    3. Entwicklung
    4. Adapter mihome-vacuum anpassungen
      mumurik @dirkhe last edited by
      @dirkhe
      mihome-vacuum.0	2020-01-19 17:46:33.160	error	[8](unknown) -> data for segment is not a number
      mihome-vacuum.0	2020-01-19 17:46:33.159	debug	Receive <<< {"error":{"code":-10000,"message":"data for segment is not a number"},"id":8}<<< 21310070000000000f9d2ccf5e2487e8c9051a4918a4ed5fa74f4af3d0fc86180d55212412c09a0daa616947a3b1b72c0a841aacf20
      mihome-vacuum.0	2020-01-19 17:46:31.798	debug	sendMsgRaw >>> 21310060000000000f9d2ccf5e2487e7baeddb91e685ffd1b5d10376ab481804d5b038b381e72cc623fef9f4b40f8cfc5b3792455b1aaee44afa7bd56e5b38c844505b8b566afd5408801c56ae5f9fd2b246176debcb61543c93a4761
      mihome-vacuum.0	2020-01-19 17:46:31.798	debug	sendMsg >>> {"id":8,"method":"app_segment_clean","params":[null,null]}
      mihome-vacuum.0	2020-01-19 17:46:31.795	debug	Timestamp: 5e2487e7
      mihome-vacuum.0	2020-01-19 17:46:31.793	info	trigger cleaning segment 16,19
      mihome-vacuum.0	2020-01-19 17:46:31.791	debug	redis pmessage messagebox.system.adapter.mihome-vacuum.0 messagebox.system.adapter.mihome-vacuum.0 {"command":"cleanSegments","message":"16,19","from":"system.adapter.mihome-vacuum.0","_id":77384923}
      mihome-vacuum.0	2020-01-19 17:46:31.788	debug	sendTo "cleanSegments" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0: 16,19
      mihome-vacuum.0	2020-01-19 17:46:31.786	error	state must be .mapIndex for roomManager.cleanRooms mihome-vacuum.0.rooms.137001123083.roomFanPower
      mihome-vacuum.0	2020-01-19 17:46:31.784	error	state must be .mapIndex for roomManager.cleanRooms mihome-vacuum.0.rooms.137001123082.roomFanPower
      mihome-vacuum.0	2020-01-19 17:46:31.781	error	state must be .mapIndex for roomManager.cleanRooms mihome-vacuum.0.rooms.137001123083.roomClean
      mihome-vacuum.0	2020-01-19 17:46:31.779	error	state must be .mapIndex for roomManager.cleanRooms mihome-vacuum.0.rooms.137001123082.roomClean
      mihome-vacuum.0	2020-01-19 17:46:31.777	error	state must be .mapIndex for roomManager.cleanRooms mihome-vacuum.0.rooms.multiRoomClean
      mihome-vacuum.0	2020-01-19 17:46:31.635	debug	stateChange mihome-vacuum.0.rooms.multiRoomClean {"val":true,"ack":false,"ts":1579452391626,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1579452391626}
        dirkhe Developer @mumurik last edited by
        @mumurik lade nochmal herunter bitte
          @dirkhe
          jetzt läufts, sowohl multiRoomClean, als auch die Timer.
          Vielen Dank für die Mühe!
          • Meistertr
            Meistertr Developer @base last edited by
            @base nein wird aber noch anderweitig integriert.
              misteriobroker last edited by
              Wie genau installiere ich denn diese aktuellste Version über Github?!
              Auf den grünen Download Button und diesen Link dort nehmen und im ioBroker über die Katze dann mit der URL installieren?
                dirkhe Developer last edited by
                Aus eigener URL hinzufügen, ich glaube das ist die Katze und dann github auswählen und einfach nach Vakuum suchen
                  Sebastian Strobl last edited by
                  Bei mir kommt leider eine Fehlermeldung... Cannot install https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/master: 1
                    Was genau sagt das Log? Ich habe das eben noch gemacht. Passt die Berechtigung vlt nicht?
                      misteriobroker @dirkhe last edited by
                      @dirkhe said in Adapter mihome-vacuum anpassungen:
                      Ich habe das nochmal gemacht jetzt.
                      Es wird als erfolgreich beendet und bei meinen Adaptern steht der Mi Vacuum auf 1.1.5 weiterhin.
                      Wie genau muss der Reiter Rooms denn erscheinen?!
                      D Diginix 2 Replies Last reply Reply Quote 0
                        dirkhe Developer @misteriobroker last edited by
                        @misteriobroker als verfügbar oder installiert?
                        Verfügbar steht bei mir auch 1.1.5, das liegt daran, das es noch nicht bei npm ist, glaube ich.
                        Was steht denn im Log, welche Version er gestartet hst?
                        • Diginix
                          Diginix @misteriobroker last edited by
                          @misteriobroker Als Knoten unterhalb der Adapter Objekte.
                          Aber wenn deine Version noch auf 1.1.5 steht, dann ist die 1.10.x höchstunwahrscheinlich installiert.
                          ioBroker Fixer mal ausführen falls Berechtigungen im node_modules nicht passen oder auch einfach so.
                          Im Log steht auch welche Version vom Adapter gestartet wurde.
                            misteriobroker last edited by misteriobroker
                            Er startet die 1.1.5 🤔
                            Verfügbar und installiert beides auf 1.1.5
                              Ggf mal die Einstellungen kopieren, geht unter config und dann adapter löschen und dann wie oben beschrieben neu installieren
                                Ich glaube, unter den allgemeinen Einstellungen muss der verwahrungsort noch auf latest gestellt werden
                                  Mit den Einstellungen meinst du die Instanzen und deren Inhalt?
                                    Wenn du viel eingestellt hast, macht das Sinn, zumindest den Token mal wegsichern
                                    • X
                                      xADDRx @dirkhe last edited by
                                      @dirkhe Hallo dirkhe,
                                      wo soll denn die Nummer herkommen? Ich habe einfach ne nummer ausprobiert...
                                        dirkhe Developer @xADDRx last edited by
                                        @xADDRx du meinst den mapindex? Wenn deine Firmware das unterstützt, sendet er die von sich aus. Dazu musst du in der mihome App die Räume benennen. Wenn nicht, einfach mal testen.
                                        • X
                                          @dirkhe Ich habe den s5 mit der flolevac software. Dort kann man leider noch keine räume benennen.
                                            @xADDRx also ich würde mal versuchen, über die mihome App die Räume zu benennen. Irgendwer hier im Thread hat auch den s5 und bekommt die Räume auch nicht zurück, kann sie aber ansteuern, darum habe ich dieses manuelle raum hinzufügen gemacht, wo man ja mittlerweile auch Zonen Koordinaten hinterlegen kann
                                            adapter entwicklung raumreinigung roborock test vacuum zeitplan
                                            67
                                            511
                                            104719
