43:00.030	error	(392) at Timeout._onTimeout (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:501:7)
            javascript.0	2020-01-18 19:43:00.029	error	(392) at C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:543:11
            javascript.0	2020-01-18 19:43:00.029	error	(392) at Job.invoke (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:173:10)
            javascript.0	2020-01-18 19:43:00.029	error	(392) at Job.nodeSchedule.scheduleJob [as job] (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1319:34)
            javascript.0	2020-01-18 19:43:00.029	error	(392) at Object.<anonymous> (script.js.Listen.Energy_Devices1:424:2)
            javascript.0	2020-01-18 19:43:00.029	error	(392) at writeHTML (script.js.Listen.Energy_Devices1:297:26)
            javascript.0	2020-01-18 19:43:00.029	error	(392) at Object.result.each (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:846:29)
            javascript.0	2020-01-18 19:43:00.029	error	(392) at script.js.Listen.Energy_Devices1:309:61
            javascript.0	2020-01-18 19:43:00.028	error	(392) Error in callback: TypeError: getState(...).val.substr is not a function
            javascript.0	2020-01-18 19:42:53.808	error	(392) at Script.runInContext (vm.js:133:20)
            javascript.0	2020-01-18 19:42:53.808	error	(392) at script.js.Listen.Energy_Devices1:427:2
            javascript.0	2020-01-18 19:42:53.808	error	(392) at writeHTML (script.js.Listen.Energy_Devices1:297:26)
            javascript.0	2020-01-18 19:42:53.808	error	(392) at Object.result.each (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:846:29)
            javascript.0	2020-01-18 19:42:53.808	error	(392) at script.js.Listen.Energy_Devices1:309:61
            javascript.0	2020-01-18 19:42:53.808	error	(392) TypeError: getState(...).val.substr is not a function
            javascript.0	2020-01-18 19:42:53.808	error	(392) ^
            javascript.0	2020-01-18 19:42:53.808	error	(392) val4=getState(id.replace("totalNow","power")).val.substr(0,4)+ " W" ; // log (val4) //.substring(0,4)
            javascript.0	2020-01-18 19:42:53.808	error	(392) script.js.Listen.Energy_Devices1: script.js.Listen.Energy_Devices1:309
              A Former User @liv-in-sky last edited by
              @liv-in-sky
              Hier mein Log
              19:42:17.908	info	javascript.0 (8084) Stop script script.js.Stromgeräte_Tabelle
              19:42:19.869	info	javascript.0 (8084) Start javascript script.js.Stromgeräte_Tabelle
              19:42:19.902	error	javascript.0 (8084) script.js.Stromgeräte_Tabelle: script.js.Stromgeräte_Tabelle:309
              19:42:19.903	error	javascript.0 (8084) at script.js.Stromgeräte_Tabelle:309:61
              19:42:19.903	error	javascript.0 (8084) at writeHTML (script.js.Stromgeräte_Tabelle:297:26)
              19:42:19.904	error	javascript.0 (8084) at script.js.Stromgeräte_Tabelle:427:2
              19:42:25.451	info	javascript.0 (8084) Stop script script.js.Stromgeräte_Tabelle
              Hier meine angelegten DP zur Zeit und zwei Screens von zwei Geräten mit Verbrauch (HS110 und Sonoff POWR2)
              Bildschirmfoto 2020-01-18 um 19.40.36.JPG Bildschirmfoto 2020-01-18 um 19.41.04.JPG
                liv-in-sky @Guest last edited by liv-in-sky
                @HeinrichB @sigi234
                ich checke es nicht - ist der selbe fehler bei euch beiden - bei mir geht es - irgendwie sind unsere datenpunkte verschieden , denn den befehl gibt es aber anscheinend ist er bei euch nicht auf den datenpunkt anwendbar
                der datenpunkt hs100.0.*.power ist doch eine dp mit typ zeichenkette (string) - genauso wie ..voltage und ...current
                  Ja
                  Stimmt das?
