    3. Entwicklung
    4. Hue adapter
    Hue adapter
      looxer01 last edited by
      Hi PMAN,
      ich habe jetzt deinen Adapter und die dynamischen Scenen von ruhr erfolgreich im Einsatz. sehr cool….
      Ein blick ins log zeigt mir fast nur noch Hue aktionen wenn die dynamischen Scenen , eingeschaltet sind. (siehe unten)
      Gibt es eine Möglichkeit die Logeinträge auf Warnungen zu reduzieren ?
      vG L....
      hue-0	2015-08-22 10:49:46	info	final lightState: {"bri":254,"on":true,"hue":13374,"sat":254,"transitiontime":14,"colormode":"hs"}
      hue-0	2015-08-22 10:49:46	info	final lightState: {"bri":254,"on":true,"hue":11143,"sat":254,"transitiontime":23,"colormode":"hs"}
      hue-0	2015-08-22 10:49:44	info	final lightState: {"bri":254,"on":true,"hue":15820,"sat":254,"transitiontime":16,"colormode":"hs"}
      hue-0	2015-08-22 10:49:44	info	final lightState: {"bri":254,"on":true,"hue":15379,"sat":254,"transitiontime":16,"colormode":"hs"}
      hue-0	2015-08-22 10:49:44	info	final lightState: {"bri":254,"on":true,"hue":15640,"sat":254,"transitiontime":23,"colormode":"hs"}
      hue-0	2015-08-22 10:49:43	info	final lightState: {"bri":254,"on":true,"hue":16621,"sat":254,"transitiontime":12,"colormode":"hs"}
      hue-0	2015-08-22 10:49:42	info	final lightState: {"bri":254,"on":true,"hue":12300,"sat":254,"transitiontime":18,"colormode":"hs"}
      hue-0	2015-08-22 10:49:41	info	final lightState: {"bri":254,"on":true,"hue":16050,"sat":254,"transitiontime":20,"colormode":"hs"}
      hue-0	2015-08-22 10:49:40	info	final lightState: {"bri":254,"on":true,"hue":11345,"sat":254,"transitiontime":18,"colormode":"hs"}
      hue-0	2015-08-22 10:49:40	info	final lightState: {"bri":254,"on":true,"hue":14661,"sat":254,"transitiontime":29,"colormode":"hs"}
      hue-0	2015-08-22 10:49:40	info	final lightState: {"bri":254,"on":true,"hue":13500,"sat":254,"transitiontime":18,"colormode":"hs"}
      hue-0	2015-08-22 10:49:39	info	final lightState: {"bri":254,"on":true,"hue":15283,"sat":254,"transitiontime":11,"colormode":"hs"}
      hue-0	2015-08-22 10:49:38	info	final lightState: {"bri":254,"on":true,"hue":15992,"sat":254,"transitiontime":13,"colormode":"hs"}
      hue-0	2015-08-22 10:49:38	info	final lightState: {"bri":254,"on":true,"hue":11544,"sat":254,"transitiontime":19,"colormode":"hs"}
      hue-0	2015-08-22 10:49:37	info	final lightState: {"bri":254,"on":true,"hue":11206,"sat":254,"transitiontime":19,"colormode":"hs"}
      hue-0	2015-08-22 10:49:36	info	final lightState: {"bri":254,"on":true,"hue":11818,"sat":254,"transitiontime":18,"colormode":"hs"}
      hue-0	2015-08-22 10:49:35	info	final lightState: {"bri":254,"on":true,"hue":13986,"sat":254,"transitiontime":17,"colormode":"hs"}
      hue-0	2015-08-22 10:49:35	info	final lightState: {"bri":254,"on":true,"hue":13437,"sat":254,"transitiontime":28,"colormode":"hs"}
      hue-0	2015-08-22 10:49:34	info	final lightState: {"bri":254,"on":true,"hue":11842,"sat":254,"transitiontime":20,"colormode":"hs"}
      hue-0	2015-08-22 10:49:33	info	final lightState: {"bri":254,"on":true,"hue":15773,"sat":254,"transitiontime":22,"colormode":"hs"}
      hue-0	2015-08-22 10:49:33	info	final lightState: {"bri":254,"on":true,"hue":15266,"sat":254,"transitiontime":18,"colormode":"hs"}
      hue-0	2015-08-22 10:49:33	info	final lightState: {"bri":254,"on":true,"hue":14939,"sat":254,"transitiontime":17,"colormode":"hs"}
      hue-0	2015-08-22 10:49:31	info	final lightState: {"bri":254,"on":true,"hue":13260,"sat":254,"transitiontime":20,"colormode":"hs"}
      hue-0	2015-08-22 10:49:30	info	final lightState: {"bri":254,"on":true,"hue":16694,"sat":254,"transitiontime":28,"colormode":"hs"}
      hue-0	2015-08-22 10:49:30	info	final lightState: {"bri":254,"on":true,"hue":13720,"sat":254,"transitiontime":28,"colormode":"hs"}
      hue-0	2015-08-22 10:49:29	info	final lightState: {"bri":254,"on":true,"hue":16646,"sat":254,"transitiontime":17,"colormode":"hs"}
      hue-0	2015-08-22 10:49:28	info	final lightState: {"bri":254,"on":true,"hue":10718,"sat":254,"transitiontime":16,"colormode":"hs"}
        Pman last edited by
        Du kannst das Loglevel aller Instanzen in Admin unter Instanzen einstellen. Die Ausgaben werden noch reduziert oder auf debug geändert. Im moment ist es so, damit ich bei Fehlern auch aussagekräftige Logs bekomme.
