    3. Entwicklung
    4. Adapter mihome-vacuum anpassungen
    • magiczoom
      magiczoom last edited by
      Erstmal danke für die Mühen mit diesem Adapter.
      Ich habe selbst den S5 Max und hatte die offizielle Version 1.15 drauf, die Räume bspw waren also nicht drin.
      Wenn ich aber versuche über den Link von Git zu installieren, erhalte ich folgenden Error:
      Folgende Versionen nutze ich auf dem Pi:
      npm 6.13.4
      node 10.18.1
      nodejs 10.18.1
      Was mache ich falsch?
      $ ./iobroker url "https://github.com/dirkhe/ioBroker.mihome-vacuum.git"
      install https://github.com/dirkhe/ioBroker.mihome-vacuum/tarball/0055cde5fafc5409065c90bca3ac2519fdf68160
      NPM version: 6.13.4
      npm install https://github.com/dirkhe/ioBroker.mihome-vacuum/tarball/0055cde5fafc5409065c90bca3ac2519fdf68160 --loglevel error --prefix "/opt/iobroker" (System call)
      node-aead-crypto is no longer needed on NodeJS 10+
      Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' foundgyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
      gyp
       ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.75-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.18.1gyp ERR! node-gyp -v v5.0.5gyp ERR! not ok
      node-pre-gyp
       ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      node-pre-gyp ERR! System Linux 4.19.75-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.18.1node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
      npm
       ERR! code ELIFECYCLEnpm ERR! errno 1npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the canvas@2.6.1 install script.npm ERR!
       This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-01-19T22_13_38_864Z-debug.log
      ERROR: host.raspi Cannot install https://github.com/dirkhe/ioBroker.mihome-vacuum/tarball/0055cde5fafc5409065c90bca3ac2519fdf68160: 1
      ERROR: process exited with code 25
      • X
        xADDRx @dirkhe last edited by
        @dirkhe habe den adapter mal neugestratet, dann ging es einmal....beim nächsten raum kommt das:should trigger cleaning segment 18, but is currently active. Add to queue und es tut sich nichts
        • X
          @dirkhe und die meldung: 8375) 74 -> data for segment is not a number
            dirkhe Developer @xADDRx last edited by
            @xADDRx Dann ist er noch im Status des reinigens. Wenn du dann den nächsten Raum triggerst, packt er das in eine Queue. bis der status es wieder zulässt, den nächsten zu senden
            X haselchen 2 Replies Last reply Reply Quote 0
              @xADDRx sagte in Adapter mihome-vacuum anpassungen:
              Kannst du mal mehr log schicken, bitte
              • X
                @dirkhe muss er eventuel den raum erst fertig gefahren haben, damit der nächste funktioniert?
                • X
                  xADDRx @dirkhe last edited by xADDRx
                  mihome-vacuum.0	2020-01-19 23:23:29.605	debug	(16163) CLEAN_LOGGING[{"Datum":"19.1","Start":"23:23","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"19.1","Start":"23:22","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":fal
                  mihome-vacuum.0	2020-01-19 23:23:29.429	debug	(16163) Receive <<< {"result":[[1579470392,1579470395,3,0,0,0,2,3]],"id":104}<<< 213100600000000007082f8d5e24d6e14150b0d7af951a27b14ffb5f6ed68afa6881f53ede9e0aa534d00069ff28de8db516c01230c3201cc0fa7de
                  mihome-vacuum.0	2020-01-19 23:23:29.403	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6e2a05f0f89ab64905f72adf4832ba70efdb1cfa9852dff46ff8923f15b24eae3b427c951be00c8dc57925ca38c12d4e6032e291abc26e99e1206d242bb6630a67e95705991f9b9b646b
                  mihome-vacuum.0	2020-01-19 23:23:29.403	debug	(16163) sendMsg >>> {"id":104,"method":"get_clean_record","params":[1579470392]}
                  mihome-vacuum.0	2020-01-19 23:23:29.401	debug	(16163) Timestamp: 5e24d6e2
                  mihome-vacuum.0	2020-01-19 23:23:29.400	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":104,"X_send_command":77,"miIO.info":79,"get_sound_volume":83,"get_carpet_mode":84,"get_room_mapping":17,"se
                  mihome-vacuum.0	2020-01-19 23:23:29.400	debug	(16163) Request log entry: 1579470392
                  mihome-vacuum.0	2020-01-19 23:23:29.214	debug	(16163) Receive <<< {"result":[[1579470405,1579470407,2,0,0,0,2,3]],"id":103}<<< 213100600000000007082f8d5e24d6e1b724bff1c9a2bb4e11ffe418f2573ec96881f53ede9e0aa534d00069ff28de8dc763200087e083204c2d64f
                  mihome-vacuum.0	2020-01-19 23:23:29.198	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6e22b29f0e12edeb6c8aa63a11d4cbfa8dabfabc84fbe5ed99fdbe7bb46e59391e4ddbdc34176c1a3a4a97ff73b7d1e33acee31dd65c9ed7fa9fe2a6d018203dbf265a57e2d86c80f764
                  mihome-vacuum.0	2020-01-19 23:23:29.198	debug	(16163) sendMsg >>> {"id":103,"method":"get_clean_record","params":[1579470405]}
                  mihome-vacuum.0	2020-01-19 23:23:29.197	debug	(16163) Timestamp: 5e24d6e2
                  mihome-vacuum.0	2020-01-19 23:23:29.196	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":103,"X_send_command":77,"miIO.info":79,"get_sound_volume":83,"get_carpet_mode":84,"get_room_mapping":17,"se
                  mihome-vacuum.0	2020-01-19 23:23:29.195	debug	(16163) Request log entry: 1579470405
                  mihome-vacuum.0	2020-01-19 23:23:29.008	debug	(16163) Receive <<< {"result":[[1579470417,1579470420,2,0,0,0,2,3]],"id":102}<<< 213100600000000007082f8d5e24d6e1fc582b52c35268c704183de816f437096881f53ede9e0aa534d00069ff28de8dc80e8454d735b002aef579f
                  mihome-vacuum.0	2020-01-19 23:23:28.995	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6e1b3c2872e52dc19af7e0745467c086dbf6eb89e5fc5d1bd95d8221d58a8635f5c8f426f231983e77d3464baef989e88e5f5b1f2d98d4ee6b36ac64de0f8f919365fd7edb33a9d8e7a0
                  mihome-vacuum.0	2020-01-19 23:23:28.994	debug	(16163) sendMsg >>> {"id":102,"method":"get_clean_record","params":[1579470417]}
                  mihome-vacuum.0	2020-01-19 23:23:28.993	debug	(16163) Timestamp: 5e24d6e1
                  mihome-vacuum.0	2020-01-19 23:23:28.992	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":102,"X_send_command":77,"miIO.info":79,"get_sound_volume":83,"get_carpet_mode":84,"get_room_mapping":17,"se
                  mihome-vacuum.0	2020-01-19 23:23:28.992	debug	(16163) Request log entry: 1579470417