                  • Glasfaser
                    Glasfaser @liv-in-sky last edited by
                    homematic user
                    Jipp ...HMIP
                      @sigi234 bitte teste mal - danke für deine geduld
                      let kwhPreis=0.29;
                      var pow=true;
                      var tuya=true;
                      var homematic=true;
                      //GANZE TABELLE
                      //FELDER UND RAHMEN
                      let htmlcenterHelp;
                      var anzahl;
                      var AkkuAlarm=[];
                      var htmlOut="";
                      var mix;
                      var counter;
                      var arrTrigger=[];
                      anzahl=0;
                      htmlOut="";
                      counter=-1;
                      htmlTabUeber="";
                      if (pow){
                            counter=0;
                            counter=0;
                            counter=-1
                               // log (id)
                               anzahl++;
                                counter++;
                                    val1="❌";
                                else{
                                    val1="✅";
                      } //ende fritzdect
                       if (gosundSP1x){
                            counter=0;
                            counter=0;
                            counter=-1
                               // log (id)
                               anzahl++;
                                 counter++;
                                    val1="❌";
                                else{
                                    val1="✅";
                      } //ende fritzdect
                       if (hs100){
                            counter=0;
                            counter=0;
                            counter=-1
                       $('hs100.*.*.totalNow').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                               // log (id)
                               anzahl++;
                                counter++;
                                val1=getState(id.replace("totalNow","state")).val;          //    hs100.0.192_168_178_43.power
                                val4=(getState(id.replace("totalNow","power")).val).substr(0,4) + " W"     ;    // log (val4)       //.substring(0,4)
                                if(valVersion=="1.0")  {val2=(getState(id.replace("totalNow","current")).val).substr(0,5)+ " A";} else {val2=getState(id.replace("totalNow","current")).val+ " mA";}
                                val3=(getState(id.replace("totalNow","voltage")).val).substring(0,3)+" V";
                                val7=(getState(id.replace("totalNow","totalMonthNow")).val).substr(0,5)+ " kWh";
                                if (!val1) {
                                    val1="❌";
                                else{
                                    val1="✅";
                      } //ende fritzdect
                       if (homematic){
                            counter=0;
                            counter=0;
                            counter=-1
                               // log (id)
                               anzahl++;
                                counter++;
                                if (!val1) {
                                    val1="❌";
                                else{
                                    val1="✅";
                      } //ende fritzdect
                      } // function ende
                      //MAIN:
                       writeHTML();
                       writeHTML();
                                                               } break;
                                                               } break;
                           } //switch ende
                               case 1:    break;
                                          break;
                                          break;
                                          break; }
                               case 1:    break;
                                          break;
                                          break;
                                          break; }
                                 var htmlOutVIS="";
                                    } else {
                       //log(htmlOut);
                        liv-in-sky @Glasfaser last edited by
                        @Glasfaser hast du eine ahnung warum das nicht geht - datenpunkt ist ein string
                        val4=getState(id.replace("totalNow","power")).val.substr(0,4) + " W"
                          @liv-in-sky
                          Skript wird kurz Grün und geht dann auf Gelb (Pause)
                          javascript.0	2020-01-18 20:03:00.017	error	(7176) at tryOnTimeout (timers.js:300:5)
                          javascript.0	2020-01-18 20:03:00.017	error	(7176) at ontimeout (timers.js:436:11)
                          javascript.0	2020-01-18 20:03:00.017	error	(7176) at Timeout._onTimeout (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:501:7)
                          javascript.0	2020-01-18 20:03:00.017	error	(7176) at C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:543:11
                          javascript.0	2020-01-18 20:03:00.016	error	(7176) at Job.invoke (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:173:10)
                          javascript.0	2020-01-18 20:03:00.016	error	(7176) at Job.nodeSchedule.scheduleJob [as job] (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1319:34)