          Pman last edited by
          Wer Zeit hat bitte mal die neue Version von iobroker.hue testen:
          npm install --production --prefix /opt/iobroker https://github.com/ioBroker/ioBroker.hue/tarball/master
          Besonderns interessiert mich ob es Probleme auf Wheezy und mit älteren Node Versionen gibt, ich musste ein paar Dinge fixen, damit es auf Jessie und Node 5.0 läuft.
          Die zweite Neurung: Die RGB Steuerung sollte jetzt deutlich treffsicherer sein bzw. eine passendere Farbe raussuchen, wenn man eine Farbe außerhalb des möglichen Spektrums ausgewählt hat. Außerdem wird am beim Polling aus den xy Werten eine RGB Farbe ausgerechnet und in die RGB States gespeichert. Nicht wundern: Wenn man eine RGB Farbe einstellt wird der RGB Wert beim nächsten Polling an die (möglichst) tatsächliche Farbe der Lampe angepasst. Setzt man nun diesen RGB Wert neu, kommt wieder eine andere Farbe/Helligkeit raus. Das liegt daran, dass man die Farbräume nicht 1:1 umrechnen kann.
          Langfristig wird es besser sein, einen Colorpicker auf Basis von Arnd Brugmans toller Vorarbeit umzusetzen:
          http://arndbrugman.github.io/huepi/hueI … l?size=256
          • V
            vader722 last edited by
            Moin,
            vielleicht habe ich es überlesen, aber kann ich auch über die Gruppe "0" alle Lichter addressieren ? Laut hue Api kann ich über die spezielle Gruppe 0 alle Lichter erreichen.
            Ich möchte mit einem Befehl alle Lichter ausschalten, geht das mit dem hue Adapter ?
            Gruss Marco
              Heinzelmaennchen last edited by
              Ich glaube nicht, dass das geht. Weil der Adapter beim Vorhandensein einer Gruppe diese dann auch in den Objekten anzeigen würde. Und die Gruppe 0 kann man glaube ich auch nicht auslesen oder bedienen.
              Ich habe das über eine scene gelöst, in der einfach alle leuchtmittel drin sind. Das funzt prima.
                Pman last edited by
                Die Gruppe 0 ist nicht implementiert, falls das überhaupt geht.
                Du kannst kannst aber in Hue einfach eine Gruppe mit allen Lichtern erstellen, die wird dann angezeigt. Oder in ioBroker eine Scene, was aber mehr Kommunikation mit der Bridge erfordert und diese ist bei zu vielen Anfragen pro Sekunde überfordert -> Verzögerungen einbauen. Für Dinge wie "alle aus" eignet sich eine Hue-interne Gruppe besser, da dann die Bridge sicherstellt, dass alle Befehle ausgeführt werden.
                  soef last edited by
                  bei der verwendeten Funktion api.getFullStates() wird die Gruppe 0 nicht zurückgegeben. Man könnte eine separate Anfrage per api.getAllGroups() stellen. Da aber in der Regel die Gruppe 0 statisch und immer vorhanden ist, könnte man sehr einfach in der main()-Funktion des Hue-Adapters folgendes unter die Zeile
                  main()
                          var groups = config.groups;
                  einfügen:
                          groups[0] = {
                              name: "All",   //"Lightset 0"
                              type: "LightGroup",
                              action: {
                                  lights: "ALL",
                                  alert: "select",
                                  bri: 0,
                                  colormode: "",
                                  ct: 0,
                                  effect: "none",
                                  hue: 0,
                                  on: false
                  Ich hoffe das hilft.
                  • V
                    Super!
                    So hatte ich mir das vorgestellt. So kann ich mit einem ioBroker Befehl alle hue's ausschalten (z.B. beim Haustür abschliessen) 🙂
                    Mit der Szene hatte ich das vorher gemacht, aber bei 20 Lichtern ist das relativ aufwändig und 20 Befehle zur Bridge sind irgendwie unelegant 😉
                    Da mein ioBroker sowieso ab einer gewissen Anzahl an Adaptern instabil läuft bin ich froh, wenn ich die Last etwas reduzieren kann.