                  mihome-vacuum.0	2020-01-19 23:23:28.860	debug	(16163) Receive <<< {"result":[[1579470427,1579470431,4,0,0,0,2,3]],"id":101}<<< 213100600000000007082f8d5e24d6e1cc52406b82cd10eaad37e8a09485721e6881f53ede9e0aa534d00069ff28de8d224d4a704b516e4514f344b
                  mihome-vacuum.0	2020-01-19 23:23:28.790	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6e189bc6b085dd3473cbde4d42204cf2aba107b4a48a4902432fda48742fd641d6af1a1c2fae739b79b72218ba2c36a7e14b293fab1ff177e80e12bcb7fc217b20565a720ecb52ea0fc5
                  mihome-vacuum.0	2020-01-19 23:23:28.790	debug	(16163) sendMsg >>> {"id":101,"method":"get_clean_record","params":[1579470427]}
                  mihome-vacuum.0	2020-01-19 23:23:28.789	debug	(16163) Timestamp: 5e24d6e1
                  mihome-vacuum.0	2020-01-19 23:23:28.788	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":101,"X_send_command":77,"miIO.info":79,"get_sound_volume":83,"get_carpet_mode":84,"get_room_mapping":17,"se
                  mihome-vacuum.0	2020-01-19 23:23:28.787	debug	(16163) Request log entry: 1579470427
                  mihome-vacuum.0	2020-01-19 23:23:28.598	debug	(16163) Receive <<< {"result":[[1579470441,1579470444,3,0,0,0,2,3]],"id":100}<<< 213100600000000007082f8d5e24d6e0940a1285f88b0366f2f4d875d73425396881f53ede9e0aa534d00069ff28de8d69fde98f7d271188e6c906b
                  mihome-vacuum.0	2020-01-19 23:23:28.585	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6e14f72df2224e964628a357bd63dd0291eb66a8e0334d0e7675369d78d640c87d0ce6d16a37ecccee7336a0d1b64688341b35887d33c9cb3461e388a53817ca19f046739a8f9e84d0f4
                  mihome-vacuum.0	2020-01-19 23:23:28.585	debug	(16163) sendMsg >>> {"id":100,"method":"get_clean_record","params":[1579470441]}
                  mihome-vacuum.0	2020-01-19 23:23:28.584	debug	(16163) Timestamp: 5e24d6e1
                  mihome-vacuum.0	2020-01-19 23:23:28.583	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":100,"X_send_command":77,"miIO.info":79,"get_sound_volume":83,"get_carpet_mode":84,"get_room_mapping":17,"se
                  mihome-vacuum.0	2020-01-19 23:23:28.582	debug	(16163) Request log entry: 1579470441
                  mihome-vacuum.0	2020-01-19 23:23:28.394	debug	(16163) Receive <<< {"result":[[1579470455,1579470458,3,0,0,0,2,3]],"id":99}<<< 213100600000000007082f8d5e24d6e0646f6569cd7b3b34e23a904166d8711c6881f53ede9e0aa534d00069ff28de8d5efcddab7727745d12c2e9ff
                  mihome-vacuum.0	2020-01-19 23:23:28.380	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6e10af0993bb807ddf4813a356aa8de1ccc7d42d8f01015d93d66d35151ffc47a706e11345775ffae12495993df950c6abcd058ef046b4c3fc58faf84384b2bc4214e883cdd2bbc276b5
                  mihome-vacuum.0	2020-01-19 23:23:28.380	debug	(16163) sendMsg >>> {"id":99,"method":"get_clean_record","params":[1579470455]}
                  mihome-vacuum.0	2020-01-19 23:23:28.379	debug	(16163) Timestamp: 5e24d6e1
                  mihome-vacuum.0	2020-01-19 23:23:28.378	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":99,"X_send_command":77,"miIO.info":79,"get_sound_volume":83,"get_carpet_mode":84,"get_room_mapping":17,"set
                  mihome-vacuum.0	2020-01-19 23:23:28.377	debug	(16163) Request log entry: 1579470455
                  mihome-vacuum.0	2020-01-19 23:23:28.227	debug	(16163) Receive <<< {"result":[[1579470494,1579470497,3,0,0,0,2,3]],"id":98}<<< 213100600000000007082f8d5e24d6e08c107d0daa499fc8dfec7a4bbfc55c396881f53ede9e0aa534d00069ff28de8d1061893ab2eaa158c005f19c
                  mihome-vacuum.0	2020-01-19 23:23:28.176	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6e1b3352afce94a707e7d98d1cb2224ff23530a13539b89c239f50502efd9c943c962168d37bbde7825ac39bfb87e0d46d64fa4bad36e5a23f2c3d6d63863aa61698e20bfee55c02c872
                  mihome-vacuum.0	2020-01-19 23:23:28.176	debug	(16163) sendMsg >>> {"id":98,"method":"get_clean_record","params":[1579470494]}
                  mihome-vacuum.0	2020-01-19 23:23:28.175	debug	(16163) Timestamp: 5e24d6e1
                  mihome-vacuum.0	2020-01-19 23:23:28.174	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":98,"X_send_command":77,"miIO.info":79,"get_sound_volume":83,"get_carpet_mode":84,"get_room_mapping":17,"set
                  mihome-vacuum.0	2020-01-19 23:23:28.174	debug	(16163) Request log entry: 1579470494
                  mihome-vacuum.0	2020-01-19 23:23:28.016	debug	(16163) Receive <<< {"result":[[1579470535,1579470539,4,0,0,0,2,3]],"id":97}<<< 213100600000000007082f8d5e24d6e02261a8e495f2fab4167e908328b049ed6881f53ede9e0aa534d00069ff28de8dd2d35e502b5edfd44efea8db
                  mihome-vacuum.0	2020-01-19 23:23:27.972	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6e0b1161e25c5d8b0775447179e3410bc388c7393dc66778ee18b6b644f9aa9da5d0dae55b8c1212553824cf7445e4473a556e9c9340e83f9dcbaa19532004047b924a894c9638bddf1a
                  mihome-vacuum.0	2020-01-19 23:23:27.972	debug	(16163) sendMsg >>> {"id":97,"method":"get_clean_record","params":[1579470535]}
                  mihome-vacuum.0	2020-01-19 23:23:27.971	debug	(16163) Timestamp: 5e24d6e0
                  mihome-vacuum.0	2020-01-19 23:23:27.970	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":97,"X_send_command":77,"miIO.info":79,"get_sound_volume":83,"get_carpet_mode":84,"get_room_mapping":17,"set
                  mihome-vacuum.0	2020-01-19 23:23:27.969	debug	(16163) Request log entry: 1579470535
                  mihome-vacuum.0	2020-01-19 23:23:27.779	debug	(16163) Receive <<< {"result":[[1579470588,1579470591,3,0,0,0,2,3]],"id":96}<<< 213100600000000007082f8d5e24d6e0640b66c789e01c00950935fc17b3bb446881f53ede9e0aa534d00069ff28de8d8ad5bdffa7575d7db2917ef8
                  mihome-vacuum.0	2020-01-19 23:23:27.768	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6e0ab1ea30ea79e0e1285e04055a3fd776f956319f7979d1c3cdb62eae23f9bf21760392a1bafceb513361f00317790266c8b52888d1ecba6aa95f3f568de661b086f85828f7175f9cd3
                  mihome-vacuum.0	2020-01-19 23:23:27.768	debug	(16163) sendMsg >>> {"id":96,"method":"get_clean_record","params":[1579470588]}
                  mihome-vacuum.0	2020-01-19 23:23:27.767	debug	(16163) Timestamp: 5e24d6e0
                  mihome-vacuum.0	2020-01-19 23:23:27.766	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":96,"X_send_command":77,"miIO.info":79,"get_sound_volume":83,"get_carpet_mode":84,"get_room_mapping":17,"set
                  mihome-vacuum.0	2020-01-19 23:23:27.765	debug	(16163) Request log entry: 1579470588