                          javascript.0	2020-01-18 20:03:00.016	error	(7176) at Object.<anonymous> (script.js.Listen.Energy_Devices1:424:2)
                          javascript.0	2020-01-18 20:03:00.016	error	(7176) at writeHTML (script.js.Listen.Energy_Devices1:297:26)
                          javascript.0	2020-01-18 20:03:00.016	error	(7176) at Object.result.each (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:846:29)
                          javascript.0	2020-01-18 20:03:00.016	error	(7176) at script.js.Listen.Energy_Devices1:309:63
                          javascript.0	2020-01-18 20:03:00.015	error	(7176) Error in callback: TypeError: getState(...).val.substr is not a function
                          javascript.0	2020-01-18 20:02:51.025	error	(7176) at Script.runInContext (vm.js:133:20)
                          javascript.0	2020-01-18 20:02:51.025	error	(7176) at script.js.Listen.Energy_Devices1:427:2
                          javascript.0	2020-01-18 20:02:51.025	error	(7176) at writeHTML (script.js.Listen.Energy_Devices1:297:26)
                          javascript.0	2020-01-18 20:02:51.025	error	(7176) at Object.result.each (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:846:29)
                          javascript.0	2020-01-18 20:02:51.025	error	(7176) at script.js.Listen.Energy_Devices1:309:63
                          javascript.0	2020-01-18 20:02:51.025	error	(7176) TypeError: getState(...).val.substr is not a function
                          javascript.0	2020-01-18 20:02:51.025	error	(7176) ^
                          javascript.0	2020-01-18 20:02:51.024	error	(7176) val4=(getState(id.replace("totalNow","power")).val).substr(0,4) + " W" ; // log (val4) //.substring(0,4)
                          javascript.0	2020-01-18 20:02:51.024	error	(7176) script.js.Listen.Energy_Devices1: script.js.Listen.Energy_Devices1:309
                          javascript.0	2020-01-18 20:02:51.016	info	(7176) Start javascript script.js.Listen.Energy_Devices1
                          javascript.0	2020-01-18 20:02:49.790	info	(7176) Stop script script.js.Listen.Energy_Devices1
                            @sigi234 - hier mal alle substrings raus - wenn das nix bringt - muss ich pause machen
                            let kwhPreis=0.29;
                            var pow=true;
                            var tuya=true;
                            var homematic=true;
                            //GANZE TABELLE
                            //FELDER UND RAHMEN
                            let htmlcenterHelp;
                            var anzahl;
                            var AkkuAlarm=[];
                            var htmlOut="";
                            var mix;
                            var counter;
                            var arrTrigger=[];
                            anzahl=0;
                            htmlOut="";
                            counter=-1;
                            htmlTabUeber="";
                            if (pow){
                                  counter=0;
                                  counter=0;
                                  counter=-1
                                     // log (id)
                                     anzahl++;
                                      counter++;
                                          val1="❌";
                                          val0=(" <font color=\"red\"> ")+val0 ;
                                          val8=(" <font color=\"red\"> ")+val8;
                                          val9=(" <font color=\"red\"> ")+val9}
                                      else{
                                          val1="✅";
                            } //ende fritzdect
                             if (gosundSP1x){
                                  counter=0;
                                  counter=0;
                                  counter=-1
                                     // log (id)
                                     anzahl++;
                                       counter++;
                                          val1="❌";
                                      else{
                                          val1="✅";
                            } //ende fritzdect
                             if (hs100){
                                  counter=0;
                                  counter=0;
                                  counter=-1
                                     // log (id)
                                     anzahl++;
                                      counter++;
                                     // val4=(getState(id.replace("totalNow","power")).val).substr(0, 4) + " W"     ;    // log (val4)       //.substring(0,4)
                                      val4=getState(id.replace("totalNow","power")).val + " W"     ;    // log (val4)       //.substring(0,4)
                                    //  if(valVersion=="1.0")  {val2=(getState(id.replace("totalNow","current")).val).substr(0, 5)+ " A";} else {val2=getState(id.replace("totalNow","current")).val+ " mA";}
                                      if(valVersion=="1.0")  {val2=getState(id.replace("totalNow","current")).val + " A";} else {val2=getState(id.replace("totalNow","current")).val+ " mA";}
                                     // val3=(getState(id.replace("totalNow","voltage")).val).substring(0, 3)+" V";
                                      val3=getState(id.replace("totalNow","voltage")).val +" V";
                                      //val6=getState(id).val.substring(0,5)+ " kWh";