                    Ich weiss nicht wie es bei Euch ist, aber der Raspi2 nagt bei mir am immer Speicherlimit. Ich hab schon einige Adapter deaktiviert, sonst crasht ioBroker jeden Tag.
                    Viele Dank für den hilfreichen Code, ich habe ihn bei mir mal in pman's Adapter eingefügt.
                    Gruss Marco
                      Pman last edited by
                      @soef:
                      main()
                      einfügen:
                              groups[0] = {
                                  type: "LightGroup",
                                  action: {
                                      lights: "ALL",
                                      alert: "select",
                                      bri: 0,
                                      colormode: "",
                                      ct: 0,
                                      effect: "none",
                                      hue: 0,
                                      on: false
                      Ich hoffe das hilft. `
                      Kannst du einen pull request mit den Änderungen machen?
                        soef last edited by
                        Bluefox hat den Pull Request mittlerweile gemerged.
                          chaos99 last edited by
                          Guten Morgen , kurz ne frage , wird die hü Bridge 2 auch unterstütz ?
                            Pman last edited by
                            Habe keine zum Testen da, sollte aber AFAIK die selbe API haben.
                            • V
                              Ich benutze die Hue Bridge 2.0. Funktioniert ohne Probleme (ist ja auch die gleich API).
                              Gruss Marco
                                Phteven last edited by
                                ich bin derzeit dabei von ccu.io auf ioBroker zu migrieren und vermisse schmerzlich das hue widget "hue_ctrl - jqui Dialog HUE_EXTENDED_COLOR_LIGHT", welches es für dashUI gibt.
                                Ich habe nun versucht dieses widget für vis selber zu erstellen (mit der Modifikation, dass die Hintergrundfarbe des widget buttons der eingestellten Farbe der hue Lampe entspricht). Hat auch soweit ganz gut geklappt…
                                Das Einzige was derzeit nicht funktioniert, ist die Anzeige bzw. das Initialisieren der eingestellten Werte, nach dem ersten Laden der View.
                                Wenn ich den Dialog nach dem Laden der View öffne sieht es so aus wie auf dem angehängten screenshot.
                                Alles steht auf 0 bzw hat einen undefinierten Wert, obwohl die hue Objekte sehr wohl einen Wert beinhalten.
                                Sobald ich einen Zustand verändere (z.B manuell in der Zustands-Liste der ioBroker Oberfläche) wird dieser eingestellte Wert dann auch richtig in dem Widget Dialog angezeigt.
                                Hat jemand einen Rat für mich wie ich dieses initialisieren hinbekommen kann?
                                  pepp86 last edited by
                                  ich weiß, dass der Thread schon eine weile inaktiv ist.
                                  Ich habe seit heute zwei Lightify Steckdosen an der Hue Bridge angemeldet. Via App kann ich die auch korrekt steuern. Im Adapter sind die Datenpunkte alle da und werden auch aktualisiert.
                                  Aber wenn ich jetzt aus ioBroker heraus die Steckdose schalten will geht sie kurz an und wird dann wieder ausgeschaltet weil der Adapter zwingend irgendwelche werte schreiben will (zB den bri Wert) die für die Steckdose aber nicht vorhanden sind. Api meldet Fehler dass der bri wert nicht vorhanden ist. Und dann wird on auf false gesetzt.
                                  Wenn weitere Informationen benötigt werden liefere ich die gerne nach.
                                  Danke.
                                    Hier habe ich jetzt noch einen Screenshot aus dem Log. Die Steckdose geht an, und kurz danach wieder aus.
                                      Pman last edited by
                                      Da brauchst du im Moment nicht weiter probieren, der Adapter kann ausschließlich Lampen steuern. Da ich keine HUE Steckdosen habe kann ich es leider nicht implementieren.
                                        Ok. Also ein generelles Problem.
                                        Hast du eine Idee woran es liegt? Bin mit meinen javascript fähigkeiten mal in den Adapter und habe geschaut, denn schalten tut er die Steckdose ja.
                                        Oder liegt es an der verwendeten Api? Eine der Komponenten baut den final lightState ja falsch um. Meine Vermutung ist, wenn man "bri" nicht mitsendet, dass es dann geht.
                                        Oder liege ich falsch?
                                        Kann dich gerne mit Daten versorgen oder testen wenn das bei der Implementierung hilft?!
                                          Pman last edited by
                                          Der Adapter nutzt die hue-node-api, dort werden so weit ich weiß auch schon keine switches unterstützt. Welche states wurden für den switch in ioBroker angelegt?
                                            Hier die States.
                                            Ausschalten klappt übrigens wunderbar
                                            185
                                            46259