                  mihome-vacuum.0	2020-01-19 23:23:27.593	debug	(16163) Receive <<< {"result":[[1579470604,1579470607,3,0,0,0,2,3]],"id":95}<<< 213100600000000007082f8d5e24d6df15f2ea05fb7d0c02608f7d96d8318f056881f53ede9e0aa534d00069ff28de8dddcdc1daa86942566e22619a
                  mihome-vacuum.0	2020-01-19 23:23:27.565	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6e089ee52952753d408cc91b2daba898d650b01b5a0a08bbc00c2ffa956dde003282994e30d54f64bf131aa5ccef38d7fd8f3f531bdb043dfbd0df7dc0fa7d4ce5df42ad5238e8c54a4e
                  mihome-vacuum.0	2020-01-19 23:23:27.564	debug	(16163) sendMsg >>> {"id":95,"method":"get_clean_record","params":[1579470604]}
                  mihome-vacuum.0	2020-01-19 23:23:27.563	debug	(16163) Timestamp: 5e24d6e0
                  mihome-vacuum.0	2020-01-19 23:23:27.562	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":95,"X_send_command":77,"miIO.info":79,"get_sound_volume":83,"get_carpet_mode":84,"get_room_mapping":17,"set
                  mihome-vacuum.0	2020-01-19 23:23:27.562	debug	(16163) Request log entry: 1579470604
                  mihome-vacuum.0	2020-01-19 23:23:27.380	debug	(16163) Receive <<< {"result":[[1579470618,1579470621,3,0,0,0,2,3]],"id":94}<<< 213100600000000007082f8d5e24d6dfb25455e1398044d5e8422ef71143b06e6881f53ede9e0aa534d00069ff28de8d24a04e8561c626eeba75449d
                  mihome-vacuum.0	2020-01-19 23:23:27.361	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6e0eea9d9e848c92ed27c82b21a5b36887d2fd8325815231b7dfe05507c2381e22ade516c40b9fdaae4e5b1ac81653bcd985805142cfc4d02c0ce1cca3521ec3075dbf2cdd005313c091
                  mihome-vacuum.0	2020-01-19 23:23:27.360	debug	(16163) sendMsg >>> {"id":94,"method":"get_clean_record","params":[1579470618]}
                  mihome-vacuum.0	2020-01-19 23:23:27.359	debug	(16163) Timestamp: 5e24d6e0
                  mihome-vacuum.0	2020-01-19 23:23:27.358	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":94,"X_send_command":77,"miIO.info":79,"get_sound_volume":83,"get_carpet_mode":84,"get_room_mapping":17,"set
                  mihome-vacuum.0	2020-01-19 23:23:27.358	debug	(16163) Request log entry: 1579470618
                  mihome-vacuum.0	2020-01-19 23:23:27.211	debug	(16163) Receive <<< {"result":[[1579470633,1579470635,2,0,0,0,2,3]],"id":93}<<< 213100600000000007082f8d5e24d6df5cf6c65fa8ae35ec941fb17655cda2fb6881f53ede9e0aa534d00069ff28de8d17a727a36f43e42df56f929c
                  mihome-vacuum.0	2020-01-19 23:23:27.156	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6e0ae607a57b8685443313ca44235255009f9a6e1f7afb9b54f4a255559ffbf565fb55e1e539d7b7ebe6ac3fb288c6d31a2607a248be08a0a88b0250ef81374a301bf25e2b8f1ba29d55
                  mihome-vacuum.0	2020-01-19 23:23:27.155	debug	(16163) sendMsg >>> {"id":93,"method":"get_clean_record","params":[1579470633]}
                  mihome-vacuum.0	2020-01-19 23:23:27.153	debug	(16163) Timestamp: 5e24d6e0
                  mihome-vacuum.0	2020-01-19 23:23:27.152	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":93,"X_send_command":77,"miIO.info":79,"get_sound_volume":83,"get_carpet_mode":84,"get_room_mapping":17,"set
                  mihome-vacuum.0	2020-01-19 23:23:27.151	debug	(16163) Request log entry: 1579470633
                  mihome-vacuum.0	2020-01-19 23:23:26.965	debug	(16163) Receive <<< {"result":[[1579470841,1579470843,2,0,0,0,2,1]],"id":92}<<< 213100600000000007082f8d5e24d6dfbafeea8744024e2d171c74fc26c9651f6881f53ede9e0aa534d00069ff28de8df1be2d6aa4bee7922b51767a
                  mihome-vacuum.0	2020-01-19 23:23:26.949	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6df00c0132c26e98fb7bffe9ce7dd72a94e130898fafca0619ad886048103128eadb11e5d2b17666a3ebae667b19b958f1d792e81f2d62ee2e433d1ec663a1e81ec0b0f12f1a526c4596
                  mihome-vacuum.0	2020-01-19 23:23:26.948	debug	(16163) sendMsg >>> {"id":92,"method":"get_clean_record","params":[1579470841]}
                  mihome-vacuum.0	2020-01-19 23:23:26.947	debug	(16163) Timestamp: 5e24d6df
                  mihome-vacuum.0	2020-01-19 23:23:26.946	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":92,"X_send_command":77,"miIO.info":79,"get_sound_volume":83,"get_carpet_mode":84,"get_room_mapping":17,"set
                  mihome-vacuum.0	2020-01-19 23:23:26.946	debug	(16163) Request log entry: 1579470841
                  mihome-vacuum.0	2020-01-19 23:23:26.761	debug	(16163) Receive <<< {"result":[[1579470955,1579470960,4,0,0,0,2,3]],"id":91}<<< 213100600000000007082f8d5e24d6df17b5be3082b3c667e61571cf44276fa86881f53ede9e0aa534d00069ff28de8d60aeca1963ee35504edbee14
                  mihome-vacuum.0	2020-01-19 23:23:26.744	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6dff2f58a51224e306e8014e3c49916feeb828b6c334e716bb05c3d55c3311f53a5e95fa07a96d5d88d1e61fcf82a177b61acfe3abc79f52e5b5a732b462ba819b1b711a5203586cb69a
                  mihome-vacuum.0	2020-01-19 23:23:26.744	debug	(16163) sendMsg >>> {"id":91,"method":"get_clean_record","params":[1579470955]}
                  mihome-vacuum.0	2020-01-19 23:23:26.743	debug	(16163) Timestamp: 5e24d6df
                  mihome-vacuum.0	2020-01-19 23:23:26.742	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":91,"X_send_command":77,"miIO.info":79,"get_sound_volume":83,"get_carpet_mode":84,"get_room_mapping":17,"set
                  mihome-vacuum.0	2020-01-19 23:23:26.741	debug	(16163) Request log entry: 1579470955
                  mihome-vacuum.0	2020-01-19 23:23:26.564	debug	(16163) Receive <<< {"result":[[1579470964,1579470966,1,0,0,0,2,1]],"id":90}<<< 213100600000000007082f8d5e24d6dee8c263050833c42d329a3e4202ff17e26881f53ede9e0aa534d00069ff28de8d78ced62bc8773b9af651f961
                  mihome-vacuum.0	2020-01-19 23:23:26.540	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6dfaed773ebb949064dca07044a98ccd10c4931f714f6f1170d45aba8130ae75d2bbc4c2a45b2530894b6c22e9ed77e2eaa25cc2a970c9fcfa5e27becea465090f16f9118ba6d0ee14b5
                  mihome-vacuum.0	2020-01-19 23:23:26.539	debug	(16163) sendMsg >>> {"id":90,"method":"get_clean_record","params":[1579470964]}
                  mihome-vacuum.0	2020-01-19 23:23:26.536	debug	(16163) Timestamp: 5e24d6df
                  mihome-vacuum.0	2020-01-19 23:23:26.535	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":90,"X_send_command":77,"miIO.info":79,"get_sound_volume":83,"get_carpet_mode":84,"get_room_mapping":17,"set
                  mihome-vacuum.0	2020-01-19 23:23:26.534	debug	(16163) Request log entry: 1579470964