                                      val6=getState(id).val + " kWh";
                                     // val7=(getState(id.replace("totalNow","totalMonthNow")).val).substr(0, 5)+ " kWh";
                                      val7=getState(id.replace("totalNow","totalMonthNow")).val+ " kWh";
                                      if (!val1) {
                                          val1="❌";
                                      else{
                                          val1="✅";
                            } //ende fritzdect
                             if (homematic){
                                  counter=0;
                                  counter=0;
                                  counter=-1
                                     // log (id)
                                     anzahl++;
                                      counter++;
                                      if (!val1) {
                                          val1="❌";
                                      else{
                                          val1="✅";
                            } //ende fritzdect
                            } // function ende
                            //MAIN:
                             writeHTML();
                             writeHTML();
        } break;
        } break;
                                 } //switch ende
                                     case 1:    break;
                                                break;
                                                break;
                                                break; }
                                     case 1:    break;
                                                break;
                                                break;
                                                break; }
                                       var htmlOutVIS="";
                                          } else {
                             //log(htmlOut);
                            • Glasfaser
                              Mhh .....
                              @sigi234
                              Kannst du mal vom Datenpunkt mehr Infos ausgeben :
                                sigi234 Forum Testing Most Active @Glasfaser last edited by
                                @Glasfaser sagte in Strom Geräte als HTML Tabelle - Vis - Iqontrol:
                                Mhh .....
                                @sigi234
                                  "from": "system.adapter.hs100.0",
                                  "user": "system.user.admin",
                                  "ts": 1573318948174,
                                  "common": {
                                    "name": "Strom LG TV",
                                    "type": "string",
                                    "read": true,
                                    "write": true,
                                    "role": "value",
                                    "desc": "totalNow",
                                    "def": 0,
                                    "custom": {
                                      "history.0": {
                                        "enabled": true,
                                        "changesOnly": true,
                                        "debounce": "1000",
                                        "maxLength": "10",
                                        "retention": "31536000",
                                        "changesRelogInterval": 5,
                                        "changesMinDelta": 0,
                                        "aliasId": ""
                                    "smartName": {
                                      "smartType": "SMARTPLUG"
                                  "native": {
                                    "ip": "192.168.178.23"
                                  "acl": {
                                    "object": 1636,
                                    "owner": "system.user.admin",
                                    "state": 1636
                                  "_id": "hs100.0.192_168_178_23.totalNow",
                                  "type": "state"
                                    @sigi234geht und sieht sch.. aus - mich wunderts, das es bei mir funktoniert - ich mußte die werte von hand eingeben, weil sie duch den import nicht da waren - sonst ist ja alles gleich
                                      Homoran Global Moderator Administrators @liv-in-sky last edited by
                                      homematic user
                                        liv-in-sky @Homoran last edited by
                                        @Homoran
                                        das ist eine sehr seltsame stelle für einen fehler - hast du was verändert - probiere bitte nochmal das script reinzukopieren - vielleicht fehlt was
                                          Homoran Global Moderator Administrators @liv-in-sky last edited by Homoran
                                          Das dachte ich auch, deshalb hatte ich bereits dreimal neu kopiert, jetzt nochmals neu angelegt, bleibt dabei
                                          Das einzige was ich geändert hatte war der Pfad zum ANzahl-Datenpunkt da steht aber 11 drin - das könnte passen
                                            @Homoran steht im log-tab etwas mehr an fehleranalyse
                                            javascript
                                            13
                                            289
                                            35457