                  mihome-vacuum.0	2020-01-19 23:23:26.360	debug	(16163) Receive <<< {"result":[[1579470976,1579470981,5,0,0,0,2,3]],"id":89}<<< 213100600000000007082f8d5e24d6de96ebc7286ab37eecea16f2c14e21d3fc6881f53ede9e0aa534d00069ff28de8d8959eccc1e315c93f31947a7
                  mihome-vacuum.0	2020-01-19 23:23:26.332	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6df3af1195e35f41edaaef8aebdb4d70e146a212788339674d2533f8b02e7d64e7f3eff0eb6a3806cd6a925b35c0b58c442aa1409eb61c5b3bfb961df430d634b42bf524a326d69ce63a
                  mihome-vacuum.0	2020-01-19 23:23:26.332	debug	(16163) sendMsg >>> {"id":89,"method":"get_clean_record","params":[1579470976]}
                  mihome-vacuum.0	2020-01-19 23:23:26.330	debug	(16163) Timestamp: 5e24d6df
                  mihome-vacuum.0	2020-01-19 23:23:26.330	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":89,"X_send_command":77,"miIO.info":79,"get_sound_volume":83,"get_carpet_mode":84,"get_room_mapping":17,"set
                  mihome-vacuum.0	2020-01-19 23:23:26.329	debug	(16163) Request log entry: 1579470976
                  mihome-vacuum.0	2020-01-19 23:23:26.141	debug	(16163) Receive <<< {"result":[[1579472094,1579472096,2,0,0,0,2,3]],"id":88}<<< 213100600000000007082f8d5e24d6de8eaef502b1ebcc8e45c9378889b15aa66881f53ede9e0aa534d00069ff28de8df26b34405d6d5f934d8f14b7
                  mihome-vacuum.0	2020-01-19 23:23:26.128	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6df3bc92e5a493fed8e634f59b00e05103b2cb56e55ad4d852e0a6d7b3fd4f1860d2387ef74f9b0837914cea65ae49af95b913eb03fe6609eba0b2baa169d8c7709bc4a2cae85b705cf8
                  mihome-vacuum.0	2020-01-19 23:23:26.127	debug	(16163) sendMsg >>> {"id":88,"method":"get_clean_record","params":[1579472094]}
                  mihome-vacuum.0	2020-01-19 23:23:26.126	debug	(16163) Timestamp: 5e24d6df
                  mihome-vacuum.0	2020-01-19 23:23:26.125	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":88,"X_send_command":77,"miIO.info":79,"get_sound_volume":83,"get_carpet_mode":84,"get_room_mapping":17,"set
                  mihome-vacuum.0	2020-01-19 23:23:26.125	debug	(16163) Request log entry: 1579472094
                  mihome-vacuum.0	2020-01-19 23:23:25.940	debug	(16163) Receive <<< {"result":[[1579472394,1579472397,3,0,0,0,2,3]],"id":87}<<< 213100600000000007082f8d5e24d6def008d05f23e40602eb3595765cbe08d96881f53ede9e0aa534d00069ff28de8d94c1299bab3e064e65856349
                  mihome-vacuum.0	2020-01-19 23:23:25.923	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6def9a731c8cef6725e3e91019d902e5c361d2c75a111836c3a19b2926302889777e69839bef6721814fad3571ef3cb8cb5bed0ed13251d480140edac11570800320b71af7b9272a89f1
                  mihome-vacuum.0	2020-01-19 23:23:25.923	debug	(16163) sendMsg >>> {"id":87,"method":"get_clean_record","params":[1579472394]}
                  mihome-vacuum.0	2020-01-19 23:23:25.922	debug	(16163) Timestamp: 5e24d6de
                  mihome-vacuum.0	2020-01-19 23:23:25.921	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":87,"X_send_command":77,"miIO.info":79,"get_sound_volume":83,"get_carpet_mode":84,"get_room_mapping":17,"set
                  mihome-vacuum.0	2020-01-19 23:23:25.919	debug	(16163) Request log entry: 1579472394
                  mihome-vacuum.0	2020-01-19 23:23:25.734	debug	(16163) Receive <<< {"result":[[1579472546,1579472552,5,0,0,0,2,3]],"id":86}<<< 213100600000000007082f8d5e24d6de48ac708742e0776b9c10ca7eb044fecf6881f53ede9e0aa534d00069ff28de8d935447f867ae53e5fbd6825e
                  mihome-vacuum.0	2020-01-19 23:23:25.718	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6de1c6fd305fb15d2cbd900d0619516a145f33c28e758536390ff0160f98fa6f4d2f9ffa3caf37a9264d99832d23145dd648183d226e7c8ac88665770876c85ea8095cc510354e4bdf8f
                  mihome-vacuum.0	2020-01-19 23:23:25.717	debug	(16163) sendMsg >>> {"id":86,"method":"get_clean_record","params":[1579472546]}
                  mihome-vacuum.0	2020-01-19 23:23:25.716	debug	(16163) Timestamp: 5e24d6de
                  mihome-vacuum.0	2020-01-19 23:23:25.715	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":86,"X_send_command":77,"miIO.info":79,"get_sound_volume":83,"get_carpet_mode":84,"get_room_mapping":17,"set
                  mihome-vacuum.0	2020-01-19 23:23:25.715	debug	(16163) Request log entry: 1579472546
                  mihome-vacuum.0	2020-01-19 23:23:25.539	debug	(16163) Receive <<< {"result":[[1579472598,1579472601,2,0,0,0,2,3]],"id":85}<<< 213100600000000007082f8d5e24d6dd701f91fbb26b0ccb367cfd332f1547786881f53ede9e0aa534d00069ff28de8dc7cb876e08d97f1989c4abe2
                  mihome-vacuum.0	2020-01-19 23:23:25.513	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6def7dfb0b3c8589ab75d8779e21e1e220f7e9b55566744c9b56afbfb81275bd73dc5839cc261f22ac44df831d0bbb2cdca2d05a0dd8a40f52326aad18dfd8cbea333e982b1d65d2ccfb
                  mihome-vacuum.0	2020-01-19 23:23:25.513	debug	(16163) sendMsg >>> {"id":85,"method":"get_clean_record","params":[1579472598]}
                  mihome-vacuum.0	2020-01-19 23:23:25.511	debug	(16163) Timestamp: 5e24d6de
                  mihome-vacuum.0	2020-01-19 23:23:25.510	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":85,"X_send_command":77,"miIO.info":79,"get_sound_volume":83,"get_carpet_mode":84,"get_room_mapping":17,"set
                  mihome-vacuum.0	2020-01-19 23:23:25.510	debug	(16163) Request log entry: 1579472598
                  mihome-vacuum.0	2020-01-19 23:23:25.340	debug	(16163) Receive <<< {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":84}<<< 213100900000000007082f8d5e24d6ddcaad673873e5b3670319048aad281651f0c
                  mihome-vacuum.0	2020-01-19 23:23:25.308	debug	(16163) sendMsgRaw >>> 213100500000000007082f8d5e24d6de86eefc49c7e94bd7a3523c80b968e1a738d5cf44af38b8ad45cf1b390056191ad2732e42bfcd5272e04f47b37eec10a776614f50f3259936af189cf64462bc7d
                  mihome-vacuum.0	2020-01-19 23:23:25.307	debug	(16163) sendMsg >>> {"id":84,"method":"get_carpet_mode"}
                  mihome-vacuum.0	2020-01-19 23:23:25.306	debug	(16163) Timestamp: 5e24d6de
                  mihome-vacuum.0	2020-01-19 23:23:25.305	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":59,"X_send_command":77,"miIO.info":79,"get_sound_volume":83,"get_carpet_mode":84,"get_room_mapping":17,"set
                  mihome-vacuum.0	2020-01-19 23:23:25.119	debug	(16163) Receive <<< {"result":[52],"id":83}<<< 213100400000000007082f8d5e24d6dd74a6c823212470b263e192d4060e65d736a04fa82e4d0c0f83d6ff60135ccbc54a52ae6164975fd71595fda49dc0fc24
                  mihome-vacuum.0	2020-01-19 23:23:25.105	debug	(16163) sendMsgRaw >>> 213100500000000007082f8d5e24d6deaaf6d7557f40832a90e00a42c87f09308f4321c03e595733e4076a931df80a29019a059629c2bbb7af51dd42816297f718c70c1ae76873503a95e720aed9717f
                  mihome-vacuum.0	2020-01-19 23:23:25.104	debug	(16163) sendMsg >>> {"id":83,"method":"get_sound_volume"}
                  mihome-vacuum.0	2020-01-19 23:23:25.103	debug	(16163) Timestamp: 5e24d6de
                  mihome-vacuum.0	2020-01-19 23:23:25.102	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":59,"X_send_command":77,"miIO.info":79,"get_sound_volume":83,"get_carpet_mode":75,"get_room_mapping":17,"set
                  mihome-vacuum.0	2020-01-19 23:23:24.993	debug	(16163) Receive <<< {"result":[430637,6466027500,567,[1579472598,1579472546,1579472394,1579472094,1579470976,1579470964,1579470955,1579470841,1579470633,1579470618,1579470604,1579470588,1579470535,157
                  mihome-vacuum.0	2020-01-19 23:23:24.900	debug	(16163) sendMsgRaw >>> 213100500000000007082f8d5e24d6dde1f8b96c16541eb81c3a554619e56d1f6cdf753f4aa92b8f5bfa6a9d2d985eb582d923f949c2638bfbaa491b94ce811674ab2d2c44d0994616051b7197397788
                  mihome-vacuum.0	2020-01-19 23:23:24.900	debug	(16163) sendMsg >>> {"id":82,"method":"get_clean_summary"}
                  mihome-vacuum.0	2020-01-19 23:23:24.898	debug	(16163) Timestamp: 5e24d6dd
                  mihome-vacuum.0	2020-01-19 23:23:24.897	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":82,"get_clean_record":59,"X_send_command":77,"miIO.info":79,"get_sound_volume":73,"get_carpet_mode":75,"get_room_mapping":17,"set
                  mihome-vacuum.0	2020-01-19 23:23:24.896	error	(16163) [81](unknown) -> data for segment is not a number
                  mihome-vacuum.0	2020-01-19 23:23:24.895	debug	(16163) Receive <<< {"error":{"code":-10000,"message":"data for segment is not a number"},"id":81}<<< 213100700000000007082f8d5e24d6dd1b252718f937103bf578bd7c06c0de3250f7a040a62432ae34747f8cc7a80808ba
                  mihome-vacuum.0	2020-01-19 23:23:24.881	debug	(16163) Receive <<< {"result":[{"main_brush_work_time":35451,"side_brush_work_time":67178,"filter_work_time":35451,"filter_element_work_time":0,"sensor_dirty_time":67143}],"id":80}<<< 213100d000000000
                  mihome-vacuum.0	2020-01-19 23:23:24.864	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6dd2e09f9211e67f7ece2552f0ff029f13579bdd4154a35f7592ead62028ba91cc5099c50918d622a207fb758e01af66e6ff293e0a2bdc03ad2801ccec8a95e35b7b3f825bee02df56d9
                  mihome-vacuum.0	2020-01-19 23:23:24.864	debug	(16163) sendMsg >>> {"id":81,"method":"app_segment_clean","params":["17"]}
                  mihome-vacuum.0	2020-01-19 23:23:24.863	debug	(16163) Timestamp: 5e24d6dd
                  mihome-vacuum.0	2020-01-19 23:23:24.862	info	(16163) trigger cleaning segment 17
                  mihome-vacuum.0	2020-01-19 23:23:24.861	debug	(16163) use clean trigger from Queue
                  mihome-vacuum.0	2020-01-19 23:23:24.859	debug	(16163) Receive <<< {"result":[{"msg_ver":3,"msg_seq":5175,"state":8,"battery":100,"clean_time":2,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
                  mihome-vacuum.0	2020-01-19 23:23:24.735	debug	(16163) Receive <<< {"partner_id":"","id":79,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.7_002008","ap":{"ssid":"FritzBox 6590","bssid":"F4:06:8D:86:0B:71","rssi":-75},"netif":{"l
                  mihome-vacuum.0	2020-01-19 23:23:24.732	debug	(16163) Receive <<< Helo <<< 213100200000000007082f8d5e24d6ddffffffffffffffffffffffffffffffff
                  mihome-vacuum.0	2020-01-19 23:23:24.696	debug	(16163) sendMsgRaw >>> 213100500000000007082f8d5e24d6dc2107d2902e7600c57ccd895dfe9b3c1b06191759faeabd6c58027e752ab8ef5512e69acdfec67d08d8e4a3c0bad89444ef8ce2621922ba8fbc06246d1a6e49a1
                  mihome-vacuum.0	2020-01-19 23:23:24.695	debug	(16163) sendMsg >>> {"id":80,"method":"get_consumable"}
                  mihome-vacuum.0	2020-01-19 23:23:24.694	debug	(16163) Timestamp: 5e24d6dc
                  mihome-vacuum.0	2020-01-19 23:23:24.693	debug	(16163) lastid{"get_status":78,"get_consumable":80,"get_clean_summary":72,"get_clean_record":59,"X_send_command":77,"miIO.info":79,"get_sound_volume":73,"get_carpet_mode":75,"get_room_mapping":17,"set
                  mihome-vacuum.0	2020-01-19 23:23:24.492	debug	(16163) sendMsgRaw >>> 213100400000000007082f8d5e24d6dce443c5c7f8c34e2053cb0b2b7f5a5ac811c6d44f4c9d4cc3049508ce7e05fa5a26ed91ac46433ebfc7f8aee2a0815e03
                  mihome-vacuum.0	2020-01-19 23:23:24.491	debug	(16163) sendMsg >>> {"id":79,"method":"miIO.info"}
                  mihome-vacuum.0	2020-01-19 23:23:24.490	debug	(16163) Timestamp: 5e24d6dc
                  mihome-vacuum.0	2020-01-19 23:23:24.489	debug	(16163) lastid{"get_status":78,"get_consumable":71,"get_clean_summary":72,"get_clean_record":59,"X_send_command":77,"miIO.info":79,"get_sound_volume":73,"get_carpet_mode":75,"get_room_mapping":17,"set
                  mihome-vacuum.0	2020-01-19 23:23:24.288	debug	(16163) sendMsgRaw >>> 213100400000000007082f8d5e24d6dceef127f57d10ddb509c0867379ceab2ddde532320c6f163f3ffdf876ca0c2161d3b1fd0a7229388b842f72f55006fd23
                  mihome-vacuum.0	2020-01-19 23:23:24.288	debug	(16163) sendMsg >>> {"id":78,"method":"get_status"}
                  mihome-vacuum.0	2020-01-19 23:23:24.287	debug	(16163) Timestamp: 5e24d6dc
                  mihome-vacuum.0	2020-01-19 23:23:24.286	debug	(16163) lastid{"get_status":78,"get_consumable":71,"get_clean_summary":72,"get_clean_record":59,"X_send_command":77,"miIO.info":70,"get_sound_volume":73,"get_carpet_mode":75,"get_room_mapping":17,"set
                  mihome-vacuum.0	2020-01-19 23:23:24.285	debug	(16163) requesting params every: 60 Sec
                  mihome-vacuum.0	2020-01-19 23:23:23.940	debug	(16163) system.adapter.admin.0: logging true
                  synology.0	2020-01-19 23:23:23.930	debug	(903) system.adapter.admin.0: logging true
                  mihome-vacuum.0	2020-01-19 23:23:22.008	debug	(16163) system.adapter.admin.0: logging false
                  synology.0	2020-01-19 23:23:21.996	debug	(903) system.adapter.admin.0: logging false
                  mihome-vacuum.0	2020-01-19 23:23:17.978	debug	(16163) Receive <<< {"result":["ok"],"id":77}<<< 213100400000000007082f8d5e24d6d64793098ccc4b51aa7d939d330bdba486f0220de36dc99b989f0bcc1812f5b27d46fa92f78fbddfd4a1f9b7bc2a5e185d
                  mihome-vacuum.0	2020-01-19 23:23:17.932	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6d548af150ee9dc7d1c59c50e21d07354e20ba20365ea09e2b6f6db33af32ad65a1ba67718e7fc3a5a78c3978ac7ccd215f537e184806a90d9c39da24a6d9f1d39b9d1b0b8bcf2c1b8f
                  mihome-vacuum.0	2020-01-19 23:23:17.932	debug	(16163) sendMsg >>> {"id":77,"method":"app_segment_clean","params":[17]}
                  mihome-vacuum.0	2020-01-19 23:23:17.931	debug	(16163) Timestamp: 5e24d6d5
                  mihome-vacuum.0	2020-01-19 23:23:17.930	debug	(16163) lastid{"get_status":68,"get_consumable":71,"get_clean_summary":72,"get_clean_record":59,"X_send_command":77,"miIO.info":70,"get_sound_volume":73,"get_carpet_mode":75,"get_room_mapping":17,"se
                  mihome-vacuum.0	2020-01-19 23:23:17.930	info	(16163) send message: Method: app_segment_clean Params: [17]
                  mihome-vacuum.0	2020-01-19 23:23:17.929	debug	(16163) stateChange mihome-vacuum.0.control.X_send_command {"val":"app_segment_clean;[17]","ack":false,"ts":1579472597925,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1579471
                  mihome-vacuum.0	2020-01-19 23:23:05.183	debug	(16163) Receive <<< {"result":["ok"],"id":76}<<< 213100400000000007082f8d5e24d6c991d9080b1a741ec6354126f61fcd9a5cf0220de36dc99b989f0bcc1812f5b27d4b91bb590842a218a4289a11a98f1a9c
                  mihome-vacuum.0	2020-01-19 23:23:05.173	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6c92f07962eca5473d775eefefa5d7e81b1d65614de9f16eb9ce0ada3f10a390ed688dfb1335515ca079b380351fb78666308921292db3e8df3a0397ffdfa69dcaf686109202a75510b
                  mihome-vacuum.0	2020-01-19 23:23:05.172	debug	(16163) sendMsg >>> {"id":76,"method":"set_custom_mode","params":[101]}
                  mihome-vacuum.0	2020-01-19 23:23:05.171	debug	(16163) Timestamp: 5e24d6c9
                  mihome-vacuum.0	2020-01-19 23:23:05.170	debug	(16163) lastid{"get_status":68,"get_consumable":71,"get_clean_summary":72,"get_clean_record":59,"X_send_command":74,"miIO.info":70,"get_sound_volume":73,"get_carpet_mode":75,"get_room_mapping":17,"se
                  mihome-vacuum.0	2020-01-19 23:23:05.169	debug	(16163) stateChange mihome-vacuum.0.control.fan_power {"val":101,"ack":false,"ts":1579472585165,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1579465582283}
                  mihome-vacuum.0	2020-01-19 23:23:05.163	info	(16163) should trigger cleaning segment 17, but is currently active. Add to queue
                  mihome-vacuum.0	2020-01-19 23:23:05.161	debug	(16163) sendTo "cleanSegments" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0: 17
                  mihome-vacuum.0	2020-01-19 23:23:05.159	debug	(16163) stateChange mihome-vacuum.0.rooms.manual_17.roomClean {"val":true,"ack":false,"ts":1579472585155,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1579471395915}
                  mihome-vacuum.0	2020-01-19 23:23:04.298	debug	(16163) Receive <<< Helo <<< 213100200000000007082f8d5e24d6c8ffffffffffffffffffffffffffffffff
                  mihome-vacuum.0	2020-01-19 23:22:44.309	debug	(16163) Receive <<< Helo <<< 213100200000000007082f8d5e24d6b4ffffffffffffffffffffffffffffffff
                  mihome-vacuum.0	2020-01-19 23:22:38.176	debug	(16163) system.adapter.admin.0: logging true
                  synology.0	2020-01-19 23:22:38.168	debug	(903) system.adapter.admin.0: logging true
                  mihome-vacuum.0	2020-01-19 23:22:30.174	debug	(16163) system.adapter.admin.0: logging false
                  synology.0	2020-01-19 23:22:30.164	debug	(903) system.adapter.admin.0: logging false
                  mihome-vacuum.0	2020-01-19 23:22:25.338	debug	(16163) Receive <<< {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":75}<<< 213100900000000007082f8d5e24d6a1225d7a80d144911849529d5349dd7971f0
                  mihome-vacuum.0	2020-01-19 23:22:25.312	debug	(16163) sendMsgRaw >>> 213100500000000007082f8d5e24d6a1e7b5405c24332c8d38c49b75110726921bf8499ca1537e2edd33a5555af2203fe5b4263cd1e5ca36e4c4e0ae6367935782380289e097049138a5ae07888e08dc
                  mihome-vacuum.0	2020-01-19 23:22:25.312	debug	(16163) sendMsg >>> {"id":75,"method":"get_carpet_mode"}
                  mihome-vacuum.0	2020-01-19 23:22:25.310	debug	(16163) Timestamp: 5e24d6a1
                  mihome-vacuum.0	2020-01-19 23:22:25.308	debug	(16163) lastid{"get_status":68,"get_consumable":71,"get_clean_summary":72,"get_clean_record":59,"X_send_command":74,"miIO.info":70,"get_sound_volume":73,"get_carpet_mode":75,"get_room_mapping":17,"se
                  mihome-vacuum.0	2020-01-19 23:22:25.266	debug	(16163) Receive <<< {"result":["ok"],"id":74}<<< 213100400000000007082f8d5e24d6a1819a6ae5d0ae80a275eb52dd0e949e8bf0220de36dc99b989f0bcc1812f5b27d77ee61be57c3fd393ae2a60e7c25ff9d
                  mihome-vacuum.0	2020-01-19 23:22:25.236	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6a17f7504af6ba848548965869e560dc9a6d8c01623f64e09803926c51a2cea3df51f02cb15a7054934984d2d9cb6f7fdb1d371c1606b8674afa9d9d8be915634e467da15144299d190
                  mihome-vacuum.0	2020-01-19 23:22:25.235	debug	(16163) sendMsg >>> {"id":74,"method":"app_segment_clean","params":[17]}
                  mihome-vacuum.0	2020-01-19 23:22:25.234	debug	(16163) Timestamp: 5e24d6a1
                  mihome-vacuum.0	2020-01-19 23:22:25.233	debug	(16163) lastid{"get_status":68,"get_consumable":71,"get_clean_summary":72,"get_clean_record":59,"X_send_command":74,"miIO.info":70,"get_sound_volume":73,"get_carpet_mode":66,"get_room_mapping":17,"se
                  mihome-vacuum.0	2020-01-19 23:22:25.232	info	(16163) send message: Method: app_segment_clean Params: [17]
                  mihome-vacuum.0	2020-01-19 23:22:25.231	debug	(16163) stateChange mihome-vacuum.0.control.X_send_command {"val":"app_segment_clean;[17]","ack":false,"ts":1579472545228,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1579471
                  mihome-vacuum.0	2020-01-19 23:22:25.119	debug	(16163) Receive <<< {"result":[52],"id":73}<<< 213100400000000007082f8d5e24d6a1bd60b6c3cabcf4488458012477563e1636a04fa82e4d0c0f83d6ff60135ccbc5636d7bb5aa84f99bf3700901ccfe0f7e
                  mihome-vacuum.0	2020-01-19 23:22:25.108	debug	(16163) sendMsgRaw >>> 213100500000000007082f8d5e24d6a1c8790084d2d7a6c9d79bfae007ae76d6ee5ef799fd83b9f68b794b5660f0d8e711591a50f40bb14614a0ae1fa8039492a3e745ecfc7a78bfc63cbf76b92e70ff
                  mihome-vacuum.0	2020-01-19 23:22:25.107	debug	(16163) sendMsg >>> {"id":73,"method":"get_sound_volume"}
                  mihome-vacuum.0	2020-01-19 23:22:25.106	debug	(16163) Timestamp: 5e24d6a1
                  mihome-vacuum.0	2020-01-19 23:22:25.105	debug	(16163) lastid{"get_status":68,"get_consumable":71,"get_clean_summary":72,"get_clean_record":59,"X_send_command":30,"miIO.info":70,"get_sound_volume":73,"get_carpet_mode":66,"get_room_mapping":17,"se
                  mihome-vacuum.0	2020-01-19 23:22:24.968	debug	(16163) Receive <<< {"result":[430630,6466027500,565,[1579472394,1579472094,1579470976,1579470964,1579470955,1579470841,1579470633,1579470618,1579470604,1579470588,1579470535,1579470494,1579470455,15
                  mihome-vacuum.0	2020-01-19 23:22:24.903	debug	(16163) sendMsgRaw >>> 213100500000000007082f8d5e24d6a045f38722dd7e42d52db4d65032a1204ae8628837bb666121ef9d0ff39b3d5a75b3c976ba38bdc1220ffc467ae2218576fccd73fa6f0662b3c029aed27d4bffff
                  mihome-vacuum.0	2020-01-19 23:22:24.903	debug	(16163) sendMsg >>> {"id":72,"method":"get_clean_summary"}
                  mihome-vacuum.0	2020-01-19 23:22:24.901	debug	(16163) Timestamp: 5e24d6a0
                  mihome-vacuum.0	2020-01-19 23:22:24.900	debug	(16163) lastid{"get_status":68,"get_consumable":71,"get_clean_summary":72,"get_clean_record":59,"X_send_command":30,"miIO.info":70,"get_sound_volume":65,"get_carpet_mode":66,"get_room_mapping":17,"se
                  mihome-vacuum.0	2020-01-19 23:22:24.726	debug	(16163) Receive <<< {"result":[{"main_brush_work_time":35444,"side_brush_work_time":67171,"filter_work_time":35444,"filter_element_work_time":0,"sensor_dirty_time":67136}],"id":71}<<< 213100d00000000
                  mihome-vacuum.0	2020-01-19 23:22:24.700	debug	(16163) sendMsgRaw >>> 213100500000000007082f8d5e24d6a038208daf84118fb0945d9907612ef2b85c205c1adb3270c85d2846faf7ebf4b418cc0f542d83b4cb9c956c372e9eee00c1034ae5a4fb0557bbdbb01fee11fc1d
                  mihome-vacuum.0	2020-01-19 23:22:24.699	debug	(16163) sendMsg >>> {"id":71,"method":"get_consumable"}
                  mihome-vacuum.0	2020-01-19 23:22:24.698	debug	(16163) Timestamp: 5e24d6a0
                  mihome-vacuum.0	2020-01-19 23:22:24.697	debug	(16163) lastid{"get_status":68,"get_consumable":71,"get_clean_summary":64,"get_clean_record":59,"X_send_command":30,"miIO.info":70,"get_sound_volume":65,"get_carpet_mode":66,"get_room_mapping":17,"se
                  mihome-vacuum.0	2020-01-19 23:22:24.503	debug	(16163) Receive <<< {"partner_id":"","id":70,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.7_002008","ap":{"ssid":"FritzBox 6590","bssid":"F4:06:8D:86:0B:71","rssi":-75},"netif":{"
                  mihome-vacuum.0	2020-01-19 23:22:24.495	debug	(16163) sendMsgRaw >>> 213100400000000007082f8d5e24d6a0350a63bff5bd3cce3bbda4b31bf442c68823423eb000adc9feba9bd993debc15e19b981517b268dec819f4ac20f0513b
                  mihome-vacuum.0	2020-01-19 23:22:24.494	debug	(16163) sendMsg >>> {"id":70,"method":"miIO.info"}
                  mihome-vacuum.0	2020-01-19 23:22:24.493	debug	(16163) Timestamp: 5e24d6a0
                  mihome-vacuum.0	2020-01-19 23:22:24.492	debug	(16163) lastid{"get_status":68,"get_consumable":63,"get_clean_summary":64,"get_clean_record":59,"X_send_command":30,"miIO.info":70,"get_sound_volume":65,"get_carpet_mode":66,"get_room_mapping":17,"se
                  mihome-vacuum.0	2020-01-19 23:22:24.341	error	(16163) [69](unknown) -> data for segment is not a number
                  mihome-vacuum.0	2020-01-19 23:22:24.340	debug	(16163) Receive <<< {"error":{"code":-10000,"message":"data for segment is not a number"},"id":69}<<< 213100700000000007082f8d5e24d6a0f7c7eedd1443340dc417d777b6c27c9b50f7a040a62432ae34747f8cc7a80808b
                  mihome-vacuum.0	2020-01-19 23:22:24.329	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d6a08fa0c11367bd3d7b9ab48d19d55a66480a5621157be49141cb6f0ede36adfcb096769d8afc44cc79de2189d1aee9dd6dc1368a4e67b8943322b79ba4f7e690c9ed5155e0da397836
                  mihome-vacuum.0	2020-01-19 23:22:24.329	debug	(16163) sendMsg >>> {"id":69,"method":"app_segment_clean","params":["17"]}
                  mihome-vacuum.0	2020-01-19 23:22:24.328	debug	(16163) Timestamp: 5e24d6a0
                  mihome-vacuum.0	2020-01-19 23:22:24.327	info	(16163) trigger cleaning segment 17
                  mihome-vacuum.0	2020-01-19 23:22:24.326	debug	(16163) use clean trigger from Queue
                  mihome-vacuum.0	2020-01-19 23:22:24.324	debug	(16163) Receive <<< {"result":[{"msg_ver":3,"msg_seq":5116,"state":8,"battery":100,"clean_time":3,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"la
                  mihome-vacuum.0	2020-01-19 23:22:24.322	debug	(16163) Receive <<< Helo <<< 213100200000000007082f8d5e24d6a0ffffffffffffffffffffffffffffffff
                  mihome-vacuum.0	2020-01-19 23:22:24.290	debug	(16163) sendMsgRaw >>> 213100400000000007082f8d5e24d6a0938ba539e7d548b2d736362226dfcb89ca89a2ea9f24c442a58254e9d41097e0cb2135a4abf6cc42af6fddb9e7f73c64
                  mihome-vacuum.0	2020-01-19 23:22:24.288	debug	(16163) sendMsg >>> {"id":68,"method":"get_status"}
                  mihome-vacuum.0	2020-01-19 23:22:24.287	debug	(16163) Timestamp: 5e24d6a0
                  mihome-vacuum.0	2020-01-19 23:22:24.286	debug	(16163) lastid{"get_status":68,"get_consumable":63,"get_clean_summary":64,"get_clean_record":59,"X_send_command":30,"miIO.info":62,"get_sound_volume":65,"get_carpet_mode":66,"get_room_mapping":17,"se
                  mihome-vacuum.0	2020-01-19 23:22:24.285	debug	(16163) requesting params every: 60 Sec
                  mihome-vacuum.0	2020-01-19 23:22:07.095	debug	(16163) Receive <<< {"result":["ok"],"id":67}<<< 213100400000000007082f8d5e24d68f0d34112f0db189551720acc87390dd21f0220de36dc99b989f0bcc1812f5b27d94b4cb15e63861a9973688d905493ed1
                  mihome-vacuum.0	2020-01-19 23:22:07.083	debug	(16163) sendMsgRaw >>> 213100600000000007082f8d5e24d68f27a9763b163593bd3198f2449a5946fd868d5cddb1e451a16e2ab909908e578518cbeb54612796b332ce7dbb88cb3f73e4a20bb19635895b978ec988f590a5c37ac81d928d3d8dba
                  mihome-vacuum.0	2020-01-19 23:22:07.082	debug	(16163) sendMsg >>> {"id":67,"method":"set_custom_mode","params":[101]}
                  mihome-vacuum.0	2020-01-19 23:22:07.081	debug	(16163) Timestamp: 5e24d68f
                  mihome-vacuum.0	2020-01-19 23:22:07.080	debug	(16163) lastid{"get_status":60,"get_consumable":63,"get_clean_summary":64,"get_clean_record":59,"X_send_command":30,"miIO.info":62,"get_sound_volume":65,"get_carpet_mode":66,"get_room_mapping":17,"se
                  mihome-vacuum.0	2020-01-19 23:22:07.080	debug	(16163) stateChange mihome-vacuum.0.control.fan_power {"val":101,"ack":false,"ts":1579472527076,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1579465582283}
                  mihome-vacuum.0	2020-01-19 23:22:07.029	info	(16163) should trigger cleaning segment 17, but is currently active. Add to queue
                  mihome-vacuum.0	2020-01-19 23:22:07.025	debug	(16163) sendTo "cleanSegments" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0: 17
                  mihome-vacuum.0	2020-01-19 23:22:07.022	debug	(16163) stateChange mihome-vacuum.0.rooms.manual_17.roomClean {"val":true,"ack":false,"ts":1579472527018,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1579471395915}
                  mit app_segment_clean;[17] über send command geht es, nur nicht mit der erstellten index nummer
                    dirkhe Developer @magiczoom last edited by
                    @magiczoom Zuerst benutzte mal den aktuellen Adapter https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum, bzw. über die Katzte und dann aus github den offiziellen Adapter auswählen, siehe auch weiter Post oben
                    Das ander sieht eher wieder wie ein Problem aus, dass der Raspi was eigene installiert braucht, für die canvas in Valetudo,schau mal hier https://forum.iobroker.net/post/355086
                      @xADDRx auf ein neues.....
                      • X
                        @dirkhe keine Fehler mehr, sieht gut aus. muss jetzt noch die Räume finden...komischer weise zeigt er mir nun bei jeder Zahl den gleichen raum an.... denke aber das liegt nicht am adapter... Vielen Dank!!!!
                          ple last edited by
                          Geht der Apater eigentlich auch mit dem New-Xiaomi-Mijia-2-in-1-Robot-Vacuum-Mop-Vacuum-Cleaner ???
                          Der läuft gerade bei mir, aber zufrieden bin ich damit nicht wegen dem Akku.
                          Habe mir gerade noch mal den S55 bestellt.
                          Den kann man bestimmt immer noch nicht am Mainland Server anmelden, oder?
                          Sonst müsste ich den wieder rooten und die cfg Datei löschen, aber dann ist es wieder vorbei mit updates direkt über die Xiaomi app.
                            dirkhe Developer @ple last edited by
                            @ple am besten testen. Wenn dann irgendwelche Parameter nicht passen, müssen wir die anpassen
                              ple last edited by
                              Ok, bis jetzt wüsste ich nicht mal wie ich an den Token kommen sollte. Müsste morgen mal auf ne Android Handy testen ob der überhaupt ausgespuckt wird. Fraglich ist dann immer noch was der so sendet.
                              Bin ich der einzige der den hat? Oder ist hier noch jemand.
                              Parallel habe ich noch mal wieder den s55 bestellt, falls das mit den 2 in 1 nichts werden sollte.
                                misteriobroker last edited by
                                Hallo nochmal,
                                Habe es nun geschafft und die 1.10.3 installiert.
                                Was ist denn nun genau der nächste Step um die Räume angezeigt zu bekommen?
                                Der Reiter rooms fehlt weiterhin.
                                Grüße Kai
                                  dirkhe Developer @misteriobroker last edited by
                                  @misteriobroker Erstmal get_room_mapping über send command einegeben. Da muss eine Antwort kommen. Normalerweise macht der Adapter das alleine. Vl. auch nochmal starten
                                    Hab jetzt gesehen der Ordner ist da.
                                    Ohne was eingegeben zu haben sogar.
                                    Habe nun add rooms, load rooms und multiroom drinnen.
                                    Bei betätigen von load rooms passiert zumindest nix
                                      @misteriobroker Ja er probiert es 2 mal beim Start, einmal direkt und einmal 5 min. später nochmal... Da hat er dann bei dir geantwortet.
                                      Wenn du keine Räume hast, mußt du in die App gehen und die Räume benennen, habe ich weiter oben auch schon mal beschrieben. Wenn du das mit deine mihome app nicht kannst, mußt du manuell entweder mapindexes via probieren eingeben oder Koordinaten, steht aber auch alles weiter oben
                                        Hm habe den s50. Kann nix benennen.
                                        Habe bisher mit Flole alles ausgelesen und seit der 2008er Firmware is da alles tot.
                                        Wie genau kommt man da nun an Koordinaten🤔
                                        • haselchen
                                          haselchen Most Active last edited by haselchen
                                          @dirkhe
                                          Klink mich mal mit ein.
                                          Habe den Adapter von 1.1.2 auf die neueste Version geupdatet.
                                          Sauger ist nicht gerootet und kein Valetudo drauf.
                                          Zum Saugen wird die Mihome App benutzt.
                                          Nach dem Update habe ich bei Rooms ein Undefined Ordner?!
                                          Edit:
                                          Bei Response bekomme ich : "unknown_method"
                                            @misteriobroker Also entweder testen, wie weiter oben beschrieben oder du installierst dir die mihome app via Bluestacks und wireshark und dann must du halt den Datenverkehr mitschneiden. Dann gibt es mehrere Möglichkeiten, die traffic auszuwerten, mußt mal ein bisschen googeln. Das ist aber anspruchsvoll. Ich habe 1-2 Tage gebraucht, bis ich die Ergebnisse hatte.
                                            adapter entwicklung raumreinigung roborock test vacuum zeitplan
                                            67
                                            511
                                            104679
